[U-Boot] [PATCH v3 0/8] Add support for Espresso7420 board
Changes since v2: - changes based on comments from Simon Glass and Minkyu Kang.
This patch series add support for Espresso7420 board. This board is the development/evaluation platform for Exynos7420 SoC. The SoC is composed of quad Cortex-A57 block, a quad Cortex-A53 block and various other peripherals. The board includes multiple components such as the EMMC/Codec and support multiple interconnect interfaces including HDMI and USB.
The first two patches add Exynos7420 pinctrl driver support which was initially posted seperatly but now included in this series. Thanks to Simon Glass and Minkyu Kang for their review. The rest of the patches add Exynos7420 clock driver support, minor changes in the S5P serial driver, Exynos7420 SoC support and Espresso7420 board support.
Thomas Abraham (8): pinctrl: add the DM_UC_FLAG_SEQ_ALIAS flag for numbering the devices pinctrl: Add pinctrl driver support for Exynos7420 SoC clk: exynos: add clock driver for Exynos7420 Soc serial: s5p: get the port id number from the alias of the device node serial: s5p: use clock api to get clock rate arm: exynos: realign the code to allow support for newer 64-bit platforms arm: exynos: add support for Exynos7420 SoC board: samsung: add initial Espresso7420 board support
arch/arm/Kconfig | 1 - arch/arm/dts/Makefile | 1 + arch/arm/dts/exynos7420-espresso7420.dts | 24 +++ arch/arm/dts/exynos7420.dtsi | 83 ++++++++++ arch/arm/mach-exynos/Kconfig | 61 +++++++- arch/arm/mach-exynos/Makefile | 6 +- arch/arm/mach-exynos/include/mach/cpu.h | 2 +- arch/arm/mach-exynos/include/mach/gpio.h | 2 +- arch/arm/mach-exynos/mmu-arm64.c | 35 ++++ arch/arm/mach-exynos/soc.c | 10 + board/samsung/common/board.c | 10 +- board/samsung/espresso7420/Kconfig | 16 ++ board/samsung/espresso7420/MAINTAINERS | 5 + board/samsung/espresso7420/Makefile | 10 + board/samsung/espresso7420/espresso7420.c | 16 ++ configs/arndale_defconfig | 1 + configs/espresso7420_defconfig | 9 + configs/odroid-xu3_defconfig | 1 + configs/odroid_defconfig | 1 + configs/origen_defconfig | 1 + configs/peach-pi_defconfig | 1 + configs/peach-pit_defconfig | 1 + configs/s5pc210_universal_defconfig | 1 + configs/smdk5250_defconfig | 1 + configs/smdk5420_defconfig | 1 + configs/smdkv310_defconfig | 1 + configs/snow_defconfig | 1 + configs/spring_defconfig | 1 + configs/trats2_defconfig | 1 + configs/trats_defconfig | 1 + drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/exynos/Kconfig | 18 ++ drivers/clk/exynos/Makefile | 9 + drivers/clk/exynos/clk-exynos7420.c | 236 +++++++++++++++++++++++++++ drivers/clk/exynos/clk-pll.c | 33 ++++ drivers/clk/exynos/clk-pll.h | 9 + drivers/pinctrl/Kconfig | 1 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/exynos/Kconfig | 10 + drivers/pinctrl/exynos/Makefile | 9 + drivers/pinctrl/exynos/pinctrl-exynos.c | 141 ++++++++++++++++ drivers/pinctrl/exynos/pinctrl-exynos.h | 77 +++++++++ drivers/pinctrl/exynos/pinctrl-exynos7420.c | 120 ++++++++++++++ drivers/pinctrl/pinctrl-uclass.c | 1 + drivers/serial/serial_s5p.c | 19 ++- include/configs/espresso7420.h | 34 ++++ include/configs/exynos7420-common.h | 113 +++++++++++++ include/dt-bindings/clock/exynos7420-clk.h | 207 +++++++++++++++++++++++ 49 files changed, 1334 insertions(+), 11 deletions(-) create mode 100644 arch/arm/dts/exynos7420-espresso7420.dts create mode 100644 arch/arm/dts/exynos7420.dtsi create mode 100644 arch/arm/mach-exynos/mmu-arm64.c create mode 100644 board/samsung/espresso7420/Kconfig create mode 100644 board/samsung/espresso7420/MAINTAINERS create mode 100644 board/samsung/espresso7420/Makefile create mode 100644 board/samsung/espresso7420/espresso7420.c create mode 100644 configs/espresso7420_defconfig create mode 100644 drivers/clk/exynos/Kconfig create mode 100644 drivers/clk/exynos/Makefile create mode 100644 drivers/clk/exynos/clk-exynos7420.c create mode 100644 drivers/clk/exynos/clk-pll.c create mode 100644 drivers/clk/exynos/clk-pll.h create mode 100644 drivers/pinctrl/exynos/Kconfig create mode 100644 drivers/pinctrl/exynos/Makefile create mode 100644 drivers/pinctrl/exynos/pinctrl-exynos.c create mode 100644 drivers/pinctrl/exynos/pinctrl-exynos.h create mode 100644 drivers/pinctrl/exynos/pinctrl-exynos7420.c create mode 100644 include/configs/espresso7420.h create mode 100644 include/configs/exynos7420-common.h create mode 100644 include/dt-bindings/clock/exynos7420-clk.h
It is possible to have multiple pin controllers in the system. Use the DM_UC_FLAG_SEQ_ALIAS flag so that the pinctrl instances are assigned a sequence number.
Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Simon Glass sjg@chromium.org Signed-off-by: Thomas Abraham thomas.ab@samsung.com Reviewed-by: Simon Glass sjg@chromium.org --- drivers/pinctrl/pinctrl-uclass.c | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/drivers/pinctrl/pinctrl-uclass.c b/drivers/pinctrl/pinctrl-uclass.c index ccc5d30..fd04b26 100644 --- a/drivers/pinctrl/pinctrl-uclass.c +++ b/drivers/pinctrl/pinctrl-uclass.c @@ -287,5 +287,6 @@ static int pinctrl_post_bind(struct udevice *dev) UCLASS_DRIVER(pinctrl) = { .id = UCLASS_PINCTRL, .post_bind = pinctrl_post_bind, + .flags = DM_UC_FLAG_SEQ_ALIAS, .name = "pinctrl", };
Add pinctrl driver support for Samsung's Exynos7420 SoC. The changes have been split into Exynos7420 specific and common Exynos specific portions so that this implementation is reusable on other Exynos SoCs as well.
The Exynos pinctrl driver supports only device tree based pin configuration. The bindings used are similar to the ones used in the linux kernel.
Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Simon Glass sjg@chromium.org Cc: Minkyu Kang mk7.kang@samsung.com Signed-off-by: Thomas Abraham thomas.ab@samsung.com Reviewed-by: Simon Glass sjg@chromium.org Acked-by: Minkyu Kang mk7.kang@samsung.com --- drivers/pinctrl/Kconfig | 1 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/exynos/Kconfig | 10 ++ drivers/pinctrl/exynos/Makefile | 9 ++ drivers/pinctrl/exynos/pinctrl-exynos.c | 141 +++++++++++++++++++++++++++ drivers/pinctrl/exynos/pinctrl-exynos.h | 77 +++++++++++++++ drivers/pinctrl/exynos/pinctrl-exynos7420.c | 120 +++++++++++++++++++++++ 7 files changed, 359 insertions(+), 0 deletions(-) create mode 100644 drivers/pinctrl/exynos/Kconfig create mode 100644 drivers/pinctrl/exynos/Makefile create mode 100644 drivers/pinctrl/exynos/pinctrl-exynos.c create mode 100644 drivers/pinctrl/exynos/pinctrl-exynos.h create mode 100644 drivers/pinctrl/exynos/pinctrl-exynos7420.c
diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index 2a69bab..bdf8931 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -145,5 +145,6 @@ endif
source "drivers/pinctrl/nxp/Kconfig" source "drivers/pinctrl/uniphier/Kconfig" +source "drivers/pinctrl/exynos/Kconfig"
endmenu diff --git a/drivers/pinctrl/Makefile b/drivers/pinctrl/Makefile index 37dc904..19beb04 100644 --- a/drivers/pinctrl/Makefile +++ b/drivers/pinctrl/Makefile @@ -11,3 +11,4 @@ obj-$(CONFIG_PINCTRL_SANDBOX) += pinctrl-sandbox.o
obj-$(CONFIG_PINCTRL_UNIPHIER) += uniphier/ obj-$(CONFIG_PIC32_PINCTRL) += pinctrl_pic32.o +obj-$(CONFIG_PINCTRL_EXYNOS) += exynos/ diff --git a/drivers/pinctrl/exynos/Kconfig b/drivers/pinctrl/exynos/Kconfig new file mode 100644 index 0000000..84b6aaa --- /dev/null +++ b/drivers/pinctrl/exynos/Kconfig @@ -0,0 +1,10 @@ +config PINCTRL_EXYNOS + bool + +config PINCTRL_EXYNOS7420 + bool "Samsung Exynos7420 pinctrl driver" + depends on ARCH_EXYNOS && PINCTRL_FULL + select PINCTRL_EXYNOS + help + Support pin multiplexing and pin configuration control on + Samsung's Exynos7420 SoC. diff --git a/drivers/pinctrl/exynos/Makefile b/drivers/pinctrl/exynos/Makefile new file mode 100644 index 0000000..d9b941a --- /dev/null +++ b/drivers/pinctrl/exynos/Makefile @@ -0,0 +1,9 @@ +# +# Copyright (C) 2016 Samsung Electronics +# Thomas Abraham thomas.ab@samsung.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-$(CONFIG_PINCTRL_EXYNOS) += pinctrl-exynos.o +obj-$(CONFIG_PINCTRL_EXYNOS7420) += pinctrl-exynos7420.o diff --git a/drivers/pinctrl/exynos/pinctrl-exynos.c b/drivers/pinctrl/exynos/pinctrl-exynos.c new file mode 100644 index 0000000..a28405f --- /dev/null +++ b/drivers/pinctrl/exynos/pinctrl-exynos.c @@ -0,0 +1,141 @@ +/* + * Exynos pinctrl driver common code. + * Copyright (C) 2016 Samsung Electronics + * Thomas Abraham thomas.ab@samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <asm/io.h> +#include "pinctrl-exynos.h" + +DECLARE_GLOBAL_DATA_PTR; + +/** + * exynos_pinctrl_setup_peri: setup pinctrl for a peripheral. + * conf: soc specific pin configuration data array + * num_conf: number of configurations in the conf array. + * base: base address of the pin controller. + */ +void exynos_pinctrl_setup_peri(struct exynos_pinctrl_config_data *conf, + unsigned int num_conf, unsigned long base) +{ + unsigned int idx, val; + + for (idx = 0; idx < num_conf; idx++) { + val = readl(base + conf[idx].offset); + val &= ~(conf[idx].mask); + val |= conf[idx].value; + writel(val, base + conf[idx].offset); + } +} + +/* given a pin-name, return the address of pin config registers */ +static unsigned long pin_to_bank_base(struct udevice *dev, const char *pin_name, + u32 *pin) +{ + struct exynos_pinctrl_priv *priv = dev_get_priv(dev); + const struct samsung_pin_ctrl *pin_ctrl = priv->pin_ctrl; + const struct samsung_pin_bank_data *bank_data = pin_ctrl->pin_banks; + u32 nr_banks = pin_ctrl->nr_banks, idx = 0; + char bank[10]; + + /* + * The format of the pin name is <bank name>-<pin_number>. + * Example: gpa0-4 (gpa0 is the bank name and 4 is the pin number. + */ + while (pin_name[idx] != '-') { + bank[idx] = pin_name[idx]; + idx++; + } + bank[idx] = '\0'; + *pin = pin_name[++idx] - '0'; + + /* lookup the pin bank data using the pin bank name */ + for (idx = 0; idx < nr_banks; idx++) + if (!strcmp(bank, bank_data[idx].name)) + break; + + return priv->base + bank_data[idx].offset; +} + +/** + * exynos_pinctrl_set_state: configure a pin state. + * dev: the pinctrl device to be configured. + * config: the state to be configured. + */ +int exynos_pinctrl_set_state(struct udevice *dev, struct udevice *config) +{ + const void *fdt = gd->fdt_blob; + int node = config->of_offset; + unsigned int count, idx, pin_num, ret; + unsigned int pinfunc, pinpud, pindrv; + unsigned long reg, value; + const char *name; + + /* + * refer to the following document for the pinctrl bindings + * linux/Documentation/devicetree/bindings/pinctrl/samsung-pinctrl.txt + */ + count = fdt_count_strings(fdt, node, "samsung,pins"); + if (count <= 0) + return -EINVAL; + + pinfunc = fdtdec_get_int(fdt, node, "samsung,pin-function", -1); + pinpud = fdtdec_get_int(fdt, node, "samsung,pin-pud", -1); + pindrv = fdtdec_get_int(fdt, node, "samsung,pin-drv", -1); + + for (idx = 0; idx < count; idx++) { + ret = fdt_get_string_index(fdt, node, "samsung,pins", + idx, &name); + if (ret < 0) + continue; + reg = pin_to_bank_base(dev, name, &pin_num); + + if (pinfunc != -1) { + value = readl(reg + PIN_CON); + value &= ~(0xf << (pin_num << 2)); + value |= (pinfunc << (pin_num << 2)); + writel(value, reg + PIN_CON); + } + + if (pinpud != -1) { + value = readl(reg + PIN_PUD); + value &= ~(0x3 << (pin_num << 1)); + value |= (pinpud << (pin_num << 1)); + writel(value, reg + PIN_PUD); + } + + if (pindrv != -1) { + value = readl(reg + PIN_DRV); + value &= ~(0x3 << (pin_num << 1)); + value |= (pindrv << (pin_num << 1)); + writel(value, reg + PIN_DRV); + } + } + + return 0; +} + +int exynos_pinctrl_probe(struct udevice *dev) +{ + struct exynos_pinctrl_priv *priv; + fdt_addr_t base; + + priv = dev_get_priv(dev); + if (!priv) + return -EINVAL; + + base = dev_get_addr(dev); + if (base == FDT_ADDR_T_NONE) + return -EINVAL; + + priv->base = base; + priv->pin_ctrl = (struct samsung_pin_ctrl *)dev_get_driver_data(dev) + + dev->req_seq; + + return 0; +} diff --git a/drivers/pinctrl/exynos/pinctrl-exynos.h b/drivers/pinctrl/exynos/pinctrl-exynos.h new file mode 100644 index 0000000..abd582d --- /dev/null +++ b/drivers/pinctrl/exynos/pinctrl-exynos.h @@ -0,0 +1,77 @@ +/* + * Exynos pinctrl driver header. + * Copyright (C) 2016 Samsung Electronics + * Thomas Abraham thomas.ab@samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __PINCTRL_EXYNOS_H_ +#define __PINCTRL_EXYNOS__H_ + +#define PIN_CON 0x00 /* Offset of pin function register */ +#define PIN_DAT 0x04 /* Offset of pin data register */ +#define PIN_PUD 0x08 /* Offset of pin pull up/down config register */ +#define PIN_DRV 0x0C /* Offset of pin drive strength register */ + +/** + * struct samsung_pin_bank_data: represent a controller pin-bank data. + * @offset: starting offset of the pin-bank registers. + * @nr_pins: number of pins included in this bank. + * @name: name to be prefixed for each pin in this pin bank. + */ +struct samsung_pin_bank_data { + u32 offset; + u8 nr_pins; + const char *name; +}; + +#define EXYNOS_PIN_BANK(pins, reg, id) \ + { \ + .offset = reg, \ + .nr_pins = pins, \ + .name = id \ + } + +/** + * struct samsung_pin_ctrl: represent a pin controller. + * @pin_banks: list of pin banks included in this controller. + * @nr_banks: number of pin banks. + */ +struct samsung_pin_ctrl { + const struct samsung_pin_bank_data *pin_banks; + u32 nr_banks; +}; + +/** + * struct exynos_pinctrl_priv: exynos pin controller driver private data + * @pin_ctrl: pin controller bank information. + * @base: base address of the pin controller instance. + * @num_banks: number of pin banks included in the pin controller. + */ +struct exynos_pinctrl_priv { + const struct samsung_pin_ctrl *pin_ctrl; + unsigned long base; + int num_banks; +}; + +/** + * struct exynos_pinctrl_config_data: configuration for a peripheral. + * @offset: offset of the config registers in the controller. + * @mask: value of the register to be masked with. + * @value: new value to be programmed. + */ +struct exynos_pinctrl_config_data { + const unsigned int offset; + const unsigned int mask; + const unsigned int value; +}; + + +void exynos_pinctrl_setup_peri(struct exynos_pinctrl_config_data *conf, + unsigned int num_conf, unsigned long base); +int exynos_pinctrl_set_state(struct udevice *dev, + struct udevice *config); +int exynos_pinctrl_probe(struct udevice *dev); + +#endif /* __PINCTRL_EXYNOS_H_ */ diff --git a/drivers/pinctrl/exynos/pinctrl-exynos7420.c b/drivers/pinctrl/exynos/pinctrl-exynos7420.c new file mode 100644 index 0000000..8ae5ce7 --- /dev/null +++ b/drivers/pinctrl/exynos/pinctrl-exynos7420.c @@ -0,0 +1,120 @@ +/* + * Exynos7420 pinctrl driver. + * Copyright (C) 2016 Samsung Electronics + * Thomas Abraham thomas.ab@samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <asm/io.h> +#include <dm/pinctrl.h> +#include <dm/root.h> +#include <fdtdec.h> +#include <asm/arch/pinmux.h> +#include "pinctrl-exynos.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define GPD1_OFFSET 0xc0 + +static struct exynos_pinctrl_config_data serial2_conf[] = { + { + .offset = GPD1_OFFSET + PIN_CON, + .mask = 0x00ff0000, + .value = 0x00220000, + }, { + .offset = GPD1_OFFSET + PIN_PUD, + .mask = 0x00000f00, + .value = 0x00000f00, + }, +}; + +static int exynos7420_pinctrl_request(struct udevice *dev, int peripheral, + int flags) +{ + struct exynos_pinctrl_priv *priv = dev_get_priv(dev); + unsigned long base = priv->base; + + switch (PERIPH_ID_UART2) { + case PERIPH_ID_UART2: + exynos_pinctrl_setup_peri(serial2_conf, + ARRAY_SIZE(serial2_conf), base); + break; + default: + return -ENODEV; + } + + return 0; +} + +static struct pinctrl_ops exynos7420_pinctrl_ops = { + .set_state = exynos_pinctrl_set_state, + .request = exynos7420_pinctrl_request, +}; + +/* pin banks of Exynos7420 pin-controller - BUS0 */ +static const struct samsung_pin_bank_data exynos7420_pin_banks0[] = { + EXYNOS_PIN_BANK(5, 0x000, "gpb0"), + EXYNOS_PIN_BANK(8, 0x020, "gpc0"), + EXYNOS_PIN_BANK(2, 0x040, "gpc1"), + EXYNOS_PIN_BANK(6, 0x060, "gpc2"), + EXYNOS_PIN_BANK(8, 0x080, "gpc3"), + EXYNOS_PIN_BANK(4, 0x0a0, "gpd0"), + EXYNOS_PIN_BANK(6, 0x0c0, "gpd1"), + EXYNOS_PIN_BANK(8, 0x0e0, "gpd2"), + EXYNOS_PIN_BANK(5, 0x100, "gpd4"), + EXYNOS_PIN_BANK(4, 0x120, "gpd5"), + EXYNOS_PIN_BANK(6, 0x140, "gpd6"), + EXYNOS_PIN_BANK(3, 0x160, "gpd7"), + EXYNOS_PIN_BANK(2, 0x180, "gpd8"), + EXYNOS_PIN_BANK(2, 0x1a0, "gpg0"), + EXYNOS_PIN_BANK(4, 0x1c0, "gpg3"), +}; + +/* pin banks of Exynos7420 pin-controller - FSYS0 */ +static const struct samsung_pin_bank_data exynos7420_pin_banks1[] = { + EXYNOS_PIN_BANK(7, 0x000, "gpr4"), +}; + +/* pin banks of Exynos7420 pin-controller - FSYS1 */ +static const struct samsung_pin_bank_data exynos7420_pin_banks2[] = { + EXYNOS_PIN_BANK(4, 0x000, "gpr0"), + EXYNOS_PIN_BANK(8, 0x020, "gpr1"), + EXYNOS_PIN_BANK(5, 0x040, "gpr2"), + EXYNOS_PIN_BANK(8, 0x060, "gpr3"), +}; + +const struct samsung_pin_ctrl exynos7420_pin_ctrl[] = { + { + /* pin-controller instance BUS0 data */ + .pin_banks = exynos7420_pin_banks0, + .nr_banks = ARRAY_SIZE(exynos7420_pin_banks0), + }, { + /* pin-controller instance FSYS0 data */ + .pin_banks = exynos7420_pin_banks1, + .nr_banks = ARRAY_SIZE(exynos7420_pin_banks1), + }, { + /* pin-controller instance FSYS1 data */ + .pin_banks = exynos7420_pin_banks2, + .nr_banks = ARRAY_SIZE(exynos7420_pin_banks2), + }, +}; + +static const struct udevice_id exynos7420_pinctrl_ids[] = { + { .compatible = "samsung,exynos7420-pinctrl", + .data = (ulong)exynos7420_pin_ctrl }, + { } +}; + +U_BOOT_DRIVER(pinctrl_exynos7420) = { + .name = "pinctrl_exynos7420", + .id = UCLASS_PINCTRL, + .of_match = exynos7420_pinctrl_ids, + .priv_auto_alloc_size = sizeof(struct exynos_pinctrl_priv), + .ops = &exynos7420_pinctrl_ops, + .probe = exynos_pinctrl_probe, + .flags = DM_FLAG_PRE_RELOC +};
Add a clock driver for Exynos7420 SoC. There are about 25 clock controller blocks in Exynos7420 out of which support for topc, top0 and peric1 blocks are added in this initial version of the driver.
Cc: Minkyu Kang mk7.kang@samsung.com Cc: Simon Glass sjg@chromium.org Signed-off-by: Thomas Abraham thomas.ab@samsung.com --- drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/exynos/Kconfig | 18 ++ drivers/clk/exynos/Makefile | 9 + drivers/clk/exynos/clk-exynos7420.c | 236 ++++++++++++++++++++++++++++ drivers/clk/exynos/clk-pll.c | 33 ++++ drivers/clk/exynos/clk-pll.h | 9 + include/dt-bindings/clock/exynos7420-clk.h | 207 ++++++++++++++++++++++++ 8 files changed, 514 insertions(+), 0 deletions(-) create mode 100644 drivers/clk/exynos/Kconfig create mode 100644 drivers/clk/exynos/Makefile create mode 100644 drivers/clk/exynos/clk-exynos7420.c create mode 100644 drivers/clk/exynos/clk-pll.c create mode 100644 drivers/clk/exynos/clk-pll.h create mode 100644 include/dt-bindings/clock/exynos7420-clk.h
diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index a98b74b..6eee8eb 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -21,5 +21,6 @@ config SPL_CLK used as U-Boot proper.
source "drivers/clk/uniphier/Kconfig" +source "drivers/clk/exynos/Kconfig"
endmenu diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index c51db15..81fe600 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -11,3 +11,4 @@ obj-$(CONFIG_ROCKCHIP_RK3288) += clk_rk3288.o obj-$(CONFIG_SANDBOX) += clk_sandbox.o obj-$(CONFIG_MACH_PIC32) += clk_pic32.o obj-$(CONFIG_CLK_UNIPHIER) += uniphier/ +obj-$(CONFIG_CLK_EXYNOS) += exynos/ diff --git a/drivers/clk/exynos/Kconfig b/drivers/clk/exynos/Kconfig new file mode 100644 index 0000000..eb0efa9 --- /dev/null +++ b/drivers/clk/exynos/Kconfig @@ -0,0 +1,18 @@ +config CLK_EXYNOS + bool + select CLK + help + This enables support for common clock driver API on Samsung + Exynos SoCs. + +menu "Clock drivers for Exynos SoCs" + depends on CLK_EXYNOS + +config CLK_EXYNOS7420 + bool "Clock driver for Samsung's Exynos7420 SoC" + default y + help + This enables common clock driver support for platforms based + on Samsung Exynos7420 SoC. + +endmenu diff --git a/drivers/clk/exynos/Makefile b/drivers/clk/exynos/Makefile new file mode 100644 index 0000000..1df10fe --- /dev/null +++ b/drivers/clk/exynos/Makefile @@ -0,0 +1,9 @@ +# +# Copyright (C) 2016 Samsung Electronics +# Thomas Abraham thomas.ab@samsung.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += clk-pll.o +obj-$(CONFIG_CLK_EXYNOS7420) += clk-exynos7420.o diff --git a/drivers/clk/exynos/clk-exynos7420.c b/drivers/clk/exynos/clk-exynos7420.c new file mode 100644 index 0000000..bf5d0e6 --- /dev/null +++ b/drivers/clk/exynos/clk-exynos7420.c @@ -0,0 +1,236 @@ +/* + * Samsung Exynos7420 clock driver. + * Copyright (C) 2016 Samsung Electronics + * Thomas Abraham thomas.ab@samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <clk.h> +#include <asm/io.h> +#include <dt-bindings/clock/exynos7420-clk.h> +#include "clk-pll.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define DIVIDER(reg, shift, mask) \ + (((readl(reg) >> shift) & mask) + 1) + +/* CMU TOPC block device structure */ +struct exynos7420_clk_cmu_topc { + unsigned int rsvd1[68]; + unsigned int bus0_pll_con[2]; + unsigned int rsvd2[2]; + unsigned int bus1_pll_con[2]; + unsigned int rsvd3[54]; + unsigned int mux_sel[6]; + unsigned int rsvd4[250]; + unsigned int div[4]; +}; + +/* CMU TOP0 block device structure */ +struct exynos7420_clk_cmu_top0 { + unsigned int rsvd0[128]; + unsigned int mux_sel[7]; + unsigned int rsvd1[261]; + unsigned int div_peric[5]; +}; + +/** + * struct exynos7420_clk_topc_priv - private data for CMU topc clock driver. + * + * @topc: base address of the memory mapped CMU TOPC controller. + * @fin_freq: frequency of the Oscillator clock. + * @sclk_bus0_pll_a: frequency of sclk_bus0_pll_a clock. + * @sclk_bus1_pll_a: frequency of sclk_bus1_pll_a clock. + */ +struct exynos7420_clk_topc_priv { + struct exynos7420_clk_cmu_topc *topc; + unsigned long fin_freq; + unsigned long sclk_bus0_pll_a; + unsigned long sclk_bus1_pll_a; +}; + +/** + * struct exynos7420_clk_top0_priv - private data for CMU top0 clock driver. + * + * @top0: base address of the memory mapped CMU TOP0 controller. + * @mout_top0_bus0_pll_half: frequency of mout_top0_bus0_pll_half clock + * @sclk_uart2: frequency of sclk_uart2 clock. + */ +struct exynos7420_clk_top0_priv { + struct exynos7420_clk_cmu_top0 *top0; + unsigned long mout_top0_bus0_pll_half; + unsigned long sclk_uart2; +}; + +static ulong exynos7420_topc_get_periph_rate(struct udevice *dev, int periph) +{ + struct exynos7420_clk_topc_priv *priv = dev_get_priv(dev); + + switch (periph) { + case DOUT_SCLK_BUS0_PLL: + case SCLK_BUS0_PLL_A: + case SCLK_BUS0_PLL_B: + return priv->sclk_bus0_pll_a; + case DOUT_SCLK_BUS1_PLL: + case SCLK_BUS1_PLL_A: + case SCLK_BUS1_PLL_B: + return priv->sclk_bus1_pll_a; + default: + return 0; + } +} + +static struct clk_ops exynos7420_clk_topc_ops = { + .get_periph_rate = exynos7420_topc_get_periph_rate, +}; + +static int exynos7420_clk_topc_probe(struct udevice *dev) +{ + struct exynos7420_clk_topc_priv *priv = dev_get_priv(dev); + struct exynos7420_clk_cmu_topc *topc; + struct udevice *clk_dev; + unsigned long rate; + fdt_addr_t base; + int ret; + + base = dev_get_addr(dev); + if (base == FDT_ADDR_T_NONE) + return -EINVAL; + + topc = (struct exynos7420_clk_cmu_topc *)base; + priv->topc = topc; + + ret = clk_get_by_index(dev, 0, &clk_dev); + if (ret >= 0) + priv->fin_freq = clk_get_rate(clk_dev); + + rate = pll145x_get_rate(&topc->bus0_pll_con[0], priv->fin_freq); + if (readl(&topc->mux_sel[1]) & (1 << 16)) + rate >>= 1; + rate /= DIVIDER(&topc->div[3], 0, 0xf); + priv->sclk_bus0_pll_a = rate; + + rate = pll145x_get_rate(&topc->bus1_pll_con[0], priv->fin_freq) / + DIVIDER(&topc->div[3], 8, 0xf); + priv->sclk_bus1_pll_a = rate; + + return 0; +} + +static ulong exynos7420_top0_get_periph_rate(struct udevice *dev, int periph) +{ + struct exynos7420_clk_top0_priv *priv = dev_get_priv(dev); + struct exynos7420_clk_cmu_top0 *top0 = priv->top0; + + switch (periph) { + case CLK_SCLK_UART2: + return priv->mout_top0_bus0_pll_half / + DIVIDER(&top0->div_peric[3], 8, 0xf); + default: + return 0; + } +} + +static struct clk_ops exynos7420_clk_top0_ops = { + .get_periph_rate = exynos7420_top0_get_periph_rate, +}; + +static int exynos7420_clk_top0_probe(struct udevice *dev) +{ + struct exynos7420_clk_top0_priv *priv; + struct exynos7420_clk_cmu_top0 *top0; + struct udevice *clk_dev; + fdt_addr_t base; + int ret; + + priv = dev_get_priv(dev); + if (!priv) + return -EINVAL; + + base = dev_get_addr(dev); + if (base == FDT_ADDR_T_NONE) + return -EINVAL; + + top0 = (struct exynos7420_clk_cmu_top0 *)base; + priv->top0 = top0; + + ret = clk_get_by_index(dev, 1, &clk_dev); + if (ret >= 0) { + priv->mout_top0_bus0_pll_half = + clk_get_periph_rate(clk_dev, ret); + if (readl(&top0->mux_sel[1]) & (1 << 16)) + priv->mout_top0_bus0_pll_half >>= 1; + } + + return 0; +} + +static ulong exynos7420_peric1_get_periph_rate(struct udevice *dev, int periph) +{ + struct udevice *clk_dev; + unsigned int ret; + unsigned long freq = 0; + + switch (periph) { + case SCLK_UART2: + ret = clk_get_by_index(dev, 3, &clk_dev); + if (ret < 0) + return ret; + freq = clk_get_periph_rate(clk_dev, ret); + break; + } + + return freq; +} + +static struct clk_ops exynos7420_clk_peric1_ops = { + .get_periph_rate = exynos7420_peric1_get_periph_rate, +}; + +static const struct udevice_id exynos7420_clk_topc_compat[] = { + { .compatible = "samsung,exynos7-clock-topc" }, + { } +}; + +U_BOOT_DRIVER(exynos7420_clk_topc) = { + .name = "exynos7420-clock-topc", + .id = UCLASS_CLK, + .of_match = exynos7420_clk_topc_compat, + .probe = exynos7420_clk_topc_probe, + .priv_auto_alloc_size = sizeof(struct exynos7420_clk_topc_priv), + .ops = &exynos7420_clk_topc_ops, + .flags = DM_FLAG_PRE_RELOC, +}; + +static const struct udevice_id exynos7420_clk_top0_compat[] = { + { .compatible = "samsung,exynos7-clock-top0" }, + { } +}; + +U_BOOT_DRIVER(exynos7420_clk_top0) = { + .name = "exynos7420-clock-top0", + .id = UCLASS_CLK, + .of_match = exynos7420_clk_top0_compat, + .probe = exynos7420_clk_top0_probe, + .priv_auto_alloc_size = sizeof(struct exynos7420_clk_top0_priv), + .ops = &exynos7420_clk_top0_ops, + .flags = DM_FLAG_PRE_RELOC, +}; + +static const struct udevice_id exynos7420_clk_peric1_compat[] = { + { .compatible = "samsung,exynos7-clock-peric1" }, + { } +}; + +U_BOOT_DRIVER(exynos7420_clk_peric1) = { + .name = "exynos7420-clock-peric1", + .id = UCLASS_CLK, + .of_match = exynos7420_clk_peric1_compat, + .ops = &exynos7420_clk_peric1_ops, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/drivers/clk/exynos/clk-pll.c b/drivers/clk/exynos/clk-pll.c new file mode 100644 index 0000000..27220c5 --- /dev/null +++ b/drivers/clk/exynos/clk-pll.c @@ -0,0 +1,33 @@ +/* + * Exynos PLL helper functions for clock drivers. + * Copyright (C) 2016 Samsung Electronics + * Thomas Abraham thomas.ab@samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <div64.h> + +#define PLL145X_MDIV_SHIFT 16 +#define PLL145X_MDIV_MASK 0x3ff +#define PLL145X_PDIV_SHIFT 8 +#define PLL145X_PDIV_MASK 0x3f +#define PLL145X_SDIV_SHIFT 0 +#define PLL145X_SDIV_MASK 0x7 + +unsigned long pll145x_get_rate(unsigned int *con1, unsigned long fin_freq) +{ + unsigned long pll_con1 = readl(con1); + unsigned long mdiv, sdiv, pdiv; + uint64_t fvco = fin_freq; + + mdiv = (pll_con1 >> PLL145X_MDIV_SHIFT) & PLL145X_MDIV_MASK; + pdiv = (pll_con1 >> PLL145X_PDIV_SHIFT) & PLL145X_PDIV_MASK; + sdiv = (pll_con1 >> PLL145X_SDIV_SHIFT) & PLL145X_SDIV_MASK; + + fvco *= mdiv; + do_div(fvco, (pdiv << sdiv)); + return (unsigned long)fvco; +} diff --git a/drivers/clk/exynos/clk-pll.h b/drivers/clk/exynos/clk-pll.h new file mode 100644 index 0000000..631d035 --- /dev/null +++ b/drivers/clk/exynos/clk-pll.h @@ -0,0 +1,9 @@ +/* + * Exynos PLL helper functions for clock drivers. + * Copyright (C) 2016 Samsung Electronics + * Thomas Abraham thomas.ab@samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +unsigned long pll145x_get_rate(unsigned int *con1, unsigned long fin_freq); diff --git a/include/dt-bindings/clock/exynos7420-clk.h b/include/dt-bindings/clock/exynos7420-clk.h new file mode 100644 index 0000000..10c5586 --- /dev/null +++ b/include/dt-bindings/clock/exynos7420-clk.h @@ -0,0 +1,207 @@ +/* + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * Author: Naveen Krishna Ch naveenkrishna.ch@gmail.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. +*/ + +#ifndef _DT_BINDINGS_CLOCK_EXYNOS7_H +#define _DT_BINDINGS_CLOCK_EXYNOS7_H + +/* TOPC */ +#define DOUT_ACLK_PERIS 1 +#define DOUT_SCLK_BUS0_PLL 2 +#define DOUT_SCLK_BUS1_PLL 3 +#define DOUT_SCLK_CC_PLL 4 +#define DOUT_SCLK_MFC_PLL 5 +#define DOUT_ACLK_CCORE_133 6 +#define DOUT_ACLK_MSCL_532 7 +#define ACLK_MSCL_532 8 +#define DOUT_SCLK_AUD_PLL 9 +#define FOUT_AUD_PLL 10 +#define SCLK_AUD_PLL 11 +#define SCLK_MFC_PLL_B 12 +#define SCLK_MFC_PLL_A 13 +#define SCLK_BUS1_PLL_B 14 +#define SCLK_BUS1_PLL_A 15 +#define SCLK_BUS0_PLL_B 16 +#define SCLK_BUS0_PLL_A 17 +#define SCLK_CC_PLL_B 18 +#define SCLK_CC_PLL_A 19 +#define ACLK_CCORE_133 20 +#define ACLK_PERIS_66 21 +#define TOPC_NR_CLK 22 + +/* TOP0 */ +#define DOUT_ACLK_PERIC1 1 +#define DOUT_ACLK_PERIC0 2 +#define CLK_SCLK_UART0 3 +#define CLK_SCLK_UART1 4 +#define CLK_SCLK_UART2 5 +#define CLK_SCLK_UART3 6 +#define CLK_SCLK_SPI0 7 +#define CLK_SCLK_SPI1 8 +#define CLK_SCLK_SPI2 9 +#define CLK_SCLK_SPI3 10 +#define CLK_SCLK_SPI4 11 +#define CLK_SCLK_SPDIF 12 +#define CLK_SCLK_PCM1 13 +#define CLK_SCLK_I2S1 14 +#define CLK_ACLK_PERIC0_66 15 +#define CLK_ACLK_PERIC1_66 16 +#define TOP0_NR_CLK 17 + +/* TOP1 */ +#define DOUT_ACLK_FSYS1_200 1 +#define DOUT_ACLK_FSYS0_200 2 +#define DOUT_SCLK_MMC2 3 +#define DOUT_SCLK_MMC1 4 +#define DOUT_SCLK_MMC0 5 +#define CLK_SCLK_MMC2 6 +#define CLK_SCLK_MMC1 7 +#define CLK_SCLK_MMC0 8 +#define CLK_ACLK_FSYS0_200 9 +#define CLK_ACLK_FSYS1_200 10 +#define CLK_SCLK_PHY_FSYS1 11 +#define CLK_SCLK_PHY_FSYS1_26M 12 +#define MOUT_SCLK_UFSUNIPRO20 13 +#define DOUT_SCLK_UFSUNIPRO20 14 +#define CLK_SCLK_UFSUNIPRO20 15 +#define DOUT_SCLK_PHY_FSYS1 16 +#define DOUT_SCLK_PHY_FSYS1_26M 17 +#define TOP1_NR_CLK 18 + +/* CCORE */ +#define PCLK_RTC 1 +#define CCORE_NR_CLK 2 + +/* PERIC0 */ +#define PCLK_UART0 1 +#define SCLK_UART0 2 +#define PCLK_HSI2C0 3 +#define PCLK_HSI2C1 4 +#define PCLK_HSI2C4 5 +#define PCLK_HSI2C5 6 +#define PCLK_HSI2C9 7 +#define PCLK_HSI2C10 8 +#define PCLK_HSI2C11 9 +#define PCLK_PWM 10 +#define SCLK_PWM 11 +#define PCLK_ADCIF 12 +#define PERIC0_NR_CLK 13 + +/* PERIC1 */ +#define PCLK_UART1 1 +#define PCLK_UART2 2 +#define PCLK_UART3 3 +#define SCLK_UART1 4 +#define SCLK_UART2 5 +#define SCLK_UART3 6 +#define PCLK_HSI2C2 7 +#define PCLK_HSI2C3 8 +#define PCLK_HSI2C6 9 +#define PCLK_HSI2C7 10 +#define PCLK_HSI2C8 11 +#define PCLK_SPI0 12 +#define PCLK_SPI1 13 +#define PCLK_SPI2 14 +#define PCLK_SPI3 15 +#define PCLK_SPI4 16 +#define SCLK_SPI0 17 +#define SCLK_SPI1 18 +#define SCLK_SPI2 19 +#define SCLK_SPI3 20 +#define SCLK_SPI4 21 +#define PCLK_I2S1 22 +#define PCLK_PCM1 23 +#define PCLK_SPDIF 24 +#define SCLK_I2S1 25 +#define SCLK_PCM1 26 +#define SCLK_SPDIF 27 +#define PERIC1_NR_CLK 28 + +/* PERIS */ +#define PCLK_CHIPID 1 +#define SCLK_CHIPID 2 +#define PCLK_WDT 3 +#define PCLK_TMU 4 +#define SCLK_TMU 5 +#define PERIS_NR_CLK 6 + +/* FSYS0 */ +#define ACLK_MMC2 1 +#define ACLK_AXIUS_USBDRD30X_FSYS0X 2 +#define ACLK_USBDRD300 3 +#define SCLK_USBDRD300_SUSPENDCLK 4 +#define SCLK_USBDRD300_REFCLK 5 +#define PHYCLK_USBDRD300_UDRD30_PIPE_PCLK_USER 6 +#define PHYCLK_USBDRD300_UDRD30_PHYCLK_USER 7 +#define OSCCLK_PHY_CLKOUT_USB30_PHY 8 +#define ACLK_PDMA0 9 +#define ACLK_PDMA1 10 +#define FSYS0_NR_CLK 11 + +/* FSYS1 */ +#define ACLK_MMC1 1 +#define ACLK_MMC0 2 +#define PHYCLK_UFS20_TX0_SYMBOL 3 +#define PHYCLK_UFS20_RX0_SYMBOL 4 +#define PHYCLK_UFS20_RX1_SYMBOL 5 +#define ACLK_UFS20_LINK 6 +#define SCLK_UFSUNIPRO20_USER 7 +#define PHYCLK_UFS20_RX1_SYMBOL_USER 8 +#define PHYCLK_UFS20_RX0_SYMBOL_USER 9 +#define PHYCLK_UFS20_TX0_SYMBOL_USER 10 +#define OSCCLK_PHY_CLKOUT_EMBEDDED_COMBO_PHY 11 +#define SCLK_COMBO_PHY_EMBEDDED_26M 12 +#define DOUT_PCLK_FSYS1 13 +#define PCLK_GPIO_FSYS1 14 +#define MOUT_FSYS1_PHYCLK_SEL1 15 +#define FSYS1_NR_CLK 16 + +/* MSCL */ +#define USERMUX_ACLK_MSCL_532 1 +#define DOUT_PCLK_MSCL 2 +#define ACLK_MSCL_0 3 +#define ACLK_MSCL_1 4 +#define ACLK_JPEG 5 +#define ACLK_G2D 6 +#define ACLK_LH_ASYNC_SI_MSCL_0 7 +#define ACLK_LH_ASYNC_SI_MSCL_1 8 +#define ACLK_AXI2ACEL_BRIDGE 9 +#define ACLK_XIU_MSCLX_0 10 +#define ACLK_XIU_MSCLX_1 11 +#define ACLK_QE_MSCL_0 12 +#define ACLK_QE_MSCL_1 13 +#define ACLK_QE_JPEG 14 +#define ACLK_QE_G2D 15 +#define ACLK_PPMU_MSCL_0 16 +#define ACLK_PPMU_MSCL_1 17 +#define ACLK_MSCLNP_133 18 +#define ACLK_AHB2APB_MSCL0P 19 +#define ACLK_AHB2APB_MSCL1P 20 + +#define PCLK_MSCL_0 21 +#define PCLK_MSCL_1 22 +#define PCLK_JPEG 23 +#define PCLK_G2D 24 +#define PCLK_QE_MSCL_0 25 +#define PCLK_QE_MSCL_1 26 +#define PCLK_QE_JPEG 27 +#define PCLK_QE_G2D 28 +#define PCLK_PPMU_MSCL_0 29 +#define PCLK_PPMU_MSCL_1 30 +#define PCLK_AXI2ACEL_BRIDGE 31 +#define PCLK_PMU_MSCL 32 +#define MSCL_NR_CLK 33 + +/* AUD */ +#define SCLK_I2S 1 +#define SCLK_PCM 2 +#define PCLK_I2S 3 +#define PCLK_PCM 4 +#define ACLK_ADMA 5 +#define AUD_NR_CLK 6 +#endif /* _DT_BINDINGS_CLOCK_EXYNOS7_H */
The port id, if not specified in the device node, can be obtained from the alias of the device node listed in the aliases node.
Cc: Minkyu Kang mk7.kang@samsung.com Signed-off-by: Thomas Abraham thomas.ab@samsung.com --- drivers/serial/serial_s5p.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/serial/serial_s5p.c b/drivers/serial/serial_s5p.c index feba467..8590dfd 100644 --- a/drivers/serial/serial_s5p.c +++ b/drivers/serial/serial_s5p.c @@ -174,8 +174,8 @@ static int s5p_serial_ofdata_to_platdata(struct udevice *dev) return -EINVAL;
plat->reg = (struct s5p_uart *)addr; - plat->port_id = fdtdec_get_int(gd->fdt_blob, dev->of_offset, "id", -1); - + plat->port_id = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "id", dev->seq); return 0; }
On Exynos platforms that support clock driver API, allow the driver to use clock api get the SCLK clock rate.
Cc: Minkyu Kang mk7.kang@samsung.com Signed-off-by: Thomas Abraham thomas.ab@samsung.com Reviewed-by: Simon Glass sjg@chromium.org --- drivers/serial/serial_s5p.c | 15 ++++++++++++++- 1 files changed, 14 insertions(+), 1 deletions(-)
diff --git a/drivers/serial/serial_s5p.c b/drivers/serial/serial_s5p.c index 8590dfd..cb55c5a 100644 --- a/drivers/serial/serial_s5p.c +++ b/drivers/serial/serial_s5p.c @@ -17,6 +17,7 @@ #include <asm/arch/clk.h> #include <asm/arch/uart.h> #include <serial.h> +#include <clk.h>
@@ -90,7 +91,19 @@ int s5p_serial_setbrg(struct udevice *dev, int baudrate) { struct s5p_serial_platdata *plat = dev->platdata; struct s5p_uart *const uart = plat->reg; - u32 uclk = get_uart_clk(plat->port_id); + u32 uclk; + +#ifdef CONFIG_CLK_EXYNOS + struct udevice *clk_dev; + u32 ret; + + ret = clk_get_by_index(dev, 1, &clk_dev); + if (ret < 0) + return ret; + uclk = clk_get_periph_rate(clk_dev, ret); +#else + uclk = get_uart_clk(plat->port_id); +#endif
s5p_serial_baud(uart, uclk, baudrate);
The existing Exynos 32-bit platform support needs to be realigned in order to support newer 64-bit Exynos platforms. The driver model will be utlized for drivers on the 64-bit Exynos platforms and so some of the older platform support code would not be required for the newer 64-bit Exynos platforms.
Cc: Minkyu Kang mk7.kang@samsung.com Signed-off-by: Thomas Abraham thomas.ab@samsung.com --- arch/arm/Kconfig | 1 - arch/arm/mach-exynos/Kconfig | 34 +++++++++++++++++++++++++++++- arch/arm/mach-exynos/Makefile | 5 ++- arch/arm/mach-exynos/include/mach/cpu.h | 2 +- arch/arm/mach-exynos/include/mach/gpio.h | 2 +- arch/arm/mach-exynos/soc.c | 2 + configs/arndale_defconfig | 1 + configs/odroid-xu3_defconfig | 1 + configs/odroid_defconfig | 1 + configs/origen_defconfig | 1 + configs/peach-pi_defconfig | 1 + configs/peach-pit_defconfig | 1 + configs/s5pc210_universal_defconfig | 1 + configs/smdk5250_defconfig | 1 + configs/smdk5420_defconfig | 1 + configs/smdkv310_defconfig | 1 + configs/snow_defconfig | 1 + configs/spring_defconfig | 1 + configs/trats2_defconfig | 1 + configs/trats_defconfig | 1 + 20 files changed, 54 insertions(+), 6 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index d1c3157..0ad5fa9 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -426,7 +426,6 @@ config TARGET_BCMNSP
config ARCH_EXYNOS bool "Samsung EXYNOS" - select CPU_V7 select DM select DM_SPI_FLASH select DM_SERIAL diff --git a/arch/arm/mach-exynos/Kconfig b/arch/arm/mach-exynos/Kconfig index a6a7597..28a6a60 100644 --- a/arch/arm/mach-exynos/Kconfig +++ b/arch/arm/mach-exynos/Kconfig @@ -1,9 +1,32 @@ if ARCH_EXYNOS
choice - prompt "EXYNOS board select" + prompt "EXYNOS architecture type select" optional
+config ARCH_EXYNOS4 + bool "Exynos4 SoC family" + select CPU_V7 + help + Samsung Exynos4 SoC family are based on ARM Cortex-A9 CPU. There + are multiple SoCs in this family including Exynos4210, Exynos4412, + and Exynos4212. + +config ARCH_EXYNOS5 + bool "Exynos5 SoC family" + select CPU_V7 + help + Samsung Exynos5 SoC family are based on ARM Cortex-A15 CPU (and + Cortex-A7 CPU in big.LITTLE configuration). There are multiple SoCs + in this family including Exynos5250, Exynos5420 and Exynos5800. + +endchoice + +if ARCH_EXYNOS4 + +choice + prompt "EXYNOS4 board select" + config TARGET_SMDKV310 select SUPPORT_SPL bool "Exynos4210 SMDKV310 board" @@ -25,6 +48,14 @@ config TARGET_TRATS2 config TARGET_ODROID bool "Exynos4412 Odroid board"
+endchoice +endif + +if ARCH_EXYNOS5 + +choice + prompt "EXYNOS5 board select" + config TARGET_ODROID_XU3 bool "Exynos5422 Odroid board" select OF_CONTROL @@ -68,6 +99,7 @@ config TARGET_PEACH_PIT select OF_CONTROL
endchoice +endif
config SYS_SOC default "exynos" diff --git a/arch/arm/mach-exynos/Makefile b/arch/arm/mach-exynos/Makefile index 8542f89..f3c07b7 100644 --- a/arch/arm/mach-exynos/Makefile +++ b/arch/arm/mach-exynos/Makefile @@ -5,7 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += clock.o power.o soc.o system.o pinmux.o tzpc.o +obj-y += soc.o +obj-$(CONFIG_CPU_V7) += clock.o pinmux.o power.o system.o
obj-$(CONFIG_EXYNOS5420) += sec_boot.o
@@ -13,6 +14,6 @@ ifdef CONFIG_SPL_BUILD obj-$(CONFIG_EXYNOS5) += clock_init_exynos5.o obj-$(CONFIG_EXYNOS5) += dmc_common.o dmc_init_ddr3.o obj-$(CONFIG_EXYNOS4210)+= dmc_init_exynos4.o clock_init_exynos4.o -obj-y += spl_boot.o +obj-y += spl_boot.o tzpc.o obj-y += lowlevel_init.o endif diff --git a/arch/arm/mach-exynos/include/mach/cpu.h b/arch/arm/mach-exynos/include/mach/cpu.h index 14a1692..f12e3d6 100644 --- a/arch/arm/mach-exynos/include/mach/cpu.h +++ b/arch/arm/mach-exynos/include/mach/cpu.h @@ -270,7 +270,7 @@ IS_EXYNOS_TYPE(exynos5420, 0x5420) IS_EXYNOS_TYPE(exynos5422, 0x5422)
#define SAMSUNG_BASE(device, base) \ -static inline unsigned int __attribute__((no_instrument_function)) \ +static inline unsigned long __attribute__((no_instrument_function)) \ samsung_get_base_##device(void) \ { \ if (cpu_is_exynos4()) { \ diff --git a/arch/arm/mach-exynos/include/mach/gpio.h b/arch/arm/mach-exynos/include/mach/gpio.h index 7fc8e61..81363bd 100644 --- a/arch/arm/mach-exynos/include/mach/gpio.h +++ b/arch/arm/mach-exynos/include/mach/gpio.h @@ -1349,7 +1349,7 @@ enum exynos5420_gpio_pin { };
struct gpio_info { - unsigned int reg_addr; /* Address of register for this part */ + unsigned long reg_addr; /* Address of register for this part */ unsigned int max_gpio; /* Maximum GPIO in this part */ };
diff --git a/arch/arm/mach-exynos/soc.c b/arch/arm/mach-exynos/soc.c index 0f116b1..737a8dd 100644 --- a/arch/arm/mach-exynos/soc.c +++ b/arch/arm/mach-exynos/soc.c @@ -11,7 +11,9 @@
void reset_cpu(ulong addr) { +#ifdef CONFIG_CPU_V7 writel(0x1, samsung_get_base_swreset()); +#endif }
#ifndef CONFIG_SYS_DCACHE_OFF diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index b323e98..cfd02c8 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y +CONFIG_ARCH_EXYNOS5=y CONFIG_TARGET_ARNDALE=y CONFIG_DM_I2C=y CONFIG_DEFAULT_DEVICE_TREE="exynos5250-arndale" diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index bb0576a..49195a2 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y +CONFIG_ARCH_EXYNOS5=y CONFIG_TARGET_ODROID_XU3=y CONFIG_DM_I2C=y CONFIG_DEFAULT_DEVICE_TREE="exynos5422-odroidxu3" diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index a92bbe1..02536a7 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y +CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_ODROID=y CONFIG_DM_I2C=y CONFIG_DEFAULT_DEVICE_TREE="exynos4412-odroid" diff --git a/configs/origen_defconfig b/configs/origen_defconfig index de4a816..1f73ada 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y +CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_ORIGEN=y CONFIG_DEFAULT_DEVICE_TREE="exynos4210-origen" CONFIG_SPL=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index 23b9762..6498639 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y +CONFIG_ARCH_EXYNOS5=y CONFIG_TARGET_PEACH_PI=y CONFIG_DM_I2C=y CONFIG_DEFAULT_DEVICE_TREE="exynos5800-peach-pi" diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index adde56f..57160a0 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y +CONFIG_ARCH_EXYNOS5=y CONFIG_TARGET_PEACH_PIT=y CONFIG_DM_I2C=y CONFIG_DEFAULT_DEVICE_TREE="exynos5420-peach-pit" diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index d91b433..2cd013c 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y +CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_S5PC210_UNIVERSAL=y CONFIG_DEFAULT_DEVICE_TREE="exynos4210-universal_c210" CONFIG_SYS_PROMPT="Universal # " diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index b3d16ab..2ccffc1 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y +CONFIG_ARCH_EXYNOS5=y CONFIG_TARGET_SMDK5250=y CONFIG_DM_I2C=y CONFIG_DEFAULT_DEVICE_TREE="exynos5250-smdk5250" diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index a84d159..a418933 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y +CONFIG_ARCH_EXYNOS5=y CONFIG_TARGET_SMDK5420=y CONFIG_DM_I2C=y CONFIG_DEFAULT_DEVICE_TREE="exynos5420-smdk5420" diff --git a/configs/smdkv310_defconfig b/configs/smdkv310_defconfig index 851fc5c..c0ba861 100644 --- a/configs/smdkv310_defconfig +++ b/configs/smdkv310_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y +CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_SMDKV310=y CONFIG_DEFAULT_DEVICE_TREE="exynos4210-smdkv310" CONFIG_SPL=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 5dbd18a..e2630c6 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y +CONFIG_ARCH_EXYNOS5=y CONFIG_TARGET_SNOW=y CONFIG_DM_I2C=y CONFIG_DEFAULT_DEVICE_TREE="exynos5250-snow" diff --git a/configs/spring_defconfig b/configs/spring_defconfig index 352bd1a..44e3809 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y +CONFIG_ARCH_EXYNOS5=y CONFIG_TARGET_SPRING=y CONFIG_DM_I2C=y CONFIG_DEFAULT_DEVICE_TREE="exynos5250-spring" diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index 14bdc6a..f5acf62 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y +CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_TRATS2=y CONFIG_DEFAULT_DEVICE_TREE="exynos4412-trats2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/trats_defconfig b/configs/trats_defconfig index c3b82bb..8094d0d 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y +CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_TRATS=y CONFIG_DEFAULT_DEVICE_TREE="exynos4210-trats" CONFIG_FIT=y
Add support for Exynos7420 SoC. The Exynos7420 SoC has four Cortex-A57 and four Cortex-A53 CPUs and includes various peripheral controllers.
Signed-off-by: Thomas Abraham thomas.ab@samsung.com Reviewed-by: Simon Glass sjg@chromium.org --- arch/arm/dts/exynos7420.dtsi | 83 +++++++++++++++++++++++++ arch/arm/mach-exynos/Kconfig | 8 +++ arch/arm/mach-exynos/Makefile | 1 + arch/arm/mach-exynos/mmu-arm64.c | 35 +++++++++++ arch/arm/mach-exynos/soc.c | 8 +++ include/configs/espresso7420.h | 34 +++++++++++ include/configs/exynos7420-common.h | 113 +++++++++++++++++++++++++++++++++++ 7 files changed, 282 insertions(+), 0 deletions(-) create mode 100644 arch/arm/dts/exynos7420.dtsi create mode 100644 arch/arm/mach-exynos/mmu-arm64.c create mode 100644 include/configs/espresso7420.h create mode 100644 include/configs/exynos7420-common.h
diff --git a/arch/arm/dts/exynos7420.dtsi b/arch/arm/dts/exynos7420.dtsi new file mode 100644 index 0000000..b398021 --- /dev/null +++ b/arch/arm/dts/exynos7420.dtsi @@ -0,0 +1,83 @@ +/* + * Samsung Exynos7420 SoC device tree source + * + * Copyright (c) 2016 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +#include "skeleton.dtsi" +#include <dt-bindings/clock/exynos7420-clk.h> +/ { + compatible = "samsung,exynos7420"; + + fin_pll: xxti { + compatible = "fixed-clock"; + clock-output-names = "fin_pll"; + u-boot,dm-pre-reloc; + #clock-cells = <0>; + }; + + clock_topc: clock-controller@10570000 { + compatible = "samsung,exynos7-clock-topc"; + reg = <0x10570000 0x10000>; + u-boot,dm-pre-reloc; + #clock-cells = <1>; + clocks = <&fin_pll>; + clock-names = "fin_pll"; + }; + + clock_top0: clock-controller@105d0000 { + compatible = "samsung,exynos7-clock-top0"; + reg = <0x105d0000 0xb000>; + u-boot,dm-pre-reloc; + #clock-cells = <1>; + clocks = <&fin_pll>, <&clock_topc DOUT_SCLK_BUS0_PLL>, + <&clock_topc DOUT_SCLK_BUS1_PLL>, + <&clock_topc DOUT_SCLK_CC_PLL>, + <&clock_topc DOUT_SCLK_MFC_PLL>; + clock-names = "fin_pll", "dout_sclk_bus0_pll", + "dout_sclk_bus1_pll", "dout_sclk_cc_pll", + "dout_sclk_mfc_pll"; + }; + + clock_peric1: clock-controller@14c80000 { + compatible = "samsung,exynos7-clock-peric1"; + reg = <0x14c80000 0xd00>; + u-boot,dm-pre-reloc; + #clock-cells = <1>; + clocks = <&fin_pll>, <&clock_top0 DOUT_ACLK_PERIC1>, + <&clock_top0 CLK_SCLK_UART1>, + <&clock_top0 CLK_SCLK_UART2>, + <&clock_top0 CLK_SCLK_UART3>; + clock-names = "fin_pll", "dout_aclk_peric1_66", + "sclk_uart1", "sclk_uart2", "sclk_uart3"; + }; + + pinctrl@13470000 { + compatible = "samsung,exynos7420-pinctrl"; + reg = <0x13470000 0x1000>; + u-boot,dm-pre-reloc; + + serial2_bus: serial2-bus { + samsung,pins = "gpd1-4", "gpd1-5"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + u-boot,dm-pre-reloc; + }; + }; + + serial@14C30000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x14C30000 0x100>; + u-boot,dm-pre-reloc; + clocks = <&clock_peric1 PCLK_UART2>, + <&clock_peric1 SCLK_UART2>; + clock-names = "uart", "clk_uart_baud0"; + pinctrl-names = "default"; + pinctrl-0 = <&serial2_bus>; + }; +}; diff --git a/arch/arm/mach-exynos/Kconfig b/arch/arm/mach-exynos/Kconfig index 28a6a60..0a6cb33 100644 --- a/arch/arm/mach-exynos/Kconfig +++ b/arch/arm/mach-exynos/Kconfig @@ -20,6 +20,14 @@ config ARCH_EXYNOS5 Cortex-A7 CPU in big.LITTLE configuration). There are multiple SoCs in this family including Exynos5250, Exynos5420 and Exynos5800.
+config ARCH_EXYNOS7 + bool "Exynos7 SoC family" + select ARM64 + help + Samsung Exynos7 SoC family are based on ARM Cortex-A57 CPU or + Cortex-A53 CPU (and some in a big.LITTLE configuration). There are + multiple SoCs in this family including Exynos7420. + endchoice
if ARCH_EXYNOS4 diff --git a/arch/arm/mach-exynos/Makefile b/arch/arm/mach-exynos/Makefile index f3c07b7..0cc6c32 100644 --- a/arch/arm/mach-exynos/Makefile +++ b/arch/arm/mach-exynos/Makefile @@ -7,6 +7,7 @@
obj-y += soc.o obj-$(CONFIG_CPU_V7) += clock.o pinmux.o power.o system.o +obj-$(CONFIG_ARM64) += mmu-arm64.o
diff --git a/arch/arm/mach-exynos/mmu-arm64.c b/arch/arm/mach-exynos/mmu-arm64.c new file mode 100644 index 0000000..ba6d99d --- /dev/null +++ b/arch/arm/mach-exynos/mmu-arm64.c @@ -0,0 +1,35 @@ +/* + * Copyright (C) 2016 Samsung Electronics + * Thomas Abraham thomas.ab@samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/armv8/mmu.h> + +DECLARE_GLOBAL_DATA_PTR; + +#ifdef CONFIG_EXYNOS7420 +static struct mm_region exynos7420_mem_map[] = { + { + .base = 0x10000000UL, + .size = 0x10000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN, + }, { + .base = 0x40000000UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE, + }, { + /* List terminator */ + .base = 0, + .size = 0, + .attrs = 0, + }, +}; + +struct mm_region *mem_map = exynos7420_mem_map; +#endif diff --git a/arch/arm/mach-exynos/soc.c b/arch/arm/mach-exynos/soc.c index 737a8dd..f9c7468 100644 --- a/arch/arm/mach-exynos/soc.c +++ b/arch/arm/mach-exynos/soc.c @@ -23,3 +23,11 @@ void enable_caches(void) dcache_enable(); } #endif + +#ifdef CONFIG_ARM64 +void lowlevel_init(void) +{ + armv8_switch_to_el2(); + armv8_switch_to_el1(); +} +#endif diff --git a/include/configs/espresso7420.h b/include/configs/espresso7420.h new file mode 100644 index 0000000..c6a756d --- /dev/null +++ b/include/configs/espresso7420.h @@ -0,0 +1,34 @@ +/* + * Configuration settings for the SAMSUNG ESPRESSO7420 board. + * Copyright (C) 2016 Samsung Electronics + * Thomas Abraham thomas.ab@samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_ESPRESSO7420_H +#define __CONFIG_ESPRESSO7420_H + +#include <configs/exynos7420-common.h> + +#define CONFIG_BOARD_COMMON + +#define CONFIG_ESPRESSO7420 +#define CONFIG_ENV_IS_NOWHERE + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define CONFIG_SYS_TEXT_BASE 0x43E00000 +#define CONFIG_SPL_STACK CONFIG_IRAM_END +#define CONFIG_SYS_INIT_SP_ADDR CONFIG_IRAM_END + +/* select serial console configuration */ +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" + +#define CONFIG_IDENT_STRING " for ESPRESSO7420" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" + +/* DRAM Memory Banks */ +#define CONFIG_NR_DRAM_BANKS 8 +#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ + +#endif /* __CONFIG_ESPRESSO7420_H */ diff --git a/include/configs/exynos7420-common.h b/include/configs/exynos7420-common.h new file mode 100644 index 0000000..9e03962 --- /dev/null +++ b/include/configs/exynos7420-common.h @@ -0,0 +1,113 @@ +/* + * Configuration settings for the Espresso7420 board. + * Copyright (C) 2016 Samsung Electronics + * Thomas Abraham thomas.ab@samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_EXYNOS7420_COMMON_H +#define __CONFIG_EXYNOS7420_COMMON_H + +/* High Level Configuration Options */ +#define CONFIG_SAMSUNG /* in a SAMSUNG core */ +#define CONFIG_EXYNOS7420 /* Exynos7 Family */ +#define CONFIG_S5P + +#include <asm/arch/cpu.h> /* get chip and board defs */ +#include <linux/sizes.h> + +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_EARLY_INIT_F + +/* Size of malloc() pool before and after relocation */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (80 << 20)) + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE 1024 /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ + +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* select serial console configuration */ +#define CONFIG_BAUDRATE 115200 + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +/* Timer input clock frequency */ +#define COUNTER_FREQUENCY 24000000 + +/* Device Tree */ +#define CONFIG_DEVICE_TREE_LIST "exynos7420-espresso7420" + +/* IRAM Layout */ +#define CONFIG_IRAM_BASE 0x02100000 +#define CONFIG_IRAM_SIZE 0x58000 +#define CONFIG_IRAM_END (CONFIG_IRAM_BASE + CONFIG_IRAM_SIZE) + +/* Number of CPUs available */ +#define CONFIG_CORE_COUNT 0x8 + +/* select serial console configuration */ +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SILENT_CONSOLE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_CONSOLE_MUX + +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000) + +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE +#define PHYS_SDRAM_1_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_2 (CONFIG_SYS_SDRAM_BASE + SDRAM_BANK_SIZE) +#define PHYS_SDRAM_2_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_3 (CONFIG_SYS_SDRAM_BASE + (2 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_3_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_4 (CONFIG_SYS_SDRAM_BASE + (3 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_4_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_5 (CONFIG_SYS_SDRAM_BASE + (4 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_5_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_6 (CONFIG_SYS_SDRAM_BASE + (5 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_6_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_7 (CONFIG_SYS_SDRAM_BASE + (6 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_7_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_8 (CONFIG_SYS_SDRAM_BASE + (7 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_8_SIZE SDRAM_BANK_SIZE + +/* Configuration of ENV Blocks */ +#define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 1) \ + func(MMC, mmc, 0) \ + +#ifndef MEM_LAYOUT_ENV_SETTINGS +#define MEM_LAYOUT_ENV_SETTINGS \ + "bootm_size=0x10000000\0" \ + "kernel_addr_r=0x42000000\0" \ + "fdt_addr_r=0x43000000\0" \ + "ramdisk_addr_r=0x43300000\0" \ + "scriptaddr=0x50000000\0" \ + "pxefile_addr_r=0x51000000\0" +#endif + +#ifndef EXYNOS_DEVICE_SETTINGS +#define EXYNOS_DEVICE_SETTINGS \ + "stdin=serial\0" \ + "stdout=serial\0" \ + "stderr=serial\0" +#endif + +#ifndef EXYNOS_FDTFILE_SETTING +#define EXYNOS_FDTFILE_SETTING +#endif + +#define CONFIG_EXTRA_ENV_SETTINGS \ + EXYNOS_DEVICE_SETTINGS \ + EXYNOS_FDTFILE_SETTING \ + MEM_LAYOUT_ENV_SETTINGS + +#endif /* __CONFIG_EXYNOS7420_COMMON_H */
Espresso7420 is a development/evaluation board for Exynos7420 SoC. It includes multiple onboard compoments (EMMC/Codec) and various interconnects (USB/HDMI).
Signed-off-by: Thomas Abraham thomas.ab@samsung.com Reviewed-by: Simon Glass sjg@chromium.org --- arch/arm/dts/Makefile | 1 + arch/arm/dts/exynos7420-espresso7420.dts | 24 ++++++++++++++++++++++++ arch/arm/mach-exynos/Kconfig | 19 +++++++++++++++++++ board/samsung/common/board.c | 10 ++++++++-- board/samsung/espresso7420/Kconfig | 16 ++++++++++++++++ board/samsung/espresso7420/MAINTAINERS | 5 +++++ board/samsung/espresso7420/Makefile | 10 ++++++++++ board/samsung/espresso7420/espresso7420.c | 16 ++++++++++++++++ configs/espresso7420_defconfig | 9 +++++++++ 9 files changed, 108 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/exynos7420-espresso7420.dts create mode 100644 board/samsung/espresso7420/Kconfig create mode 100644 board/samsung/espresso7420/MAINTAINERS create mode 100644 board/samsung/espresso7420/Makefile create mode 100644 board/samsung/espresso7420/espresso7420.c create mode 100644 configs/espresso7420_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index aa31fd9..a08e45f 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -19,6 +19,7 @@ dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ exynos5420-peach-pit.dtb \ exynos5800-peach-pi.dtb \ exynos5422-odroidxu3.dtb +dtb-$(CONFIG_EXYNOS7420) += exynos7420-espresso7420.dtb dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3288-firefly.dtb \ rk3288-jerry.dtb \ diff --git a/arch/arm/dts/exynos7420-espresso7420.dts b/arch/arm/dts/exynos7420-espresso7420.dts new file mode 100644 index 0000000..f17a848 --- /dev/null +++ b/arch/arm/dts/exynos7420-espresso7420.dts @@ -0,0 +1,24 @@ +/* + * Samsung Espresso7420 board device tree source + * + * Copyright (c) 2016 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include "exynos7420.dtsi" +/ { + model = "Samsung Espresso7420 board based on Exynos7420"; + compatible = "samsung,espresso7420", "samsung,exynos7420"; + + aliases { + serial2 = "/serial@14C30000"; + console = "/serial@14C30000"; + pinctrl0 = "/pinctrl@13470000"; + }; +}; + +&fin_pll { + clock-frequency = <24000000>; +}; diff --git a/arch/arm/mach-exynos/Kconfig b/arch/arm/mach-exynos/Kconfig index 0a6cb33..c25fcf3 100644 --- a/arch/arm/mach-exynos/Kconfig +++ b/arch/arm/mach-exynos/Kconfig @@ -109,6 +109,24 @@ config TARGET_PEACH_PIT endchoice endif
+if ARCH_EXYNOS7 + +choice + prompt "EXYNOS7 board select" + +config TARGET_ESPRESSO7420 + bool "ESPRESSO7420 board" + select ARM64 + select SUPPORT_SPL + select OF_CONTROL + select SPL_DISABLE_OF_CONTROL + select PINCTRL + select PINCTRL_EXYNOS7420 + select CLK_EXYNOS + +endchoice +endif + config SYS_SOC default "exynos"
@@ -121,5 +139,6 @@ source "board/samsung/odroid/Kconfig" source "board/samsung/arndale/Kconfig" source "board/samsung/smdk5250/Kconfig" source "board/samsung/smdk5420/Kconfig" +source "board/samsung/espresso7420/Kconfig"
endif diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index 1334c22..7995174 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -27,6 +27,8 @@ #include <usb.h> #include <dwc3-uboot.h> #include <samsung/misc.h> +#include <dm/pinctrl.h> +#include <dm.h>
@@ -97,7 +99,7 @@ int board_init(void) int dram_init(void) { unsigned int i; - u32 addr; + unsigned long addr;
for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { addr = CONFIG_SYS_SDRAM_BASE + (i * SDRAM_BANK_SIZE); @@ -109,7 +111,7 @@ int dram_init(void) void dram_init_banksize(void) { unsigned int i; - u32 addr, size; + unsigned long addr, size;
for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { addr = CONFIG_SYS_SDRAM_BASE + (i * SDRAM_BANK_SIZE); @@ -122,6 +124,7 @@ void dram_init_banksize(void)
static int board_uart_init(void) { +#ifndef CONFIG_PINCTRL_EXYNOS int err, uart_id, ret = 0;
for (uart_id = PERIPH_ID_UART0; uart_id <= PERIPH_ID_UART3; uart_id++) { @@ -133,6 +136,9 @@ static int board_uart_init(void) } } return ret; +#else + return 0; +#endif }
#ifdef CONFIG_BOARD_EARLY_INIT_F diff --git a/board/samsung/espresso7420/Kconfig b/board/samsung/espresso7420/Kconfig new file mode 100644 index 0000000..62251c5 --- /dev/null +++ b/board/samsung/espresso7420/Kconfig @@ -0,0 +1,16 @@ +if TARGET_ESPRESSO7420 + +config SYS_BOARD + default "espresso7420" + help + Espresso7420 is a development/evaluation board for Exynos7420 SoC. + It includes multiple onboard compoments (EMMC/Codec) and various + interconnects (USB/HDMI). + +config SYS_VENDOR + default "samsung" + +config SYS_CONFIG_NAME + default "espresso7420" + +endif diff --git a/board/samsung/espresso7420/MAINTAINERS b/board/samsung/espresso7420/MAINTAINERS new file mode 100644 index 0000000..aaebc4c --- /dev/null +++ b/board/samsung/espresso7420/MAINTAINERS @@ -0,0 +1,5 @@ +ESPRESSO7420 Board +M: Thomas Abraham thomas.ab@samsung.com +S: Maintained +F: board/samsung/espresso7420/ +F: include/configs/espresso7420.h diff --git a/board/samsung/espresso7420/Makefile b/board/samsung/espresso7420/Makefile new file mode 100644 index 0000000..d514dc2 --- /dev/null +++ b/board/samsung/espresso7420/Makefile @@ -0,0 +1,10 @@ +# +# Copyright (C) 2016 Samsung Electronics +# Thomas Abraham thomas.ab@samsung.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +ifndef CONFIG_SPL_BUILD +obj-y += espresso7420.o +endif diff --git a/board/samsung/espresso7420/espresso7420.c b/board/samsung/espresso7420/espresso7420.c new file mode 100644 index 0000000..04a83bc --- /dev/null +++ b/board/samsung/espresso7420/espresso7420.c @@ -0,0 +1,16 @@ +/* + * Espresso7420 board file + * Copyright (C) 2016 Samsung Electronics + * Thomas Abraham thomas.ab@samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> + +DECLARE_GLOBAL_DATA_PTR; + +int exynos_init(void) +{ + return 0; +} diff --git a/configs/espresso7420_defconfig b/configs/espresso7420_defconfig new file mode 100644 index 0000000..0fe2759 --- /dev/null +++ b/configs/espresso7420_defconfig @@ -0,0 +1,9 @@ +CONFIG_ARM=y +CONFIG_ARCH_EXYNOS=y +CONFIG_ARCH_EXYNOS7=y +CONFIG_TARGET_ESPRESSO7420=y +CONFIG_DEFAULT_DEVICE_TREE="exynos7420-espresso7420" +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SYS_PROMPT="ESPRESSO7420 # " +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_SETEXPR is not set
On Sat, Apr 23, 2016 at 10:18:06PM +0530, Thomas Abraham wrote:
Changes since v2:
- changes based on comments from Simon Glass and Minkyu Kang.
This patch series add support for Espresso7420 board. This board is the development/evaluation platform for Exynos7420 SoC. The SoC is composed of quad Cortex-A57 block, a quad Cortex-A53 block and various other peripherals. The board includes multiple components such as the EMMC/Codec and support multiple interconnect interfaces including HDMI and USB.
The first two patches add Exynos7420 pinctrl driver support which was initially posted seperatly but now included in this series. Thanks to Simon Glass and Minkyu Kang for their review. The rest of the patches add Exynos7420 clock driver support, minor changes in the S5P serial driver, Exynos7420 SoC support and Espresso7420 board support.
Things look good here to me and I expect this to come in via the samsung tree. I'll like it up to you and Minkyu to decide if it's now or next merge window. Thanks!
Hi Thomas,
On 04/23/2016 10:18 PM, Thomas Abraham wrote:
Changes since v2:
Thomas Abraham (8): pinctrl: add the DM_UC_FLAG_SEQ_ALIAS flag for numbering the devices pinctrl: Add pinctrl driver support for Exynos7420 SoC clk: exynos: add clock driver for Exynos7420 Soc serial: s5p: get the port id number from the alias of the device node serial: s5p: use clock api to get clock rate arm: exynos: realign the code to allow support for newer 64-bit platforms arm: exynos: add support for Exynos7420 SoC board: samsung: add initial Espresso7420 board support
Tested this version on espresso7420 board, feel free to add Tested-by: Alim Akhtar alim.akhtar@samsung.com
arch/arm/Kconfig | 1 - arch/arm/dts/Makefile | 1 + arch/arm/dts/exynos7420-espresso7420.dts | 24 +++ arch/arm/dts/exynos7420.dtsi | 83 ++++++++++ arch/arm/mach-exynos/Kconfig | 61 +++++++- arch/arm/mach-exynos/Makefile | 6 +- arch/arm/mach-exynos/include/mach/cpu.h | 2 +- arch/arm/mach-exynos/include/mach/gpio.h | 2 +- arch/arm/mach-exynos/mmu-arm64.c | 35 ++++ arch/arm/mach-exynos/soc.c | 10 + board/samsung/common/board.c | 10 +- board/samsung/espresso7420/Kconfig | 16 ++ board/samsung/espresso7420/MAINTAINERS | 5 + board/samsung/espresso7420/Makefile | 10 + board/samsung/espresso7420/espresso7420.c | 16 ++ configs/arndale_defconfig | 1 + configs/espresso7420_defconfig | 9 + configs/odroid-xu3_defconfig | 1 + configs/odroid_defconfig | 1 + configs/origen_defconfig | 1 + configs/peach-pi_defconfig | 1 + configs/peach-pit_defconfig | 1 + configs/s5pc210_universal_defconfig | 1 + configs/smdk5250_defconfig | 1 + configs/smdk5420_defconfig | 1 + configs/smdkv310_defconfig | 1 + configs/snow_defconfig | 1 + configs/spring_defconfig | 1 + configs/trats2_defconfig | 1 + configs/trats_defconfig | 1 + drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/exynos/Kconfig | 18 ++ drivers/clk/exynos/Makefile | 9 + drivers/clk/exynos/clk-exynos7420.c | 236 +++++++++++++++++++++++++++ drivers/clk/exynos/clk-pll.c | 33 ++++ drivers/clk/exynos/clk-pll.h | 9 + drivers/pinctrl/Kconfig | 1 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/exynos/Kconfig | 10 + drivers/pinctrl/exynos/Makefile | 9 + drivers/pinctrl/exynos/pinctrl-exynos.c | 141 ++++++++++++++++ drivers/pinctrl/exynos/pinctrl-exynos.h | 77 +++++++++ drivers/pinctrl/exynos/pinctrl-exynos7420.c | 120 ++++++++++++++ drivers/pinctrl/pinctrl-uclass.c | 1 + drivers/serial/serial_s5p.c | 19 ++- include/configs/espresso7420.h | 34 ++++ include/configs/exynos7420-common.h | 113 +++++++++++++ include/dt-bindings/clock/exynos7420-clk.h | 207 +++++++++++++++++++++++ 49 files changed, 1334 insertions(+), 11 deletions(-) create mode 100644 arch/arm/dts/exynos7420-espresso7420.dts create mode 100644 arch/arm/dts/exynos7420.dtsi create mode 100644 arch/arm/mach-exynos/mmu-arm64.c create mode 100644 board/samsung/espresso7420/Kconfig create mode 100644 board/samsung/espresso7420/MAINTAINERS create mode 100644 board/samsung/espresso7420/Makefile create mode 100644 board/samsung/espresso7420/espresso7420.c create mode 100644 configs/espresso7420_defconfig create mode 100644 drivers/clk/exynos/Kconfig create mode 100644 drivers/clk/exynos/Makefile create mode 100644 drivers/clk/exynos/clk-exynos7420.c create mode 100644 drivers/clk/exynos/clk-pll.c create mode 100644 drivers/clk/exynos/clk-pll.h create mode 100644 drivers/pinctrl/exynos/Kconfig create mode 100644 drivers/pinctrl/exynos/Makefile create mode 100644 drivers/pinctrl/exynos/pinctrl-exynos.c create mode 100644 drivers/pinctrl/exynos/pinctrl-exynos.h create mode 100644 drivers/pinctrl/exynos/pinctrl-exynos7420.c create mode 100644 include/configs/espresso7420.h create mode 100644 include/configs/exynos7420-common.h create mode 100644 include/dt-bindings/clock/exynos7420-clk.h
On 24/04/16 01:48, Thomas Abraham wrote:
Changes since v2:
applied to u-boot-samsung.
Thanks, Minkyu Kang.
participants (5)
Alim Akhtar
Minkyu Kang
Thomas Abraham
