[U-Boot] [PATCH] sunxi: Add support for eth1addr
Currently we will already fill ethaddr with a fixed unique address based on the SoCs serial (from the sid) to make sure that boards which use the integrated emac / gmac get a fixed mac rather then a random one.
On some boards (observed on 2 tablets using sdio rtl8703as wifi chips) the wifi does not come with a fixed mac either, so also set eth1addr, so that dts files can set an ethernet1 alias to get mac-address and local-mac-address filled for dt nodes describing the wifi controller.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- board/sunxi/board.c | 59 ++++++++++++++++++++++++++++++++++++++--------------- 1 file changed, 43 insertions(+), 16 deletions(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 78dfda5..955a44f 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -26,6 +26,7 @@ #endif #include <asm/gpio.h> #include <asm/io.h> +#include <libfdt.h> #include <nand.h> #include <net.h> #include <sy8106a.h> @@ -609,36 +610,38 @@ static void parse_spl_header(const uint32_t spl_addr) } #endif
-#ifdef CONFIG_MISC_INIT_R -int misc_init_r(void) +static void setup_environment(const void *fdt) { char serial_string[17] = { 0 }; unsigned int sid[4]; uint8_t mac_addr[6]; - int ret; - -#if !defined(CONFIG_SPL_BUILD) - setenv("fel_booted", NULL); - setenv("fel_scriptaddr", NULL); - /* determine if we are running in FEL mode */ - if (!is_boot0_magic(SPL_ADDR + 4)) { /* eGON.BT0 */ - setenv("fel_booted", "1"); - parse_spl_header(SPL_ADDR); - } -#endif + char ethaddr[16]; + int i, ret;
ret = sunxi_get_sid(sid); if (ret == 0 && sid[0] != 0 && sid[3] != 0) { - if (!getenv("ethaddr")) { + for (i = 0; i < 4; i++) { + sprintf(ethaddr, "ethernet%d", i); + if (!fdt_get_alias(fdt, ethaddr)) + continue; + + if (i == 0) + strcpy(ethaddr, "ethaddr"); + else + sprintf(ethaddr, "eth%daddr", i); + + if (getenv(ethaddr)) + continue; + /* Non OUI / registered MAC address */ - mac_addr[0] = 0x02; + mac_addr[0] = (i << 4) | 0x02; mac_addr[1] = (sid[0] >> 0) & 0xff; mac_addr[2] = (sid[3] >> 24) & 0xff; mac_addr[3] = (sid[3] >> 16) & 0xff; mac_addr[4] = (sid[3] >> 8) & 0xff; mac_addr[5] = (sid[3] >> 0) & 0xff;
- eth_setenv_enetaddr("ethaddr", mac_addr); + eth_setenv_enetaddr(ethaddr, mac_addr); }
if (!getenv("serial#")) { @@ -648,6 +651,24 @@ int misc_init_r(void) setenv("serial#", serial_string); } } +} + +#ifdef CONFIG_MISC_INIT_R +int misc_init_r(void) +{ + int ret; + +#if !defined(CONFIG_SPL_BUILD) + setenv("fel_booted", NULL); + setenv("fel_scriptaddr", NULL); + /* determine if we are running in FEL mode */ + if (!is_boot0_magic(SPL_ADDR + 4)) { /* eGON.BT0 */ + setenv("fel_booted", "1"); + parse_spl_header(SPL_ADDR); + } +#endif + + setup_environment(gd->fdt_blob);
#ifndef CONFIG_MACH_SUN9I ret = sunxi_usb_phy_probe(); @@ -664,6 +685,12 @@ int ft_board_setup(void *blob, bd_t *bd) { int __maybe_unused r;
+ /* + * Call setup_environment again in case the boot fdt has + * ethernet aliases the u-boot copy does not have. + */ + setup_environment(blob); + #ifdef CONFIG_VIDEO_DT_SIMPLEFB r = sunxi_simplefb_setup(blob); if (r)
Oops, I forgot to update the commit msg and mark this as v2, I will send a new version instead.
Regards,
Hans
- int ret;
-#endif
char ethaddr[16];
int i, ret;
continue;
if (i == 0)
else
continue;
mac_addr[0] = 0x02;
- int ret;
- setup_environment(gd->fdt_blob);
- setup_environment(blob);
Hans de Goede
