[PATCH] net: tftp: don't call stop callback from UDP handler
From: Alexander Sverdlin alexander.sverdlin@siemens.com
Contrary to doc/develop/driver-model/ethernet.rst contract, eth_ops .free_pkt can be called after .stop, there are several error paths in TFTP, for instance:
eth_halt() <= tftp_handler() <= net_process_received_packet() <= eth_rx() ... am65_cpsw_free_pkt() <= eth_rx()
Which results in (deliberately "tftpboot"ing non-existing file):
TFTP error: 'File not found' (1) Not retrying... am65_cpsw_nuss_port ethernet@8000000port@1: RX dma free_pkt failed -22
Avoid the DMA error message (and follow the documentation) by deferring eth_halt() until net_loop() calls net_start_again() and only do eth_halt_state_only() instead.
Fixes: aafda38fb266 ("Add error codes/handling for TFTP-server") Signed-off-by: Alexander Sverdlin alexander.sverdlin@siemens.com --- net/eth-uclass.c | 2 ++ net/tftp.c | 4 ++-- 2 files changed, 4 insertions(+), 2 deletions(-)
This isn't a v2, but a completely different approach to https://patchwork.ozlabs.org/project/uboot/patch/20240508183605.955341-1-ale...
diff --git a/net/eth-uclass.c b/net/eth-uclass.c index 193218a328b..9863db59d68 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -450,6 +450,8 @@ int eth_rx(void) eth_get_ops(current)->free_pkt(current, packet, ret); if (ret <= 0) break; + if (!eth_is_active(current)) + break; } if (ret == -EAGAIN) ret = 0; diff --git a/net/tftp.c b/net/tftp.c index 2e335413492..081014a1fde 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -649,7 +649,7 @@ static void tftp_handler(uchar *pkt, unsigned dest, struct in_addr sip, net_set_timeout_handler(timeout_ms, tftp_timeout_handler);
if (store_block(tftp_cur_block, pkt + 2, len)) { - eth_halt(); + eth_halt_state_only(); net_set_state(NETLOOP_FAIL); break; } @@ -678,7 +678,7 @@ static void tftp_handler(uchar *pkt, unsigned dest, struct in_addr sip, case TFTP_ERR_FILE_NOT_FOUND: case TFTP_ERR_ACCESS_DENIED: puts("Not retrying...\n"); - eth_halt(); + eth_halt_state_only(); net_set_state(NETLOOP_FAIL); break; case TFTP_ERR_UNDEFINED:
A. Sverdlin
