[PATCH v2] initcall: break loop immediately on failure
The current ordering always results in func pointing to the next function in the init_sequence. e.g. if fdtdec_setup() fails, ret will be set to the error code, then func will be updated to point to initf_malloc(), only then is ret checked and the loop broken. The end result of this is that the "initcall failed at ..." error will point you to initf_malloc(), when the error actually occured in fdtdec_setup()!
This can be quite confusing and result in a lot of time wasted debugging code that has nothing to do with the failure (ask me how I know :P).
Adjust the for loop to check ret immediately after the call and break early so that func will correctly reference the failed function.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- Changes in v2: - Don't drop the initialisation of ret (thanks Dan!). - Link to v1: https://lore.kernel.org/u-boot/20240219183519.2183405-1-caleb.connolly@linar...
Cc: Dan Carpenter dan.carpenter@linaro.org --- lib/initcall.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/lib/initcall.c b/lib/initcall.c index ce317af213ab..c8e2b0f6a386 100644 --- a/lib/initcall.c +++ b/lib/initcall.c @@ -54,9 +54,9 @@ int initcall_run_list(const init_fnc_t init_sequence[]) enum event_t type; init_fnc_t func; int ret = 0;
- for (ptr = init_sequence; func = *ptr, !ret && func; ptr++) { + for (ptr = init_sequence; func = *ptr, func; ptr++) { type = initcall_is_event(func);
if (type) { if (!CONFIG_IS_ENABLED(EVENT)) @@ -70,8 +70,10 @@ int initcall_run_list(const init_fnc_t init_sequence[]) debug("initcall: %p\n", (char *)func - reloc_ofs); }
ret = type ? event_notify_null(type) : func(); + if (ret) + break; }
if (ret) { if (CONFIG_IS_ENABLED(EVENT)) {
Changes in v2:
Awesome. Thanks!
Reviewed-by: Dan Carpenter dan.carpenter@linaro.org
regards, dan carpenter
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org Reviewed-by: Dan Carpenter dan.carpenter@linaro.org
Caleb Connolly
Dan Carpenter
