[U-Boot] [PATCH v2 0/4] regmap: Add a managed API, custom read/write callbacks and support for regmap fields
This is the first of a few series, the goal of which is to facilitate porting drivers from the linux kernel. Most of the series will be about adding managed API to existing infrastructure (GPIO, reset, phy,...)
This particular series is about regmaps. It adds the managed API, using the same API as linux. It also adds support for regmap fields and for custom read/write callbacks.
Changes in v2: - Fix comment for devm_regmap_init() - Fix spelling in commit log - Only use custom accessors if {,SPL,TPL}_REGMAP_ACCESSORS is enabled
Jean-Jacques Hiblot (4): regmap: Add devm_regmap_init() regmap: Allow providing read/write callbacks through struct regmap_config regmap: Add support for regmap fields test: dm: Add tests for regmap managed API and regmap fields
arch/sandbox/dts/test.dts | 13 +++ drivers/core/Kconfig | 25 +++++ drivers/core/regmap.c | 123 ++++++++++++++++++++++++- include/regmap.h | 148 +++++++++++++++++++++++++++++ test/dm/regmap.c | 189 ++++++++++++++++++++++++++++++++++++++ 5 files changed, 497 insertions(+), 1 deletion(-)
Most of new linux drivers are using managed-API to allocate resources. To ease porting drivers from linux to U-Boot, introduce devm_regmap_init() as a managed API to get a regmap from the device tree.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Simon Glass sjg@chromium.org
drivers/core/regmap.c | 26 ++++++++++++++++++++++++++ include/regmap.h | 18 ++++++++++++++++++ 2 files changed, 44 insertions(+)
diff --git a/drivers/core/regmap.c b/drivers/core/regmap.c index e9e55c9d16..f69ff6d12f 100644 --- a/drivers/core/regmap.c +++ b/drivers/core/regmap.c @@ -219,6 +219,32 @@ int regmap_init_mem(ofnode node, struct regmap **mapp)
return 0; } + +static void devm_regmap_release(struct udevice *dev, void *res) +{ + regmap_uninit(*(struct regmap **)res); +} + +struct regmap *devm_regmap_init(struct udevice *dev, + const struct regmap_bus *bus, + void *bus_context, + const struct regmap_config *config) +{ + int rc; + struct regmap **mapp; + + mapp = devres_alloc(devm_regmap_release, sizeof(struct regmap *), + __GFP_ZERO); + if (unlikely(!mapp)) + return ERR_PTR(-ENOMEM); + + rc = regmap_init_mem(dev_ofnode(dev), mapp); + if (rc) + return ERR_PTR(rc); + + devres_add(dev, mapp); + return *mapp; +} #endif
void *regmap_get_range(struct regmap *map, unsigned int range_num) diff --git a/include/regmap.h b/include/regmap.h index 9ada1af5ef..624cdd8c98 100644 --- a/include/regmap.h +++ b/include/regmap.h @@ -73,6 +73,9 @@ struct regmap_range { ulong size; };
+struct regmap_bus; +struct regmap_config; + /** * struct regmap - a way of accessing hardware/bus registers * @@ -333,6 +336,21 @@ int regmap_init_mem_platdata(struct udevice *dev, fdt_val_t *reg, int count,
int regmap_init_mem_index(ofnode node, struct regmap **mapp, int index);
+/** + * devm_regmap_init() - Initialise register map (device managed) + * + * @dev: Device that will be interacted with + * @bus: Bus-specific callbacks to use with device (IGNORED) + * @bus_context: Data passed to bus-specific callbacks (IGNORED) + * @config: Configuration for register map (IGNORED) + * + * @Return a valid pointer to a struct regmap or a ERR_PTR() on error. + * The structure is automatically freed when the device is unbound + */ +struct regmap *devm_regmap_init(struct udevice *dev, + const struct regmap_bus *bus, + void *bus_context, + const struct regmap_config *config); /** * regmap_get_range() - Obtain the base memory address of a regmap range *
Some linux drivers provide their own read/write functions to access data from/of the regmap. Adding support for it.
Changes in v2: - Only use custom accessors if {,SPL,TPL}_REGMAP_ACCESSORS is enabled
drivers/core/Kconfig | 25 +++++++++++++++++++++++++ drivers/core/regmap.c | 22 ++++++++++++++++++++-- include/regmap.h | 28 +++++++++++++++++++++++++--- 3 files changed, 70 insertions(+), 5 deletions(-)
diff --git a/drivers/core/Kconfig b/drivers/core/Kconfig index 3b95b5387b..3d836a63bf 100644 --- a/drivers/core/Kconfig +++ b/drivers/core/Kconfig @@ -129,6 +129,31 @@ config TPL_REGMAP support any bus type (I2C, SPI) but so far this only supports direct memory access.
+config REGMAP_ACCESSORS + bool + depends on REGMAP + default y + +config SPL_REGMAP_ACCESSORS + bool "Support custom regmap accessors in SPL" + depends on SPL_REGMAP + help + Allow to use a regmap with custom accessors. The acessors are the + low-level functions actually performing the read and write + operations. + This option can be used to access registers that are not + memory-mapped. + +config TPL_REGMAP_ACCESSORS + bool "Support custom regmap accessors in TPL" + depends on TPL_REGMAP + help + Allow to use a regmap with custom accessors. The acessors are the + low-level functions actually performing the read and write + operations. + This option can be used to access registers that are not + memory-mapped. + config SYSCON bool "Support system controllers" depends on REGMAP diff --git a/drivers/core/regmap.c b/drivers/core/regmap.c index f69ff6d12f..10ae9f918a 100644 --- a/drivers/core/regmap.c +++ b/drivers/core/regmap.c @@ -31,7 +31,11 @@ static struct regmap *regmap_alloc(int count) if (!map) return NULL; map->range_count = count; - +#if CONFIG_IS_ENABLED(REGMAP_ACCESSORS) + map->bus_context = NULL; + map->reg_read = NULL; + map->reg_write = NULL; +#endif return map; }
@@ -241,7 +245,11 @@ struct regmap *devm_regmap_init(struct udevice *dev, rc = regmap_init_mem(dev_ofnode(dev), mapp); if (rc) return ERR_PTR(rc); - +#if CONFIG_IS_ENABLED(REGMAP_ACCESSORS) + (*mapp)->reg_read = config->reg_read; + (*mapp)->reg_write = config->reg_write; + (*mapp)->bus_context = bus_context; +#endif devres_add(dev, mapp); return *mapp; } @@ -320,6 +328,11 @@ int regmap_raw_read_range(struct regmap *map, uint range_num, uint offset, struct regmap_range *range; void *ptr;
+#if CONFIG_IS_ENABLED(REGMAP_ACCESSORS) + if (map->reg_read) + return map->reg_read(map->bus_context, offset, valp); +#endif + if (range_num >= map->range_count) { debug("%s: range index %d larger than range count\n", __func__, range_num); @@ -429,6 +442,11 @@ int regmap_raw_write_range(struct regmap *map, uint range_num, uint offset, struct regmap_range *range; void *ptr;
+#if CONFIG_IS_ENABLED(REGMAP_ACCESSORS) + if (map->reg_write) + return map->reg_write(map->bus_context, offset, + *(unsigned int *)val); +#endif if (range_num >= map->range_count) { debug("%s: range index %d larger than range count\n", __func__, range_num); diff --git a/include/regmap.h b/include/regmap.h index 624cdd8c98..730e747d90 100644 --- a/include/regmap.h +++ b/include/regmap.h @@ -74,16 +74,38 @@ struct regmap_range { };
struct regmap_bus; -struct regmap_config; +/** + * struct regmap_config - a way of accessing hardware/bus registers + * + * @reg_read: Optional callback that if filled will be used to perform + * all the reads from the registers. Should only be provided for + * devices whose read operation cannot be represented as a simple + * read operation on a bus such as SPI, I2C, etc. Most of the + * devices do not need this. + * @reg_write: Same as above for writing. + */ +struct regmap_config { + int (*reg_read)(void *context, unsigned int reg, unsigned int *val); + int (*reg_write)(void *context, unsigned int reg, unsigned int val); +};
/** * struct regmap - a way of accessing hardware/bus registers * * @range_count: Number of ranges available within the map * @ranges: Array of ranges + * @bus_context: Data passed to bus-specific callbacks + * @reg_read: Optional callback that if filled will be used to perform + * all the reads from the registers. + * @reg_write: Same as above for writing. */ struct regmap { enum regmap_endianness_t endianness; +#if CONFIG_IS_ENABLED(REGMAP_ACCESSORS) + void *bus_context; + int (*reg_read)(void *context, unsigned int reg, unsigned int *val); + int (*reg_write)(void *context, unsigned int reg, unsigned int val); +#endif int range_count; struct regmap_range ranges[0]; }; @@ -341,8 +363,8 @@ int regmap_init_mem_index(ofnode node, struct regmap **mapp, int index); * * @dev: Device that will be interacted with * @bus: Bus-specific callbacks to use with device (IGNORED) - * @bus_context: Data passed to bus-specific callbacks (IGNORED) - * @config: Configuration for register map (IGNORED) + * @bus_context: Data passed to bus-specific callbacks + * @config: Configuration for register map * * @Return a valid pointer to a struct regmap or a ERR_PTR() on error. * The structure is automatically freed when the device is unbound
Hi Jean-Jacques,
Changes in v2:
Coming back to the discussion on driver model....
How do you specify the fields? I would expect that this would be done in the driver tree? Perhaps in a subnode of the device?
Just to state what I see as the advantages of using a separate device for access:
- Remove the #ifdef in the regmap struct - Easy to specify the behaviour in a device-tree node - Easy to extend as the child device can do what it likes with respect to access
Disadvantage is that it takes a bit more space.
Hi Simon,
On 10/12/2019 16:18, Simon Glass wrote:
Hi Jean-Jacques,
Changes in v2:
That sure is a better abstraction. However the goal of this patch is only to use the same API as linux. It allows porting the drivers as-is and thus reduce the burden of maintenance.
JJ
Hi Jean-Jacques,
On Mon, 16 Dec 2019 at 03:10, Jean-Jacques Hiblot jjhiblot@ti.com wrote:
Hi Simon,
Hi Jean-Jacques,
Changes in v2:
So how do you specify the fields? See my question above.
It is not possible to use a similar API without importing the internal implementation. Linux's driver model is less homogenous.
Simon,
On 24/12/2019 16:58, Simon Glass wrote:
Hi Jean-Jacques,
Hi Simon,
Hi Jean-Jacques,
Changes in v2:
The fields are filled when creating the regmap.
ex:
static struct regmap_config cfg = { .reg_write = regmaptest_write, .reg_read = regmaptest_read, }; and then regmap = devm_regmap_init(dev, NULL, &ctx, &cfg);
You can have a look at the tests in the last patch of the series.
JJ
Hi Jean-Jacques,
On Wed, 8 Jan 2020 at 09:16, Jean-Jacques Hiblot jjhiblot@ti.com wrote:
Simon,
Hi Jean-Jacques,
Hi Simon,
Hi Jean-Jacques,
Changes in v2:
ex:
JJ
Then I really think we should try to use driver model for the accessors too.
IMO the access method could be described in the device tree. But if not, we could bind the accessor driver as a child.
Hi Simon,
I would be taking up this series and address the comments.
On 10/12/19 03:18PM, Simon Glass wrote:
Hi Jean-Jacques,
Changes in v2:
IIUC, you are suggesting that we create a uclass for regmap, and fill in the ops with the driver's custom read/write functions, correct? This would mean we will have to create udevice for each regmap. A driver can have multiple regmaps (up to 18 for example in the Linux Cadence Sierra PHY driver in kernel). Creating a device for each regmap is very inefficient. Is the overhead really worth it? Does it solve any significant problem? Also, a regmap is not a device, it is an abstraction layer to simplify register access. Does it then make sense to model it as a device?
If you really want to remove the #ifdefs, we can set reg_read to a default, and let drivers override if when creating a regmap. Then in regmap_read, just call reg_read. This gets rid of the #ifdefs with a small change. I suspect this will have a much smaller impact on memory usage than using a udevice.
Quoting from the kernel's documentation of regmap_config:
reg_read: Optional callback that if filled will be used to perform all the reads from the registers. Should only be provided for devices whose read operation cannot be represented as a simple read operation on a bus such as SPI, I2C, etc. Most of the devices do not need this. reg_write: Same as above for writing.
These custom accessors are meant to be used when the read or write needs more work to be done than the standard regmap reads/writes. And so they are supposed to be driver-specific functions. I don't think it is at all possible to specify something like this in devicetree. Am I missing something?
Hi Pratyush,
On Tue, 5 May 2020 at 13:47, Pratyush Yadav p.yadav@ti.com wrote:
Hi Simon,
Hi Jean-Jacques,
Changes in v2:
I was actually referring to the access method of the regmap but I suppose the effect is the same. This question has been running for a while.
The issue is that this is getting more and more complicated. We use devices to model complicated things. It is an abstraction. It doesn't have to be a physical device.
With regmap we are creating an ad-hoc structure and associated infrastructure to deal with this one case. It is not possible to see the regmaps with 'dm dump', for example.
Yes that sounds good, but you are getting closer and closer to it being a device.
Can you point to an example of this extra read/write code?
The kernel is a rabbit-warren of custom interfaces. I am trying to keep driver model uniform, so long as the cost is reasonable. I'm not sure that it is worth having a regmap device for simple things, but as things get more complex, I think we should look at it.
Of course you can specify this in the device tree: just use a compatible string to select the appropriate regmap driver.
spi { compatible = "vendor,myspi"; regmaps = <®map_simple 4 ®map_mailbox 0 FLAGS>; }
regmap_mailbox: regmap-mailbox { compatible = "regmap,mailbox"; other props }
struct regmap *regmap = regmap_get_by_index(dev, 1)
regmap_read(regmap, ...)
Yes space is a concern. A device takes about 84 bytes I think. But as we add more and more complexity we might as well take the hit.
On 06/05/20 8:17 pm, Simon Glass wrote:
Hi Pratyush,
Hi Simon,
Hi Jean-Jacques,
Changes in v2:
Here is the cadence sierra PHY driver for which this series is a pre requiste
https://elixir.bootlin.com/linux/latest/source/drivers/phy/cadence/phy-caden...
PHY Registers are 16 bit wide. Some implementations (SoCs) have arranged these registers continuously (so they are aligned to 16 bit address boundary) but some implementation place each register at 32 bit boundary (wasting the upper 16 bits)
There are few other nits but above is the major one.
Custom regmap read()/write() hooks abstracts all these from actual driver logic.
It is possible to re implement driver w/o regmap abstraction but this would deviate the driver significantly from that of kernel. PHY drivers often get updated with new register settings as and when HW characterization progresses which need to be ported to kernel and U-Boot. Having U-Boot driver same as kernel will ease porting effort and also reduces the chances of errors.
This would mean U-Boot and Kernel DT files would be significantly different and would defeat the whole purpose of maintaining common DT bindings b/w kernel and U-Boot.
IMHO, regmap is pure SW abstraction that hides complexities of accessing underlying register map therefore I don't think representing such abstraction in DT will be accepted by upstream DT maintainers.
If there a way to use DM w/o DT changes, we can definitely explore that...
Hi Vignesh,
Hi Pratyush,
Hi Simon,
Hi Jean-Jacques,
Changes in v2:
OK I see. So it's fairly simple, not accessing through a mailbox, etc.
I actually don't think that argument holds much water. I am not suggesting that the regmap interface be different, so the code should remain the same in the driver. Perhaps the probe() code might change a bit as it sets things up. But there are already differences there.
Yes it means that U-Boot would have extra nodes that the kernel DT does not have. We already have that problem, although I hope with the DTE project U-Boot might finally get a say in what is allowed in the bindings.
That is a very strange argument. Above you told me that the access mechanism is different in the hardware - 16 bits with different positioning, for example. That is exactly the sort of thing the DT is supposed to describe.
You can certainly do that. Just device_bind() a driver that implements your access mechanism. So long as the driver uses the same access mechanism no matter what hardware it is running on, that makes sense. But from what you say above, that might not be true, so you would end up setting the platform data of the regmap driver from its parent. That's not terrible, but not ideal.
Given the simple access you need above, I think you could just add that as another option in the regmap, perhaps turning endianness into some flags?
Hi Simon,
I tried doing it without custom regmap accessors. The rough patch below is what I came up with. Does it look any better than custom accessors?
PS: I can probably play around with regmap ranges instead of using 'base_offset', but it gets the job done minimally so I think it is good enough for a proof-of-concept.
-- 8< -- Subject: [RFC PATCH] regmap: allow specifying base offset and register shift and access size
To accommodate more complex access patterns that are needed in the Cadence Sierra PHY driver (which will be added as a follow-up), introduce 'base_offset' and 'reg_offset_shift', two values that can be used to adjust the final regmap read/write address.
'base_offset' is an extra offset on the regmap base discovered from the device tree. This is useful when some regmaps of a device need to access memory at one offset, and some at another.
'reg_offset_shift' will shift the register offset left before access.
'size' can be used to specify the width of reads (1/2/4/8 bytes). If 0, defaults to 4 bytes to maintain backward compatibility.
Signed-off-by: Pratyush Yadav p.yadav@ti.com --- drivers/core/regmap.c | 16 ++++++++++++---- include/regmap.h | 27 ++++++++++++++++++++++++++- 2 files changed, 38 insertions(+), 5 deletions(-)
diff --git a/drivers/core/regmap.c b/drivers/core/regmap.c index 41293e5af0..9bce719b45 100644 --- a/drivers/core/regmap.c +++ b/drivers/core/regmap.c @@ -38,6 +38,7 @@ static struct regmap *regmap_alloc(int count) map = malloc(sizeof(*map) + sizeof(map->ranges[0]) * count); if (!map) return NULL; + memset(map, 0, sizeof(*map)); map->range_count = count;
return map; @@ -258,6 +259,10 @@ struct regmap *devm_regmap_init(struct udevice *dev, if (rc) return ERR_PTR(rc);
+ (*mapp)->base_offset = config->base_offset; + (*mapp)->reg_offset_shift = config->reg_offset_shift; + (*mapp)->size = config->size; + devres_add(dev, mapp); return *mapp; } @@ -343,7 +348,9 @@ int regmap_raw_read_range(struct regmap *map, uint range_num, uint offset, } range = &map->ranges[range_num];
- ptr = map_physmem(range->start + offset, val_len, MAP_NOCACHE); + offset <<= map->reg_offset_shift; + + ptr = map_physmem(range->start + map->base_offset + offset, val_len, MAP_NOCACHE);
if (offset + val_len > range->size) { debug("%s: offset/size combination invalid\n", __func__); @@ -380,7 +387,7 @@ int regmap_raw_read(struct regmap *map, uint offset, void *valp, size_t val_len)
int regmap_read(struct regmap *map, uint offset, uint *valp) { - return regmap_raw_read(map, offset, valp, REGMAP_SIZE_32); + return regmap_raw_read(map, offset, valp, map->size ? map->size : REGMAP_SIZE_32); }
static inline void __write_8(u8 *addr, const u8 *val, @@ -452,7 +459,8 @@ int regmap_raw_write_range(struct regmap *map, uint range_num, uint offset, } range = &map->ranges[range_num];
- ptr = map_physmem(range->start + offset, val_len, MAP_NOCACHE); + offset <<= map->reg_offset_shift; + ptr = map_physmem(range->start + map->base_offset + offset, val_len, MAP_NOCACHE);
if (offset + val_len > range->size) { debug("%s: offset/size combination invalid\n", __func__); @@ -490,7 +498,7 @@ int regmap_raw_write(struct regmap *map, uint offset, const void *val,
int regmap_write(struct regmap *map, uint offset, uint val) { - return regmap_raw_write(map, offset, &val, REGMAP_SIZE_32); + return regmap_raw_write(map, offset, &val, map->size ? map->size : REGMAP_SIZE_32); }
int regmap_update_bits(struct regmap *map, uint offset, uint mask, uint val) diff --git a/include/regmap.h b/include/regmap.h index 2edbf9359a..4adb04f7e3 100644 --- a/include/regmap.h +++ b/include/regmap.h @@ -74,16 +74,41 @@ struct regmap_range { };
struct regmap_bus; -struct regmap_config; +/** + * struct regmap_config - a way of accessing hardware/bus registers + * + * @base_offset: Offset from the base of the regmap for reads and writes. + * (OPTIONAL) + * @reg_offset_shift: Left shift register offset by this value before + * performing reads or writes. (OPTIONAL) + * @size: Size/width of the read or write operation. Defaults to + * REGMAP_SIZE_32 if set to zero. + */ +struct regmap_config { + u32 base_offset; + u32 reg_offset_shift; + enum regmap_size_t size; +};
/** * struct regmap - a way of accessing hardware/bus registers * + * @base_offset: Offset from the base of the regmap for reads and writes. + * (OPTIONAL) + * @reg_offset_shift: Left shift register offset by this value before + * performing reads or writes. (OPTIONAL) + * @size: Size/width of the read or write operation. Defaults to + * REGMAP_SIZE_32 if set to zero. * @range_count: Number of ranges available within the map * @ranges: Array of ranges */ struct regmap { enum regmap_endianness_t endianness; + + u32 base_offset; + u32 reg_offset_shift; + enum regmap_size_t size; + int range_count; struct regmap_range ranges[0]; };
Hi Pratyush,
On Mon, 11 May 2020 at 06:00, Yadav, Pratyush p.yadav@ti.com wrote:
Hi Simon,
This looks OK. Should use a local variable instead of (*mapp)-> though. Also please add docs.
- SImon
memset(map, 0, sizeof(*map)); map->range_count = count; return map;
ptr = map_physmem(range->start + map->base_offset + offset, val_len, MAP_NOCACHE); if (offset + val_len > range->size) { debug("%s: offset/size combination invalid\n", __func__);
- struct regmap_config - a way of accessing hardware/bus registers
- @base_offset: Offset from the base of the regmap for reads and writes.
(OPTIONAL)
- @reg_offset_shift: Left shift register offset by this value before
- @size: Size/width of the read or write operation. Defaults to
u32 base_offset;
- struct regmap - a way of accessing hardware/bus registers
(OPTIONAL)
- @range_count: Number of ranges available within the map
- @ranges: Array of ranges
u32 base_offset;
-- Regards, Pratyush Yadav Texas Instruments India
A regmap field is an abstraction available in Linux. It provides to access bitfields in a regmap without having to worry about shifts and masks.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v2: None
drivers/core/regmap.c | 77 ++++++++++++++++++++++++++++++ include/regmap.h | 108 ++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 185 insertions(+)
diff --git a/drivers/core/regmap.c b/drivers/core/regmap.c index 10ae9f918a..905bc0b63d 100644 --- a/drivers/core/regmap.c +++ b/drivers/core/regmap.c @@ -15,6 +15,14 @@ #include <dm/of_addr.h> #include <linux/ioport.h>
+struct regmap_field { + struct regmap *regmap; + unsigned int mask; + /* lsb */ + unsigned int shift; + unsigned int reg; +}; + DECLARE_GLOBAL_DATA_PTR;
/** @@ -508,3 +516,72 @@ int regmap_update_bits(struct regmap *map, uint offset, uint mask, uint val)
return regmap_write(map, offset, reg | (val & mask)); } + +int regmap_field_read(struct regmap_field *field, unsigned int *val) +{ + int ret; + unsigned int reg_val; + + ret = regmap_read(field->regmap, field->reg, ®_val); + if (ret != 0) + return ret; + + reg_val &= field->mask; + reg_val >>= field->shift; + *val = reg_val; + + return ret; +} + +int regmap_field_write(struct regmap_field *field, unsigned int val) +{ + return regmap_update_bits(field->regmap, field->reg, field->mask, + val << field->shift); +} + +static void regmap_field_init(struct regmap_field *rm_field, + struct regmap *regmap, + struct reg_field reg_field) +{ + rm_field->regmap = regmap; + rm_field->reg = reg_field.reg; + rm_field->shift = reg_field.lsb; + rm_field->mask = GENMASK(reg_field.msb, reg_field.lsb); +} + +struct regmap_field *devm_regmap_field_alloc(struct udevice *dev, + struct regmap *regmap, + struct reg_field reg_field) +{ + struct regmap_field *rm_field = devm_kzalloc(dev, sizeof(*rm_field), + GFP_KERNEL); + if (!rm_field) + return ERR_PTR(-ENOMEM); + + regmap_field_init(rm_field, regmap, reg_field); + + return rm_field; +} + +void devm_regmap_field_free(struct udevice *dev, struct regmap_field *field) +{ + devm_kfree(dev, field); +} + +struct regmap_field *regmap_field_alloc(struct regmap *regmap, + struct reg_field reg_field) +{ + struct regmap_field *rm_field = kzalloc(sizeof(*rm_field), GFP_KERNEL); + + if (!rm_field) + return ERR_PTR(-ENOMEM); + + regmap_field_init(rm_field, regmap, reg_field); + + return rm_field; +} + +void regmap_field_free(struct regmap_field *field) +{ + kfree(field); +} diff --git a/include/regmap.h b/include/regmap.h index 730e747d90..8619566a95 100644 --- a/include/regmap.h +++ b/include/regmap.h @@ -314,6 +314,43 @@ int regmap_raw_read_range(struct regmap *map, uint range_num, uint offset, regmap_read_poll_timeout_test(map, addr, val, cond, sleep_us, \ timeout_ms, 0) \
+/** + * regmap_field_read_poll_timeout - Poll until a condition is met or a timeout + * occurs + * + * @field: Regmap field to read from + * @val: Unsigned integer variable to read the value into + * @cond: Break condition (usually involving @val) + * @sleep_us: Maximum time to sleep between reads in us (0 tight-loops). + * @timeout_ms: Timeout in ms, 0 means never timeout + * + * Returns 0 on success and -ETIMEDOUT upon a timeout or the regmap_field_read + * error return value in case of a error read. In the two former cases, + * the last read value at @addr is stored in @val. + * + * This is modelled after the regmap_read_poll_timeout macros in linux but + * with millisecond timeout. + */ +#define regmap_field_read_poll_timeout(field, val, cond, sleep_us, timeout_ms) \ +({ \ + unsigned long __start = get_timer(0); \ + int __ret; \ + for (;;) { \ + __ret = regmap_field_read((field), &(val)); \ + if (__ret) \ + break; \ + if (cond) \ + break; \ + if ((timeout_ms) && get_timer(__start) > (timeout_ms)) { \ + __ret = regmap_field_read((field), &(val)); \ + break; \ + } \ + if ((sleep_us)) \ + udelay((sleep_us)); \ + } \ + __ret ?: ((cond) ? 0 : -ETIMEDOUT); \ +}) + /** * regmap_update_bits() - Perform a read/modify/write using a mask * @@ -390,4 +427,75 @@ void *regmap_get_range(struct regmap *map, unsigned int range_num); */ int regmap_uninit(struct regmap *map);
+/** + * struct reg_field - Description of an register field + * + * @reg: Offset of the register within the regmap bank + * @lsb: lsb of the register field. + * @msb: msb of the register field. + * @id_size: port size if it has some ports + * @id_offset: address offset for each ports + */ +struct reg_field { + unsigned int reg; + unsigned int lsb; + unsigned int msb; +}; + +struct regmap_field; + +#define REG_FIELD(_reg, _lsb, _msb) { \ + .reg = _reg, \ + .lsb = _lsb, \ + .msb = _msb, \ + } + +/** + * devm_regmap_field_alloc() - Allocate and initialise a register field. + * + * @dev: Device that will be interacted with + * @regmap: regmap bank in which this register field is located. + * @reg_field: Register field with in the bank. + * + * The return value will be an ERR_PTR() on error or a valid pointer + * to a struct regmap_field. The regmap_field will be automatically freed + * by the device management code. + */ +struct regmap_field *devm_regmap_field_alloc(struct udevice *dev, + struct regmap *regmap, + struct reg_field reg_field); +/** + * devm_regmap_field_free() - Free a register field allocated using + * devm_regmap_field_alloc. + * + * @dev: Device that will be interacted with + * @field: regmap field which should be freed. + * + * Free register field allocated using devm_regmap_field_alloc(). Usually + * drivers need not call this function, as the memory allocated via devm + * will be freed as per device-driver life-cyle. + */ +void devm_regmap_field_free(struct udevice *dev, struct regmap_field *field); + +/** + * regmap_field_write() - Write a value to a regmap field + * + * @field: Regmap field to write to + * @val: Data to write to the regmap at the specified offset + * + * Return: 0 if OK, -ve on error + */ +int regmap_field_write(struct regmap_field *field, unsigned int val); + +/** + * regmap_read() - Read a 32-bit value from a regmap + * + * @field: Regmap field to write to + * @valp: Pointer to the buffer to receive the data read from the regmap + * field + * + * Return: 0 if OK, -ve on error + */ +int regmap_field_read(struct regmap_field *field, unsigned int *val); + #endif
The tests rely on a dummy driver to allocate and initialize the regmap and the regmap fields using the managed API. The first test checks that the read/write callbacks are used. The second test checks if regmap fields behave properly (mask and shift are ok) by peeking into the regmap.
Changes in v2: None
arch/sandbox/dts/test.dts | 13 +++ test/dm/regmap.c | 189 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 202 insertions(+)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index fdb08f2111..aa9eaec338 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -889,6 +889,19 @@ mdio: mdio-test { compatible = "sandbox,mdio"; }; + + some_regmapped-bus { + #address-cells = <0x1>; + #size-cells = <0x1>; + + ranges = <0x0 0x0 0x10>; + compatible = "simple-bus"; + + regmap-test_0 { + reg = <0 0x10>; + compatible = "sandbox,regmap_test"; + }; + }; };
#include "sandbox_pmic.dtsi" diff --git a/test/dm/regmap.c b/test/dm/regmap.c index 6fd1f20656..1a0dc78019 100644 --- a/test/dm/regmap.c +++ b/test/dm/regmap.c @@ -184,3 +184,192 @@ static int dm_test_regmap_poll(struct unit_test_state *uts) }
DM_TEST(dm_test_regmap_poll, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +struct regmaptest_priv { + struct regmap *regmap; + struct regmap_field **fields; +}; + +#define REGMAP_TEST_BUF_SZ 12 +struct regmaptest_context { + unsigned short buffer[REGMAP_TEST_BUF_SZ]; +} ctx; + +static int regmaptest_write(void *context, unsigned int reg, unsigned int val) +{ + struct regmaptest_context *ctx = context; + + if (reg < ARRAY_SIZE(ctx->buffer)) { + ctx->buffer[reg] = val; + return 0; + } + return -ERANGE; +} + +static int regmaptest_read(void *context, unsigned int reg, unsigned int *val) +{ + struct regmaptest_context *ctx = context; + + if (reg < ARRAY_SIZE(ctx->buffer)) { + *val = ctx->buffer[reg]; + return 0; + } + + return -ERANGE; +} + +static struct regmap_config cfg = { + .reg_write = regmaptest_write, + .reg_read = regmaptest_read, +}; + +static const struct reg_field field_cfgs[] = { + { + .reg = 0, + .lsb = 0, + .msb = 6, + }, + { + .reg = 1, + .lsb = 4, + .msb = 12, + }, + { + .reg = 1, + .lsb = 12, + .msb = 15, + } +}; + +static int remaptest_probe(struct udevice *dev) +{ + struct regmaptest_priv *priv = dev_get_priv(dev); + struct regmap *regmap; + struct regmap_field *field; + int i; + static const int n = ARRAY_SIZE(field_cfgs); + + regmap = devm_regmap_init(dev, NULL, &ctx, &cfg); + if (IS_ERR(regmap)) + return PTR_ERR(regmap); + priv->regmap = regmap; + + priv->fields = devm_kzalloc(dev, sizeof(struct regmap_field *) * n, + GFP_KERNEL); + if (!priv->fields) + return -ENOMEM; + + for (i = 0 ; i < n; i++) { + field = devm_regmap_field_alloc(dev, regmap, field_cfgs[i]); + if (IS_ERR(field)) + return PTR_ERR(field); + priv->fields[i] = field; + } + return 0; +} + +static const struct udevice_id regmaptest_ids[] = { + { .compatible = "sandbox,regmap_test" }, + { } +}; + +U_BOOT_DRIVER(regmap_test) = { + .name = "regmaptest_drv", + .of_match = regmaptest_ids, + .id = UCLASS_NOP, + .probe = remaptest_probe, + .priv_auto_alloc_size = sizeof(struct regmaptest_priv), +}; + +static int dm_test_devm_regmap(struct unit_test_state *uts) +{ + int i = 0; + u32 val; + u16 pattern[REGMAP_TEST_BUF_SZ]; + struct udevice *dev; + struct regmaptest_priv *priv; + + ut_assertok(uclass_get_device_by_name(UCLASS_NOP, "regmap-test_0", + &dev)); + + priv = dev_get_priv(dev); + + srand(get_ticks() + rand()); + for (i = REGMAP_TEST_BUF_SZ - 1; i >= 0; i--) { + pattern[i] = rand() & 0xFFFF; + ut_assertok(regmap_write(priv->regmap, i, pattern[i])); + } + for (i = 0; i < REGMAP_TEST_BUF_SZ; i++) { + ut_assertok(regmap_read(priv->regmap, i, &val)); + ut_asserteq(val, ctx.buffer[i]); + ut_asserteq(val, pattern[i]); + } + + ut_asserteq(-ERANGE, regmap_write(priv->regmap, REGMAP_TEST_BUF_SZ, + val)); + ut_asserteq(-ERANGE, regmap_read(priv->regmap, REGMAP_TEST_BUF_SZ, + &val)); + ut_asserteq(-ERANGE, regmap_write(priv->regmap, -1, val)); + ut_asserteq(-ERANGE, regmap_read(priv->regmap, -1, &val)); + + return 0; +} +DM_TEST(dm_test_devm_regmap, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +static int test_one_field(struct unit_test_state *uts, + struct regmap *regmap, + struct regmap_field *field, + struct reg_field field_cfg) +{ + int j; + unsigned int val; + int mask = (1 << (field_cfg.msb - field_cfg.lsb + 1)) - 1; + int shift = field_cfg.lsb; + + ut_assertok(regmap_write(regmap, field_cfg.reg, 0)); + ut_assertok(regmap_read(regmap, field_cfg.reg, &val)); + ut_asserteq(0, val); + + for (j = 0; j <= mask; j++) { + ut_assertok(regmap_field_write(field, j)); + ut_assertok(regmap_field_read(field, &val)); + ut_asserteq(j, val); + ut_assertok(regmap_read(regmap, field_cfg.reg, &val)); + ut_asserteq(j << shift, val); + } + + ut_assertok(regmap_field_write(field, mask + 1)); + ut_assertok(regmap_read(regmap, field_cfg.reg, &val)); + ut_asserteq(0, val); + + ut_assertok(regmap_field_write(field, 0xFFFF)); + ut_assertok(regmap_read(regmap, field_cfg.reg, &val)); + ut_asserteq(mask << shift, val); + + ut_assertok(regmap_write(regmap, field_cfg.reg, 0xFFFF)); + ut_assertok(regmap_field_write(field, 0)); + ut_assertok(regmap_read(regmap, field_cfg.reg, &val)); + ut_asserteq(0xFFFF & ~(mask << shift), val); + return 0; +} + +static int dm_test_devm_regmap_field(struct unit_test_state *uts) +{ + int i, rc; + struct udevice *dev; + struct regmaptest_priv *priv; + + ut_assertok(uclass_get_device_by_name(UCLASS_NOP, "regmap-test_0", + &dev)); + priv = dev_get_priv(dev); + + for (i = 0 ; i < ARRAY_SIZE(field_cfgs); i++) { + rc = test_one_field(uts, priv->regmap, priv->fields[i], + field_cfgs[i]); + if (rc) + break; + } + + return 0; +} +DM_TEST(dm_test_devm_regmap_field, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
participants (5)
Jean-Jacques Hiblot
Pratyush Yadav
Vignesh Raghavendra
Yadav, Pratyush
