[U-Boot] [PATCH v2 1/2] ihs_mdio: Encapsulate register access
To prepare for DM conversion, encapsulate all register accesses in function calls.
Signed-off-by: Mario Six mario.six@gdsys.cc ---
v1 -> v2: No changes
--- board/gdsys/common/ihs_mdio.c | 41 ++++++++++++++++++++++++++++++++++------- 1 file changed, 34 insertions(+), 7 deletions(-)
diff --git a/board/gdsys/common/ihs_mdio.c b/board/gdsys/common/ihs_mdio.c index 822517d4b2..b5fe3dbbdc 100644 --- a/board/gdsys/common/ihs_mdio.c +++ b/board/gdsys/common/ihs_mdio.c @@ -12,6 +12,34 @@
#include "ihs_mdio.h"
+static inline u16 read_control(struct ihs_mdio_info *info) +{ + u16 val; + + FPGA_GET_REG(info->fpga, mdio.control, &val); + + return val; +} + +static inline void write_control(struct ihs_mdio_info *info, u16 val) +{ + FPGA_SET_REG(info->fpga, mdio.control, val); +} + +static inline void write_addr_data(struct ihs_mdio_info *info, u16 val) +{ + FPGA_SET_REG(info->fpga, mdio.address_data, val); +} + +static inline u16 read_rx_data(struct ihs_mdio_info *info) +{ + u16 val; + + FPGA_GET_REG(info->fpga, mdio.rx_data, &val); + + return val; +} + static int ihs_mdio_idle(struct mii_dev *bus) { struct ihs_mdio_info *info = bus->priv; @@ -19,7 +47,7 @@ static int ihs_mdio_idle(struct mii_dev *bus) unsigned int ctr = 0;
do { - FPGA_GET_REG(info->fpga, mdio.control, &val); + val = read_control(info); udelay(100); if (ctr++ > 10) return -1; @@ -43,13 +71,13 @@ static int ihs_mdio_read(struct mii_dev *bus, int addr, int dev_addr,
ihs_mdio_idle(bus);
- FPGA_SET_REG(info->fpga, mdio.control, - ((addr & 0x1f) << 5) | (regnum & 0x1f) | (2 << 10)); + write_control(info, + ((addr & 0x1f) << 5) | (regnum & 0x1f) | (2 << 10));
/* wait for rx data available */ udelay(100);
- FPGA_GET_REG(info->fpga, mdio.rx_data, &val); + val = read_rx_data(info);
return val; } @@ -61,9 +89,8 @@ static int ihs_mdio_write(struct mii_dev *bus, int addr, int dev_addr,
ihs_mdio_idle(bus);
- FPGA_SET_REG(info->fpga, mdio.address_data, value); - FPGA_SET_REG(info->fpga, mdio.control, - ((addr & 0x1f) << 5) | (regnum & 0x1f) | (1 << 10)); + write_addr_data(info, value); + write_control(info, ((addr & 0x1f) << 5) | (regnum & 0x1f) | (1 << 10));
return 0; }
Make the ihs_mdio driver DM-compatible, while retaining the old functionality for not-yet-converted boards.
v1 -> v2: * Switched to regmap usage (instead of fpgamap)
--- board/gdsys/common/ihs_mdio.c | 58 +++++++++++++++++++++++++++++++++++++++---- board/gdsys/common/ihs_mdio.h | 5 ++++ 2 files changed, 58 insertions(+), 5 deletions(-)
diff --git a/board/gdsys/common/ihs_mdio.c b/board/gdsys/common/ihs_mdio.c index b5fe3dbbdc..6b06b1d692 100644 --- a/board/gdsys/common/ihs_mdio.c +++ b/board/gdsys/common/ihs_mdio.c @@ -7,36 +7,84 @@
#include <common.h>
-#include <gdsys_fpga.h> #include <miiphy.h> +#ifdef CONFIG_GDSYS_LEGACY_DRIVERS +#include <gdsys_fpga.h> +#else +#include <fdtdec.h> +#include <regmap.h> +#endif
+#ifndef CONFIG_GDSYS_LEGACY_DRIVERS +enum { + REG_MDIO_CONTROL = 0x0, + REG_MDIO_ADDR_DATA = 0x2, + REG_MDIO_RX_DATA = 0x4, +}; + +static inline u16 read_reg(struct udevice *fpga, uint base, uint addr) +{ + struct regmap *map; + u8 *ptr; + + regmap_init_mem(fpga, &map); + ptr = regmap_get_range(map, 0); + + return in_le16((u16 *)(ptr + base + addr)); +} + +static inline void write_reg(struct udevice *fpga, uint base, uint addr, + u16 val) +{ + struct regmap *map; + u8 *ptr; + + regmap_init_mem(fpga, &map); + ptr = regmap_get_range(map, 0); + + out_le16((u16 *)(ptr + base + addr), val); +} +#endif + static inline u16 read_control(struct ihs_mdio_info *info) { u16 val; - +#ifdef CONFIG_GDSYS_LEGACY_DRIVERS FPGA_GET_REG(info->fpga, mdio.control, &val); - +#else + val = read_reg(info->fpga, info->base, REG_MDIO_CONTROL); +#endif return val; }
static inline void write_control(struct ihs_mdio_info *info, u16 val) { +#ifdef CONFIG_GDSYS_LEGACY_DRIVERS FPGA_SET_REG(info->fpga, mdio.control, val); +#else + write_reg(info->fpga, info->base, REG_MDIO_CONTROL, val); +#endif }
static inline void write_addr_data(struct ihs_mdio_info *info, u16 val) { +#ifdef CONFIG_GDSYS_LEGACY_DRIVERS FPGA_SET_REG(info->fpga, mdio.address_data, val); +#else + write_reg(info->fpga, info->base, REG_MDIO_ADDR_DATA, val); +#endif }
static inline u16 read_rx_data(struct ihs_mdio_info *info) { u16 val; - +#ifdef CONFIG_GDSYS_LEGACY_DRIVERS FPGA_GET_REG(info->fpga, mdio.rx_data, &val); - +#else + val = read_reg(info->fpga, info->base, REG_MDIO_RX_DATA); +#endif return val; }
diff --git a/board/gdsys/common/ihs_mdio.h b/board/gdsys/common/ihs_mdio.h index 64b4049378..3e3ba25bc6 100644 --- a/board/gdsys/common/ihs_mdio.h +++ b/board/gdsys/common/ihs_mdio.h @@ -9,7 +9,12 @@ #define _IHS_MDIO_H_
struct ihs_mdio_info { +#ifdef CONFIG_GDSYS_LEGACY_DRIVERS u32 fpga; +#else + struct udevice *fpga; + int base; +#endif char *name; };
Mario Six
