[PATCH] i2c: designware_i2c: Correct the selection of speed mode
Unfortunately a recent change adjusted the order of the checks here such that 400MHz now shows up as fast-plus speed (1Mbps). Fix it.
Signed-off-by: Simon Glass sjg@chromium.org Fixes: d96440d1e3 ("i2c: designware_i2c: Add support for fast-plus speed") ---
drivers/i2c/designware_i2c.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/i2c/designware_i2c.c b/drivers/i2c/designware_i2c.c index e1d5aeb19d..0b5e70af59 100644 --- a/drivers/i2c/designware_i2c.c +++ b/drivers/i2c/designware_i2c.c @@ -212,9 +212,9 @@ static int calc_bus_speed(struct dw_i2c *priv, int speed, ulong bus_clk, if (speed >= I2C_SPEED_HIGH_RATE && (!scl_sda_cfg || scl_sda_cfg->has_high_speed)) i2c_spd = IC_SPEED_MODE_HIGH; - else if (speed >= I2C_SPEED_FAST_RATE) - i2c_spd = IC_SPEED_MODE_FAST_PLUS; else if (speed >= I2C_SPEED_FAST_PLUS_RATE) + i2c_spd = IC_SPEED_MODE_FAST_PLUS; + else if (speed >= I2C_SPEED_FAST_RATE) i2c_spd = IC_SPEED_MODE_FAST; else i2c_spd = IC_SPEED_MODE_STANDARD;
Hello Simon,
Am 13.02.2020 um 21:24 schrieb Simon Glass:
Reviewed-by: Heiko Schocher hs@denx.de
I started travis build, and if successful, I send pull request to Tom soon, thanks for detecting this.
bye, Heiko
Hello Simon,
Applied to u-boot-i2c master
Thanks!
bye, Heiko
Heiko Schocher
