[U-Boot] [PATCH] onenand: Fix compile errors due to FlexOneNAND
This patch fixes the compile error while trying to compile for omap3evm.
env_onenand.c: In function 'env_relocate_spec': env_onenand.c:70: error: 'CONFIG_ENV_ADDR_FLEX' undeclared (first use in this function) env_onenand.c:70: error: (Each undeclared identifier is re ported only once env_onenand.c:70: error: for each function it appears in.) env_onenand.c: In function 'saveenv': env_onenand.c:106: error: 'CONFIG_ENV_ADDR_FLEX' undeclare d (first use in this function) env_onenand.c:107: error: 'CONFIG_ENV_SIZE_FLEX' undeclare d (first use in this function)
Signed-off-by: Sanjeev Premi premi@ti.com --- common/env_onenand.c | 5 ++++- 1 files changed, 4 insertions(+), 1 deletions(-)
diff --git a/common/env_onenand.c b/common/env_onenand.c index 23d2caa..473e0b2 100644 --- a/common/env_onenand.c +++ b/common/env_onenand.c @@ -66,9 +66,10 @@ void env_relocate_spec(void) size_t retlen;
env_addr = CONFIG_ENV_ADDR; +#ifdef CONFIG_ENV_ADDR_FLEX if (FLEXONENAND(this)) env_addr = CONFIG_ENV_ADDR_FLEX; - +#endif /* Check OneNAND exist */ if (mtd->writesize) /* Ignore read fail */ @@ -102,12 +103,14 @@ int saveenv(void) size_t retlen;
instr.len = CONFIG_ENV_SIZE; +#ifdef CONFIG_ENV_ADDR_FLEX if (FLEXONENAND(this)) { env_addr = CONFIG_ENV_ADDR_FLEX; instr.len = CONFIG_ENV_SIZE_FLEX; instr.len <<= onenand_mtd.eraseregions[0].numblocks == 1 ? 1 : 0; } +#endif instr.addr = env_addr; instr.mtd = mtd; if (mtd->erase(mtd, &instr)) {
<snip>
Please also add this #ifdef around the declaration of
struct onenand_chip *this = &onenand_chip;
There are 'unused variable' warnings now
Otherwise fine. Tom
Sanjeev Premi
Tom
