[U-Boot] [PATCH 1/3] gplugd: use CONFIG_MACH_TYPE instead of MACH_TYPE_SHEEVAD
mach-type update will rename MACH_TYPE_SHEEVAD to MACH_TYPE_GPLUGD
Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com --- board/Marvell/gplugd/gplugd.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/board/Marvell/gplugd/gplugd.c b/board/Marvell/gplugd/gplugd.c index a697c19..8d9916a 100644 --- a/board/Marvell/gplugd/gplugd.c +++ b/board/Marvell/gplugd/gplugd.c @@ -92,7 +92,7 @@ int board_init(void) (struct armd1apb2_registers *)ARMD1_APBC2_BASE;
/* arch number of Board */ - gd->bd->bi_arch_number = MACH_TYPE_SHEEVAD; + gd->bd->bi_arch_number = CONFIG_MACH_TYPE; /* adress of boot parameters */ gd->bd->bi_boot_params = armd1_sdram_base(0) + 0x100; /* Assert PHY_RST# */
ventana uses board/nvidia/seaboard/seaboard.c which uses machine_is_ventana.
Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com --- include/configs/ventana.h | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/include/configs/ventana.h b/include/configs/ventana.h index acc9b43..b5caebb 100644 --- a/include/configs/ventana.h +++ b/include/configs/ventana.h @@ -24,6 +24,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_MACH_VENTANA + #include <asm/sizes.h> #include "tegra2-common.h"
It'd be nice not to have to do this; that header already does:
#define CONFIG_MACH_TYPE MACH_TYPE_VENTANA
Can't the code key off that? Otherwise, any use of machine_is_xxx() will be very error-prone, since CONFIG_MACH_XXX has to be manually defined, and people will forget.
This updates u-boot to the same as the Dec 6, 2011 mach-types upate to Linux.
Note: 1. MACH_TYPE_SMDK5250 changed value from 3774 to 3825 2. MACH_TYPE_SHEEVAD has become MACH_TYPE_GPLUGD 3. MACH_TYPE_TIAM335EVM has become MACH_TYPE_AM335XEVM
Before this patch MAKEALL -a arm gives Boards compiled: 226 Boards with warnings or errors: 80
After this patch MAKEALL -a arm gives Boards compiled: 226 Boards with warnings or errors: 80
Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com --- arch/arm/include/asm/mach-types.h | 6490 +++++++++++++++++++++---------------- include/configs/am335x_evm.h | 3 +- include/configs/calimain.h | 1 - include/configs/dns325.h | 1 - include/configs/dreamplug.h | 13 - include/configs/ea20.h | 12 + include/configs/enbw_cmc.h | 1 - include/configs/flea3.h | 5 - include/configs/gplugd.h | 12 +- include/configs/m28evk.h | 5 - include/configs/mcx.h | 1 - include/configs/mt_ventoux.h | 1 - include/configs/omap3_mvblx.h | 11 + include/configs/seaboard.h | 7 + include/configs/smdk5250.h | 2 - include/configs/top9000.h | 11 + include/configs/tricorder.h | 11 + include/configs/tx25.h | 4 - include/configs/ventana.h | 15 + include/configs/zmx25.h | 11 + 20 files changed, 3689 insertions(+), 2928 deletions(-)
diff --git a/arch/arm/include/asm/mach-types.h b/arch/arm/include/asm/mach-types.h index 2d5c3bc..a7db956 100644 --- a/arch/arm/include/asm/mach-types.h +++ b/arch/arm/include/asm/mach-types.h @@ -56,6 +56,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_H7202 162 #define MACH_TYPE_IQ80321 169 #define MACH_TYPE_KS8695 180 +#define MACH_TYPE_KARO 190 #define MACH_TYPE_SMDK2410 193 #define MACH_TYPE_CEIVA 200 #define MACH_TYPE_VOICEBLUE 218 @@ -179,6 +180,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_DAVINCI_EVM 901 #define MACH_TYPE_PALMZ72 904 #define MACH_TYPE_NXDB500 905 +#define MACH_TYPE_APF9328 906 #define MACH_TYPE_PALMT5 917 #define MACH_TYPE_PALMTC 918 #define MACH_TYPE_OMAP_APOLLON 919 @@ -262,10 +264,12 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_TS209 1565 #define MACH_TYPE_AT91CAP9ADK 1566 #define MACH_TYPE_MX31MOBOARD 1574 +#define MACH_TYPE_VISION_EP9307 1578 #define MACH_TYPE_TERASTATION_PRO2 1584 #define MACH_TYPE_LINKSTATION_PRO 1585 #define MACH_TYPE_E350 1596 #define MACH_TYPE_TS409 1601 +#define MACH_TYPE_RSI_EWS 1609 #define MACH_TYPE_CM_X300 1616 #define MACH_TYPE_AT91SAM9G20EK 1624 #define MACH_TYPE_SMDK6410 1626 @@ -309,7 +313,6 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_MX25_3DS 1771 #define MACH_TYPE_OMAP3530_LV_SOM 1773 #define MACH_TYPE_DAVINCI_DA830_EVM 1781 -#define MACH_TYPE_AT572D940HFEB 1783 #define MACH_TYPE_DOVE_DB 1788 #define MACH_TYPE_OVERO 1798 #define MACH_TYPE_AT2440EVB 1799 @@ -322,6 +325,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_TAVOREVB 1827 #define MACH_TYPE_SAAR 1828 #define MACH_TYPE_AT91SAM9M10G45EK 1830 +#define MACH_TYPE_USB_A9G20 1841 #define MACH_TYPE_MXLADS 1851 #define MACH_TYPE_LINKSTATION_MINI 1858 #define MACH_TYPE_AFEB9260 1859 @@ -360,6 +364,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_SHEEVAPLUG 2097 #define MACH_TYPE_AVENGERS_LITE 2104 #define MACH_TYPE_MX51_BABBAGE 2125 +#define MACH_TYPE_TX37 2127 #define MACH_TYPE_RD78X00_MASA 2135 #define MACH_TYPE_DM355_LEOPARD 2138 #define MACH_TYPE_TS219 2139 @@ -370,6 +375,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_MAGX_ZN5 2162 #define MACH_TYPE_BTMAVB101 2172 #define MACH_TYPE_BTMAWB101 2173 +#define MACH_TYPE_TX25 2177 #define MACH_TYPE_OMAP3_TORPEDO 2178 #define MACH_TYPE_ANW6410 2183 #define MACH_TYPE_IMX27_VISSTRIM_M10 2187 @@ -414,6 +420,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_RAUMFELD_CONNECTOR 2414 #define MACH_TYPE_RAUMFELD_SPEAKER 2415 #define MACH_TYPE_TNETV107X 2418 +#define MACH_TYPE_MX51_M2ID 2428 #define MACH_TYPE_SMDKV210 2456 #define MACH_TYPE_OMAP_ZOOM3 2464 #define MACH_TYPE_OMAP_3630SDP 2465 @@ -424,14 +431,17 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_TS41X 2502 #define MACH_TYPE_PHY3250 2511 #define MACH_TYPE_MINI6410 2520 +#define MACH_TYPE_TX51 2529 #define MACH_TYPE_MX28EVK 2531 #define MACH_TYPE_SMARTQ5 2534 #define MACH_TYPE_DAVINCI_DM6467TEVM 2548 #define MACH_TYPE_MXT_TD60 2550 #define MACH_TYPE_RIOT_BEI2 2576 #define MACH_TYPE_RIOT_X37 2578 +#define MACH_TYPE_PCA101 2595 #define MACH_TYPE_CAPC7117 2612 #define MACH_TYPE_ICONTROL 2624 +#define MACH_TYPE_GPLUGD 2625 #define MACH_TYPE_QSD8X50A_ST1_5 2627 #define MACH_TYPE_MX23EVK 2629 #define MACH_TYPE_AP4EVB 2630 @@ -472,380 +482,53 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_EUKREA_CPUIMX51SD 2822 #define MACH_TYPE_EUKREA_CPUIMX51 2823 #define MACH_TYPE_SMDKC210 2838 -#define MACH_TYPE_OMAP3_BRAILLO 2839 -#define MACH_TYPE_SPYPLUG 2840 -#define MACH_TYPE_GINGER 2841 -#define MACH_TYPE_TNY_T3530 2842 #define MACH_TYPE_PCA102 2843 -#define MACH_TYPE_SPADE 2844 -#define MACH_TYPE_MXC25_TOPAZ 2845 #define MACH_TYPE_T5325 2846 -#define MACH_TYPE_GW2361 2847 -#define MACH_TYPE_ELOG 2848 #define MACH_TYPE_INCOME 2849 -#define MACH_TYPE_BCM589X 2850 -#define MACH_TYPE_ETNA 2851 -#define MACH_TYPE_HAWKS 2852 -#define MACH_TYPE_MESON 2853 -#define MACH_TYPE_XSBASE255 2854 -#define MACH_TYPE_PVM2030 2855 -#define MACH_TYPE_MIOA502 2856 #define MACH_TYPE_VVBOX_SDORIG2 2857 #define MACH_TYPE_VVBOX_SDLITE2 2858 #define MACH_TYPE_VVBOX_SDPRO4 2859 -#define MACH_TYPE_HTC_SPV_M700 2860 #define MACH_TYPE_MX257SX 2861 #define MACH_TYPE_GONI 2862 -#define MACH_TYPE_MSM8X55_SVLTE_FFA 2863 -#define MACH_TYPE_MSM8X55_SVLTE_SURF 2864 -#define MACH_TYPE_QUICKSTEP 2865 -#define MACH_TYPE_DMW96 2866 -#define MACH_TYPE_HAMMERHEAD 2867 -#define MACH_TYPE_TRIDENT 2868 -#define MACH_TYPE_LIGHTNING 2869 -#define MACH_TYPE_ICONNECT 2870 -#define MACH_TYPE_AUTOBOT 2871 -#define MACH_TYPE_COCONUT 2872 -#define MACH_TYPE_DURIAN 2873 -#define MACH_TYPE_CAYENNE 2874 -#define MACH_TYPE_FUJI 2875 -#define MACH_TYPE_SYNOLOGY_6282 2876 -#define MACH_TYPE_EM1SY 2877 -#define MACH_TYPE_M502 2878 -#define MACH_TYPE_MATRIX518 2879 -#define MACH_TYPE_TINY_GURNARD 2880 -#define MACH_TYPE_SPEAR1310 2881 #define MACH_TYPE_BV07 2882 -#define MACH_TYPE_MXT_TD61 2883 #define MACH_TYPE_OPENRD_ULTIMATE 2884 #define MACH_TYPE_DEVIXP 2885 #define MACH_TYPE_MICCPT 2886 #define MACH_TYPE_MIC256 2887 -#define MACH_TYPE_AS1167 2888 -#define MACH_TYPE_OMAP3_IBIZA 2889 #define MACH_TYPE_U5500 2890 -#define MACH_TYPE_DAVINCI_PICTO 2891 -#define MACH_TYPE_MECHA 2892 -#define MACH_TYPE_BUBBA3 2893 -#define MACH_TYPE_PUPITRE 2894 -#define MACH_TYPE_TEGRA_VOGUE 2896 -#define MACH_TYPE_TEGRA_E1165 2897 -#define MACH_TYPE_SIMPLENET 2898 -#define MACH_TYPE_EC4350TBM 2899 -#define MACH_TYPE_PEC_TC 2900 -#define MACH_TYPE_PEC_HC2 2901 -#define MACH_TYPE_ESL_MOBILIS_A 2902 -#define MACH_TYPE_ESL_MOBILIS_B 2903 -#define MACH_TYPE_ESL_WAVE_A 2904 -#define MACH_TYPE_ESL_WAVE_B 2905 -#define MACH_TYPE_UNISENSE_MMM 2906 -#define MACH_TYPE_BLUESHARK 2907 -#define MACH_TYPE_E10 2908 -#define MACH_TYPE_APP3K_ROBIN 2909 -#define MACH_TYPE_POV15HD 2910 -#define MACH_TYPE_STELLA 2911 #define MACH_TYPE_LINKSTATION_LSCHL 2913 -#define MACH_TYPE_NETWALKER 2914 -#define MACH_TYPE_ACSX106 2915 -#define MACH_TYPE_ATLAS5_C1 2916 -#define MACH_TYPE_NSB3AST 2917 -#define MACH_TYPE_GNET_SLC 2918 -#define MACH_TYPE_AF4000 2919 -#define MACH_TYPE_ARK9431 2920 -#define MACH_TYPE_FS_S5PC100 2921 -#define MACH_TYPE_OMAP3505NOVA8 2922 -#define MACH_TYPE_OMAP3621_EDP1 2923 -#define MACH_TYPE_ORATISAES 2924 #define MACH_TYPE_SMDKV310 2925 -#define MACH_TYPE_SIEMENS_L0 2926 -#define MACH_TYPE_VENTANA 2927 #define MACH_TYPE_WM8505_7IN_NETBOOK 2928 -#define MACH_TYPE_EC4350SDB 2929 -#define MACH_TYPE_MIMAS 2930 -#define MACH_TYPE_TITAN 2931 #define MACH_TYPE_CRANEBOARD 2932 -#define MACH_TYPE_ES2440 2933 -#define MACH_TYPE_NAJAY_A9263 2934 -#define MACH_TYPE_HTCTORNADO 2935 -#define MACH_TYPE_DIMM_MX257 2936 -#define MACH_TYPE_JIGEN 2937 #define MACH_TYPE_SMDK6450 2938 -#define MACH_TYPE_MENO_QNG 2939 -#define MACH_TYPE_NS2416 2940 -#define MACH_TYPE_RPC353 2941 -#define MACH_TYPE_TQ6410 2942 -#define MACH_TYPE_SKY6410 2943 -#define MACH_TYPE_DYNASTY 2944 -#define MACH_TYPE_VIVO 2945 -#define MACH_TYPE_BURY_BL7582 2946 -#define MACH_TYPE_BURY_BPS5270 2947 -#define MACH_TYPE_BASI 2948 -#define MACH_TYPE_TN200 2949 -#define MACH_TYPE_C2MMI 2950 -#define MACH_TYPE_MESON_6236M 2951 -#define MACH_TYPE_MESON_8626M 2952 -#define MACH_TYPE_TUBE 2953 -#define MACH_TYPE_MESSINA 2954 -#define MACH_TYPE_MX50_ARM2 2955 -#define MACH_TYPE_CETUS9263 2956 #define MACH_TYPE_BROWNSTONE 2957 -#define MACH_TYPE_VMX25 2958 -#define MACH_TYPE_VMX51 2959 -#define MACH_TYPE_ABACUS 2960 -#define MACH_TYPE_CM4745 2961 -#define MACH_TYPE_ORATISLINK 2962 -#define MACH_TYPE_DAVINCI_DM365_DVR 2963 -#define MACH_TYPE_NETVIZ 2964 #define MACH_TYPE_FLEXIBITY 2965 -#define MACH_TYPE_WLAN_COMPUTER 2966 -#define MACH_TYPE_LPC24XX 2967 -#define MACH_TYPE_SPICA 2968 -#define MACH_TYPE_GPSDISPLAY 2969 -#define MACH_TYPE_BIPNET 2970 -#define MACH_TYPE_OVERO_CTU_INERTIAL 2971 -#define MACH_TYPE_DAVINCI_DM355_MMM 2972 -#define MACH_TYPE_PC9260_V2 2973 -#define MACH_TYPE_PTX7545 2974 -#define MACH_TYPE_TM_EFDC 2975 -#define MACH_TYPE_OMAP3_WALDO1 2977 -#define MACH_TYPE_FLYER 2978 -#define MACH_TYPE_TORNADO3240 2979 -#define MACH_TYPE_SOLI_01 2980 -#define MACH_TYPE_OMAPL138_EUROPALC 2981 -#define MACH_TYPE_HELIOS_V1 2982 -#define MACH_TYPE_NETSPACE_LITE_V2 2983 -#define MACH_TYPE_SSC 2984 -#define MACH_TYPE_PREMIERWAVE_EN 2985 -#define MACH_TYPE_WASABI 2986 #define MACH_TYPE_MX50_RDP 2988 #define MACH_TYPE_UNIVERSAL_C210 2989 #define MACH_TYPE_REAL6410 2990 -#define MACH_TYPE_SPX_SAKURA 2991 -#define MACH_TYPE_IJ3K_2440 2992 -#define MACH_TYPE_OMAP3_BC10 2993 -#define MACH_TYPE_THEBE 2994 -#define MACH_TYPE_RV082 2995 -#define MACH_TYPE_ARMLGUEST 2996 -#define MACH_TYPE_TJINC1000 2997 #define MACH_TYPE_DOCKSTAR 2998 -#define MACH_TYPE_AX8008 2999 -#define MACH_TYPE_GNET_SGCE 3000 -#define MACH_TYPE_PXWNAS_500_1000 3001 -#define MACH_TYPE_EA20 3002 -#define MACH_TYPE_AWM2 3003 #define MACH_TYPE_TI8148EVM 3004 #define MACH_TYPE_SEABOARD 3005 -#define MACH_TYPE_LINKSTATION_CHLV2 3006 -#define MACH_TYPE_TERA_PRO2_RACK 3007 -#define MACH_TYPE_RUBYS 3008 -#define MACH_TYPE_AQUARIUS 3009 #define MACH_TYPE_MX53_ARD 3010 #define MACH_TYPE_MX53_SMD 3011 -#define MACH_TYPE_LSWXL 3012 -#define MACH_TYPE_DOVE_AVNG_V3 3013 -#define MACH_TYPE_SDI_ESS_9263 3014 -#define MACH_TYPE_JOCPU550 3015 #define MACH_TYPE_MSM8X60_RUMI3 3016 #define MACH_TYPE_MSM8X60_FFA 3017 -#define MACH_TYPE_YANOMAMI 3018 -#define MACH_TYPE_GTA04 3019 #define MACH_TYPE_CM_A510 3020 -#define MACH_TYPE_OMAP3_RFS200 3021 -#define MACH_TYPE_KX33XX 3022 -#define MACH_TYPE_PTX7510 3023 -#define MACH_TYPE_TOP9000 3024 -#define MACH_TYPE_TEENOTE 3025 -#define MACH_TYPE_TS3 3026 -#define MACH_TYPE_A0 3027 -#define MACH_TYPE_FSM9XXX_SURF 3028 -#define MACH_TYPE_FSM9XXX_FFA 3029 -#define MACH_TYPE_FRRHWCDMA60W 3030 -#define MACH_TYPE_REMUS 3031 -#define MACH_TYPE_AT91CAP7XDK 3032 -#define MACH_TYPE_AT91CAP7STK 3033 -#define MACH_TYPE_KT_SBC_SAM9_1 3034 -#define MACH_TYPE_ARMADA_XP_DB 3036 -#define MACH_TYPE_SPDM 3037 -#define MACH_TYPE_GTIB 3038 -#define MACH_TYPE_DGM3240 3039 -#define MACH_TYPE_HTCMEGA 3041 -#define MACH_TYPE_TRICORDER 3042 #define MACH_TYPE_TX28 3043 -#define MACH_TYPE_BSTBRD 3044 -#define MACH_TYPE_PWB3090 3045 -#define MACH_TYPE_IDEA6410 3046 -#define MACH_TYPE_QBC9263 3047 -#define MACH_TYPE_BORABORA 3048 -#define MACH_TYPE_VALDEZ 3049 -#define MACH_TYPE_LS9G20 3050 -#define MACH_TYPE_MIOS_V1 3051 -#define MACH_TYPE_S5PC110_CRESPO 3052 -#define MACH_TYPE_CONTROLTEK9G20 3053 -#define MACH_TYPE_TIN307 3054 -#define MACH_TYPE_TIN510 3055 -#define MACH_TYPE_BLUECHEESE 3057 -#define MACH_TYPE_TEM3X30 3058 -#define MACH_TYPE_HARVEST_DESOTO 3059 -#define MACH_TYPE_MSM8X60_QRDC 3060 -#define MACH_TYPE_SPEAR900 3061 #define MACH_TYPE_PCONTROL_G20 3062 -#define MACH_TYPE_RDSTOR 3063 -#define MACH_TYPE_USDLOADER 3064 -#define MACH_TYPE_TSOPLOADER 3065 -#define MACH_TYPE_KRONOS 3066 -#define MACH_TYPE_FFCORE 3067 -#define MACH_TYPE_MONE 3068 -#define MACH_TYPE_UNIT2S 3069 -#define MACH_TYPE_ACER_A5 3070 -#define MACH_TYPE_ETHERPRO_ISP 3071 -#define MACH_TYPE_STRETCHS7000 3072 -#define MACH_TYPE_P87_SMARTSIM 3073 -#define MACH_TYPE_TULIP 3074 -#define MACH_TYPE_SUNFLOWER 3075 -#define MACH_TYPE_RIB 3076 -#define MACH_TYPE_CLOD 3077 -#define MACH_TYPE_RUMP 3078 -#define MACH_TYPE_TENDERLOIN 3079 -#define MACH_TYPE_SHORTLOIN 3080 -#define MACH_TYPE_ANTARES 3082 -#define MACH_TYPE_WB40N 3083 -#define MACH_TYPE_HERRING 3084 -#define MACH_TYPE_NAXY400 3085 -#define MACH_TYPE_NAXY1200 3086 #define MACH_TYPE_VPR200 3087 -#define MACH_TYPE_BUG20 3088 -#define MACH_TYPE_GOFLEXNET 3089 #define MACH_TYPE_TORBRECK 3090 -#define MACH_TYPE_SAARB_MG1 3091 -#define MACH_TYPE_CALLISTO 3092 -#define MACH_TYPE_MULTHSU 3093 -#define MACH_TYPE_SALUDA 3094 -#define MACH_TYPE_PEMP_OMAP3_APOLLO 3095 -#define MACH_TYPE_VC0718 3096 -#define MACH_TYPE_MVBLX 3097 -#define MACH_TYPE_INHAND_APEIRON 3098 -#define MACH_TYPE_INHAND_FURY 3099 -#define MACH_TYPE_INHAND_SIREN 3100 -#define MACH_TYPE_HDNVP 3101 -#define MACH_TYPE_SOFTWINNER 3102 #define MACH_TYPE_PRIMA2_EVB 3103 -#define MACH_TYPE_NAS6210 3104 -#define MACH_TYPE_UNISDEV 3105 -#define MACH_TYPE_SBCA11 3106 -#define MACH_TYPE_SAGA 3107 -#define MACH_TYPE_NS_K330 3108 -#define MACH_TYPE_TANNA 3109 -#define MACH_TYPE_IMATE8502 3110 -#define MACH_TYPE_ASPEN 3111 -#define MACH_TYPE_DAINTREE_CWAC 3112 -#define MACH_TYPE_ZMX25 3113 -#define MACH_TYPE_MAPLE1 3114 -#define MACH_TYPE_QSD8X72_SURF 3115 -#define MACH_TYPE_QSD8X72_FFA 3116 -#define MACH_TYPE_ABILENE 3117 -#define MACH_TYPE_EIGEN_TTR 3118 -#define MACH_TYPE_IOMEGA_IX2_200 3119 -#define MACH_TYPE_CORETEC_VCX7400 3120 -#define MACH_TYPE_SANTIAGO 3121 -#define MACH_TYPE_MX257SOL 3122 -#define MACH_TYPE_STRASBOURG 3123 -#define MACH_TYPE_MSM8X60_FLUID 3124 -#define MACH_TYPE_SMARTQV5 3125 -#define MACH_TYPE_SMARTQV3 3126 -#define MACH_TYPE_SMARTQV7 3127 #define MACH_TYPE_PAZ00 3128 #define MACH_TYPE_ACMENETUSFOXG20 3129 -#define MACH_TYPE_FWBD_0404 3131 -#define MACH_TYPE_HDGU 3132 -#define MACH_TYPE_PYRAMID 3133 -#define MACH_TYPE_EPIPHAN 3134 -#define MACH_TYPE_OMAP_BENDER 3135 -#define MACH_TYPE_GURNARD 3136 -#define MACH_TYPE_GTL_IT5100 3137 -#define MACH_TYPE_BCM2708 3138 -#define MACH_TYPE_MX51_GGC 3139 -#define MACH_TYPE_SHARESPACE 3140 -#define MACH_TYPE_HABA_KNX_EXPLORER 3141 -#define MACH_TYPE_SIMTEC_KIRKMOD 3142 -#define MACH_TYPE_CRUX 3143 -#define MACH_TYPE_MX51_BRAVO 3144 -#define MACH_TYPE_CHARON 3145 -#define MACH_TYPE_PICOCOM3 3146 -#define MACH_TYPE_PICOCOM4 3147 -#define MACH_TYPE_SERRANO 3148 -#define MACH_TYPE_DOUBLESHOT 3149 -#define MACH_TYPE_EVSY 3150 -#define MACH_TYPE_HUASHAN 3151 -#define MACH_TYPE_LAUSANNE 3152 -#define MACH_TYPE_EMERALD 3153 -#define MACH_TYPE_TQMA35 3154 -#define MACH_TYPE_MARVEL 3155 -#define MACH_TYPE_MANUAE 3156 -#define MACH_TYPE_CHACHA 3157 -#define MACH_TYPE_LEMON 3158 -#define MACH_TYPE_CSC 3159 -#define MACH_TYPE_GIRA_KNXIP_ROUTER 3160 -#define MACH_TYPE_T20 3161 -#define MACH_TYPE_HDMINI 3162 -#define MACH_TYPE_SCIPHONE_G2 3163 -#define MACH_TYPE_EXPRESS 3164 -#define MACH_TYPE_EXPRESS_KT 3165 -#define MACH_TYPE_MAXIMASP 3166 -#define MACH_TYPE_NITROGEN_IMX51 3167 -#define MACH_TYPE_NITROGEN_IMX53 3168 -#define MACH_TYPE_SUNFIRE 3169 -#define MACH_TYPE_AROWANA 3170 -#define MACH_TYPE_TEGRA_DAYTONA 3171 -#define MACH_TYPE_TEGRA_SWORDFISH 3172 -#define MACH_TYPE_EDISON 3173 -#define MACH_TYPE_SVP8500V1 3174 -#define MACH_TYPE_SVP8500V2 3175 -#define MACH_TYPE_SVP5500 3176 -#define MACH_TYPE_B5500 3177 -#define MACH_TYPE_S5500 3178 -#define MACH_TYPE_ICON 3179 -#define MACH_TYPE_ELEPHANT 3180 -#define MACH_TYPE_SHOOTER 3182 -#define MACH_TYPE_SPADE_LTE 3183 -#define MACH_TYPE_PHILHWANI 3184 -#define MACH_TYPE_GSNCOMM 3185 -#define MACH_TYPE_STRASBOURG_A2 3186 -#define MACH_TYPE_MMM 3187 -#define MACH_TYPE_DAVINCI_DM365_BV 3188 #define MACH_TYPE_AG5EVM 3189 -#define MACH_TYPE_SC575PLC 3190 -#define MACH_TYPE_SC575IPC 3191 -#define MACH_TYPE_OMAP3_TDM3730 3192 -#define MACH_TYPE_TOP9000_EVAL 3194 -#define MACH_TYPE_TOP9000_SU 3195 -#define MACH_TYPE_UTM300 3196 #define MACH_TYPE_TSUNAGI 3197 -#define MACH_TYPE_TS75XX 3198 -#define MACH_TYPE_TS47XX 3200 -#define MACH_TYPE_DA850_K5 3201 -#define MACH_TYPE_AX502 3202 -#define MACH_TYPE_IGEP0032 3203 -#define MACH_TYPE_ANTERO 3204 -#define MACH_TYPE_SYNERGY 3205 #define MACH_TYPE_ICS_IF_VOIP 3206 #define MACH_TYPE_WLF_CRAGG_6410 3207 -#define MACH_TYPE_PUNICA 3208 #define MACH_TYPE_TRIMSLICE 3209 -#define MACH_TYPE_MX27_WMULTRA 3210 #define MACH_TYPE_MACKEREL 3211 -#define MACH_TYPE_FA9X27 3213 -#define MACH_TYPE_NS2816TB 3214 -#define MACH_TYPE_NS2816_NTPAD 3215 -#define MACH_TYPE_NS2816_NTNB 3216 #define MACH_TYPE_KAEN 3217 -#define MACH_TYPE_NV1000 3218 -#define MACH_TYPE_NUC950TS 3219 #define MACH_TYPE_NOKIA_RM680 3220 -#define MACH_TYPE_AST2200 3221 -#define MACH_TYPE_LEAD 3222 -#define MACH_TYPE_UNINO1 3223 -#define MACH_TYPE_GREECO 3224 -#define MACH_TYPE_VERDI 3225 #define MACH_TYPE_DM6446_ADBOX 3226 #define MACH_TYPE_QUAD_SALSA 3227 #define MACH_TYPE_ABB_GMA_1_1 3228 @@ -930,13 +613,11 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_TS4800 3313 #define MACH_TYPE_TQMA9263 3314 #define MACH_TYPE_HOLIDAY 3315 -#define MACH_TYPE_DMA6410 3316 #define MACH_TYPE_PCATS_OVERLAY 3317 #define MACH_TYPE_HWGW6410 3318 #define MACH_TYPE_SHENZHOU 3319 #define MACH_TYPE_CWME9210 3320 #define MACH_TYPE_CWME9210JS 3321 -#define MACH_TYPE_PGS_SITARA 3322 #define MACH_TYPE_COLIBRI_TEGRA2 3323 #define MACH_TYPE_W21 3324 #define MACH_TYPE_POLYSAT1 3325 @@ -1002,13 +683,11 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_BOCKW 3386 #define MACH_TYPE_EVA2000 3387 #define MACH_TYPE_STEELYARD 3388 -#define MACH_TYPE_MACH_SDH001 3390 #define MACH_TYPE_NSSLSBOARD 3392 #define MACH_TYPE_GENEVA_B5 3393 #define MACH_TYPE_SPEAR1340 3394 #define MACH_TYPE_REXMAS 3395 #define MACH_TYPE_MSM8960_CDP 3396 -#define MACH_TYPE_MSM8960_MDP 3397 #define MACH_TYPE_MSM8960_FLUID 3398 #define MACH_TYPE_MSM8960_APQ 3399 #define MACH_TYPE_HELIOS_V2 3400 @@ -1104,7 +783,384 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_THALES_ADC 3492 #define MACH_TYPE_UBISYS_P9D_EVP 3493 #define MACH_TYPE_ATDGP318 3494 +#define MACH_TYPE_DMA210U 3495 +#define MACH_TYPE_EM_T3 3496 +#define MACH_TYPE_HTX3250 3497 +#define MACH_TYPE_G50 3498 +#define MACH_TYPE_ECO5 3499 +#define MACH_TYPE_WINTERGRASP 3500 +#define MACH_TYPE_PURO 3501 +#define MACH_TYPE_SHOOTER_K 3502 +#define MACH_TYPE_NSPIRE 3503 +#define MACH_TYPE_MICKXX 3504 +#define MACH_TYPE_LXMB 3505 +#define MACH_TYPE_ADAM 3507 +#define MACH_TYPE_B1004 3508 +#define MACH_TYPE_OBOEA 3509 +#define MACH_TYPE_A1015 3510 +#define MACH_TYPE_ROBIN_VBDT30 3511 +#define MACH_TYPE_TEGRA_ENTERPRISE 3512 +#define MACH_TYPE_RFL108200_MK10 3513 +#define MACH_TYPE_RFL108300_MK16 3514 +#define MACH_TYPE_ROVER_V7 3515 +#define MACH_TYPE_MIPHONE 3516 +#define MACH_TYPE_FEMTOBTS 3517 +#define MACH_TYPE_MONOPOLI 3518 +#define MACH_TYPE_BOSS 3519 +#define MACH_TYPE_DAVINCI_DM368_VTAM 3520 +#define MACH_TYPE_CLCON 3521 +#define MACH_TYPE_NOKIA_RM696 3522 +#define MACH_TYPE_TAHITI 3523 +#define MACH_TYPE_FIGHTER 3524 +#define MACH_TYPE_SGH_I710 3525 +#define MACH_TYPE_INTEGREPROSCB 3526 +#define MACH_TYPE_MONZA 3527 +#define MACH_TYPE_CALIMAIN 3528 +#define MACH_TYPE_MX6Q_SABREAUTO 3529 +#define MACH_TYPE_GMA01X 3530 +#define MACH_TYPE_SBC51 3531 +#define MACH_TYPE_FIT 3532 +#define MACH_TYPE_STEELHEAD 3533 +#define MACH_TYPE_PANTHER 3534 +#define MACH_TYPE_MSM8960_LIQUID 3535 +#define MACH_TYPE_LEXIKONCT 3536 +#define MACH_TYPE_NS2816_STB 3537 +#define MACH_TYPE_SEI_MM2_LPC3250 3538 +#define MACH_TYPE_CMIMX53 3539 +#define MACH_TYPE_SANDWICH 3540 +#define MACH_TYPE_CHIEF 3541 +#define MACH_TYPE_POGO_E02 3542 +#define MACH_TYPE_MIKRAP_X168 3543 +#define MACH_TYPE_HTCMOZART 3544 +#define MACH_TYPE_HTCGOLD 3545 +#define MACH_TYPE_MT72XX 3546 +#define MACH_TYPE_MX51_IVY 3547 +#define MACH_TYPE_MX51_LVD 3548 +#define MACH_TYPE_OMAP3_WISER2 3549 +#define MACH_TYPE_DREAMPLUG 3550 +#define MACH_TYPE_COBAS_C_111 3551 +#define MACH_TYPE_COBAS_U_411 3552 +#define MACH_TYPE_HSSD 3553 +#define MACH_TYPE_IOM35X 3554 +#define MACH_TYPE_PSOM_OMAP 3555 +#define MACH_TYPE_IPHONE_2G 3556 +#define MACH_TYPE_IPHONE_3G 3557 +#define MACH_TYPE_IPOD_TOUCH_1G 3558 +#define MACH_TYPE_PHAROS_TPC 3559 +#define MACH_TYPE_MX53_HYDRA 3560 +#define MACH_TYPE_NS2816_DEV_BOARD 3561 +#define MACH_TYPE_IPHONE_3GS 3562 +#define MACH_TYPE_IPHONE_4 3563 +#define MACH_TYPE_IPOD_TOUCH_4G 3564 +#define MACH_TYPE_DRAGON_E1100 3565 +#define MACH_TYPE_TOPSIDE 3566 +#define MACH_TYPE_IRISIII 3567 +#define MACH_TYPE_DETO_MACARM9 3568 +#define MACH_TYPE_ETI_D1 3569 +#define MACH_TYPE_SOM3530SDK 3570 +#define MACH_TYPE_OC_ENGINE 3571 +#define MACH_TYPE_APQ8064_SIM 3572 +#define MACH_TYPE_ALPS 3575 +#define MACH_TYPE_TNY_T3730 3576 +#define MACH_TYPE_GERYON_NFE 3577 +#define MACH_TYPE_NS2816_REF_BOARD 3578 +#define MACH_TYPE_SILVERSTONE 3579 +#define MACH_TYPE_MTT2440 3580 +#define MACH_TYPE_YNICDB 3581 +#define MACH_TYPE_BCT 3582 +#define MACH_TYPE_TUSCAN 3583 +#define MACH_TYPE_XBT_SAM9G45 3584 +#define MACH_TYPE_ENBW_CMC 3585 +#define MACH_TYPE_CH104MX257 3587 +#define MACH_TYPE_OPENPRI 3588 +#define MACH_TYPE_AM335XEVM 3589 +#define MACH_TYPE_PICODMB 3590 +#define MACH_TYPE_WALUIGI 3591 +#define MACH_TYPE_PUNICAG7 3592 +#define MACH_TYPE_IPAD_1G 3593 +#define MACH_TYPE_APPLETV_2G 3594 +#define MACH_TYPE_MACH_ECOG45 3595 +#define MACH_TYPE_AIT_CAM_ENC_4XX 3596 +#define MACH_TYPE_RUNNYMEDE 3597 +#define MACH_TYPE_PLAY 3598 +#define MACH_TYPE_HW90260 3599 +#define MACH_TYPE_TAGH 3600 +#define MACH_TYPE_FILBERT 3601 +#define MACH_TYPE_GETINGE_NETCOMV3 3602 +#define MACH_TYPE_CW20 3603 +#define MACH_TYPE_CINEMA 3604 +#define MACH_TYPE_CINEMA_TEA 3605 +#define MACH_TYPE_CINEMA_COFFEE 3606 +#define MACH_TYPE_CINEMA_JUICE 3607 +#define MACH_TYPE_MX53_MIRAGE2 3609 +#define MACH_TYPE_MX53_EFIKASB 3610 +#define MACH_TYPE_STM_B2000 3612 +#define MACH_TYPE_M28EVK 3613 +#define MACH_TYPE_PDA 3614 +#define MACH_TYPE_MERAKI_MR58 3615 +#define MACH_TYPE_KOTA2 3616 +#define MACH_TYPE_LETCOOL 3617 +#define MACH_TYPE_MX27IAT 3618 +#define MACH_TYPE_APOLLO_TD 3619 +#define MACH_TYPE_ARENA 3620 +#define MACH_TYPE_GSNGATEWAY 3621 +#define MACH_TYPE_LF2000 3622 +#define MACH_TYPE_BONITO 3623 +#define MACH_TYPE_ASYMPTOTE 3624 +#define MACH_TYPE_BST2BRD 3625 +#define MACH_TYPE_TX335S 3626 +#define MACH_TYPE_PELCO_TESLA 3627 +#define MACH_TYPE_RRHTESTPLAT 3628 +#define MACH_TYPE_VIDTONIC_PRO 3629 +#define MACH_TYPE_PL_APOLLO 3630 +#define MACH_TYPE_PL_PHOENIX 3631 +#define MACH_TYPE_M28CU3 3632 +#define MACH_TYPE_VVBOX_HD 3633 +#define MACH_TYPE_COREWARE_SAM9260_ 3634 +#define MACH_TYPE_MARMADUKE 3635 +#define MACH_TYPE_AMG_XLCORE_CAMERA 3636 +#define MACH_TYPE_OMAP3_EGF 3637 +#define MACH_TYPE_SMDK4212 3638 +#define MACH_TYPE_DNP9200 3639 +#define MACH_TYPE_TF101 3640 +#define MACH_TYPE_OMAP3SILVIO 3641 +#define MACH_TYPE_PICASSO2 3642 +#define MACH_TYPE_VANGOGH2 3643 +#define MACH_TYPE_OLPC_XO_1_75 3644 +#define MACH_TYPE_GX400 3645 +#define MACH_TYPE_GS300 3646 +#define MACH_TYPE_ACER_A9 3647 +#define MACH_TYPE_VIVOW_EVM 3648 +#define MACH_TYPE_VELOCE_CXQ 3649 +#define MACH_TYPE_VELOCE_CXM 3650 +#define MACH_TYPE_P1852 3651 +#define MACH_TYPE_NAXY100 3652 +#define MACH_TYPE_TAISHAN 3653 +#define MACH_TYPE_TOUCHLINK 3654 +#define MACH_TYPE_STM32F103ZE 3655 +#define MACH_TYPE_MCX 3656 +#define MACH_TYPE_STM_NMHDK_FLI7610 3657 +#define MACH_TYPE_TOP28X 3658 +#define MACH_TYPE_OKL4VP_MICROVISOR 3659 +#define MACH_TYPE_POP 3660 +#define MACH_TYPE_LAYER 3661 +#define MACH_TYPE_TRONDHEIM 3662 +#define MACH_TYPE_EVA 3663 +#define MACH_TYPE_TRUST_TAURUS 3664 +#define MACH_TYPE_NS2816_HUASHAN 3665 +#define MACH_TYPE_NS2816_YANGCHENG 3666 +#define MACH_TYPE_P852 3667 +#define MACH_TYPE_FLEA3 3668 +#define MACH_TYPE_BOWFIN 3669 +#define MACH_TYPE_MV88DE3100 3670 +#define MACH_TYPE_PIA_AM35X 3671 +#define MACH_TYPE_CEDAR 3672 +#define MACH_TYPE_PICASSO_E 3673 +#define MACH_TYPE_SAMSUNG_E60 3674 +#define MACH_TYPE_SDVR_MINI 3676 +#define MACH_TYPE_OMAP3_IJ3K 3677 +#define MACH_TYPE_MODASMC1 3678 +#define MACH_TYPE_APQ8064_RUMI3 3679 +#define MACH_TYPE_MATRIX506 3680 +#define MACH_TYPE_MSM9615_MTP 3681 +#define MACH_TYPE_DM36X_SPAWNDC 3682 +#define MACH_TYPE_SFF792 3683 +#define MACH_TYPE_AM335XIAEVM 3684 +#define MACH_TYPE_G3C2440 3685 +#define MACH_TYPE_TION270 3686 +#define MACH_TYPE_W22Q7ARM02 3687 +#define MACH_TYPE_OMAP_CAT 3688 +#define MACH_TYPE_AT91SAM9N12EK 3689 +#define MACH_TYPE_MORRISON 3690 +#define MACH_TYPE_SVDU 3691 +#define MACH_TYPE_LPP01 3692 +#define MACH_TYPE_UBC283 3693 +#define MACH_TYPE_ZEPPELIN 3694 +#define MACH_TYPE_MOTUS 3695 +#define MACH_TYPE_NEOMAINBOARD 3696 +#define MACH_TYPE_DEVKIT3250 3697 +#define MACH_TYPE_DEVKIT7000 3698 +#define MACH_TYPE_FMC_UIC 3699 +#define MACH_TYPE_FMC_DCM 3700 +#define MACH_TYPE_BATWM 3701 +#define MACH_TYPE_ATLAS6CB 3702 +#define MACH_TYPE_BLUE 3705 +#define MACH_TYPE_COLORADO 3706 +#define MACH_TYPE_POPC 3707 +#define MACH_TYPE_PROMWAD_JADE 3708 +#define MACH_TYPE_AMP 3709 +#define MACH_TYPE_GNET_AMP 3710 +#define MACH_TYPE_TOQUES 3711 +#define MACH_TYPE_DCT_STORM 3713 +#define MACH_TYPE_OWL 3715 +#define MACH_TYPE_COGENT_CSB1741 3716 +#define MACH_TYPE_ADILLUSTRA610 3718 +#define MACH_TYPE_ECAFE_NA04 3719 +#define MACH_TYPE_POPCT 3720 +#define MACH_TYPE_OMAP3_HELENA 3721 +#define MACH_TYPE_ACH 3722 +#define MACH_TYPE_MODULE_DTB 3723 +#define MACH_TYPE_OSLO_ELISABETH 3725 +#define MACH_TYPE_TT01 3726 +#define MACH_TYPE_MSM8930_CDP 3727 +#define MACH_TYPE_MSM8930_MTP 3728 +#define MACH_TYPE_MSM8930_FLUID 3729 +#define MACH_TYPE_LTU11 3730 +#define MACH_TYPE_AM1808_SPAWNCO 3731 +#define MACH_TYPE_FLX6410 3732 +#define MACH_TYPE_MX6Q_QSB 3733 +#define MACH_TYPE_MX53_PLT424 3734 +#define MACH_TYPE_JASMINE 3735 +#define MACH_TYPE_L138_OWLBOARD_PLUS 3736 +#define MACH_TYPE_WR21 3737 +#define MACH_TYPE_PEABOY 3739 +#define MACH_TYPE_MX28_PLATO 3740 +#define MACH_TYPE_KACOM2 3741 +#define MACH_TYPE_SLCO 3742 +#define MACH_TYPE_IMX51PICO 3743 +#define MACH_TYPE_GLINK1 3744 +#define MACH_TYPE_DIAMOND 3745 +#define MACH_TYPE_D9000 3746 +#define MACH_TYPE_W5300E01 3747 +#define MACH_TYPE_IM6000 3748 +#define MACH_TYPE_MX51_FRED51 3749 +#define MACH_TYPE_STM32F2 3750 +#define MACH_TYPE_VILLE 3751 +#define MACH_TYPE_PTIP_MURNAU 3752 +#define MACH_TYPE_PTIP_CLASSIC 3753 +#define MACH_TYPE_MX53GRB 3754 +#define MACH_TYPE_GAGARIN 3755 +#define MACH_TYPE_NAS2BIG 3757 +#define MACH_TYPE_SUPERFEMTO 3758 +#define MACH_TYPE_TEUFEL 3759 +#define MACH_TYPE_DINARA 3760 +#define MACH_TYPE_VANQUISH 3761 +#define MACH_TYPE_ZIPABOX1 3762 +#define MACH_TYPE_U9540 3763 +#define MACH_TYPE_JET 3764 +#define MACH_TYPE_SMDK4412 3765 +#define MACH_TYPE_ELITE 3766 +#define MACH_TYPE_SPEAR320_HMI 3767 +#define MACH_TYPE_ONTARIO 3768 +#define MACH_TYPE_MX6Q_SABRELITE 3769 +#define MACH_TYPE_VC200 3770 +#define MACH_TYPE_MSM7625A_FFA 3771 +#define MACH_TYPE_MSM7625A_SURF 3772 +#define MACH_TYPE_BENTHOSSBP 3773 +#define MACH_TYPE_SMDK5210 3774 +#define MACH_TYPE_EMPQ2300 3775 +#define MACH_TYPE_MINIPOS 3776 #define MACH_TYPE_OMAP5_SEVM 3777 +#define MACH_TYPE_SHELTER 3778 +#define MACH_TYPE_OMAP3_DEVKIT8500 3779 +#define MACH_TYPE_EDGETD 3780 +#define MACH_TYPE_COPPERYARD 3781 +#define MACH_TYPE_EDGE 3782 +#define MACH_TYPE_EDGE_U 3783 +#define MACH_TYPE_EDGE_TD 3784 +#define MACH_TYPE_WDSS 3785 +#define MACH_TYPE_DL_PB25 3786 +#define MACH_TYPE_DSS11 3787 +#define MACH_TYPE_CPA 3788 +#define MACH_TYPE_APTP2000 3789 +#define MACH_TYPE_MARZEN 3790 +#define MACH_TYPE_ST_TURBINE 3791 +#define MACH_TYPE_GTL_IT3300 3792 +#define MACH_TYPE_MX6_MULE 3793 +#define MACH_TYPE_V7PXA_DT 3794 +#define MACH_TYPE_V7MMP_DT 3795 +#define MACH_TYPE_DRAGON7 3796 +#define MACH_TYPE_KROME 3797 +#define MACH_TYPE_ORATISDANTE 3798 +#define MACH_TYPE_FATHOM 3799 +#define MACH_TYPE_DNS325 3800 +#define MACH_TYPE_SARNEN 3801 +#define MACH_TYPE_UBISYS_G1 3802 +#define MACH_TYPE_MX53_PF1 3803 +#define MACH_TYPE_ASANTI 3804 +#define MACH_TYPE_VOLTA 3805 +#define MACH_TYPE_KNIGHT 3807 +#define MACH_TYPE_BEAGLEBONE 3808 +#define MACH_TYPE_BECKER 3809 +#define MACH_TYPE_FC360 3810 +#define MACH_TYPE_PMI2_XLS 3811 +#define MACH_TYPE_TARANTO 3812 +#define MACH_TYPE_PLUTUX 3813 +#define MACH_TYPE_IPMP_MEDCOM 3814 +#define MACH_TYPE_ABSOLUT 3815 +#define MACH_TYPE_AWPB3 3816 +#define MACH_TYPE_NFP32XX_DT 3817 +#define MACH_TYPE_DL_PB53 3818 +#define MACH_TYPE_ACU_II 3819 +#define MACH_TYPE_AVALON 3820 +#define MACH_TYPE_SPHINX 3821 +#define MACH_TYPE_TITAN_T 3822 +#define MACH_TYPE_HARVEST_BORIS 3823 +#define MACH_TYPE_MACH_MSM7X30_M3S 3824 +#define MACH_TYPE_SMDK5250 3825 +#define MACH_TYPE_IMXT_LITE 3826 +#define MACH_TYPE_IMXT_STD 3827 +#define MACH_TYPE_IMXT_LOG 3828 +#define MACH_TYPE_IMXT_NAV 3829 +#define MACH_TYPE_IMXT_FULL 3830 +#define MACH_TYPE_AG09015 3831 +#define MACH_TYPE_AM3517_MT_VENTOUX 3832 +#define MACH_TYPE_DP1ARM9 3833 +#define MACH_TYPE_PICASSO_M 3834 +#define MACH_TYPE_VIDEO_GADGET 3835 +#define MACH_TYPE_MTT_OM3X 3836 +#define MACH_TYPE_MX6Q_ARM2 3837 +#define MACH_TYPE_PICOSAM9G45 3838 +#define MACH_TYPE_VPM_DM365 3839 +#define MACH_TYPE_BONFIRE 3840 +#define MACH_TYPE_MT2P2D 3841 +#define MACH_TYPE_SIGPDA01 3842 +#define MACH_TYPE_CN27 3843 +#define MACH_TYPE_MX25_CWTAP 3844 +#define MACH_TYPE_APF28 3845 +#define MACH_TYPE_PELCO_MAXWELL 3846 +#define MACH_TYPE_GE_PHOENIX 3847 +#define MACH_TYPE_EMPC_A500 3848 +#define MACH_TYPE_IMS_ARM9 3849 +#define MACH_TYPE_MINI2416 3850 +#define MACH_TYPE_MINI2450 3851 +#define MACH_TYPE_MINI310 3852 +#define MACH_TYPE_SPEAR_HURRICANE 3853 +#define MACH_TYPE_MT7208 3854 +#define MACH_TYPE_LPC178X 3855 +#define MACH_TYPE_FARLEYS 3856 +#define MACH_TYPE_EFM32GG_DK3750 3857 +#define MACH_TYPE_ZEUS_BOARD 3858 +#define MACH_TYPE_CC51 3859 +#define MACH_TYPE_FXI_C210 3860 +#define MACH_TYPE_MSM8627_CDP 3861 +#define MACH_TYPE_MSM8627_MTP 3862 +#define MACH_TYPE_ARMADILLO800EVA 3863 +#define MACH_TYPE_PRIMOU 3864 +#define MACH_TYPE_PRIMOC 3865 +#define MACH_TYPE_PRIMOCT 3866 +#define MACH_TYPE_A9500 3867 +#define MACH_TYPE_PLUTO 3869 +#define MACH_TYPE_ACFX100 3870 +#define MACH_TYPE_MSM8625_RUMI3 3871 +#define MACH_TYPE_VALENTE 3872 +#define MACH_TYPE_CRFS_RFEYE 3873 +#define MACH_TYPE_RFEYE 3874 +#define MACH_TYPE_PHIDGET_SBC3 3875 +#define MACH_TYPE_TCW_MIKA 3876 +#define MACH_TYPE_IMX28_EGF 3877 +#define MACH_TYPE_VALENTE_WX 3878 +#define MACH_TYPE_HUANGSHANS 3879 +#define MACH_TYPE_BOSPHORUS1 3880 +#define MACH_TYPE_PRIMA 3881 +#define MACH_TYPE_EVITA_ULK 3884 +#define MACH_TYPE_MERISC600 3885 +#define MACH_TYPE_DOLAK 3886 +#define MACH_TYPE_SBC53 3887 +#define MACH_TYPE_ELITE_ULK 3888 +#define MACH_TYPE_POV2 3889 +#define MACH_TYPE_IPOD_TOUCH_2G 3890 +#define MACH_TYPE_DA850_PQAB 3891
#ifdef CONFIG_ARCH_EBSA110 # ifdef machine_arch_type @@ -1634,6 +1690,18 @@ extern unsigned int __machine_arch_type; # define machine_is_ks8695() (0) #endif
+#ifdef CONFIG_ARCH_KARO +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_KARO +# endif +# define machine_is_karo() (machine_arch_type == MACH_TYPE_KARO) +#else +# define machine_is_karo() (0) +#endif + #ifdef CONFIG_ARCH_SMDK2410 # ifdef machine_arch_type # undef machine_arch_type @@ -3110,6 +3178,18 @@ extern unsigned int __machine_arch_type; # define machine_is_nxdb500() (0) #endif
+#ifdef CONFIG_MACH_APF9328 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_APF9328 +# endif +# define machine_is_apf9328() (machine_arch_type == MACH_TYPE_APF9328) +#else +# define machine_is_apf9328() (0) +#endif + #ifdef CONFIG_MACH_PALMT5 # ifdef machine_arch_type # undef machine_arch_type @@ -4077,9 +4157,9 @@ extern unsigned int __machine_arch_type; # else # define machine_arch_type MACH_TYPE_TS209 # endif -# define machine_is_ts_x09() (machine_arch_type == MACH_TYPE_TS209) +# define machine_is_ts209() (machine_arch_type == MACH_TYPE_TS209) #else -# define machine_is_ts_x09() (0) +# define machine_is_ts209() (0) #endif
#ifdef CONFIG_MACH_AT91CAP9ADK @@ -4106,6 +4186,18 @@ extern unsigned int __machine_arch_type; # define machine_is_mx31moboard() (0) #endif
+#ifdef CONFIG_MACH_VISION_EP9307 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_VISION_EP9307 +# endif +# define machine_is_vision_ep9307() (machine_arch_type == MACH_TYPE_VISION_EP9307) +#else +# define machine_is_vision_ep9307() (0) +#endif + #ifdef CONFIG_MACH_TERASTATION_PRO2 # ifdef machine_arch_type # undef machine_arch_type @@ -4154,6 +4246,18 @@ extern unsigned int __machine_arch_type; # define machine_is_ts409() (0) #endif
+#ifdef CONFIG_MACH_RSI_EWS +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_RSI_EWS +# endif +# define machine_is_rsi_ews() (machine_arch_type == MACH_TYPE_RSI_EWS) +#else +# define machine_is_rsi_ews() (0) +#endif + #ifdef CONFIG_MACH_CM_X300 # ifdef machine_arch_type # undef machine_arch_type @@ -4670,18 +4774,6 @@ extern unsigned int __machine_arch_type; # define machine_is_davinci_da830_evm() (0) #endif
-#ifdef CONFIG_MACH_AT572D940HFEB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT572D940HFEB -# endif -# define machine_is_at572d940hfek() (machine_arch_type == MACH_TYPE_AT572D940HFEB) -#else -# define machine_is_at572d940hfek() (0) -#endif - #ifdef CONFIG_MACH_DOVE_DB # ifdef machine_arch_type # undef machine_arch_type @@ -4826,6 +4918,18 @@ extern unsigned int __machine_arch_type; # define machine_is_at91sam9m10g45ek() (0) #endif
+#ifdef CONFIG_MACH_USB_A9G20 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_USB_A9G20 +# endif +# define machine_is_usb_a9g20() (machine_arch_type == MACH_TYPE_USB_A9G20) +#else +# define machine_is_usb_a9g20() (0) +#endif + #ifdef CONFIG_MACH_MXLADS # ifdef machine_arch_type # undef machine_arch_type @@ -5282,6 +5386,18 @@ extern unsigned int __machine_arch_type; # define machine_is_mx51_babbage() (0) #endif
+#ifdef CONFIG_MACH_TX37 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_TX37 +# endif +# define machine_is_tx37() (machine_arch_type == MACH_TYPE_TX37) +#else +# define machine_is_tx37() (0) +#endif + #ifdef CONFIG_MACH_RD78X00_MASA # ifdef machine_arch_type # undef machine_arch_type @@ -5402,6 +5518,18 @@ extern unsigned int __machine_arch_type; # define machine_is_btmawb101() (0) #endif
+#ifdef CONFIG_MACH_TX25 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_TX25 +# endif +# define machine_is_tx25() (machine_arch_type == MACH_TYPE_TX25) +#else +# define machine_is_tx25() (0) +#endif + #ifdef CONFIG_MACH_OMAP3_TORPEDO # ifdef machine_arch_type # undef machine_arch_type @@ -5930,6 +6058,18 @@ extern unsigned int __machine_arch_type; # define machine_is_tnetv107x() (0) #endif
+#ifdef CONFIG_MACH_MX51_M2ID +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_MX51_M2ID +# endif +# define machine_is_mx51_m2id() (machine_arch_type == MACH_TYPE_MX51_M2ID) +#else +# define machine_is_mx51_m2id() (0) +#endif + #ifdef CONFIG_MACH_SMDKV210 # ifdef machine_arch_type # undef machine_arch_type @@ -6050,6 +6190,18 @@ extern unsigned int __machine_arch_type; # define machine_is_mini6410() (0) #endif
+#ifdef CONFIG_MACH_TX51 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_TX51 +# endif +# define machine_is_tx51() (machine_arch_type == MACH_TYPE_TX51) +#else +# define machine_is_tx51() (0) +#endif + #ifdef CONFIG_MACH_MX28EVK # ifdef machine_arch_type # undef machine_arch_type @@ -6122,6 +6274,18 @@ extern unsigned int __machine_arch_type; # define machine_is_riot_x37() (0) #endif
+#ifdef CONFIG_MACH_PCA101 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_PCA101 +# endif +# define machine_is_pca101() (machine_arch_type == MACH_TYPE_PCA101) +#else +# define machine_is_pca101() (0) +#endif + #ifdef CONFIG_MACH_CAPC7117 # ifdef machine_arch_type # undef machine_arch_type @@ -6146,6 +6310,18 @@ extern unsigned int __machine_arch_type; # define machine_is_icontrol() (0) #endif
+#ifdef CONFIG_MACH_GPLUGD +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_GPLUGD +# endif +# define machine_is_gplugd() (machine_arch_type == MACH_TYPE_GPLUGD) +#else +# define machine_is_gplugd() (0) +#endif + #ifdef CONFIG_MACH_QSD8X50A_ST1_5 # ifdef machine_arch_type # undef machine_arch_type @@ -6249,9 +6425,9 @@ extern unsigned int __machine_arch_type; # else # define machine_arch_type MACH_TYPE_ESATA_SHEEVAPLUG # endif -# define machine_is_sheeva_esata() (machine_arch_type == MACH_TYPE_ESATA_SHEEVAPLUG) +# define machine_is_esata_sheevaplug() (machine_arch_type == MACH_TYPE_ESATA_SHEEVAPLUG) #else -# define machine_is_sheeva_esata() (0) +# define machine_is_esata_sheevaplug() (0) #endif
#ifdef CONFIG_MACH_MSM7X30_SURF @@ -6626,7600 +6802,8152 @@ extern unsigned int __machine_arch_type; # define machine_is_smdkc210() (0) #endif
-#ifdef CONFIG_MACH_OMAP3_BRAILLO +#ifdef CONFIG_MACH_PCA102 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OMAP3_BRAILLO +# define machine_arch_type MACH_TYPE_PCA102 # endif -# define machine_is_omap3_braillo() (machine_arch_type == MACH_TYPE_OMAP3_BRAILLO) +# define machine_is_pca102() (machine_arch_type == MACH_TYPE_PCA102) #else -# define machine_is_omap3_braillo() (0) +# define machine_is_pca102() (0) #endif
-#ifdef CONFIG_MACH_SPYPLUG +#ifdef CONFIG_MACH_T5325 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SPYPLUG +# define machine_arch_type MACH_TYPE_T5325 # endif -# define machine_is_spyplug() (machine_arch_type == MACH_TYPE_SPYPLUG) +# define machine_is_t5325() (machine_arch_type == MACH_TYPE_T5325) #else -# define machine_is_spyplug() (0) +# define machine_is_t5325() (0) #endif
-#ifdef CONFIG_MACH_GINGER +#ifdef CONFIG_MACH_INCOME # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GINGER +# define machine_arch_type MACH_TYPE_INCOME # endif -# define machine_is_ginger() (machine_arch_type == MACH_TYPE_GINGER) +# define machine_is_income() (machine_arch_type == MACH_TYPE_INCOME) #else -# define machine_is_ginger() (0) +# define machine_is_income() (0) #endif
-#ifdef CONFIG_MACH_TNY_T3530 +#ifdef CONFIG_MACH_VVBOX_SDORIG2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TNY_T3530 +# define machine_arch_type MACH_TYPE_VVBOX_SDORIG2 # endif -# define machine_is_tny_t3530() (machine_arch_type == MACH_TYPE_TNY_T3530) +# define machine_is_vvbox_sdorig2() (machine_arch_type == MACH_TYPE_VVBOX_SDORIG2) #else -# define machine_is_tny_t3530() (0) +# define machine_is_vvbox_sdorig2() (0) #endif
-#ifdef CONFIG_MACH_PCA102 +#ifdef CONFIG_MACH_VVBOX_SDLITE2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PCA102 +# define machine_arch_type MACH_TYPE_VVBOX_SDLITE2 # endif -# define machine_is_pca102() (machine_arch_type == MACH_TYPE_PCA102) +# define machine_is_vvbox_sdlite2() (machine_arch_type == MACH_TYPE_VVBOX_SDLITE2) #else -# define machine_is_pca102() (0) +# define machine_is_vvbox_sdlite2() (0) #endif
-#ifdef CONFIG_MACH_SPADE +#ifdef CONFIG_MACH_VVBOX_SDPRO4 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SPADE +# define machine_arch_type MACH_TYPE_VVBOX_SDPRO4 # endif -# define machine_is_spade() (machine_arch_type == MACH_TYPE_SPADE) +# define machine_is_vvbox_sdpro4() (machine_arch_type == MACH_TYPE_VVBOX_SDPRO4) #else -# define machine_is_spade() (0) +# define machine_is_vvbox_sdpro4() (0) #endif
-#ifdef CONFIG_MACH_MXC25_TOPAZ +#ifdef CONFIG_MACH_MX257SX # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MXC25_TOPAZ +# define machine_arch_type MACH_TYPE_MX257SX # endif -# define machine_is_mxc25_topaz() (machine_arch_type == MACH_TYPE_MXC25_TOPAZ) +# define machine_is_mx257sx() (machine_arch_type == MACH_TYPE_MX257SX) #else -# define machine_is_mxc25_topaz() (0) +# define machine_is_mx257sx() (0) #endif
-#ifdef CONFIG_MACH_T5325 +#ifdef CONFIG_MACH_GONI # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_T5325 +# define machine_arch_type MACH_TYPE_GONI # endif -# define machine_is_t5325() (machine_arch_type == MACH_TYPE_T5325) +# define machine_is_goni() (machine_arch_type == MACH_TYPE_GONI) #else -# define machine_is_t5325() (0) +# define machine_is_goni() (0) #endif
-#ifdef CONFIG_MACH_GW2361 +#ifdef CONFIG_MACH_BV07 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GW2361 +# define machine_arch_type MACH_TYPE_BV07 # endif -# define machine_is_gw2361() (machine_arch_type == MACH_TYPE_GW2361) +# define machine_is_bv07() (machine_arch_type == MACH_TYPE_BV07) #else -# define machine_is_gw2361() (0) +# define machine_is_bv07() (0) #endif
-#ifdef CONFIG_MACH_ELOG +#ifdef CONFIG_MACH_OPENRD_ULTIMATE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ELOG +# define machine_arch_type MACH_TYPE_OPENRD_ULTIMATE # endif -# define machine_is_elog() (machine_arch_type == MACH_TYPE_ELOG) +# define machine_is_openrd_ultimate() (machine_arch_type == MACH_TYPE_OPENRD_ULTIMATE) #else -# define machine_is_elog() (0) +# define machine_is_openrd_ultimate() (0) #endif
-#ifdef CONFIG_MACH_INCOME +#ifdef CONFIG_MACH_DEVIXP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_INCOME +# define machine_arch_type MACH_TYPE_DEVIXP # endif -# define machine_is_income() (machine_arch_type == MACH_TYPE_INCOME) +# define machine_is_devixp() (machine_arch_type == MACH_TYPE_DEVIXP) #else -# define machine_is_income() (0) +# define machine_is_devixp() (0) #endif
-#ifdef CONFIG_MACH_BCM589X +#ifdef CONFIG_MACH_MICCPT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BCM589X +# define machine_arch_type MACH_TYPE_MICCPT # endif -# define machine_is_bcm589x() (machine_arch_type == MACH_TYPE_BCM589X) +# define machine_is_miccpt() (machine_arch_type == MACH_TYPE_MICCPT) #else -# define machine_is_bcm589x() (0) +# define machine_is_miccpt() (0) #endif
-#ifdef CONFIG_MACH_ETNA +#ifdef CONFIG_MACH_MIC256 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ETNA +# define machine_arch_type MACH_TYPE_MIC256 # endif -# define machine_is_etna() (machine_arch_type == MACH_TYPE_ETNA) +# define machine_is_mic256() (machine_arch_type == MACH_TYPE_MIC256) #else -# define machine_is_etna() (0) +# define machine_is_mic256() (0) #endif
-#ifdef CONFIG_MACH_HAWKS +#ifdef CONFIG_MACH_U5500 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HAWKS +# define machine_arch_type MACH_TYPE_U5500 # endif -# define machine_is_hawks() (machine_arch_type == MACH_TYPE_HAWKS) +# define machine_is_u5500() (machine_arch_type == MACH_TYPE_U5500) #else -# define machine_is_hawks() (0) +# define machine_is_u5500() (0) #endif
-#ifdef CONFIG_MACH_MESON +#ifdef CONFIG_MACH_LINKSTATION_LSCHL # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MESON +# define machine_arch_type MACH_TYPE_LINKSTATION_LSCHL # endif -# define machine_is_meson() (machine_arch_type == MACH_TYPE_MESON) +# define machine_is_linkstation_lschl() (machine_arch_type == MACH_TYPE_LINKSTATION_LSCHL) #else -# define machine_is_meson() (0) +# define machine_is_linkstation_lschl() (0) #endif
-#ifdef CONFIG_MACH_XSBASE255 +#ifdef CONFIG_MACH_SMDKV310 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_XSBASE255 +# define machine_arch_type MACH_TYPE_SMDKV310 # endif -# define machine_is_xsbase255() (machine_arch_type == MACH_TYPE_XSBASE255) +# define machine_is_smdkv310() (machine_arch_type == MACH_TYPE_SMDKV310) #else -# define machine_is_xsbase255() (0) +# define machine_is_smdkv310() (0) #endif
-#ifdef CONFIG_MACH_PVM2030 +#ifdef CONFIG_MACH_WM8505_7IN_NETBOOK # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PVM2030 +# define machine_arch_type MACH_TYPE_WM8505_7IN_NETBOOK # endif -# define machine_is_pvm2030() (machine_arch_type == MACH_TYPE_PVM2030) +# define machine_is_wm8505_7in_netbook() (machine_arch_type == MACH_TYPE_WM8505_7IN_NETBOOK) #else -# define machine_is_pvm2030() (0) +# define machine_is_wm8505_7in_netbook() (0) #endif
-#ifdef CONFIG_MACH_MIOA502 +#ifdef CONFIG_MACH_CRANEBOARD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MIOA502 +# define machine_arch_type MACH_TYPE_CRANEBOARD # endif -# define machine_is_mioa502() (machine_arch_type == MACH_TYPE_MIOA502) +# define machine_is_craneboard() (machine_arch_type == MACH_TYPE_CRANEBOARD) #else -# define machine_is_mioa502() (0) +# define machine_is_craneboard() (0) #endif
-#ifdef CONFIG_MACH_VVBOX_SDORIG2 +#ifdef CONFIG_MACH_SMDK6450 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VVBOX_SDORIG2 +# define machine_arch_type MACH_TYPE_SMDK6450 # endif -# define machine_is_vvbox_sdorig2() (machine_arch_type == MACH_TYPE_VVBOX_SDORIG2) +# define machine_is_smdk6450() (machine_arch_type == MACH_TYPE_SMDK6450) #else -# define machine_is_vvbox_sdorig2() (0) +# define machine_is_smdk6450() (0) #endif
-#ifdef CONFIG_MACH_VVBOX_SDLITE2 +#ifdef CONFIG_MACH_BROWNSTONE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VVBOX_SDLITE2 +# define machine_arch_type MACH_TYPE_BROWNSTONE # endif -# define machine_is_vvbox_sdlite2() (machine_arch_type == MACH_TYPE_VVBOX_SDLITE2) +# define machine_is_brownstone() (machine_arch_type == MACH_TYPE_BROWNSTONE) #else -# define machine_is_vvbox_sdlite2() (0) +# define machine_is_brownstone() (0) #endif
-#ifdef CONFIG_MACH_VVBOX_SDPRO4 +#ifdef CONFIG_MACH_FLEXIBITY # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VVBOX_SDPRO4 +# define machine_arch_type MACH_TYPE_FLEXIBITY # endif -# define machine_is_vvbox_sdpro4() (machine_arch_type == MACH_TYPE_VVBOX_SDPRO4) +# define machine_is_flexibity() (machine_arch_type == MACH_TYPE_FLEXIBITY) #else -# define machine_is_vvbox_sdpro4() (0) +# define machine_is_flexibity() (0) #endif
-#ifdef CONFIG_MACH_HTC_SPV_M700 +#ifdef CONFIG_MACH_MX50_RDP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HTC_SPV_M700 +# define machine_arch_type MACH_TYPE_MX50_RDP # endif -# define machine_is_htc_spv_m700() (machine_arch_type == MACH_TYPE_HTC_SPV_M700) +# define machine_is_mx50_rdp() (machine_arch_type == MACH_TYPE_MX50_RDP) #else -# define machine_is_htc_spv_m700() (0) +# define machine_is_mx50_rdp() (0) #endif
-#ifdef CONFIG_MACH_MX257SX +#ifdef CONFIG_MACH_UNIVERSAL_C210 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MX257SX +# define machine_arch_type MACH_TYPE_UNIVERSAL_C210 # endif -# define machine_is_mx257sx() (machine_arch_type == MACH_TYPE_MX257SX) +# define machine_is_universal_c210() (machine_arch_type == MACH_TYPE_UNIVERSAL_C210) #else -# define machine_is_mx257sx() (0) +# define machine_is_universal_c210() (0) #endif
-#ifdef CONFIG_MACH_GONI +#ifdef CONFIG_MACH_REAL6410 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GONI +# define machine_arch_type MACH_TYPE_REAL6410 # endif -# define machine_is_goni() (machine_arch_type == MACH_TYPE_GONI) +# define machine_is_real6410() (machine_arch_type == MACH_TYPE_REAL6410) #else -# define machine_is_goni() (0) +# define machine_is_real6410() (0) #endif
-#ifdef CONFIG_MACH_MSM8X55_SVLTE_FFA +#ifdef CONFIG_MACH_DOCKSTAR # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MSM8X55_SVLTE_FFA +# define machine_arch_type MACH_TYPE_DOCKSTAR # endif -# define machine_is_msm8x55_svlte_ffa() (machine_arch_type == MACH_TYPE_MSM8X55_SVLTE_FFA) +# define machine_is_dockstar() (machine_arch_type == MACH_TYPE_DOCKSTAR) #else -# define machine_is_msm8x55_svlte_ffa() (0) +# define machine_is_dockstar() (0) #endif
-#ifdef CONFIG_MACH_MSM8X55_SVLTE_SURF +#ifdef CONFIG_MACH_TI8148EVM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MSM8X55_SVLTE_SURF +# define machine_arch_type MACH_TYPE_TI8148EVM # endif -# define machine_is_msm8x55_svlte_surf() (machine_arch_type == MACH_TYPE_MSM8X55_SVLTE_SURF) +# define machine_is_ti8148evm() (machine_arch_type == MACH_TYPE_TI8148EVM) #else -# define machine_is_msm8x55_svlte_surf() (0) +# define machine_is_ti8148evm() (0) #endif
-#ifdef CONFIG_MACH_QUICKSTEP +#ifdef CONFIG_MACH_SEABOARD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_QUICKSTEP +# define machine_arch_type MACH_TYPE_SEABOARD # endif -# define machine_is_quickstep() (machine_arch_type == MACH_TYPE_QUICKSTEP) +# define machine_is_seaboard() (machine_arch_type == MACH_TYPE_SEABOARD) #else -# define machine_is_quickstep() (0) +# define machine_is_seaboard() (0) #endif
-#ifdef CONFIG_MACH_DMW96 +#ifdef CONFIG_MACH_MX53_ARD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DMW96 +# define machine_arch_type MACH_TYPE_MX53_ARD # endif -# define machine_is_dmw96() (machine_arch_type == MACH_TYPE_DMW96) +# define machine_is_mx53_ard() (machine_arch_type == MACH_TYPE_MX53_ARD) #else -# define machine_is_dmw96() (0) +# define machine_is_mx53_ard() (0) #endif
-#ifdef CONFIG_MACH_HAMMERHEAD +#ifdef CONFIG_MACH_MX53_SMD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HAMMERHEAD +# define machine_arch_type MACH_TYPE_MX53_SMD # endif -# define machine_is_hammerhead() (machine_arch_type == MACH_TYPE_HAMMERHEAD) +# define machine_is_mx53_smd() (machine_arch_type == MACH_TYPE_MX53_SMD) #else -# define machine_is_hammerhead() (0) +# define machine_is_mx53_smd() (0) #endif
-#ifdef CONFIG_MACH_TRIDENT +#ifdef CONFIG_MACH_MSM8X60_RUMI3 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TRIDENT +# define machine_arch_type MACH_TYPE_MSM8X60_RUMI3 # endif -# define machine_is_trident() (machine_arch_type == MACH_TYPE_TRIDENT) +# define machine_is_msm8x60_rumi3() (machine_arch_type == MACH_TYPE_MSM8X60_RUMI3) #else -# define machine_is_trident() (0) +# define machine_is_msm8x60_rumi3() (0) #endif
-#ifdef CONFIG_MACH_LIGHTNING +#ifdef CONFIG_MACH_MSM8X60_FFA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_LIGHTNING +# define machine_arch_type MACH_TYPE_MSM8X60_FFA # endif -# define machine_is_lightning() (machine_arch_type == MACH_TYPE_LIGHTNING) +# define machine_is_msm8x60_ffa() (machine_arch_type == MACH_TYPE_MSM8X60_FFA) #else -# define machine_is_lightning() (0) +# define machine_is_msm8x60_ffa() (0) #endif
-#ifdef CONFIG_MACH_ICONNECT +#ifdef CONFIG_MACH_CM_A510 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ICONNECT +# define machine_arch_type MACH_TYPE_CM_A510 # endif -# define machine_is_iconnect() (machine_arch_type == MACH_TYPE_ICONNECT) +# define machine_is_cm_a510() (machine_arch_type == MACH_TYPE_CM_A510) #else -# define machine_is_iconnect() (0) +# define machine_is_cm_a510() (0) #endif
-#ifdef CONFIG_MACH_AUTOBOT +#ifdef CONFIG_MACH_TX28 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_AUTOBOT +# define machine_arch_type MACH_TYPE_TX28 # endif -# define machine_is_autobot() (machine_arch_type == MACH_TYPE_AUTOBOT) +# define machine_is_tx28() (machine_arch_type == MACH_TYPE_TX28) #else -# define machine_is_autobot() (0) +# define machine_is_tx28() (0) #endif
-#ifdef CONFIG_MACH_COCONUT +#ifdef CONFIG_MACH_PCONTROL_G20 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_COCONUT +# define machine_arch_type MACH_TYPE_PCONTROL_G20 # endif -# define machine_is_coconut() (machine_arch_type == MACH_TYPE_COCONUT) +# define machine_is_pcontrol_g20() (machine_arch_type == MACH_TYPE_PCONTROL_G20) #else -# define machine_is_coconut() (0) +# define machine_is_pcontrol_g20() (0) #endif
-#ifdef CONFIG_MACH_DURIAN +#ifdef CONFIG_MACH_VPR200 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DURIAN +# define machine_arch_type MACH_TYPE_VPR200 # endif -# define machine_is_durian() (machine_arch_type == MACH_TYPE_DURIAN) +# define machine_is_vpr200() (machine_arch_type == MACH_TYPE_VPR200) #else -# define machine_is_durian() (0) +# define machine_is_vpr200() (0) #endif
-#ifdef CONFIG_MACH_CAYENNE +#ifdef CONFIG_MACH_TORBRECK # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CAYENNE +# define machine_arch_type MACH_TYPE_TORBRECK # endif -# define machine_is_cayenne() (machine_arch_type == MACH_TYPE_CAYENNE) +# define machine_is_torbreck() (machine_arch_type == MACH_TYPE_TORBRECK) #else -# define machine_is_cayenne() (0) +# define machine_is_torbreck() (0) #endif
-#ifdef CONFIG_MACH_FUJI +#ifdef CONFIG_MACH_PRIMA2_EVB # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_FUJI +# define machine_arch_type MACH_TYPE_PRIMA2_EVB # endif -# define machine_is_fuji() (machine_arch_type == MACH_TYPE_FUJI) +# define machine_is_prima2_evb() (machine_arch_type == MACH_TYPE_PRIMA2_EVB) #else -# define machine_is_fuji() (0) +# define machine_is_prima2_evb() (0) #endif
-#ifdef CONFIG_MACH_SYNOLOGY_6282 +#ifdef CONFIG_MACH_PAZ00 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SYNOLOGY_6282 +# define machine_arch_type MACH_TYPE_PAZ00 # endif -# define machine_is_synology_6282() (machine_arch_type == MACH_TYPE_SYNOLOGY_6282) +# define machine_is_paz00() (machine_arch_type == MACH_TYPE_PAZ00) #else -# define machine_is_synology_6282() (0) +# define machine_is_paz00() (0) #endif
-#ifdef CONFIG_MACH_EM1SY +#ifdef CONFIG_MACH_ACMENETUSFOXG20 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_EM1SY +# define machine_arch_type MACH_TYPE_ACMENETUSFOXG20 # endif -# define machine_is_em1sy() (machine_arch_type == MACH_TYPE_EM1SY) +# define machine_is_acmenetusfoxg20() (machine_arch_type == MACH_TYPE_ACMENETUSFOXG20) #else -# define machine_is_em1sy() (0) +# define machine_is_acmenetusfoxg20() (0) #endif
-#ifdef CONFIG_MACH_M502 +#ifdef CONFIG_MACH_AG5EVM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_M502 +# define machine_arch_type MACH_TYPE_AG5EVM # endif -# define machine_is_m502() (machine_arch_type == MACH_TYPE_M502) +# define machine_is_ag5evm() (machine_arch_type == MACH_TYPE_AG5EVM) #else -# define machine_is_m502() (0) +# define machine_is_ag5evm() (0) #endif
-#ifdef CONFIG_MACH_MATRIX518 +#ifdef CONFIG_MACH_TSUNAGI # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MATRIX518 +# define machine_arch_type MACH_TYPE_TSUNAGI # endif -# define machine_is_matrix518() (machine_arch_type == MACH_TYPE_MATRIX518) +# define machine_is_tsunagi() (machine_arch_type == MACH_TYPE_TSUNAGI) #else -# define machine_is_matrix518() (0) +# define machine_is_tsunagi() (0) #endif
-#ifdef CONFIG_MACH_TINY_GURNARD +#ifdef CONFIG_MACH_ICS_IF_VOIP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TINY_GURNARD +# define machine_arch_type MACH_TYPE_ICS_IF_VOIP # endif -# define machine_is_tiny_gurnard() (machine_arch_type == MACH_TYPE_TINY_GURNARD) +# define machine_is_ics_if_voip() (machine_arch_type == MACH_TYPE_ICS_IF_VOIP) #else -# define machine_is_tiny_gurnard() (0) +# define machine_is_ics_if_voip() (0) #endif
-#ifdef CONFIG_MACH_SPEAR1310 +#ifdef CONFIG_MACH_WLF_CRAGG_6410 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SPEAR1310 +# define machine_arch_type MACH_TYPE_WLF_CRAGG_6410 # endif -# define machine_is_spear1310() (machine_arch_type == MACH_TYPE_SPEAR1310) +# define machine_is_wlf_cragg_6410() (machine_arch_type == MACH_TYPE_WLF_CRAGG_6410) #else -# define machine_is_spear1310() (0) +# define machine_is_wlf_cragg_6410() (0) #endif
-#ifdef CONFIG_MACH_BV07 +#ifdef CONFIG_MACH_TRIMSLICE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BV07 +# define machine_arch_type MACH_TYPE_TRIMSLICE # endif -# define machine_is_bv07() (machine_arch_type == MACH_TYPE_BV07) +# define machine_is_trimslice() (machine_arch_type == MACH_TYPE_TRIMSLICE) #else -# define machine_is_bv07() (0) +# define machine_is_trimslice() (0) #endif
-#ifdef CONFIG_MACH_MXT_TD61 +#ifdef CONFIG_MACH_MACKEREL # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MXT_TD61 +# define machine_arch_type MACH_TYPE_MACKEREL # endif -# define machine_is_mxt_td61() (machine_arch_type == MACH_TYPE_MXT_TD61) +# define machine_is_mackerel() (machine_arch_type == MACH_TYPE_MACKEREL) #else -# define machine_is_mxt_td61() (0) +# define machine_is_mackerel() (0) #endif
-#ifdef CONFIG_MACH_OPENRD_ULTIMATE +#ifdef CONFIG_MACH_KAEN # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OPENRD_ULTIMATE +# define machine_arch_type MACH_TYPE_KAEN # endif -# define machine_is_openrd_ultimate() (machine_arch_type == MACH_TYPE_OPENRD_ULTIMATE) +# define machine_is_kaen() (machine_arch_type == MACH_TYPE_KAEN) #else -# define machine_is_openrd_ultimate() (0) +# define machine_is_kaen() (0) #endif
-#ifdef CONFIG_MACH_DEVIXP +#ifdef CONFIG_MACH_NOKIA_RM680 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DEVIXP +# define machine_arch_type MACH_TYPE_NOKIA_RM680 # endif -# define machine_is_devixp() (machine_arch_type == MACH_TYPE_DEVIXP) +# define machine_is_nokia_rm680() (machine_arch_type == MACH_TYPE_NOKIA_RM680) #else -# define machine_is_devixp() (0) +# define machine_is_nokia_rm680() (0) #endif
-#ifdef CONFIG_MACH_MICCPT +#ifdef CONFIG_MACH_DM6446_ADBOX # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MICCPT +# define machine_arch_type MACH_TYPE_DM6446_ADBOX # endif -# define machine_is_miccpt() (machine_arch_type == MACH_TYPE_MICCPT) +# define machine_is_dm6446_adbox() (machine_arch_type == MACH_TYPE_DM6446_ADBOX) #else -# define machine_is_miccpt() (0) +# define machine_is_dm6446_adbox() (0) #endif
-#ifdef CONFIG_MACH_MIC256 +#ifdef CONFIG_MACH_QUAD_SALSA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MIC256 +# define machine_arch_type MACH_TYPE_QUAD_SALSA # endif -# define machine_is_mic256() (machine_arch_type == MACH_TYPE_MIC256) +# define machine_is_quad_salsa() (machine_arch_type == MACH_TYPE_QUAD_SALSA) #else -# define machine_is_mic256() (0) +# define machine_is_quad_salsa() (0) #endif
-#ifdef CONFIG_MACH_AS1167 +#ifdef CONFIG_MACH_ABB_GMA_1_1 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_AS1167 +# define machine_arch_type MACH_TYPE_ABB_GMA_1_1 # endif -# define machine_is_as1167() (machine_arch_type == MACH_TYPE_AS1167) +# define machine_is_abb_gma_1_1() (machine_arch_type == MACH_TYPE_ABB_GMA_1_1) #else -# define machine_is_as1167() (0) +# define machine_is_abb_gma_1_1() (0) #endif
-#ifdef CONFIG_MACH_OMAP3_IBIZA +#ifdef CONFIG_MACH_SVCID # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OMAP3_IBIZA +# define machine_arch_type MACH_TYPE_SVCID # endif -# define machine_is_omap3_ibiza() (machine_arch_type == MACH_TYPE_OMAP3_IBIZA) +# define machine_is_svcid() (machine_arch_type == MACH_TYPE_SVCID) #else -# define machine_is_omap3_ibiza() (0) +# define machine_is_svcid() (0) #endif
-#ifdef CONFIG_MACH_U5500 +#ifdef CONFIG_MACH_MSM8960_SIM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_U5500 +# define machine_arch_type MACH_TYPE_MSM8960_SIM # endif -# define machine_is_u5500() (machine_arch_type == MACH_TYPE_U5500) +# define machine_is_msm8960_sim() (machine_arch_type == MACH_TYPE_MSM8960_SIM) #else -# define machine_is_u5500() (0) +# define machine_is_msm8960_sim() (0) #endif
-#ifdef CONFIG_MACH_DAVINCI_PICTO +#ifdef CONFIG_MACH_MSM8960_RUMI3 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DAVINCI_PICTO +# define machine_arch_type MACH_TYPE_MSM8960_RUMI3 # endif -# define machine_is_davinci_picto() (machine_arch_type == MACH_TYPE_DAVINCI_PICTO) +# define machine_is_msm8960_rumi3() (machine_arch_type == MACH_TYPE_MSM8960_RUMI3) #else -# define machine_is_davinci_picto() (0) +# define machine_is_msm8960_rumi3() (0) #endif
-#ifdef CONFIG_MACH_MECHA +#ifdef CONFIG_MACH_ICON_G # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MECHA +# define machine_arch_type MACH_TYPE_ICON_G # endif -# define machine_is_mecha() (machine_arch_type == MACH_TYPE_MECHA) +# define machine_is_icon_g() (machine_arch_type == MACH_TYPE_ICON_G) #else -# define machine_is_mecha() (0) +# define machine_is_icon_g() (0) #endif
-#ifdef CONFIG_MACH_BUBBA3 +#ifdef CONFIG_MACH_MB3 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BUBBA3 +# define machine_arch_type MACH_TYPE_MB3 # endif -# define machine_is_bubba3() (machine_arch_type == MACH_TYPE_BUBBA3) +# define machine_is_mb3() (machine_arch_type == MACH_TYPE_MB3) #else -# define machine_is_bubba3() (0) +# define machine_is_mb3() (0) #endif
-#ifdef CONFIG_MACH_PUPITRE +#ifdef CONFIG_MACH_GSIA18S # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PUPITRE +# define machine_arch_type MACH_TYPE_GSIA18S # endif -# define machine_is_pupitre() (machine_arch_type == MACH_TYPE_PUPITRE) +# define machine_is_gsia18s() (machine_arch_type == MACH_TYPE_GSIA18S) #else -# define machine_is_pupitre() (0) +# define machine_is_gsia18s() (0) #endif
-#ifdef CONFIG_MACH_TEGRA_VOGUE +#ifdef CONFIG_MACH_PIVICC # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TEGRA_VOGUE +# define machine_arch_type MACH_TYPE_PIVICC # endif -# define machine_is_tegra_vogue() (machine_arch_type == MACH_TYPE_TEGRA_VOGUE) +# define machine_is_pivicc() (machine_arch_type == MACH_TYPE_PIVICC) #else -# define machine_is_tegra_vogue() (0) +# define machine_is_pivicc() (0) #endif
-#ifdef CONFIG_MACH_TEGRA_E1165 +#ifdef CONFIG_MACH_PCM048 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TEGRA_E1165 +# define machine_arch_type MACH_TYPE_PCM048 # endif -# define machine_is_tegra_e1165() (machine_arch_type == MACH_TYPE_TEGRA_E1165) +# define machine_is_pcm048() (machine_arch_type == MACH_TYPE_PCM048) #else -# define machine_is_tegra_e1165() (0) +# define machine_is_pcm048() (0) #endif
-#ifdef CONFIG_MACH_SIMPLENET +#ifdef CONFIG_MACH_DDS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SIMPLENET +# define machine_arch_type MACH_TYPE_DDS # endif -# define machine_is_simplenet() (machine_arch_type == MACH_TYPE_SIMPLENET) +# define machine_is_dds() (machine_arch_type == MACH_TYPE_DDS) #else -# define machine_is_simplenet() (0) +# define machine_is_dds() (0) #endif
-#ifdef CONFIG_MACH_EC4350TBM +#ifdef CONFIG_MACH_CHALTEN_XA1 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_EC4350TBM +# define machine_arch_type MACH_TYPE_CHALTEN_XA1 # endif -# define machine_is_ec4350tbm() (machine_arch_type == MACH_TYPE_EC4350TBM) +# define machine_is_chalten_xa1() (machine_arch_type == MACH_TYPE_CHALTEN_XA1) #else -# define machine_is_ec4350tbm() (0) +# define machine_is_chalten_xa1() (0) #endif
-#ifdef CONFIG_MACH_PEC_TC +#ifdef CONFIG_MACH_TS48XX # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PEC_TC +# define machine_arch_type MACH_TYPE_TS48XX # endif -# define machine_is_pec_tc() (machine_arch_type == MACH_TYPE_PEC_TC) +# define machine_is_ts48xx() (machine_arch_type == MACH_TYPE_TS48XX) #else -# define machine_is_pec_tc() (0) +# define machine_is_ts48xx() (0) #endif
-#ifdef CONFIG_MACH_PEC_HC2 +#ifdef CONFIG_MACH_TONGA2_TFTTIMER # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PEC_HC2 +# define machine_arch_type MACH_TYPE_TONGA2_TFTTIMER # endif -# define machine_is_pec_hc2() (machine_arch_type == MACH_TYPE_PEC_HC2) +# define machine_is_tonga2_tfttimer() (machine_arch_type == MACH_TYPE_TONGA2_TFTTIMER) #else -# define machine_is_pec_hc2() (0) +# define machine_is_tonga2_tfttimer() (0) #endif
-#ifdef CONFIG_MACH_ESL_MOBILIS_A +#ifdef CONFIG_MACH_WHISTLER # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ESL_MOBILIS_A +# define machine_arch_type MACH_TYPE_WHISTLER # endif -# define machine_is_esl_mobilis_a() (machine_arch_type == MACH_TYPE_ESL_MOBILIS_A) +# define machine_is_whistler() (machine_arch_type == MACH_TYPE_WHISTLER) #else -# define machine_is_esl_mobilis_a() (0) +# define machine_is_whistler() (0) #endif
-#ifdef CONFIG_MACH_ESL_MOBILIS_B +#ifdef CONFIG_MACH_ASL_PHOENIX # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ESL_MOBILIS_B +# define machine_arch_type MACH_TYPE_ASL_PHOENIX # endif -# define machine_is_esl_mobilis_b() (machine_arch_type == MACH_TYPE_ESL_MOBILIS_B) +# define machine_is_asl_phoenix() (machine_arch_type == MACH_TYPE_ASL_PHOENIX) #else -# define machine_is_esl_mobilis_b() (0) +# define machine_is_asl_phoenix() (0) #endif
-#ifdef CONFIG_MACH_ESL_WAVE_A +#ifdef CONFIG_MACH_AT91SAM9263OTLITE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ESL_WAVE_A +# define machine_arch_type MACH_TYPE_AT91SAM9263OTLITE # endif -# define machine_is_esl_wave_a() (machine_arch_type == MACH_TYPE_ESL_WAVE_A) +# define machine_is_at91sam9263otlite() (machine_arch_type == MACH_TYPE_AT91SAM9263OTLITE) #else -# define machine_is_esl_wave_a() (0) +# define machine_is_at91sam9263otlite() (0) #endif
-#ifdef CONFIG_MACH_ESL_WAVE_B +#ifdef CONFIG_MACH_DDPLUG # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ESL_WAVE_B +# define machine_arch_type MACH_TYPE_DDPLUG # endif -# define machine_is_esl_wave_b() (machine_arch_type == MACH_TYPE_ESL_WAVE_B) +# define machine_is_ddplug() (machine_arch_type == MACH_TYPE_DDPLUG) #else -# define machine_is_esl_wave_b() (0) +# define machine_is_ddplug() (0) #endif
-#ifdef CONFIG_MACH_UNISENSE_MMM +#ifdef CONFIG_MACH_D2PLUG # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_UNISENSE_MMM +# define machine_arch_type MACH_TYPE_D2PLUG # endif -# define machine_is_unisense_mmm() (machine_arch_type == MACH_TYPE_UNISENSE_MMM) +# define machine_is_d2plug() (machine_arch_type == MACH_TYPE_D2PLUG) #else -# define machine_is_unisense_mmm() (0) +# define machine_is_d2plug() (0) #endif
-#ifdef CONFIG_MACH_BLUESHARK +#ifdef CONFIG_MACH_KZM9D # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BLUESHARK +# define machine_arch_type MACH_TYPE_KZM9D # endif -# define machine_is_blueshark() (machine_arch_type == MACH_TYPE_BLUESHARK) +# define machine_is_kzm9d() (machine_arch_type == MACH_TYPE_KZM9D) #else -# define machine_is_blueshark() (0) +# define machine_is_kzm9d() (0) #endif
-#ifdef CONFIG_MACH_E10 +#ifdef CONFIG_MACH_VERDI_LTE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_E10 +# define machine_arch_type MACH_TYPE_VERDI_LTE # endif -# define machine_is_e10() (machine_arch_type == MACH_TYPE_E10) +# define machine_is_verdi_lte() (machine_arch_type == MACH_TYPE_VERDI_LTE) #else -# define machine_is_e10() (0) +# define machine_is_verdi_lte() (0) #endif
-#ifdef CONFIG_MACH_APP3K_ROBIN +#ifdef CONFIG_MACH_NANOZOOM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_APP3K_ROBIN +# define machine_arch_type MACH_TYPE_NANOZOOM # endif -# define machine_is_app3k_robin() (machine_arch_type == MACH_TYPE_APP3K_ROBIN) +# define machine_is_nanozoom() (machine_arch_type == MACH_TYPE_NANOZOOM) #else -# define machine_is_app3k_robin() (0) +# define machine_is_nanozoom() (0) #endif
-#ifdef CONFIG_MACH_POV15HD +#ifdef CONFIG_MACH_DM3730_SOM_LV # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_POV15HD +# define machine_arch_type MACH_TYPE_DM3730_SOM_LV # endif -# define machine_is_pov15hd() (machine_arch_type == MACH_TYPE_POV15HD) +# define machine_is_dm3730_som_lv() (machine_arch_type == MACH_TYPE_DM3730_SOM_LV) #else -# define machine_is_pov15hd() (0) +# define machine_is_dm3730_som_lv() (0) #endif
-#ifdef CONFIG_MACH_STELLA +#ifdef CONFIG_MACH_DM3730_TORPEDO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_STELLA +# define machine_arch_type MACH_TYPE_DM3730_TORPEDO # endif -# define machine_is_stella() (machine_arch_type == MACH_TYPE_STELLA) +# define machine_is_dm3730_torpedo() (machine_arch_type == MACH_TYPE_DM3730_TORPEDO) #else -# define machine_is_stella() (0) +# define machine_is_dm3730_torpedo() (0) #endif
-#ifdef CONFIG_MACH_LINKSTATION_LSCHL +#ifdef CONFIG_MACH_ANCHOVY # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_LINKSTATION_LSCHL +# define machine_arch_type MACH_TYPE_ANCHOVY # endif -# define machine_is_linkstation_lschl() (machine_arch_type == MACH_TYPE_LINKSTATION_LSCHL) +# define machine_is_anchovy() (machine_arch_type == MACH_TYPE_ANCHOVY) #else -# define machine_is_linkstation_lschl() (0) +# define machine_is_anchovy() (0) #endif
-#ifdef CONFIG_MACH_NETWALKER +#ifdef CONFIG_MACH_RE2REV20 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NETWALKER +# define machine_arch_type MACH_TYPE_RE2REV20 # endif -# define machine_is_netwalker() (machine_arch_type == MACH_TYPE_NETWALKER) +# define machine_is_re2rev20() (machine_arch_type == MACH_TYPE_RE2REV20) #else -# define machine_is_netwalker() (0) +# define machine_is_re2rev20() (0) #endif
-#ifdef CONFIG_MACH_ACSX106 +#ifdef CONFIG_MACH_RE2REV21 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ACSX106 +# define machine_arch_type MACH_TYPE_RE2REV21 # endif -# define machine_is_acsx106() (machine_arch_type == MACH_TYPE_ACSX106) +# define machine_is_re2rev21() (machine_arch_type == MACH_TYPE_RE2REV21) #else -# define machine_is_acsx106() (0) +# define machine_is_re2rev21() (0) #endif
-#ifdef CONFIG_MACH_ATLAS5_C1 +#ifdef CONFIG_MACH_CNS21XX # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ATLAS5_C1 +# define machine_arch_type MACH_TYPE_CNS21XX # endif -# define machine_is_atlas5_c1() (machine_arch_type == MACH_TYPE_ATLAS5_C1) +# define machine_is_cns21xx() (machine_arch_type == MACH_TYPE_CNS21XX) #else -# define machine_is_atlas5_c1() (0) +# define machine_is_cns21xx() (0) #endif
-#ifdef CONFIG_MACH_NSB3AST +#ifdef CONFIG_MACH_RIDER # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NSB3AST +# define machine_arch_type MACH_TYPE_RIDER # endif -# define machine_is_nsb3ast() (machine_arch_type == MACH_TYPE_NSB3AST) +# define machine_is_rider() (machine_arch_type == MACH_TYPE_RIDER) #else -# define machine_is_nsb3ast() (0) +# define machine_is_rider() (0) #endif
-#ifdef CONFIG_MACH_GNET_SLC +#ifdef CONFIG_MACH_NSK330 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GNET_SLC +# define machine_arch_type MACH_TYPE_NSK330 # endif -# define machine_is_gnet_slc() (machine_arch_type == MACH_TYPE_GNET_SLC) +# define machine_is_nsk330() (machine_arch_type == MACH_TYPE_NSK330) #else -# define machine_is_gnet_slc() (0) +# define machine_is_nsk330() (0) #endif
-#ifdef CONFIG_MACH_AF4000 +#ifdef CONFIG_MACH_CNS2133EVB # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_AF4000 +# define machine_arch_type MACH_TYPE_CNS2133EVB # endif -# define machine_is_af4000() (machine_arch_type == MACH_TYPE_AF4000) +# define machine_is_cns2133evb() (machine_arch_type == MACH_TYPE_CNS2133EVB) #else -# define machine_is_af4000() (0) +# define machine_is_cns2133evb() (0) #endif
-#ifdef CONFIG_MACH_ARK9431 +#ifdef CONFIG_MACH_Z3_816X_MOD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ARK9431 +# define machine_arch_type MACH_TYPE_Z3_816X_MOD # endif -# define machine_is_ark9431() (machine_arch_type == MACH_TYPE_ARK9431) +# define machine_is_z3_816x_mod() (machine_arch_type == MACH_TYPE_Z3_816X_MOD) #else -# define machine_is_ark9431() (0) +# define machine_is_z3_816x_mod() (0) #endif
-#ifdef CONFIG_MACH_FS_S5PC100 +#ifdef CONFIG_MACH_Z3_814X_MOD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_FS_S5PC100 +# define machine_arch_type MACH_TYPE_Z3_814X_MOD # endif -# define machine_is_fs_s5pc100() (machine_arch_type == MACH_TYPE_FS_S5PC100) +# define machine_is_z3_814x_mod() (machine_arch_type == MACH_TYPE_Z3_814X_MOD) #else -# define machine_is_fs_s5pc100() (0) +# define machine_is_z3_814x_mod() (0) #endif
-#ifdef CONFIG_MACH_OMAP3505NOVA8 +#ifdef CONFIG_MACH_BEECT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OMAP3505NOVA8 +# define machine_arch_type MACH_TYPE_BEECT # endif -# define machine_is_omap3505nova8() (machine_arch_type == MACH_TYPE_OMAP3505NOVA8) +# define machine_is_beect() (machine_arch_type == MACH_TYPE_BEECT) #else -# define machine_is_omap3505nova8() (0) +# define machine_is_beect() (0) #endif
-#ifdef CONFIG_MACH_OMAP3621_EDP1 +#ifdef CONFIG_MACH_DMA_THUNDERBUG # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OMAP3621_EDP1 +# define machine_arch_type MACH_TYPE_DMA_THUNDERBUG # endif -# define machine_is_omap3621_edp1() (machine_arch_type == MACH_TYPE_OMAP3621_EDP1) +# define machine_is_dma_thunderbug() (machine_arch_type == MACH_TYPE_DMA_THUNDERBUG) #else -# define machine_is_omap3621_edp1() (0) +# define machine_is_dma_thunderbug() (0) #endif
-#ifdef CONFIG_MACH_ORATISAES +#ifdef CONFIG_MACH_OMN_AT91SAM9G20 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ORATISAES +# define machine_arch_type MACH_TYPE_OMN_AT91SAM9G20 # endif -# define machine_is_oratisaes() (machine_arch_type == MACH_TYPE_ORATISAES) +# define machine_is_omn_at91sam9g20() (machine_arch_type == MACH_TYPE_OMN_AT91SAM9G20) #else -# define machine_is_oratisaes() (0) +# define machine_is_omn_at91sam9g20() (0) #endif
-#ifdef CONFIG_MACH_SMDKV310 +#ifdef CONFIG_MACH_MX25_E2S_UC # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SMDKV310 +# define machine_arch_type MACH_TYPE_MX25_E2S_UC # endif -# define machine_is_smdkv310() (machine_arch_type == MACH_TYPE_SMDKV310) +# define machine_is_mx25_e2s_uc() (machine_arch_type == MACH_TYPE_MX25_E2S_UC) #else -# define machine_is_smdkv310() (0) +# define machine_is_mx25_e2s_uc() (0) #endif
-#ifdef CONFIG_MACH_SIEMENS_L0 +#ifdef CONFIG_MACH_MIONE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SIEMENS_L0 +# define machine_arch_type MACH_TYPE_MIONE # endif -# define machine_is_siemens_l0() (machine_arch_type == MACH_TYPE_SIEMENS_L0) +# define machine_is_mione() (machine_arch_type == MACH_TYPE_MIONE) #else -# define machine_is_siemens_l0() (0) +# define machine_is_mione() (0) #endif
-#ifdef CONFIG_MACH_VENTANA +#ifdef CONFIG_MACH_TOP9000_TCU # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VENTANA +# define machine_arch_type MACH_TYPE_TOP9000_TCU # endif -# define machine_is_ventana() (machine_arch_type == MACH_TYPE_VENTANA) +# define machine_is_top9000_tcu() (machine_arch_type == MACH_TYPE_TOP9000_TCU) #else -# define machine_is_ventana() (0) +# define machine_is_top9000_tcu() (0) #endif
-#ifdef CONFIG_MACH_WM8505_7IN_NETBOOK +#ifdef CONFIG_MACH_TOP9000_BSL # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_WM8505_7IN_NETBOOK +# define machine_arch_type MACH_TYPE_TOP9000_BSL # endif -# define machine_is_wm8505_7in_netbook() (machine_arch_type == MACH_TYPE_WM8505_7IN_NETBOOK) +# define machine_is_top9000_bsl() (machine_arch_type == MACH_TYPE_TOP9000_BSL) #else -# define machine_is_wm8505_7in_netbook() (0) +# define machine_is_top9000_bsl() (0) #endif
-#ifdef CONFIG_MACH_EC4350SDB +#ifdef CONFIG_MACH_KINGDOM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_EC4350SDB +# define machine_arch_type MACH_TYPE_KINGDOM # endif -# define machine_is_ec4350sdb() (machine_arch_type == MACH_TYPE_EC4350SDB) +# define machine_is_kingdom() (machine_arch_type == MACH_TYPE_KINGDOM) #else -# define machine_is_ec4350sdb() (0) +# define machine_is_kingdom() (0) #endif
-#ifdef CONFIG_MACH_MIMAS +#ifdef CONFIG_MACH_ARMADILLO460 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MIMAS +# define machine_arch_type MACH_TYPE_ARMADILLO460 # endif -# define machine_is_mimas() (machine_arch_type == MACH_TYPE_MIMAS) +# define machine_is_armadillo460() (machine_arch_type == MACH_TYPE_ARMADILLO460) #else -# define machine_is_mimas() (0) +# define machine_is_armadillo460() (0) #endif
-#ifdef CONFIG_MACH_TITAN +#ifdef CONFIG_MACH_LQ2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TITAN +# define machine_arch_type MACH_TYPE_LQ2 # endif -# define machine_is_titan() (machine_arch_type == MACH_TYPE_TITAN) +# define machine_is_lq2() (machine_arch_type == MACH_TYPE_LQ2) #else -# define machine_is_titan() (0) +# define machine_is_lq2() (0) #endif
-#ifdef CONFIG_MACH_CRANEBOARD +#ifdef CONFIG_MACH_SWEDA_TMS2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CRANEBOARD +# define machine_arch_type MACH_TYPE_SWEDA_TMS2 # endif -# define machine_is_craneboard() (machine_arch_type == MACH_TYPE_CRANEBOARD) +# define machine_is_sweda_tms2() (machine_arch_type == MACH_TYPE_SWEDA_TMS2) #else -# define machine_is_craneboard() (0) +# define machine_is_sweda_tms2() (0) #endif
-#ifdef CONFIG_MACH_ES2440 +#ifdef CONFIG_MACH_MX53_LOCO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ES2440 +# define machine_arch_type MACH_TYPE_MX53_LOCO # endif -# define machine_is_es2440() (machine_arch_type == MACH_TYPE_ES2440) +# define machine_is_mx53_loco() (machine_arch_type == MACH_TYPE_MX53_LOCO) #else -# define machine_is_es2440() (0) +# define machine_is_mx53_loco() (0) #endif
-#ifdef CONFIG_MACH_NAJAY_A9263 +#ifdef CONFIG_MACH_ACER_A8 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NAJAY_A9263 +# define machine_arch_type MACH_TYPE_ACER_A8 # endif -# define machine_is_najay_a9263() (machine_arch_type == MACH_TYPE_NAJAY_A9263) +# define machine_is_acer_a8() (machine_arch_type == MACH_TYPE_ACER_A8) #else -# define machine_is_najay_a9263() (0) +# define machine_is_acer_a8() (0) #endif
-#ifdef CONFIG_MACH_HTCTORNADO +#ifdef CONFIG_MACH_ACER_GAUGUIN # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HTCTORNADO +# define machine_arch_type MACH_TYPE_ACER_GAUGUIN # endif -# define machine_is_htctornado() (machine_arch_type == MACH_TYPE_HTCTORNADO) +# define machine_is_acer_gauguin() (machine_arch_type == MACH_TYPE_ACER_GAUGUIN) #else -# define machine_is_htctornado() (0) +# define machine_is_acer_gauguin() (0) #endif
-#ifdef CONFIG_MACH_DIMM_MX257 +#ifdef CONFIG_MACH_GUPPY # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DIMM_MX257 +# define machine_arch_type MACH_TYPE_GUPPY # endif -# define machine_is_dimm_mx257() (machine_arch_type == MACH_TYPE_DIMM_MX257) +# define machine_is_guppy() (machine_arch_type == MACH_TYPE_GUPPY) #else -# define machine_is_dimm_mx257() (0) +# define machine_is_guppy() (0) #endif
-#ifdef CONFIG_MACH_JIGEN +#ifdef CONFIG_MACH_MX61_ARD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_JIGEN +# define machine_arch_type MACH_TYPE_MX61_ARD # endif -# define machine_is_jigen301() (machine_arch_type == MACH_TYPE_JIGEN) +# define machine_is_mx61_ard() (machine_arch_type == MACH_TYPE_MX61_ARD) #else -# define machine_is_jigen301() (0) +# define machine_is_mx61_ard() (0) #endif
-#ifdef CONFIG_MACH_SMDK6450 +#ifdef CONFIG_MACH_TX53 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SMDK6450 +# define machine_arch_type MACH_TYPE_TX53 # endif -# define machine_is_smdk6450() (machine_arch_type == MACH_TYPE_SMDK6450) +# define machine_is_tx53() (machine_arch_type == MACH_TYPE_TX53) #else -# define machine_is_smdk6450() (0) +# define machine_is_tx53() (0) #endif
-#ifdef CONFIG_MACH_MENO_QNG +#ifdef CONFIG_MACH_OMAPL138_CASE_A3 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MENO_QNG +# define machine_arch_type MACH_TYPE_OMAPL138_CASE_A3 # endif -# define machine_is_meno_qng() (machine_arch_type == MACH_TYPE_MENO_QNG) +# define machine_is_omapl138_case_a3() (machine_arch_type == MACH_TYPE_OMAPL138_CASE_A3) #else -# define machine_is_meno_qng() (0) +# define machine_is_omapl138_case_a3() (0) #endif
-#ifdef CONFIG_MACH_NS2416 +#ifdef CONFIG_MACH_UEMD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NS2416 +# define machine_arch_type MACH_TYPE_UEMD # endif -# define machine_is_ns2416() (machine_arch_type == MACH_TYPE_NS2416) +# define machine_is_uemd() (machine_arch_type == MACH_TYPE_UEMD) #else -# define machine_is_ns2416() (0) +# define machine_is_uemd() (0) #endif
-#ifdef CONFIG_MACH_RPC353 +#ifdef CONFIG_MACH_CCWMX51MUT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_RPC353 +# define machine_arch_type MACH_TYPE_CCWMX51MUT # endif -# define machine_is_rpc353() (machine_arch_type == MACH_TYPE_RPC353) +# define machine_is_ccwmx51mut() (machine_arch_type == MACH_TYPE_CCWMX51MUT) #else -# define machine_is_rpc353() (0) +# define machine_is_ccwmx51mut() (0) #endif
-#ifdef CONFIG_MACH_TQ6410 +#ifdef CONFIG_MACH_ROCKHOPPER # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TQ6410 +# define machine_arch_type MACH_TYPE_ROCKHOPPER # endif -# define machine_is_tq6410() (machine_arch_type == MACH_TYPE_TQ6410) +# define machine_is_rockhopper() (machine_arch_type == MACH_TYPE_ROCKHOPPER) #else -# define machine_is_tq6410() (0) +# define machine_is_rockhopper() (0) #endif
-#ifdef CONFIG_MACH_SKY6410 +#ifdef CONFIG_MACH_ENCORE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SKY6410 +# define machine_arch_type MACH_TYPE_ENCORE # endif -# define machine_is_sky6410() (machine_arch_type == MACH_TYPE_SKY6410) +# define machine_is_encore() (machine_arch_type == MACH_TYPE_ENCORE) #else -# define machine_is_sky6410() (0) +# define machine_is_encore() (0) #endif
-#ifdef CONFIG_MACH_DYNASTY +#ifdef CONFIG_MACH_HKDKC100 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DYNASTY +# define machine_arch_type MACH_TYPE_HKDKC100 # endif -# define machine_is_dynasty() (machine_arch_type == MACH_TYPE_DYNASTY) +# define machine_is_hkdkc100() (machine_arch_type == MACH_TYPE_HKDKC100) #else -# define machine_is_dynasty() (0) +# define machine_is_hkdkc100() (0) #endif
-#ifdef CONFIG_MACH_VIVO +#ifdef CONFIG_MACH_TS42XX # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VIVO +# define machine_arch_type MACH_TYPE_TS42XX # endif -# define machine_is_vivo() (machine_arch_type == MACH_TYPE_VIVO) +# define machine_is_ts42xx() (machine_arch_type == MACH_TYPE_TS42XX) #else -# define machine_is_vivo() (0) +# define machine_is_ts42xx() (0) #endif
-#ifdef CONFIG_MACH_BURY_BL7582 +#ifdef CONFIG_MACH_AEBL # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BURY_BL7582 +# define machine_arch_type MACH_TYPE_AEBL # endif -# define machine_is_bury_bl7582() (machine_arch_type == MACH_TYPE_BURY_BL7582) +# define machine_is_aebl() (machine_arch_type == MACH_TYPE_AEBL) #else -# define machine_is_bury_bl7582() (0) +# define machine_is_aebl() (0) #endif
-#ifdef CONFIG_MACH_BURY_BPS5270 +#ifdef CONFIG_MACH_WARIO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BURY_BPS5270 +# define machine_arch_type MACH_TYPE_WARIO # endif -# define machine_is_bury_bps5270() (machine_arch_type == MACH_TYPE_BURY_BPS5270) +# define machine_is_wario() (machine_arch_type == MACH_TYPE_WARIO) #else -# define machine_is_bury_bps5270() (0) +# define machine_is_wario() (0) #endif
-#ifdef CONFIG_MACH_BASI +#ifdef CONFIG_MACH_GFS_SPM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BASI +# define machine_arch_type MACH_TYPE_GFS_SPM # endif -# define machine_is_basi() (machine_arch_type == MACH_TYPE_BASI) +# define machine_is_gfs_spm() (machine_arch_type == MACH_TYPE_GFS_SPM) #else -# define machine_is_basi() (0) +# define machine_is_gfs_spm() (0) #endif
-#ifdef CONFIG_MACH_TN200 +#ifdef CONFIG_MACH_CM_T3730 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TN200 +# define machine_arch_type MACH_TYPE_CM_T3730 # endif -# define machine_is_tn200() (machine_arch_type == MACH_TYPE_TN200) +# define machine_is_cm_t3730() (machine_arch_type == MACH_TYPE_CM_T3730) #else -# define machine_is_tn200() (0) +# define machine_is_cm_t3730() (0) #endif
-#ifdef CONFIG_MACH_C2MMI +#ifdef CONFIG_MACH_ISC3 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_C2MMI +# define machine_arch_type MACH_TYPE_ISC3 # endif -# define machine_is_c2mmi() (machine_arch_type == MACH_TYPE_C2MMI) +# define machine_is_isc3() (machine_arch_type == MACH_TYPE_ISC3) #else -# define machine_is_c2mmi() (0) +# define machine_is_isc3() (0) #endif
-#ifdef CONFIG_MACH_MESON_6236M +#ifdef CONFIG_MACH_RASCAL # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MESON_6236M +# define machine_arch_type MACH_TYPE_RASCAL # endif -# define machine_is_meson_6236m() (machine_arch_type == MACH_TYPE_MESON_6236M) +# define machine_is_rascal() (machine_arch_type == MACH_TYPE_RASCAL) #else -# define machine_is_meson_6236m() (0) +# define machine_is_rascal() (0) #endif
-#ifdef CONFIG_MACH_MESON_8626M +#ifdef CONFIG_MACH_HREFV60 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MESON_8626M +# define machine_arch_type MACH_TYPE_HREFV60 # endif -# define machine_is_meson_8626m() (machine_arch_type == MACH_TYPE_MESON_8626M) +# define machine_is_hrefv60() (machine_arch_type == MACH_TYPE_HREFV60) #else -# define machine_is_meson_8626m() (0) +# define machine_is_hrefv60() (0) #endif
-#ifdef CONFIG_MACH_TUBE +#ifdef CONFIG_MACH_TPT_2_0 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TUBE +# define machine_arch_type MACH_TYPE_TPT_2_0 # endif -# define machine_is_tube() (machine_arch_type == MACH_TYPE_TUBE) +# define machine_is_tpt_2_0() (machine_arch_type == MACH_TYPE_TPT_2_0) #else -# define machine_is_tube() (0) +# define machine_is_tpt_2_0() (0) #endif
-#ifdef CONFIG_MACH_MESSINA +#ifdef CONFIG_MACH_SPLENDOR # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MESSINA +# define machine_arch_type MACH_TYPE_SPLENDOR # endif -# define machine_is_messina() (machine_arch_type == MACH_TYPE_MESSINA) +# define machine_is_splendor() (machine_arch_type == MACH_TYPE_SPLENDOR) #else -# define machine_is_messina() (0) +# define machine_is_splendor() (0) #endif
-#ifdef CONFIG_MACH_MX50_ARM2 +#ifdef CONFIG_MACH_MSM8X60_QT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MX50_ARM2 +# define machine_arch_type MACH_TYPE_MSM8X60_QT # endif -# define machine_is_mx50_arm2() (machine_arch_type == MACH_TYPE_MX50_ARM2) +# define machine_is_msm8x60_qt() (machine_arch_type == MACH_TYPE_MSM8X60_QT) #else -# define machine_is_mx50_arm2() (0) +# define machine_is_msm8x60_qt() (0) #endif
-#ifdef CONFIG_MACH_CETUS9263 +#ifdef CONFIG_MACH_HTC_HD_MINI # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CETUS9263 +# define machine_arch_type MACH_TYPE_HTC_HD_MINI # endif -# define machine_is_cetus9263() (machine_arch_type == MACH_TYPE_CETUS9263) +# define machine_is_htc_hd_mini() (machine_arch_type == MACH_TYPE_HTC_HD_MINI) #else -# define machine_is_cetus9263() (0) +# define machine_is_htc_hd_mini() (0) #endif
-#ifdef CONFIG_MACH_BROWNSTONE +#ifdef CONFIG_MACH_ATHENE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BROWNSTONE +# define machine_arch_type MACH_TYPE_ATHENE # endif -# define machine_is_brownstone() (machine_arch_type == MACH_TYPE_BROWNSTONE) +# define machine_is_athene() (machine_arch_type == MACH_TYPE_ATHENE) #else -# define machine_is_brownstone() (0) +# define machine_is_athene() (0) #endif
-#ifdef CONFIG_MACH_VMX25 +#ifdef CONFIG_MACH_DEEP_R_EK_1 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VMX25 +# define machine_arch_type MACH_TYPE_DEEP_R_EK_1 # endif -# define machine_is_vmx25() (machine_arch_type == MACH_TYPE_VMX25) +# define machine_is_deep_r_ek_1() (machine_arch_type == MACH_TYPE_DEEP_R_EK_1) #else -# define machine_is_vmx25() (0) +# define machine_is_deep_r_ek_1() (0) #endif
-#ifdef CONFIG_MACH_VMX51 +#ifdef CONFIG_MACH_VIVOW_CT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VMX51 +# define machine_arch_type MACH_TYPE_VIVOW_CT # endif -# define machine_is_vmx51() (machine_arch_type == MACH_TYPE_VMX51) +# define machine_is_vivow_ct() (machine_arch_type == MACH_TYPE_VIVOW_CT) #else -# define machine_is_vmx51() (0) +# define machine_is_vivow_ct() (0) #endif
-#ifdef CONFIG_MACH_ABACUS +#ifdef CONFIG_MACH_NERY_1000 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ABACUS +# define machine_arch_type MACH_TYPE_NERY_1000 # endif -# define machine_is_abacus() (machine_arch_type == MACH_TYPE_ABACUS) +# define machine_is_nery_1000() (machine_arch_type == MACH_TYPE_NERY_1000) #else -# define machine_is_abacus() (0) +# define machine_is_nery_1000() (0) #endif
-#ifdef CONFIG_MACH_CM4745 +#ifdef CONFIG_MACH_RFL109145_SSRV # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CM4745 +# define machine_arch_type MACH_TYPE_RFL109145_SSRV # endif -# define machine_is_cm4745() (machine_arch_type == MACH_TYPE_CM4745) +# define machine_is_rfl109145_ssrv() (machine_arch_type == MACH_TYPE_RFL109145_SSRV) #else -# define machine_is_cm4745() (0) +# define machine_is_rfl109145_ssrv() (0) #endif
-#ifdef CONFIG_MACH_ORATISLINK +#ifdef CONFIG_MACH_NMH # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ORATISLINK +# define machine_arch_type MACH_TYPE_NMH # endif -# define machine_is_oratislink() (machine_arch_type == MACH_TYPE_ORATISLINK) +# define machine_is_nmh() (machine_arch_type == MACH_TYPE_NMH) #else -# define machine_is_oratislink() (0) +# define machine_is_nmh() (0) #endif
-#ifdef CONFIG_MACH_DAVINCI_DM365_DVR +#ifdef CONFIG_MACH_WN802T # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DAVINCI_DM365_DVR +# define machine_arch_type MACH_TYPE_WN802T # endif -# define machine_is_davinci_dm365_dvr() (machine_arch_type == MACH_TYPE_DAVINCI_DM365_DVR) +# define machine_is_wn802t() (machine_arch_type == MACH_TYPE_WN802T) #else -# define machine_is_davinci_dm365_dvr() (0) +# define machine_is_wn802t() (0) #endif
-#ifdef CONFIG_MACH_NETVIZ +#ifdef CONFIG_MACH_DRAGONET # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NETVIZ +# define machine_arch_type MACH_TYPE_DRAGONET # endif -# define machine_is_netviz() (machine_arch_type == MACH_TYPE_NETVIZ) +# define machine_is_dragonet() (machine_arch_type == MACH_TYPE_DRAGONET) #else -# define machine_is_netviz() (0) +# define machine_is_dragonet() (0) #endif
-#ifdef CONFIG_MACH_FLEXIBITY +#ifdef CONFIG_MACH_AT91SAM9263DESK16L # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_FLEXIBITY +# define machine_arch_type MACH_TYPE_AT91SAM9263DESK16L # endif -# define machine_is_flexibity() (machine_arch_type == MACH_TYPE_FLEXIBITY) +# define machine_is_at91sam9263desk16l() (machine_arch_type == MACH_TYPE_AT91SAM9263DESK16L) #else -# define machine_is_flexibity() (0) +# define machine_is_at91sam9263desk16l() (0) #endif
-#ifdef CONFIG_MACH_WLAN_COMPUTER +#ifdef CONFIG_MACH_BCMHANA_SV # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_WLAN_COMPUTER +# define machine_arch_type MACH_TYPE_BCMHANA_SV # endif -# define machine_is_wlan_computer() (machine_arch_type == MACH_TYPE_WLAN_COMPUTER) +# define machine_is_bcmhana_sv() (machine_arch_type == MACH_TYPE_BCMHANA_SV) #else -# define machine_is_wlan_computer() (0) +# define machine_is_bcmhana_sv() (0) #endif
-#ifdef CONFIG_MACH_LPC24XX +#ifdef CONFIG_MACH_BCMHANA_TABLET # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_LPC24XX +# define machine_arch_type MACH_TYPE_BCMHANA_TABLET # endif -# define machine_is_lpc24xx() (machine_arch_type == MACH_TYPE_LPC24XX) +# define machine_is_bcmhana_tablet() (machine_arch_type == MACH_TYPE_BCMHANA_TABLET) #else -# define machine_is_lpc24xx() (0) +# define machine_is_bcmhana_tablet() (0) #endif
-#ifdef CONFIG_MACH_SPICA +#ifdef CONFIG_MACH_KOI # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SPICA +# define machine_arch_type MACH_TYPE_KOI # endif -# define machine_is_spica() (machine_arch_type == MACH_TYPE_SPICA) +# define machine_is_koi() (machine_arch_type == MACH_TYPE_KOI) #else -# define machine_is_spica() (0) +# define machine_is_koi() (0) #endif
-#ifdef CONFIG_MACH_GPSDISPLAY +#ifdef CONFIG_MACH_TS4800 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GPSDISPLAY +# define machine_arch_type MACH_TYPE_TS4800 # endif -# define machine_is_gpsdisplay() (machine_arch_type == MACH_TYPE_GPSDISPLAY) +# define machine_is_ts4800() (machine_arch_type == MACH_TYPE_TS4800) #else -# define machine_is_gpsdisplay() (0) +# define machine_is_ts4800() (0) #endif
-#ifdef CONFIG_MACH_BIPNET +#ifdef CONFIG_MACH_TQMA9263 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BIPNET +# define machine_arch_type MACH_TYPE_TQMA9263 # endif -# define machine_is_bipnet() (machine_arch_type == MACH_TYPE_BIPNET) +# define machine_is_tqma9263() (machine_arch_type == MACH_TYPE_TQMA9263) #else -# define machine_is_bipnet() (0) +# define machine_is_tqma9263() (0) #endif
-#ifdef CONFIG_MACH_OVERO_CTU_INERTIAL +#ifdef CONFIG_MACH_HOLIDAY # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OVERO_CTU_INERTIAL +# define machine_arch_type MACH_TYPE_HOLIDAY # endif -# define machine_is_overo_ctu_inertial() (machine_arch_type == MACH_TYPE_OVERO_CTU_INERTIAL) +# define machine_is_holiday() (machine_arch_type == MACH_TYPE_HOLIDAY) #else -# define machine_is_overo_ctu_inertial() (0) +# define machine_is_holiday() (0) #endif
-#ifdef CONFIG_MACH_DAVINCI_DM355_MMM +#ifdef CONFIG_MACH_PCATS_OVERLAY # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DAVINCI_DM355_MMM +# define machine_arch_type MACH_TYPE_PCATS_OVERLAY # endif -# define machine_is_davinci_dm355_mmm() (machine_arch_type == MACH_TYPE_DAVINCI_DM355_MMM) +# define machine_is_pcats_overlay() (machine_arch_type == MACH_TYPE_PCATS_OVERLAY) #else -# define machine_is_davinci_dm355_mmm() (0) +# define machine_is_pcats_overlay() (0) #endif
-#ifdef CONFIG_MACH_PC9260_V2 +#ifdef CONFIG_MACH_HWGW6410 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PC9260_V2 +# define machine_arch_type MACH_TYPE_HWGW6410 # endif -# define machine_is_pc9260_v2() (machine_arch_type == MACH_TYPE_PC9260_V2) +# define machine_is_hwgw6410() (machine_arch_type == MACH_TYPE_HWGW6410) #else -# define machine_is_pc9260_v2() (0) +# define machine_is_hwgw6410() (0) #endif
-#ifdef CONFIG_MACH_PTX7545 +#ifdef CONFIG_MACH_SHENZHOU # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PTX7545 +# define machine_arch_type MACH_TYPE_SHENZHOU # endif -# define machine_is_ptx7545() (machine_arch_type == MACH_TYPE_PTX7545) +# define machine_is_shenzhou() (machine_arch_type == MACH_TYPE_SHENZHOU) #else -# define machine_is_ptx7545() (0) +# define machine_is_shenzhou() (0) #endif
-#ifdef CONFIG_MACH_TM_EFDC +#ifdef CONFIG_MACH_CWME9210 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TM_EFDC +# define machine_arch_type MACH_TYPE_CWME9210 # endif -# define machine_is_tm_efdc() (machine_arch_type == MACH_TYPE_TM_EFDC) +# define machine_is_cwme9210() (machine_arch_type == MACH_TYPE_CWME9210) #else -# define machine_is_tm_efdc() (0) +# define machine_is_cwme9210() (0) #endif
-#ifdef CONFIG_MACH_OMAP3_WALDO1 +#ifdef CONFIG_MACH_CWME9210JS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OMAP3_WALDO1 +# define machine_arch_type MACH_TYPE_CWME9210JS # endif -# define machine_is_omap3_waldo1() (machine_arch_type == MACH_TYPE_OMAP3_WALDO1) +# define machine_is_cwme9210js() (machine_arch_type == MACH_TYPE_CWME9210JS) #else -# define machine_is_omap3_waldo1() (0) +# define machine_is_cwme9210js() (0) #endif
-#ifdef CONFIG_MACH_FLYER +#ifdef CONFIG_MACH_COLIBRI_TEGRA2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_FLYER +# define machine_arch_type MACH_TYPE_COLIBRI_TEGRA2 # endif -# define machine_is_flyer() (machine_arch_type == MACH_TYPE_FLYER) +# define machine_is_colibri_tegra2() (machine_arch_type == MACH_TYPE_COLIBRI_TEGRA2) #else -# define machine_is_flyer() (0) +# define machine_is_colibri_tegra2() (0) #endif
-#ifdef CONFIG_MACH_TORNADO3240 +#ifdef CONFIG_MACH_W21 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TORNADO3240 +# define machine_arch_type MACH_TYPE_W21 # endif -# define machine_is_tornado3240() (machine_arch_type == MACH_TYPE_TORNADO3240) +# define machine_is_w21() (machine_arch_type == MACH_TYPE_W21) #else -# define machine_is_tornado3240() (0) +# define machine_is_w21() (0) #endif
-#ifdef CONFIG_MACH_SOLI_01 +#ifdef CONFIG_MACH_POLYSAT1 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SOLI_01 +# define machine_arch_type MACH_TYPE_POLYSAT1 # endif -# define machine_is_soli_01() (machine_arch_type == MACH_TYPE_SOLI_01) +# define machine_is_polysat1() (machine_arch_type == MACH_TYPE_POLYSAT1) #else -# define machine_is_soli_01() (0) +# define machine_is_polysat1() (0) #endif
-#ifdef CONFIG_MACH_OMAPL138_EUROPALC +#ifdef CONFIG_MACH_DATAWAY # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OMAPL138_EUROPALC +# define machine_arch_type MACH_TYPE_DATAWAY # endif -# define machine_is_omapl138_europalc() (machine_arch_type == MACH_TYPE_OMAPL138_EUROPALC) +# define machine_is_dataway() (machine_arch_type == MACH_TYPE_DATAWAY) #else -# define machine_is_omapl138_europalc() (0) +# define machine_is_dataway() (0) #endif
-#ifdef CONFIG_MACH_HELIOS_V1 +#ifdef CONFIG_MACH_COBRAL138 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HELIOS_V1 +# define machine_arch_type MACH_TYPE_COBRAL138 # endif -# define machine_is_helios_v1() (machine_arch_type == MACH_TYPE_HELIOS_V1) +# define machine_is_cobral138() (machine_arch_type == MACH_TYPE_COBRAL138) #else -# define machine_is_helios_v1() (0) +# define machine_is_cobral138() (0) #endif
-#ifdef CONFIG_MACH_NETSPACE_LITE_V2 +#ifdef CONFIG_MACH_ROVERPCS8 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NETSPACE_LITE_V2 +# define machine_arch_type MACH_TYPE_ROVERPCS8 # endif -# define machine_is_netspace_lite_v2() (machine_arch_type == MACH_TYPE_NETSPACE_LITE_V2) +# define machine_is_roverpcs8() (machine_arch_type == MACH_TYPE_ROVERPCS8) #else -# define machine_is_netspace_lite_v2() (0) +# define machine_is_roverpcs8() (0) #endif
-#ifdef CONFIG_MACH_SSC +#ifdef CONFIG_MACH_MARVELC # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SSC +# define machine_arch_type MACH_TYPE_MARVELC # endif -# define machine_is_ssc() (machine_arch_type == MACH_TYPE_SSC) +# define machine_is_marvelc() (machine_arch_type == MACH_TYPE_MARVELC) #else -# define machine_is_ssc() (0) +# define machine_is_marvelc() (0) #endif
-#ifdef CONFIG_MACH_PREMIERWAVE_EN +#ifdef CONFIG_MACH_NAVEFIHID # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PREMIERWAVE_EN +# define machine_arch_type MACH_TYPE_NAVEFIHID # endif -# define machine_is_premierwave_en() (machine_arch_type == MACH_TYPE_PREMIERWAVE_EN) +# define machine_is_navefihid() (machine_arch_type == MACH_TYPE_NAVEFIHID) #else -# define machine_is_premierwave_en() (0) +# define machine_is_navefihid() (0) #endif
-#ifdef CONFIG_MACH_WASABI +#ifdef CONFIG_MACH_DM365_CV100 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_WASABI +# define machine_arch_type MACH_TYPE_DM365_CV100 # endif -# define machine_is_wasabi() (machine_arch_type == MACH_TYPE_WASABI) +# define machine_is_dm365_cv100() (machine_arch_type == MACH_TYPE_DM365_CV100) #else -# define machine_is_wasabi() (0) +# define machine_is_dm365_cv100() (0) #endif
-#ifdef CONFIG_MACH_MX50_RDP +#ifdef CONFIG_MACH_ABLE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MX50_RDP +# define machine_arch_type MACH_TYPE_ABLE # endif -# define machine_is_mx50_rdp() (machine_arch_type == MACH_TYPE_MX50_RDP) +# define machine_is_able() (machine_arch_type == MACH_TYPE_ABLE) #else -# define machine_is_mx50_rdp() (0) +# define machine_is_able() (0) #endif
-#ifdef CONFIG_MACH_UNIVERSAL_C210 +#ifdef CONFIG_MACH_LEGACY +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_LEGACY +# endif +# define machine_is_legacy() (machine_arch_type == MACH_TYPE_LEGACY) +#else +# define machine_is_legacy() (0) +#endif + +#ifdef CONFIG_MACH_ICONG +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_ICONG +# endif +# define machine_is_icong() (machine_arch_type == MACH_TYPE_ICONG) +#else +# define machine_is_icong() (0) +#endif + +#ifdef CONFIG_MACH_ROVER_G8 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_ROVER_G8 +# endif +# define machine_is_rover_g8() (machine_arch_type == MACH_TYPE_ROVER_G8) +#else +# define machine_is_rover_g8() (0) +#endif + +#ifdef CONFIG_MACH_T5388P +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_T5388P +# endif +# define machine_is_t5388p() (machine_arch_type == MACH_TYPE_T5388P) +#else +# define machine_is_t5388p() (0) +#endif + +#ifdef CONFIG_MACH_DINGO +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_DINGO +# endif +# define machine_is_dingo() (machine_arch_type == MACH_TYPE_DINGO) +#else +# define machine_is_dingo() (0) +#endif + +#ifdef CONFIG_MACH_GOFLEXHOME +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_GOFLEXHOME +# endif +# define machine_is_goflexhome() (machine_arch_type == MACH_TYPE_GOFLEXHOME) +#else +# define machine_is_goflexhome() (0) +#endif + +#ifdef CONFIG_MACH_LANREADYFN511 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_LANREADYFN511 +# endif +# define machine_is_lanreadyfn511() (machine_arch_type == MACH_TYPE_LANREADYFN511) +#else +# define machine_is_lanreadyfn511() (0) +#endif + +#ifdef CONFIG_MACH_OMAP3_BAIA +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_OMAP3_BAIA +# endif +# define machine_is_omap3_baia() (machine_arch_type == MACH_TYPE_OMAP3_BAIA) +#else +# define machine_is_omap3_baia() (0) +#endif + +#ifdef CONFIG_MACH_OMAP3SMARTDISPLAY +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_OMAP3SMARTDISPLAY +# endif +# define machine_is_omap3smartdisplay() (machine_arch_type == MACH_TYPE_OMAP3SMARTDISPLAY) +#else +# define machine_is_omap3smartdisplay() (0) +#endif + +#ifdef CONFIG_MACH_XILINX +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_XILINX +# endif +# define machine_is_xilinx() (machine_arch_type == MACH_TYPE_XILINX) +#else +# define machine_is_xilinx() (0) +#endif + +#ifdef CONFIG_MACH_A2F +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_A2F +# endif +# define machine_is_a2f() (machine_arch_type == MACH_TYPE_A2F) +#else +# define machine_is_a2f() (0) +#endif + +#ifdef CONFIG_MACH_SKY25 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_SKY25 +# endif +# define machine_is_sky25() (machine_arch_type == MACH_TYPE_SKY25) +#else +# define machine_is_sky25() (0) +#endif + +#ifdef CONFIG_MACH_CCMX53 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_CCMX53 +# endif +# define machine_is_ccmx53() (machine_arch_type == MACH_TYPE_CCMX53) +#else +# define machine_is_ccmx53() (0) +#endif + +#ifdef CONFIG_MACH_CCMX53JS +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_CCMX53JS +# endif +# define machine_is_ccmx53js() (machine_arch_type == MACH_TYPE_CCMX53JS) +#else +# define machine_is_ccmx53js() (0) +#endif + +#ifdef CONFIG_MACH_CCWMX53 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_CCWMX53 +# endif +# define machine_is_ccwmx53() (machine_arch_type == MACH_TYPE_CCWMX53) +#else +# define machine_is_ccwmx53() (0) +#endif + +#ifdef CONFIG_MACH_CCWMX53JS +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_CCWMX53JS +# endif +# define machine_is_ccwmx53js() (machine_arch_type == MACH_TYPE_CCWMX53JS) +#else +# define machine_is_ccwmx53js() (0) +#endif + +#ifdef CONFIG_MACH_FRISMS +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_FRISMS +# endif +# define machine_is_frisms() (machine_arch_type == MACH_TYPE_FRISMS) +#else +# define machine_is_frisms() (0) +#endif + +#ifdef CONFIG_MACH_MSM7X27A_FFA +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_MSM7X27A_FFA +# endif +# define machine_is_msm7x27a_ffa() (machine_arch_type == MACH_TYPE_MSM7X27A_FFA) +#else +# define machine_is_msm7x27a_ffa() (0) +#endif + +#ifdef CONFIG_MACH_MSM7X27A_SURF +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_MSM7X27A_SURF +# endif +# define machine_is_msm7x27a_surf() (machine_arch_type == MACH_TYPE_MSM7X27A_SURF) +#else +# define machine_is_msm7x27a_surf() (0) +#endif + +#ifdef CONFIG_MACH_MSM7X27A_RUMI3 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_MSM7X27A_RUMI3 +# endif +# define machine_is_msm7x27a_rumi3() (machine_arch_type == MACH_TYPE_MSM7X27A_RUMI3) +#else +# define machine_is_msm7x27a_rumi3() (0) +#endif + +#ifdef CONFIG_MACH_DIMMSAM9G20 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_DIMMSAM9G20 +# endif +# define machine_is_dimmsam9g20() (machine_arch_type == MACH_TYPE_DIMMSAM9G20) +#else +# define machine_is_dimmsam9g20() (0) +#endif + +#ifdef CONFIG_MACH_DIMM_IMX28 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_DIMM_IMX28 +# endif +# define machine_is_dimm_imx28() (machine_arch_type == MACH_TYPE_DIMM_IMX28) +#else +# define machine_is_dimm_imx28() (0) +#endif + +#ifdef CONFIG_MACH_AMK_A4 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_AMK_A4 +# endif +# define machine_is_amk_a4() (machine_arch_type == MACH_TYPE_AMK_A4) +#else +# define machine_is_amk_a4() (0) +#endif + +#ifdef CONFIG_MACH_GNET_SGME +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_GNET_SGME +# endif +# define machine_is_gnet_sgme() (machine_arch_type == MACH_TYPE_GNET_SGME) +#else +# define machine_is_gnet_sgme() (0) +#endif + +#ifdef CONFIG_MACH_SHOOTER_U +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_SHOOTER_U +# endif +# define machine_is_shooter_u() (machine_arch_type == MACH_TYPE_SHOOTER_U) +#else +# define machine_is_shooter_u() (0) +#endif + +#ifdef CONFIG_MACH_VMX53 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_VMX53 +# endif +# define machine_is_vmx53() (machine_arch_type == MACH_TYPE_VMX53) +#else +# define machine_is_vmx53() (0) +#endif + +#ifdef CONFIG_MACH_RHINO +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_RHINO +# endif +# define machine_is_rhino() (machine_arch_type == MACH_TYPE_RHINO) +#else +# define machine_is_rhino() (0) +#endif + +#ifdef CONFIG_MACH_ARMLEX4210 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_UNIVERSAL_C210 +# define machine_arch_type MACH_TYPE_ARMLEX4210 # endif -# define machine_is_universal_c210() (machine_arch_type == MACH_TYPE_UNIVERSAL_C210) +# define machine_is_armlex4210() (machine_arch_type == MACH_TYPE_ARMLEX4210) #else -# define machine_is_universal_c210() (0) +# define machine_is_armlex4210() (0) #endif
-#ifdef CONFIG_MACH_REAL6410 +#ifdef CONFIG_MACH_SWARCOEXTMODEM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_REAL6410 +# define machine_arch_type MACH_TYPE_SWARCOEXTMODEM # endif -# define machine_is_real6410() (machine_arch_type == MACH_TYPE_REAL6410) +# define machine_is_swarcoextmodem() (machine_arch_type == MACH_TYPE_SWARCOEXTMODEM) #else -# define machine_is_real6410() (0) +# define machine_is_swarcoextmodem() (0) +#endif + +#ifdef CONFIG_MACH_SNOWBALL +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_SNOWBALL +# endif +# define machine_is_snowball() (machine_arch_type == MACH_TYPE_SNOWBALL) +#else +# define machine_is_snowball() (0) +#endif + +#ifdef CONFIG_MACH_PCM049 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_PCM049 +# endif +# define machine_is_pcm049() (machine_arch_type == MACH_TYPE_PCM049) +#else +# define machine_is_pcm049() (0) +#endif + +#ifdef CONFIG_MACH_VIGOR +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_VIGOR +# endif +# define machine_is_vigor() (machine_arch_type == MACH_TYPE_VIGOR) +#else +# define machine_is_vigor() (0) +#endif + +#ifdef CONFIG_MACH_OSLO_AMUNDSEN +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_OSLO_AMUNDSEN +# endif +# define machine_is_oslo_amundsen() (machine_arch_type == MACH_TYPE_OSLO_AMUNDSEN) +#else +# define machine_is_oslo_amundsen() (0) +#endif + +#ifdef CONFIG_MACH_GSL_DIAMOND +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_GSL_DIAMOND +# endif +# define machine_is_gsl_diamond() (machine_arch_type == MACH_TYPE_GSL_DIAMOND) +#else +# define machine_is_gsl_diamond() (0) +#endif + +#ifdef CONFIG_MACH_CV2201 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_CV2201 +# endif +# define machine_is_cv2201() (machine_arch_type == MACH_TYPE_CV2201) +#else +# define machine_is_cv2201() (0) +#endif + +#ifdef CONFIG_MACH_CV2202 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_CV2202 +# endif +# define machine_is_cv2202() (machine_arch_type == MACH_TYPE_CV2202) +#else +# define machine_is_cv2202() (0) +#endif + +#ifdef CONFIG_MACH_CV2203 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_CV2203 +# endif +# define machine_is_cv2203() (machine_arch_type == MACH_TYPE_CV2203) +#else +# define machine_is_cv2203() (0) +#endif + +#ifdef CONFIG_MACH_VIT_IBOX +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_VIT_IBOX +# endif +# define machine_is_vit_ibox() (machine_arch_type == MACH_TYPE_VIT_IBOX) +#else +# define machine_is_vit_ibox() (0) +#endif + +#ifdef CONFIG_MACH_DM6441_ESP +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_DM6441_ESP +# endif +# define machine_is_dm6441_esp() (machine_arch_type == MACH_TYPE_DM6441_ESP) +#else +# define machine_is_dm6441_esp() (0) +#endif + +#ifdef CONFIG_MACH_AT91SAM9X5EK +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_AT91SAM9X5EK +# endif +# define machine_is_at91sam9x5ek() (machine_arch_type == MACH_TYPE_AT91SAM9X5EK) +#else +# define machine_is_at91sam9x5ek() (0) +#endif + +#ifdef CONFIG_MACH_LIBRA +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_LIBRA +# endif +# define machine_is_libra() (machine_arch_type == MACH_TYPE_LIBRA) +#else +# define machine_is_libra() (0) +#endif + +#ifdef CONFIG_MACH_EASYCRRH +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_EASYCRRH +# endif +# define machine_is_easycrrh() (machine_arch_type == MACH_TYPE_EASYCRRH) +#else +# define machine_is_easycrrh() (0) +#endif + +#ifdef CONFIG_MACH_TRIPEL +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_TRIPEL +# endif +# define machine_is_tripel() (machine_arch_type == MACH_TYPE_TRIPEL) +#else +# define machine_is_tripel() (0) +#endif + +#ifdef CONFIG_MACH_ENDIAN_MINI +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_ENDIAN_MINI +# endif +# define machine_is_endian_mini() (machine_arch_type == MACH_TYPE_ENDIAN_MINI) +#else +# define machine_is_endian_mini() (0) +#endif + +#ifdef CONFIG_MACH_XILINX_EP107 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_XILINX_EP107 +# endif +# define machine_is_xilinx_ep107() (machine_arch_type == MACH_TYPE_XILINX_EP107) +#else +# define machine_is_xilinx_ep107() (0) +#endif + +#ifdef CONFIG_MACH_NURI +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_NURI +# endif +# define machine_is_nuri() (machine_arch_type == MACH_TYPE_NURI) +#else +# define machine_is_nuri() (0) +#endif + +#ifdef CONFIG_MACH_JANUS +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_JANUS +# endif +# define machine_is_janus() (machine_arch_type == MACH_TYPE_JANUS) +#else +# define machine_is_janus() (0) +#endif + +#ifdef CONFIG_MACH_DDNAS +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_DDNAS +# endif +# define machine_is_ddnas() (machine_arch_type == MACH_TYPE_DDNAS) +#else +# define machine_is_ddnas() (0) #endif
-#ifdef CONFIG_MACH_SPX_SAKURA +#ifdef CONFIG_MACH_TAG # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SPX_SAKURA +# define machine_arch_type MACH_TYPE_TAG # endif -# define machine_is_spx_sakura() (machine_arch_type == MACH_TYPE_SPX_SAKURA) +# define machine_is_tag() (machine_arch_type == MACH_TYPE_TAG) #else -# define machine_is_spx_sakura() (0) +# define machine_is_tag() (0) #endif
-#ifdef CONFIG_MACH_IJ3K_2440 +#ifdef CONFIG_MACH_TAGW # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_IJ3K_2440 +# define machine_arch_type MACH_TYPE_TAGW # endif -# define machine_is_ij3k_2440() (machine_arch_type == MACH_TYPE_IJ3K_2440) +# define machine_is_tagw() (machine_arch_type == MACH_TYPE_TAGW) #else -# define machine_is_ij3k_2440() (0) +# define machine_is_tagw() (0) #endif
-#ifdef CONFIG_MACH_OMAP3_BC10 +#ifdef CONFIG_MACH_NITROGEN_VM_IMX51 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OMAP3_BC10 +# define machine_arch_type MACH_TYPE_NITROGEN_VM_IMX51 # endif -# define machine_is_omap3_bc10() (machine_arch_type == MACH_TYPE_OMAP3_BC10) +# define machine_is_nitrogen_vm_imx51() (machine_arch_type == MACH_TYPE_NITROGEN_VM_IMX51) #else -# define machine_is_omap3_bc10() (0) +# define machine_is_nitrogen_vm_imx51() (0) #endif
-#ifdef CONFIG_MACH_THEBE +#ifdef CONFIG_MACH_VIPRINET # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_THEBE +# define machine_arch_type MACH_TYPE_VIPRINET # endif -# define machine_is_thebe() (machine_arch_type == MACH_TYPE_THEBE) +# define machine_is_viprinet() (machine_arch_type == MACH_TYPE_VIPRINET) #else -# define machine_is_thebe() (0) +# define machine_is_viprinet() (0) #endif
-#ifdef CONFIG_MACH_RV082 +#ifdef CONFIG_MACH_BOCKW # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_RV082 +# define machine_arch_type MACH_TYPE_BOCKW # endif -# define machine_is_rv082() (machine_arch_type == MACH_TYPE_RV082) +# define machine_is_bockw() (machine_arch_type == MACH_TYPE_BOCKW) #else -# define machine_is_rv082() (0) +# define machine_is_bockw() (0) #endif
-#ifdef CONFIG_MACH_ARMLGUEST +#ifdef CONFIG_MACH_EVA2000 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ARMLGUEST +# define machine_arch_type MACH_TYPE_EVA2000 # endif -# define machine_is_armlguest() (machine_arch_type == MACH_TYPE_ARMLGUEST) +# define machine_is_eva2000() (machine_arch_type == MACH_TYPE_EVA2000) #else -# define machine_is_armlguest() (0) +# define machine_is_eva2000() (0) #endif
-#ifdef CONFIG_MACH_TJINC1000 +#ifdef CONFIG_MACH_STEELYARD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TJINC1000 +# define machine_arch_type MACH_TYPE_STEELYARD # endif -# define machine_is_tjinc1000() (machine_arch_type == MACH_TYPE_TJINC1000) +# define machine_is_steelyard() (machine_arch_type == MACH_TYPE_STEELYARD) #else -# define machine_is_tjinc1000() (0) +# define machine_is_steelyard() (0) #endif
-#ifdef CONFIG_MACH_DOCKSTAR +#ifdef CONFIG_MACH_NSSLSBOARD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DOCKSTAR +# define machine_arch_type MACH_TYPE_NSSLSBOARD # endif -# define machine_is_dockstar() (machine_arch_type == MACH_TYPE_DOCKSTAR) +# define machine_is_nsslsboard() (machine_arch_type == MACH_TYPE_NSSLSBOARD) #else -# define machine_is_dockstar() (0) +# define machine_is_nsslsboard() (0) #endif
-#ifdef CONFIG_MACH_AX8008 +#ifdef CONFIG_MACH_GENEVA_B5 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_AX8008 +# define machine_arch_type MACH_TYPE_GENEVA_B5 # endif -# define machine_is_ax8008() (machine_arch_type == MACH_TYPE_AX8008) +# define machine_is_geneva_b5() (machine_arch_type == MACH_TYPE_GENEVA_B5) #else -# define machine_is_ax8008() (0) +# define machine_is_geneva_b5() (0) #endif
-#ifdef CONFIG_MACH_GNET_SGCE +#ifdef CONFIG_MACH_SPEAR1340 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GNET_SGCE +# define machine_arch_type MACH_TYPE_SPEAR1340 # endif -# define machine_is_gnet_sgce() (machine_arch_type == MACH_TYPE_GNET_SGCE) +# define machine_is_spear1340() (machine_arch_type == MACH_TYPE_SPEAR1340) #else -# define machine_is_gnet_sgce() (0) +# define machine_is_spear1340() (0) #endif
-#ifdef CONFIG_MACH_PXWNAS_500_1000 +#ifdef CONFIG_MACH_REXMAS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PXWNAS_500_1000 +# define machine_arch_type MACH_TYPE_REXMAS # endif -# define machine_is_pxwnas_500_1000() (machine_arch_type == MACH_TYPE_PXWNAS_500_1000) +# define machine_is_rexmas() (machine_arch_type == MACH_TYPE_REXMAS) #else -# define machine_is_pxwnas_500_1000() (0) +# define machine_is_rexmas() (0) #endif
-#ifdef CONFIG_MACH_EA20 +#ifdef CONFIG_MACH_MSM8960_CDP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_EA20 +# define machine_arch_type MACH_TYPE_MSM8960_CDP # endif -# define machine_is_ea20() (machine_arch_type == MACH_TYPE_EA20) +# define machine_is_msm8960_cdp() (machine_arch_type == MACH_TYPE_MSM8960_CDP) #else -# define machine_is_ea20() (0) +# define machine_is_msm8960_cdp() (0) #endif
-#ifdef CONFIG_MACH_AWM2 +#ifdef CONFIG_MACH_MSM8960_FLUID # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_AWM2 +# define machine_arch_type MACH_TYPE_MSM8960_FLUID # endif -# define machine_is_awm2() (machine_arch_type == MACH_TYPE_AWM2) +# define machine_is_msm8960_fluid() (machine_arch_type == MACH_TYPE_MSM8960_FLUID) #else -# define machine_is_awm2() (0) +# define machine_is_msm8960_fluid() (0) #endif
-#ifdef CONFIG_MACH_TI8148EVM +#ifdef CONFIG_MACH_MSM8960_APQ # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TI8148EVM +# define machine_arch_type MACH_TYPE_MSM8960_APQ # endif -# define machine_is_ti8148evm() (machine_arch_type == MACH_TYPE_TI8148EVM) +# define machine_is_msm8960_apq() (machine_arch_type == MACH_TYPE_MSM8960_APQ) #else -# define machine_is_ti8148evm() (0) +# define machine_is_msm8960_apq() (0) #endif
-#ifdef CONFIG_MACH_SEABOARD +#ifdef CONFIG_MACH_HELIOS_V2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SEABOARD +# define machine_arch_type MACH_TYPE_HELIOS_V2 # endif -# define machine_is_seaboard() (machine_arch_type == MACH_TYPE_SEABOARD) +# define machine_is_helios_v2() (machine_arch_type == MACH_TYPE_HELIOS_V2) #else -# define machine_is_seaboard() (0) +# define machine_is_helios_v2() (0) #endif
-#ifdef CONFIG_MACH_LINKSTATION_CHLV2 +#ifdef CONFIG_MACH_MIF10P # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_LINKSTATION_CHLV2 +# define machine_arch_type MACH_TYPE_MIF10P # endif -# define machine_is_linkstation_chlv2() (machine_arch_type == MACH_TYPE_LINKSTATION_CHLV2) +# define machine_is_mif10p() (machine_arch_type == MACH_TYPE_MIF10P) #else -# define machine_is_linkstation_chlv2() (0) +# define machine_is_mif10p() (0) #endif
-#ifdef CONFIG_MACH_TERA_PRO2_RACK +#ifdef CONFIG_MACH_IAM28 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TERA_PRO2_RACK +# define machine_arch_type MACH_TYPE_IAM28 # endif -# define machine_is_tera_pro2_rack() (machine_arch_type == MACH_TYPE_TERA_PRO2_RACK) +# define machine_is_iam28() (machine_arch_type == MACH_TYPE_IAM28) #else -# define machine_is_tera_pro2_rack() (0) +# define machine_is_iam28() (0) #endif
-#ifdef CONFIG_MACH_RUBYS +#ifdef CONFIG_MACH_PICASSO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_RUBYS +# define machine_arch_type MACH_TYPE_PICASSO # endif -# define machine_is_rubys() (machine_arch_type == MACH_TYPE_RUBYS) +# define machine_is_picasso() (machine_arch_type == MACH_TYPE_PICASSO) #else -# define machine_is_rubys() (0) +# define machine_is_picasso() (0) #endif
-#ifdef CONFIG_MACH_AQUARIUS +#ifdef CONFIG_MACH_MR301A # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_AQUARIUS +# define machine_arch_type MACH_TYPE_MR301A # endif -# define machine_is_aquarius() (machine_arch_type == MACH_TYPE_AQUARIUS) +# define machine_is_mr301a() (machine_arch_type == MACH_TYPE_MR301A) #else -# define machine_is_aquarius() (0) +# define machine_is_mr301a() (0) #endif
-#ifdef CONFIG_MACH_MX53_ARD +#ifdef CONFIG_MACH_NOTLE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MX53_ARD +# define machine_arch_type MACH_TYPE_NOTLE # endif -# define machine_is_mx53_ard() (machine_arch_type == MACH_TYPE_MX53_ARD) +# define machine_is_notle() (machine_arch_type == MACH_TYPE_NOTLE) #else -# define machine_is_mx53_ard() (0) +# define machine_is_notle() (0) #endif
-#ifdef CONFIG_MACH_MX53_SMD +#ifdef CONFIG_MACH_EELX2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MX53_SMD +# define machine_arch_type MACH_TYPE_EELX2 # endif -# define machine_is_mx53_smd() (machine_arch_type == MACH_TYPE_MX53_SMD) +# define machine_is_eelx2() (machine_arch_type == MACH_TYPE_EELX2) #else -# define machine_is_mx53_smd() (0) +# define machine_is_eelx2() (0) #endif
-#ifdef CONFIG_MACH_LSWXL +#ifdef CONFIG_MACH_MOON # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_LSWXL +# define machine_arch_type MACH_TYPE_MOON # endif -# define machine_is_lswxl() (machine_arch_type == MACH_TYPE_LSWXL) +# define machine_is_moon() (machine_arch_type == MACH_TYPE_MOON) #else -# define machine_is_lswxl() (0) +# define machine_is_moon() (0) #endif
-#ifdef CONFIG_MACH_DOVE_AVNG_V3 +#ifdef CONFIG_MACH_RUBY # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DOVE_AVNG_V3 +# define machine_arch_type MACH_TYPE_RUBY # endif -# define machine_is_dove_avng_v3() (machine_arch_type == MACH_TYPE_DOVE_AVNG_V3) +# define machine_is_ruby() (machine_arch_type == MACH_TYPE_RUBY) #else -# define machine_is_dove_avng_v3() (0) +# define machine_is_ruby() (0) #endif
-#ifdef CONFIG_MACH_SDI_ESS_9263 +#ifdef CONFIG_MACH_GOLDENGATE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SDI_ESS_9263 +# define machine_arch_type MACH_TYPE_GOLDENGATE # endif -# define machine_is_sdi_ess_9263() (machine_arch_type == MACH_TYPE_SDI_ESS_9263) +# define machine_is_goldengate() (machine_arch_type == MACH_TYPE_GOLDENGATE) #else -# define machine_is_sdi_ess_9263() (0) +# define machine_is_goldengate() (0) #endif
-#ifdef CONFIG_MACH_JOCPU550 +#ifdef CONFIG_MACH_CTBU_GEN2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_JOCPU550 +# define machine_arch_type MACH_TYPE_CTBU_GEN2 # endif -# define machine_is_jocpu550() (machine_arch_type == MACH_TYPE_JOCPU550) +# define machine_is_ctbu_gen2() (machine_arch_type == MACH_TYPE_CTBU_GEN2) #else -# define machine_is_jocpu550() (0) +# define machine_is_ctbu_gen2() (0) #endif
-#ifdef CONFIG_MACH_MSM8X60_RUMI3 +#ifdef CONFIG_MACH_KMP_AM17_01 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MSM8X60_RUMI3 +# define machine_arch_type MACH_TYPE_KMP_AM17_01 # endif -# define machine_is_msm8x60_rumi3() (machine_arch_type == MACH_TYPE_MSM8X60_RUMI3) +# define machine_is_kmp_am17_01() (machine_arch_type == MACH_TYPE_KMP_AM17_01) #else -# define machine_is_msm8x60_rumi3() (0) +# define machine_is_kmp_am17_01() (0) #endif
-#ifdef CONFIG_MACH_MSM8X60_FFA +#ifdef CONFIG_MACH_WTPLUG # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MSM8X60_FFA +# define machine_arch_type MACH_TYPE_WTPLUG # endif -# define machine_is_msm8x60_ffa() (machine_arch_type == MACH_TYPE_MSM8X60_FFA) +# define machine_is_wtplug() (machine_arch_type == MACH_TYPE_WTPLUG) #else -# define machine_is_msm8x60_ffa() (0) +# define machine_is_wtplug() (0) #endif
-#ifdef CONFIG_MACH_YANOMAMI +#ifdef CONFIG_MACH_MX27SU2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_YANOMAMI +# define machine_arch_type MACH_TYPE_MX27SU2 # endif -# define machine_is_yanomami() (machine_arch_type == MACH_TYPE_YANOMAMI) +# define machine_is_mx27su2() (machine_arch_type == MACH_TYPE_MX27SU2) #else -# define machine_is_yanomami() (0) +# define machine_is_mx27su2() (0) #endif
-#ifdef CONFIG_MACH_GTA04 +#ifdef CONFIG_MACH_NB31 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GTA04 +# define machine_arch_type MACH_TYPE_NB31 # endif -# define machine_is_gta04() (machine_arch_type == MACH_TYPE_GTA04) +# define machine_is_nb31() (machine_arch_type == MACH_TYPE_NB31) #else -# define machine_is_gta04() (0) +# define machine_is_nb31() (0) #endif
-#ifdef CONFIG_MACH_CM_A510 +#ifdef CONFIG_MACH_HJSDU # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CM_A510 +# define machine_arch_type MACH_TYPE_HJSDU # endif -# define machine_is_cm_a510() (machine_arch_type == MACH_TYPE_CM_A510) +# define machine_is_hjsdu() (machine_arch_type == MACH_TYPE_HJSDU) #else -# define machine_is_cm_a510() (0) +# define machine_is_hjsdu() (0) #endif
-#ifdef CONFIG_MACH_OMAP3_RFS200 +#ifdef CONFIG_MACH_TD3_REV1 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OMAP3_RFS200 +# define machine_arch_type MACH_TYPE_TD3_REV1 # endif -# define machine_is_omap3_rfs200() (machine_arch_type == MACH_TYPE_OMAP3_RFS200) +# define machine_is_td3_rev1() (machine_arch_type == MACH_TYPE_TD3_REV1) #else -# define machine_is_omap3_rfs200() (0) +# define machine_is_td3_rev1() (0) #endif
-#ifdef CONFIG_MACH_KX33XX +#ifdef CONFIG_MACH_EAG_CI4000 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_KX33XX +# define machine_arch_type MACH_TYPE_EAG_CI4000 # endif -# define machine_is_kx33xx() (machine_arch_type == MACH_TYPE_KX33XX) +# define machine_is_eag_ci4000() (machine_arch_type == MACH_TYPE_EAG_CI4000) #else -# define machine_is_kx33xx() (0) +# define machine_is_eag_ci4000() (0) #endif
-#ifdef CONFIG_MACH_PTX7510 +#ifdef CONFIG_MACH_NET5BIG_NAND_V2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PTX7510 +# define machine_arch_type MACH_TYPE_NET5BIG_NAND_V2 # endif -# define machine_is_ptx7510() (machine_arch_type == MACH_TYPE_PTX7510) +# define machine_is_net5big_nand_v2() (machine_arch_type == MACH_TYPE_NET5BIG_NAND_V2) #else -# define machine_is_ptx7510() (0) +# define machine_is_net5big_nand_v2() (0) #endif
-#ifdef CONFIG_MACH_TOP9000 +#ifdef CONFIG_MACH_CPX2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TOP9000 +# define machine_arch_type MACH_TYPE_CPX2 # endif -# define machine_is_top9000() (machine_arch_type == MACH_TYPE_TOP9000) +# define machine_is_cpx2() (machine_arch_type == MACH_TYPE_CPX2) #else -# define machine_is_top9000() (0) +# define machine_is_cpx2() (0) #endif
-#ifdef CONFIG_MACH_TEENOTE +#ifdef CONFIG_MACH_NET2BIG_NAND_V2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TEENOTE +# define machine_arch_type MACH_TYPE_NET2BIG_NAND_V2 # endif -# define machine_is_teenote() (machine_arch_type == MACH_TYPE_TEENOTE) +# define machine_is_net2big_nand_v2() (machine_arch_type == MACH_TYPE_NET2BIG_NAND_V2) #else -# define machine_is_teenote() (0) +# define machine_is_net2big_nand_v2() (0) #endif
-#ifdef CONFIG_MACH_TS3 +#ifdef CONFIG_MACH_ECUV5 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TS3 +# define machine_arch_type MACH_TYPE_ECUV5 # endif -# define machine_is_ts3() (machine_arch_type == MACH_TYPE_TS3) +# define machine_is_ecuv5() (machine_arch_type == MACH_TYPE_ECUV5) #else -# define machine_is_ts3() (0) +# define machine_is_ecuv5() (0) #endif
-#ifdef CONFIG_MACH_A0 +#ifdef CONFIG_MACH_HSGX6D # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_A0 +# define machine_arch_type MACH_TYPE_HSGX6D # endif -# define machine_is_a0() (machine_arch_type == MACH_TYPE_A0) +# define machine_is_hsgx6d() (machine_arch_type == MACH_TYPE_HSGX6D) #else -# define machine_is_a0() (0) +# define machine_is_hsgx6d() (0) #endif
-#ifdef CONFIG_MACH_FSM9XXX_SURF +#ifdef CONFIG_MACH_DAWAD7 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_FSM9XXX_SURF +# define machine_arch_type MACH_TYPE_DAWAD7 # endif -# define machine_is_fsm9xxx_surf() (machine_arch_type == MACH_TYPE_FSM9XXX_SURF) +# define machine_is_dawad7() (machine_arch_type == MACH_TYPE_DAWAD7) #else -# define machine_is_fsm9xxx_surf() (0) +# define machine_is_dawad7() (0) #endif
-#ifdef CONFIG_MACH_FSM9XXX_FFA +#ifdef CONFIG_MACH_SAM9REPEATER # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_FSM9XXX_FFA +# define machine_arch_type MACH_TYPE_SAM9REPEATER # endif -# define machine_is_fsm9xxx_ffa() (machine_arch_type == MACH_TYPE_FSM9XXX_FFA) +# define machine_is_sam9repeater() (machine_arch_type == MACH_TYPE_SAM9REPEATER) #else -# define machine_is_fsm9xxx_ffa() (0) +# define machine_is_sam9repeater() (0) #endif
-#ifdef CONFIG_MACH_FRRHWCDMA60W +#ifdef CONFIG_MACH_GT_I5700 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_FRRHWCDMA60W +# define machine_arch_type MACH_TYPE_GT_I5700 # endif -# define machine_is_frrhwcdma60w() (machine_arch_type == MACH_TYPE_FRRHWCDMA60W) +# define machine_is_gt_i5700() (machine_arch_type == MACH_TYPE_GT_I5700) #else -# define machine_is_frrhwcdma60w() (0) +# define machine_is_gt_i5700() (0) #endif
-#ifdef CONFIG_MACH_REMUS +#ifdef CONFIG_MACH_CTERA_PLUG_C2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_REMUS +# define machine_arch_type MACH_TYPE_CTERA_PLUG_C2 # endif -# define machine_is_remus() (machine_arch_type == MACH_TYPE_REMUS) +# define machine_is_ctera_plug_c2() (machine_arch_type == MACH_TYPE_CTERA_PLUG_C2) #else -# define machine_is_remus() (0) +# define machine_is_ctera_plug_c2() (0) #endif
-#ifdef CONFIG_MACH_AT91CAP7XDK +#ifdef CONFIG_MACH_MARVELCT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_AT91CAP7XDK +# define machine_arch_type MACH_TYPE_MARVELCT # endif -# define machine_is_at91cap7xdk() (machine_arch_type == MACH_TYPE_AT91CAP7XDK) +# define machine_is_marvelct() (machine_arch_type == MACH_TYPE_MARVELCT) #else -# define machine_is_at91cap7xdk() (0) +# define machine_is_marvelct() (0) #endif
-#ifdef CONFIG_MACH_AT91CAP7STK +#ifdef CONFIG_MACH_AG11005 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_AT91CAP7STK +# define machine_arch_type MACH_TYPE_AG11005 # endif -# define machine_is_at91cap7stk() (machine_arch_type == MACH_TYPE_AT91CAP7STK) +# define machine_is_ag11005() (machine_arch_type == MACH_TYPE_AG11005) #else -# define machine_is_at91cap7stk() (0) +# define machine_is_ag11005() (0) #endif
-#ifdef CONFIG_MACH_KT_SBC_SAM9_1 +#ifdef CONFIG_MACH_VANGOGH # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_KT_SBC_SAM9_1 +# define machine_arch_type MACH_TYPE_VANGOGH # endif -# define machine_is_kt_sbc_sam9_1() (machine_arch_type == MACH_TYPE_KT_SBC_SAM9_1) +# define machine_is_vangogh() (machine_arch_type == MACH_TYPE_VANGOGH) #else -# define machine_is_kt_sbc_sam9_1() (0) +# define machine_is_vangogh() (0) #endif
-#ifdef CONFIG_MACH_ARMADA_XP_DB +#ifdef CONFIG_MACH_MATRIX505 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ARMADA_XP_DB +# define machine_arch_type MACH_TYPE_MATRIX505 # endif -# define machine_is_armada_xp_db() (machine_arch_type == MACH_TYPE_ARMADA_XP_DB) +# define machine_is_matrix505() (machine_arch_type == MACH_TYPE_MATRIX505) #else -# define machine_is_armada_xp_db() (0) +# define machine_is_matrix505() (0) #endif
-#ifdef CONFIG_MACH_SPDM +#ifdef CONFIG_MACH_OCE_NIGMA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SPDM +# define machine_arch_type MACH_TYPE_OCE_NIGMA # endif -# define machine_is_spdm() (machine_arch_type == MACH_TYPE_SPDM) +# define machine_is_oce_nigma() (machine_arch_type == MACH_TYPE_OCE_NIGMA) #else -# define machine_is_spdm() (0) +# define machine_is_oce_nigma() (0) #endif
-#ifdef CONFIG_MACH_GTIB +#ifdef CONFIG_MACH_T55 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GTIB +# define machine_arch_type MACH_TYPE_T55 # endif -# define machine_is_gtib() (machine_arch_type == MACH_TYPE_GTIB) +# define machine_is_t55() (machine_arch_type == MACH_TYPE_T55) #else -# define machine_is_gtib() (0) +# define machine_is_t55() (0) #endif
-#ifdef CONFIG_MACH_DGM3240 +#ifdef CONFIG_MACH_BIO3K # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DGM3240 +# define machine_arch_type MACH_TYPE_BIO3K # endif -# define machine_is_dgm3240() (machine_arch_type == MACH_TYPE_DGM3240) +# define machine_is_bio3k() (machine_arch_type == MACH_TYPE_BIO3K) #else -# define machine_is_dgm3240() (0) +# define machine_is_bio3k() (0) #endif
-#ifdef CONFIG_MACH_HTCMEGA +#ifdef CONFIG_MACH_EXPRESSCT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HTCMEGA +# define machine_arch_type MACH_TYPE_EXPRESSCT # endif -# define machine_is_htcmega() (machine_arch_type == MACH_TYPE_HTCMEGA) +# define machine_is_expressct() (machine_arch_type == MACH_TYPE_EXPRESSCT) #else -# define machine_is_htcmega() (0) +# define machine_is_expressct() (0) #endif
-#ifdef CONFIG_MACH_TRICORDER +#ifdef CONFIG_MACH_CARDHU # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TRICORDER +# define machine_arch_type MACH_TYPE_CARDHU # endif -# define machine_is_tricorder() (machine_arch_type == MACH_TYPE_TRICORDER) +# define machine_is_cardhu() (machine_arch_type == MACH_TYPE_CARDHU) #else -# define machine_is_tricorder() (0) +# define machine_is_cardhu() (0) #endif
-#ifdef CONFIG_MACH_TX28 +#ifdef CONFIG_MACH_ARUBA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TX28 +# define machine_arch_type MACH_TYPE_ARUBA # endif -# define machine_is_tx28() (machine_arch_type == MACH_TYPE_TX28) +# define machine_is_aruba() (machine_arch_type == MACH_TYPE_ARUBA) #else -# define machine_is_tx28() (0) +# define machine_is_aruba() (0) #endif
-#ifdef CONFIG_MACH_BSTBRD +#ifdef CONFIG_MACH_BONAIRE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BSTBRD +# define machine_arch_type MACH_TYPE_BONAIRE # endif -# define machine_is_bstbrd() (machine_arch_type == MACH_TYPE_BSTBRD) +# define machine_is_bonaire() (machine_arch_type == MACH_TYPE_BONAIRE) #else -# define machine_is_bstbrd() (0) +# define machine_is_bonaire() (0) #endif
-#ifdef CONFIG_MACH_PWB3090 +#ifdef CONFIG_MACH_NUC700EVB # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PWB3090 +# define machine_arch_type MACH_TYPE_NUC700EVB # endif -# define machine_is_pwb3090() (machine_arch_type == MACH_TYPE_PWB3090) +# define machine_is_nuc700evb() (machine_arch_type == MACH_TYPE_NUC700EVB) #else -# define machine_is_pwb3090() (0) +# define machine_is_nuc700evb() (0) #endif
-#ifdef CONFIG_MACH_IDEA6410 +#ifdef CONFIG_MACH_NUC710EVB # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_IDEA6410 +# define machine_arch_type MACH_TYPE_NUC710EVB # endif -# define machine_is_idea6410() (machine_arch_type == MACH_TYPE_IDEA6410) +# define machine_is_nuc710evb() (machine_arch_type == MACH_TYPE_NUC710EVB) #else -# define machine_is_idea6410() (0) +# define machine_is_nuc710evb() (0) #endif
-#ifdef CONFIG_MACH_QBC9263 +#ifdef CONFIG_MACH_NUC740EVB # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_QBC9263 +# define machine_arch_type MACH_TYPE_NUC740EVB # endif -# define machine_is_qbc9263() (machine_arch_type == MACH_TYPE_QBC9263) +# define machine_is_nuc740evb() (machine_arch_type == MACH_TYPE_NUC740EVB) #else -# define machine_is_qbc9263() (0) +# define machine_is_nuc740evb() (0) #endif
-#ifdef CONFIG_MACH_BORABORA +#ifdef CONFIG_MACH_NUC745EVB # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BORABORA +# define machine_arch_type MACH_TYPE_NUC745EVB # endif -# define machine_is_borabora() (machine_arch_type == MACH_TYPE_BORABORA) +# define machine_is_nuc745evb() (machine_arch_type == MACH_TYPE_NUC745EVB) #else -# define machine_is_borabora() (0) +# define machine_is_nuc745evb() (0) #endif
-#ifdef CONFIG_MACH_VALDEZ +#ifdef CONFIG_MACH_TRANSCEDE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VALDEZ +# define machine_arch_type MACH_TYPE_TRANSCEDE # endif -# define machine_is_valdez() (machine_arch_type == MACH_TYPE_VALDEZ) +# define machine_is_transcede() (machine_arch_type == MACH_TYPE_TRANSCEDE) #else -# define machine_is_valdez() (0) +# define machine_is_transcede() (0) #endif
-#ifdef CONFIG_MACH_LS9G20 +#ifdef CONFIG_MACH_MORA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_LS9G20 +# define machine_arch_type MACH_TYPE_MORA # endif -# define machine_is_ls9g20() (machine_arch_type == MACH_TYPE_LS9G20) +# define machine_is_mora() (machine_arch_type == MACH_TYPE_MORA) #else -# define machine_is_ls9g20() (0) +# define machine_is_mora() (0) #endif
-#ifdef CONFIG_MACH_MIOS_V1 +#ifdef CONFIG_MACH_NDA_EVM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MIOS_V1 +# define machine_arch_type MACH_TYPE_NDA_EVM # endif -# define machine_is_mios_v1() (machine_arch_type == MACH_TYPE_MIOS_V1) +# define machine_is_nda_evm() (machine_arch_type == MACH_TYPE_NDA_EVM) #else -# define machine_is_mios_v1() (0) +# define machine_is_nda_evm() (0) #endif
-#ifdef CONFIG_MACH_S5PC110_CRESPO +#ifdef CONFIG_MACH_TIMU # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_S5PC110_CRESPO +# define machine_arch_type MACH_TYPE_TIMU # endif -# define machine_is_s5pc110_crespo() (machine_arch_type == MACH_TYPE_S5PC110_CRESPO) +# define machine_is_timu() (machine_arch_type == MACH_TYPE_TIMU) #else -# define machine_is_s5pc110_crespo() (0) +# define machine_is_timu() (0) #endif
-#ifdef CONFIG_MACH_CONTROLTEK9G20 +#ifdef CONFIG_MACH_EXPRESSH # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CONTROLTEK9G20 +# define machine_arch_type MACH_TYPE_EXPRESSH # endif -# define machine_is_controltek9g20() (machine_arch_type == MACH_TYPE_CONTROLTEK9G20) +# define machine_is_expressh() (machine_arch_type == MACH_TYPE_EXPRESSH) #else -# define machine_is_controltek9g20() (0) +# define machine_is_expressh() (0) #endif
-#ifdef CONFIG_MACH_TIN307 +#ifdef CONFIG_MACH_VERIDIS_A300 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TIN307 +# define machine_arch_type MACH_TYPE_VERIDIS_A300 # endif -# define machine_is_tin307() (machine_arch_type == MACH_TYPE_TIN307) +# define machine_is_veridis_a300() (machine_arch_type == MACH_TYPE_VERIDIS_A300) #else -# define machine_is_tin307() (0) +# define machine_is_veridis_a300() (0) #endif
-#ifdef CONFIG_MACH_TIN510 +#ifdef CONFIG_MACH_DM368_LEOPARD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TIN510 +# define machine_arch_type MACH_TYPE_DM368_LEOPARD # endif -# define machine_is_tin510() (machine_arch_type == MACH_TYPE_TIN510) +# define machine_is_dm368_leopard() (machine_arch_type == MACH_TYPE_DM368_LEOPARD) #else -# define machine_is_tin510() (0) +# define machine_is_dm368_leopard() (0) #endif
-#ifdef CONFIG_MACH_BLUECHEESE +#ifdef CONFIG_MACH_OMAP_MCOP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BLUECHEESE +# define machine_arch_type MACH_TYPE_OMAP_MCOP # endif -# define machine_is_bluecheese() (machine_arch_type == MACH_TYPE_BLUECHEESE) +# define machine_is_omap_mcop() (machine_arch_type == MACH_TYPE_OMAP_MCOP) #else -# define machine_is_bluecheese() (0) +# define machine_is_omap_mcop() (0) #endif
-#ifdef CONFIG_MACH_TEM3X30 +#ifdef CONFIG_MACH_TRITIP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TEM3X30 +# define machine_arch_type MACH_TYPE_TRITIP # endif -# define machine_is_tem3x30() (machine_arch_type == MACH_TYPE_TEM3X30) +# define machine_is_tritip() (machine_arch_type == MACH_TYPE_TRITIP) #else -# define machine_is_tem3x30() (0) +# define machine_is_tritip() (0) #endif
-#ifdef CONFIG_MACH_HARVEST_DESOTO +#ifdef CONFIG_MACH_SM1K # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HARVEST_DESOTO +# define machine_arch_type MACH_TYPE_SM1K # endif -# define machine_is_harvest_desoto() (machine_arch_type == MACH_TYPE_HARVEST_DESOTO) +# define machine_is_sm1k() (machine_arch_type == MACH_TYPE_SM1K) #else -# define machine_is_harvest_desoto() (0) +# define machine_is_sm1k() (0) #endif
-#ifdef CONFIG_MACH_MSM8X60_QRDC +#ifdef CONFIG_MACH_MONCH # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MSM8X60_QRDC +# define machine_arch_type MACH_TYPE_MONCH # endif -# define machine_is_msm8x60_qrdc() (machine_arch_type == MACH_TYPE_MSM8X60_QRDC) +# define machine_is_monch() (machine_arch_type == MACH_TYPE_MONCH) #else -# define machine_is_msm8x60_qrdc() (0) +# define machine_is_monch() (0) #endif
-#ifdef CONFIG_MACH_SPEAR900 +#ifdef CONFIG_MACH_CURACAO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SPEAR900 +# define machine_arch_type MACH_TYPE_CURACAO # endif -# define machine_is_spear900() (machine_arch_type == MACH_TYPE_SPEAR900) +# define machine_is_curacao() (machine_arch_type == MACH_TYPE_CURACAO) #else -# define machine_is_spear900() (0) +# define machine_is_curacao() (0) #endif
-#ifdef CONFIG_MACH_PCONTROL_G20 +#ifdef CONFIG_MACH_ORIGEN # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PCONTROL_G20 +# define machine_arch_type MACH_TYPE_ORIGEN # endif -# define machine_is_pcontrol_g20() (machine_arch_type == MACH_TYPE_PCONTROL_G20) +# define machine_is_origen() (machine_arch_type == MACH_TYPE_ORIGEN) #else -# define machine_is_pcontrol_g20() (0) +# define machine_is_origen() (0) #endif
-#ifdef CONFIG_MACH_RDSTOR +#ifdef CONFIG_MACH_EPC10 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_RDSTOR +# define machine_arch_type MACH_TYPE_EPC10 # endif -# define machine_is_rdstor() (machine_arch_type == MACH_TYPE_RDSTOR) +# define machine_is_epc10() (machine_arch_type == MACH_TYPE_EPC10) #else -# define machine_is_rdstor() (0) +# define machine_is_epc10() (0) #endif
-#ifdef CONFIG_MACH_USDLOADER +#ifdef CONFIG_MACH_SGH_I740 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_USDLOADER +# define machine_arch_type MACH_TYPE_SGH_I740 # endif -# define machine_is_usdloader() (machine_arch_type == MACH_TYPE_USDLOADER) +# define machine_is_sgh_i740() (machine_arch_type == MACH_TYPE_SGH_I740) #else -# define machine_is_usdloader() (0) +# define machine_is_sgh_i740() (0) #endif
-#ifdef CONFIG_MACH_TSOPLOADER +#ifdef CONFIG_MACH_TUNA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TSOPLOADER +# define machine_arch_type MACH_TYPE_TUNA # endif -# define machine_is_tsoploader() (machine_arch_type == MACH_TYPE_TSOPLOADER) +# define machine_is_tuna() (machine_arch_type == MACH_TYPE_TUNA) #else -# define machine_is_tsoploader() (0) +# define machine_is_tuna() (0) #endif
-#ifdef CONFIG_MACH_KRONOS +#ifdef CONFIG_MACH_MX51_TULIP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_KRONOS +# define machine_arch_type MACH_TYPE_MX51_TULIP # endif -# define machine_is_kronos() (machine_arch_type == MACH_TYPE_KRONOS) +# define machine_is_mx51_tulip() (machine_arch_type == MACH_TYPE_MX51_TULIP) #else -# define machine_is_kronos() (0) +# define machine_is_mx51_tulip() (0) #endif
-#ifdef CONFIG_MACH_FFCORE +#ifdef CONFIG_MACH_MX51_ASTER7 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_FFCORE +# define machine_arch_type MACH_TYPE_MX51_ASTER7 # endif -# define machine_is_ffcore() (machine_arch_type == MACH_TYPE_FFCORE) +# define machine_is_mx51_aster7() (machine_arch_type == MACH_TYPE_MX51_ASTER7) #else -# define machine_is_ffcore() (0) +# define machine_is_mx51_aster7() (0) #endif
-#ifdef CONFIG_MACH_MONE +#ifdef CONFIG_MACH_ACRO37XBRD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MONE +# define machine_arch_type MACH_TYPE_ACRO37XBRD # endif -# define machine_is_mone() (machine_arch_type == MACH_TYPE_MONE) +# define machine_is_acro37xbrd() (machine_arch_type == MACH_TYPE_ACRO37XBRD) #else -# define machine_is_mone() (0) +# define machine_is_acro37xbrd() (0) #endif
-#ifdef CONFIG_MACH_UNIT2S +#ifdef CONFIG_MACH_ELKE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_UNIT2S +# define machine_arch_type MACH_TYPE_ELKE # endif -# define machine_is_unit2s() (machine_arch_type == MACH_TYPE_UNIT2S) +# define machine_is_elke() (machine_arch_type == MACH_TYPE_ELKE) #else -# define machine_is_unit2s() (0) +# define machine_is_elke() (0) #endif
-#ifdef CONFIG_MACH_ACER_A5 +#ifdef CONFIG_MACH_SBC6000X # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ACER_A5 +# define machine_arch_type MACH_TYPE_SBC6000X # endif -# define machine_is_acer_a5() (machine_arch_type == MACH_TYPE_ACER_A5) +# define machine_is_sbc6000x() (machine_arch_type == MACH_TYPE_SBC6000X) #else -# define machine_is_acer_a5() (0) +# define machine_is_sbc6000x() (0) #endif
-#ifdef CONFIG_MACH_ETHERPRO_ISP +#ifdef CONFIG_MACH_R1801E # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ETHERPRO_ISP +# define machine_arch_type MACH_TYPE_R1801E # endif -# define machine_is_etherpro_isp() (machine_arch_type == MACH_TYPE_ETHERPRO_ISP) +# define machine_is_r1801e() (machine_arch_type == MACH_TYPE_R1801E) #else -# define machine_is_etherpro_isp() (0) +# define machine_is_r1801e() (0) #endif
-#ifdef CONFIG_MACH_STRETCHS7000 +#ifdef CONFIG_MACH_H1600 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_STRETCHS7000 +# define machine_arch_type MACH_TYPE_H1600 # endif -# define machine_is_stretchs7000() (machine_arch_type == MACH_TYPE_STRETCHS7000) +# define machine_is_h1600() (machine_arch_type == MACH_TYPE_H1600) #else -# define machine_is_stretchs7000() (0) +# define machine_is_h1600() (0) #endif
-#ifdef CONFIG_MACH_P87_SMARTSIM +#ifdef CONFIG_MACH_MINI210 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_P87_SMARTSIM +# define machine_arch_type MACH_TYPE_MINI210 # endif -# define machine_is_p87_smartsim() (machine_arch_type == MACH_TYPE_P87_SMARTSIM) +# define machine_is_mini210() (machine_arch_type == MACH_TYPE_MINI210) #else -# define machine_is_p87_smartsim() (0) +# define machine_is_mini210() (0) #endif
-#ifdef CONFIG_MACH_TULIP +#ifdef CONFIG_MACH_MINI8168 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TULIP +# define machine_arch_type MACH_TYPE_MINI8168 # endif -# define machine_is_tulip() (machine_arch_type == MACH_TYPE_TULIP) +# define machine_is_mini8168() (machine_arch_type == MACH_TYPE_MINI8168) #else -# define machine_is_tulip() (0) +# define machine_is_mini8168() (0) #endif
-#ifdef CONFIG_MACH_SUNFLOWER +#ifdef CONFIG_MACH_PC7308 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SUNFLOWER +# define machine_arch_type MACH_TYPE_PC7308 # endif -# define machine_is_sunflower() (machine_arch_type == MACH_TYPE_SUNFLOWER) +# define machine_is_pc7308() (machine_arch_type == MACH_TYPE_PC7308) #else -# define machine_is_sunflower() (0) +# define machine_is_pc7308() (0) #endif
-#ifdef CONFIG_MACH_RIB +#ifdef CONFIG_MACH_KMM2M01 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_RIB +# define machine_arch_type MACH_TYPE_KMM2M01 # endif -# define machine_is_rib() (machine_arch_type == MACH_TYPE_RIB) +# define machine_is_kmm2m01() (machine_arch_type == MACH_TYPE_KMM2M01) #else -# define machine_is_rib() (0) +# define machine_is_kmm2m01() (0) #endif
-#ifdef CONFIG_MACH_CLOD +#ifdef CONFIG_MACH_MX51EREBUS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CLOD +# define machine_arch_type MACH_TYPE_MX51EREBUS # endif -# define machine_is_clod() (machine_arch_type == MACH_TYPE_CLOD) +# define machine_is_mx51erebus() (machine_arch_type == MACH_TYPE_MX51EREBUS) #else -# define machine_is_clod() (0) +# define machine_is_mx51erebus() (0) #endif
-#ifdef CONFIG_MACH_RUMP +#ifdef CONFIG_MACH_WM8650REFBOARD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_RUMP +# define machine_arch_type MACH_TYPE_WM8650REFBOARD # endif -# define machine_is_rump() (machine_arch_type == MACH_TYPE_RUMP) +# define machine_is_wm8650refboard() (machine_arch_type == MACH_TYPE_WM8650REFBOARD) #else -# define machine_is_rump() (0) +# define machine_is_wm8650refboard() (0) #endif
-#ifdef CONFIG_MACH_TENDERLOIN +#ifdef CONFIG_MACH_TUXRAIL # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TENDERLOIN +# define machine_arch_type MACH_TYPE_TUXRAIL # endif -# define machine_is_tenderloin() (machine_arch_type == MACH_TYPE_TENDERLOIN) +# define machine_is_tuxrail() (machine_arch_type == MACH_TYPE_TUXRAIL) #else -# define machine_is_tenderloin() (0) +# define machine_is_tuxrail() (0) #endif
-#ifdef CONFIG_MACH_SHORTLOIN +#ifdef CONFIG_MACH_ARTHUR # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SHORTLOIN +# define machine_arch_type MACH_TYPE_ARTHUR # endif -# define machine_is_shortloin() (machine_arch_type == MACH_TYPE_SHORTLOIN) +# define machine_is_arthur() (machine_arch_type == MACH_TYPE_ARTHUR) #else -# define machine_is_shortloin() (0) +# define machine_is_arthur() (0) #endif
-#ifdef CONFIG_MACH_ANTARES +#ifdef CONFIG_MACH_DOORBOY # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ANTARES +# define machine_arch_type MACH_TYPE_DOORBOY # endif -# define machine_is_antares() (machine_arch_type == MACH_TYPE_ANTARES) +# define machine_is_doorboy() (machine_arch_type == MACH_TYPE_DOORBOY) #else -# define machine_is_antares() (0) +# define machine_is_doorboy() (0) #endif
-#ifdef CONFIG_MACH_WB40N +#ifdef CONFIG_MACH_XARINA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_WB40N +# define machine_arch_type MACH_TYPE_XARINA # endif -# define machine_is_wb40n() (machine_arch_type == MACH_TYPE_WB40N) +# define machine_is_xarina() (machine_arch_type == MACH_TYPE_XARINA) #else -# define machine_is_wb40n() (0) +# define machine_is_xarina() (0) #endif
-#ifdef CONFIG_MACH_HERRING +#ifdef CONFIG_MACH_ROVERX7 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HERRING +# define machine_arch_type MACH_TYPE_ROVERX7 # endif -# define machine_is_herring() (machine_arch_type == MACH_TYPE_HERRING) +# define machine_is_roverx7() (machine_arch_type == MACH_TYPE_ROVERX7) #else -# define machine_is_herring() (0) +# define machine_is_roverx7() (0) #endif
-#ifdef CONFIG_MACH_NAXY400 +#ifdef CONFIG_MACH_SDVR # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NAXY400 +# define machine_arch_type MACH_TYPE_SDVR # endif -# define machine_is_naxy400() (machine_arch_type == MACH_TYPE_NAXY400) +# define machine_is_sdvr() (machine_arch_type == MACH_TYPE_SDVR) #else -# define machine_is_naxy400() (0) +# define machine_is_sdvr() (0) #endif
-#ifdef CONFIG_MACH_NAXY1200 +#ifdef CONFIG_MACH_ACER_MAYA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NAXY1200 +# define machine_arch_type MACH_TYPE_ACER_MAYA # endif -# define machine_is_naxy1200() (machine_arch_type == MACH_TYPE_NAXY1200) +# define machine_is_acer_maya() (machine_arch_type == MACH_TYPE_ACER_MAYA) #else -# define machine_is_naxy1200() (0) +# define machine_is_acer_maya() (0) #endif
-#ifdef CONFIG_MACH_VPR200 +#ifdef CONFIG_MACH_PICO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VPR200 +# define machine_arch_type MACH_TYPE_PICO # endif -# define machine_is_vpr200() (machine_arch_type == MACH_TYPE_VPR200) +# define machine_is_pico() (machine_arch_type == MACH_TYPE_PICO) #else -# define machine_is_vpr200() (0) +# define machine_is_pico() (0) #endif
-#ifdef CONFIG_MACH_BUG20 +#ifdef CONFIG_MACH_CWMX233 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BUG20 +# define machine_arch_type MACH_TYPE_CWMX233 # endif -# define machine_is_bug20() (machine_arch_type == MACH_TYPE_BUG20) +# define machine_is_cwmx233() (machine_arch_type == MACH_TYPE_CWMX233) #else -# define machine_is_bug20() (0) +# define machine_is_cwmx233() (0) #endif
-#ifdef CONFIG_MACH_GOFLEXNET +#ifdef CONFIG_MACH_CWAM1808 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GOFLEXNET +# define machine_arch_type MACH_TYPE_CWAM1808 # endif -# define machine_is_goflexnet() (machine_arch_type == MACH_TYPE_GOFLEXNET) +# define machine_is_cwam1808() (machine_arch_type == MACH_TYPE_CWAM1808) #else -# define machine_is_goflexnet() (0) +# define machine_is_cwam1808() (0) #endif
-#ifdef CONFIG_MACH_TORBRECK +#ifdef CONFIG_MACH_CWDM365 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TORBRECK +# define machine_arch_type MACH_TYPE_CWDM365 # endif -# define machine_is_torbreck() (machine_arch_type == MACH_TYPE_TORBRECK) +# define machine_is_cwdm365() (machine_arch_type == MACH_TYPE_CWDM365) #else -# define machine_is_torbreck() (0) +# define machine_is_cwdm365() (0) #endif
-#ifdef CONFIG_MACH_SAARB_MG1 +#ifdef CONFIG_MACH_MX51_MORAY # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SAARB_MG1 +# define machine_arch_type MACH_TYPE_MX51_MORAY # endif -# define machine_is_saarb_mg1() (machine_arch_type == MACH_TYPE_SAARB_MG1) +# define machine_is_mx51_moray() (machine_arch_type == MACH_TYPE_MX51_MORAY) #else -# define machine_is_saarb_mg1() (0) +# define machine_is_mx51_moray() (0) #endif
-#ifdef CONFIG_MACH_CALLISTO +#ifdef CONFIG_MACH_THALES_CBC # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CALLISTO +# define machine_arch_type MACH_TYPE_THALES_CBC # endif -# define machine_is_callisto() (machine_arch_type == MACH_TYPE_CALLISTO) +# define machine_is_thales_cbc() (machine_arch_type == MACH_TYPE_THALES_CBC) #else -# define machine_is_callisto() (0) +# define machine_is_thales_cbc() (0) #endif
-#ifdef CONFIG_MACH_MULTHSU +#ifdef CONFIG_MACH_BLUEPOINT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MULTHSU +# define machine_arch_type MACH_TYPE_BLUEPOINT # endif -# define machine_is_multhsu() (machine_arch_type == MACH_TYPE_MULTHSU) +# define machine_is_bluepoint() (machine_arch_type == MACH_TYPE_BLUEPOINT) #else -# define machine_is_multhsu() (0) +# define machine_is_bluepoint() (0) #endif
-#ifdef CONFIG_MACH_SALUDA +#ifdef CONFIG_MACH_DIR665 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SALUDA +# define machine_arch_type MACH_TYPE_DIR665 # endif -# define machine_is_saluda() (machine_arch_type == MACH_TYPE_SALUDA) +# define machine_is_dir665() (machine_arch_type == MACH_TYPE_DIR665) #else -# define machine_is_saluda() (0) +# define machine_is_dir665() (0) #endif
-#ifdef CONFIG_MACH_PEMP_OMAP3_APOLLO +#ifdef CONFIG_MACH_ACMEROVER1 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PEMP_OMAP3_APOLLO +# define machine_arch_type MACH_TYPE_ACMEROVER1 # endif -# define machine_is_pemp_omap3_apollo() (machine_arch_type == MACH_TYPE_PEMP_OMAP3_APOLLO) +# define machine_is_acmerover1() (machine_arch_type == MACH_TYPE_ACMEROVER1) #else -# define machine_is_pemp_omap3_apollo() (0) +# define machine_is_acmerover1() (0) #endif
-#ifdef CONFIG_MACH_VC0718 +#ifdef CONFIG_MACH_SHOOTER_CT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VC0718 +# define machine_arch_type MACH_TYPE_SHOOTER_CT # endif -# define machine_is_vc0718() (machine_arch_type == MACH_TYPE_VC0718) +# define machine_is_shooter_ct() (machine_arch_type == MACH_TYPE_SHOOTER_CT) #else -# define machine_is_vc0718() (0) +# define machine_is_shooter_ct() (0) #endif
-#ifdef CONFIG_MACH_MVBLX +#ifdef CONFIG_MACH_BLISS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MVBLX +# define machine_arch_type MACH_TYPE_BLISS # endif -# define machine_is_mvblx() (machine_arch_type == MACH_TYPE_MVBLX) +# define machine_is_bliss() (machine_arch_type == MACH_TYPE_BLISS) #else -# define machine_is_mvblx() (0) +# define machine_is_bliss() (0) #endif
-#ifdef CONFIG_MACH_INHAND_APEIRON +#ifdef CONFIG_MACH_BLISSC # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_INHAND_APEIRON +# define machine_arch_type MACH_TYPE_BLISSC # endif -# define machine_is_inhand_apeiron() (machine_arch_type == MACH_TYPE_INHAND_APEIRON) +# define machine_is_blissc() (machine_arch_type == MACH_TYPE_BLISSC) #else -# define machine_is_inhand_apeiron() (0) +# define machine_is_blissc() (0) #endif
-#ifdef CONFIG_MACH_INHAND_FURY +#ifdef CONFIG_MACH_THALES_ADC # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_INHAND_FURY +# define machine_arch_type MACH_TYPE_THALES_ADC # endif -# define machine_is_inhand_fury() (machine_arch_type == MACH_TYPE_INHAND_FURY) +# define machine_is_thales_adc() (machine_arch_type == MACH_TYPE_THALES_ADC) #else -# define machine_is_inhand_fury() (0) +# define machine_is_thales_adc() (0) #endif
-#ifdef CONFIG_MACH_INHAND_SIREN +#ifdef CONFIG_MACH_UBISYS_P9D_EVP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_INHAND_SIREN +# define machine_arch_type MACH_TYPE_UBISYS_P9D_EVP # endif -# define machine_is_inhand_siren() (machine_arch_type == MACH_TYPE_INHAND_SIREN) +# define machine_is_ubisys_p9d_evp() (machine_arch_type == MACH_TYPE_UBISYS_P9D_EVP) #else -# define machine_is_inhand_siren() (0) +# define machine_is_ubisys_p9d_evp() (0) #endif
-#ifdef CONFIG_MACH_HDNVP +#ifdef CONFIG_MACH_ATDGP318 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HDNVP +# define machine_arch_type MACH_TYPE_ATDGP318 # endif -# define machine_is_hdnvp() (machine_arch_type == MACH_TYPE_HDNVP) +# define machine_is_atdgp318() (machine_arch_type == MACH_TYPE_ATDGP318) #else -# define machine_is_hdnvp() (0) +# define machine_is_atdgp318() (0) #endif
-#ifdef CONFIG_MACH_SOFTWINNER +#ifdef CONFIG_MACH_DMA210U # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SOFTWINNER +# define machine_arch_type MACH_TYPE_DMA210U # endif -# define machine_is_softwinner() (machine_arch_type == MACH_TYPE_SOFTWINNER) +# define machine_is_dma210u() (machine_arch_type == MACH_TYPE_DMA210U) #else -# define machine_is_softwinner() (0) +# define machine_is_dma210u() (0) #endif
-#ifdef CONFIG_MACH_PRIMA2_EVB +#ifdef CONFIG_MACH_EM_T3 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PRIMA2_EVB +# define machine_arch_type MACH_TYPE_EM_T3 # endif -# define machine_is_prima2_evb() (machine_arch_type == MACH_TYPE_PRIMA2_EVB) +# define machine_is_em_t3() (machine_arch_type == MACH_TYPE_EM_T3) #else -# define machine_is_prima2_evb() (0) +# define machine_is_em_t3() (0) #endif
-#ifdef CONFIG_MACH_NAS6210 +#ifdef CONFIG_MACH_HTX3250 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NAS6210 +# define machine_arch_type MACH_TYPE_HTX3250 # endif -# define machine_is_nas6210() (machine_arch_type == MACH_TYPE_NAS6210) +# define machine_is_htx3250() (machine_arch_type == MACH_TYPE_HTX3250) #else -# define machine_is_nas6210() (0) +# define machine_is_htx3250() (0) #endif
-#ifdef CONFIG_MACH_UNISDEV +#ifdef CONFIG_MACH_G50 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_UNISDEV +# define machine_arch_type MACH_TYPE_G50 # endif -# define machine_is_unisdev() (machine_arch_type == MACH_TYPE_UNISDEV) +# define machine_is_g50() (machine_arch_type == MACH_TYPE_G50) #else -# define machine_is_unisdev() (0) +# define machine_is_g50() (0) #endif
-#ifdef CONFIG_MACH_SBCA11 +#ifdef CONFIG_MACH_ECO5 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SBCA11 +# define machine_arch_type MACH_TYPE_ECO5 # endif -# define machine_is_sbca11() (machine_arch_type == MACH_TYPE_SBCA11) +# define machine_is_eco5() (machine_arch_type == MACH_TYPE_ECO5) #else -# define machine_is_sbca11() (0) +# define machine_is_eco5() (0) #endif
-#ifdef CONFIG_MACH_SAGA +#ifdef CONFIG_MACH_WINTERGRASP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SAGA +# define machine_arch_type MACH_TYPE_WINTERGRASP # endif -# define machine_is_saga() (machine_arch_type == MACH_TYPE_SAGA) +# define machine_is_wintergrasp() (machine_arch_type == MACH_TYPE_WINTERGRASP) #else -# define machine_is_saga() (0) +# define machine_is_wintergrasp() (0) #endif
-#ifdef CONFIG_MACH_NS_K330 +#ifdef CONFIG_MACH_PURO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NS_K330 +# define machine_arch_type MACH_TYPE_PURO # endif -# define machine_is_ns_k330() (machine_arch_type == MACH_TYPE_NS_K330) +# define machine_is_puro() (machine_arch_type == MACH_TYPE_PURO) #else -# define machine_is_ns_k330() (0) +# define machine_is_puro() (0) #endif
-#ifdef CONFIG_MACH_TANNA +#ifdef CONFIG_MACH_SHOOTER_K # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TANNA +# define machine_arch_type MACH_TYPE_SHOOTER_K # endif -# define machine_is_tanna() (machine_arch_type == MACH_TYPE_TANNA) +# define machine_is_shooter_k() (machine_arch_type == MACH_TYPE_SHOOTER_K) #else -# define machine_is_tanna() (0) +# define machine_is_shooter_k() (0) #endif
-#ifdef CONFIG_MACH_IMATE8502 +#ifdef CONFIG_MACH_NSPIRE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_IMATE8502 +# define machine_arch_type MACH_TYPE_NSPIRE # endif -# define machine_is_imate8502() (machine_arch_type == MACH_TYPE_IMATE8502) +# define machine_is_nspire() (machine_arch_type == MACH_TYPE_NSPIRE) #else -# define machine_is_imate8502() (0) +# define machine_is_nspire() (0) #endif
-#ifdef CONFIG_MACH_ASPEN +#ifdef CONFIG_MACH_MICKXX # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ASPEN +# define machine_arch_type MACH_TYPE_MICKXX # endif -# define machine_is_aspen() (machine_arch_type == MACH_TYPE_ASPEN) +# define machine_is_mickxx() (machine_arch_type == MACH_TYPE_MICKXX) #else -# define machine_is_aspen() (0) +# define machine_is_mickxx() (0) #endif
-#ifdef CONFIG_MACH_DAINTREE_CWAC +#ifdef CONFIG_MACH_LXMB # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DAINTREE_CWAC +# define machine_arch_type MACH_TYPE_LXMB # endif -# define machine_is_daintree_cwac() (machine_arch_type == MACH_TYPE_DAINTREE_CWAC) +# define machine_is_lxmb() (machine_arch_type == MACH_TYPE_LXMB) #else -# define machine_is_daintree_cwac() (0) +# define machine_is_lxmb() (0) #endif
-#ifdef CONFIG_MACH_ZMX25 +#ifdef CONFIG_MACH_ADAM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ZMX25 +# define machine_arch_type MACH_TYPE_ADAM # endif -# define machine_is_zmx25() (machine_arch_type == MACH_TYPE_ZMX25) +# define machine_is_adam() (machine_arch_type == MACH_TYPE_ADAM) #else -# define machine_is_zmx25() (0) +# define machine_is_adam() (0) #endif
-#ifdef CONFIG_MACH_MAPLE1 +#ifdef CONFIG_MACH_B1004 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MAPLE1 +# define machine_arch_type MACH_TYPE_B1004 # endif -# define machine_is_maple1() (machine_arch_type == MACH_TYPE_MAPLE1) +# define machine_is_b1004() (machine_arch_type == MACH_TYPE_B1004) #else -# define machine_is_maple1() (0) +# define machine_is_b1004() (0) #endif
-#ifdef CONFIG_MACH_QSD8X72_SURF +#ifdef CONFIG_MACH_OBOEA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_QSD8X72_SURF +# define machine_arch_type MACH_TYPE_OBOEA # endif -# define machine_is_qsd8x72_surf() (machine_arch_type == MACH_TYPE_QSD8X72_SURF) +# define machine_is_oboea() (machine_arch_type == MACH_TYPE_OBOEA) #else -# define machine_is_qsd8x72_surf() (0) +# define machine_is_oboea() (0) #endif
-#ifdef CONFIG_MACH_QSD8X72_FFA +#ifdef CONFIG_MACH_A1015 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_QSD8X72_FFA +# define machine_arch_type MACH_TYPE_A1015 # endif -# define machine_is_qsd8x72_ffa() (machine_arch_type == MACH_TYPE_QSD8X72_FFA) +# define machine_is_a1015() (machine_arch_type == MACH_TYPE_A1015) #else -# define machine_is_qsd8x72_ffa() (0) +# define machine_is_a1015() (0) #endif
-#ifdef CONFIG_MACH_ABILENE +#ifdef CONFIG_MACH_ROBIN_VBDT30 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ABILENE +# define machine_arch_type MACH_TYPE_ROBIN_VBDT30 # endif -# define machine_is_abilene() (machine_arch_type == MACH_TYPE_ABILENE) +# define machine_is_robin_vbdt30() (machine_arch_type == MACH_TYPE_ROBIN_VBDT30) #else -# define machine_is_abilene() (0) +# define machine_is_robin_vbdt30() (0) #endif
-#ifdef CONFIG_MACH_EIGEN_TTR +#ifdef CONFIG_MACH_TEGRA_ENTERPRISE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_EIGEN_TTR +# define machine_arch_type MACH_TYPE_TEGRA_ENTERPRISE # endif -# define machine_is_eigen_ttr() (machine_arch_type == MACH_TYPE_EIGEN_TTR) +# define machine_is_tegra_enterprise() (machine_arch_type == MACH_TYPE_TEGRA_ENTERPRISE) #else -# define machine_is_eigen_ttr() (0) +# define machine_is_tegra_enterprise() (0) #endif
-#ifdef CONFIG_MACH_IOMEGA_IX2_200 +#ifdef CONFIG_MACH_RFL108200_MK10 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_IOMEGA_IX2_200 +# define machine_arch_type MACH_TYPE_RFL108200_MK10 # endif -# define machine_is_iomega_ix2_200() (machine_arch_type == MACH_TYPE_IOMEGA_IX2_200) +# define machine_is_rfl108200_mk10() (machine_arch_type == MACH_TYPE_RFL108200_MK10) #else -# define machine_is_iomega_ix2_200() (0) +# define machine_is_rfl108200_mk10() (0) #endif
-#ifdef CONFIG_MACH_CORETEC_VCX7400 +#ifdef CONFIG_MACH_RFL108300_MK16 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CORETEC_VCX7400 +# define machine_arch_type MACH_TYPE_RFL108300_MK16 # endif -# define machine_is_coretec_vcx7400() (machine_arch_type == MACH_TYPE_CORETEC_VCX7400) +# define machine_is_rfl108300_mk16() (machine_arch_type == MACH_TYPE_RFL108300_MK16) #else -# define machine_is_coretec_vcx7400() (0) +# define machine_is_rfl108300_mk16() (0) #endif
-#ifdef CONFIG_MACH_SANTIAGO +#ifdef CONFIG_MACH_ROVER_V7 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SANTIAGO +# define machine_arch_type MACH_TYPE_ROVER_V7 # endif -# define machine_is_santiago() (machine_arch_type == MACH_TYPE_SANTIAGO) +# define machine_is_rover_v7() (machine_arch_type == MACH_TYPE_ROVER_V7) #else -# define machine_is_santiago() (0) +# define machine_is_rover_v7() (0) #endif
-#ifdef CONFIG_MACH_MX257SOL +#ifdef CONFIG_MACH_MIPHONE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MX257SOL +# define machine_arch_type MACH_TYPE_MIPHONE # endif -# define machine_is_mx257sol() (machine_arch_type == MACH_TYPE_MX257SOL) +# define machine_is_miphone() (machine_arch_type == MACH_TYPE_MIPHONE) #else -# define machine_is_mx257sol() (0) +# define machine_is_miphone() (0) #endif
-#ifdef CONFIG_MACH_STRASBOURG +#ifdef CONFIG_MACH_FEMTOBTS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_STRASBOURG +# define machine_arch_type MACH_TYPE_FEMTOBTS # endif -# define machine_is_strasbourg() (machine_arch_type == MACH_TYPE_STRASBOURG) +# define machine_is_femtobts() (machine_arch_type == MACH_TYPE_FEMTOBTS) #else -# define machine_is_strasbourg() (0) +# define machine_is_femtobts() (0) #endif
-#ifdef CONFIG_MACH_MSM8X60_FLUID +#ifdef CONFIG_MACH_MONOPOLI # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MSM8X60_FLUID +# define machine_arch_type MACH_TYPE_MONOPOLI # endif -# define machine_is_msm8x60_fluid() (machine_arch_type == MACH_TYPE_MSM8X60_FLUID) +# define machine_is_monopoli() (machine_arch_type == MACH_TYPE_MONOPOLI) #else -# define machine_is_msm8x60_fluid() (0) +# define machine_is_monopoli() (0) #endif
-#ifdef CONFIG_MACH_SMARTQV5 +#ifdef CONFIG_MACH_BOSS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SMARTQV5 +# define machine_arch_type MACH_TYPE_BOSS # endif -# define machine_is_smartqv5() (machine_arch_type == MACH_TYPE_SMARTQV5) +# define machine_is_boss() (machine_arch_type == MACH_TYPE_BOSS) #else -# define machine_is_smartqv5() (0) +# define machine_is_boss() (0) #endif
-#ifdef CONFIG_MACH_SMARTQV3 +#ifdef CONFIG_MACH_DAVINCI_DM368_VTAM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SMARTQV3 +# define machine_arch_type MACH_TYPE_DAVINCI_DM368_VTAM # endif -# define machine_is_smartqv3() (machine_arch_type == MACH_TYPE_SMARTQV3) +# define machine_is_davinci_dm368_vtam() (machine_arch_type == MACH_TYPE_DAVINCI_DM368_VTAM) #else -# define machine_is_smartqv3() (0) +# define machine_is_davinci_dm368_vtam() (0) #endif
-#ifdef CONFIG_MACH_SMARTQV7 +#ifdef CONFIG_MACH_CLCON # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SMARTQV7 +# define machine_arch_type MACH_TYPE_CLCON # endif -# define machine_is_smartqv7() (machine_arch_type == MACH_TYPE_SMARTQV7) +# define machine_is_clcon() (machine_arch_type == MACH_TYPE_CLCON) #else -# define machine_is_smartqv7() (0) +# define machine_is_clcon() (0) #endif
-#ifdef CONFIG_MACH_PAZ00 +#ifdef CONFIG_MACH_NOKIA_RM696 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PAZ00 +# define machine_arch_type MACH_TYPE_NOKIA_RM696 # endif -# define machine_is_paz00() (machine_arch_type == MACH_TYPE_PAZ00) +# define machine_is_nokia_rm696() (machine_arch_type == MACH_TYPE_NOKIA_RM696) #else -# define machine_is_paz00() (0) +# define machine_is_nokia_rm696() (0) #endif
-#ifdef CONFIG_MACH_ACMENETUSFOXG20 +#ifdef CONFIG_MACH_TAHITI # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ACMENETUSFOXG20 +# define machine_arch_type MACH_TYPE_TAHITI # endif -# define machine_is_acmenetusfoxg20() (machine_arch_type == MACH_TYPE_ACMENETUSFOXG20) +# define machine_is_tahiti() (machine_arch_type == MACH_TYPE_TAHITI) #else -# define machine_is_acmenetusfoxg20() (0) +# define machine_is_tahiti() (0) #endif
-#ifdef CONFIG_MACH_FWBD_0404 +#ifdef CONFIG_MACH_FIGHTER # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_FWBD_0404 +# define machine_arch_type MACH_TYPE_FIGHTER # endif -# define machine_is_fwbd_0404() (machine_arch_type == MACH_TYPE_FWBD_0404) +# define machine_is_fighter() (machine_arch_type == MACH_TYPE_FIGHTER) #else -# define machine_is_fwbd_0404() (0) +# define machine_is_fighter() (0) #endif
-#ifdef CONFIG_MACH_HDGU +#ifdef CONFIG_MACH_SGH_I710 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HDGU +# define machine_arch_type MACH_TYPE_SGH_I710 # endif -# define machine_is_hdgu() (machine_arch_type == MACH_TYPE_HDGU) +# define machine_is_sgh_i710() (machine_arch_type == MACH_TYPE_SGH_I710) #else -# define machine_is_hdgu() (0) +# define machine_is_sgh_i710() (0) #endif
-#ifdef CONFIG_MACH_PYRAMID +#ifdef CONFIG_MACH_INTEGREPROSCB # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PYRAMID +# define machine_arch_type MACH_TYPE_INTEGREPROSCB # endif -# define machine_is_pyramid() (machine_arch_type == MACH_TYPE_PYRAMID) +# define machine_is_integreproscb() (machine_arch_type == MACH_TYPE_INTEGREPROSCB) #else -# define machine_is_pyramid() (0) +# define machine_is_integreproscb() (0) #endif
-#ifdef CONFIG_MACH_EPIPHAN +#ifdef CONFIG_MACH_MONZA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_EPIPHAN +# define machine_arch_type MACH_TYPE_MONZA # endif -# define machine_is_epiphan() (machine_arch_type == MACH_TYPE_EPIPHAN) +# define machine_is_monza() (machine_arch_type == MACH_TYPE_MONZA) #else -# define machine_is_epiphan() (0) +# define machine_is_monza() (0) #endif
-#ifdef CONFIG_MACH_OMAP_BENDER +#ifdef CONFIG_MACH_CALIMAIN # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OMAP_BENDER +# define machine_arch_type MACH_TYPE_CALIMAIN # endif -# define machine_is_omap_bender() (machine_arch_type == MACH_TYPE_OMAP_BENDER) +# define machine_is_calimain() (machine_arch_type == MACH_TYPE_CALIMAIN) #else -# define machine_is_omap_bender() (0) +# define machine_is_calimain() (0) #endif
-#ifdef CONFIG_MACH_GURNARD +#ifdef CONFIG_MACH_MX6Q_SABREAUTO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GURNARD +# define machine_arch_type MACH_TYPE_MX6Q_SABREAUTO # endif -# define machine_is_gurnard() (machine_arch_type == MACH_TYPE_GURNARD) +# define machine_is_mx6q_sabreauto() (machine_arch_type == MACH_TYPE_MX6Q_SABREAUTO) #else -# define machine_is_gurnard() (0) +# define machine_is_mx6q_sabreauto() (0) #endif
-#ifdef CONFIG_MACH_GTL_IT5100 +#ifdef CONFIG_MACH_GMA01X # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GTL_IT5100 +# define machine_arch_type MACH_TYPE_GMA01X # endif -# define machine_is_gtl_it5100() (machine_arch_type == MACH_TYPE_GTL_IT5100) +# define machine_is_gma01x() (machine_arch_type == MACH_TYPE_GMA01X) #else -# define machine_is_gtl_it5100() (0) +# define machine_is_gma01x() (0) #endif
-#ifdef CONFIG_MACH_BCM2708 +#ifdef CONFIG_MACH_SBC51 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BCM2708 +# define machine_arch_type MACH_TYPE_SBC51 # endif -# define machine_is_bcm2708() (machine_arch_type == MACH_TYPE_BCM2708) +# define machine_is_sbc51() (machine_arch_type == MACH_TYPE_SBC51) #else -# define machine_is_bcm2708() (0) +# define machine_is_sbc51() (0) #endif
-#ifdef CONFIG_MACH_MX51_GGC +#ifdef CONFIG_MACH_FIT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MX51_GGC +# define machine_arch_type MACH_TYPE_FIT # endif -# define machine_is_mx51_ggc() (machine_arch_type == MACH_TYPE_MX51_GGC) +# define machine_is_fit() (machine_arch_type == MACH_TYPE_FIT) #else -# define machine_is_mx51_ggc() (0) +# define machine_is_fit() (0) #endif
-#ifdef CONFIG_MACH_SHARESPACE +#ifdef CONFIG_MACH_STEELHEAD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SHARESPACE +# define machine_arch_type MACH_TYPE_STEELHEAD # endif -# define machine_is_sharespace() (machine_arch_type == MACH_TYPE_SHARESPACE) +# define machine_is_steelhead() (machine_arch_type == MACH_TYPE_STEELHEAD) #else -# define machine_is_sharespace() (0) +# define machine_is_steelhead() (0) #endif
-#ifdef CONFIG_MACH_HABA_KNX_EXPLORER +#ifdef CONFIG_MACH_PANTHER # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HABA_KNX_EXPLORER +# define machine_arch_type MACH_TYPE_PANTHER # endif -# define machine_is_haba_knx_explorer() (machine_arch_type == MACH_TYPE_HABA_KNX_EXPLORER) +# define machine_is_panther() (machine_arch_type == MACH_TYPE_PANTHER) #else -# define machine_is_haba_knx_explorer() (0) +# define machine_is_panther() (0) #endif
-#ifdef CONFIG_MACH_SIMTEC_KIRKMOD +#ifdef CONFIG_MACH_MSM8960_LIQUID # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SIMTEC_KIRKMOD +# define machine_arch_type MACH_TYPE_MSM8960_LIQUID # endif -# define machine_is_simtec_kirkmod() (machine_arch_type == MACH_TYPE_SIMTEC_KIRKMOD) +# define machine_is_msm8960_liquid() (machine_arch_type == MACH_TYPE_MSM8960_LIQUID) #else -# define machine_is_simtec_kirkmod() (0) +# define machine_is_msm8960_liquid() (0) #endif
-#ifdef CONFIG_MACH_CRUX +#ifdef CONFIG_MACH_LEXIKONCT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CRUX +# define machine_arch_type MACH_TYPE_LEXIKONCT # endif -# define machine_is_crux() (machine_arch_type == MACH_TYPE_CRUX) +# define machine_is_lexikonct() (machine_arch_type == MACH_TYPE_LEXIKONCT) #else -# define machine_is_crux() (0) +# define machine_is_lexikonct() (0) #endif
-#ifdef CONFIG_MACH_MX51_BRAVO +#ifdef CONFIG_MACH_NS2816_STB # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MX51_BRAVO +# define machine_arch_type MACH_TYPE_NS2816_STB # endif -# define machine_is_mx51_bravo() (machine_arch_type == MACH_TYPE_MX51_BRAVO) +# define machine_is_ns2816_stb() (machine_arch_type == MACH_TYPE_NS2816_STB) #else -# define machine_is_mx51_bravo() (0) +# define machine_is_ns2816_stb() (0) #endif
-#ifdef CONFIG_MACH_CHARON +#ifdef CONFIG_MACH_SEI_MM2_LPC3250 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CHARON +# define machine_arch_type MACH_TYPE_SEI_MM2_LPC3250 # endif -# define machine_is_charon() (machine_arch_type == MACH_TYPE_CHARON) +# define machine_is_sei_mm2_lpc3250() (machine_arch_type == MACH_TYPE_SEI_MM2_LPC3250) #else -# define machine_is_charon() (0) +# define machine_is_sei_mm2_lpc3250() (0) #endif
-#ifdef CONFIG_MACH_PICOCOM3 +#ifdef CONFIG_MACH_CMIMX53 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PICOCOM3 +# define machine_arch_type MACH_TYPE_CMIMX53 # endif -# define machine_is_picocom3() (machine_arch_type == MACH_TYPE_PICOCOM3) +# define machine_is_cmimx53() (machine_arch_type == MACH_TYPE_CMIMX53) #else -# define machine_is_picocom3() (0) +# define machine_is_cmimx53() (0) #endif
-#ifdef CONFIG_MACH_PICOCOM4 +#ifdef CONFIG_MACH_SANDWICH # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PICOCOM4 +# define machine_arch_type MACH_TYPE_SANDWICH # endif -# define machine_is_picocom4() (machine_arch_type == MACH_TYPE_PICOCOM4) +# define machine_is_sandwich() (machine_arch_type == MACH_TYPE_SANDWICH) #else -# define machine_is_picocom4() (0) +# define machine_is_sandwich() (0) #endif
-#ifdef CONFIG_MACH_SERRANO +#ifdef CONFIG_MACH_CHIEF # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SERRANO +# define machine_arch_type MACH_TYPE_CHIEF # endif -# define machine_is_serrano() (machine_arch_type == MACH_TYPE_SERRANO) +# define machine_is_chief() (machine_arch_type == MACH_TYPE_CHIEF) #else -# define machine_is_serrano() (0) +# define machine_is_chief() (0) #endif
-#ifdef CONFIG_MACH_DOUBLESHOT +#ifdef CONFIG_MACH_POGO_E02 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DOUBLESHOT +# define machine_arch_type MACH_TYPE_POGO_E02 # endif -# define machine_is_doubleshot() (machine_arch_type == MACH_TYPE_DOUBLESHOT) +# define machine_is_pogo_e02() (machine_arch_type == MACH_TYPE_POGO_E02) #else -# define machine_is_doubleshot() (0) +# define machine_is_pogo_e02() (0) #endif
-#ifdef CONFIG_MACH_EVSY +#ifdef CONFIG_MACH_MIKRAP_X168 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_EVSY +# define machine_arch_type MACH_TYPE_MIKRAP_X168 # endif -# define machine_is_evsy() (machine_arch_type == MACH_TYPE_EVSY) +# define machine_is_mikrap_x168() (machine_arch_type == MACH_TYPE_MIKRAP_X168) #else -# define machine_is_evsy() (0) +# define machine_is_mikrap_x168() (0) #endif
-#ifdef CONFIG_MACH_HUASHAN +#ifdef CONFIG_MACH_HTCMOZART # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HUASHAN +# define machine_arch_type MACH_TYPE_HTCMOZART # endif -# define machine_is_huashan() (machine_arch_type == MACH_TYPE_HUASHAN) +# define machine_is_htcmozart() (machine_arch_type == MACH_TYPE_HTCMOZART) #else -# define machine_is_huashan() (0) +# define machine_is_htcmozart() (0) #endif
-#ifdef CONFIG_MACH_LAUSANNE +#ifdef CONFIG_MACH_HTCGOLD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_LAUSANNE +# define machine_arch_type MACH_TYPE_HTCGOLD # endif -# define machine_is_lausanne() (machine_arch_type == MACH_TYPE_LAUSANNE) +# define machine_is_htcgold() (machine_arch_type == MACH_TYPE_HTCGOLD) #else -# define machine_is_lausanne() (0) +# define machine_is_htcgold() (0) #endif
-#ifdef CONFIG_MACH_EMERALD +#ifdef CONFIG_MACH_MT72XX # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_EMERALD +# define machine_arch_type MACH_TYPE_MT72XX # endif -# define machine_is_emerald() (machine_arch_type == MACH_TYPE_EMERALD) +# define machine_is_mt72xx() (machine_arch_type == MACH_TYPE_MT72XX) #else -# define machine_is_emerald() (0) +# define machine_is_mt72xx() (0) #endif
-#ifdef CONFIG_MACH_TQMA35 +#ifdef CONFIG_MACH_MX51_IVY # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TQMA35 +# define machine_arch_type MACH_TYPE_MX51_IVY # endif -# define machine_is_tqma35() (machine_arch_type == MACH_TYPE_TQMA35) +# define machine_is_mx51_ivy() (machine_arch_type == MACH_TYPE_MX51_IVY) #else -# define machine_is_tqma35() (0) +# define machine_is_mx51_ivy() (0) #endif
-#ifdef CONFIG_MACH_MARVEL +#ifdef CONFIG_MACH_MX51_LVD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MARVEL +# define machine_arch_type MACH_TYPE_MX51_LVD # endif -# define machine_is_marvel() (machine_arch_type == MACH_TYPE_MARVEL) +# define machine_is_mx51_lvd() (machine_arch_type == MACH_TYPE_MX51_LVD) #else -# define machine_is_marvel() (0) +# define machine_is_mx51_lvd() (0) #endif
-#ifdef CONFIG_MACH_MANUAE +#ifdef CONFIG_MACH_OMAP3_WISER2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MANUAE +# define machine_arch_type MACH_TYPE_OMAP3_WISER2 # endif -# define machine_is_manuae() (machine_arch_type == MACH_TYPE_MANUAE) +# define machine_is_omap3_wiser2() (machine_arch_type == MACH_TYPE_OMAP3_WISER2) #else -# define machine_is_manuae() (0) +# define machine_is_omap3_wiser2() (0) #endif
-#ifdef CONFIG_MACH_CHACHA +#ifdef CONFIG_MACH_DREAMPLUG # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CHACHA +# define machine_arch_type MACH_TYPE_DREAMPLUG # endif -# define machine_is_chacha() (machine_arch_type == MACH_TYPE_CHACHA) +# define machine_is_dreamplug() (machine_arch_type == MACH_TYPE_DREAMPLUG) #else -# define machine_is_chacha() (0) +# define machine_is_dreamplug() (0) #endif
-#ifdef CONFIG_MACH_LEMON +#ifdef CONFIG_MACH_COBAS_C_111 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_LEMON +# define machine_arch_type MACH_TYPE_COBAS_C_111 # endif -# define machine_is_lemon() (machine_arch_type == MACH_TYPE_LEMON) +# define machine_is_cobas_c_111() (machine_arch_type == MACH_TYPE_COBAS_C_111) #else -# define machine_is_lemon() (0) +# define machine_is_cobas_c_111() (0) #endif
-#ifdef CONFIG_MACH_CSC +#ifdef CONFIG_MACH_COBAS_U_411 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CSC +# define machine_arch_type MACH_TYPE_COBAS_U_411 # endif -# define machine_is_csc() (machine_arch_type == MACH_TYPE_CSC) +# define machine_is_cobas_u_411() (machine_arch_type == MACH_TYPE_COBAS_U_411) #else -# define machine_is_csc() (0) +# define machine_is_cobas_u_411() (0) #endif
-#ifdef CONFIG_MACH_GIRA_KNXIP_ROUTER +#ifdef CONFIG_MACH_HSSD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GIRA_KNXIP_ROUTER +# define machine_arch_type MACH_TYPE_HSSD # endif -# define machine_is_gira_knxip_router() (machine_arch_type == MACH_TYPE_GIRA_KNXIP_ROUTER) +# define machine_is_hssd() (machine_arch_type == MACH_TYPE_HSSD) #else -# define machine_is_gira_knxip_router() (0) +# define machine_is_hssd() (0) #endif
-#ifdef CONFIG_MACH_T20 +#ifdef CONFIG_MACH_IOM35X # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_T20 +# define machine_arch_type MACH_TYPE_IOM35X # endif -# define machine_is_t20() (machine_arch_type == MACH_TYPE_T20) +# define machine_is_iom35x() (machine_arch_type == MACH_TYPE_IOM35X) #else -# define machine_is_t20() (0) +# define machine_is_iom35x() (0) #endif
-#ifdef CONFIG_MACH_HDMINI +#ifdef CONFIG_MACH_PSOM_OMAP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HDMINI +# define machine_arch_type MACH_TYPE_PSOM_OMAP # endif -# define machine_is_hdmini() (machine_arch_type == MACH_TYPE_HDMINI) +# define machine_is_psom_omap() (machine_arch_type == MACH_TYPE_PSOM_OMAP) #else -# define machine_is_hdmini() (0) +# define machine_is_psom_omap() (0) #endif
-#ifdef CONFIG_MACH_SCIPHONE_G2 +#ifdef CONFIG_MACH_IPHONE_2G # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SCIPHONE_G2 +# define machine_arch_type MACH_TYPE_IPHONE_2G # endif -# define machine_is_sciphone_g2() (machine_arch_type == MACH_TYPE_SCIPHONE_G2) +# define machine_is_iphone_2g() (machine_arch_type == MACH_TYPE_IPHONE_2G) #else -# define machine_is_sciphone_g2() (0) +# define machine_is_iphone_2g() (0) #endif
-#ifdef CONFIG_MACH_EXPRESS +#ifdef CONFIG_MACH_IPHONE_3G # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_EXPRESS +# define machine_arch_type MACH_TYPE_IPHONE_3G # endif -# define machine_is_express() (machine_arch_type == MACH_TYPE_EXPRESS) +# define machine_is_iphone_3g() (machine_arch_type == MACH_TYPE_IPHONE_3G) #else -# define machine_is_express() (0) +# define machine_is_iphone_3g() (0) #endif
-#ifdef CONFIG_MACH_EXPRESS_KT +#ifdef CONFIG_MACH_IPOD_TOUCH_1G # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_EXPRESS_KT +# define machine_arch_type MACH_TYPE_IPOD_TOUCH_1G # endif -# define machine_is_express_kt() (machine_arch_type == MACH_TYPE_EXPRESS_KT) +# define machine_is_ipod_touch_1g() (machine_arch_type == MACH_TYPE_IPOD_TOUCH_1G) #else -# define machine_is_express_kt() (0) +# define machine_is_ipod_touch_1g() (0) #endif
-#ifdef CONFIG_MACH_MAXIMASP +#ifdef CONFIG_MACH_PHAROS_TPC # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MAXIMASP +# define machine_arch_type MACH_TYPE_PHAROS_TPC # endif -# define machine_is_maximasp() (machine_arch_type == MACH_TYPE_MAXIMASP) +# define machine_is_pharos_tpc() (machine_arch_type == MACH_TYPE_PHAROS_TPC) #else -# define machine_is_maximasp() (0) +# define machine_is_pharos_tpc() (0) #endif
-#ifdef CONFIG_MACH_NITROGEN_IMX51 +#ifdef CONFIG_MACH_MX53_HYDRA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NITROGEN_IMX51 +# define machine_arch_type MACH_TYPE_MX53_HYDRA # endif -# define machine_is_nitrogen_imx51() (machine_arch_type == MACH_TYPE_NITROGEN_IMX51) +# define machine_is_mx53_hydra() (machine_arch_type == MACH_TYPE_MX53_HYDRA) #else -# define machine_is_nitrogen_imx51() (0) +# define machine_is_mx53_hydra() (0) #endif
-#ifdef CONFIG_MACH_NITROGEN_IMX53 +#ifdef CONFIG_MACH_NS2816_DEV_BOARD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NITROGEN_IMX53 +# define machine_arch_type MACH_TYPE_NS2816_DEV_BOARD # endif -# define machine_is_nitrogen_imx53() (machine_arch_type == MACH_TYPE_NITROGEN_IMX53) +# define machine_is_ns2816_dev_board() (machine_arch_type == MACH_TYPE_NS2816_DEV_BOARD) #else -# define machine_is_nitrogen_imx53() (0) +# define machine_is_ns2816_dev_board() (0) #endif
-#ifdef CONFIG_MACH_SUNFIRE +#ifdef CONFIG_MACH_IPHONE_3GS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SUNFIRE +# define machine_arch_type MACH_TYPE_IPHONE_3GS # endif -# define machine_is_sunfire() (machine_arch_type == MACH_TYPE_SUNFIRE) +# define machine_is_iphone_3gs() (machine_arch_type == MACH_TYPE_IPHONE_3GS) #else -# define machine_is_sunfire() (0) +# define machine_is_iphone_3gs() (0) #endif
-#ifdef CONFIG_MACH_AROWANA +#ifdef CONFIG_MACH_IPHONE_4 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_AROWANA +# define machine_arch_type MACH_TYPE_IPHONE_4 # endif -# define machine_is_arowana() (machine_arch_type == MACH_TYPE_AROWANA) +# define machine_is_iphone_4() (machine_arch_type == MACH_TYPE_IPHONE_4) #else -# define machine_is_arowana() (0) +# define machine_is_iphone_4() (0) #endif
-#ifdef CONFIG_MACH_TEGRA_DAYTONA +#ifdef CONFIG_MACH_IPOD_TOUCH_4G # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TEGRA_DAYTONA +# define machine_arch_type MACH_TYPE_IPOD_TOUCH_4G # endif -# define machine_is_tegra_daytona() (machine_arch_type == MACH_TYPE_TEGRA_DAYTONA) +# define machine_is_ipod_touch_4g() (machine_arch_type == MACH_TYPE_IPOD_TOUCH_4G) #else -# define machine_is_tegra_daytona() (0) +# define machine_is_ipod_touch_4g() (0) #endif
-#ifdef CONFIG_MACH_TEGRA_SWORDFISH +#ifdef CONFIG_MACH_DRAGON_E1100 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TEGRA_SWORDFISH +# define machine_arch_type MACH_TYPE_DRAGON_E1100 # endif -# define machine_is_tegra_swordfish() (machine_arch_type == MACH_TYPE_TEGRA_SWORDFISH) +# define machine_is_dragon_e1100() (machine_arch_type == MACH_TYPE_DRAGON_E1100) #else -# define machine_is_tegra_swordfish() (0) +# define machine_is_dragon_e1100() (0) #endif
-#ifdef CONFIG_MACH_EDISON +#ifdef CONFIG_MACH_TOPSIDE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_EDISON +# define machine_arch_type MACH_TYPE_TOPSIDE # endif -# define machine_is_edison() (machine_arch_type == MACH_TYPE_EDISON) +# define machine_is_topside() (machine_arch_type == MACH_TYPE_TOPSIDE) #else -# define machine_is_edison() (0) +# define machine_is_topside() (0) #endif
-#ifdef CONFIG_MACH_SVP8500V1 +#ifdef CONFIG_MACH_IRISIII # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SVP8500V1 +# define machine_arch_type MACH_TYPE_IRISIII # endif -# define machine_is_svp8500v1() (machine_arch_type == MACH_TYPE_SVP8500V1) +# define machine_is_irisiii() (machine_arch_type == MACH_TYPE_IRISIII) #else -# define machine_is_svp8500v1() (0) +# define machine_is_irisiii() (0) #endif
-#ifdef CONFIG_MACH_SVP8500V2 +#ifdef CONFIG_MACH_DETO_MACARM9 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SVP8500V2 +# define machine_arch_type MACH_TYPE_DETO_MACARM9 # endif -# define machine_is_svp8500v2() (machine_arch_type == MACH_TYPE_SVP8500V2) +# define machine_is_deto_macarm9() (machine_arch_type == MACH_TYPE_DETO_MACARM9) #else -# define machine_is_svp8500v2() (0) +# define machine_is_deto_macarm9() (0) #endif
-#ifdef CONFIG_MACH_SVP5500 +#ifdef CONFIG_MACH_ETI_D1 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SVP5500 +# define machine_arch_type MACH_TYPE_ETI_D1 # endif -# define machine_is_svp5500() (machine_arch_type == MACH_TYPE_SVP5500) +# define machine_is_eti_d1() (machine_arch_type == MACH_TYPE_ETI_D1) #else -# define machine_is_svp5500() (0) +# define machine_is_eti_d1() (0) #endif
-#ifdef CONFIG_MACH_B5500 +#ifdef CONFIG_MACH_SOM3530SDK # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_B5500 +# define machine_arch_type MACH_TYPE_SOM3530SDK # endif -# define machine_is_b5500() (machine_arch_type == MACH_TYPE_B5500) +# define machine_is_som3530sdk() (machine_arch_type == MACH_TYPE_SOM3530SDK) #else -# define machine_is_b5500() (0) +# define machine_is_som3530sdk() (0) #endif
-#ifdef CONFIG_MACH_S5500 +#ifdef CONFIG_MACH_OC_ENGINE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_S5500 +# define machine_arch_type MACH_TYPE_OC_ENGINE # endif -# define machine_is_s5500() (machine_arch_type == MACH_TYPE_S5500) +# define machine_is_oc_engine() (machine_arch_type == MACH_TYPE_OC_ENGINE) #else -# define machine_is_s5500() (0) +# define machine_is_oc_engine() (0) #endif
-#ifdef CONFIG_MACH_ICON +#ifdef CONFIG_MACH_APQ8064_SIM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ICON +# define machine_arch_type MACH_TYPE_APQ8064_SIM # endif -# define machine_is_icon() (machine_arch_type == MACH_TYPE_ICON) +# define machine_is_apq8064_sim() (machine_arch_type == MACH_TYPE_APQ8064_SIM) #else -# define machine_is_icon() (0) +# define machine_is_apq8064_sim() (0) #endif
-#ifdef CONFIG_MACH_ELEPHANT +#ifdef CONFIG_MACH_ALPS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ELEPHANT +# define machine_arch_type MACH_TYPE_ALPS # endif -# define machine_is_elephant() (machine_arch_type == MACH_TYPE_ELEPHANT) +# define machine_is_alps() (machine_arch_type == MACH_TYPE_ALPS) #else -# define machine_is_elephant() (0) +# define machine_is_alps() (0) #endif
-#ifdef CONFIG_MACH_SHOOTER +#ifdef CONFIG_MACH_TNY_T3730 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SHOOTER +# define machine_arch_type MACH_TYPE_TNY_T3730 # endif -# define machine_is_shooter() (machine_arch_type == MACH_TYPE_SHOOTER) +# define machine_is_tny_t3730() (machine_arch_type == MACH_TYPE_TNY_T3730) #else -# define machine_is_shooter() (0) +# define machine_is_tny_t3730() (0) #endif
-#ifdef CONFIG_MACH_SPADE_LTE +#ifdef CONFIG_MACH_GERYON_NFE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SPADE_LTE +# define machine_arch_type MACH_TYPE_GERYON_NFE # endif -# define machine_is_spade_lte() (machine_arch_type == MACH_TYPE_SPADE_LTE) +# define machine_is_geryon_nfe() (machine_arch_type == MACH_TYPE_GERYON_NFE) #else -# define machine_is_spade_lte() (0) +# define machine_is_geryon_nfe() (0) #endif
-#ifdef CONFIG_MACH_PHILHWANI +#ifdef CONFIG_MACH_NS2816_REF_BOARD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PHILHWANI +# define machine_arch_type MACH_TYPE_NS2816_REF_BOARD # endif -# define machine_is_philhwani() (machine_arch_type == MACH_TYPE_PHILHWANI) +# define machine_is_ns2816_ref_board() (machine_arch_type == MACH_TYPE_NS2816_REF_BOARD) #else -# define machine_is_philhwani() (0) +# define machine_is_ns2816_ref_board() (0) #endif
-#ifdef CONFIG_MACH_GSNCOMM +#ifdef CONFIG_MACH_SILVERSTONE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GSNCOMM +# define machine_arch_type MACH_TYPE_SILVERSTONE # endif -# define machine_is_gsncomm() (machine_arch_type == MACH_TYPE_GSNCOMM) +# define machine_is_silverstone() (machine_arch_type == MACH_TYPE_SILVERSTONE) #else -# define machine_is_gsncomm() (0) +# define machine_is_silverstone() (0) #endif
-#ifdef CONFIG_MACH_STRASBOURG_A2 +#ifdef CONFIG_MACH_MTT2440 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_STRASBOURG_A2 +# define machine_arch_type MACH_TYPE_MTT2440 # endif -# define machine_is_strasbourg_a2() (machine_arch_type == MACH_TYPE_STRASBOURG_A2) +# define machine_is_mtt2440() (machine_arch_type == MACH_TYPE_MTT2440) #else -# define machine_is_strasbourg_a2() (0) +# define machine_is_mtt2440() (0) #endif
-#ifdef CONFIG_MACH_MMM +#ifdef CONFIG_MACH_YNICDB # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MMM +# define machine_arch_type MACH_TYPE_YNICDB # endif -# define machine_is_mmm() (machine_arch_type == MACH_TYPE_MMM) +# define machine_is_ynicdb() (machine_arch_type == MACH_TYPE_YNICDB) #else -# define machine_is_mmm() (0) +# define machine_is_ynicdb() (0) #endif
-#ifdef CONFIG_MACH_DAVINCI_DM365_BV +#ifdef CONFIG_MACH_BCT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DAVINCI_DM365_BV +# define machine_arch_type MACH_TYPE_BCT # endif -# define machine_is_davinci_dm365_bv() (machine_arch_type == MACH_TYPE_DAVINCI_DM365_BV) +# define machine_is_bct() (machine_arch_type == MACH_TYPE_BCT) #else -# define machine_is_davinci_dm365_bv() (0) +# define machine_is_bct() (0) #endif
-#ifdef CONFIG_MACH_AG5EVM +#ifdef CONFIG_MACH_TUSCAN # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_AG5EVM +# define machine_arch_type MACH_TYPE_TUSCAN # endif -# define machine_is_ag5evm() (machine_arch_type == MACH_TYPE_AG5EVM) +# define machine_is_tuscan() (machine_arch_type == MACH_TYPE_TUSCAN) #else -# define machine_is_ag5evm() (0) +# define machine_is_tuscan() (0) #endif
-#ifdef CONFIG_MACH_SC575PLC +#ifdef CONFIG_MACH_XBT_SAM9G45 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SC575PLC +# define machine_arch_type MACH_TYPE_XBT_SAM9G45 # endif -# define machine_is_sc575plc() (machine_arch_type == MACH_TYPE_SC575PLC) +# define machine_is_xbt_sam9g45() (machine_arch_type == MACH_TYPE_XBT_SAM9G45) #else -# define machine_is_sc575plc() (0) +# define machine_is_xbt_sam9g45() (0) #endif
-#ifdef CONFIG_MACH_SC575IPC +#ifdef CONFIG_MACH_ENBW_CMC # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SC575IPC +# define machine_arch_type MACH_TYPE_ENBW_CMC # endif -# define machine_is_sc575hmi() (machine_arch_type == MACH_TYPE_SC575IPC) +# define machine_is_enbw_cmc() (machine_arch_type == MACH_TYPE_ENBW_CMC) #else -# define machine_is_sc575hmi() (0) +# define machine_is_enbw_cmc() (0) #endif
-#ifdef CONFIG_MACH_OMAP3_TDM3730 +#ifdef CONFIG_MACH_CH104MX257 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OMAP3_TDM3730 +# define machine_arch_type MACH_TYPE_CH104MX257 # endif -# define machine_is_omap3_tdm3730() (machine_arch_type == MACH_TYPE_OMAP3_TDM3730) +# define machine_is_ch104mx257() (machine_arch_type == MACH_TYPE_CH104MX257) #else -# define machine_is_omap3_tdm3730() (0) +# define machine_is_ch104mx257() (0) #endif
-#ifdef CONFIG_MACH_TOP9000_EVAL +#ifdef CONFIG_MACH_OPENPRI # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TOP9000_EVAL +# define machine_arch_type MACH_TYPE_OPENPRI # endif -# define machine_is_top9000_eval() (machine_arch_type == MACH_TYPE_TOP9000_EVAL) +# define machine_is_openpri() (machine_arch_type == MACH_TYPE_OPENPRI) #else -# define machine_is_top9000_eval() (0) +# define machine_is_openpri() (0) #endif
-#ifdef CONFIG_MACH_TOP9000_SU +#ifdef CONFIG_MACH_AM335XEVM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TOP9000_SU +# define machine_arch_type MACH_TYPE_AM335XEVM # endif -# define machine_is_top9000_su() (machine_arch_type == MACH_TYPE_TOP9000_SU) +# define machine_is_am335xevm() (machine_arch_type == MACH_TYPE_AM335XEVM) #else -# define machine_is_top9000_su() (0) +# define machine_is_am335xevm() (0) #endif
-#ifdef CONFIG_MACH_UTM300 +#ifdef CONFIG_MACH_PICODMB # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_UTM300 +# define machine_arch_type MACH_TYPE_PICODMB # endif -# define machine_is_utm300() (machine_arch_type == MACH_TYPE_UTM300) +# define machine_is_picodmb() (machine_arch_type == MACH_TYPE_PICODMB) #else -# define machine_is_utm300() (0) +# define machine_is_picodmb() (0) #endif
-#ifdef CONFIG_MACH_TSUNAGI +#ifdef CONFIG_MACH_WALUIGI # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TSUNAGI +# define machine_arch_type MACH_TYPE_WALUIGI # endif -# define machine_is_tsunagi() (machine_arch_type == MACH_TYPE_TSUNAGI) +# define machine_is_waluigi() (machine_arch_type == MACH_TYPE_WALUIGI) #else -# define machine_is_tsunagi() (0) +# define machine_is_waluigi() (0) #endif
-#ifdef CONFIG_MACH_TS75XX +#ifdef CONFIG_MACH_PUNICAG7 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TS75XX +# define machine_arch_type MACH_TYPE_PUNICAG7 # endif -# define machine_is_ts75xx() (machine_arch_type == MACH_TYPE_TS75XX) +# define machine_is_punicag7() (machine_arch_type == MACH_TYPE_PUNICAG7) #else -# define machine_is_ts75xx() (0) +# define machine_is_punicag7() (0) #endif
-#ifdef CONFIG_MACH_TS47XX +#ifdef CONFIG_MACH_IPAD_1G # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TS47XX +# define machine_arch_type MACH_TYPE_IPAD_1G # endif -# define machine_is_ts47xx() (machine_arch_type == MACH_TYPE_TS47XX) +# define machine_is_ipad_1g() (machine_arch_type == MACH_TYPE_IPAD_1G) #else -# define machine_is_ts47xx() (0) +# define machine_is_ipad_1g() (0) #endif
-#ifdef CONFIG_MACH_DA850_K5 +#ifdef CONFIG_MACH_APPLETV_2G # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DA850_K5 +# define machine_arch_type MACH_TYPE_APPLETV_2G # endif -# define machine_is_da850_k5() (machine_arch_type == MACH_TYPE_DA850_K5) +# define machine_is_appletv_2g() (machine_arch_type == MACH_TYPE_APPLETV_2G) #else -# define machine_is_da850_k5() (0) +# define machine_is_appletv_2g() (0) #endif
-#ifdef CONFIG_MACH_AX502 +#ifdef CONFIG_MACH_MACH_ECOG45 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_AX502 +# define machine_arch_type MACH_TYPE_MACH_ECOG45 # endif -# define machine_is_ax502() (machine_arch_type == MACH_TYPE_AX502) +# define machine_is_mach_ecog45() (machine_arch_type == MACH_TYPE_MACH_ECOG45) #else -# define machine_is_ax502() (0) +# define machine_is_mach_ecog45() (0) #endif
-#ifdef CONFIG_MACH_IGEP0032 +#ifdef CONFIG_MACH_AIT_CAM_ENC_4XX # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_IGEP0032 +# define machine_arch_type MACH_TYPE_AIT_CAM_ENC_4XX # endif -# define machine_is_igep0032() (machine_arch_type == MACH_TYPE_IGEP0032) +# define machine_is_ait_cam_enc_4xx() (machine_arch_type == MACH_TYPE_AIT_CAM_ENC_4XX) #else -# define machine_is_igep0032() (0) +# define machine_is_ait_cam_enc_4xx() (0) #endif
-#ifdef CONFIG_MACH_ANTERO +#ifdef CONFIG_MACH_RUNNYMEDE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ANTERO +# define machine_arch_type MACH_TYPE_RUNNYMEDE # endif -# define machine_is_antero() (machine_arch_type == MACH_TYPE_ANTERO) +# define machine_is_runnymede() (machine_arch_type == MACH_TYPE_RUNNYMEDE) #else -# define machine_is_antero() (0) +# define machine_is_runnymede() (0) #endif
-#ifdef CONFIG_MACH_SYNERGY +#ifdef CONFIG_MACH_PLAY # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SYNERGY +# define machine_arch_type MACH_TYPE_PLAY # endif -# define machine_is_synergy() (machine_arch_type == MACH_TYPE_SYNERGY) +# define machine_is_play() (machine_arch_type == MACH_TYPE_PLAY) #else -# define machine_is_synergy() (0) +# define machine_is_play() (0) #endif
-#ifdef CONFIG_MACH_ICS_IF_VOIP +#ifdef CONFIG_MACH_HW90260 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ICS_IF_VOIP +# define machine_arch_type MACH_TYPE_HW90260 # endif -# define machine_is_ics_if_voip() (machine_arch_type == MACH_TYPE_ICS_IF_VOIP) +# define machine_is_hw90260() (machine_arch_type == MACH_TYPE_HW90260) #else -# define machine_is_ics_if_voip() (0) +# define machine_is_hw90260() (0) #endif
-#ifdef CONFIG_MACH_WLF_CRAGG_6410 +#ifdef CONFIG_MACH_TAGH # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_WLF_CRAGG_6410 +# define machine_arch_type MACH_TYPE_TAGH # endif -# define machine_is_wlf_cragg_6410() (machine_arch_type == MACH_TYPE_WLF_CRAGG_6410) +# define machine_is_tagh() (machine_arch_type == MACH_TYPE_TAGH) #else -# define machine_is_wlf_cragg_6410() (0) +# define machine_is_tagh() (0) #endif
-#ifdef CONFIG_MACH_PUNICA +#ifdef CONFIG_MACH_FILBERT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PUNICA +# define machine_arch_type MACH_TYPE_FILBERT # endif -# define machine_is_punica() (machine_arch_type == MACH_TYPE_PUNICA) +# define machine_is_filbert() (machine_arch_type == MACH_TYPE_FILBERT) #else -# define machine_is_punica() (0) +# define machine_is_filbert() (0) #endif
-#ifdef CONFIG_MACH_TRIMSLICE +#ifdef CONFIG_MACH_GETINGE_NETCOMV3 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TRIMSLICE +# define machine_arch_type MACH_TYPE_GETINGE_NETCOMV3 # endif -# define machine_is_trimslice() (machine_arch_type == MACH_TYPE_TRIMSLICE) +# define machine_is_getinge_netcomv3() (machine_arch_type == MACH_TYPE_GETINGE_NETCOMV3) #else -# define machine_is_trimslice() (0) +# define machine_is_getinge_netcomv3() (0) #endif
-#ifdef CONFIG_MACH_MX27_WMULTRA +#ifdef CONFIG_MACH_CW20 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MX27_WMULTRA +# define machine_arch_type MACH_TYPE_CW20 # endif -# define machine_is_mx27_wmultra() (machine_arch_type == MACH_TYPE_MX27_WMULTRA) +# define machine_is_cw20() (machine_arch_type == MACH_TYPE_CW20) #else -# define machine_is_mx27_wmultra() (0) +# define machine_is_cw20() (0) #endif
-#ifdef CONFIG_MACH_MACKEREL +#ifdef CONFIG_MACH_CINEMA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MACKEREL +# define machine_arch_type MACH_TYPE_CINEMA # endif -# define machine_is_mackerel() (machine_arch_type == MACH_TYPE_MACKEREL) +# define machine_is_cinema() (machine_arch_type == MACH_TYPE_CINEMA) #else -# define machine_is_mackerel() (0) +# define machine_is_cinema() (0) #endif
-#ifdef CONFIG_MACH_FA9X27 +#ifdef CONFIG_MACH_CINEMA_TEA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_FA9X27 +# define machine_arch_type MACH_TYPE_CINEMA_TEA # endif -# define machine_is_fa9x27() (machine_arch_type == MACH_TYPE_FA9X27) +# define machine_is_cinema_tea() (machine_arch_type == MACH_TYPE_CINEMA_TEA) #else -# define machine_is_fa9x27() (0) +# define machine_is_cinema_tea() (0) #endif
-#ifdef CONFIG_MACH_NS2816TB +#ifdef CONFIG_MACH_CINEMA_COFFEE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NS2816TB +# define machine_arch_type MACH_TYPE_CINEMA_COFFEE # endif -# define machine_is_ns2816tb() (machine_arch_type == MACH_TYPE_NS2816TB) +# define machine_is_cinema_coffee() (machine_arch_type == MACH_TYPE_CINEMA_COFFEE) #else -# define machine_is_ns2816tb() (0) +# define machine_is_cinema_coffee() (0) #endif
-#ifdef CONFIG_MACH_NS2816_NTPAD +#ifdef CONFIG_MACH_CINEMA_JUICE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NS2816_NTPAD +# define machine_arch_type MACH_TYPE_CINEMA_JUICE # endif -# define machine_is_ns2816_ntpad() (machine_arch_type == MACH_TYPE_NS2816_NTPAD) +# define machine_is_cinema_juice() (machine_arch_type == MACH_TYPE_CINEMA_JUICE) #else -# define machine_is_ns2816_ntpad() (0) +# define machine_is_cinema_juice() (0) #endif
-#ifdef CONFIG_MACH_NS2816_NTNB +#ifdef CONFIG_MACH_MX53_MIRAGE2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NS2816_NTNB +# define machine_arch_type MACH_TYPE_MX53_MIRAGE2 # endif -# define machine_is_ns2816_ntnb() (machine_arch_type == MACH_TYPE_NS2816_NTNB) +# define machine_is_mx53_mirage2() (machine_arch_type == MACH_TYPE_MX53_MIRAGE2) #else -# define machine_is_ns2816_ntnb() (0) +# define machine_is_mx53_mirage2() (0) #endif
-#ifdef CONFIG_MACH_KAEN +#ifdef CONFIG_MACH_MX53_EFIKASB # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_KAEN +# define machine_arch_type MACH_TYPE_MX53_EFIKASB # endif -# define machine_is_kaen() (machine_arch_type == MACH_TYPE_KAEN) +# define machine_is_mx53_efikasb() (machine_arch_type == MACH_TYPE_MX53_EFIKASB) #else -# define machine_is_kaen() (0) +# define machine_is_mx53_efikasb() (0) #endif
-#ifdef CONFIG_MACH_NV1000 +#ifdef CONFIG_MACH_STM_B2000 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NV1000 +# define machine_arch_type MACH_TYPE_STM_B2000 # endif -# define machine_is_nv1000() (machine_arch_type == MACH_TYPE_NV1000) +# define machine_is_stm_b2000() (machine_arch_type == MACH_TYPE_STM_B2000) #else -# define machine_is_nv1000() (0) +# define machine_is_stm_b2000() (0) #endif
-#ifdef CONFIG_MACH_NUC950TS +#ifdef CONFIG_MACH_M28EVK # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NUC950TS +# define machine_arch_type MACH_TYPE_M28EVK # endif -# define machine_is_nuc950ts() (machine_arch_type == MACH_TYPE_NUC950TS) +# define machine_is_m28evk() (machine_arch_type == MACH_TYPE_M28EVK) #else -# define machine_is_nuc950ts() (0) +# define machine_is_m28evk() (0) #endif
-#ifdef CONFIG_MACH_NOKIA_RM680 +#ifdef CONFIG_MACH_PDA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NOKIA_RM680 +# define machine_arch_type MACH_TYPE_PDA # endif -# define machine_is_nokia_rm680() (machine_arch_type == MACH_TYPE_NOKIA_RM680) +# define machine_is_pda() (machine_arch_type == MACH_TYPE_PDA) #else -# define machine_is_nokia_rm680() (0) +# define machine_is_pda() (0) #endif
-#ifdef CONFIG_MACH_AST2200 +#ifdef CONFIG_MACH_MERAKI_MR58 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_AST2200 +# define machine_arch_type MACH_TYPE_MERAKI_MR58 # endif -# define machine_is_ast2200() (machine_arch_type == MACH_TYPE_AST2200) +# define machine_is_meraki_mr58() (machine_arch_type == MACH_TYPE_MERAKI_MR58) #else -# define machine_is_ast2200() (0) +# define machine_is_meraki_mr58() (0) #endif
-#ifdef CONFIG_MACH_LEAD +#ifdef CONFIG_MACH_KOTA2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_LEAD +# define machine_arch_type MACH_TYPE_KOTA2 # endif -# define machine_is_lead() (machine_arch_type == MACH_TYPE_LEAD) +# define machine_is_kota2() (machine_arch_type == MACH_TYPE_KOTA2) #else -# define machine_is_lead() (0) +# define machine_is_kota2() (0) #endif
-#ifdef CONFIG_MACH_UNINO1 +#ifdef CONFIG_MACH_LETCOOL # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_UNINO1 +# define machine_arch_type MACH_TYPE_LETCOOL # endif -# define machine_is_unino1() (machine_arch_type == MACH_TYPE_UNINO1) +# define machine_is_letcool() (machine_arch_type == MACH_TYPE_LETCOOL) #else -# define machine_is_unino1() (0) +# define machine_is_letcool() (0) #endif
-#ifdef CONFIG_MACH_GREECO +#ifdef CONFIG_MACH_MX27IAT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GREECO +# define machine_arch_type MACH_TYPE_MX27IAT # endif -# define machine_is_greeco() (machine_arch_type == MACH_TYPE_GREECO) +# define machine_is_mx27iat() (machine_arch_type == MACH_TYPE_MX27IAT) #else -# define machine_is_greeco() (0) +# define machine_is_mx27iat() (0) #endif
-#ifdef CONFIG_MACH_VERDI +#ifdef CONFIG_MACH_APOLLO_TD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VERDI +# define machine_arch_type MACH_TYPE_APOLLO_TD # endif -# define machine_is_verdi() (machine_arch_type == MACH_TYPE_VERDI) +# define machine_is_apollo_td() (machine_arch_type == MACH_TYPE_APOLLO_TD) #else -# define machine_is_verdi() (0) +# define machine_is_apollo_td() (0) #endif
-#ifdef CONFIG_MACH_DM6446_ADBOX +#ifdef CONFIG_MACH_ARENA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DM6446_ADBOX +# define machine_arch_type MACH_TYPE_ARENA # endif -# define machine_is_dm6446_adbox() (machine_arch_type == MACH_TYPE_DM6446_ADBOX) +# define machine_is_arena() (machine_arch_type == MACH_TYPE_ARENA) #else -# define machine_is_dm6446_adbox() (0) +# define machine_is_arena() (0) #endif
-#ifdef CONFIG_MACH_QUAD_SALSA +#ifdef CONFIG_MACH_GSNGATEWAY # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_QUAD_SALSA +# define machine_arch_type MACH_TYPE_GSNGATEWAY # endif -# define machine_is_quad_salsa() (machine_arch_type == MACH_TYPE_QUAD_SALSA) +# define machine_is_gsngateway() (machine_arch_type == MACH_TYPE_GSNGATEWAY) #else -# define machine_is_quad_salsa() (0) +# define machine_is_gsngateway() (0) #endif
-#ifdef CONFIG_MACH_ABB_GMA_1_1 +#ifdef CONFIG_MACH_LF2000 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ABB_GMA_1_1 +# define machine_arch_type MACH_TYPE_LF2000 # endif -# define machine_is_abb_gma_1_1() (machine_arch_type == MACH_TYPE_ABB_GMA_1_1) +# define machine_is_lf2000() (machine_arch_type == MACH_TYPE_LF2000) #else -# define machine_is_abb_gma_1_1() (0) +# define machine_is_lf2000() (0) #endif
-#ifdef CONFIG_MACH_SVCID +#ifdef CONFIG_MACH_BONITO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SVCID +# define machine_arch_type MACH_TYPE_BONITO # endif -# define machine_is_svcid() (machine_arch_type == MACH_TYPE_SVCID) +# define machine_is_bonito() (machine_arch_type == MACH_TYPE_BONITO) #else -# define machine_is_svcid() (0) +# define machine_is_bonito() (0) #endif
-#ifdef CONFIG_MACH_MSM8960_SIM +#ifdef CONFIG_MACH_ASYMPTOTE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MSM8960_SIM +# define machine_arch_type MACH_TYPE_ASYMPTOTE # endif -# define machine_is_msm8960_sim() (machine_arch_type == MACH_TYPE_MSM8960_SIM) +# define machine_is_asymptote() (machine_arch_type == MACH_TYPE_ASYMPTOTE) #else -# define machine_is_msm8960_sim() (0) +# define machine_is_asymptote() (0) #endif
-#ifdef CONFIG_MACH_MSM8960_RUMI3 +#ifdef CONFIG_MACH_BST2BRD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MSM8960_RUMI3 +# define machine_arch_type MACH_TYPE_BST2BRD # endif -# define machine_is_msm8960_rumi3() (machine_arch_type == MACH_TYPE_MSM8960_RUMI3) +# define machine_is_bst2brd() (machine_arch_type == MACH_TYPE_BST2BRD) #else -# define machine_is_msm8960_rumi3() (0) +# define machine_is_bst2brd() (0) #endif
-#ifdef CONFIG_MACH_ICON_G +#ifdef CONFIG_MACH_TX335S # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ICON_G +# define machine_arch_type MACH_TYPE_TX335S # endif -# define machine_is_icon_g() (machine_arch_type == MACH_TYPE_ICON_G) +# define machine_is_tx335s() (machine_arch_type == MACH_TYPE_TX335S) #else -# define machine_is_icon_g() (0) +# define machine_is_tx335s() (0) #endif
-#ifdef CONFIG_MACH_MB3 +#ifdef CONFIG_MACH_PELCO_TESLA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MB3 +# define machine_arch_type MACH_TYPE_PELCO_TESLA # endif -# define machine_is_mb3() (machine_arch_type == MACH_TYPE_MB3) +# define machine_is_pelco_tesla() (machine_arch_type == MACH_TYPE_PELCO_TESLA) #else -# define machine_is_mb3() (0) +# define machine_is_pelco_tesla() (0) #endif
-#ifdef CONFIG_MACH_GSIA18S +#ifdef CONFIG_MACH_RRHTESTPLAT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GSIA18S +# define machine_arch_type MACH_TYPE_RRHTESTPLAT # endif -# define machine_is_gsia18s() (machine_arch_type == MACH_TYPE_GSIA18S) +# define machine_is_rrhtestplat() (machine_arch_type == MACH_TYPE_RRHTESTPLAT) #else -# define machine_is_gsia18s() (0) +# define machine_is_rrhtestplat() (0) #endif
-#ifdef CONFIG_MACH_PIVICC +#ifdef CONFIG_MACH_VIDTONIC_PRO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PIVICC +# define machine_arch_type MACH_TYPE_VIDTONIC_PRO # endif -# define machine_is_pivicc() (machine_arch_type == MACH_TYPE_PIVICC) +# define machine_is_vidtonic_pro() (machine_arch_type == MACH_TYPE_VIDTONIC_PRO) #else -# define machine_is_pivicc() (0) +# define machine_is_vidtonic_pro() (0) #endif
-#ifdef CONFIG_MACH_PCM048 +#ifdef CONFIG_MACH_PL_APOLLO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PCM048 +# define machine_arch_type MACH_TYPE_PL_APOLLO # endif -# define machine_is_pcm048() (machine_arch_type == MACH_TYPE_PCM048) +# define machine_is_pl_apollo() (machine_arch_type == MACH_TYPE_PL_APOLLO) #else -# define machine_is_pcm048() (0) +# define machine_is_pl_apollo() (0) #endif
-#ifdef CONFIG_MACH_DDS +#ifdef CONFIG_MACH_PL_PHOENIX # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DDS +# define machine_arch_type MACH_TYPE_PL_PHOENIX # endif -# define machine_is_dds() (machine_arch_type == MACH_TYPE_DDS) +# define machine_is_pl_phoenix() (machine_arch_type == MACH_TYPE_PL_PHOENIX) #else -# define machine_is_dds() (0) +# define machine_is_pl_phoenix() (0) #endif
-#ifdef CONFIG_MACH_CHALTEN_XA1 +#ifdef CONFIG_MACH_M28CU3 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CHALTEN_XA1 +# define machine_arch_type MACH_TYPE_M28CU3 # endif -# define machine_is_chalten_xa1() (machine_arch_type == MACH_TYPE_CHALTEN_XA1) +# define machine_is_m28cu3() (machine_arch_type == MACH_TYPE_M28CU3) #else -# define machine_is_chalten_xa1() (0) +# define machine_is_m28cu3() (0) #endif
-#ifdef CONFIG_MACH_TS48XX +#ifdef CONFIG_MACH_VVBOX_HD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TS48XX +# define machine_arch_type MACH_TYPE_VVBOX_HD # endif -# define machine_is_ts48xx() (machine_arch_type == MACH_TYPE_TS48XX) +# define machine_is_vvbox_hd() (machine_arch_type == MACH_TYPE_VVBOX_HD) #else -# define machine_is_ts48xx() (0) +# define machine_is_vvbox_hd() (0) #endif
-#ifdef CONFIG_MACH_TONGA2_TFTTIMER +#ifdef CONFIG_MACH_COREWARE_SAM9260_ # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TONGA2_TFTTIMER +# define machine_arch_type MACH_TYPE_COREWARE_SAM9260_ # endif -# define machine_is_tonga2_tfttimer() (machine_arch_type == MACH_TYPE_TONGA2_TFTTIMER) +# define machine_is_coreware_sam9260_() (machine_arch_type == MACH_TYPE_COREWARE_SAM9260_) #else -# define machine_is_tonga2_tfttimer() (0) +# define machine_is_coreware_sam9260_() (0) #endif
-#ifdef CONFIG_MACH_WHISTLER +#ifdef CONFIG_MACH_MARMADUKE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_WHISTLER +# define machine_arch_type MACH_TYPE_MARMADUKE # endif -# define machine_is_whistler() (machine_arch_type == MACH_TYPE_WHISTLER) +# define machine_is_marmaduke() (machine_arch_type == MACH_TYPE_MARMADUKE) #else -# define machine_is_whistler() (0) +# define machine_is_marmaduke() (0) #endif
-#ifdef CONFIG_MACH_ASL_PHOENIX +#ifdef CONFIG_MACH_AMG_XLCORE_CAMERA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ASL_PHOENIX +# define machine_arch_type MACH_TYPE_AMG_XLCORE_CAMERA # endif -# define machine_is_asl_phoenix() (machine_arch_type == MACH_TYPE_ASL_PHOENIX) +# define machine_is_amg_xlcore_camera() (machine_arch_type == MACH_TYPE_AMG_XLCORE_CAMERA) #else -# define machine_is_asl_phoenix() (0) +# define machine_is_amg_xlcore_camera() (0) #endif
-#ifdef CONFIG_MACH_AT91SAM9263OTLITE +#ifdef CONFIG_MACH_OMAP3_EGF # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_AT91SAM9263OTLITE +# define machine_arch_type MACH_TYPE_OMAP3_EGF # endif -# define machine_is_at91sam9263otlite() (machine_arch_type == MACH_TYPE_AT91SAM9263OTLITE) +# define machine_is_omap3_egf() (machine_arch_type == MACH_TYPE_OMAP3_EGF) #else -# define machine_is_at91sam9263otlite() (0) +# define machine_is_omap3_egf() (0) #endif
-#ifdef CONFIG_MACH_DDPLUG +#ifdef CONFIG_MACH_SMDK4212 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DDPLUG +# define machine_arch_type MACH_TYPE_SMDK4212 # endif -# define machine_is_ddplug() (machine_arch_type == MACH_TYPE_DDPLUG) +# define machine_is_smdk4212() (machine_arch_type == MACH_TYPE_SMDK4212) #else -# define machine_is_ddplug() (0) +# define machine_is_smdk4212() (0) #endif
-#ifdef CONFIG_MACH_D2PLUG +#ifdef CONFIG_MACH_DNP9200 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_D2PLUG +# define machine_arch_type MACH_TYPE_DNP9200 # endif -# define machine_is_d2plug() (machine_arch_type == MACH_TYPE_D2PLUG) +# define machine_is_dnp9200() (machine_arch_type == MACH_TYPE_DNP9200) #else -# define machine_is_d2plug() (0) +# define machine_is_dnp9200() (0) #endif
-#ifdef CONFIG_MACH_KZM9D +#ifdef CONFIG_MACH_TF101 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_KZM9D +# define machine_arch_type MACH_TYPE_TF101 # endif -# define machine_is_kzm9d() (machine_arch_type == MACH_TYPE_KZM9D) +# define machine_is_tf101() (machine_arch_type == MACH_TYPE_TF101) #else -# define machine_is_kzm9d() (0) +# define machine_is_tf101() (0) #endif
-#ifdef CONFIG_MACH_VERDI_LTE +#ifdef CONFIG_MACH_OMAP3SILVIO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VERDI_LTE +# define machine_arch_type MACH_TYPE_OMAP3SILVIO # endif -# define machine_is_verdi_lte() (machine_arch_type == MACH_TYPE_VERDI_LTE) +# define machine_is_omap3silvio() (machine_arch_type == MACH_TYPE_OMAP3SILVIO) #else -# define machine_is_verdi_lte() (0) +# define machine_is_omap3silvio() (0) #endif
-#ifdef CONFIG_MACH_NANOZOOM +#ifdef CONFIG_MACH_PICASSO2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NANOZOOM +# define machine_arch_type MACH_TYPE_PICASSO2 # endif -# define machine_is_nanozoom() (machine_arch_type == MACH_TYPE_NANOZOOM) +# define machine_is_picasso2() (machine_arch_type == MACH_TYPE_PICASSO2) #else -# define machine_is_nanozoom() (0) +# define machine_is_picasso2() (0) #endif
-#ifdef CONFIG_MACH_DM3730_SOM_LV +#ifdef CONFIG_MACH_VANGOGH2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DM3730_SOM_LV +# define machine_arch_type MACH_TYPE_VANGOGH2 # endif -# define machine_is_dm3730_som_lv() (machine_arch_type == MACH_TYPE_DM3730_SOM_LV) +# define machine_is_vangogh2() (machine_arch_type == MACH_TYPE_VANGOGH2) #else -# define machine_is_dm3730_som_lv() (0) +# define machine_is_vangogh2() (0) #endif
-#ifdef CONFIG_MACH_DM3730_TORPEDO +#ifdef CONFIG_MACH_OLPC_XO_1_75 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DM3730_TORPEDO +# define machine_arch_type MACH_TYPE_OLPC_XO_1_75 # endif -# define machine_is_dm3730_torpedo() (machine_arch_type == MACH_TYPE_DM3730_TORPEDO) +# define machine_is_olpc_xo_1_75() (machine_arch_type == MACH_TYPE_OLPC_XO_1_75) #else -# define machine_is_dm3730_torpedo() (0) +# define machine_is_olpc_xo_1_75() (0) #endif
-#ifdef CONFIG_MACH_ANCHOVY +#ifdef CONFIG_MACH_GX400 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ANCHOVY +# define machine_arch_type MACH_TYPE_GX400 # endif -# define machine_is_anchovy() (machine_arch_type == MACH_TYPE_ANCHOVY) +# define machine_is_gx400() (machine_arch_type == MACH_TYPE_GX400) #else -# define machine_is_anchovy() (0) +# define machine_is_gx400() (0) #endif
-#ifdef CONFIG_MACH_RE2REV20 +#ifdef CONFIG_MACH_GS300 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_RE2REV20 +# define machine_arch_type MACH_TYPE_GS300 # endif -# define machine_is_re2rev20() (machine_arch_type == MACH_TYPE_RE2REV20) +# define machine_is_gs300() (machine_arch_type == MACH_TYPE_GS300) #else -# define machine_is_re2rev20() (0) +# define machine_is_gs300() (0) #endif
-#ifdef CONFIG_MACH_RE2REV21 +#ifdef CONFIG_MACH_ACER_A9 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_RE2REV21 +# define machine_arch_type MACH_TYPE_ACER_A9 # endif -# define machine_is_re2rev21() (machine_arch_type == MACH_TYPE_RE2REV21) +# define machine_is_acer_a9() (machine_arch_type == MACH_TYPE_ACER_A9) #else -# define machine_is_re2rev21() (0) +# define machine_is_acer_a9() (0) #endif
-#ifdef CONFIG_MACH_CNS21XX +#ifdef CONFIG_MACH_VIVOW_EVM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CNS21XX +# define machine_arch_type MACH_TYPE_VIVOW_EVM # endif -# define machine_is_cns21xx() (machine_arch_type == MACH_TYPE_CNS21XX) +# define machine_is_vivow_evm() (machine_arch_type == MACH_TYPE_VIVOW_EVM) #else -# define machine_is_cns21xx() (0) +# define machine_is_vivow_evm() (0) #endif
-#ifdef CONFIG_MACH_RIDER +#ifdef CONFIG_MACH_VELOCE_CXQ # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_RIDER +# define machine_arch_type MACH_TYPE_VELOCE_CXQ # endif -# define machine_is_rider() (machine_arch_type == MACH_TYPE_RIDER) +# define machine_is_veloce_cxq() (machine_arch_type == MACH_TYPE_VELOCE_CXQ) #else -# define machine_is_rider() (0) +# define machine_is_veloce_cxq() (0) #endif
-#ifdef CONFIG_MACH_NSK330 +#ifdef CONFIG_MACH_VELOCE_CXM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NSK330 +# define machine_arch_type MACH_TYPE_VELOCE_CXM # endif -# define machine_is_nsk330() (machine_arch_type == MACH_TYPE_NSK330) +# define machine_is_veloce_cxm() (machine_arch_type == MACH_TYPE_VELOCE_CXM) #else -# define machine_is_nsk330() (0) +# define machine_is_veloce_cxm() (0) #endif
-#ifdef CONFIG_MACH_CNS2133EVB +#ifdef CONFIG_MACH_P1852 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CNS2133EVB +# define machine_arch_type MACH_TYPE_P1852 # endif -# define machine_is_cns2133evb() (machine_arch_type == MACH_TYPE_CNS2133EVB) +# define machine_is_p1852() (machine_arch_type == MACH_TYPE_P1852) #else -# define machine_is_cns2133evb() (0) +# define machine_is_p1852() (0) #endif
-#ifdef CONFIG_MACH_Z3_816X_MOD +#ifdef CONFIG_MACH_NAXY100 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_Z3_816X_MOD +# define machine_arch_type MACH_TYPE_NAXY100 # endif -# define machine_is_z3_816x_mod() (machine_arch_type == MACH_TYPE_Z3_816X_MOD) +# define machine_is_naxy100() (machine_arch_type == MACH_TYPE_NAXY100) #else -# define machine_is_z3_816x_mod() (0) +# define machine_is_naxy100() (0) #endif
-#ifdef CONFIG_MACH_Z3_814X_MOD +#ifdef CONFIG_MACH_TAISHAN # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_Z3_814X_MOD +# define machine_arch_type MACH_TYPE_TAISHAN # endif -# define machine_is_z3_814x_mod() (machine_arch_type == MACH_TYPE_Z3_814X_MOD) +# define machine_is_taishan() (machine_arch_type == MACH_TYPE_TAISHAN) #else -# define machine_is_z3_814x_mod() (0) +# define machine_is_taishan() (0) #endif
-#ifdef CONFIG_MACH_BEECT +#ifdef CONFIG_MACH_TOUCHLINK # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BEECT +# define machine_arch_type MACH_TYPE_TOUCHLINK # endif -# define machine_is_beect() (machine_arch_type == MACH_TYPE_BEECT) +# define machine_is_touchlink() (machine_arch_type == MACH_TYPE_TOUCHLINK) #else -# define machine_is_beect() (0) +# define machine_is_touchlink() (0) #endif
-#ifdef CONFIG_MACH_DMA_THUNDERBUG +#ifdef CONFIG_MACH_STM32F103ZE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DMA_THUNDERBUG +# define machine_arch_type MACH_TYPE_STM32F103ZE # endif -# define machine_is_dma_thunderbug() (machine_arch_type == MACH_TYPE_DMA_THUNDERBUG) +# define machine_is_stm32f103ze() (machine_arch_type == MACH_TYPE_STM32F103ZE) #else -# define machine_is_dma_thunderbug() (0) +# define machine_is_stm32f103ze() (0) #endif
-#ifdef CONFIG_MACH_OMN_AT91SAM9G20 +#ifdef CONFIG_MACH_MCX # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OMN_AT91SAM9G20 +# define machine_arch_type MACH_TYPE_MCX # endif -# define machine_is_omn_at91sam9g20() (machine_arch_type == MACH_TYPE_OMN_AT91SAM9G20) +# define machine_is_mcx() (machine_arch_type == MACH_TYPE_MCX) #else -# define machine_is_omn_at91sam9g20() (0) +# define machine_is_mcx() (0) #endif
-#ifdef CONFIG_MACH_MX25_E2S_UC +#ifdef CONFIG_MACH_STM_NMHDK_FLI7610 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MX25_E2S_UC +# define machine_arch_type MACH_TYPE_STM_NMHDK_FLI7610 # endif -# define machine_is_mx25_e2s_uc() (machine_arch_type == MACH_TYPE_MX25_E2S_UC) +# define machine_is_stm_nmhdk_fli7610() (machine_arch_type == MACH_TYPE_STM_NMHDK_FLI7610) #else -# define machine_is_mx25_e2s_uc() (0) +# define machine_is_stm_nmhdk_fli7610() (0) #endif
-#ifdef CONFIG_MACH_MIONE +#ifdef CONFIG_MACH_TOP28X # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MIONE +# define machine_arch_type MACH_TYPE_TOP28X # endif -# define machine_is_mione() (machine_arch_type == MACH_TYPE_MIONE) +# define machine_is_top28x() (machine_arch_type == MACH_TYPE_TOP28X) #else -# define machine_is_mione() (0) +# define machine_is_top28x() (0) #endif
-#ifdef CONFIG_MACH_TOP9000_TCU +#ifdef CONFIG_MACH_OKL4VP_MICROVISOR # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TOP9000_TCU +# define machine_arch_type MACH_TYPE_OKL4VP_MICROVISOR # endif -# define machine_is_top9000_tcu() (machine_arch_type == MACH_TYPE_TOP9000_TCU) +# define machine_is_okl4vp_microvisor() (machine_arch_type == MACH_TYPE_OKL4VP_MICROVISOR) #else -# define machine_is_top9000_tcu() (0) +# define machine_is_okl4vp_microvisor() (0) #endif
-#ifdef CONFIG_MACH_TOP9000_BSL +#ifdef CONFIG_MACH_POP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TOP9000_BSL +# define machine_arch_type MACH_TYPE_POP # endif -# define machine_is_top9000_bsl() (machine_arch_type == MACH_TYPE_TOP9000_BSL) +# define machine_is_pop() (machine_arch_type == MACH_TYPE_POP) #else -# define machine_is_top9000_bsl() (0) +# define machine_is_pop() (0) #endif
-#ifdef CONFIG_MACH_KINGDOM +#ifdef CONFIG_MACH_LAYER # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_KINGDOM +# define machine_arch_type MACH_TYPE_LAYER # endif -# define machine_is_kingdom() (machine_arch_type == MACH_TYPE_KINGDOM) +# define machine_is_layer() (machine_arch_type == MACH_TYPE_LAYER) #else -# define machine_is_kingdom() (0) +# define machine_is_layer() (0) #endif
-#ifdef CONFIG_MACH_ARMADILLO460 +#ifdef CONFIG_MACH_TRONDHEIM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ARMADILLO460 +# define machine_arch_type MACH_TYPE_TRONDHEIM # endif -# define machine_is_armadillo460() (machine_arch_type == MACH_TYPE_ARMADILLO460) +# define machine_is_trondheim() (machine_arch_type == MACH_TYPE_TRONDHEIM) #else -# define machine_is_armadillo460() (0) +# define machine_is_trondheim() (0) #endif
-#ifdef CONFIG_MACH_LQ2 +#ifdef CONFIG_MACH_EVA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_LQ2 +# define machine_arch_type MACH_TYPE_EVA # endif -# define machine_is_lq2() (machine_arch_type == MACH_TYPE_LQ2) +# define machine_is_eva() (machine_arch_type == MACH_TYPE_EVA) #else -# define machine_is_lq2() (0) +# define machine_is_eva() (0) #endif
-#ifdef CONFIG_MACH_SWEDA_TMS2 +#ifdef CONFIG_MACH_TRUST_TAURUS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SWEDA_TMS2 +# define machine_arch_type MACH_TYPE_TRUST_TAURUS # endif -# define machine_is_sweda_tms2() (machine_arch_type == MACH_TYPE_SWEDA_TMS2) +# define machine_is_trust_taurus() (machine_arch_type == MACH_TYPE_TRUST_TAURUS) #else -# define machine_is_sweda_tms2() (0) +# define machine_is_trust_taurus() (0) #endif
-#ifdef CONFIG_MACH_MX53_LOCO +#ifdef CONFIG_MACH_NS2816_HUASHAN # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MX53_LOCO +# define machine_arch_type MACH_TYPE_NS2816_HUASHAN # endif -# define machine_is_mx53_loco() (machine_arch_type == MACH_TYPE_MX53_LOCO) +# define machine_is_ns2816_huashan() (machine_arch_type == MACH_TYPE_NS2816_HUASHAN) #else -# define machine_is_mx53_loco() (0) +# define machine_is_ns2816_huashan() (0) #endif
-#ifdef CONFIG_MACH_ACER_A8 +#ifdef CONFIG_MACH_NS2816_YANGCHENG # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ACER_A8 +# define machine_arch_type MACH_TYPE_NS2816_YANGCHENG # endif -# define machine_is_acer_a8() (machine_arch_type == MACH_TYPE_ACER_A8) +# define machine_is_ns2816_yangcheng() (machine_arch_type == MACH_TYPE_NS2816_YANGCHENG) #else -# define machine_is_acer_a8() (0) +# define machine_is_ns2816_yangcheng() (0) #endif
-#ifdef CONFIG_MACH_ACER_GAUGUIN +#ifdef CONFIG_MACH_P852 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ACER_GAUGUIN +# define machine_arch_type MACH_TYPE_P852 # endif -# define machine_is_acer_gauguin() (machine_arch_type == MACH_TYPE_ACER_GAUGUIN) +# define machine_is_p852() (machine_arch_type == MACH_TYPE_P852) #else -# define machine_is_acer_gauguin() (0) +# define machine_is_p852() (0) #endif
-#ifdef CONFIG_MACH_GUPPY +#ifdef CONFIG_MACH_FLEA3 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GUPPY +# define machine_arch_type MACH_TYPE_FLEA3 # endif -# define machine_is_guppy() (machine_arch_type == MACH_TYPE_GUPPY) +# define machine_is_flea3() (machine_arch_type == MACH_TYPE_FLEA3) #else -# define machine_is_guppy() (0) +# define machine_is_flea3() (0) #endif
-#ifdef CONFIG_MACH_MX61_ARD +#ifdef CONFIG_MACH_BOWFIN # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MX61_ARD +# define machine_arch_type MACH_TYPE_BOWFIN # endif -# define machine_is_mx61_ard() (machine_arch_type == MACH_TYPE_MX61_ARD) +# define machine_is_bowfin() (machine_arch_type == MACH_TYPE_BOWFIN) #else -# define machine_is_mx61_ard() (0) +# define machine_is_bowfin() (0) #endif
-#ifdef CONFIG_MACH_TX53 +#ifdef CONFIG_MACH_MV88DE3100 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TX53 +# define machine_arch_type MACH_TYPE_MV88DE3100 # endif -# define machine_is_tx53() (machine_arch_type == MACH_TYPE_TX53) +# define machine_is_mv88de3100() (machine_arch_type == MACH_TYPE_MV88DE3100) #else -# define machine_is_tx53() (0) +# define machine_is_mv88de3100() (0) #endif
-#ifdef CONFIG_MACH_OMAPL138_CASE_A3 +#ifdef CONFIG_MACH_PIA_AM35X # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OMAPL138_CASE_A3 +# define machine_arch_type MACH_TYPE_PIA_AM35X # endif -# define machine_is_omapl138_case_a3() (machine_arch_type == MACH_TYPE_OMAPL138_CASE_A3) +# define machine_is_pia_am35x() (machine_arch_type == MACH_TYPE_PIA_AM35X) #else -# define machine_is_omapl138_case_a3() (0) +# define machine_is_pia_am35x() (0) #endif
-#ifdef CONFIG_MACH_UEMD +#ifdef CONFIG_MACH_CEDAR # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_UEMD +# define machine_arch_type MACH_TYPE_CEDAR # endif -# define machine_is_uemd() (machine_arch_type == MACH_TYPE_UEMD) +# define machine_is_cedar() (machine_arch_type == MACH_TYPE_CEDAR) #else -# define machine_is_uemd() (0) +# define machine_is_cedar() (0) #endif
-#ifdef CONFIG_MACH_CCWMX51MUT +#ifdef CONFIG_MACH_PICASSO_E # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CCWMX51MUT +# define machine_arch_type MACH_TYPE_PICASSO_E # endif -# define machine_is_ccwmx51mut() (machine_arch_type == MACH_TYPE_CCWMX51MUT) +# define machine_is_picasso_e() (machine_arch_type == MACH_TYPE_PICASSO_E) #else -# define machine_is_ccwmx51mut() (0) +# define machine_is_picasso_e() (0) #endif
-#ifdef CONFIG_MACH_ROCKHOPPER +#ifdef CONFIG_MACH_SAMSUNG_E60 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ROCKHOPPER +# define machine_arch_type MACH_TYPE_SAMSUNG_E60 # endif -# define machine_is_rockhopper() (machine_arch_type == MACH_TYPE_ROCKHOPPER) +# define machine_is_samsung_e60() (machine_arch_type == MACH_TYPE_SAMSUNG_E60) #else -# define machine_is_rockhopper() (0) +# define machine_is_samsung_e60() (0) #endif
-#ifdef CONFIG_MACH_ENCORE +#ifdef CONFIG_MACH_SDVR_MINI # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ENCORE +# define machine_arch_type MACH_TYPE_SDVR_MINI # endif -# define machine_is_encore() (machine_arch_type == MACH_TYPE_ENCORE) +# define machine_is_sdvr_mini() (machine_arch_type == MACH_TYPE_SDVR_MINI) #else -# define machine_is_encore() (0) +# define machine_is_sdvr_mini() (0) #endif
-#ifdef CONFIG_MACH_HKDKC100 +#ifdef CONFIG_MACH_OMAP3_IJ3K # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HKDKC100 +# define machine_arch_type MACH_TYPE_OMAP3_IJ3K # endif -# define machine_is_hkdkc100() (machine_arch_type == MACH_TYPE_HKDKC100) +# define machine_is_omap3_ij3k() (machine_arch_type == MACH_TYPE_OMAP3_IJ3K) #else -# define machine_is_hkdkc100() (0) +# define machine_is_omap3_ij3k() (0) #endif
-#ifdef CONFIG_MACH_TS42XX +#ifdef CONFIG_MACH_MODASMC1 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TS42XX +# define machine_arch_type MACH_TYPE_MODASMC1 # endif -# define machine_is_ts42xx() (machine_arch_type == MACH_TYPE_TS42XX) +# define machine_is_modasmc1() (machine_arch_type == MACH_TYPE_MODASMC1) #else -# define machine_is_ts42xx() (0) +# define machine_is_modasmc1() (0) #endif
-#ifdef CONFIG_MACH_AEBL +#ifdef CONFIG_MACH_APQ8064_RUMI3 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_AEBL +# define machine_arch_type MACH_TYPE_APQ8064_RUMI3 # endif -# define machine_is_aebl() (machine_arch_type == MACH_TYPE_AEBL) +# define machine_is_apq8064_rumi3() (machine_arch_type == MACH_TYPE_APQ8064_RUMI3) #else -# define machine_is_aebl() (0) +# define machine_is_apq8064_rumi3() (0) #endif
-#ifdef CONFIG_MACH_WARIO +#ifdef CONFIG_MACH_MATRIX506 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_WARIO +# define machine_arch_type MACH_TYPE_MATRIX506 # endif -# define machine_is_wario() (machine_arch_type == MACH_TYPE_WARIO) +# define machine_is_matrix506() (machine_arch_type == MACH_TYPE_MATRIX506) #else -# define machine_is_wario() (0) +# define machine_is_matrix506() (0) #endif
-#ifdef CONFIG_MACH_GFS_SPM +#ifdef CONFIG_MACH_MSM9615_MTP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GFS_SPM +# define machine_arch_type MACH_TYPE_MSM9615_MTP # endif -# define machine_is_gfs_spm() (machine_arch_type == MACH_TYPE_GFS_SPM) +# define machine_is_msm9615_mtp() (machine_arch_type == MACH_TYPE_MSM9615_MTP) #else -# define machine_is_gfs_spm() (0) +# define machine_is_msm9615_mtp() (0) #endif
-#ifdef CONFIG_MACH_CM_T3730 +#ifdef CONFIG_MACH_DM36X_SPAWNDC # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CM_T3730 +# define machine_arch_type MACH_TYPE_DM36X_SPAWNDC # endif -# define machine_is_cm_t3730() (machine_arch_type == MACH_TYPE_CM_T3730) +# define machine_is_dm36x_spawndc() (machine_arch_type == MACH_TYPE_DM36X_SPAWNDC) #else -# define machine_is_cm_t3730() (0) +# define machine_is_dm36x_spawndc() (0) #endif
-#ifdef CONFIG_MACH_ISC3 +#ifdef CONFIG_MACH_SFF792 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ISC3 +# define machine_arch_type MACH_TYPE_SFF792 # endif -# define machine_is_isc3() (machine_arch_type == MACH_TYPE_ISC3) +# define machine_is_sff792() (machine_arch_type == MACH_TYPE_SFF792) #else -# define machine_is_isc3() (0) +# define machine_is_sff792() (0) #endif
-#ifdef CONFIG_MACH_RASCAL +#ifdef CONFIG_MACH_AM335XIAEVM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_RASCAL +# define machine_arch_type MACH_TYPE_AM335XIAEVM # endif -# define machine_is_rascal() (machine_arch_type == MACH_TYPE_RASCAL) +# define machine_is_am335xiaevm() (machine_arch_type == MACH_TYPE_AM335XIAEVM) #else -# define machine_is_rascal() (0) +# define machine_is_am335xiaevm() (0) #endif
-#ifdef CONFIG_MACH_HREFV60 +#ifdef CONFIG_MACH_G3C2440 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HREFV60 +# define machine_arch_type MACH_TYPE_G3C2440 # endif -# define machine_is_hrefv60() (machine_arch_type == MACH_TYPE_HREFV60) +# define machine_is_g3c2440() (machine_arch_type == MACH_TYPE_G3C2440) #else -# define machine_is_hrefv60() (0) +# define machine_is_g3c2440() (0) #endif
-#ifdef CONFIG_MACH_TPT_2_0 +#ifdef CONFIG_MACH_TION270 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TPT_2_0 +# define machine_arch_type MACH_TYPE_TION270 # endif -# define machine_is_tpt_2_0() (machine_arch_type == MACH_TYPE_TPT_2_0) +# define machine_is_tion270() (machine_arch_type == MACH_TYPE_TION270) #else -# define machine_is_tpt_2_0() (0) +# define machine_is_tion270() (0) #endif
-#ifdef CONFIG_MACH_SPLENDOR +#ifdef CONFIG_MACH_W22Q7ARM02 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SPLENDOR +# define machine_arch_type MACH_TYPE_W22Q7ARM02 # endif -# define machine_is_splendor() (machine_arch_type == MACH_TYPE_SPLENDOR) +# define machine_is_w22q7arm02() (machine_arch_type == MACH_TYPE_W22Q7ARM02) #else -# define machine_is_splendor() (0) +# define machine_is_w22q7arm02() (0) #endif
-#ifdef CONFIG_MACH_MSM8X60_QT +#ifdef CONFIG_MACH_OMAP_CAT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MSM8X60_QT +# define machine_arch_type MACH_TYPE_OMAP_CAT # endif -# define machine_is_msm8x60_qt() (machine_arch_type == MACH_TYPE_MSM8X60_QT) +# define machine_is_omap_cat() (machine_arch_type == MACH_TYPE_OMAP_CAT) #else -# define machine_is_msm8x60_qt() (0) +# define machine_is_omap_cat() (0) #endif
-#ifdef CONFIG_MACH_HTC_HD_MINI +#ifdef CONFIG_MACH_AT91SAM9N12EK # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HTC_HD_MINI +# define machine_arch_type MACH_TYPE_AT91SAM9N12EK # endif -# define machine_is_htc_hd_mini() (machine_arch_type == MACH_TYPE_HTC_HD_MINI) +# define machine_is_at91sam9n12ek() (machine_arch_type == MACH_TYPE_AT91SAM9N12EK) #else -# define machine_is_htc_hd_mini() (0) +# define machine_is_at91sam9n12ek() (0) #endif
-#ifdef CONFIG_MACH_ATHENE +#ifdef CONFIG_MACH_MORRISON # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ATHENE +# define machine_arch_type MACH_TYPE_MORRISON # endif -# define machine_is_athene() (machine_arch_type == MACH_TYPE_ATHENE) +# define machine_is_morrison() (machine_arch_type == MACH_TYPE_MORRISON) #else -# define machine_is_athene() (0) +# define machine_is_morrison() (0) #endif
-#ifdef CONFIG_MACH_DEEP_R_EK_1 +#ifdef CONFIG_MACH_SVDU # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DEEP_R_EK_1 +# define machine_arch_type MACH_TYPE_SVDU # endif -# define machine_is_deep_r_ek_1() (machine_arch_type == MACH_TYPE_DEEP_R_EK_1) +# define machine_is_svdu() (machine_arch_type == MACH_TYPE_SVDU) #else -# define machine_is_deep_r_ek_1() (0) +# define machine_is_svdu() (0) #endif
-#ifdef CONFIG_MACH_VIVOW_CT +#ifdef CONFIG_MACH_LPP01 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VIVOW_CT +# define machine_arch_type MACH_TYPE_LPP01 # endif -# define machine_is_vivow_ct() (machine_arch_type == MACH_TYPE_VIVOW_CT) +# define machine_is_lpp01() (machine_arch_type == MACH_TYPE_LPP01) #else -# define machine_is_vivow_ct() (0) +# define machine_is_lpp01() (0) #endif
-#ifdef CONFIG_MACH_NERY_1000 +#ifdef CONFIG_MACH_UBC283 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NERY_1000 +# define machine_arch_type MACH_TYPE_UBC283 # endif -# define machine_is_nery_1000() (machine_arch_type == MACH_TYPE_NERY_1000) +# define machine_is_ubc283() (machine_arch_type == MACH_TYPE_UBC283) #else -# define machine_is_nery_1000() (0) +# define machine_is_ubc283() (0) #endif
-#ifdef CONFIG_MACH_RFL109145_SSRV +#ifdef CONFIG_MACH_ZEPPELIN # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_RFL109145_SSRV +# define machine_arch_type MACH_TYPE_ZEPPELIN # endif -# define machine_is_rfl109145_ssrv() (machine_arch_type == MACH_TYPE_RFL109145_SSRV) +# define machine_is_zeppelin() (machine_arch_type == MACH_TYPE_ZEPPELIN) #else -# define machine_is_rfl109145_ssrv() (0) +# define machine_is_zeppelin() (0) #endif
-#ifdef CONFIG_MACH_NMH +#ifdef CONFIG_MACH_MOTUS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NMH +# define machine_arch_type MACH_TYPE_MOTUS # endif -# define machine_is_nmh() (machine_arch_type == MACH_TYPE_NMH) +# define machine_is_motus() (machine_arch_type == MACH_TYPE_MOTUS) #else -# define machine_is_nmh() (0) +# define machine_is_motus() (0) #endif
-#ifdef CONFIG_MACH_WN802T +#ifdef CONFIG_MACH_NEOMAINBOARD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_WN802T +# define machine_arch_type MACH_TYPE_NEOMAINBOARD # endif -# define machine_is_wn802t() (machine_arch_type == MACH_TYPE_WN802T) +# define machine_is_neomainboard() (machine_arch_type == MACH_TYPE_NEOMAINBOARD) #else -# define machine_is_wn802t() (0) +# define machine_is_neomainboard() (0) #endif
-#ifdef CONFIG_MACH_DRAGONET +#ifdef CONFIG_MACH_DEVKIT3250 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DRAGONET +# define machine_arch_type MACH_TYPE_DEVKIT3250 # endif -# define machine_is_dragonet() (machine_arch_type == MACH_TYPE_DRAGONET) +# define machine_is_devkit3250() (machine_arch_type == MACH_TYPE_DEVKIT3250) #else -# define machine_is_dragonet() (0) +# define machine_is_devkit3250() (0) #endif
-#ifdef CONFIG_MACH_AT91SAM9263DESK16L +#ifdef CONFIG_MACH_DEVKIT7000 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_AT91SAM9263DESK16L +# define machine_arch_type MACH_TYPE_DEVKIT7000 # endif -# define machine_is_at91sam9263desk16l() (machine_arch_type == MACH_TYPE_AT91SAM9263DESK16L) +# define machine_is_devkit7000() (machine_arch_type == MACH_TYPE_DEVKIT7000) #else -# define machine_is_at91sam9263desk16l() (0) +# define machine_is_devkit7000() (0) #endif
-#ifdef CONFIG_MACH_BCMHANA_SV +#ifdef CONFIG_MACH_FMC_UIC # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BCMHANA_SV +# define machine_arch_type MACH_TYPE_FMC_UIC # endif -# define machine_is_bcmhana_sv() (machine_arch_type == MACH_TYPE_BCMHANA_SV) +# define machine_is_fmc_uic() (machine_arch_type == MACH_TYPE_FMC_UIC) #else -# define machine_is_bcmhana_sv() (0) +# define machine_is_fmc_uic() (0) #endif
-#ifdef CONFIG_MACH_BCMHANA_TABLET +#ifdef CONFIG_MACH_FMC_DCM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BCMHANA_TABLET +# define machine_arch_type MACH_TYPE_FMC_DCM # endif -# define machine_is_bcmhana_tablet() (machine_arch_type == MACH_TYPE_BCMHANA_TABLET) +# define machine_is_fmc_dcm() (machine_arch_type == MACH_TYPE_FMC_DCM) #else -# define machine_is_bcmhana_tablet() (0) +# define machine_is_fmc_dcm() (0) #endif
-#ifdef CONFIG_MACH_KOI +#ifdef CONFIG_MACH_BATWM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_KOI +# define machine_arch_type MACH_TYPE_BATWM # endif -# define machine_is_koi() (machine_arch_type == MACH_TYPE_KOI) +# define machine_is_batwm() (machine_arch_type == MACH_TYPE_BATWM) #else -# define machine_is_koi() (0) +# define machine_is_batwm() (0) #endif
-#ifdef CONFIG_MACH_TS4800 +#ifdef CONFIG_MACH_ATLAS6CB # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TS4800 +# define machine_arch_type MACH_TYPE_ATLAS6CB # endif -# define machine_is_ts4800() (machine_arch_type == MACH_TYPE_TS4800) +# define machine_is_atlas6cb() (machine_arch_type == MACH_TYPE_ATLAS6CB) #else -# define machine_is_ts4800() (0) +# define machine_is_atlas6cb() (0) #endif
-#ifdef CONFIG_MACH_TQMA9263 +#ifdef CONFIG_MACH_BLUE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TQMA9263 +# define machine_arch_type MACH_TYPE_BLUE # endif -# define machine_is_tqma9263() (machine_arch_type == MACH_TYPE_TQMA9263) +# define machine_is_blue() (machine_arch_type == MACH_TYPE_BLUE) #else -# define machine_is_tqma9263() (0) +# define machine_is_blue() (0) #endif
-#ifdef CONFIG_MACH_HOLIDAY +#ifdef CONFIG_MACH_COLORADO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HOLIDAY +# define machine_arch_type MACH_TYPE_COLORADO # endif -# define machine_is_holiday() (machine_arch_type == MACH_TYPE_HOLIDAY) +# define machine_is_colorado() (machine_arch_type == MACH_TYPE_COLORADO) #else -# define machine_is_holiday() (0) +# define machine_is_colorado() (0) #endif
-#ifdef CONFIG_MACH_DMA6410 +#ifdef CONFIG_MACH_POPC # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DMA6410 +# define machine_arch_type MACH_TYPE_POPC # endif -# define machine_is_dma_6410() (machine_arch_type == MACH_TYPE_DMA6410) +# define machine_is_popc() (machine_arch_type == MACH_TYPE_POPC) #else -# define machine_is_dma_6410() (0) +# define machine_is_popc() (0) #endif
-#ifdef CONFIG_MACH_PCATS_OVERLAY +#ifdef CONFIG_MACH_PROMWAD_JADE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PCATS_OVERLAY +# define machine_arch_type MACH_TYPE_PROMWAD_JADE # endif -# define machine_is_pcats_overlay() (machine_arch_type == MACH_TYPE_PCATS_OVERLAY) +# define machine_is_promwad_jade() (machine_arch_type == MACH_TYPE_PROMWAD_JADE) #else -# define machine_is_pcats_overlay() (0) +# define machine_is_promwad_jade() (0) #endif
-#ifdef CONFIG_MACH_HWGW6410 +#ifdef CONFIG_MACH_AMP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HWGW6410 +# define machine_arch_type MACH_TYPE_AMP # endif -# define machine_is_hwgw6410() (machine_arch_type == MACH_TYPE_HWGW6410) +# define machine_is_amp() (machine_arch_type == MACH_TYPE_AMP) #else -# define machine_is_hwgw6410() (0) +# define machine_is_amp() (0) #endif
-#ifdef CONFIG_MACH_SHENZHOU +#ifdef CONFIG_MACH_GNET_AMP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SHENZHOU +# define machine_arch_type MACH_TYPE_GNET_AMP # endif -# define machine_is_shenzhou() (machine_arch_type == MACH_TYPE_SHENZHOU) +# define machine_is_gnet_amp() (machine_arch_type == MACH_TYPE_GNET_AMP) #else -# define machine_is_shenzhou() (0) +# define machine_is_gnet_amp() (0) #endif
-#ifdef CONFIG_MACH_CWME9210 +#ifdef CONFIG_MACH_TOQUES # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CWME9210 +# define machine_arch_type MACH_TYPE_TOQUES # endif -# define machine_is_cwme9210() (machine_arch_type == MACH_TYPE_CWME9210) +# define machine_is_toques() (machine_arch_type == MACH_TYPE_TOQUES) #else -# define machine_is_cwme9210() (0) +# define machine_is_toques() (0) #endif
-#ifdef CONFIG_MACH_CWME9210JS +#ifdef CONFIG_MACH_DCT_STORM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CWME9210JS +# define machine_arch_type MACH_TYPE_DCT_STORM # endif -# define machine_is_cwme9210js() (machine_arch_type == MACH_TYPE_CWME9210JS) +# define machine_is_dct_storm() (machine_arch_type == MACH_TYPE_DCT_STORM) #else -# define machine_is_cwme9210js() (0) +# define machine_is_dct_storm() (0) #endif
-#ifdef CONFIG_MACH_PGS_SITARA +#ifdef CONFIG_MACH_OWL # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PGS_SITARA +# define machine_arch_type MACH_TYPE_OWL # endif -# define machine_is_pgs_v1() (machine_arch_type == MACH_TYPE_PGS_SITARA) +# define machine_is_owl() (machine_arch_type == MACH_TYPE_OWL) #else -# define machine_is_pgs_v1() (0) +# define machine_is_owl() (0) #endif
-#ifdef CONFIG_MACH_COLIBRI_TEGRA2 +#ifdef CONFIG_MACH_COGENT_CSB1741 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_COLIBRI_TEGRA2 +# define machine_arch_type MACH_TYPE_COGENT_CSB1741 # endif -# define machine_is_colibri_tegra2() (machine_arch_type == MACH_TYPE_COLIBRI_TEGRA2) +# define machine_is_cogent_csb1741() (machine_arch_type == MACH_TYPE_COGENT_CSB1741) #else -# define machine_is_colibri_tegra2() (0) +# define machine_is_cogent_csb1741() (0) #endif
-#ifdef CONFIG_MACH_W21 +#ifdef CONFIG_MACH_ADILLUSTRA610 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_W21 +# define machine_arch_type MACH_TYPE_ADILLUSTRA610 # endif -# define machine_is_w21() (machine_arch_type == MACH_TYPE_W21) +# define machine_is_adillustra610() (machine_arch_type == MACH_TYPE_ADILLUSTRA610) #else -# define machine_is_w21() (0) +# define machine_is_adillustra610() (0) #endif
-#ifdef CONFIG_MACH_POLYSAT1 +#ifdef CONFIG_MACH_ECAFE_NA04 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_POLYSAT1 +# define machine_arch_type MACH_TYPE_ECAFE_NA04 # endif -# define machine_is_polysat1() (machine_arch_type == MACH_TYPE_POLYSAT1) +# define machine_is_ecafe_na04() (machine_arch_type == MACH_TYPE_ECAFE_NA04) #else -# define machine_is_polysat1() (0) +# define machine_is_ecafe_na04() (0) #endif
-#ifdef CONFIG_MACH_DATAWAY +#ifdef CONFIG_MACH_POPCT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DATAWAY +# define machine_arch_type MACH_TYPE_POPCT # endif -# define machine_is_dataway() (machine_arch_type == MACH_TYPE_DATAWAY) +# define machine_is_popct() (machine_arch_type == MACH_TYPE_POPCT) #else -# define machine_is_dataway() (0) +# define machine_is_popct() (0) #endif
-#ifdef CONFIG_MACH_COBRAL138 +#ifdef CONFIG_MACH_OMAP3_HELENA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_COBRAL138 +# define machine_arch_type MACH_TYPE_OMAP3_HELENA # endif -# define machine_is_cobral138() (machine_arch_type == MACH_TYPE_COBRAL138) +# define machine_is_omap3_helena() (machine_arch_type == MACH_TYPE_OMAP3_HELENA) #else -# define machine_is_cobral138() (0) +# define machine_is_omap3_helena() (0) #endif
-#ifdef CONFIG_MACH_ROVERPCS8 +#ifdef CONFIG_MACH_ACH # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ROVERPCS8 +# define machine_arch_type MACH_TYPE_ACH # endif -# define machine_is_roverpcs8() (machine_arch_type == MACH_TYPE_ROVERPCS8) +# define machine_is_ach() (machine_arch_type == MACH_TYPE_ACH) #else -# define machine_is_roverpcs8() (0) +# define machine_is_ach() (0) #endif
-#ifdef CONFIG_MACH_MARVELC +#ifdef CONFIG_MACH_MODULE_DTB # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MARVELC +# define machine_arch_type MACH_TYPE_MODULE_DTB # endif -# define machine_is_marvelc() (machine_arch_type == MACH_TYPE_MARVELC) +# define machine_is_module_dtb() (machine_arch_type == MACH_TYPE_MODULE_DTB) #else -# define machine_is_marvelc() (0) +# define machine_is_module_dtb() (0) #endif
-#ifdef CONFIG_MACH_NAVEFIHID +#ifdef CONFIG_MACH_OSLO_ELISABETH # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NAVEFIHID +# define machine_arch_type MACH_TYPE_OSLO_ELISABETH # endif -# define machine_is_navefihid() (machine_arch_type == MACH_TYPE_NAVEFIHID) +# define machine_is_oslo_elisabeth() (machine_arch_type == MACH_TYPE_OSLO_ELISABETH) #else -# define machine_is_navefihid() (0) +# define machine_is_oslo_elisabeth() (0) #endif
-#ifdef CONFIG_MACH_DM365_CV100 +#ifdef CONFIG_MACH_TT01 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DM365_CV100 +# define machine_arch_type MACH_TYPE_TT01 # endif -# define machine_is_dm365_cv100() (machine_arch_type == MACH_TYPE_DM365_CV100) +# define machine_is_tt01() (machine_arch_type == MACH_TYPE_TT01) #else -# define machine_is_dm365_cv100() (0) +# define machine_is_tt01() (0) #endif
-#ifdef CONFIG_MACH_ABLE +#ifdef CONFIG_MACH_MSM8930_CDP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ABLE +# define machine_arch_type MACH_TYPE_MSM8930_CDP # endif -# define machine_is_able() (machine_arch_type == MACH_TYPE_ABLE) +# define machine_is_msm8930_cdp() (machine_arch_type == MACH_TYPE_MSM8930_CDP) #else -# define machine_is_able() (0) +# define machine_is_msm8930_cdp() (0) #endif
-#ifdef CONFIG_MACH_LEGACY +#ifdef CONFIG_MACH_MSM8930_MTP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_LEGACY +# define machine_arch_type MACH_TYPE_MSM8930_MTP # endif -# define machine_is_legacy() (machine_arch_type == MACH_TYPE_LEGACY) +# define machine_is_msm8930_mtp() (machine_arch_type == MACH_TYPE_MSM8930_MTP) #else -# define machine_is_legacy() (0) +# define machine_is_msm8930_mtp() (0) #endif
-#ifdef CONFIG_MACH_ICONG +#ifdef CONFIG_MACH_MSM8930_FLUID # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ICONG +# define machine_arch_type MACH_TYPE_MSM8930_FLUID # endif -# define machine_is_icong() (machine_arch_type == MACH_TYPE_ICONG) +# define machine_is_msm8930_fluid() (machine_arch_type == MACH_TYPE_MSM8930_FLUID) #else -# define machine_is_icong() (0) +# define machine_is_msm8930_fluid() (0) #endif
-#ifdef CONFIG_MACH_ROVER_G8 +#ifdef CONFIG_MACH_LTU11 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ROVER_G8 +# define machine_arch_type MACH_TYPE_LTU11 # endif -# define machine_is_rover_g8() (machine_arch_type == MACH_TYPE_ROVER_G8) +# define machine_is_ltu11() (machine_arch_type == MACH_TYPE_LTU11) #else -# define machine_is_rover_g8() (0) +# define machine_is_ltu11() (0) #endif
-#ifdef CONFIG_MACH_T5388P +#ifdef CONFIG_MACH_AM1808_SPAWNCO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_T5388P +# define machine_arch_type MACH_TYPE_AM1808_SPAWNCO # endif -# define machine_is_t5388p() (machine_arch_type == MACH_TYPE_T5388P) +# define machine_is_am1808_spawnco() (machine_arch_type == MACH_TYPE_AM1808_SPAWNCO) #else -# define machine_is_t5388p() (0) +# define machine_is_am1808_spawnco() (0) #endif
-#ifdef CONFIG_MACH_DINGO +#ifdef CONFIG_MACH_FLX6410 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DINGO +# define machine_arch_type MACH_TYPE_FLX6410 # endif -# define machine_is_dingo() (machine_arch_type == MACH_TYPE_DINGO) +# define machine_is_flx6410() (machine_arch_type == MACH_TYPE_FLX6410) #else -# define machine_is_dingo() (0) +# define machine_is_flx6410() (0) #endif
-#ifdef CONFIG_MACH_GOFLEXHOME +#ifdef CONFIG_MACH_MX6Q_QSB # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GOFLEXHOME +# define machine_arch_type MACH_TYPE_MX6Q_QSB # endif -# define machine_is_goflexhome() (machine_arch_type == MACH_TYPE_GOFLEXHOME) +# define machine_is_mx6q_qsb() (machine_arch_type == MACH_TYPE_MX6Q_QSB) #else -# define machine_is_goflexhome() (0) +# define machine_is_mx6q_qsb() (0) #endif
-#ifdef CONFIG_MACH_LANREADYFN511 +#ifdef CONFIG_MACH_MX53_PLT424 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_LANREADYFN511 +# define machine_arch_type MACH_TYPE_MX53_PLT424 # endif -# define machine_is_lanreadyfn511() (machine_arch_type == MACH_TYPE_LANREADYFN511) +# define machine_is_mx53_plt424() (machine_arch_type == MACH_TYPE_MX53_PLT424) #else -# define machine_is_lanreadyfn511() (0) +# define machine_is_mx53_plt424() (0) #endif
-#ifdef CONFIG_MACH_OMAP3_BAIA +#ifdef CONFIG_MACH_JASMINE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OMAP3_BAIA +# define machine_arch_type MACH_TYPE_JASMINE # endif -# define machine_is_omap3_baia() (machine_arch_type == MACH_TYPE_OMAP3_BAIA) +# define machine_is_jasmine() (machine_arch_type == MACH_TYPE_JASMINE) #else -# define machine_is_omap3_baia() (0) +# define machine_is_jasmine() (0) #endif
-#ifdef CONFIG_MACH_OMAP3SMARTDISPLAY +#ifdef CONFIG_MACH_L138_OWLBOARD_PLUS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OMAP3SMARTDISPLAY +# define machine_arch_type MACH_TYPE_L138_OWLBOARD_PLUS # endif -# define machine_is_omap3smartdisplay() (machine_arch_type == MACH_TYPE_OMAP3SMARTDISPLAY) +# define machine_is_l138_owlboard_plus() (machine_arch_type == MACH_TYPE_L138_OWLBOARD_PLUS) #else -# define machine_is_omap3smartdisplay() (0) +# define machine_is_l138_owlboard_plus() (0) #endif
-#ifdef CONFIG_MACH_XILINX +#ifdef CONFIG_MACH_WR21 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_XILINX +# define machine_arch_type MACH_TYPE_WR21 # endif -# define machine_is_xilinx() (machine_arch_type == MACH_TYPE_XILINX) +# define machine_is_wr21() (machine_arch_type == MACH_TYPE_WR21) #else -# define machine_is_xilinx() (0) +# define machine_is_wr21() (0) #endif
-#ifdef CONFIG_MACH_A2F +#ifdef CONFIG_MACH_PEABOY # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_A2F +# define machine_arch_type MACH_TYPE_PEABOY # endif -# define machine_is_a2f() (machine_arch_type == MACH_TYPE_A2F) +# define machine_is_peaboy() (machine_arch_type == MACH_TYPE_PEABOY) #else -# define machine_is_a2f() (0) +# define machine_is_peaboy() (0) #endif
-#ifdef CONFIG_MACH_SKY25 +#ifdef CONFIG_MACH_MX28_PLATO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SKY25 +# define machine_arch_type MACH_TYPE_MX28_PLATO # endif -# define machine_is_sky25() (machine_arch_type == MACH_TYPE_SKY25) +# define machine_is_mx28_plato() (machine_arch_type == MACH_TYPE_MX28_PLATO) #else -# define machine_is_sky25() (0) +# define machine_is_mx28_plato() (0) #endif
-#ifdef CONFIG_MACH_CCMX53 +#ifdef CONFIG_MACH_KACOM2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CCMX53 +# define machine_arch_type MACH_TYPE_KACOM2 # endif -# define machine_is_ccmx53() (machine_arch_type == MACH_TYPE_CCMX53) +# define machine_is_kacom2() (machine_arch_type == MACH_TYPE_KACOM2) #else -# define machine_is_ccmx53() (0) +# define machine_is_kacom2() (0) #endif
-#ifdef CONFIG_MACH_CCMX53JS +#ifdef CONFIG_MACH_SLCO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CCMX53JS +# define machine_arch_type MACH_TYPE_SLCO # endif -# define machine_is_ccmx53js() (machine_arch_type == MACH_TYPE_CCMX53JS) +# define machine_is_slco() (machine_arch_type == MACH_TYPE_SLCO) #else -# define machine_is_ccmx53js() (0) +# define machine_is_slco() (0) #endif
-#ifdef CONFIG_MACH_CCWMX53 +#ifdef CONFIG_MACH_IMX51PICO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CCWMX53 +# define machine_arch_type MACH_TYPE_IMX51PICO # endif -# define machine_is_ccwmx53() (machine_arch_type == MACH_TYPE_CCWMX53) +# define machine_is_imx51pico() (machine_arch_type == MACH_TYPE_IMX51PICO) #else -# define machine_is_ccwmx53() (0) +# define machine_is_imx51pico() (0) #endif
-#ifdef CONFIG_MACH_CCWMX53JS +#ifdef CONFIG_MACH_GLINK1 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CCWMX53JS +# define machine_arch_type MACH_TYPE_GLINK1 # endif -# define machine_is_ccwmx53js() (machine_arch_type == MACH_TYPE_CCWMX53JS) +# define machine_is_glink1() (machine_arch_type == MACH_TYPE_GLINK1) #else -# define machine_is_ccwmx53js() (0) +# define machine_is_glink1() (0) #endif
-#ifdef CONFIG_MACH_FRISMS +#ifdef CONFIG_MACH_DIAMOND # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_FRISMS +# define machine_arch_type MACH_TYPE_DIAMOND # endif -# define machine_is_frisms() (machine_arch_type == MACH_TYPE_FRISMS) +# define machine_is_diamond() (machine_arch_type == MACH_TYPE_DIAMOND) #else -# define machine_is_frisms() (0) +# define machine_is_diamond() (0) #endif
-#ifdef CONFIG_MACH_MSM7X27A_FFA +#ifdef CONFIG_MACH_D9000 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MSM7X27A_FFA +# define machine_arch_type MACH_TYPE_D9000 # endif -# define machine_is_msm7x27a_ffa() (machine_arch_type == MACH_TYPE_MSM7X27A_FFA) +# define machine_is_d9000() (machine_arch_type == MACH_TYPE_D9000) #else -# define machine_is_msm7x27a_ffa() (0) +# define machine_is_d9000() (0) #endif
-#ifdef CONFIG_MACH_MSM7X27A_SURF +#ifdef CONFIG_MACH_W5300E01 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MSM7X27A_SURF +# define machine_arch_type MACH_TYPE_W5300E01 # endif -# define machine_is_msm7x27a_surf() (machine_arch_type == MACH_TYPE_MSM7X27A_SURF) +# define machine_is_w5300e01() (machine_arch_type == MACH_TYPE_W5300E01) #else -# define machine_is_msm7x27a_surf() (0) +# define machine_is_w5300e01() (0) #endif
-#ifdef CONFIG_MACH_MSM7X27A_RUMI3 +#ifdef CONFIG_MACH_IM6000 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MSM7X27A_RUMI3 +# define machine_arch_type MACH_TYPE_IM6000 # endif -# define machine_is_msm7x27a_rumi3() (machine_arch_type == MACH_TYPE_MSM7X27A_RUMI3) +# define machine_is_im6000() (machine_arch_type == MACH_TYPE_IM6000) #else -# define machine_is_msm7x27a_rumi3() (0) +# define machine_is_im6000() (0) #endif
-#ifdef CONFIG_MACH_DIMMSAM9G20 +#ifdef CONFIG_MACH_MX51_FRED51 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DIMMSAM9G20 +# define machine_arch_type MACH_TYPE_MX51_FRED51 # endif -# define machine_is_dimmsam9g20() (machine_arch_type == MACH_TYPE_DIMMSAM9G20) +# define machine_is_mx51_fred51() (machine_arch_type == MACH_TYPE_MX51_FRED51) #else -# define machine_is_dimmsam9g20() (0) +# define machine_is_mx51_fred51() (0) #endif
-#ifdef CONFIG_MACH_DIMM_IMX28 +#ifdef CONFIG_MACH_STM32F2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DIMM_IMX28 +# define machine_arch_type MACH_TYPE_STM32F2 # endif -# define machine_is_dimm_imx28() (machine_arch_type == MACH_TYPE_DIMM_IMX28) +# define machine_is_stm32f2() (machine_arch_type == MACH_TYPE_STM32F2) #else -# define machine_is_dimm_imx28() (0) +# define machine_is_stm32f2() (0) #endif
-#ifdef CONFIG_MACH_AMK_A4 +#ifdef CONFIG_MACH_VILLE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_AMK_A4 +# define machine_arch_type MACH_TYPE_VILLE # endif -# define machine_is_amk_a4() (machine_arch_type == MACH_TYPE_AMK_A4) +# define machine_is_ville() (machine_arch_type == MACH_TYPE_VILLE) #else -# define machine_is_amk_a4() (0) +# define machine_is_ville() (0) #endif
-#ifdef CONFIG_MACH_GNET_SGME +#ifdef CONFIG_MACH_PTIP_MURNAU # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GNET_SGME +# define machine_arch_type MACH_TYPE_PTIP_MURNAU # endif -# define machine_is_gnet_sgme() (machine_arch_type == MACH_TYPE_GNET_SGME) +# define machine_is_ptip_murnau() (machine_arch_type == MACH_TYPE_PTIP_MURNAU) #else -# define machine_is_gnet_sgme() (0) +# define machine_is_ptip_murnau() (0) #endif
-#ifdef CONFIG_MACH_SHOOTER_U +#ifdef CONFIG_MACH_PTIP_CLASSIC # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SHOOTER_U +# define machine_arch_type MACH_TYPE_PTIP_CLASSIC # endif -# define machine_is_shooter_u() (machine_arch_type == MACH_TYPE_SHOOTER_U) +# define machine_is_ptip_classic() (machine_arch_type == MACH_TYPE_PTIP_CLASSIC) #else -# define machine_is_shooter_u() (0) +# define machine_is_ptip_classic() (0) #endif
-#ifdef CONFIG_MACH_VMX53 +#ifdef CONFIG_MACH_MX53GRB # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VMX53 +# define machine_arch_type MACH_TYPE_MX53GRB # endif -# define machine_is_vmx53() (machine_arch_type == MACH_TYPE_VMX53) +# define machine_is_mx53grb() (machine_arch_type == MACH_TYPE_MX53GRB) #else -# define machine_is_vmx53() (0) +# define machine_is_mx53grb() (0) #endif
-#ifdef CONFIG_MACH_RHINO +#ifdef CONFIG_MACH_GAGARIN # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_RHINO +# define machine_arch_type MACH_TYPE_GAGARIN # endif -# define machine_is_rhino() (machine_arch_type == MACH_TYPE_RHINO) +# define machine_is_gagarin() (machine_arch_type == MACH_TYPE_GAGARIN) #else -# define machine_is_rhino() (0) +# define machine_is_gagarin() (0) #endif
-#ifdef CONFIG_MACH_ARMLEX4210 +#ifdef CONFIG_MACH_NAS2BIG # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ARMLEX4210 +# define machine_arch_type MACH_TYPE_NAS2BIG # endif -# define machine_is_armlex4210() (machine_arch_type == MACH_TYPE_ARMLEX4210) +# define machine_is_nas2big() (machine_arch_type == MACH_TYPE_NAS2BIG) #else -# define machine_is_armlex4210() (0) +# define machine_is_nas2big() (0) #endif
-#ifdef CONFIG_MACH_SWARCOEXTMODEM +#ifdef CONFIG_MACH_SUPERFEMTO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SWARCOEXTMODEM +# define machine_arch_type MACH_TYPE_SUPERFEMTO # endif -# define machine_is_swarcoextmodem() (machine_arch_type == MACH_TYPE_SWARCOEXTMODEM) +# define machine_is_superfemto() (machine_arch_type == MACH_TYPE_SUPERFEMTO) #else -# define machine_is_swarcoextmodem() (0) +# define machine_is_superfemto() (0) #endif
-#ifdef CONFIG_MACH_SNOWBALL +#ifdef CONFIG_MACH_TEUFEL # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SNOWBALL +# define machine_arch_type MACH_TYPE_TEUFEL # endif -# define machine_is_snowball() (machine_arch_type == MACH_TYPE_SNOWBALL) +# define machine_is_teufel() (machine_arch_type == MACH_TYPE_TEUFEL) #else -# define machine_is_snowball() (0) +# define machine_is_teufel() (0) #endif
-#ifdef CONFIG_MACH_PCM049 +#ifdef CONFIG_MACH_DINARA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PCM049 +# define machine_arch_type MACH_TYPE_DINARA # endif -# define machine_is_pcm049() (machine_arch_type == MACH_TYPE_PCM049) +# define machine_is_dinara() (machine_arch_type == MACH_TYPE_DINARA) #else -# define machine_is_pcm049() (0) +# define machine_is_dinara() (0) #endif
-#ifdef CONFIG_MACH_VIGOR +#ifdef CONFIG_MACH_VANQUISH # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VIGOR +# define machine_arch_type MACH_TYPE_VANQUISH # endif -# define machine_is_vigor() (machine_arch_type == MACH_TYPE_VIGOR) +# define machine_is_vanquish() (machine_arch_type == MACH_TYPE_VANQUISH) #else -# define machine_is_vigor() (0) +# define machine_is_vanquish() (0) #endif
-#ifdef CONFIG_MACH_OSLO_AMUNDSEN +#ifdef CONFIG_MACH_ZIPABOX1 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OSLO_AMUNDSEN +# define machine_arch_type MACH_TYPE_ZIPABOX1 # endif -# define machine_is_oslo_amundsen() (machine_arch_type == MACH_TYPE_OSLO_AMUNDSEN) +# define machine_is_zipabox1() (machine_arch_type == MACH_TYPE_ZIPABOX1) #else -# define machine_is_oslo_amundsen() (0) +# define machine_is_zipabox1() (0) #endif
-#ifdef CONFIG_MACH_GSL_DIAMOND +#ifdef CONFIG_MACH_U9540 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GSL_DIAMOND +# define machine_arch_type MACH_TYPE_U9540 # endif -# define machine_is_gsl_diamond() (machine_arch_type == MACH_TYPE_GSL_DIAMOND) +# define machine_is_u9540() (machine_arch_type == MACH_TYPE_U9540) #else -# define machine_is_gsl_diamond() (0) +# define machine_is_u9540() (0) #endif
-#ifdef CONFIG_MACH_CV2201 +#ifdef CONFIG_MACH_JET # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CV2201 +# define machine_arch_type MACH_TYPE_JET # endif -# define machine_is_cv2201() (machine_arch_type == MACH_TYPE_CV2201) +# define machine_is_jet() (machine_arch_type == MACH_TYPE_JET) #else -# define machine_is_cv2201() (0) +# define machine_is_jet() (0) #endif
-#ifdef CONFIG_MACH_CV2202 +#ifdef CONFIG_MACH_SMDK4412 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CV2202 +# define machine_arch_type MACH_TYPE_SMDK4412 # endif -# define machine_is_cv2202() (machine_arch_type == MACH_TYPE_CV2202) +# define machine_is_smdk4412() (machine_arch_type == MACH_TYPE_SMDK4412) #else -# define machine_is_cv2202() (0) +# define machine_is_smdk4412() (0) #endif
-#ifdef CONFIG_MACH_CV2203 +#ifdef CONFIG_MACH_ELITE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CV2203 +# define machine_arch_type MACH_TYPE_ELITE # endif -# define machine_is_cv2203() (machine_arch_type == MACH_TYPE_CV2203) +# define machine_is_elite() (machine_arch_type == MACH_TYPE_ELITE) #else -# define machine_is_cv2203() (0) +# define machine_is_elite() (0) #endif
-#ifdef CONFIG_MACH_VIT_IBOX +#ifdef CONFIG_MACH_SPEAR320_HMI # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VIT_IBOX +# define machine_arch_type MACH_TYPE_SPEAR320_HMI # endif -# define machine_is_vit_ibox() (machine_arch_type == MACH_TYPE_VIT_IBOX) +# define machine_is_spear320_hmi() (machine_arch_type == MACH_TYPE_SPEAR320_HMI) #else -# define machine_is_vit_ibox() (0) +# define machine_is_spear320_hmi() (0) #endif
-#ifdef CONFIG_MACH_DM6441_ESP +#ifdef CONFIG_MACH_ONTARIO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DM6441_ESP +# define machine_arch_type MACH_TYPE_ONTARIO # endif -# define machine_is_dm6441_esp() (machine_arch_type == MACH_TYPE_DM6441_ESP) +# define machine_is_ontario() (machine_arch_type == MACH_TYPE_ONTARIO) #else -# define machine_is_dm6441_esp() (0) +# define machine_is_ontario() (0) #endif
-#ifdef CONFIG_MACH_AT91SAM9X5EK +#ifdef CONFIG_MACH_MX6Q_SABRELITE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_AT91SAM9X5EK +# define machine_arch_type MACH_TYPE_MX6Q_SABRELITE # endif -# define machine_is_at91sam9x5ek() (machine_arch_type == MACH_TYPE_AT91SAM9X5EK) +# define machine_is_mx6q_sabrelite() (machine_arch_type == MACH_TYPE_MX6Q_SABRELITE) #else -# define machine_is_at91sam9x5ek() (0) +# define machine_is_mx6q_sabrelite() (0) #endif
-#ifdef CONFIG_MACH_LIBRA +#ifdef CONFIG_MACH_VC200 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_LIBRA +# define machine_arch_type MACH_TYPE_VC200 # endif -# define machine_is_libra() (machine_arch_type == MACH_TYPE_LIBRA) +# define machine_is_vc200() (machine_arch_type == MACH_TYPE_VC200) #else -# define machine_is_libra() (0) +# define machine_is_vc200() (0) #endif
-#ifdef CONFIG_MACH_EASYCRRH +#ifdef CONFIG_MACH_MSM7625A_FFA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_EASYCRRH +# define machine_arch_type MACH_TYPE_MSM7625A_FFA # endif -# define machine_is_easycrrh() (machine_arch_type == MACH_TYPE_EASYCRRH) +# define machine_is_msm7625a_ffa() (machine_arch_type == MACH_TYPE_MSM7625A_FFA) #else -# define machine_is_easycrrh() (0) +# define machine_is_msm7625a_ffa() (0) #endif
-#ifdef CONFIG_MACH_TRIPEL +#ifdef CONFIG_MACH_MSM7625A_SURF # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TRIPEL +# define machine_arch_type MACH_TYPE_MSM7625A_SURF # endif -# define machine_is_tripel() (machine_arch_type == MACH_TYPE_TRIPEL) +# define machine_is_msm7625a_surf() (machine_arch_type == MACH_TYPE_MSM7625A_SURF) #else -# define machine_is_tripel() (0) +# define machine_is_msm7625a_surf() (0) #endif
-#ifdef CONFIG_MACH_ENDIAN_MINI +#ifdef CONFIG_MACH_BENTHOSSBP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ENDIAN_MINI +# define machine_arch_type MACH_TYPE_BENTHOSSBP # endif -# define machine_is_endian_mini() (machine_arch_type == MACH_TYPE_ENDIAN_MINI) +# define machine_is_benthossbp() (machine_arch_type == MACH_TYPE_BENTHOSSBP) #else -# define machine_is_endian_mini() (0) +# define machine_is_benthossbp() (0) #endif
-#ifdef CONFIG_MACH_XILINX_EP107 +#ifdef CONFIG_MACH_SMDK5210 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_XILINX_EP107 +# define machine_arch_type MACH_TYPE_SMDK5210 # endif -# define machine_is_xilinx_ep107() (machine_arch_type == MACH_TYPE_XILINX_EP107) +# define machine_is_smdk5210() (machine_arch_type == MACH_TYPE_SMDK5210) #else -# define machine_is_xilinx_ep107() (0) +# define machine_is_smdk5210() (0) #endif
-#ifdef CONFIG_MACH_NURI +#ifdef CONFIG_MACH_EMPQ2300 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NURI +# define machine_arch_type MACH_TYPE_EMPQ2300 # endif -# define machine_is_nuri() (machine_arch_type == MACH_TYPE_NURI) +# define machine_is_empq2300() (machine_arch_type == MACH_TYPE_EMPQ2300) #else -# define machine_is_nuri() (0) +# define machine_is_empq2300() (0) #endif
-#ifdef CONFIG_MACH_JANUS +#ifdef CONFIG_MACH_MINIPOS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_JANUS +# define machine_arch_type MACH_TYPE_MINIPOS # endif -# define machine_is_janus() (machine_arch_type == MACH_TYPE_JANUS) +# define machine_is_minipos() (machine_arch_type == MACH_TYPE_MINIPOS) #else -# define machine_is_janus() (0) +# define machine_is_minipos() (0) #endif
-#ifdef CONFIG_MACH_DDNAS +#ifdef CONFIG_MACH_OMAP5_SEVM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DDNAS +# define machine_arch_type MACH_TYPE_OMAP5_SEVM # endif -# define machine_is_ddnas() (machine_arch_type == MACH_TYPE_DDNAS) +# define machine_is_omap5_sevm() (machine_arch_type == MACH_TYPE_OMAP5_SEVM) #else -# define machine_is_ddnas() (0) +# define machine_is_omap5_sevm() (0) #endif
-#ifdef CONFIG_MACH_TAG +#ifdef CONFIG_MACH_SHELTER # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TAG +# define machine_arch_type MACH_TYPE_SHELTER # endif -# define machine_is_tag() (machine_arch_type == MACH_TYPE_TAG) +# define machine_is_shelter() (machine_arch_type == MACH_TYPE_SHELTER) #else -# define machine_is_tag() (0) +# define machine_is_shelter() (0) #endif
-#ifdef CONFIG_MACH_TAGW +#ifdef CONFIG_MACH_OMAP3_DEVKIT8500 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TAGW +# define machine_arch_type MACH_TYPE_OMAP3_DEVKIT8500 # endif -# define machine_is_tagw() (machine_arch_type == MACH_TYPE_TAGW) +# define machine_is_omap3_devkit8500() (machine_arch_type == MACH_TYPE_OMAP3_DEVKIT8500) #else -# define machine_is_tagw() (0) +# define machine_is_omap3_devkit8500() (0) #endif
-#ifdef CONFIG_MACH_NITROGEN_VM_IMX51 +#ifdef CONFIG_MACH_EDGETD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NITROGEN_VM_IMX51 +# define machine_arch_type MACH_TYPE_EDGETD # endif -# define machine_is_nitrogen_vm_imx51() (machine_arch_type == MACH_TYPE_NITROGEN_VM_IMX51) +# define machine_is_edgetd() (machine_arch_type == MACH_TYPE_EDGETD) #else -# define machine_is_nitrogen_vm_imx51() (0) +# define machine_is_edgetd() (0) #endif
-#ifdef CONFIG_MACH_VIPRINET +#ifdef CONFIG_MACH_COPPERYARD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VIPRINET +# define machine_arch_type MACH_TYPE_COPPERYARD # endif -# define machine_is_viprinet() (machine_arch_type == MACH_TYPE_VIPRINET) +# define machine_is_copperyard() (machine_arch_type == MACH_TYPE_COPPERYARD) #else -# define machine_is_viprinet() (0) +# define machine_is_copperyard() (0) #endif
-#ifdef CONFIG_MACH_BOCKW +#ifdef CONFIG_MACH_EDGE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BOCKW +# define machine_arch_type MACH_TYPE_EDGE # endif -# define machine_is_bockw() (machine_arch_type == MACH_TYPE_BOCKW) +# define machine_is_edge() (machine_arch_type == MACH_TYPE_EDGE) #else -# define machine_is_bockw() (0) +# define machine_is_edge() (0) #endif
-#ifdef CONFIG_MACH_EVA2000 +#ifdef CONFIG_MACH_EDGE_U # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_EVA2000 +# define machine_arch_type MACH_TYPE_EDGE_U # endif -# define machine_is_eva2000() (machine_arch_type == MACH_TYPE_EVA2000) +# define machine_is_edge_u() (machine_arch_type == MACH_TYPE_EDGE_U) #else -# define machine_is_eva2000() (0) +# define machine_is_edge_u() (0) #endif
-#ifdef CONFIG_MACH_STEELYARD +#ifdef CONFIG_MACH_EDGE_TD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_STEELYARD +# define machine_arch_type MACH_TYPE_EDGE_TD # endif -# define machine_is_steelyard() (machine_arch_type == MACH_TYPE_STEELYARD) +# define machine_is_edge_td() (machine_arch_type == MACH_TYPE_EDGE_TD) #else -# define machine_is_steelyard() (0) +# define machine_is_edge_td() (0) #endif
-#ifdef CONFIG_MACH_MACH_SDH001 +#ifdef CONFIG_MACH_WDSS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MACH_SDH001 +# define machine_arch_type MACH_TYPE_WDSS # endif -# define machine_is_sdh001() (machine_arch_type == MACH_TYPE_MACH_SDH001) +# define machine_is_wdss() (machine_arch_type == MACH_TYPE_WDSS) #else -# define machine_is_sdh001() (0) +# define machine_is_wdss() (0) #endif
-#ifdef CONFIG_MACH_NSSLSBOARD +#ifdef CONFIG_MACH_DL_PB25 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NSSLSBOARD +# define machine_arch_type MACH_TYPE_DL_PB25 # endif -# define machine_is_nsslsboard() (machine_arch_type == MACH_TYPE_NSSLSBOARD) +# define machine_is_dl_pb25() (machine_arch_type == MACH_TYPE_DL_PB25) #else -# define machine_is_nsslsboard() (0) +# define machine_is_dl_pb25() (0) #endif
-#ifdef CONFIG_MACH_GENEVA_B5 +#ifdef CONFIG_MACH_DSS11 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GENEVA_B5 +# define machine_arch_type MACH_TYPE_DSS11 # endif -# define machine_is_geneva_b5() (machine_arch_type == MACH_TYPE_GENEVA_B5) +# define machine_is_dss11() (machine_arch_type == MACH_TYPE_DSS11) #else -# define machine_is_geneva_b5() (0) +# define machine_is_dss11() (0) #endif
-#ifdef CONFIG_MACH_SPEAR1340 +#ifdef CONFIG_MACH_CPA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SPEAR1340 +# define machine_arch_type MACH_TYPE_CPA # endif -# define machine_is_spear1340() (machine_arch_type == MACH_TYPE_SPEAR1340) +# define machine_is_cpa() (machine_arch_type == MACH_TYPE_CPA) #else -# define machine_is_spear1340() (0) +# define machine_is_cpa() (0) #endif
-#ifdef CONFIG_MACH_REXMAS +#ifdef CONFIG_MACH_APTP2000 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_REXMAS +# define machine_arch_type MACH_TYPE_APTP2000 # endif -# define machine_is_rexmas() (machine_arch_type == MACH_TYPE_REXMAS) +# define machine_is_aptp2000() (machine_arch_type == MACH_TYPE_APTP2000) #else -# define machine_is_rexmas() (0) +# define machine_is_aptp2000() (0) #endif
-#ifdef CONFIG_MACH_MSM8960_CDP +#ifdef CONFIG_MACH_MARZEN # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MSM8960_CDP +# define machine_arch_type MACH_TYPE_MARZEN # endif -# define machine_is_msm8960_cdp() (machine_arch_type == MACH_TYPE_MSM8960_CDP) +# define machine_is_marzen() (machine_arch_type == MACH_TYPE_MARZEN) #else -# define machine_is_msm8960_cdp() (0) +# define machine_is_marzen() (0) #endif
-#ifdef CONFIG_MACH_MSM8960_MDP +#ifdef CONFIG_MACH_ST_TURBINE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MSM8960_MDP +# define machine_arch_type MACH_TYPE_ST_TURBINE # endif -# define machine_is_msm8960_mdp() (machine_arch_type == MACH_TYPE_MSM8960_MDP) +# define machine_is_st_turbine() (machine_arch_type == MACH_TYPE_ST_TURBINE) #else -# define machine_is_msm8960_mdp() (0) +# define machine_is_st_turbine() (0) #endif
-#ifdef CONFIG_MACH_MSM8960_FLUID +#ifdef CONFIG_MACH_GTL_IT3300 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MSM8960_FLUID +# define machine_arch_type MACH_TYPE_GTL_IT3300 # endif -# define machine_is_msm8960_fluid() (machine_arch_type == MACH_TYPE_MSM8960_FLUID) +# define machine_is_gtl_it3300() (machine_arch_type == MACH_TYPE_GTL_IT3300) #else -# define machine_is_msm8960_fluid() (0) +# define machine_is_gtl_it3300() (0) #endif
-#ifdef CONFIG_MACH_MSM8960_APQ +#ifdef CONFIG_MACH_MX6_MULE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MSM8960_APQ +# define machine_arch_type MACH_TYPE_MX6_MULE # endif -# define machine_is_msm8960_apq() (machine_arch_type == MACH_TYPE_MSM8960_APQ) +# define machine_is_mx6_mule() (machine_arch_type == MACH_TYPE_MX6_MULE) #else -# define machine_is_msm8960_apq() (0) +# define machine_is_mx6_mule() (0) #endif
-#ifdef CONFIG_MACH_HELIOS_V2 +#ifdef CONFIG_MACH_V7PXA_DT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HELIOS_V2 +# define machine_arch_type MACH_TYPE_V7PXA_DT # endif -# define machine_is_helios_v2() (machine_arch_type == MACH_TYPE_HELIOS_V2) +# define machine_is_v7pxa_dt() (machine_arch_type == MACH_TYPE_V7PXA_DT) #else -# define machine_is_helios_v2() (0) +# define machine_is_v7pxa_dt() (0) #endif
-#ifdef CONFIG_MACH_MIF10P +#ifdef CONFIG_MACH_V7MMP_DT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MIF10P +# define machine_arch_type MACH_TYPE_V7MMP_DT # endif -# define machine_is_mif10p() (machine_arch_type == MACH_TYPE_MIF10P) +# define machine_is_v7mmp_dt() (machine_arch_type == MACH_TYPE_V7MMP_DT) #else -# define machine_is_mif10p() (0) +# define machine_is_v7mmp_dt() (0) #endif
-#ifdef CONFIG_MACH_IAM28 +#ifdef CONFIG_MACH_DRAGON7 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_IAM28 +# define machine_arch_type MACH_TYPE_DRAGON7 # endif -# define machine_is_iam28() (machine_arch_type == MACH_TYPE_IAM28) +# define machine_is_dragon7() (machine_arch_type == MACH_TYPE_DRAGON7) #else -# define machine_is_iam28() (0) +# define machine_is_dragon7() (0) #endif
-#ifdef CONFIG_MACH_PICASSO +#ifdef CONFIG_MACH_KROME # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PICASSO +# define machine_arch_type MACH_TYPE_KROME # endif -# define machine_is_picasso() (machine_arch_type == MACH_TYPE_PICASSO) +# define machine_is_krome() (machine_arch_type == MACH_TYPE_KROME) #else -# define machine_is_picasso() (0) +# define machine_is_krome() (0) #endif
-#ifdef CONFIG_MACH_MR301A +#ifdef CONFIG_MACH_ORATISDANTE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MR301A +# define machine_arch_type MACH_TYPE_ORATISDANTE # endif -# define machine_is_mr301a() (machine_arch_type == MACH_TYPE_MR301A) +# define machine_is_oratisdante() (machine_arch_type == MACH_TYPE_ORATISDANTE) #else -# define machine_is_mr301a() (0) +# define machine_is_oratisdante() (0) #endif
-#ifdef CONFIG_MACH_NOTLE +#ifdef CONFIG_MACH_FATHOM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NOTLE +# define machine_arch_type MACH_TYPE_FATHOM # endif -# define machine_is_notle() (machine_arch_type == MACH_TYPE_NOTLE) +# define machine_is_fathom() (machine_arch_type == MACH_TYPE_FATHOM) #else -# define machine_is_notle() (0) +# define machine_is_fathom() (0) #endif
-#ifdef CONFIG_MACH_EELX2 +#ifdef CONFIG_MACH_DNS325 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_EELX2 +# define machine_arch_type MACH_TYPE_DNS325 # endif -# define machine_is_eelx2() (machine_arch_type == MACH_TYPE_EELX2) +# define machine_is_dns325() (machine_arch_type == MACH_TYPE_DNS325) #else -# define machine_is_eelx2() (0) +# define machine_is_dns325() (0) #endif
-#ifdef CONFIG_MACH_MOON +#ifdef CONFIG_MACH_SARNEN # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MOON +# define machine_arch_type MACH_TYPE_SARNEN # endif -# define machine_is_moon() (machine_arch_type == MACH_TYPE_MOON) +# define machine_is_sarnen() (machine_arch_type == MACH_TYPE_SARNEN) #else -# define machine_is_moon() (0) +# define machine_is_sarnen() (0) #endif
-#ifdef CONFIG_MACH_RUBY +#ifdef CONFIG_MACH_UBISYS_G1 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_RUBY +# define machine_arch_type MACH_TYPE_UBISYS_G1 # endif -# define machine_is_ruby() (machine_arch_type == MACH_TYPE_RUBY) +# define machine_is_ubisys_g1() (machine_arch_type == MACH_TYPE_UBISYS_G1) #else -# define machine_is_ruby() (0) +# define machine_is_ubisys_g1() (0) #endif
-#ifdef CONFIG_MACH_GOLDENGATE +#ifdef CONFIG_MACH_MX53_PF1 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GOLDENGATE +# define machine_arch_type MACH_TYPE_MX53_PF1 # endif -# define machine_is_goldengate() (machine_arch_type == MACH_TYPE_GOLDENGATE) +# define machine_is_mx53_pf1() (machine_arch_type == MACH_TYPE_MX53_PF1) #else -# define machine_is_goldengate() (0) +# define machine_is_mx53_pf1() (0) #endif
-#ifdef CONFIG_MACH_CTBU_GEN2 +#ifdef CONFIG_MACH_ASANTI # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CTBU_GEN2 +# define machine_arch_type MACH_TYPE_ASANTI # endif -# define machine_is_ctbu_gen2() (machine_arch_type == MACH_TYPE_CTBU_GEN2) +# define machine_is_asanti() (machine_arch_type == MACH_TYPE_ASANTI) #else -# define machine_is_ctbu_gen2() (0) +# define machine_is_asanti() (0) #endif
-#ifdef CONFIG_MACH_KMP_AM17_01 +#ifdef CONFIG_MACH_VOLTA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_KMP_AM17_01 +# define machine_arch_type MACH_TYPE_VOLTA # endif -# define machine_is_kmp_am17_01() (machine_arch_type == MACH_TYPE_KMP_AM17_01) +# define machine_is_volta() (machine_arch_type == MACH_TYPE_VOLTA) #else -# define machine_is_kmp_am17_01() (0) +# define machine_is_volta() (0) #endif
-#ifdef CONFIG_MACH_WTPLUG +#ifdef CONFIG_MACH_KNIGHT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_WTPLUG +# define machine_arch_type MACH_TYPE_KNIGHT # endif -# define machine_is_wtplug() (machine_arch_type == MACH_TYPE_WTPLUG) +# define machine_is_knight() (machine_arch_type == MACH_TYPE_KNIGHT) #else -# define machine_is_wtplug() (0) +# define machine_is_knight() (0) #endif
-#ifdef CONFIG_MACH_MX27SU2 +#ifdef CONFIG_MACH_BEAGLEBONE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MX27SU2 +# define machine_arch_type MACH_TYPE_BEAGLEBONE # endif -# define machine_is_mx27su2() (machine_arch_type == MACH_TYPE_MX27SU2) +# define machine_is_beaglebone() (machine_arch_type == MACH_TYPE_BEAGLEBONE) #else -# define machine_is_mx27su2() (0) +# define machine_is_beaglebone() (0) #endif
-#ifdef CONFIG_MACH_NB31 +#ifdef CONFIG_MACH_BECKER # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NB31 +# define machine_arch_type MACH_TYPE_BECKER # endif -# define machine_is_nb31() (machine_arch_type == MACH_TYPE_NB31) +# define machine_is_becker() (machine_arch_type == MACH_TYPE_BECKER) #else -# define machine_is_nb31() (0) +# define machine_is_becker() (0) #endif
-#ifdef CONFIG_MACH_HJSDU +#ifdef CONFIG_MACH_FC360 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HJSDU +# define machine_arch_type MACH_TYPE_FC360 # endif -# define machine_is_hjsdu() (machine_arch_type == MACH_TYPE_HJSDU) +# define machine_is_fc360() (machine_arch_type == MACH_TYPE_FC360) #else -# define machine_is_hjsdu() (0) +# define machine_is_fc360() (0) #endif
-#ifdef CONFIG_MACH_TD3_REV1 +#ifdef CONFIG_MACH_PMI2_XLS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TD3_REV1 +# define machine_arch_type MACH_TYPE_PMI2_XLS # endif -# define machine_is_td3_rev1() (machine_arch_type == MACH_TYPE_TD3_REV1) +# define machine_is_pmi2_xls() (machine_arch_type == MACH_TYPE_PMI2_XLS) #else -# define machine_is_td3_rev1() (0) +# define machine_is_pmi2_xls() (0) #endif
-#ifdef CONFIG_MACH_EAG_CI4000 +#ifdef CONFIG_MACH_TARANTO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_EAG_CI4000 +# define machine_arch_type MACH_TYPE_TARANTO # endif -# define machine_is_eag_ci4000() (machine_arch_type == MACH_TYPE_EAG_CI4000) +# define machine_is_taranto() (machine_arch_type == MACH_TYPE_TARANTO) #else -# define machine_is_eag_ci4000() (0) +# define machine_is_taranto() (0) #endif
-#ifdef CONFIG_MACH_NET5BIG_NAND_V2 +#ifdef CONFIG_MACH_PLUTUX # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NET5BIG_NAND_V2 +# define machine_arch_type MACH_TYPE_PLUTUX # endif -# define machine_is_net5big_nand_v2() (machine_arch_type == MACH_TYPE_NET5BIG_NAND_V2) +# define machine_is_plutux() (machine_arch_type == MACH_TYPE_PLUTUX) #else -# define machine_is_net5big_nand_v2() (0) +# define machine_is_plutux() (0) #endif
-#ifdef CONFIG_MACH_CPX2 +#ifdef CONFIG_MACH_IPMP_MEDCOM # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CPX2 +# define machine_arch_type MACH_TYPE_IPMP_MEDCOM # endif -# define machine_is_cpx2() (machine_arch_type == MACH_TYPE_CPX2) +# define machine_is_ipmp_medcom() (machine_arch_type == MACH_TYPE_IPMP_MEDCOM) #else -# define machine_is_cpx2() (0) +# define machine_is_ipmp_medcom() (0) #endif
-#ifdef CONFIG_MACH_NET2BIG_NAND_V2 +#ifdef CONFIG_MACH_ABSOLUT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NET2BIG_NAND_V2 +# define machine_arch_type MACH_TYPE_ABSOLUT # endif -# define machine_is_net2big_nand_v2() (machine_arch_type == MACH_TYPE_NET2BIG_NAND_V2) +# define machine_is_absolut() (machine_arch_type == MACH_TYPE_ABSOLUT) #else -# define machine_is_net2big_nand_v2() (0) +# define machine_is_absolut() (0) #endif
-#ifdef CONFIG_MACH_ECUV5 +#ifdef CONFIG_MACH_AWPB3 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ECUV5 +# define machine_arch_type MACH_TYPE_AWPB3 # endif -# define machine_is_ecuv5() (machine_arch_type == MACH_TYPE_ECUV5) +# define machine_is_awpb3() (machine_arch_type == MACH_TYPE_AWPB3) #else -# define machine_is_ecuv5() (0) +# define machine_is_awpb3() (0) #endif
-#ifdef CONFIG_MACH_HSGX6D +#ifdef CONFIG_MACH_NFP32XX_DT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_HSGX6D +# define machine_arch_type MACH_TYPE_NFP32XX_DT # endif -# define machine_is_hsgx6d() (machine_arch_type == MACH_TYPE_HSGX6D) +# define machine_is_nfp32xx_dt() (machine_arch_type == MACH_TYPE_NFP32XX_DT) #else -# define machine_is_hsgx6d() (0) +# define machine_is_nfp32xx_dt() (0) #endif
-#ifdef CONFIG_MACH_DAWAD7 +#ifdef CONFIG_MACH_DL_PB53 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DAWAD7 +# define machine_arch_type MACH_TYPE_DL_PB53 # endif -# define machine_is_dawad7() (machine_arch_type == MACH_TYPE_DAWAD7) +# define machine_is_dl_pb53() (machine_arch_type == MACH_TYPE_DL_PB53) #else -# define machine_is_dawad7() (0) +# define machine_is_dl_pb53() (0) #endif
-#ifdef CONFIG_MACH_SAM9REPEATER +#ifdef CONFIG_MACH_ACU_II # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SAM9REPEATER +# define machine_arch_type MACH_TYPE_ACU_II # endif -# define machine_is_sam9repeater() (machine_arch_type == MACH_TYPE_SAM9REPEATER) +# define machine_is_acu_ii() (machine_arch_type == MACH_TYPE_ACU_II) #else -# define machine_is_sam9repeater() (0) +# define machine_is_acu_ii() (0) #endif
-#ifdef CONFIG_MACH_GT_I5700 +#ifdef CONFIG_MACH_AVALON # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_GT_I5700 +# define machine_arch_type MACH_TYPE_AVALON # endif -# define machine_is_gt_i5700() (machine_arch_type == MACH_TYPE_GT_I5700) +# define machine_is_avalon() (machine_arch_type == MACH_TYPE_AVALON) #else -# define machine_is_gt_i5700() (0) +# define machine_is_avalon() (0) #endif
-#ifdef CONFIG_MACH_CTERA_PLUG_C2 +#ifdef CONFIG_MACH_SPHINX # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CTERA_PLUG_C2 +# define machine_arch_type MACH_TYPE_SPHINX # endif -# define machine_is_ctera_plug_c2() (machine_arch_type == MACH_TYPE_CTERA_PLUG_C2) +# define machine_is_sphinx() (machine_arch_type == MACH_TYPE_SPHINX) #else -# define machine_is_ctera_plug_c2() (0) +# define machine_is_sphinx() (0) #endif
-#ifdef CONFIG_MACH_MARVELCT +#ifdef CONFIG_MACH_TITAN_T # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MARVELCT +# define machine_arch_type MACH_TYPE_TITAN_T # endif -# define machine_is_marvelct() (machine_arch_type == MACH_TYPE_MARVELCT) +# define machine_is_titan_t() (machine_arch_type == MACH_TYPE_TITAN_T) #else -# define machine_is_marvelct() (0) +# define machine_is_titan_t() (0) #endif
-#ifdef CONFIG_MACH_AG11005 +#ifdef CONFIG_MACH_HARVEST_BORIS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_AG11005 +# define machine_arch_type MACH_TYPE_HARVEST_BORIS # endif -# define machine_is_ag11005() (machine_arch_type == MACH_TYPE_AG11005) +# define machine_is_harvest_boris() (machine_arch_type == MACH_TYPE_HARVEST_BORIS) #else -# define machine_is_ag11005() (0) +# define machine_is_harvest_boris() (0) #endif
-#ifdef CONFIG_MACH_VANGOGH +#ifdef CONFIG_MACH_MACH_MSM7X30_M3S # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VANGOGH +# define machine_arch_type MACH_TYPE_MACH_MSM7X30_M3S # endif -# define machine_is_vangogh() (machine_arch_type == MACH_TYPE_VANGOGH) +# define machine_is_mach_msm7x30_m3s() (machine_arch_type == MACH_TYPE_MACH_MSM7X30_M3S) #else -# define machine_is_vangogh() (0) +# define machine_is_mach_msm7x30_m3s() (0) #endif
-#ifdef CONFIG_MACH_MATRIX505 +#ifdef CONFIG_MACH_SMDK5250 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MATRIX505 +# define machine_arch_type MACH_TYPE_SMDK5250 # endif -# define machine_is_matrix505() (machine_arch_type == MACH_TYPE_MATRIX505) +# define machine_is_smdk5250() (machine_arch_type == MACH_TYPE_SMDK5250) #else -# define machine_is_matrix505() (0) +# define machine_is_smdk5250() (0) #endif
-#ifdef CONFIG_MACH_OCE_NIGMA +#ifdef CONFIG_MACH_IMXT_LITE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OCE_NIGMA +# define machine_arch_type MACH_TYPE_IMXT_LITE # endif -# define machine_is_oce_nigma() (machine_arch_type == MACH_TYPE_OCE_NIGMA) +# define machine_is_imxt_lite() (machine_arch_type == MACH_TYPE_IMXT_LITE) #else -# define machine_is_oce_nigma() (0) +# define machine_is_imxt_lite() (0) #endif
-#ifdef CONFIG_MACH_T55 +#ifdef CONFIG_MACH_IMXT_STD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_T55 +# define machine_arch_type MACH_TYPE_IMXT_STD # endif -# define machine_is_t55() (machine_arch_type == MACH_TYPE_T55) +# define machine_is_imxt_std() (machine_arch_type == MACH_TYPE_IMXT_STD) #else -# define machine_is_t55() (0) +# define machine_is_imxt_std() (0) #endif
-#ifdef CONFIG_MACH_BIO3K +#ifdef CONFIG_MACH_IMXT_LOG # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BIO3K +# define machine_arch_type MACH_TYPE_IMXT_LOG # endif -# define machine_is_bio3k() (machine_arch_type == MACH_TYPE_BIO3K) +# define machine_is_imxt_log() (machine_arch_type == MACH_TYPE_IMXT_LOG) #else -# define machine_is_bio3k() (0) +# define machine_is_imxt_log() (0) #endif
-#ifdef CONFIG_MACH_EXPRESSCT +#ifdef CONFIG_MACH_IMXT_NAV # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_EXPRESSCT +# define machine_arch_type MACH_TYPE_IMXT_NAV # endif -# define machine_is_expressct() (machine_arch_type == MACH_TYPE_EXPRESSCT) +# define machine_is_imxt_nav() (machine_arch_type == MACH_TYPE_IMXT_NAV) #else -# define machine_is_expressct() (0) +# define machine_is_imxt_nav() (0) #endif
-#ifdef CONFIG_MACH_CARDHU +#ifdef CONFIG_MACH_IMXT_FULL # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CARDHU +# define machine_arch_type MACH_TYPE_IMXT_FULL # endif -# define machine_is_cardhu() (machine_arch_type == MACH_TYPE_CARDHU) +# define machine_is_imxt_full() (machine_arch_type == MACH_TYPE_IMXT_FULL) #else -# define machine_is_cardhu() (0) +# define machine_is_imxt_full() (0) #endif
-#ifdef CONFIG_MACH_ARUBA +#ifdef CONFIG_MACH_AG09015 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ARUBA +# define machine_arch_type MACH_TYPE_AG09015 # endif -# define machine_is_aruba() (machine_arch_type == MACH_TYPE_ARUBA) +# define machine_is_ag09015() (machine_arch_type == MACH_TYPE_AG09015) #else -# define machine_is_aruba() (0) +# define machine_is_ag09015() (0) #endif
-#ifdef CONFIG_MACH_BONAIRE +#ifdef CONFIG_MACH_AM3517_MT_VENTOUX # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BONAIRE +# define machine_arch_type MACH_TYPE_AM3517_MT_VENTOUX # endif -# define machine_is_bonaire() (machine_arch_type == MACH_TYPE_BONAIRE) +# define machine_is_am3517_mt_ventoux() (machine_arch_type == MACH_TYPE_AM3517_MT_VENTOUX) #else -# define machine_is_bonaire() (0) +# define machine_is_am3517_mt_ventoux() (0) #endif
-#ifdef CONFIG_MACH_NUC700EVB +#ifdef CONFIG_MACH_DP1ARM9 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NUC700EVB +# define machine_arch_type MACH_TYPE_DP1ARM9 # endif -# define machine_is_nuc700evb() (machine_arch_type == MACH_TYPE_NUC700EVB) +# define machine_is_dp1arm9() (machine_arch_type == MACH_TYPE_DP1ARM9) #else -# define machine_is_nuc700evb() (0) +# define machine_is_dp1arm9() (0) #endif
-#ifdef CONFIG_MACH_NUC710EVB +#ifdef CONFIG_MACH_PICASSO_M # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NUC710EVB +# define machine_arch_type MACH_TYPE_PICASSO_M # endif -# define machine_is_nuc710evb() (machine_arch_type == MACH_TYPE_NUC710EVB) +# define machine_is_picasso_m() (machine_arch_type == MACH_TYPE_PICASSO_M) #else -# define machine_is_nuc710evb() (0) +# define machine_is_picasso_m() (0) #endif
-#ifdef CONFIG_MACH_NUC740EVB +#ifdef CONFIG_MACH_VIDEO_GADGET # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NUC740EVB +# define machine_arch_type MACH_TYPE_VIDEO_GADGET # endif -# define machine_is_nuc740evb() (machine_arch_type == MACH_TYPE_NUC740EVB) +# define machine_is_video_gadget() (machine_arch_type == MACH_TYPE_VIDEO_GADGET) #else -# define machine_is_nuc740evb() (0) +# define machine_is_video_gadget() (0) #endif
-#ifdef CONFIG_MACH_NUC745EVB +#ifdef CONFIG_MACH_MTT_OM3X # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NUC745EVB +# define machine_arch_type MACH_TYPE_MTT_OM3X # endif -# define machine_is_nuc745evb() (machine_arch_type == MACH_TYPE_NUC745EVB) +# define machine_is_mtt_om3x() (machine_arch_type == MACH_TYPE_MTT_OM3X) #else -# define machine_is_nuc745evb() (0) +# define machine_is_mtt_om3x() (0) #endif
-#ifdef CONFIG_MACH_TRANSCEDE +#ifdef CONFIG_MACH_MX6Q_ARM2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TRANSCEDE +# define machine_arch_type MACH_TYPE_MX6Q_ARM2 # endif -# define machine_is_transcede() (machine_arch_type == MACH_TYPE_TRANSCEDE) +# define machine_is_mx6q_arm2() (machine_arch_type == MACH_TYPE_MX6Q_ARM2) #else -# define machine_is_transcede() (0) +# define machine_is_mx6q_arm2() (0) #endif
-#ifdef CONFIG_MACH_MORA +#ifdef CONFIG_MACH_PICOSAM9G45 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MORA +# define machine_arch_type MACH_TYPE_PICOSAM9G45 # endif -# define machine_is_mora() (machine_arch_type == MACH_TYPE_MORA) +# define machine_is_picosam9g45() (machine_arch_type == MACH_TYPE_PICOSAM9G45) #else -# define machine_is_mora() (0) +# define machine_is_picosam9g45() (0) #endif
-#ifdef CONFIG_MACH_NDA_EVM +#ifdef CONFIG_MACH_VPM_DM365 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_NDA_EVM +# define machine_arch_type MACH_TYPE_VPM_DM365 # endif -# define machine_is_nda_evm() (machine_arch_type == MACH_TYPE_NDA_EVM) +# define machine_is_vpm_dm365() (machine_arch_type == MACH_TYPE_VPM_DM365) #else -# define machine_is_nda_evm() (0) +# define machine_is_vpm_dm365() (0) #endif
-#ifdef CONFIG_MACH_TIMU +#ifdef CONFIG_MACH_BONFIRE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TIMU +# define machine_arch_type MACH_TYPE_BONFIRE # endif -# define machine_is_timu() (machine_arch_type == MACH_TYPE_TIMU) +# define machine_is_bonfire() (machine_arch_type == MACH_TYPE_BONFIRE) #else -# define machine_is_timu() (0) +# define machine_is_bonfire() (0) #endif
-#ifdef CONFIG_MACH_EXPRESSH +#ifdef CONFIG_MACH_MT2P2D # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_EXPRESSH +# define machine_arch_type MACH_TYPE_MT2P2D # endif -# define machine_is_expressh() (machine_arch_type == MACH_TYPE_EXPRESSH) +# define machine_is_mt2p2d() (machine_arch_type == MACH_TYPE_MT2P2D) #else -# define machine_is_expressh() (0) +# define machine_is_mt2p2d() (0) #endif
-#ifdef CONFIG_MACH_VERIDIS_A300 +#ifdef CONFIG_MACH_SIGPDA01 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_VERIDIS_A300 +# define machine_arch_type MACH_TYPE_SIGPDA01 # endif -# define machine_is_veridis_a300() (machine_arch_type == MACH_TYPE_VERIDIS_A300) +# define machine_is_sigpda01() (machine_arch_type == MACH_TYPE_SIGPDA01) #else -# define machine_is_veridis_a300() (0) +# define machine_is_sigpda01() (0) #endif
-#ifdef CONFIG_MACH_DM368_LEOPARD +#ifdef CONFIG_MACH_CN27 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DM368_LEOPARD +# define machine_arch_type MACH_TYPE_CN27 # endif -# define machine_is_dm368_leopard() (machine_arch_type == MACH_TYPE_DM368_LEOPARD) +# define machine_is_cn27() (machine_arch_type == MACH_TYPE_CN27) #else -# define machine_is_dm368_leopard() (0) +# define machine_is_cn27() (0) #endif
-#ifdef CONFIG_MACH_OMAP_MCOP +#ifdef CONFIG_MACH_MX25_CWTAP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OMAP_MCOP +# define machine_arch_type MACH_TYPE_MX25_CWTAP # endif -# define machine_is_omap_mcop() (machine_arch_type == MACH_TYPE_OMAP_MCOP) +# define machine_is_mx25_cwtap() (machine_arch_type == MACH_TYPE_MX25_CWTAP) #else -# define machine_is_omap_mcop() (0) +# define machine_is_mx25_cwtap() (0) #endif
-#ifdef CONFIG_MACH_TRITIP +#ifdef CONFIG_MACH_APF28 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TRITIP +# define machine_arch_type MACH_TYPE_APF28 # endif -# define machine_is_tritip() (machine_arch_type == MACH_TYPE_TRITIP) +# define machine_is_apf28() (machine_arch_type == MACH_TYPE_APF28) #else -# define machine_is_tritip() (0) +# define machine_is_apf28() (0) #endif
-#ifdef CONFIG_MACH_SM1K +#ifdef CONFIG_MACH_PELCO_MAXWELL # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SM1K +# define machine_arch_type MACH_TYPE_PELCO_MAXWELL # endif -# define machine_is_sm1k() (machine_arch_type == MACH_TYPE_SM1K) +# define machine_is_pelco_maxwell() (machine_arch_type == MACH_TYPE_PELCO_MAXWELL) #else -# define machine_is_sm1k() (0) +# define machine_is_pelco_maxwell() (0) #endif
-#ifdef CONFIG_MACH_MONCH +#ifdef CONFIG_MACH_GE_PHOENIX # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MONCH +# define machine_arch_type MACH_TYPE_GE_PHOENIX # endif -# define machine_is_monch() (machine_arch_type == MACH_TYPE_MONCH) +# define machine_is_ge_phoenix() (machine_arch_type == MACH_TYPE_GE_PHOENIX) #else -# define machine_is_monch() (0) +# define machine_is_ge_phoenix() (0) #endif
-#ifdef CONFIG_MACH_CURACAO +#ifdef CONFIG_MACH_EMPC_A500 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CURACAO +# define machine_arch_type MACH_TYPE_EMPC_A500 # endif -# define machine_is_curacao() (machine_arch_type == MACH_TYPE_CURACAO) +# define machine_is_empc_a500() (machine_arch_type == MACH_TYPE_EMPC_A500) #else -# define machine_is_curacao() (0) +# define machine_is_empc_a500() (0) #endif
-#ifdef CONFIG_MACH_ORIGEN +#ifdef CONFIG_MACH_IMS_ARM9 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ORIGEN +# define machine_arch_type MACH_TYPE_IMS_ARM9 # endif -# define machine_is_origen() (machine_arch_type == MACH_TYPE_ORIGEN) +# define machine_is_ims_arm9() (machine_arch_type == MACH_TYPE_IMS_ARM9) #else -# define machine_is_origen() (0) +# define machine_is_ims_arm9() (0) #endif
-#ifdef CONFIG_MACH_EPC10 +#ifdef CONFIG_MACH_MINI2416 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_EPC10 +# define machine_arch_type MACH_TYPE_MINI2416 # endif -# define machine_is_epc10() (machine_arch_type == MACH_TYPE_EPC10) +# define machine_is_mini2416() (machine_arch_type == MACH_TYPE_MINI2416) #else -# define machine_is_epc10() (0) +# define machine_is_mini2416() (0) #endif
-#ifdef CONFIG_MACH_SGH_I740 +#ifdef CONFIG_MACH_MINI2450 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SGH_I740 +# define machine_arch_type MACH_TYPE_MINI2450 # endif -# define machine_is_sgh_i740() (machine_arch_type == MACH_TYPE_SGH_I740) +# define machine_is_mini2450() (machine_arch_type == MACH_TYPE_MINI2450) #else -# define machine_is_sgh_i740() (0) +# define machine_is_mini2450() (0) #endif
-#ifdef CONFIG_MACH_TUNA +#ifdef CONFIG_MACH_MINI310 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TUNA +# define machine_arch_type MACH_TYPE_MINI310 # endif -# define machine_is_tuna() (machine_arch_type == MACH_TYPE_TUNA) +# define machine_is_mini310() (machine_arch_type == MACH_TYPE_MINI310) #else -# define machine_is_tuna() (0) +# define machine_is_mini310() (0) #endif
-#ifdef CONFIG_MACH_MX51_TULIP +#ifdef CONFIG_MACH_SPEAR_HURRICANE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MX51_TULIP +# define machine_arch_type MACH_TYPE_SPEAR_HURRICANE # endif -# define machine_is_mx51_tulip() (machine_arch_type == MACH_TYPE_MX51_TULIP) +# define machine_is_spear_hurricane() (machine_arch_type == MACH_TYPE_SPEAR_HURRICANE) #else -# define machine_is_mx51_tulip() (0) +# define machine_is_spear_hurricane() (0) #endif
-#ifdef CONFIG_MACH_MX51_ASTER7 +#ifdef CONFIG_MACH_MT7208 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MX51_ASTER7 +# define machine_arch_type MACH_TYPE_MT7208 # endif -# define machine_is_mx51_aster7() (machine_arch_type == MACH_TYPE_MX51_ASTER7) +# define machine_is_mt7208() (machine_arch_type == MACH_TYPE_MT7208) #else -# define machine_is_mx51_aster7() (0) +# define machine_is_mt7208() (0) #endif
-#ifdef CONFIG_MACH_ACRO37XBRD +#ifdef CONFIG_MACH_LPC178X # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ACRO37XBRD +# define machine_arch_type MACH_TYPE_LPC178X # endif -# define machine_is_acro37xbrd() (machine_arch_type == MACH_TYPE_ACRO37XBRD) +# define machine_is_lpc178x() (machine_arch_type == MACH_TYPE_LPC178X) #else -# define machine_is_acro37xbrd() (0) +# define machine_is_lpc178x() (0) #endif
-#ifdef CONFIG_MACH_ELKE +#ifdef CONFIG_MACH_FARLEYS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ELKE +# define machine_arch_type MACH_TYPE_FARLEYS # endif -# define machine_is_elke() (machine_arch_type == MACH_TYPE_ELKE) +# define machine_is_farleys() (machine_arch_type == MACH_TYPE_FARLEYS) #else -# define machine_is_elke() (0) +# define machine_is_farleys() (0) #endif
-#ifdef CONFIG_MACH_SBC6000X +#ifdef CONFIG_MACH_EFM32GG_DK3750 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SBC6000X +# define machine_arch_type MACH_TYPE_EFM32GG_DK3750 # endif -# define machine_is_sbc6000x() (machine_arch_type == MACH_TYPE_SBC6000X) +# define machine_is_efm32gg_dk3750() (machine_arch_type == MACH_TYPE_EFM32GG_DK3750) #else -# define machine_is_sbc6000x() (0) +# define machine_is_efm32gg_dk3750() (0) #endif
-#ifdef CONFIG_MACH_R1801E +#ifdef CONFIG_MACH_ZEUS_BOARD # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_R1801E +# define machine_arch_type MACH_TYPE_ZEUS_BOARD # endif -# define machine_is_r1801e() (machine_arch_type == MACH_TYPE_R1801E) +# define machine_is_zeus_board() (machine_arch_type == MACH_TYPE_ZEUS_BOARD) #else -# define machine_is_r1801e() (0) +# define machine_is_zeus_board() (0) #endif
-#ifdef CONFIG_MACH_H1600 +#ifdef CONFIG_MACH_CC51 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_H1600 +# define machine_arch_type MACH_TYPE_CC51 # endif -# define machine_is_h1600() (machine_arch_type == MACH_TYPE_H1600) +# define machine_is_cc51() (machine_arch_type == MACH_TYPE_CC51) #else -# define machine_is_h1600() (0) +# define machine_is_cc51() (0) #endif
-#ifdef CONFIG_MACH_MINI210 +#ifdef CONFIG_MACH_FXI_C210 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MINI210 +# define machine_arch_type MACH_TYPE_FXI_C210 # endif -# define machine_is_mini210() (machine_arch_type == MACH_TYPE_MINI210) +# define machine_is_fxi_c210() (machine_arch_type == MACH_TYPE_FXI_C210) #else -# define machine_is_mini210() (0) +# define machine_is_fxi_c210() (0) #endif
-#ifdef CONFIG_MACH_MINI8168 +#ifdef CONFIG_MACH_MSM8627_CDP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MINI8168 +# define machine_arch_type MACH_TYPE_MSM8627_CDP # endif -# define machine_is_mini8168() (machine_arch_type == MACH_TYPE_MINI8168) +# define machine_is_msm8627_cdp() (machine_arch_type == MACH_TYPE_MSM8627_CDP) #else -# define machine_is_mini8168() (0) +# define machine_is_msm8627_cdp() (0) #endif
-#ifdef CONFIG_MACH_PC7308 +#ifdef CONFIG_MACH_MSM8627_MTP # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PC7308 +# define machine_arch_type MACH_TYPE_MSM8627_MTP # endif -# define machine_is_pc7308() (machine_arch_type == MACH_TYPE_PC7308) +# define machine_is_msm8627_mtp() (machine_arch_type == MACH_TYPE_MSM8627_MTP) #else -# define machine_is_pc7308() (0) +# define machine_is_msm8627_mtp() (0) #endif
-#ifdef CONFIG_MACH_KMM2M01 +#ifdef CONFIG_MACH_ARMADILLO800EVA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_KMM2M01 +# define machine_arch_type MACH_TYPE_ARMADILLO800EVA # endif -# define machine_is_kmm2m01() (machine_arch_type == MACH_TYPE_KMM2M01) +# define machine_is_armadillo800eva() (machine_arch_type == MACH_TYPE_ARMADILLO800EVA) #else -# define machine_is_kmm2m01() (0) +# define machine_is_armadillo800eva() (0) #endif
-#ifdef CONFIG_MACH_MX51EREBUS +#ifdef CONFIG_MACH_PRIMOU # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MX51EREBUS +# define machine_arch_type MACH_TYPE_PRIMOU # endif -# define machine_is_mx51erebus() (machine_arch_type == MACH_TYPE_MX51EREBUS) +# define machine_is_primou() (machine_arch_type == MACH_TYPE_PRIMOU) #else -# define machine_is_mx51erebus() (0) +# define machine_is_primou() (0) #endif
-#ifdef CONFIG_MACH_WM8650REFBOARD +#ifdef CONFIG_MACH_PRIMOC # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_WM8650REFBOARD +# define machine_arch_type MACH_TYPE_PRIMOC # endif -# define machine_is_wm8650refboard() (machine_arch_type == MACH_TYPE_WM8650REFBOARD) +# define machine_is_primoc() (machine_arch_type == MACH_TYPE_PRIMOC) #else -# define machine_is_wm8650refboard() (0) +# define machine_is_primoc() (0) #endif
-#ifdef CONFIG_MACH_TUXRAIL +#ifdef CONFIG_MACH_PRIMOCT # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_TUXRAIL +# define machine_arch_type MACH_TYPE_PRIMOCT # endif -# define machine_is_tuxrail() (machine_arch_type == MACH_TYPE_TUXRAIL) +# define machine_is_primoct() (machine_arch_type == MACH_TYPE_PRIMOCT) #else -# define machine_is_tuxrail() (0) +# define machine_is_primoct() (0) #endif
-#ifdef CONFIG_MACH_ARTHUR +#ifdef CONFIG_MACH_A9500 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ARTHUR +# define machine_arch_type MACH_TYPE_A9500 # endif -# define machine_is_arthur() (machine_arch_type == MACH_TYPE_ARTHUR) +# define machine_is_a9500() (machine_arch_type == MACH_TYPE_A9500) #else -# define machine_is_arthur() (0) +# define machine_is_a9500() (0) #endif
-#ifdef CONFIG_MACH_DOORBOY +#ifdef CONFIG_MACH_PLUTO # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DOORBOY +# define machine_arch_type MACH_TYPE_PLUTO # endif -# define machine_is_doorboy() (machine_arch_type == MACH_TYPE_DOORBOY) +# define machine_is_pluto() (machine_arch_type == MACH_TYPE_PLUTO) #else -# define machine_is_doorboy() (0) +# define machine_is_pluto() (0) #endif
-#ifdef CONFIG_MACH_XARINA +#ifdef CONFIG_MACH_ACFX100 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_XARINA +# define machine_arch_type MACH_TYPE_ACFX100 # endif -# define machine_is_xarina() (machine_arch_type == MACH_TYPE_XARINA) +# define machine_is_acfx100() (machine_arch_type == MACH_TYPE_ACFX100) #else -# define machine_is_xarina() (0) +# define machine_is_acfx100() (0) #endif
-#ifdef CONFIG_MACH_ROVERX7 +#ifdef CONFIG_MACH_MSM8625_RUMI3 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ROVERX7 +# define machine_arch_type MACH_TYPE_MSM8625_RUMI3 # endif -# define machine_is_roverx7() (machine_arch_type == MACH_TYPE_ROVERX7) +# define machine_is_msm8625_rumi3() (machine_arch_type == MACH_TYPE_MSM8625_RUMI3) #else -# define machine_is_roverx7() (0) +# define machine_is_msm8625_rumi3() (0) #endif
-#ifdef CONFIG_MACH_SDVR +#ifdef CONFIG_MACH_VALENTE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SDVR +# define machine_arch_type MACH_TYPE_VALENTE # endif -# define machine_is_sdvr() (machine_arch_type == MACH_TYPE_SDVR) +# define machine_is_valente() (machine_arch_type == MACH_TYPE_VALENTE) #else -# define machine_is_sdvr() (0) +# define machine_is_valente() (0) #endif
-#ifdef CONFIG_MACH_ACER_MAYA +#ifdef CONFIG_MACH_CRFS_RFEYE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ACER_MAYA +# define machine_arch_type MACH_TYPE_CRFS_RFEYE # endif -# define machine_is_acer_maya() (machine_arch_type == MACH_TYPE_ACER_MAYA) +# define machine_is_crfs_rfeye() (machine_arch_type == MACH_TYPE_CRFS_RFEYE) #else -# define machine_is_acer_maya() (0) +# define machine_is_crfs_rfeye() (0) #endif
-#ifdef CONFIG_MACH_PICO +#ifdef CONFIG_MACH_RFEYE # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_PICO +# define machine_arch_type MACH_TYPE_RFEYE # endif -# define machine_is_pico() (machine_arch_type == MACH_TYPE_PICO) +# define machine_is_rfeye() (machine_arch_type == MACH_TYPE_RFEYE) #else -# define machine_is_pico() (0) +# define machine_is_rfeye() (0) #endif
-#ifdef CONFIG_MACH_CWMX233 +#ifdef CONFIG_MACH_PHIDGET_SBC3 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CWMX233 +# define machine_arch_type MACH_TYPE_PHIDGET_SBC3 # endif -# define machine_is_cwmx233() (machine_arch_type == MACH_TYPE_CWMX233) +# define machine_is_phidget_sbc3() (machine_arch_type == MACH_TYPE_PHIDGET_SBC3) #else -# define machine_is_cwmx233() (0) +# define machine_is_phidget_sbc3() (0) #endif
-#ifdef CONFIG_MACH_CWAM1808 +#ifdef CONFIG_MACH_TCW_MIKA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CWAM1808 +# define machine_arch_type MACH_TYPE_TCW_MIKA # endif -# define machine_is_cwam1808() (machine_arch_type == MACH_TYPE_CWAM1808) +# define machine_is_tcw_mika() (machine_arch_type == MACH_TYPE_TCW_MIKA) #else -# define machine_is_cwam1808() (0) +# define machine_is_tcw_mika() (0) #endif
-#ifdef CONFIG_MACH_CWDM365 +#ifdef CONFIG_MACH_IMX28_EGF # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_CWDM365 +# define machine_arch_type MACH_TYPE_IMX28_EGF # endif -# define machine_is_cwdm365() (machine_arch_type == MACH_TYPE_CWDM365) +# define machine_is_imx28_egf() (machine_arch_type == MACH_TYPE_IMX28_EGF) #else -# define machine_is_cwdm365() (0) +# define machine_is_imx28_egf() (0) #endif
-#ifdef CONFIG_MACH_MX51_MORAY +#ifdef CONFIG_MACH_VALENTE_WX # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_MX51_MORAY +# define machine_arch_type MACH_TYPE_VALENTE_WX # endif -# define machine_is_mx51_moray() (machine_arch_type == MACH_TYPE_MX51_MORAY) +# define machine_is_valente_wx() (machine_arch_type == MACH_TYPE_VALENTE_WX) #else -# define machine_is_mx51_moray() (0) +# define machine_is_valente_wx() (0) #endif
-#ifdef CONFIG_MACH_THALES_CBC +#ifdef CONFIG_MACH_HUANGSHANS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_THALES_CBC +# define machine_arch_type MACH_TYPE_HUANGSHANS # endif -# define machine_is_thales_cbc() (machine_arch_type == MACH_TYPE_THALES_CBC) +# define machine_is_huangshans() (machine_arch_type == MACH_TYPE_HUANGSHANS) #else -# define machine_is_thales_cbc() (0) +# define machine_is_huangshans() (0) #endif
-#ifdef CONFIG_MACH_BLUEPOINT +#ifdef CONFIG_MACH_BOSPHORUS1 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BLUEPOINT +# define machine_arch_type MACH_TYPE_BOSPHORUS1 # endif -# define machine_is_bluepoint() (machine_arch_type == MACH_TYPE_BLUEPOINT) +# define machine_is_bosphorus1() (machine_arch_type == MACH_TYPE_BOSPHORUS1) #else -# define machine_is_bluepoint() (0) +# define machine_is_bosphorus1() (0) #endif
-#ifdef CONFIG_MACH_DIR665 +#ifdef CONFIG_MACH_PRIMA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_DIR665 +# define machine_arch_type MACH_TYPE_PRIMA # endif -# define machine_is_dir665() (machine_arch_type == MACH_TYPE_DIR665) +# define machine_is_prima() (machine_arch_type == MACH_TYPE_PRIMA) #else -# define machine_is_dir665() (0) +# define machine_is_prima() (0) #endif
-#ifdef CONFIG_MACH_ACMEROVER1 +#ifdef CONFIG_MACH_EVITA_ULK # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ACMEROVER1 +# define machine_arch_type MACH_TYPE_EVITA_ULK # endif -# define machine_is_acmerover1() (machine_arch_type == MACH_TYPE_ACMEROVER1) +# define machine_is_evita_ulk() (machine_arch_type == MACH_TYPE_EVITA_ULK) #else -# define machine_is_acmerover1() (0) +# define machine_is_evita_ulk() (0) #endif
-#ifdef CONFIG_MACH_SHOOTER_CT +#ifdef CONFIG_MACH_MERISC600 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_SHOOTER_CT +# define machine_arch_type MACH_TYPE_MERISC600 # endif -# define machine_is_shooter_ct() (machine_arch_type == MACH_TYPE_SHOOTER_CT) +# define machine_is_merisc600() (machine_arch_type == MACH_TYPE_MERISC600) #else -# define machine_is_shooter_ct() (0) +# define machine_is_merisc600() (0) #endif
-#ifdef CONFIG_MACH_BLISS +#ifdef CONFIG_MACH_DOLAK # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BLISS +# define machine_arch_type MACH_TYPE_DOLAK # endif -# define machine_is_bliss() (machine_arch_type == MACH_TYPE_BLISS) +# define machine_is_dolak() (machine_arch_type == MACH_TYPE_DOLAK) #else -# define machine_is_bliss() (0) +# define machine_is_dolak() (0) #endif
-#ifdef CONFIG_MACH_BLISSC +#ifdef CONFIG_MACH_SBC53 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_BLISSC +# define machine_arch_type MACH_TYPE_SBC53 # endif -# define machine_is_blissc() (machine_arch_type == MACH_TYPE_BLISSC) +# define machine_is_sbc53() (machine_arch_type == MACH_TYPE_SBC53) #else -# define machine_is_blissc() (0) +# define machine_is_sbc53() (0) #endif
-#ifdef CONFIG_MACH_THALES_ADC +#ifdef CONFIG_MACH_ELITE_ULK # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_THALES_ADC +# define machine_arch_type MACH_TYPE_ELITE_ULK # endif -# define machine_is_thales_adc() (machine_arch_type == MACH_TYPE_THALES_ADC) +# define machine_is_elite_ulk() (machine_arch_type == MACH_TYPE_ELITE_ULK) #else -# define machine_is_thales_adc() (0) +# define machine_is_elite_ulk() (0) #endif
-#ifdef CONFIG_MACH_UBISYS_P9D_EVP +#ifdef CONFIG_MACH_POV2 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_UBISYS_P9D_EVP +# define machine_arch_type MACH_TYPE_POV2 # endif -# define machine_is_ubisys_p9d_evp() (machine_arch_type == MACH_TYPE_UBISYS_P9D_EVP) +# define machine_is_pov2() (machine_arch_type == MACH_TYPE_POV2) #else -# define machine_is_ubisys_p9d_evp() (0) +# define machine_is_pov2() (0) #endif
-#ifdef CONFIG_MACH_ATDGP318 +#ifdef CONFIG_MACH_IPOD_TOUCH_2G # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_ATDGP318 +# define machine_arch_type MACH_TYPE_IPOD_TOUCH_2G # endif -# define machine_is_atdgp318() (machine_arch_type == MACH_TYPE_ATDGP318) +# define machine_is_ipod_touch_2g() (machine_arch_type == MACH_TYPE_IPOD_TOUCH_2G) #else -# define machine_is_atdgp318() (0) +# define machine_is_ipod_touch_2g() (0) #endif
-#ifdef CONFIG_MACH_OMAP5_SEVM +#ifdef CONFIG_MACH_DA850_PQAB # ifdef machine_arch_type # undef machine_arch_type -# define machine_arch_type __machine_arch_type +# define machine_arch_type __machine_arch_type # else -# define machine_arch_type MACH_TYPE_OMAP5_SEVM +# define machine_arch_type MACH_TYPE_DA850_PQAB # endif -# define machine_is_omap5_sevm() (machine_arch_type == MACH_TYPE_OMAP5_SEVM) +# define machine_is_da850_pqab() (machine_arch_type == MACH_TYPE_DA850_PQAB) #else -# define machine_is_omap5_sevm() (0) +# define machine_is_da850_pqab() (0) #endif
/* diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 6683b3e..c57c25a 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -30,8 +30,7 @@ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (8 * 1024)) #define CONFIG_SYS_PROMPT "U-Boot# " #define CONFIG_SYS_NO_FLASH -#define MACH_TYPE_TIAM335EVM 3589 /* Until the next sync */ -#define CONFIG_MACH_TYPE MACH_TYPE_TIAM335EVM +#define CONFIG_MACH_TYPE MACH_TYPE_AM335XEVM
#define CONFIG_CMD_ASKENV #define CONFIG_VERSION_VARIABLE diff --git a/include/configs/calimain.h b/include/configs/calimain.h index 6b68f10..bcf8b8f 100644 --- a/include/configs/calimain.h +++ b/include/configs/calimain.h @@ -28,7 +28,6 @@ * Board */ #define CONFIG_DRIVER_TI_EMAC -#define MACH_TYPE_CALIMAIN 3528 #define CONFIG_MACH_TYPE MACH_TYPE_CALIMAIN
/* diff --git a/include/configs/dns325.h b/include/configs/dns325.h index b7a89d3..4ab7b86 100644 --- a/include/configs/dns325.h +++ b/include/configs/dns325.h @@ -32,7 +32,6 @@ /* * Machine number definition */ -#define MACH_TYPE_DNS325 3800 #define CONFIG_MACH_TYPE MACH_TYPE_DNS325 #define CONFIG_IDENT_STRING "\nD-Link DNS-325"
diff --git a/include/configs/dreamplug.h b/include/configs/dreamplug.h index 0f2f9a2..e63e818 100644 --- a/include/configs/dreamplug.h +++ b/include/configs/dreamplug.h @@ -29,19 +29,6 @@ #define _CONFIG_DREAMPLUG_H
/* - * FIXME: This belongs in mach-types.h. However, we only pull mach-types - * from Linus' kernel.org tree. This hasn't been updated primarily due to - * the recent arch/arm reshuffling. So, in the meantime, we'll place it - * here. - */ -#include <asm/mach-types.h> -#ifdef MACH_TYPE_DREAMPLUG -#error "MACH_TYPE_DREAMPLUG has been defined properly, please remove this." -#else -#define MACH_TYPE_DREAMPLUG 3550 -#endif - -/* * Version number information */ #define CONFIG_IDENT_STRING "\nMarvell-DreamPlug" diff --git a/include/configs/ea20.h b/include/configs/ea20.h index b4610d9..da49ae8 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -24,6 +24,18 @@ #define __CONFIG_H
/* + * FIXME: This belongs in mach-types.h. However, we only pull mach-types + * from Linus' kernel.org tree. + */ +#include <asm/mach-types.h> +#ifdef MACH_TYPE_EA20 +#error "MACH_TYPE_EA20 has been defined properly, please remove this." +#else +#define MACH_TYPE_EA20 3002 +#endif + + +/* * Board */ #define CONFIG_DRIVER_TI_EMAC diff --git a/include/configs/enbw_cmc.h b/include/configs/enbw_cmc.h index 29b0d33..8fa3185 100644 --- a/include/configs/enbw_cmc.h +++ b/include/configs/enbw_cmc.h @@ -53,7 +53,6 @@ #define CONFIG_DA8XX_GPIO #define CONFIG_HOSTNAME enbw_cmc
-#define MACH_TYPE_ENBW_CMC 3585 #define CONFIG_MACH_TYPE MACH_TYPE_ENBW_CMC
/* diff --git a/include/configs/flea3.h b/include/configs/flea3.h index 649e272..a1ac87a 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -37,11 +37,6 @@
#define CONFIG_DISPLAY_CPUINFO
-/* Only in case the value is not present in mach-types.h */ -#ifndef MACH_TYPE_FLEA3 -#define MACH_TYPE_FLEA3 3668 -#endif - #define CONFIG_MACH_TYPE MACH_TYPE_FLEA3
/* Set TEXT at the beginning of the NOR flash */ diff --git a/include/configs/gplugd.h b/include/configs/gplugd.h index 9813309..04fe1c3 100644 --- a/include/configs/gplugd.h +++ b/include/configs/gplugd.h @@ -32,16 +32,6 @@ #define __CONFIG_GPLUGD_H
/* - * FIXME: fix for error caused due to recent update to mach-types.h - */ -#include <asm/mach-types.h> -#ifdef MACH_TYPE_SHEEVAD -#error "MACH_TYPE_SHEEVAD has been defined properly, please remove this." -#else -#define MACH_TYPE_SHEEVAD 2625 -#endif - -/* * Version number information */ #define CONFIG_IDENT_STRING "\nMarvell-gplugD" @@ -52,7 +42,7 @@ #define CONFIG_SHEEVA_88SV331xV5 1 /* CPU Core subversion */ #define CONFIG_ARMADA100 1 /* SOC Family Name */ #define CONFIG_ARMADA168 1 /* SOC Used on this Board */ -#define CONFIG_MACH_TYPE MACH_TYPE_SHEEVAD /* Machine type */ +#define CONFIG_MACH_TYPE MACH_TYPE_GPLUGD /* Machine type */ #define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
#define CONFIG_SYS_TEXT_BASE 0x00f00000 diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index 4d59153..b035767 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -29,11 +29,6 @@ #define CONFIG_MXS_GPIO /* GPIO control */ #define CONFIG_SYS_HZ 1000 /* Ticks per second */
-/* - * Define M28EVK machine type by hand until it lands in mach-types - */ -#define MACH_TYPE_M28EVK 3613 - #define CONFIG_MACH_TYPE MACH_TYPE_M28EVK
#define CONFIG_SYS_NO_FLASH diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 1315c3c..96a43ef 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -28,7 +28,6 @@ #define CONFIG_OMAP34XX /* which is a 34XX */ #define CONFIG_OMAP3_MCX /* working with mcx */
-#define MACH_TYPE_MCX 3656 #define CONFIG_MACH_TYPE MACH_TYPE_MCX
#define CONFIG_SYS_CACHELINE_SIZE 64 diff --git a/include/configs/mt_ventoux.h b/include/configs/mt_ventoux.h index 2034b59..c3ecaf8 100644 --- a/include/configs/mt_ventoux.h +++ b/include/configs/mt_ventoux.h @@ -24,7 +24,6 @@
#include "tam3517-common.h"
-#define MACH_TYPE_AM3517_MT_VENTOUX 3832 #define CONFIG_MACH_TYPE MACH_TYPE_AM3517_MT_VENTOUX
#define CONFIG_BOOTDELAY 10 diff --git a/include/configs/omap3_mvblx.h b/include/configs/omap3_mvblx.h index b819d21..79ef97b 100644 --- a/include/configs/omap3_mvblx.h +++ b/include/configs/omap3_mvblx.h @@ -32,6 +32,17 @@ #define __CONFIG_H
/* + * FIXME: This belongs in mach-types.h. However, we only pull mach-types + * from Linus' kernel.org tree. + */ +#include <asm/mach-types.h> +#ifdef MACH_TYPE_MVBLX +#error "MACH_TYPE_MVBLX has been defined properly, please remove this." +#else +#define MACH_TYPE_MVBLX 3097 +#endif + +/* * High Level Configuration Options */ #define CONFIG_ARMV7 1 /* This is an ARM V7 CPU core */ diff --git a/include/configs/seaboard.h b/include/configs/seaboard.h index 261f952..8589b1d 100644 --- a/include/configs/seaboard.h +++ b/include/configs/seaboard.h @@ -45,6 +45,13 @@
#define CONFIG_BOARD_EARLY_INIT_F
+/* + * FIXME: This belongs in mach-types.h. However, we only pull mach-types + * from Linus' kernel.org tree. + */ +#define machine_is_ventana() (0) + + /* SPI */ #define CONFIG_TEGRA2_SPI #define CONFIG_SPI_FLASH diff --git a/include/configs/smdk5250.h b/include/configs/smdk5250.h index 9659f9e..f20633c 100644 --- a/include/configs/smdk5250.h +++ b/include/configs/smdk5250.h @@ -51,8 +51,6 @@ #define CONFIG_INITRD_TAG #define CONFIG_CMDLINE_EDITING
-/* MACH_TYPE_SMDK5250 macro will be removed once added to mach-types */ -#define MACH_TYPE_SMDK5250 3774 #define CONFIG_MACH_TYPE MACH_TYPE_SMDK5250
/* Power Down Modes */ diff --git a/include/configs/top9000.h b/include/configs/top9000.h index 2c66f33..d311e50 100644 --- a/include/configs/top9000.h +++ b/include/configs/top9000.h @@ -38,6 +38,17 @@ #ifndef __CONFIG_H #define __CONFIG_H
+/* + * FIXME: This belongs in mach-types.h. However, we only pull mach-types + * from Linus' kernel.org tree. + */ +#include <asm/mach-types.h> +#ifdef MACH_TYPE_TOP9000 +#error "MACH_TYPE_TOP9000 has been defined properly, please remove this." +#else +#define MACH_TYPE_TOP9000 3024 +#endif + /* SoC must be defined first, before hardware.h is included */ #define CONFIG_AT91SAM9XE #include <asm/hardware.h> diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index ba8847b..31df1fa 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -32,6 +32,17 @@ #ifndef __CONFIG_H #define __CONFIG_H
+/* + * FIXME: This belongs in mach-types.h. However, we only pull mach-types + * from Linus' kernel.org tree. + */ +#include <asm/mach-types.h> +#ifdef MACH_TYPE_TRICORDER +#error "MACH_TYPE_TRICORDER has been defined properly, please remove this." +#else +#define MACH_TYPE_TRICORDER 3042 +#endif + /* High Level Configuration Options */ #define CONFIG_OMAP /* in a TI OMAP core */ #define CONFIG_OMAP34XX /* which is a 34XX */ diff --git a/include/configs/tx25.h b/include/configs/tx25.h index 87bd8a6..0d24039 100644 --- a/include/configs/tx25.h +++ b/include/configs/tx25.h @@ -34,10 +34,6 @@ /* NAND BOOT is the only boot method */ #define CONFIG_NAND_U_BOOT
-#ifndef MACH_TYPE_TX25 -#define MACH_TYPE_TX25 2177 -#endif - #define CONFIG_MACH_TYPE MACH_TYPE_TX25
#ifdef CONFIG_NAND_SPL diff --git a/include/configs/ventana.h b/include/configs/ventana.h index b5caebb..8e8a8e3 100644 --- a/include/configs/ventana.h +++ b/include/configs/ventana.h @@ -25,6 +25,21 @@ #define __CONFIG_H
#define CONFIG_MACH_VENTANA +/* + * FIXME: This belongs in mach-types.h. However, we only pull mach-types + * from Linus' kernel.org tree. + */ +#include <asm/mach-types.h> +#ifdef MACH_TYPE_VENTANA +#error "MACH_TYPE_VENTANA has been defined properly, please remove this." +#else +#define MACH_TYPE_VENTANA 2927 +#ifdef CONFIG_MACH_VENTANA +# define machine_is_ventana() (MACH_TYPE_VENTANA == MACH_TYPE_VENTANA) +#else +# define machine_is_ventana() (0) +#endif +#endif
#include <asm/sizes.h> #include "tegra2-common.h" diff --git a/include/configs/zmx25.h b/include/configs/zmx25.h index 599d5bb..071c582 100644 --- a/include/configs/zmx25.h +++ b/include/configs/zmx25.h @@ -26,6 +26,17 @@ #ifndef __CONFIG_H #define __CONFIG_H
+/* + * FIXME: This belongs in mach-types.h. However, we only pull mach-types + * from Linus' kernel.org tree. + */ +#include <asm/mach-types.h> +#ifdef MACH_TYPE_ZMX25 +#error "MACH_TYPE_ZMX25 has been defined properly, please remove this." +#else +#define MACH_TYPE_ZMX25 3113 +#endif + #define CONFIG_ARM926EJS /* arm926ejs CPU core */ #define CONFIG_MX25 #define CONFIG_MX25_CLK32 32768 /* OSC32K frequency */
On 03/01/2012 02:13 PM, Troy Kisky wrote:
This updates u-boot to the same as the Dec 6, 2011 mach-types upate to Linux.
- FIXME: This belongs in mach-types.h. However, we only pull mach-types
- from Linus' kernel.org tree.
I'm curious how Seaboard still builds after this change; presumably ventana.h isn't included in the Seaboard build because the build isn't for Ventana, yet without ventana.h included, machine_is_ventana() doesn't exist.
Hi Troy,
+#include<asm/mach-types.h> +#ifdef MACH_TYPE_EA20 +#error "MACH_TYPE_EA20 has been defined properly, please remove this." +#else +#define MACH_TYPE_EA20 3002 +#endif
Sorry if I am being pedantic here, but the "FIXME" comment actually belongs *below* the #include line, not above. Ditto for others.
Not sure I understand why we have a "machine_ix_xxx()" here. Could you explain?
Amicalement,
On 3/1/2012 2:54 PM, Albert ARIBAUD wrote:
Hi Troy,
mach-types
I put it above because when it is moved to mach-types.h, the include should be deleted as well. That is part of the "FIXME."
mach-types
Amicalement,
Because board/nvidia/seaboard/seaboard.c uses machine_is_ventana but that machine is no longer in mach-types.
Thanks Troy
Dear Troy Kisky,
In message 4F4FFD1F.4080406@boundarydevices.com you wrote:
Not sure I understand why we have a "machine_ix_xxx()" here. Could you > explain?
Amicalement,
Because board/nvidia/seaboard/seaboard.c uses machine_is_ventana but > that machine is no longer in mach-types.
Then fix the seaboard.c code, please, instead of adding dead code.
On 03/02/2012 12:00 AM, Wolfgang Denk wrote:
Dear Troy Kisky,
Amicalement,
I think that should actually be very easy. Can't the following:
if (machine_is_foo()) { ... }
be converted to:
#if CONFIG_MACH_TYPE == MACH_TYPE_FOO ... #endif
As a related note, I expect you'll see more and more boards that don't exist in the kernel's mach-type.h since people won't register machine IDs for boards that only support device tree.
Dear Troy Kisky,
In message4F4FFD1F.4080406@boundarydevices.com you wrote:
Not sure I understand why we have a "machine_ix_xxx()" here. Could you> explain?
Amicalement,
Because board/nvidia/seaboard/seaboard.c uses machine_is_ventana but> that machine is no longer in mach-types.
be converted to:
How about reversing the test
#if CONFIG_MACH_TYPE == MACH_TYPE_SEABORD
instead of
#if CONFIG_MACH_TYPE == MACH_TYPE_VENTANA
so that I don't care that ventana is no longer defined?
Thanks Troy
Dear Troy Kisky,
Amicalement,
be converted to:
instead of
That's probably fine.
A comment right above that states that Ventana is the other possibility would be useful.
Of course, this isn't going to solve anything when we have 3 variants of Seaboard, and only Seaboard is in mach-types.h but not the other 2, but I suppose we can deal with that when it happens.
Hi Troy,
mach-types
Did I convince you, or do you still want it changed?
Thanks Troy
On 01/03/2012 22:13, Troy Kisky wrote:
mach-type update will rename MACH_TYPE_SHEEVAD to MACH_TYPE_GPLUGD
Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com
board/Marvell/gplugd/gplugd.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/board/Marvell/gplugd/gplugd.c b/board/Marvell/gplugd/gplugd.c index a697c19..8d9916a 100644 --- a/board/Marvell/gplugd/gplugd.c +++ b/board/Marvell/gplugd/gplugd.c @@ -92,7 +92,7 @@ int board_init(void) (struct armd1apb2_registers *)ARMD1_APBC2_BASE;
/* arch number of Board */
- gd->bd->bi_arch_number = MACH_TYPE_SHEEVAD;
- gd->bd->bi_arch_number = CONFIG_MACH_TYPE;
You do not need it to add this line. This is already done in common code when CONFIG_MACH_TYPE is set.
Best regards, Stefano Babic
participants (5)
Albert ARIBAUD
Stefano Babic
Stephen Warren
Troy Kisky
