[U-Boot] [PATCH 0/2] arm64: tidy up POSITION_INDEPENDENT feature and enable it for Socionext SoCs
1/2 needs ACK from NVIDIA folks.
I want to enable it in 2/2 for my platform.
Masahiro Yamada (2): arm64: add an option to switch visibility of CONFIG_SYS_INIT_SP_BSS_OFFSET ARM: uniphier_v8_defconfig: make 64bit SoC image position independent
Makefile | 4 ++-- arch/arm/Kconfig | 20 ++++++++++++++----- .../armv8/linux-kernel-image-header-vars.h | 2 +- arch/arm/lib/crt0_64.S | 2 +- arch/arm/mach-tegra/Kconfig | 1 + arch/arm/mach-tegra/tegra186/Kconfig | 3 --- arch/arm/mach-tegra/tegra210/Kconfig | 3 --- configs/uniphier_v8_defconfig | 4 +++- 8 files changed, 23 insertions(+), 16 deletions(-)
By default, CONFIG_SYS_INIT_SP_BSS_OFFSET was made invisible by not giving a prompt to it.
The only way to define it is to hard-code an extra entry in SoC/board Kconfig, like arch/arm/mach-tegra/tegra{186,210}/Kconfig.
Add a prompt to it in order to allow defconfig files to specify the value of CONFIG_SYS_INIT_SP_BSS_OFFSET.
With this, CONFIG_SYS_INIT_SP_BSS_OFFSET would become always visible. So, we need a new bool option to turn it off by default.
I move the 'default 524288' to the common place. This value is not too big, but is big enough to avoid the overwrap of DT in most platforms. If 512KB is not a suitable choice for your platform, you can change it from your defconfig or menuconfig etc.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Perhaps, another idea is to use "offset from TEXT_BASE", allowing a negative offset value.
For example, include/configs/uniphier.h defines:
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE)
My intention is, allocate the early stack _before_ the U-Boot binary, not after it.
With this, I do not need to care about the region conflict with other sections.
The disadvantage of this approach is, you cannot load U-Boot to the very start of the memory.
Just an idea.
Makefile | 4 ++-- arch/arm/Kconfig | 20 ++++++++++++++----- .../armv8/linux-kernel-image-header-vars.h | 2 +- arch/arm/lib/crt0_64.S | 2 +- arch/arm/mach-tegra/Kconfig | 1 + arch/arm/mach-tegra/tegra186/Kconfig | 3 --- arch/arm/mach-tegra/tegra210/Kconfig | 3 --- 7 files changed, 20 insertions(+), 15 deletions(-)
diff --git a/Makefile b/Makefile index 6335834d12e1..9a5afd3098ce 100644 --- a/Makefile +++ b/Makefile @@ -874,7 +874,7 @@ ifneq ($(CONFIG_BUILD_TARGET),) ALL-y += $(CONFIG_BUILD_TARGET:"%"=%) endif
-ifneq ($(CONFIG_SYS_INIT_SP_BSS_OFFSET),) +ifdef CONFIG_INIT_SP_RELATIVE ALL-y += init_sp_bss_offset_check endif
@@ -1155,7 +1155,7 @@ binary_size_check: u-boot-nodtb.bin FORCE fi \ fi
-ifneq ($(CONFIG_SYS_INIT_SP_BSS_OFFSET),) +ifdef CONFIG_INIT_SP_RELATIVE ifneq ($(CONFIG_SYS_MALLOC_F_LEN),) subtract_sys_malloc_f_len = space=$$(($${space} - $(CONFIG_SYS_MALLOC_F_LEN))) else diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f5a7630e4f99..87541977259c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -20,15 +20,25 @@ config POSITION_INDEPENDENT information that is embedded into the binary to support U-Boot relocating itself to the top-of-RAM later during execution.
-config SYS_INIT_SP_BSS_OFFSET - int +config INIT_SP_RELATIVE + bool "Specify the early stack pointer relative to the .bss section" help U-Boot typically uses a hard-coded value for the stack pointer - before relocation. Define this option to instead calculate the + before relocation. Enable this option to instead calculate the initial SP at run-time. This is useful to avoid hard-coding addresses into U-Boot, so that can be loaded and executed at arbitrary - addresses and thus avoid using arbitrary addresses at runtime. This - option's value is the offset added to &_bss_start in order to + addresses and thus avoid using arbitrary addresses at runtime. + + If this option is enabled, the early stack pointer is set to + &_bss_start with a offset value added. The offset is specified by + SYS_INIT_SP_BSS_OFFSET. + +config SYS_INIT_SP_BSS_OFFSET + int "Early stack offset from the .bss base address" + depends on INIT_SP_RELATIVE + default 524288 + help + This option's value is the offset added to &_bss_start in order to calculate the stack pointer. This offset should be large enough so that the early malloc region, global data (gd), and early stack usage do not overlap any appended DTB. diff --git a/arch/arm/cpu/armv8/linux-kernel-image-header-vars.h b/arch/arm/cpu/armv8/linux-kernel-image-header-vars.h index fa6e86d1c24b..b4220e4936f0 100644 --- a/arch/arm/cpu/armv8/linux-kernel-image-header-vars.h +++ b/arch/arm/cpu/armv8/linux-kernel-image-header-vars.h @@ -48,7 +48,7 @@ #define __MAX(a, b) (((a) > (b)) ? (a) : (b)) #define __CODE_DATA_SIZE (__bss_start - _start) #define __BSS_SIZE (__bss_end - __bss_start) -#ifdef CONFIG_SYS_INIT_SP_BSS_OFFSET +#ifdef CONFIG_INIT_SP_RELATIVE #define __MAX_EXTRA_RAM_USAGE __MAX(__BSS_SIZE, CONFIG_SYS_INIT_SP_BSS_OFFSET) #else #define __MAX_EXTRA_RAM_USAGE __BSS_SIZE diff --git a/arch/arm/lib/crt0_64.S b/arch/arm/lib/crt0_64.S index d6b632aa87d1..e76b25a03e8c 100644 --- a/arch/arm/lib/crt0_64.S +++ b/arch/arm/lib/crt0_64.S @@ -72,7 +72,7 @@ ENTRY(_main) ldr x0, =(CONFIG_TPL_STACK) #elif defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) ldr x0, =(CONFIG_SPL_STACK) -#elif defined(CONFIG_SYS_INIT_SP_BSS_OFFSET) +#elif defined(CONFIG_INIT_SP_RELATIVE) adr x0, __bss_start add x0, x0, #CONFIG_SYS_INIT_SP_BSS_OFFSET #else diff --git a/arch/arm/mach-tegra/Kconfig b/arch/arm/mach-tegra/Kconfig index 97e22ead5985..ff9f29f2d5d0 100644 --- a/arch/arm/mach-tegra/Kconfig +++ b/arch/arm/mach-tegra/Kconfig @@ -86,6 +86,7 @@ config TEGRA_ARMV7_COMMON config TEGRA_ARMV8_COMMON bool "Tegra 64-bit common options" select ARM64 + select INIT_SP_RELATIVE select LINUX_KERNEL_IMAGE_HEADER select POSITION_INDEPENDENT select TEGRA_COMMON diff --git a/arch/arm/mach-tegra/tegra186/Kconfig b/arch/arm/mach-tegra/tegra186/Kconfig index 479c0955eec6..b2e53b58caf8 100644 --- a/arch/arm/mach-tegra/tegra186/Kconfig +++ b/arch/arm/mach-tegra/tegra186/Kconfig @@ -21,9 +21,6 @@ endchoice config SYS_SOC default "tegra186"
-config SYS_INIT_SP_BSS_OFFSET - default 524288 - source "board/nvidia/p2771-0000/Kconfig"
endif diff --git a/arch/arm/mach-tegra/tegra210/Kconfig b/arch/arm/mach-tegra/tegra210/Kconfig index 250738aed312..3637473051b8 100644 --- a/arch/arm/mach-tegra/tegra210/Kconfig +++ b/arch/arm/mach-tegra/tegra210/Kconfig @@ -40,9 +40,6 @@ endchoice config SYS_SOC default "tegra210"
-config SYS_INIT_SP_BSS_OFFSET - default 524288 - source "board/nvidia/e2220-1170/Kconfig" source "board/nvidia/p2371-0000/Kconfig" source "board/nvidia/p2371-2180/Kconfig"
Yamada-san,
Just an idea.
This config/target will create a dependency of u-boot.dtb target, and it will cause an error in building dtbs for qemu_arm64 which doesn't expect any dtb. You will see messages like:
Device Tree Source is not correctly specified. Please define 'CONFIG_DEFAULT_DEVICE_TREE' or build with 'DEVICE_TREE=<device_tree>' argument
/home/akashi/arm/armv8/linaro/u-boot/dts/Makefile:28: recipe for target 'arch/arm/dts/unset.dtb' failed make[2]: *** [arch/arm/dts/unset.dtb] Error 1 /home/akashi/arm/armv8/linaro/u-boot/Makefile:1052: recipe for target 'dts/dt.dtb' failed make[1]: *** [dts/dt.dtb] Error 2 <<<
-Takahiro Akashi
endif
- int
- bool "Specify the early stack pointer relative to the .bss section" help U-Boot typically uses a hard-coded value for the stack pointer
initial SP at run-time. This is useful to avoid hard-coding addresses into U-Boot, so that can be loaded and executed at arbitrarybefore relocation. Enable this option to instead calculate the
- int "Early stack offset from the .bss base address"
- depends on INIT_SP_RELATIVE
- default 524288
- help
calculate the stack pointer. This offset should be large enough so that the early malloc region, global data (gd), and early stack usage do not overlap any appended DTB.This option's value is the offset added to &_bss_start in order to
- select INIT_SP_RELATIVE select LINUX_KERNEL_IMAGE_HEADER select POSITION_INDEPENDENT select TEGRA_COMMON
- default 524288
- default 524288
source "board/nvidia/e2220-1170/Kconfig" source "board/nvidia/p2371-0000/Kconfig" source "board/nvidia/p2371-2180/Kconfig" -- 2.17.1
Hi AKASHI-san
On Thu, Jun 27, 2019 at 9:44 AM AKASHI Takahiro takahiro.akashi@linaro.org wrote:
Yamada-san,
Just an idea.
Nope. I do not see any build error for qemu_arm64_defconfig
Probably because you *locally* defined CONFIG_INIT_SP_RELATIVE=y
Moreover, the line causing this issue is this:
init_sp_bss_offset_check: u-boot.dtb FORCE
..., which was added by the following commit:
commit 5fed97af20da955625cc06563a725b49cebb99eb Author: Stephen Warren swarren@nvidia.com Date: Tue Jan 9 12:52:14 2018 -0700
Makefile: ensure DTB doesn't overflow into initial stack
If you want to fix it, a patch is welcome, but my patch is innocent.
Thanks.
Acked-by: Stephen Warren swarren@nvidia.com
For a planned new SoC in this SoC family, the base address of the DRAM will be changed from 0x80000000 to 0x20000000.
The PIE support will be useful to maintain multiple similar SoCs whose DRAM addresses are different.
Now CONFIG_SYS_TEXT_BASE is not important. I just set it to 0 to ensure CONFIG_POSITION_INDEPENDENT is working.
configs/uniphier_v8_defconfig | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/configs/uniphier_v8_defconfig b/configs/uniphier_v8_defconfig index 83f78776b7d2..3908ff80d6b0 100644 --- a/configs/uniphier_v8_defconfig +++ b/configs/uniphier_v8_defconfig @@ -1,7 +1,9 @@ CONFIG_ARM=y +CONFIG_POSITION_INDEPENDENT=y +CONFIG_INIT_SP_RELATIVE=y CONFIG_ARM_SMCCC=y CONFIG_ARCH_UNIPHIER=y -CONFIG_SYS_TEXT_BASE=0x84000000 +CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=3 CONFIG_ARCH_UNIPHIER_V8_MULTI=y
AKASHI Takahiro
Masahiro Yamada
Stephen Warren
