[PATCH v3 0/8] Enable CONFIG_TIMER for all Kirkwood / MVEBU boards
This patchset enhaces the recently added Orion Timer driver to support all other Kirkwood & 32bit MVEBU Armada platforms. Additionally, this timer support is then enabled per default for those platforms, so that the board config files don't need to be changed. Also necessary is some dts hacking, so that the timer DT node is available in early U-Boot stages.
I've successfully tested this patchset on an Armada XP board. Additional test on other boards and platforms are very welcome and necessary.
Thanks, Stefan
Stefan Roese (8): timer: orion-timer: Use timer_conv_64() to fix timer wrap around timer: orion-timer: Add support for other Armada SoC's timer: orion-timer: Add timer_get_boot_us() for BOOTSTAGE support arm: mvebu: Use CONFIG_TIMER on all MVEBU & KIRKWOOD platforms arm: mvebu: dts: Makefile: Compile Armada 375 dtb in a separate step arm: mvebu: dts: armada-375.dtsi: Add timer0 & timer1 arm: mvebu: dts: mvebu-u-boot.dtsi: Add "u-boot,dm-pre-reloc" to timer DT node kirkwood: lsxl: Sync defconfigs
arch/arm/Kconfig | 4 + arch/arm/dts/Makefile | 6 +- arch/arm/dts/armada-375.dtsi | 4 +- arch/arm/dts/mvebu-u-boot.dtsi | 11 +++ arch/arm/mach-mvebu/include/mach/config.h | 5 -- configs/lschlv2_defconfig | 2 - configs/lsxhl_defconfig | 2 - drivers/timer/Kconfig | 5 +- drivers/timer/orion-timer.c | 103 +++++++++++++++++++--- 9 files changed, 118 insertions(+), 24 deletions(-)
While testing on some Kirkwood platforms it was noticed that the timer did not function correctly all the time. The driver did not correctly handle 32bit timer value wrap arounds. Using the timer_conv_64() conversion function fixes this issue.
Fixes: e9e73d78a8fb ("timer: add orion-timer support") Suggested-by: Stefan Herbrechtsmeier stefan.herbrechtsmeier-oss@weidmueller.com Signed-off-by: Stefan Roese sr@denx.de Tested-by: Tony Dinh mibodhi@gmail.com --- v3: - Add Fixes tag
v2: - New patch
drivers/timer/orion-timer.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/timer/orion-timer.c b/drivers/timer/orion-timer.c index fd30e1bf036c..d7d1a1b24462 100644 --- a/drivers/timer/orion-timer.c +++ b/drivers/timer/orion-timer.c @@ -19,7 +19,7 @@ static uint64_t orion_timer_get_count(struct udevice *dev) { struct orion_timer_priv *priv = dev_get_priv(dev);
- return ~readl(priv->base + TIMER0_VAL); + return timer_conv_64(~readl(priv->base + TIMER0_VAL)); }
static int orion_timer_probe(struct udevice *dev)
Applied to u-boot-marvell/master
Thanks, Stefan
v3:
- Add Fixes tag
v2:
New patch
Viele Grüße, Stefan Roese
This patch adds support for other Marvell Armada SoC's, supporting the 25MHz fixed clock operation, like the Armada XP etc.
Signed-off-by: Stefan Roese sr@denx.de Tested-by: Tony Dinh mibodhi@gmail.com --- v3: - No change
v2: - Use timer_conv_64() in timer_early_get_count()
drivers/timer/Kconfig | 5 ++++- drivers/timer/orion-timer.c | 42 ++++++++++++++++++++++++++++++++++--- 2 files changed, 43 insertions(+), 4 deletions(-)
diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index 404929014810..b0814acca3fb 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -197,8 +197,11 @@ config OMAP_TIMER config ORION_TIMER bool "Orion timer support" depends on TIMER + default y if ARCH_KIRKWOOD || (ARCH_MVEBU && ARMADA_32BIT) + select TIMER_EARLY if ARCH_MVEBU help - Select this to enable an timer for Orion devices. + Select this to enable an timer for Orion and Armada devices + like Armada XP etc.
config RISCV_TIMER bool "RISC-V timer support" diff --git a/drivers/timer/orion-timer.c b/drivers/timer/orion-timer.c index d7d1a1b24462..14f318e57d4d 100644 --- a/drivers/timer/orion-timer.c +++ b/drivers/timer/orion-timer.c @@ -11,10 +11,34 @@ #define TIMER0_RELOAD 0x10 #define TIMER0_VAL 0x14
+enum input_clock_type { + INPUT_CLOCK_NON_FIXED, + INPUT_CLOCK_25MHZ, /* input clock rate is fixed to 25MHz */ +}; + struct orion_timer_priv { void *base; };
+#define MVEBU_TIMER_FIXED_RATE_25MHZ 25000000 + +/** + * timer_early_get_rate() - Get the timer rate before driver model + */ +unsigned long notrace timer_early_get_rate(void) +{ + return MVEBU_TIMER_FIXED_RATE_25MHZ; +} + +/** + * timer_early_get_count() - Get the timer count before driver model + * + */ +u64 notrace timer_early_get_count(void) +{ + return timer_conv_64(~readl(MVEBU_TIMER_BASE + TIMER0_VAL)); +} + static uint64_t orion_timer_get_count(struct udevice *dev) { struct orion_timer_priv *priv = dev_get_priv(dev); @@ -25,6 +49,7 @@ static uint64_t orion_timer_get_count(struct udevice *dev) static int orion_timer_probe(struct udevice *dev) { struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); + enum input_clock_type type = dev_get_driver_data(dev); struct orion_timer_priv *priv = dev_get_priv(dev);
priv->base = devfdt_remap_addr_index(dev, 0); @@ -33,11 +58,20 @@ static int orion_timer_probe(struct udevice *dev) return -ENOMEM; }
- uc_priv->clock_rate = CONFIG_SYS_TCLK; - writel(~0, priv->base + TIMER0_VAL); writel(~0, priv->base + TIMER0_RELOAD);
+ if (type == INPUT_CLOCK_25MHZ) { + /* + * On Armada XP / 38x ..., the 25MHz clock source needs to + * be enabled + */ + setbits_le32(priv->base + TIMER_CTRL, BIT(11)); + uc_priv->clock_rate = MVEBU_TIMER_FIXED_RATE_25MHZ; + } else { + uc_priv->clock_rate = CONFIG_SYS_TCLK; + } + /* enable timer */ setbits_le32(priv->base + TIMER_CTRL, TIMER0_EN | TIMER0_RELOAD_EN);
@@ -49,7 +83,9 @@ static const struct timer_ops orion_timer_ops = { };
static const struct udevice_id orion_timer_ids[] = { - { .compatible = "marvell,orion-timer" }, + { .compatible = "marvell,orion-timer", .data = INPUT_CLOCK_NON_FIXED }, + { .compatible = "marvell,armada-370-timer", .data = INPUT_CLOCK_25MHZ }, + { .compatible = "marvell,armada-xp-timer", .data = INPUT_CLOCK_25MHZ }, {} };
Add timer_get_boot_us() to support boards, that have CONFIG_BOOTSTAGE enabled, like pogo_v4.
Signed-off-by: Stefan Roese sr@denx.de Tested-by: Tony Dinh mibodhi@gmail.com --- v3: - Also support fixed input clock in early timer code - Consolidate code for this
v2: - Change timer_get_boot_us() to use the timer_early functions - Remove #if CONFIG_IS_ENABLED(BOOTSTAGE)
drivers/timer/orion-timer.c | 83 ++++++++++++++++++++++++++++--------- 1 file changed, 64 insertions(+), 19 deletions(-)
diff --git a/drivers/timer/orion-timer.c b/drivers/timer/orion-timer.c index 14f318e57d4d..cd63ea916237 100644 --- a/drivers/timer/orion-timer.c +++ b/drivers/timer/orion-timer.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ #include <asm/io.h> #include <common.h> +#include <div64.h> #include <dm/device.h> #include <dm/fdtaddr.h> #include <timer.h> @@ -22,12 +23,56 @@ struct orion_timer_priv {
+static bool early_init_done __section(".data") = false; + +/* Common functions for early (boot) and DM based timer */ +static void orion_timer_init(void *base, enum input_clock_type type) +{ + writel(~0, base + TIMER0_VAL); + writel(~0, base + TIMER0_RELOAD); + + if (type == INPUT_CLOCK_25MHZ) { + /* + * On Armada XP / 38x ..., the 25MHz clock source needs to + * be enabled + */ + setbits_le32(base + TIMER_CTRL, BIT(11)); + } + + /* enable timer */ + setbits_le32(base + TIMER_CTRL, TIMER0_EN | TIMER0_RELOAD_EN); +} + +static uint64_t orion_timer_get_count(void *base) +{ + return timer_conv_64(~readl(base + TIMER0_VAL)); +} + +/* Early (e.g. bootstage etc) timer functions */ +static void notrace timer_early_init(void) +{ + /* Only init the timer once */ + if (early_init_done) + return; + early_init_done = true; + + if (IS_ENABLED(CONFIG_ARCH_MVEBU)) + orion_timer_init((void *)MVEBU_TIMER_BASE, INPUT_CLOCK_25MHZ); + else + orion_timer_init((void *)MVEBU_TIMER_BASE, INPUT_CLOCK_NON_FIXED); +} + /** * timer_early_get_rate() - Get the timer rate before driver model */ unsigned long notrace timer_early_get_rate(void) { - return MVEBU_TIMER_FIXED_RATE_25MHZ; + timer_early_init(); + + if (IS_ENABLED(CONFIG_ARCH_MVEBU)) + return MVEBU_TIMER_FIXED_RATE_25MHZ; + else + return CONFIG_SYS_TCLK; }
/** @@ -36,14 +81,25 @@ unsigned long notrace timer_early_get_rate(void) */ u64 notrace timer_early_get_count(void) { - return timer_conv_64(~readl(MVEBU_TIMER_BASE + TIMER0_VAL)); + timer_early_init(); + + return orion_timer_get_count((void *)MVEBU_TIMER_BASE); }
-static uint64_t orion_timer_get_count(struct udevice *dev) +ulong timer_get_boot_us(void) +{ + u64 ticks; + + ticks = timer_early_get_count(); + return lldiv(ticks * 1000, timer_early_get_rate()); +} + +/* DM timer functions */ +static uint64_t dm_orion_timer_get_count(struct udevice *dev) { struct orion_timer_priv *priv = dev_get_priv(dev);
- return timer_conv_64(~readl(priv->base + TIMER0_VAL)); + return orion_timer_get_count(priv->base); }
static int orion_timer_probe(struct udevice *dev) @@ -58,28 +114,17 @@ static int orion_timer_probe(struct udevice *dev) return -ENOMEM; }
- writel(~0, priv->base + TIMER0_VAL); - writel(~0, priv->base + TIMER0_RELOAD); - - if (type == INPUT_CLOCK_25MHZ) { - /* - * On Armada XP / 38x ..., the 25MHz clock source needs to - * be enabled - */ - setbits_le32(priv->base + TIMER_CTRL, BIT(11)); + if (type == INPUT_CLOCK_25MHZ) uc_priv->clock_rate = MVEBU_TIMER_FIXED_RATE_25MHZ; - } else { + else uc_priv->clock_rate = CONFIG_SYS_TCLK; - } - - /* enable timer */ - setbits_le32(priv->base + TIMER_CTRL, TIMER0_EN | TIMER0_RELOAD_EN); + orion_timer_init(priv->base, type);
return 0; }
static const struct timer_ops orion_timer_ops = { - .get_count = orion_timer_get_count, + .get_count = dm_orion_timer_get_count, };
Now that the new timer support is available for these platforms, let's select this IF for all these platforms. This way it's not necessary that each board changes it's config header.
v2: - No change
arch/arm/Kconfig | 4 ++++ arch/arm/mach-mvebu/include/mach/config.h | 5 ----- 2 files changed, 4 insertions(+), 5 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 82cd456f51f1..4ed100ab0ede 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -618,6 +618,7 @@ config ARCH_KIRKWOOD select BOARD_EARLY_INIT_F select CPU_ARM926EJS select GPIO_EXTRA_HEADER + select TIMER
config ARCH_MVEBU bool "Marvell MVEBU family (Armada XP/375/38x/3700/7K/8K)" @@ -629,6 +630,8 @@ config ARCH_MVEBU select GPIO_EXTRA_HEADER select SPL_DM_SPI if SPL select SPL_DM_SPI_FLASH if SPL + select SPL_TIMER if SPL + select TIMER select OF_CONTROL select OF_SEPARATE select SPI @@ -639,6 +642,7 @@ config ARCH_ORION5X select CPU_ARM926EJS select GPIO_EXTRA_HEADER select SPL_SEPARATE_BSS if SPL + select TIMER
config TARGET_STV0991 bool "Support stv0991" diff --git a/arch/arm/mach-mvebu/include/mach/config.h b/arch/arm/mach-mvebu/include/mach/config.h index 4add0d9e1030..9b5036c31dd3 100644 --- a/arch/arm/mach-mvebu/include/mach/config.h +++ b/arch/arm/mach-mvebu/include/mach/config.h @@ -41,9 +41,4 @@ #endif #endif
-/* Use common timer */ -#define CONFIG_SYS_TIMER_COUNTS_DOWN -#define CONFIG_SYS_TIMER_COUNTER (MVEBU_TIMER_BASE + 0x14) -#define CONFIG_SYS_TIMER_RATE 25000000 - #endif /* __MVEBU_CONFIG_H */
Hi Stefan,
v3:
- No change
v2:
- No change
select TIMER
select TIMER
2.37.3
I think this may have broken the 64-bit mvebu SoCs (at least reverting it gets my AC5X series back to a working state). As far as I can tell none of them have anything that would bring in any timer driver.
On Sat, Nov 5, 2022 at 5:03 PM Chris Packham judge.packham@gmail.com wrote:
Hi Stefan,
v3:
- No change
v2:
- No change
select TIMER
select TIMER
2.37.3
The following seems to sort things out without the need for a revert
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 710f171f87..e8968d61cd 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -640,7 +640,7 @@ config ARCH_MVEBU select SPL_DM_SPI if SPL select SPL_DM_SPI_FLASH if SPL select SPL_TIMER if SPL - select TIMER + select TIMER if !ARM64 select OF_CONTROL select OF_SEPARATE select SPI
I'll include it in the series I'm about to send.
Hi Chris,
Hi Stefan,
v3:
- No change
v2:
No change
select TIMER
select TIMER
-- 2.37.3
select TIMER
Thanks. Even though I wonder a bit that no other ARM64 Marvell user stumbled over this yet.
Thanks, Stefan
On Mon, 7 Nov 2022, 7:23 PM Stefan Roese, sr@denx.de wrote:
Hi Chris,
wrote:
Hi Stefan,
v3:
- No change
v2:
No change
select TIMER
select TIMER
-- 2.37.3
select TIMER
Yeah I did wonder. I do have access to another less obscure Marvell board at $dayjob. I'll see if I can confirm whether it needs the same change or not.
Thanks, Stefan
Hi Chris,
On 07.11.22 09:11, Chris Packham wrote:
On Mon, 7 Nov 2022, 7:23 PM Stefan Roese, <sr@denx.de mailto:sr@denx.de> wrote:
Hi Chris, On 05.11.22 05:08, Chris Packham wrote: > On Sat, Nov 5, 2022 at 5:03 PM Chris Packham <judge.packham@gmail.com <mailto:judge.packham@gmail.com>> wrote: >> >> Hi Stefan, >> >> On Fri, Sep 16, 2022 at 2:23 AM Stefan Roese <sr@denx.de <mailto:sr@denx.de>> wrote: >>> >>> Now that the new timer support is available for these platforms, let's >>> select this IF for all these platforms. This way it's not necessary >>> that each board changes it's config header. >>> >>> Signed-off-by: Stefan Roese <sr@denx.de <mailto:sr@denx.de>> >>> Tested-by: Tony Dinh <mibodhi@gmail.com <mailto:mibodhi@gmail.com>> >>> --- >>> v3: >>> - No change >>> >>> v2: >>> - No change >>> >>> arch/arm/Kconfig | 4 ++++ >>> arch/arm/mach-mvebu/include/mach/config.h | 5 ----- >>> 2 files changed, 4 insertions(+), 5 deletions(-) >>> >>> diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig >>> index 82cd456f51f1..4ed100ab0ede 100644 >>> --- a/arch/arm/Kconfig >>> +++ b/arch/arm/Kconfig >>> @@ -618,6 +618,7 @@ config ARCH_KIRKWOOD >>> select BOARD_EARLY_INIT_F >>> select CPU_ARM926EJS >>> select GPIO_EXTRA_HEADER >>> + select TIMER >>> >>> config ARCH_MVEBU >>> bool "Marvell MVEBU family (Armada XP/375/38x/3700/7K/8K)" >>> @@ -629,6 +630,8 @@ config ARCH_MVEBU >>> select GPIO_EXTRA_HEADER >>> select SPL_DM_SPI if SPL >>> select SPL_DM_SPI_FLASH if SPL >>> + select SPL_TIMER if SPL >>> + select TIMER >>> select OF_CONTROL >>> select OF_SEPARATE >>> select SPI >>> @@ -639,6 +642,7 @@ config ARCH_ORION5X >>> select CPU_ARM926EJS >>> select GPIO_EXTRA_HEADER >>> select SPL_SEPARATE_BSS if SPL >>> + select TIMER >>> >>> config TARGET_STV0991 >>> bool "Support stv0991" >>> diff --git a/arch/arm/mach-mvebu/include/mach/config.h b/arch/arm/mach-mvebu/include/mach/config.h >>> index 4add0d9e1030..9b5036c31dd3 100644 >>> --- a/arch/arm/mach-mvebu/include/mach/config.h >>> +++ b/arch/arm/mach-mvebu/include/mach/config.h >>> @@ -41,9 +41,4 @@ >>> #endif >>> #endif >>> >>> -/* Use common timer */ >>> -#define CONFIG_SYS_TIMER_COUNTS_DOWN >>> -#define CONFIG_SYS_TIMER_COUNTER (MVEBU_TIMER_BASE + 0x14) >>> -#define CONFIG_SYS_TIMER_RATE 25000000 >>> - >>> #endif /* __MVEBU_CONFIG_H */ >>> -- >>> 2.37.3 >>> >> >> I think this may have broken the 64-bit mvebu SoCs (at least reverting >> it gets my AC5X series back to a working state). As far as I can tell >> none of them have anything that would bring in any timer driver. > > The following seems to sort things out without the need for a revert > > diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig > index 710f171f87..e8968d61cd 100644 > --- a/arch/arm/Kconfig > +++ b/arch/arm/Kconfig > @@ -640,7 +640,7 @@ config ARCH_MVEBU > select SPL_DM_SPI if SPL > select SPL_DM_SPI_FLASH if SPL > select SPL_TIMER if SPL > - select TIMER > + select TIMER if !ARM64 > select OF_CONTROL > select OF_SEPARATE > select SPI > > I'll include it in the series I'm about to send. Thanks. Even though I wonder a bit that no other ARM64 Marvell user stumbled over this yet.
Cool, thanks. I'm running a CI build right now and will push your patches later today if all works fine.
Thanks, Stefan
On Monday 07 November 2022 09:13:37 Stefan Roese wrote:
Hi Chris,
Thanks, Stefan
Sorry, I have not tested A3720 with all those changes. So I do not know. I tested only A385 and it worked fine.
Hi Chris,
Thanks, Stefan
I can confirm that the original change broke CN9130 and the if !ARM64 fixes it. So with the PR that Stefan has just sent and Tom has merged v2023.01-rc1 should be good on the 64 bit MVEBU boards.
Hi Chris,
Thanks, Stefan
Thanks Chris for testing and confirming this fix.
Thanks, Stefan
This patch changes the compilation, so that the Armada 375 board(s) are compiled in a separate step. This is necessary for the timer dts conversion, as A375 has a different / timer description in the dts.
v2: - No change
arch/arm/dts/Makefile | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7330121dbaba..03e79e14681f 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -233,8 +233,11 @@ dtb-$(CONFIG_ARCH_TEGRA) += tegra20-harmony.dtb \ tegra210-p3450-0000.dtb
ifdef CONFIG_ARMADA_32BIT +ifdef CONFIG_ARMADA_375 +dtb-$(CONFIG_ARCH_MVEBU) += \ + armada-375-db.dtb +else dtb-$(CONFIG_ARCH_MVEBU) += \ - armada-375-db.dtb \ armada-385-atl-x530.dtb \ armada-385-atl-x530DP.dtb \ armada-385-db-88f6820-amc.dtb \ @@ -254,6 +257,7 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-xp-maxbcm.dtb \ armada-xp-synology-ds414.dtb \ armada-xp-theadorable.dtb +endif else dtb-$(CONFIG_ARCH_MVEBU) += \ armada-3720-db.dtb \
Add the DT bindings / descriptions for timer0 & timer1, exactly as done in mainline Linux.
v2: - No change
arch/arm/dts/armada-375.dtsi | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/armada-375.dtsi b/arch/arm/dts/armada-375.dtsi index 20a8c352b2f1..a044b3fc994f 100644 --- a/arch/arm/dts/armada-375.dtsi +++ b/arch/arm/dts/armada-375.dtsi @@ -187,7 +187,7 @@ reg = <0xc000 0x58>; };
- timer@c600 { + timer0: timer@c600 { compatible = "arm,cortex-a9-twd-timer"; reg = <0xc600 0x20>; interrupts = <GIC_PPI 13 (IRQ_TYPE_EDGE_RISING | GIC_CPU_MASK_SIMPLE(2))>; @@ -416,7 +416,7 @@ interrupts = <GIC_PPI 15 IRQ_TYPE_LEVEL_HIGH>; };
- timer@20300 { + timer1: timer@20300 { compatible = "marvell,armada-375-timer", "marvell,armada-370-timer"; reg = <0x20300 0x30>, <0x21040 0x30>; interrupts-extended = <&gic GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>,
Adding the "u-boot,dm-pre-reloc" DT property to the timer node is necesssary to support the timer in the early boot phases (e.g. SPL & pre-reloc).
v2: - No change
arch/arm/dts/mvebu-u-boot.dtsi | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/arch/arm/dts/mvebu-u-boot.dtsi b/arch/arm/dts/mvebu-u-boot.dtsi index 5538f95148de..db4bf39920b1 100644 --- a/arch/arm/dts/mvebu-u-boot.dtsi +++ b/arch/arm/dts/mvebu-u-boot.dtsi @@ -15,6 +15,17 @@ u-boot,dm-pre-reloc; };
+#ifdef CONFIG_ARMADA_375 +/* Armada 375 has multiple timers, use timer1 here */ +&timer1 { + u-boot,dm-pre-reloc; +}; +#else +&timer { + u-boot,dm-pre-reloc; +}; +#endif + #ifdef CONFIG_SPL_SPI &spi0 { u-boot,dm-pre-reloc;
With the recent changes in the Orion timer driver Kconfig setup, the board specific enabling is not needed any more. This patch sync's these 2 boards with their current defconfig version.
Signed-off-by: Stefan Roese sr@denx.de Cc: Michael Walle michael@walle.cc Tested-by: Tony Dinh mibodhi@gmail.com --- v3: - New patch
v2: - New patch
configs/lschlv2_defconfig | 2 -- configs/lsxhl_defconfig | 2 -- 2 files changed, 4 deletions(-)
diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index cfccfdcfc407..441cd8ef24ff 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -70,7 +70,5 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y -CONFIG_TIMER=y -CONFIG_ORION_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index 1945b72450c2..f350f8ff427a 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -71,7 +71,5 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y -CONFIG_TIMER=y -CONFIG_ORION_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y
Hello! Now I have tested this patch series on Turris Omnia - A385, loaded via UART kwboot and seems that everything is working fine.
Thanks, Stefan
-- 2.37.3
Thanks, Stefan
Applied to u-boot-marvell/next
Thanks, Stefan
Thanks, Stefan
Thanks, Stefan
Chris Packham
Pali Rohár
Stefan Roese
