AW: [U-Boot-Users] Flash boot issues with MPC8272ADS and PQ2FADS
Keith,
We are using several PQ2FADS-VR and MPC8272ADS boards for a Linux project and are experiencing a high occurrence of boards that get into a state where they will not boot or behave erratically during boot.
When folks bring me systems in this state, my "fix" has been to replace the 8MB flash SIMM. This usually gets them going again, but I honestly don't think the SIMM is the real problem. I have one PQ2FADS board that I have put four different SIMMs in and can not get it to boot. In most other cases, I can take the "bad" SIMM, put it in another board, reprogram it and it will work again (for a while).
known good, tested kernels. Typically, users will have been working for weeks without a problem until they run into this.
Any insight or shared experience on this is greatly appreciated.
From my experience a possible answer to your problem is that the contact
metal of the board connector does not match the metal of the contact area on your SIMMs. I saw similar problems before with self-built SDRAM SIMMs. The only way to get it working reliably was to use a board connector with gold plated contacts and to use a SIMM with a gold plated PCB. I am not a chemist or physicist but I think else the two different materials after a while build up some strange alloy / oxide that ruins the contact.
What's the plating of your board connector and what's the plating of the SIMM contact area?
Regards Mark
Jonas Mark (ST/EPP1) *
