[U-Boot-Users] ethernet on FCC
Hi, My mpc8270 board use three ehternet ports at FCC1,FCC2,FCC3.it is work well at FCC1.When I use port FCC2, I found out the u-boot is not receiving packets (It's sending correct packet when i use ethereal for sniffing). When trying "ping", it generated an ARP packet first, the other host replied with , but the board never seems to receive it(set printf at function fec_recv() /cpu/mpc8260/ether_fcc.c ).all three ethernet fcc ports initiailze is same.Do I miss something?thank you for your suggestion,my config file config FCC port parameter as follow:
#undef CONFIG_ETHER_ON_SCC /* define if ether on SCC */ #define CONFIG_ETHER_ON_FCC /* define if ether on FCC */ #undef CONFIG_ETHER_NONE /* define if ether on something else */ #define CONFIG_NET_MULTI #define CONFIG_ETHER_ON_FCC1 #define CONFIG_ETHER_ON_FCC2 #define CONFIG_ETHER_ON_FCC3
#define CFG_CMXFCR_VALUE1 (CMXFCR_RF1CS_CLK11 | CMXFCR_TF1CS_CLK12) #define CFG_CMXFCR_MASK1 (CMXFCR_FC1 | CMXFCR_RF1CS_MSK | CMXFCR_TF1CS_MSK)
#define CFG_CMXFCR_VALUE3 (CMXFCR_RF3CS_CLK13 | CMXFCR_TF3CS_CLK14) #define CFG_CMXFCR_MASK3 (CMXFCR_FC3 | CMXFCR_RF3CS_MSK | CMXFCR_TF3CS_MSK)
#define CFG_CMXFCR_VALUE2 (CMXFCR_RF2CS_CLK15 | CMXFCR_TF2CS_CLK16) #define CFG_CMXFCR_MASK2 (CMXFCR_FC2 | CMXFCR_RF2CS_MSK | CMXFCR_TF2CS_MSK)
#define CFG_RX_ETH_BUFFER 128 #define CONFIG_IPADDR 192.168.10.17 #define CONFIG_SERVERIP 192.168.10.101 #define CONFIG_HOSTNAME OceanSCC #define CONFIG_LOADADDR 1000 /* default location for tftp and bootm */ #define CONFIG_BOOTFILE u-boot.bin
#define CONFIG_ETHADDR 00:13:09:11:22:33 #define CONFIG_HAS_ETH1 #define CONFIG_ETH1ADDR 00:13:09:04:05:36 #define CONFIG_HAS_ETH2 #define CONFIG_ETH2ADDR 00:13:09:07:08:39
#define CONFIG_EXTRA_ENV_SETTINGS "ethprime=FCC1 ETHERNET"
#define CFG_CPMFCR_RAMTYPE 0 /* BDs and buffers on 60x bus */ #define CFG_FCC_PSMR (FCC_PSMR_FDE | FCC_PSMR_LPB) /* Full duplex */
#define CONFIG_MII /* MII PHY management */ #define CONFIG_BITBANGMII /* bit-bang MII PHY management */
Sincerely,
Jie
--------------------------------- Don't pick lemons. See all the new 2007 cars at Yahoo! Autos.
Sincerely,
Jie
Hi Jie,
I don't have any good insights, but some things to try: * Are you sure, positive, double checked and had a co-worker check that your clock input for FCC2-Rx is configured properly? 1) Which CLK input is used? 2) The port/pin configuration initialization in u-boot? 3) Your hardware (traces) actually connect the right pins?
* Does FCC3 work?
* If you turn off CONFIG_NET_MULTI and only use FCC2, does it work?
* If you turn off CONFIG_NET_MULTI and only use FCC3, does it work?
Good luck, gvb
Thank you for your help.The fcc2 working now,It is my mistake to config fcc2 RX_DV port pin.
Sincerely,
Jie
Sincerely,
Jie
Hi Jie,
* Does FCC3 work?
Good luck, gvb
--------------------------------- Bored stiff? Loosen up... Download and play hundreds of games for free on Yahoo! Games.
Jerry Van Baren
jie han
