Please pull u-boot-watchdog/master
Hi Tom,
please pull the following watchdog related patches:
---------------------------------------------------------------- - Update MAINTAINERS file (Stefan) - wdt-uclass.c: add a property u-boot, noautostart (Philippe) - armada_37xx: Probe driver also when watchdog is already running (Pali) - rti_wdt: Add 10% safety margin to clock frequency (Jan) ----------------------------------------------------------------
Here the Azure build, with only one unrelated issue (binman fiptool missing):
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=164&view=resu...
Thanks, Stefan
The following changes since commit 6d3c46ed0e230d999c3f20f7fd4f3a88c03b14ca:
Merge https://source.denx.de/u-boot/custodians/u-boot-sunxi (2022-03-05 20:46:55 -0500)
git@source.denx.de:u-boot/custodians/u-boot-watchdog.git
for you to fetch changes up to 817e153fe546c2da9df8e8affc94d12036815659:
watchdog: rti_wdt: Add 10% safety margin to clock frequency (2022-03-08 09:08:09 +0100)
---------------------------------------------------------------- Jan Kiszka (1): watchdog: rti_wdt: Add 10% safety margin to clock frequency
Pali Rohár (1): watchdog: armada_37xx: Probe driver also when watchdog is already running
Philippe Reynes (1): drivers: watchdog: wdt-uclass.c: add a property u-boot, noautostart
Stefan Roese (1): MAINTAINERS: Add watchdog maintainers entry
MAINTAINERS | 8 ++++++++ drivers/watchdog/armada-37xx-wdt.c | 17 +++-------------- drivers/watchdog/rti_wdt.c | 14 +++++++++++--- drivers/watchdog/wdt-uclass.c | 7 ++++++- 4 files changed, 28 insertions(+), 18 deletions(-)
Stefan Roese
