[PATCH v3] sunxi: a64: Add a defconfig for the PinePhone
The PinePhone is a smartphone produced by Pine64, with an A64 SoC, 2 or 3 GiB LPDDR3 RAM, 16 or 32 GiB eMMC, 720x1440 MIPI-DSI panel, and Quectel EG25-G modem.
There are two main board revisions: 1.1 for early adopters, and 1.2 for mass production. Since there is code to detect the board revision at boot, one config/image can support both boards.
Acked-by: Maxime Ripard mripard@kernel.org Signed-off-by: Samuel Holland samuel@sholland.org ---
Changes v2->v3: - All other patches merged - Added entry to MAINTAINERS
Changes v1->v2: - Regenerated defconfig with `make savedefconfig` - Added Acked-by tag
board/sunxi/MAINTAINERS | 5 +++++ configs/pinephone_defconfig | 12 ++++++++++++ 2 files changed, 17 insertions(+) create mode 100644 configs/pinephone_defconfig
diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 1180b86db3..d3755ae41a 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -451,6 +451,11 @@ M: Icenowy Zheng icenowy@aosc.io S: Maintained F: configs/pine_h64_defconfig
+PINEPHONE BOARD +M: Samuel Holland samuel@sholland.org +S: Maintained +F: configs/pinephone_defconfig + R16 EVB PARROT BOARD M: Quentin Schulz quentin.schulz@free-electrons.com S: Maintained diff --git a/configs/pinephone_defconfig b/configs/pinephone_defconfig new file mode 100644 index 0000000000..64ecef59c9 --- /dev/null +++ b/configs/pinephone_defconfig @@ -0,0 +1,12 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_SPL=y +CONFIG_MACH_SUN50I=y +CONFIG_SUNXI_DRAM_LPDDR3_STOCK=y +CONFIG_DRAM_CLK=552 +CONFIG_DRAM_ZQ=3881949 +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_PINEPHONE_DT_SELECTION=y +CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-pinephone-1.2" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_OF_LIST="sun50i-a64-pinephone-1.1 sun50i-a64-pinephone-1.2"
Reviewed-by: Andre Przywara andre.przywara@arm.com
Thanks, Andre
Changes v2->v3:
Changes v1->v2:
André Przywara
Samuel Holland
