[PATCH] mtd: nand: omap_gpmc: Fix NAND in SPL for AM335x
AM335x uses a special driver "am335x_spl_bch.c" as SPL NAND loader. This driver expects 1 sector at a time ECC and doesn't work well with multi-sector ECC that was implemented in commit 04fcd2587321 ("mtd: rawnand: omap_gpmc: Fix BCH6/16 HW based correction")
Switch back to 1 sector at a time read/ECC.
Fixes: 04fcd2587321 ("mtd: rawnand: omap_gpmc: Fix BCH6/16 HW based correction") Signed-off-by: Roger Quadros rogerq@kernel.org --- drivers/mtd/nand/raw/omap_gpmc.c | 95 ++++++++++---------------------- 1 file changed, 29 insertions(+), 66 deletions(-)
diff --git a/drivers/mtd/nand/raw/omap_gpmc.c b/drivers/mtd/nand/raw/omap_gpmc.c index 1a5ed0de31..2d2d2c2b6d 100644 --- a/drivers/mtd/nand/raw/omap_gpmc.c +++ b/drivers/mtd/nand/raw/omap_gpmc.c @@ -293,7 +293,7 @@ static void __maybe_unused omap_enable_hwecc_bch(struct mtd_info *mtd, break; case OMAP_ECC_BCH8_CODE_HW: bch_type = 1; - nsectors = chip->ecc.steps; + nsectors = 1; if (mode == NAND_ECC_READ) { wr_mode = BCH_WRAPMODE_1; ecc_size0 = BCH8R_ECC_SIZE0; @@ -306,7 +306,7 @@ static void __maybe_unused omap_enable_hwecc_bch(struct mtd_info *mtd, break; case OMAP_ECC_BCH16_CODE_HW: bch_type = 0x2; - nsectors = chip->ecc.steps; + nsectors = 1; if (mode == NAND_ECC_READ) { wr_mode = 0x01; ecc_size0 = 52; /* ECC bits in nibbles per sector */ @@ -345,17 +345,16 @@ static void __maybe_unused omap_enable_hwecc_bch(struct mtd_info *mtd, }
/** - * _omap_calculate_ecc_bch - Generate BCH ECC bytes for one sector + * omap_calculate_ecc_bch - Generate BCH ECC bytes for one sector * @mtd: MTD device structure * @dat: The pointer to data on which ecc is computed * @ecc_code: The ecc_code buffer - * @sector: The sector number (for a multi sector page) * * Support calculating of BCH4/8/16 ECC vectors for one sector * within a page. Sector number is in @sector. */ -static int _omap_calculate_ecc_bch(struct mtd_info *mtd, const u8 *dat, - u8 *ecc_code, int sector) +static int omap_calculate_ecc_bch(struct mtd_info *mtd, const u8 *dat, + u8 *ecc_code) { struct nand_chip *chip = mtd_to_nand(mtd); struct omap_nand_info *info = nand_get_controller_data(chip); @@ -368,7 +367,7 @@ static int _omap_calculate_ecc_bch(struct mtd_info *mtd, const u8 *dat, case OMAP_ECC_BCH8_CODE_HW_DETECTION_SW: #endif case OMAP_ECC_BCH8_CODE_HW: - ptr = &gpmc_cfg->bch_result_0_3[sector].bch_result_x[3]; + ptr = &gpmc_cfg->bch_result_0_3[0].bch_result_x[3]; val = readl(ptr); ecc_code[i++] = (val >> 0) & 0xFF; ptr--; @@ -383,21 +382,21 @@ static int _omap_calculate_ecc_bch(struct mtd_info *mtd, const u8 *dat,
break; case OMAP_ECC_BCH16_CODE_HW: - val = readl(&gpmc_cfg->bch_result_4_6[sector].bch_result_x[2]); + val = readl(&gpmc_cfg->bch_result_4_6[0].bch_result_x[2]); ecc_code[i++] = (val >> 8) & 0xFF; ecc_code[i++] = (val >> 0) & 0xFF; - val = readl(&gpmc_cfg->bch_result_4_6[sector].bch_result_x[1]); + val = readl(&gpmc_cfg->bch_result_4_6[0].bch_result_x[1]); ecc_code[i++] = (val >> 24) & 0xFF; ecc_code[i++] = (val >> 16) & 0xFF; ecc_code[i++] = (val >> 8) & 0xFF; ecc_code[i++] = (val >> 0) & 0xFF; - val = readl(&gpmc_cfg->bch_result_4_6[sector].bch_result_x[0]); + val = readl(&gpmc_cfg->bch_result_4_6[0].bch_result_x[0]); ecc_code[i++] = (val >> 24) & 0xFF; ecc_code[i++] = (val >> 16) & 0xFF; ecc_code[i++] = (val >> 8) & 0xFF; ecc_code[i++] = (val >> 0) & 0xFF; for (j = 3; j >= 0; j--) { - val = readl(&gpmc_cfg->bch_result_0_3[sector].bch_result_x[j] + val = readl(&gpmc_cfg->bch_result_0_3[0].bch_result_x[j] ); ecc_code[i++] = (val >> 24) & 0xFF; ecc_code[i++] = (val >> 16) & 0xFF; @@ -431,22 +430,6 @@ static int _omap_calculate_ecc_bch(struct mtd_info *mtd, const u8 *dat, return 0; }
-/** - * omap_calculate_ecc_bch - ECC generator for 1 sector - * @mtd: MTD device structure - * @dat: The pointer to data on which ecc is computed - * @ecc_code: The ecc_code buffer - * - * Support calculating of BCH4/8/16 ECC vectors for one sector. This is used - * when SW based correction is required as ECC is required for one sector - * at a time. - */ -static int __maybe_unused omap_calculate_ecc_bch(struct mtd_info *mtd, - const u_char *dat, u_char *ecc_calc) -{ - return _omap_calculate_ecc_bch(mtd, dat, ecc_calc, 0); -} - static inline void omap_nand_read_buf(struct mtd_info *mtd, uint8_t *buf, int len) { struct nand_chip *chip = mtd_to_nand(mtd); @@ -572,34 +555,6 @@ static void omap_nand_read_prefetch(struct mtd_info *mtd, uint8_t *buf, int len)
#ifdef CONFIG_NAND_OMAP_ELM
-/** - * omap_calculate_ecc_bch_multi - Generate ECC for multiple sectors - * @mtd: MTD device structure - * @dat: The pointer to data on which ecc is computed - * @ecc_code: The ecc_code buffer - * - * Support calculating of BCH4/8/16 ecc vectors for the entire page in one go. - */ -static int omap_calculate_ecc_bch_multi(struct mtd_info *mtd, - const u_char *dat, u_char *ecc_calc) -{ - struct nand_chip *chip = mtd_to_nand(mtd); - int eccbytes = chip->ecc.bytes; - unsigned long nsectors; - int i, ret; - - nsectors = ((readl(&gpmc_cfg->ecc_config) >> 4) & 0x7) + 1; - for (i = 0; i < nsectors; i++) { - ret = _omap_calculate_ecc_bch(mtd, dat, ecc_calc, i); - if (ret) - return ret; - - ecc_calc += eccbytes; - } - - return 0; -} - /* * omap_reverse_list - re-orders list elements in reverse order [internal] * @list: pointer to start of list @@ -752,7 +707,6 @@ static int omap_read_page_bch(struct mtd_info *mtd, struct nand_chip *chip, { int i, eccsize = chip->ecc.size; int eccbytes = chip->ecc.bytes; - int ecctotal = chip->ecc.total; int eccsteps = chip->ecc.steps; uint8_t *p = buf; uint8_t *ecc_calc = chip->buffers->ecccalc; @@ -760,24 +714,30 @@ static int omap_read_page_bch(struct mtd_info *mtd, struct nand_chip *chip, uint32_t *eccpos = chip->ecc.layout->eccpos; uint8_t *oob = chip->oob_poi; uint32_t oob_pos; + u32 data_pos = 0;
/* oob area start */ oob_pos = (eccsize * eccsteps) + chip->ecc.layout->eccpos[0]; oob += chip->ecc.layout->eccpos[0];
- /* Enable ECC engine */ - chip->ecc.hwctl(mtd, NAND_ECC_READ); + for (i = 0; eccsteps; eccsteps--, i += eccbytes, p += eccsize, + oob += eccbytes) { + /* Enable ECC engine */ + chip->ecc.hwctl(mtd, NAND_ECC_READ);
- /* read entire page */ - chip->cmdfunc(mtd, NAND_CMD_RNDOUT, 0, -1); - chip->read_buf(mtd, buf, mtd->writesize); + /* read data */ + chip->cmdfunc(mtd, NAND_CMD_RNDOUT, data_pos, -1); + chip->read_buf(mtd, p, eccsize);
- /* read all ecc bytes from oob area */ - chip->cmdfunc(mtd, NAND_CMD_RNDOUT, oob_pos, -1); - chip->read_buf(mtd, oob, ecctotal); + /* read respective ecc from oob area */ + chip->cmdfunc(mtd, NAND_CMD_RNDOUT, oob_pos, -1); + chip->read_buf(mtd, oob, eccbytes); + /* read syndrome */ + chip->ecc.calculate(mtd, p, &ecc_calc[i]);
- /* Calculate ecc bytes */ - omap_calculate_ecc_bch_multi(mtd, buf, ecc_calc); + data_pos += eccsize; + oob_pos += eccbytes; + }
for (i = 0; i < chip->ecc.total; i++) ecc_code[i] = chip->oob_poi[eccpos[i]]; @@ -945,6 +905,7 @@ static int omap_select_ecc_scheme(struct nand_chip *nand, nand->ecc.hwctl = omap_enable_hwecc_bch; nand->ecc.correct = omap_correct_data_bch_sw; nand->ecc.calculate = omap_calculate_ecc_bch; + nand->ecc.steps = eccsteps; /* define ecc-layout */ ecclayout->eccbytes = nand->ecc.bytes * eccsteps; ecclayout->eccpos[0] = BADBLOCK_MARKER_LENGTH; @@ -987,6 +948,7 @@ static int omap_select_ecc_scheme(struct nand_chip *nand, nand->ecc.correct = omap_correct_data_bch; nand->ecc.calculate = omap_calculate_ecc_bch; nand->ecc.read_page = omap_read_page_bch; + nand->ecc.steps = eccsteps; /* define ecc-layout */ ecclayout->eccbytes = nand->ecc.bytes * eccsteps; for (i = 0; i < ecclayout->eccbytes; i++) @@ -1020,6 +982,7 @@ static int omap_select_ecc_scheme(struct nand_chip *nand, nand->ecc.correct = omap_correct_data_bch; nand->ecc.calculate = omap_calculate_ecc_bch; nand->ecc.read_page = omap_read_page_bch; + nand->ecc.steps = eccsteps; /* define ecc-layout */ ecclayout->eccbytes = nand->ecc.bytes * eccsteps; for (i = 0; i < ecclayout->eccbytes; i++)
base-commit: 9e53e45292ee2f1d9d2ccc59914b161bef9b10d7
Hi Roger
- _omap_calculate_ecc_bch - Generate BCH ECC bytes for one sector
- omap_calculate_ecc_bch - Generate BCH ECC bytes for one sector
- @mtd: MTD device structure
- @dat: The pointer to data on which ecc is computed
- @ecc_code: The ecc_code buffer
- @sector: The sector number (for a multi sector page)
- Support calculating of BCH4/8/16 ECC vectors for one sector
- within a page. Sector number is in @sector.
u8 *ecc_code)
- omap_calculate_ecc_bch - ECC generator for 1 sector
- Support calculating of BCH4/8/16 ECC vectors for one sector. This is used
- when SW based correction is required as ECC is required for one sector
- at a time.
- omap_calculate_ecc_bch_multi - Generate ECC for multiple sectors
- Support calculating of BCH4/8/16 ecc vectors for the entire page in one go.
int i, ret;
if (ret)
return ret;
- omap_reverse_list - re-orders list elements in reverse order [internal]
- @list: pointer to start of list
u32 data_pos = 0; /* oob area start */ oob_pos = (eccsize * eccsteps) + chip->ecc.layout->eccpos[0]; oob += chip->ecc.layout->eccpos[0];
oob += eccbytes) {
/* read data */
/* read syndrome */
} for (i = 0; i < chip->ecc.total; i++) ecc_code[i] = chip->oob_poi[eccpos[i]];
2.34.1
Let's wait on some tested-by
Michael
Works on my draco thuban AM335x based boards booting from NAND with ECC BCH8 code.
Tested-by: Enrico Leto enrico.leto@siemens.com
Thanks
-----Original Message----- From: Michael Nazzareno Trimarchi michael@amarulasolutions.com Sent: Saturday, November 25, 2023 2:07 PM To: Roger Quadros rogerq@kernel.org Cc: dario.binacchi@amarulasolutions.com; Schocher, Heiko (EXT) (DENX Software Engineering GmbH) hs@denx.de; Leto, Enrico (SI BP R&D ZG FW CCP) enrico.leto@siemens.com; trini@konsulko.com; praneeth@ti.com; nm@ti.com; vigneshr@ti.com; u-boot@lists.denx.de Subject: Re: [PATCH] mtd: nand: omap_gpmc: Fix NAND in SPL for AM335x
Hi Roger
*mtd,
u8 *ecc_code)
val =
- readl(&gpmc_cfg->bch_result_4_6[0].bch_result_x[2]); ecc_code[i++] = (val >> 8) & 0xFF; ecc_code[i++] = (val >> 0) & 0xFF;
val =
- readl(&gpmc_cfg->bch_result_4_6[0].bch_result_x[1]); ecc_code[i++] = (val >> 24) & 0xFF; ecc_code[i++] = (val >> 16) & 0xFF; ecc_code[i++] = (val >> 8) & 0xFF; ecc_code[i++] = (val >> 0) & 0xFF;
val =
- readl(&gpmc_cfg->bch_result_4_6[0].bch_result_x[0]); ecc_code[i++] = (val >> 24) & 0xFF; ecc_code[i++] = (val >> 16) & 0xFF; ecc_code[i++] = (val >> 8) & 0xFF; ecc_code[i++] = (val >> 0) & 0xFF; for (j = 3; j >= 0; j--) {
val =
- readl(&gpmc_cfg->bch_result_0_3[0].bch_result_x[j] ); ecc_code[i++] = (val >> 24) & 0xFF; ecc_code[i++] = (val >> 16) & 0xFF; @@ -431,22
u8 *dat,
is used
sector
- at a time.
go.
int i, ret;
if (ret)
return ret;
*chip,
oob += eccbytes) {
/* read data */
/* read syndrome */
} for (i = 0; i < chip->ecc.total; i++) ecc_code[i] = chip->oob_poi[eccpos[i]]; @@ -945,6
nand_chip *nand,
2.34.1
Michael
Hi dario
Thanks
Hi Roger
*mtd,
u8 *ecc_code)
val =
val =
val =
val =
u8 *dat,
is used
sector
- at a time.
go.
int i, ret;
if (ret)
return ret;
*chip,
oob += eccbytes) {
/* read data */
/* read syndrome */
nand_chip *nand,
2.34.1
I'm not a fan of this patch but we need to cover this regression
Michael
Michael
On 27/11/2023 16:43, Michael Nazzareno Trimarchi wrote:
Hi dario
Thanks
Hi Roger
*mtd,
u8 *ecc_code)
val =
val =
val =
val =
u8 *dat,
is used
sector
- at a time.
go.
int i, ret;
if (ret)
return ret;
*chip,
oob += eccbytes) {
/* read data */
/* read syndrome */
nand_chip *nand,
2.34.1
Is it because of the performance hit for non AM335x platforms? Any suggestions for improvement?
I'm glad to see this fixed. My question is, can we abstract this slightly as I assume there's a performance hit on the newer SoCs that support more than one sector at a time for ECC and I assume it's just am335x and related that don't support the feature. Thanks.
Hi Tom,
It looks like that the ELM driver (omap_elm.c) is not yet ready for multi-sector setup yet. I will need more time to test the multi-sector implementation.
On Thu, Dec 07, 2023 at 04:22:42PM +0200, Roger Quadros wrote:
Hi Tom,
Ah, thanks. Lets make that clearer in the commit message of the next spin please.
Hello Roger,
Based on this commit and with the (rebased) patchset from Enrico:
https://lists.denx.de/pipermail/u-boot/2023-November/536793.html
I can confirm, that the draco thuban board now boots again from NAND.
Tested-by: Heiko Schocher hs@denx.de
Thanks!
bye, Heiko
Azure pipeline build fails. Not because of this patch though. https://dev.azure.com/u-boot/u-boot/_build/results?buildId=7479&view=log...
if (mode == NAND_ECC_READ) { wr_mode = BCH_WRAPMODE_1; ecc_size0 = BCH8R_ECC_SIZE0;nsectors = 1;
if (mode == NAND_ECC_READ) { wr_mode = 0x01; ecc_size0 = 52; /* ECC bits in nibbles per sector */nsectors = 1;
u8 *ecc_code)
val = readl(ptr); ecc_code[i++] = (val >> 0) & 0xFF; ptr--;ptr = &gpmc_cfg->bch_result_0_3[0].bch_result_x[3];
break;
ecc_code[i++] = (val >> 8) & 0xFF; ecc_code[i++] = (val >> 0) & 0xFF;val = readl(&gpmc_cfg->bch_result_4_6[0].bch_result_x[2]);
ecc_code[i++] = (val >> 24) & 0xFF; ecc_code[i++] = (val >> 16) & 0xFF; ecc_code[i++] = (val >> 8) & 0xFF; ecc_code[i++] = (val >> 0) & 0xFF;val = readl(&gpmc_cfg->bch_result_4_6[0].bch_result_x[1]);
ecc_code[i++] = (val >> 24) & 0xFF; ecc_code[i++] = (val >> 16) & 0xFF; ecc_code[i++] = (val >> 8) & 0xFF; ecc_code[i++] = (val >> 0) & 0xFF; for (j = 3; j >= 0; j--) {val = readl(&gpmc_cfg->bch_result_4_6[0].bch_result_x[0]);
- at a time.
- int i, ret;
if (ret)
return ret;
u32 data_pos = 0;
- for (i = 0; eccsteps; eccsteps--, i += eccbytes, p += eccsize,
oob += eccbytes) {
/* read data */
/* read syndrome */
/* define ecc-layout */ ecclayout->eccbytes = nand->ecc.bytes * eccsteps; ecclayout->eccpos[0] = BADBLOCK_MARKER_LENGTH;nand->ecc.steps = eccsteps;
/* define ecc-layout */ ecclayout->eccbytes = nand->ecc.bytes * eccsteps; for (i = 0; i < ecclayout->eccbytes; i++)nand->ecc.steps = eccsteps;
Hi
My comment below
u8 *ecc_code)
This should be as before static int __maybe_unused omap_calculate_ecc_bch(struct mtd_info *mtd,
- at a time.
If you remove you should stay with it
int i, ret;
if (ret)
return ret;
oob += eccbytes) {
/* read data */
/* read syndrome */
-- cheers, -roger
On 08/12/2023 10:41, Michael Nazzareno Trimarchi wrote:
Hi
My comment below
u8 *ecc_code)
- at a time.
Thanks. So the issue was indeed introduced by this patch.
I see a lot of #ifdeffery in this driver. Is it recommended in general to move to if defined(IS_ENABLED(CONFIG_*)) instead and get rid of __maybe_unused?
int i, ret;
if (ret)
return ret;
oob += eccbytes) {
/* read data */
/* read syndrome */
-- cheers, -roger
Er? The failure is just above the end of the page (which the link opens to for me) and is: +drivers/mtd/nand/raw/omap_gpmc.c:356:12: error: 'omap_calculate_ecc_bch' defined but not used [-Werror=unused-function] + 356 | static int omap_calculate_ecc_bch(struct mtd_info *mtd, const u8 *dat, + | ^~~~~~~~~~~~~~~~~~~~~~ +cc1: all warnings being treated as errors
And is this patch :)
Hi Roger
If the changes impact only one family can you just restrict it to those family?
Michael
u8 *ecc_code)
- at a time.
int i, ret;
if (ret)
return ret;
oob += eccbytes) {
/* read data */
/* read syndrome */
2.34.1
participants (5)
Heiko Schocher
Leto, Enrico
Roger Quadros
