[U-Boot] [PATCH v2 1/4] dt-bindings: add imx-audmux macro definitions
Import fsl-imx-audmux.h from Linux as of v5.4-rc6. The header is unchanged since v4.18.
That would make it easier to import DT files that depend on imx-audmux definitions from the kernel tree.
Signed-off-by: Baruch Siach baruch@tkos.co.il --- v2: New patch in this series. Suggested by Fabio Estevam. --- include/dt-bindings/sound/fsl-imx-audmux.h | 64 ++++++++++++++++++++++ 1 file changed, 64 insertions(+) create mode 100644 include/dt-bindings/sound/fsl-imx-audmux.h
diff --git a/include/dt-bindings/sound/fsl-imx-audmux.h b/include/dt-bindings/sound/fsl-imx-audmux.h new file mode 100644 index 000000000000..15f138bebe16 --- /dev/null +++ b/include/dt-bindings/sound/fsl-imx-audmux.h @@ -0,0 +1,64 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef __DT_FSL_IMX_AUDMUX_H +#define __DT_FSL_IMX_AUDMUX_H + +#define MX27_AUDMUX_HPCR1_SSI0 0 +#define MX27_AUDMUX_HPCR2_SSI1 1 +#define MX27_AUDMUX_HPCR3_SSI_PINS_4 2 +#define MX27_AUDMUX_PPCR1_SSI_PINS_1 3 +#define MX27_AUDMUX_PPCR2_SSI_PINS_2 4 +#define MX27_AUDMUX_PPCR3_SSI_PINS_3 5 + +#define MX31_AUDMUX_PORT1_SSI0 0 +#define MX31_AUDMUX_PORT2_SSI1 1 +#define MX31_AUDMUX_PORT3_SSI_PINS_3 2 +#define MX31_AUDMUX_PORT4_SSI_PINS_4 3 +#define MX31_AUDMUX_PORT5_SSI_PINS_5 4 +#define MX31_AUDMUX_PORT6_SSI_PINS_6 5 +#define MX31_AUDMUX_PORT7_SSI_PINS_7 6 + +#define MX51_AUDMUX_PORT1_SSI0 0 +#define MX51_AUDMUX_PORT2_SSI1 1 +#define MX51_AUDMUX_PORT3 2 +#define MX51_AUDMUX_PORT4 3 +#define MX51_AUDMUX_PORT5 4 +#define MX51_AUDMUX_PORT6 5 +#define MX51_AUDMUX_PORT7 6 + +/* + * TFCSEL/RFCSEL (i.MX27) or TFSEL/TCSEL/RFSEL/RCSEL (i.MX31/51/53/6Q) + * can be sourced from Rx/Tx. + */ +#define IMX_AUDMUX_RXFS 0x8 +#define IMX_AUDMUX_RXCLK 0x8 + +/* Register definitions for the i.MX21/27 Digital Audio Multiplexer */ +#define IMX_AUDMUX_V1_PCR_INMMASK(x) ((x) & 0xff) +#define IMX_AUDMUX_V1_PCR_INMEN (1 << 8) +#define IMX_AUDMUX_V1_PCR_TXRXEN (1 << 10) +#define IMX_AUDMUX_V1_PCR_SYN (1 << 12) +#define IMX_AUDMUX_V1_PCR_RXDSEL(x) (((x) & 0x7) << 13) +#define IMX_AUDMUX_V1_PCR_RFCSEL(x) (((x) & 0xf) << 20) +#define IMX_AUDMUX_V1_PCR_RCLKDIR (1 << 24) +#define IMX_AUDMUX_V1_PCR_RFSDIR (1 << 25) +#define IMX_AUDMUX_V1_PCR_TFCSEL(x) (((x) & 0xf) << 26) +#define IMX_AUDMUX_V1_PCR_TCLKDIR (1 << 30) +#define IMX_AUDMUX_V1_PCR_TFSDIR (1 << 31) + +/* Register definitions for the i.MX25/31/35/51 Digital Audio Multiplexer */ +#define IMX_AUDMUX_V2_PTCR_TFSDIR (1 << 31) +#define IMX_AUDMUX_V2_PTCR_TFSEL(x) (((x) & 0xf) << 27) +#define IMX_AUDMUX_V2_PTCR_TCLKDIR (1 << 26) +#define IMX_AUDMUX_V2_PTCR_TCSEL(x) (((x) & 0xf) << 22) +#define IMX_AUDMUX_V2_PTCR_RFSDIR (1 << 21) +#define IMX_AUDMUX_V2_PTCR_RFSEL(x) (((x) & 0xf) << 17) +#define IMX_AUDMUX_V2_PTCR_RCLKDIR (1 << 16) +#define IMX_AUDMUX_V2_PTCR_RCSEL(x) (((x) & 0xf) << 12) +#define IMX_AUDMUX_V2_PTCR_SYN (1 << 11) + +#define IMX_AUDMUX_V2_PDCR_RXDSEL(x) (((x) & 0x7) << 13) +#define IMX_AUDMUX_V2_PDCR_TXRXEN (1 << 12) +#define IMX_AUDMUX_V2_PDCR_MODE(x) (((x) & 0x3) << 8) +#define IMX_AUDMUX_V2_PDCR_INMMASK(x) ((x) & 0xff) + +#endif /* __DT_FSL_IMX_AUDMUX_H */
These DT files are copied from kernel v5.3 with no changes.
This is part 1 of 2 commits. Included are DT files for the original Cubox-i and Hummingboard Base/Pro.
Signed-off-by: Baruch Siach baruch@tkos.co.il --- v2: Don't remove imx-audmux macros (Fabio Estevam) Split into two commits to comply with list size limits --- arch/arm/dts/Makefile | 4 + arch/arm/dts/imx6dl-cubox-i.dts | 51 ++++ arch/arm/dts/imx6dl-hummingboard.dts | 52 ++++ arch/arm/dts/imx6q-cubox-i.dts | 59 ++++ arch/arm/dts/imx6q-hummingboard.dts | 60 ++++ arch/arm/dts/imx6qdl-cubox-i.dtsi | 269 ++++++++++++++++++ arch/arm/dts/imx6qdl-hummingboard.dtsi | 368 +++++++++++++++++++++++++ arch/arm/dts/imx6qdl-sr-som-brcm.dtsi | 144 ++++++++++ arch/arm/dts/imx6qdl-sr-som.dtsi | 121 ++++++++ 9 files changed, 1128 insertions(+) create mode 100644 arch/arm/dts/imx6dl-cubox-i.dts create mode 100644 arch/arm/dts/imx6dl-hummingboard.dts create mode 100644 arch/arm/dts/imx6q-cubox-i.dts create mode 100644 arch/arm/dts/imx6q-hummingboard.dts create mode 100644 arch/arm/dts/imx6qdl-cubox-i.dtsi create mode 100644 arch/arm/dts/imx6qdl-hummingboard.dtsi create mode 100644 arch/arm/dts/imx6qdl-sr-som-brcm.dtsi create mode 100644 arch/arm/dts/imx6qdl-sr-som.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 3b8dc2f56fd2..a2ed92b77f15 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -560,7 +560,9 @@ dtb-$(CONFIG_MX53) += imx53-cx9020.dtb \
ifneq ($(CONFIG_MX6DL)$(CONFIG_MX6QDL)$(CONFIG_MX6S),) dtb-y += \ + imx6dl-cubox-i.dtb \ imx6dl-dhcom-pdk2.dtb \ + imx6dl-hummingboard.dtb \ imx6dl-icore.dtb \ imx6dl-icore-mipi.dtb \ imx6dl-icore-rqs.dtb \ @@ -577,8 +579,10 @@ ifneq ($(CONFIG_MX6Q)$(CONFIG_MX6QDL),) dtb-y += \ imx6-apalis.dtb \ imx6q-cm-fx6.dtb \ + imx6q-cubox-i.dtb \ imx6q-dhcom-pdk2.dtb \ imx6q-display5.dtb \ + imx6q-hummingboard.dtb \ imx6q-icore.dtb \ imx6q-icore-mipi.dtb \ imx6q-icore-rqs.dtb \ diff --git a/arch/arm/dts/imx6dl-cubox-i.dts b/arch/arm/dts/imx6dl-cubox-i.dts new file mode 100644 index 000000000000..2b1b3e193f53 --- /dev/null +++ b/arch/arm/dts/imx6dl-cubox-i.dts @@ -0,0 +1,51 @@ +/* + * Copyright (C) 2014 Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; + +#include "imx6dl.dtsi" +#include "imx6qdl-sr-som.dtsi" +#include "imx6qdl-sr-som-brcm.dtsi" +#include "imx6qdl-cubox-i.dtsi" + +/ { + model = "SolidRun Cubox-i Solo/DualLite"; + compatible = "solidrun,cubox-i/dl", "fsl,imx6dl"; +}; diff --git a/arch/arm/dts/imx6dl-hummingboard.dts b/arch/arm/dts/imx6dl-hummingboard.dts new file mode 100644 index 000000000000..cbd02eb486e1 --- /dev/null +++ b/arch/arm/dts/imx6dl-hummingboard.dts @@ -0,0 +1,52 @@ +/* + * Copyright (C) 2014 Rabeeh Khoury (rabeeh@solid-run.com) + * Based on dt work by Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; + +#include "imx6dl.dtsi" +#include "imx6qdl-sr-som.dtsi" +#include "imx6qdl-sr-som-brcm.dtsi" +#include "imx6qdl-hummingboard.dtsi" + +/ { + model = "SolidRun HummingBoard Solo/DualLite"; + compatible = "solidrun,hummingboard/dl", "fsl,imx6dl"; +}; diff --git a/arch/arm/dts/imx6q-cubox-i.dts b/arch/arm/dts/imx6q-cubox-i.dts new file mode 100644 index 000000000000..1c7b262e3709 --- /dev/null +++ b/arch/arm/dts/imx6q-cubox-i.dts @@ -0,0 +1,59 @@ +/* + * Copyright (C) 2014 Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; + +#include "imx6q.dtsi" +#include "imx6qdl-sr-som.dtsi" +#include "imx6qdl-sr-som-brcm.dtsi" +#include "imx6qdl-cubox-i.dtsi" + +/ { + model = "SolidRun Cubox-i Dual/Quad"; + compatible = "solidrun,cubox-i/q", "fsl,imx6q"; +}; + +&sata { + status = "okay"; + fsl,transmit-level-mV = <1104>; + fsl,transmit-boost-mdB = <0>; + fsl,transmit-atten-16ths = <9>; + fsl,no-spread-spectrum; +}; diff --git a/arch/arm/dts/imx6q-hummingboard.dts b/arch/arm/dts/imx6q-hummingboard.dts new file mode 100644 index 000000000000..8c9e94e648a7 --- /dev/null +++ b/arch/arm/dts/imx6q-hummingboard.dts @@ -0,0 +1,60 @@ +/* + * Copyright (C) 2014 Rabeeh Khoury (rabeeh@solid-run.com) + * Based on dt work by Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; + +#include "imx6q.dtsi" +#include "imx6qdl-sr-som.dtsi" +#include "imx6qdl-sr-som-brcm.dtsi" +#include "imx6qdl-hummingboard.dtsi" + +/ { + model = "SolidRun HummingBoard Dual/Quad"; + compatible = "solidrun,hummingboard/q", "fsl,imx6q"; +}; + +&sata { + status = "okay"; + fsl,transmit-level-mV = <1025>; + fsl,transmit-boost-mdB = <3330>; + fsl,transmit-atten-16ths = <9>; + fsl,receive-eq-mdB = <3000>; +}; diff --git a/arch/arm/dts/imx6qdl-cubox-i.dtsi b/arch/arm/dts/imx6qdl-cubox-i.dtsi new file mode 100644 index 000000000000..e3be453d8a4a --- /dev/null +++ b/arch/arm/dts/imx6qdl-cubox-i.dtsi @@ -0,0 +1,269 @@ +/* + * Copyright (C) 2014 Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +#include <dt-bindings/input/input.h> +#include <dt-bindings/gpio/gpio.h> + +/ { + /* Will be filled by the bootloader */ + memory@10000000 { + device_type = "memory"; + reg = <0x10000000 0>; + }; + + ir_recv: ir-receiver { + compatible = "gpio-ir-receiver"; + gpios = <&gpio3 9 1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_cubox_i_ir>; + }; + + pwmleds { + compatible = "pwm-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_cubox_i_pwm1>; + + front { + active-low; + label = "imx6:red:front"; + max-brightness = <248>; + pwms = <&pwm1 0 50000>; + }; + }; + + v_5v0: regulator-v-5v0 { + compatible = "regulator-fixed"; + regulator-always-on; + regulator-max-microvolt = <5000000>; + regulator-min-microvolt = <5000000>; + regulator-name = "v_5v0"; + }; + + v_usb2: regulator-v-usb2 { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio1 0 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_cubox_i_usbh1_vbus>; + regulator-max-microvolt = <5000000>; + regulator-min-microvolt = <5000000>; + regulator-name = "v_usb2"; + vin-supply = <&v_5v0>; + }; + + v_usb1: regulator-v-usb1 { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio3 22 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_cubox_i_usbotg_vbus>; + regulator-max-microvolt = <5000000>; + regulator-min-microvolt = <5000000>; + regulator-name = "v_usb1"; + vin-supply = <&v_5v0>; + }; + + sound-spdif { + compatible = "fsl,imx-audio-spdif"; + model = "Integrated SPDIF"; + /* IMX6 doesn't implement this yet */ + spdif-controller = <&spdif>; + spdif-out; + }; + + gpio-keys { + compatible = "gpio-keys"; + pinctrl-0 = <&pinctrl_gpio_key>; + pinctrl-names = "default"; + + button_0 { + label = "Button 0"; + gpios = <&gpio3 8 GPIO_ACTIVE_LOW>; + linux,code = <BTN_0>; + }; + }; +}; + +&hdmi { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_cubox_i_hdmi>; + ddc-i2c-bus = <&i2c2>; + status = "okay"; +}; + +&i2c2 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_cubox_i_i2c2>; + status = "okay"; +}; + +&i2c3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_cubox_i_i2c3>; + + status = "okay"; + + rtc@68 { + compatible = "nxp,pcf8523"; + reg = <0x68>; + }; +}; + +&iomuxc { + cubox_i { + pinctrl_cubox_i_hdmi: cubox-i-hdmi { + fsl,pins = < + MX6QDL_PAD_KEY_ROW2__HDMI_TX_CEC_LINE 0x1f8b0 + >; + }; + + pinctrl_cubox_i_i2c2: cubox-i-i2c2 { + fsl,pins = < + MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x4001b8b1 + MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x4001b8b1 + >; + }; + + pinctrl_cubox_i_i2c3: cubox-i-i2c3 { + fsl,pins = < + MX6QDL_PAD_EIM_D17__I2C3_SCL 0x4001b8b1 + MX6QDL_PAD_EIM_D18__I2C3_SDA 0x4001b8b1 + >; + }; + + pinctrl_cubox_i_ir: cubox-i-ir { + fsl,pins = < + MX6QDL_PAD_EIM_DA9__GPIO3_IO09 0x80000000 + >; + }; + + pinctrl_cubox_i_pwm1: cubox-i-pwm1-front-led { + fsl,pins = <MX6QDL_PAD_DISP0_DAT8__PWM1_OUT 0x1b0b0>; + }; + + pinctrl_cubox_i_spdif: cubox-i-spdif { + fsl,pins = <MX6QDL_PAD_GPIO_17__SPDIF_OUT 0x13091>; + }; + + pinctrl_cubox_i_usbh1: cubox-i-usbh1 { + fsl,pins = <MX6QDL_PAD_GPIO_3__USB_H1_OC 0x1b0b0>; + }; + + pinctrl_cubox_i_usbh1_vbus: cubox-i-usbh1-vbus { + fsl,pins = <MX6QDL_PAD_GPIO_0__GPIO1_IO00 0x4001b0b0>; + }; + + pinctrl_cubox_i_usbotg: cubox-i-usbotg { + /* + * The Cubox-i pulls ID low, but as it's pointless + * leaving it as a pull-up, even if it is just 10uA. + */ + fsl,pins = < + MX6QDL_PAD_GPIO_1__USB_OTG_ID 0x13059 + MX6QDL_PAD_KEY_COL4__USB_OTG_OC 0x1b0b0 + >; + }; + + pinctrl_cubox_i_usbotg_vbus: cubox-i-usbotg-vbus { + fsl,pins = <MX6QDL_PAD_EIM_D22__GPIO3_IO22 0x4001b0b0>; + }; + + pinctrl_cubox_i_usdhc2_aux: cubox-i-usdhc2-aux { + fsl,pins = < + MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x1f071 + MX6QDL_PAD_KEY_ROW1__SD2_VSELECT 0x1b071 + >; + }; + + pinctrl_cubox_i_usdhc2: cubox-i-usdhc2 { + fsl,pins = < + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x17059 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x10059 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x17059 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x17059 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x17059 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x13059 + >; + }; + + pinctrl_gpio_key: gpio-key { + fsl,pins = < + MX6QDL_PAD_EIM_DA8__GPIO3_IO08 0x17059 + >; + }; + }; +}; + +&pwm1 { + status = "okay"; +}; + +&spdif { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_cubox_i_spdif>; + status = "okay"; +}; + +&usbh1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_cubox_i_usbh1>; + vbus-supply = <&v_usb2>; + status = "okay"; +}; + +&usbotg { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_cubox_i_usbotg>; + vbus-supply = <&v_usb1>; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_cubox_i_usdhc2_aux &pinctrl_cubox_i_usdhc2>; + vmmc-supply = <&vcc_3v3>; + cd-gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&vcc_3v3 { + vin-supply = <&v_5v0>; +}; diff --git a/arch/arm/dts/imx6qdl-hummingboard.dtsi b/arch/arm/dts/imx6qdl-hummingboard.dtsi new file mode 100644 index 000000000000..2ffb21dd89f2 --- /dev/null +++ b/arch/arm/dts/imx6qdl-hummingboard.dtsi @@ -0,0 +1,368 @@ +/* + * Copyright (C) 2013,2014 Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +#include <dt-bindings/sound/fsl-imx-audmux.h> + +/ { + /* Will be filled by the bootloader */ + memory@10000000 { + device_type = "memory"; + reg = <0x10000000 0>; + }; + + chosen { + stdout-path = &uart1; + }; + + ir_recv: ir-receiver { + compatible = "gpio-ir-receiver"; + gpios = <&gpio3 5 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard_gpio3_5>; + }; + + v_3v2: regulator-v-3v2 { + compatible = "regulator-fixed"; + regulator-always-on; + regulator-max-microvolt = <3300000>; + regulator-min-microvolt = <3300000>; + regulator-name = "v_3v2"; + vin-supply = <&v_5v0>; + }; + + v_5v0: regulator-v-5v0 { + compatible = "regulator-fixed"; + regulator-always-on; + regulator-max-microvolt = <5000000>; + regulator-min-microvolt = <5000000>; + regulator-name = "v_5v0"; + }; + + v_sd: regulator-v-sd { + compatible = "regulator-fixed"; + gpio = <&gpio4 30 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard_vmmc>; + regulator-boot-on; + regulator-max-microvolt = <3300000>; + regulator-min-microvolt = <3300000>; + regulator-name = "v_sd"; + startup-delay-us = <1000>; + vin-supply = <&v_3v2>; + }; + + v_usb2: regulator-v-usb2 { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio1 0 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard_usbh1_vbus>; + regulator-max-microvolt = <5000000>; + regulator-min-microvolt = <5000000>; + regulator-name = "v_usb2"; + vin-supply = <&v_5v0>; + }; + + v_usb1: regulator-v-usb1 { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio3 22 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard_usbotg_vbus>; + regulator-max-microvolt = <5000000>; + regulator-min-microvolt = <5000000>; + regulator-name = "v_usb1"; + vin-supply = <&v_5v0>; + }; + + audio: sound-sgtl5000 { + compatible = "simple-audio-card"; + simple-audio-card,name = "On-board Codec"; + simple-audio-card,format = "i2s"; + simple-audio-card,bitclock-master = <&sound_codec>; + simple-audio-card,frame-master = <&sound_codec>; + simple-audio-card,widgets = + "Microphone", "Headphone Jack", + "Headphone", "Headphone Jack"; + simple-audio-card,routing = + "MIC_IN", "Headphone Jack", + "Headphone Jack", "Mic Bias", + "Headphone Jack", "HP_OUT"; + + sound_cpu: simple-audio-card,cpu { + sound-dai = <&ssi1>; + }; + + sound_codec: simple-audio-card,codec { + sound-dai = <&sgtl5000>; + }; + }; + + sound-spdif { + compatible = "fsl,imx-audio-spdif"; + model = "On-board SPDIF"; + /* IMX6 doesn't implement this yet */ + spdif-controller = <&spdif>; + spdif-out; + }; +}; + +&audmux { + status = "okay"; + + ssi1 { + fsl,audmux-port = <0>; + fsl,port-config = < + (IMX_AUDMUX_V2_PTCR_SYN | + IMX_AUDMUX_V2_PTCR_TFSEL(4) | + IMX_AUDMUX_V2_PTCR_TCSEL(4) | + IMX_AUDMUX_V2_PTCR_TFSDIR | + IMX_AUDMUX_V2_PTCR_TCLKDIR) + IMX_AUDMUX_V2_PDCR_RXDSEL(4) + >; + }; + + pins5 { + fsl,audmux-port = <4>; + fsl,port-config = < + IMX_AUDMUX_V2_PTCR_SYN + IMX_AUDMUX_V2_PDCR_RXDSEL(0) + >; + }; +}; + +&can1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard_flexcan1>; + status = "okay"; +}; + +&hdmi { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard_hdmi>; + ddc-i2c-bus = <&i2c2>; + status = "okay"; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard_i2c1>; + status = "okay"; + + /* Pro baseboard model */ + rtc@68 { + compatible = "nxp,pcf8523"; + reg = <0x68>; + }; + + /* Pro baseboard model */ + sgtl5000: codec@a { + clocks = <&clks IMX6QDL_CLK_CKO>; + compatible = "fsl,sgtl5000"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard_sgtl5000>; + #sound-dai-cells = <0>; + reg = <0x0a>; + VDDA-supply = <&v_3v2>; + VDDIO-supply = <&v_3v2>; + }; +}; + +&i2c2 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard_i2c2>; + status = "okay"; +}; + +&iomuxc { + hummingboard { + pinctrl_hummingboard_flexcan1: hummingboard-flexcan1 { + fsl,pins = < + MX6QDL_PAD_SD3_CLK__FLEXCAN1_RX 0x80000000 + MX6QDL_PAD_SD3_CMD__FLEXCAN1_TX 0x80000000 + >; + }; + + pinctrl_hummingboard_gpio3_5: hummingboard-gpio3_5 { + fsl,pins = < + MX6QDL_PAD_EIM_DA5__GPIO3_IO05 0x1b0b1 + >; + }; + + pinctrl_hummingboard_hdmi: hummingboard-hdmi { + fsl,pins = < + MX6QDL_PAD_KEY_ROW2__HDMI_TX_CEC_LINE 0x1f8b0 + >; + }; + + pinctrl_hummingboard_i2c1: hummingboard-i2c1 { + fsl,pins = < + MX6QDL_PAD_EIM_D21__I2C1_SCL 0x4001b8b1 + MX6QDL_PAD_EIM_D28__I2C1_SDA 0x4001b8b1 + >; + }; + + pinctrl_hummingboard_i2c2: hummingboard-i2c2 { + fsl,pins = < + MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x4001b8b1 + MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x4001b8b1 + >; + }; + + pinctrl_hummingboard_pcie_reset: hummingboard-pcie-reset { + fsl,pins = < + MX6QDL_PAD_EIM_DA4__GPIO3_IO04 0x1b0b1 + >; + }; + + pinctrl_hummingboard_pwm1: pwm1grp { + fsl,pins = <MX6QDL_PAD_DISP0_DAT8__PWM1_OUT 0x1b0b1>; + }; + + pinctrl_hummingboard_sgtl5000: hummingboard-sgtl5000 { + fsl,pins = < + MX6QDL_PAD_DISP0_DAT19__AUD5_RXD 0x130b0 + MX6QDL_PAD_KEY_COL0__AUD5_TXC 0x130b0 + MX6QDL_PAD_KEY_ROW0__AUD5_TXD 0x110b0 + MX6QDL_PAD_KEY_COL1__AUD5_TXFS 0x130b0 + MX6QDL_PAD_GPIO_5__CCM_CLKO1 0x130b0 + >; + }; + + pinctrl_hummingboard_spdif: hummingboard-spdif { + fsl,pins = <MX6QDL_PAD_GPIO_17__SPDIF_OUT 0x13091>; + }; + + pinctrl_hummingboard_usbh1_vbus: hummingboard-usbh1-vbus { + fsl,pins = <MX6QDL_PAD_GPIO_0__GPIO1_IO00 0x1b0b0>; + }; + + pinctrl_hummingboard_usbotg_id: hummingboard-usbotg-id { + /* + * We want it pulled down for a fixed host connection. + */ + fsl,pins = <MX6QDL_PAD_ENET_RX_ER__USB_OTG_ID 0x13059>; + }; + + pinctrl_hummingboard_usbotg_vbus: hummingboard-usbotg-vbus { + fsl,pins = <MX6QDL_PAD_EIM_D22__GPIO3_IO22 0x1b0b0>; + }; + + pinctrl_hummingboard_usdhc2_aux: hummingboard-usdhc2-aux { + fsl,pins = < + MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x1f071 + >; + }; + + pinctrl_hummingboard_usdhc2: hummingboard-usdhc2 { + fsl,pins = < + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x17059 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x10059 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x17059 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x17059 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x17059 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x13059 + >; + }; + pinctrl_hummingboard_vmmc: hummingboard-vmmc { + fsl,pins = < + MX6QDL_PAD_DISP0_DAT9__GPIO4_IO30 0x1b0b0 + >; + }; + }; +}; + +&pcie { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard_pcie_reset>; + reset-gpio = <&gpio3 4 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&pwm1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard_pwm1>; + status = "okay"; +}; + +&pwm2 { + pinctrl-names = "default"; + status = "okay"; +}; + +&spdif { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard_spdif>; + status = "okay"; +}; + +&ssi1 { + status = "okay"; +}; + +&usbh1 { + disable-over-current; + vbus-supply = <&v_usb2>; + status = "okay"; +}; + +&usbotg { + disable-over-current; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard_usbotg_id>; + vbus-supply = <&v_usb1>; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default"; + pinctrl-0 = < + &pinctrl_hummingboard_usdhc2_aux + &pinctrl_hummingboard_usdhc2 + >; + vmmc-supply = <&v_sd>; + cd-gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&vcc_3v3 { + vin-supply = <&v_3v2>; +}; diff --git a/arch/arm/dts/imx6qdl-sr-som-brcm.dtsi b/arch/arm/dts/imx6qdl-sr-som-brcm.dtsi new file mode 100644 index 000000000000..b55af61dfeca --- /dev/null +++ b/arch/arm/dts/imx6qdl-sr-som-brcm.dtsi @@ -0,0 +1,144 @@ +/* + * Copyright (C) 2013,2014 Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +#include <dt-bindings/gpio/gpio.h> +/ { + clk_brcm: brcm-clock { + compatible = "gpio-gate-clock"; + #clock-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_microsom_brcm_osc>; + enable-gpios = <&gpio5 5 GPIO_ACTIVE_HIGH>; + }; + + reg_brcm: brcm-reg { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio3 19 0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_microsom_brcm_reg>; + regulator-name = "brcm_reg"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <200000>; + }; + + usdhc1_pwrseq: usdhc1_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&gpio5 26 GPIO_ACTIVE_LOW>, + <&gpio6 0 GPIO_ACTIVE_LOW>; + clocks = <&clk_brcm>; + clock-names = "ext_clock"; + }; +}; + +&iomuxc { + microsom { + pinctrl_microsom_brcm_bt: microsom-brcm-bt { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT14__GPIO6_IO00 0x40013070 + MX6QDL_PAD_CSI0_DAT15__GPIO6_IO01 0x40013070 + MX6QDL_PAD_CSI0_DAT18__GPIO6_IO04 0x40013070 + >; + }; + + pinctrl_microsom_brcm_osc: microsom-brcm-osc { + fsl,pins = < + MX6QDL_PAD_DISP0_DAT11__GPIO5_IO05 0x40013070 + >; + }; + + pinctrl_microsom_brcm_reg: microsom-brcm-reg { + fsl,pins = < + MX6QDL_PAD_EIM_D19__GPIO3_IO19 0x40013070 + >; + }; + + pinctrl_microsom_brcm_wifi: microsom-brcm-wifi { + fsl,pins = < + MX6QDL_PAD_GPIO_8__XTALOSC_REF_CLK_32K 0x1b0b0 + MX6QDL_PAD_CSI0_DATA_EN__GPIO5_IO20 0x40013070 + MX6QDL_PAD_CSI0_DAT8__GPIO5_IO26 0x40013070 + MX6QDL_PAD_CSI0_DAT9__GPIO5_IO27 0x40013070 + >; + }; + + pinctrl_microsom_uart4: microsom-uart4 { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT12__UART4_TX_DATA 0x1b0b1 + MX6QDL_PAD_CSI0_DAT13__UART4_RX_DATA 0x1b0b1 + MX6QDL_PAD_CSI0_DAT16__UART4_RTS_B 0x1b0b1 + MX6QDL_PAD_CSI0_DAT17__UART4_CTS_B 0x1b0b1 + >; + }; + + pinctrl_microsom_usdhc1: microsom-usdhc1 { + fsl,pins = < + MX6QDL_PAD_SD1_CMD__SD1_CMD 0x17059 + MX6QDL_PAD_SD1_CLK__SD1_CLK 0x10059 + MX6QDL_PAD_SD1_DAT0__SD1_DATA0 0x17059 + MX6QDL_PAD_SD1_DAT1__SD1_DATA1 0x17059 + MX6QDL_PAD_SD1_DAT2__SD1_DATA2 0x17059 + MX6QDL_PAD_SD1_DAT3__SD1_DATA3 0x17059 + >; + }; + }; +}; + +/* UART4 - Connected to optional BRCM Wifi/BT/FM */ +&uart4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_microsom_brcm_bt &pinctrl_microsom_uart4>; + uart-has-rtscts; + status = "okay"; +}; + +/* USDHC1 - Connected to optional BRCM Wifi/BT/FM */ +&usdhc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_microsom_brcm_wifi &pinctrl_microsom_usdhc1>; + bus-width = <4>; + mmc-pwrseq = <&usdhc1_pwrseq>; + keep-power-in-suspend; + no-1-8-v; + non-removable; + vmmc-supply = <®_brcm>; + status = "okay"; +}; diff --git a/arch/arm/dts/imx6qdl-sr-som.dtsi b/arch/arm/dts/imx6qdl-sr-som.dtsi new file mode 100644 index 000000000000..6d7f6b9035bc --- /dev/null +++ b/arch/arm/dts/imx6qdl-sr-som.dtsi @@ -0,0 +1,121 @@ +/* + * Copyright (C) 2013,2014 Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +#include <dt-bindings/gpio/gpio.h> + +/ { + vcc_3v3: regulator-vcc-3v3 { + compatible = "regulator-fixed"; + regulator-always-on; + regulator-name = "vcc_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; +}; + +&fec { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_microsom_enet_ar8035>; + phy-mode = "rgmii-id"; + phy-reset-duration = <2>; + phy-reset-gpios = <&gpio4 15 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&iomuxc { + microsom { + pinctrl_microsom_enet_ar8035: microsom-enet-ar8035 { + fsl,pins = < + MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1b8b0 + MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1b0b0 + /* AR8035 reset */ + MX6QDL_PAD_KEY_ROW4__GPIO4_IO15 0x130b0 + /* AR8035 interrupt */ + MX6QDL_PAD_DI0_PIN2__GPIO4_IO18 0x1b0b0 + /* GPIO16 -> AR8035 25MHz */ + MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x4001b0b0 + MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x13030 + MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x1b030 + MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x1b030 + MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x1b030 + MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x1b030 + MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x1b030 + /* AR8035 CLK_25M --> ENET_REF_CLK (V22) */ + MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x0a0b1 + /* AR8035 pin strapping: IO voltage: pull up */ + MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x1b030 + /* AR8035 pin strapping: PHYADDR#0: pull down */ + MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x13030 + /* AR8035 pin strapping: PHYADDR#1: pull down */ + MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x13030 + /* AR8035 pin strapping: MODE#1: pull up */ + MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x1b030 + /* AR8035 pin strapping: MODE#3: pull up */ + MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x1b030 + /* AR8035 pin strapping: MODE#0: pull down */ + MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x13030 + + /* + * As the RMII pins are also connected to RGMII + * so that an AR8030 can be placed, set these + * to high-z with the same pulls as above. + * Use the GPIO settings to avoid changing the + * input select registers. + */ + MX6QDL_PAD_ENET_CRS_DV__GPIO1_IO25 0x03000 + MX6QDL_PAD_ENET_RXD0__GPIO1_IO27 0x03000 + MX6QDL_PAD_ENET_RXD1__GPIO1_IO26 0x03000 + >; + }; + + pinctrl_microsom_uart1: microsom-uart1 { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT10__UART1_TX_DATA 0x1b0b1 + MX6QDL_PAD_CSI0_DAT11__UART1_RX_DATA 0x1b0b1 + >; + }; + }; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_microsom_uart1>; + status = "okay"; +};
Reviewed-by: Fabio Estevam festevam@gmail.com
These DT files are copied from kernel v5.3 with no changes. This is part 1 of 2 commits. Included are DT files for the original Cubox-i and Hummingboard Base/Pro. Signed-off-by: Baruch Siach baruch@tkos.co.il Reviewed-by: Fabio Estevam festevam@gmail.com
Applied to u-boot-imx, -next, thanks !
Best regards, Stefano Babic
This is part 2 of 2 commits. Included are DT files for SOM rev 1.5, and Hummingboard2 Gate/Edge.
Signed-off-by: Baruch Siach baruch@tkos.co.il --- v2: Splits into two commits to comply with list size limits --- arch/arm/dts/Makefile | 14 + arch/arm/dts/imx6dl-cubox-i-emmc-som-v15.dts | 52 ++ arch/arm/dts/imx6dl-cubox-i-som-v15.dts | 51 ++ .../dts/imx6dl-hummingboard-emmc-som-v15.dts | 53 ++ arch/arm/dts/imx6dl-hummingboard-som-v15.dts | 52 ++ ...6dl-hummingboard2-emmc-som-v15-u-boot.dtsi | 1 + .../dts/imx6dl-hummingboard2-emmc-som-v15.dts | 55 ++ arch/arm/dts/imx6dl-hummingboard2-som-v15.dts | 54 ++ arch/arm/dts/imx6dl-hummingboard2.dts | 53 ++ arch/arm/dts/imx6q-cubox-i-emmc-som-v15.dts | 60 ++ arch/arm/dts/imx6q-cubox-i-som-v15.dts | 59 ++ .../dts/imx6q-hummingboard-emmc-som-v15.dts | 61 ++ arch/arm/dts/imx6q-hummingboard-som-v15.dts | 60 ++ ...x6q-hummingboard2-emmc-som-v15-u-boot.dtsi | 1 + .../dts/imx6q-hummingboard2-emmc-som-v15.dts | 63 ++ arch/arm/dts/imx6q-hummingboard2-som-v15.dts | 62 ++ arch/arm/dts/imx6q-hummingboard2.dts | 61 ++ ...qdl-hummingboard2-emmc-som-v15-u-boot.dtsi | 36 ++ arch/arm/dts/imx6qdl-hummingboard2-emmc.dtsi | 72 +++ arch/arm/dts/imx6qdl-hummingboard2.dtsi | 577 ++++++++++++++++++ arch/arm/dts/imx6qdl-sr-som-emmc.dtsi | 70 +++ arch/arm/dts/imx6qdl-sr-som-ti.dtsi | 170 ++++++ 22 files changed, 1737 insertions(+) create mode 100644 arch/arm/dts/imx6dl-cubox-i-emmc-som-v15.dts create mode 100644 arch/arm/dts/imx6dl-cubox-i-som-v15.dts create mode 100644 arch/arm/dts/imx6dl-hummingboard-emmc-som-v15.dts create mode 100644 arch/arm/dts/imx6dl-hummingboard-som-v15.dts create mode 100644 arch/arm/dts/imx6dl-hummingboard2-emmc-som-v15-u-boot.dtsi create mode 100644 arch/arm/dts/imx6dl-hummingboard2-emmc-som-v15.dts create mode 100644 arch/arm/dts/imx6dl-hummingboard2-som-v15.dts create mode 100644 arch/arm/dts/imx6dl-hummingboard2.dts create mode 100644 arch/arm/dts/imx6q-cubox-i-emmc-som-v15.dts create mode 100644 arch/arm/dts/imx6q-cubox-i-som-v15.dts create mode 100644 arch/arm/dts/imx6q-hummingboard-emmc-som-v15.dts create mode 100644 arch/arm/dts/imx6q-hummingboard-som-v15.dts create mode 100644 arch/arm/dts/imx6q-hummingboard2-emmc-som-v15-u-boot.dtsi create mode 100644 arch/arm/dts/imx6q-hummingboard2-emmc-som-v15.dts create mode 100644 arch/arm/dts/imx6q-hummingboard2-som-v15.dts create mode 100644 arch/arm/dts/imx6q-hummingboard2.dts create mode 100644 arch/arm/dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi create mode 100644 arch/arm/dts/imx6qdl-hummingboard2-emmc.dtsi create mode 100644 arch/arm/dts/imx6qdl-hummingboard2.dtsi create mode 100644 arch/arm/dts/imx6qdl-sr-som-emmc.dtsi create mode 100644 arch/arm/dts/imx6qdl-sr-som-ti.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index a2ed92b77f15..866ee1605722 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -561,8 +561,15 @@ dtb-$(CONFIG_MX53) += imx53-cx9020.dtb \ ifneq ($(CONFIG_MX6DL)$(CONFIG_MX6QDL)$(CONFIG_MX6S),) dtb-y += \ imx6dl-cubox-i.dtb \ + imx6dl-cubox-i-emmc-som-v15.dtb \ + imx6dl-cubox-i-som-v15.dtb \ imx6dl-dhcom-pdk2.dtb \ + imx6dl-hummingboard2.dtb \ + imx6dl-hummingboard2-emmc-som-v15.dtb \ + imx6dl-hummingboard2-som-v15.dtb \ imx6dl-hummingboard.dtb \ + imx6dl-hummingboard-emmc-som-v15.dtb \ + imx6dl-hummingboard-som-v15.dtb \ imx6dl-icore.dtb \ imx6dl-icore-mipi.dtb \ imx6dl-icore-rqs.dtb \ @@ -580,9 +587,16 @@ dtb-y += \ imx6-apalis.dtb \ imx6q-cm-fx6.dtb \ imx6q-cubox-i.dtb \ + imx6q-cubox-i-emmc-som-v15.dtb \ + imx6q-cubox-i-som-v15.dtb \ imx6q-dhcom-pdk2.dtb \ imx6q-display5.dtb \ + imx6q-hummingboard2.dtb \ + imx6q-hummingboard2-emmc-som-v15.dtb \ + imx6q-hummingboard2-som-v15.dtb \ imx6q-hummingboard.dtb \ + imx6q-hummingboard-emmc-som-v15.dtb \ + imx6q-hummingboard-som-v15.dtb \ imx6q-icore.dtb \ imx6q-icore-mipi.dtb \ imx6q-icore-rqs.dtb \ diff --git a/arch/arm/dts/imx6dl-cubox-i-emmc-som-v15.dts b/arch/arm/dts/imx6dl-cubox-i-emmc-som-v15.dts new file mode 100644 index 000000000000..2b2fc360b865 --- /dev/null +++ b/arch/arm/dts/imx6dl-cubox-i-emmc-som-v15.dts @@ -0,0 +1,52 @@ +/* + * Copyright (C) 2014 Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; + +#include "imx6dl.dtsi" +#include "imx6qdl-sr-som.dtsi" +#include "imx6qdl-sr-som-ti.dtsi" +#include "imx6qdl-sr-som-emmc.dtsi" +#include "imx6qdl-cubox-i.dtsi" + +/ { + model = "SolidRun Cubox-i Solo/DualLite (1.5som+emmc)"; + compatible = "solidrun,cubox-i/dl", "fsl,imx6dl"; +}; diff --git a/arch/arm/dts/imx6dl-cubox-i-som-v15.dts b/arch/arm/dts/imx6dl-cubox-i-som-v15.dts new file mode 100644 index 000000000000..e09c565d1d1f --- /dev/null +++ b/arch/arm/dts/imx6dl-cubox-i-som-v15.dts @@ -0,0 +1,51 @@ +/* + * Copyright (C) 2014 Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; + +#include "imx6dl.dtsi" +#include "imx6qdl-sr-som.dtsi" +#include "imx6qdl-sr-som-ti.dtsi" +#include "imx6qdl-cubox-i.dtsi" + +/ { + model = "SolidRun Cubox-i Solo/DualLite (1.5som)"; + compatible = "solidrun,cubox-i/dl", "fsl,imx6dl"; +}; diff --git a/arch/arm/dts/imx6dl-hummingboard-emmc-som-v15.dts b/arch/arm/dts/imx6dl-hummingboard-emmc-som-v15.dts new file mode 100644 index 000000000000..a63f742f20d9 --- /dev/null +++ b/arch/arm/dts/imx6dl-hummingboard-emmc-som-v15.dts @@ -0,0 +1,53 @@ +/* + * Copyright (C) 2014 Rabeeh Khoury (rabeeh@solid-run.com) + * Based on dt work by Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; + +#include "imx6dl.dtsi" +#include "imx6qdl-sr-som.dtsi" +#include "imx6qdl-sr-som-ti.dtsi" +#include "imx6qdl-sr-som-emmc.dtsi" +#include "imx6qdl-hummingboard.dtsi" + +/ { + model = "SolidRun HummingBoard Solo/DualLite (1.5som+emmc)"; + compatible = "solidrun,hummingboard/dl", "fsl,imx6dl"; +}; diff --git a/arch/arm/dts/imx6dl-hummingboard-som-v15.dts b/arch/arm/dts/imx6dl-hummingboard-som-v15.dts new file mode 100644 index 000000000000..66a06cf3cdf3 --- /dev/null +++ b/arch/arm/dts/imx6dl-hummingboard-som-v15.dts @@ -0,0 +1,52 @@ +/* + * Copyright (C) 2014 Rabeeh Khoury (rabeeh@solid-run.com) + * Based on dt work by Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; + +#include "imx6dl.dtsi" +#include "imx6qdl-sr-som.dtsi" +#include "imx6qdl-sr-som-ti.dtsi" +#include "imx6qdl-hummingboard.dtsi" + +/ { + model = "SolidRun HummingBoard Solo/DualLite (1.5som)"; + compatible = "solidrun,hummingboard/dl", "fsl,imx6dl"; +}; diff --git a/arch/arm/dts/imx6dl-hummingboard2-emmc-som-v15-u-boot.dtsi b/arch/arm/dts/imx6dl-hummingboard2-emmc-som-v15-u-boot.dtsi new file mode 100644 index 000000000000..89fbec4d06fe --- /dev/null +++ b/arch/arm/dts/imx6dl-hummingboard2-emmc-som-v15-u-boot.dtsi @@ -0,0 +1 @@ +#include "imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi" diff --git a/arch/arm/dts/imx6dl-hummingboard2-emmc-som-v15.dts b/arch/arm/dts/imx6dl-hummingboard2-emmc-som-v15.dts new file mode 100644 index 000000000000..80313c13bcdb --- /dev/null +++ b/arch/arm/dts/imx6dl-hummingboard2-emmc-som-v15.dts @@ -0,0 +1,55 @@ +/* + * Device Tree file for SolidRun HummingBoard2 + * Copyright (C) 2015 Rabeeh Khoury rabeeh@solid-run.com + * Based on work by Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License. + * + * This file is distributed in the hope that it will be useful + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; + +#include "imx6dl.dtsi" +#include "imx6qdl-sr-som.dtsi" +#include "imx6qdl-sr-som-emmc.dtsi" +#include "imx6qdl-sr-som-ti.dtsi" +#include "imx6qdl-hummingboard2.dtsi" + +/ { + model = "SolidRun HummingBoard2 Solo/DualLite (1.5som+emmc)"; + compatible = "solidrun,hummingboard2/dl", "fsl,imx6dl"; +}; diff --git a/arch/arm/dts/imx6dl-hummingboard2-som-v15.dts b/arch/arm/dts/imx6dl-hummingboard2-som-v15.dts new file mode 100644 index 000000000000..e61ef1156f8b --- /dev/null +++ b/arch/arm/dts/imx6dl-hummingboard2-som-v15.dts @@ -0,0 +1,54 @@ +/* + * Device Tree file for SolidRun HummingBoard2 + * Copyright (C) 2015 Rabeeh Khoury rabeeh@solid-run.com + * Based on work by Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License. + * + * This file is distributed in the hope that it will be useful + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; + +#include "imx6dl.dtsi" +#include "imx6qdl-sr-som.dtsi" +#include "imx6qdl-sr-som-ti.dtsi" +#include "imx6qdl-hummingboard2.dtsi" + +/ { + model = "SolidRun HummingBoard2 Solo/DualLite (1.5som)"; + compatible = "solidrun,hummingboard2/dl", "fsl,imx6dl"; +}; diff --git a/arch/arm/dts/imx6dl-hummingboard2.dts b/arch/arm/dts/imx6dl-hummingboard2.dts new file mode 100644 index 000000000000..b12cd87f3f94 --- /dev/null +++ b/arch/arm/dts/imx6dl-hummingboard2.dts @@ -0,0 +1,53 @@ +/* + * Copyright (C) 2015 Rabeeh Khoury rabeeh@solid-run.com + * Based on dt work by Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; + +#include "imx6dl.dtsi" +#include "imx6qdl-sr-som.dtsi" +#include "imx6qdl-sr-som-brcm.dtsi" +#include "imx6qdl-hummingboard2.dtsi" +#include "imx6qdl-hummingboard2-emmc.dtsi" + +/ { + model = "SolidRun HummingBoard2 Solo/DualLite"; + compatible = "solidrun,hummingboard2/dl", "fsl,imx6dl"; +}; diff --git a/arch/arm/dts/imx6q-cubox-i-emmc-som-v15.dts b/arch/arm/dts/imx6q-cubox-i-emmc-som-v15.dts new file mode 100644 index 000000000000..3e59ebbb3608 --- /dev/null +++ b/arch/arm/dts/imx6q-cubox-i-emmc-som-v15.dts @@ -0,0 +1,60 @@ +/* + * Copyright (C) 2014 Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; + +#include "imx6q.dtsi" +#include "imx6qdl-sr-som.dtsi" +#include "imx6qdl-sr-som-ti.dtsi" +#include "imx6qdl-sr-som-emmc.dtsi" +#include "imx6qdl-cubox-i.dtsi" + +/ { + model = "SolidRun Cubox-i Dual/Quad (1.5som+emmc)"; + compatible = "solidrun,cubox-i/q", "fsl,imx6q"; +}; + +&sata { + status = "okay"; + fsl,transmit-level-mV = <1104>; + fsl,transmit-boost-mdB = <0>; + fsl,transmit-atten-16ths = <9>; + fsl,no-spread-spectrum; +}; diff --git a/arch/arm/dts/imx6q-cubox-i-som-v15.dts b/arch/arm/dts/imx6q-cubox-i-som-v15.dts new file mode 100644 index 000000000000..dab70d1230a2 --- /dev/null +++ b/arch/arm/dts/imx6q-cubox-i-som-v15.dts @@ -0,0 +1,59 @@ +/* + * Copyright (C) 2014 Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; + +#include "imx6q.dtsi" +#include "imx6qdl-sr-som.dtsi" +#include "imx6qdl-sr-som-ti.dtsi" +#include "imx6qdl-cubox-i.dtsi" + +/ { + model = "SolidRun Cubox-i Dual/Quad (1.5som)"; + compatible = "solidrun,cubox-i/q", "fsl,imx6q"; +}; + +&sata { + status = "okay"; + fsl,transmit-level-mV = <1104>; + fsl,transmit-boost-mdB = <0>; + fsl,transmit-atten-16ths = <9>; + fsl,no-spread-spectrum; +}; diff --git a/arch/arm/dts/imx6q-hummingboard-emmc-som-v15.dts b/arch/arm/dts/imx6q-hummingboard-emmc-som-v15.dts new file mode 100644 index 000000000000..c51b4e4fd71e --- /dev/null +++ b/arch/arm/dts/imx6q-hummingboard-emmc-som-v15.dts @@ -0,0 +1,61 @@ +/* + * Copyright (C) 2014 Rabeeh Khoury (rabeeh@solid-run.com) + * Based on dt work by Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; + +#include "imx6q.dtsi" +#include "imx6qdl-sr-som.dtsi" +#include "imx6qdl-sr-som-ti.dtsi" +#include "imx6qdl-sr-som-emmc.dtsi" +#include "imx6qdl-hummingboard.dtsi" + +/ { + model = "SolidRun HummingBoard Dual/Quad (1.5som+emmc)"; + compatible = "solidrun,hummingboard/q", "fsl,imx6q"; +}; + +&sata { + status = "okay"; + fsl,transmit-level-mV = <1025>; + fsl,transmit-boost-mdB = <3330>; + fsl,transmit-atten-16ths = <9>; + fsl,receive-eq-mdB = <3000>; +}; diff --git a/arch/arm/dts/imx6q-hummingboard-som-v15.dts b/arch/arm/dts/imx6q-hummingboard-som-v15.dts new file mode 100644 index 000000000000..e4132d62ffa2 --- /dev/null +++ b/arch/arm/dts/imx6q-hummingboard-som-v15.dts @@ -0,0 +1,60 @@ +/* + * Copyright (C) 2014 Rabeeh Khoury (rabeeh@solid-run.com) + * Based on dt work by Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; + +#include "imx6q.dtsi" +#include "imx6qdl-sr-som.dtsi" +#include "imx6qdl-sr-som-ti.dtsi" +#include "imx6qdl-hummingboard.dtsi" + +/ { + model = "SolidRun HummingBoard Dual/Quad (1.5som)"; + compatible = "solidrun,hummingboard/q", "fsl,imx6q"; +}; + +&sata { + status = "okay"; + fsl,transmit-level-mV = <1025>; + fsl,transmit-boost-mdB = <3330>; + fsl,transmit-atten-16ths = <9>; + fsl,receive-eq-mdB = <3000>; +}; diff --git a/arch/arm/dts/imx6q-hummingboard2-emmc-som-v15-u-boot.dtsi b/arch/arm/dts/imx6q-hummingboard2-emmc-som-v15-u-boot.dtsi new file mode 100644 index 000000000000..89fbec4d06fe --- /dev/null +++ b/arch/arm/dts/imx6q-hummingboard2-emmc-som-v15-u-boot.dtsi @@ -0,0 +1 @@ +#include "imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi" diff --git a/arch/arm/dts/imx6q-hummingboard2-emmc-som-v15.dts b/arch/arm/dts/imx6q-hummingboard2-emmc-som-v15.dts new file mode 100644 index 000000000000..1998ebfa0fe0 --- /dev/null +++ b/arch/arm/dts/imx6q-hummingboard2-emmc-som-v15.dts @@ -0,0 +1,63 @@ +/* + * Device Tree file for SolidRun HummingBoard2 + * Copyright (C) 2015 Rabeeh Khoury rabeeh@solid-run.com + * Based on work by Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License. + * + * This file is distributed in the hope that it will be useful + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; + +#include "imx6q.dtsi" +#include "imx6qdl-sr-som.dtsi" +#include "imx6qdl-sr-som-emmc.dtsi" +#include "imx6qdl-sr-som-ti.dtsi" +#include "imx6qdl-hummingboard2.dtsi" + +/ { + model = "SolidRun HummingBoard2 Dual/Quad (1.5som+emmc)"; + compatible = "solidrun,hummingboard2/q", "fsl,imx6q"; +}; + +&sata { + status = "okay"; + fsl,transmit-level-mV = <1104>; + fsl,transmit-boost-mdB = <0>; + fsl,transmit-atten-16ths = <9>; + fsl,no-spread-spectrum; +}; diff --git a/arch/arm/dts/imx6q-hummingboard2-som-v15.dts b/arch/arm/dts/imx6q-hummingboard2-som-v15.dts new file mode 100644 index 000000000000..d3ad7329cd6d --- /dev/null +++ b/arch/arm/dts/imx6q-hummingboard2-som-v15.dts @@ -0,0 +1,62 @@ +/* + * Device Tree file for SolidRun HummingBoard2 + * Copyright (C) 2015 Rabeeh Khoury rabeeh@solid-run.com + * Based on work by Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License. + * + * This file is distributed in the hope that it will be useful + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; + +#include "imx6q.dtsi" +#include "imx6qdl-sr-som.dtsi" +#include "imx6qdl-sr-som-ti.dtsi" +#include "imx6qdl-hummingboard2.dtsi" + +/ { + model = "SolidRun HummingBoard2 Dual/Quad (1.5som)"; + compatible = "solidrun,hummingboard2/q", "fsl,imx6q"; +}; + +&sata { + status = "okay"; + fsl,transmit-level-mV = <1104>; + fsl,transmit-boost-mdB = <0>; + fsl,transmit-atten-16ths = <9>; + fsl,no-spread-spectrum; +}; diff --git a/arch/arm/dts/imx6q-hummingboard2.dts b/arch/arm/dts/imx6q-hummingboard2.dts new file mode 100644 index 000000000000..5249f53dcdbc --- /dev/null +++ b/arch/arm/dts/imx6q-hummingboard2.dts @@ -0,0 +1,61 @@ +/* + * Copyright (C) 2015 Rabeeh Khoury rabeeh@solid-run.com + * Based on dt work by Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; + +#include "imx6q.dtsi" +#include "imx6qdl-sr-som.dtsi" +#include "imx6qdl-sr-som-brcm.dtsi" +#include "imx6qdl-hummingboard2.dtsi" +#include "imx6qdl-hummingboard2-emmc.dtsi" + +/ { + model = "SolidRun HummingBoard2 Dual/Quad"; + compatible = "solidrun,hummingboard2/q", "fsl,imx6q"; +}; + +&sata { + status = "okay"; + fsl,transmit-level-mV = <1104>; + fsl,transmit-boost-mdB = <0>; + fsl,transmit-atten-16ths = <9>; + fsl,no-spread-spectrum; +}; diff --git a/arch/arm/dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi b/arch/arm/dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi new file mode 100644 index 000000000000..d302b2e27585 --- /dev/null +++ b/arch/arm/dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi @@ -0,0 +1,36 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include "imx6qdl-u-boot.dtsi" + +/ { + board-detect { + compatible = "solidrun,hummingboard-detect"; + detect-gpios = < + &gpio2 8 0 + &gpio3 4 0 + &gpio4 9 0 + &gpio6 0 0 + &gpio6 4 0 + >; + }; +}; + +&gpio2 { + u-boot,dm-pre-reloc; +}; + +&gpio3 { + u-boot,dm-pre-reloc; +}; + +&gpio4 { + u-boot,dm-pre-reloc; +}; + +&gpio6 { + u-boot,dm-pre-reloc; +}; + +&usdhc1 { + status = "disabled"; +}; diff --git a/arch/arm/dts/imx6qdl-hummingboard2-emmc.dtsi b/arch/arm/dts/imx6qdl-hummingboard2-emmc.dtsi new file mode 100644 index 000000000000..f400405381a7 --- /dev/null +++ b/arch/arm/dts/imx6qdl-hummingboard2-emmc.dtsi @@ -0,0 +1,72 @@ +/* + * Device Tree file for SolidRun HummingBoard2 + * Copyright (C) 2015 Rabeeh Khoury rabeeh@solid-run.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +&iomuxc { + hummingboard2 { + pinctrl_hummingboard2_usdhc3: hummingboard2-usdhc3 { + fsl,pins = < + MX6QDL_PAD_SD3_CMD__SD3_CMD 0x17059 + MX6QDL_PAD_SD3_CLK__SD3_CLK 0x10059 + MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x17059 + MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x17059 + MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x17059 + MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x17059 + MX6QDL_PAD_SD3_DAT4__SD3_DATA4 0x17059 + MX6QDL_PAD_SD3_DAT5__SD3_DATA5 0x17059 + MX6QDL_PAD_SD3_DAT6__SD3_DATA6 0x17059 + MX6QDL_PAD_SD3_DAT7__SD3_DATA7 0x17059 + MX6QDL_PAD_SD3_RST__SD3_RESET 0x17059 + >; + }; + }; +}; + +&usdhc3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard2_usdhc3>; + vmmc-supply = <&v_3v2>; + vqmmc-supply = <&v_3v2>; + bus-width = <8>; + non-removable; + status = "okay"; +}; diff --git a/arch/arm/dts/imx6qdl-hummingboard2.dtsi b/arch/arm/dts/imx6qdl-hummingboard2.dtsi new file mode 100644 index 000000000000..e4231331f04e --- /dev/null +++ b/arch/arm/dts/imx6qdl-hummingboard2.dtsi @@ -0,0 +1,577 @@ +/* + * Copyright (C) 2015 Rabeeh Khoury rabeeh@solid-run.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +#include <dt-bindings/sound/fsl-imx-audmux.h> + +/ { + /* Will be filled by the bootloader */ + memory@10000000 { + device_type = "memory"; + reg = <0x10000000 0>; + }; + + chosen { + stdout-path = &uart1; + }; + + ir_recv: ir-receiver { + compatible = "gpio-ir-receiver"; + gpios = <&gpio7 9 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard2_gpio7_9>; + linux,rc-map-name = "rc-rc6-mce"; + }; + + v_3v2: regulator-v-3v2 { + compatible = "regulator-fixed"; + regulator-always-on; + regulator-max-microvolt = <3300000>; + regulator-min-microvolt = <3300000>; + regulator-name = "v_3v2"; + }; + + v_5v0: regulator-v-5v0 { + compatible = "regulator-fixed"; + regulator-always-on; + regulator-max-microvolt = <5000000>; + regulator-min-microvolt = <5000000>; + regulator-name = "v_5v0"; + }; + + vcc_1p8: regulator-vcc-1p8 { + compatible = "regulator-fixed"; + regulator-always-on; + regulator-max-microvolt = <1800000>; + regulator-min-microvolt = <1800000>; + regulator-name = "vcc_1p8"; + vin-supply = <&v_3v2>; + }; + + v_sd: regulator-v-sd { + compatible = "regulator-fixed"; + gpio = <&gpio4 30 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard2_vmmc>; + regulator-boot-on; + regulator-max-microvolt = <3300000>; + regulator-min-microvolt = <3300000>; + regulator-name = "v_sd"; + startup-delay-us = <1000>; + vin-supply = <&v_3v2>; + }; + + v_usb1: regulator-v-usb1 { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio3 22 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard2_usbotg_vbus>; + regulator-always-on; + regulator-max-microvolt = <5000000>; + regulator-min-microvolt = <5000000>; + regulator-name = "v_usb1"; + vin-supply = <&v_5v0>; + }; + + v_usb2: regulator-v-usb2 { + /* USB hub port 1 */ + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio1 0 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard2_usbh1_vbus>; + regulator-always-on; + regulator-max-microvolt = <5000000>; + regulator-min-microvolt = <5000000>; + regulator-name = "v_usb2"; + vin-supply = <&v_5v0>; + }; + + v_usb3: regulator-v-usb3 { + /* USB hub port 3 */ + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio2 13 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard2_usbh2_vbus>; + regulator-always-on; + regulator-max-microvolt = <5000000>; + regulator-min-microvolt = <5000000>; + regulator-name = "v_usb3"; + vin-supply = <&v_5v0>; + }; + + v_usb4: regulator-v-usb4 { + /* USB hub port 4 */ + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio7 10 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard2_usbh3_vbus>; + regulator-always-on; + regulator-max-microvolt = <5000000>; + regulator-min-microvolt = <5000000>; + regulator-name = "v_usb4"; + vin-supply = <&v_5v0>; + }; + + audio: sound-sgtl5000 { + compatible = "simple-audio-card"; + simple-audio-card,name = "On-board Codec"; + simple-audio-card,format = "i2s"; + simple-audio-card,bitclock-master = <&sound_codec>; + simple-audio-card,frame-master = <&sound_codec>; + simple-audio-card,widgets = + "Microphone", "Mic Jack", + "Headphone", "Headphone Jack"; + simple-audio-card,routing = + "MIC_IN", "Mic Jack", + "Mic Jack", "Mic Bias", + "Headphone Jack", "HP_OUT"; + + sound_cpu: simple-audio-card,cpu { + sound-dai = <&ssi1>; + }; + + sound_codec: simple-audio-card,codec { + sound-dai = <&sgtl5000>; + }; + }; +}; + +&audmux { + status = "okay"; + + ssi1 { + fsl,audmux-port = <0>; + fsl,port-config = < + (IMX_AUDMUX_V2_PTCR_SYN | + IMX_AUDMUX_V2_PTCR_TFSEL(4) | + IMX_AUDMUX_V2_PTCR_TCSEL(4) | + IMX_AUDMUX_V2_PTCR_TFSDIR | + IMX_AUDMUX_V2_PTCR_TCLKDIR) + IMX_AUDMUX_V2_PDCR_RXDSEL(4) + >; + }; + + pins5 { + fsl,audmux-port = <4>; + fsl,port-config = < + IMX_AUDMUX_V2_PTCR_SYN + IMX_AUDMUX_V2_PDCR_RXDSEL(0) + >; + }; +}; + +&ecspi2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard2_ecspi2>; + cs-gpios = <&gpio2 26 0>; + status = "okay"; +}; + +&hdmi { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard2_hdmi>; + ddc-i2c-bus = <&i2c2>; + status = "okay"; +}; + +&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard2_i2c1>; + status = "okay"; + + pcf8523: rtc@68 { + compatible = "nxp,pcf8523"; + reg = <0x68>; + }; + + sgtl5000: codec@a { + clocks = <&clks IMX6QDL_CLK_CKO>; + compatible = "fsl,sgtl5000"; + #sound-dai-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard2_sgtl5000>; + reg = <0x0a>; + VDDA-supply = <&v_3v2>; + VDDD-supply = <&vcc_1p8>; + VDDIO-supply = <&v_3v2>; + }; +}; + +&i2c2 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard2_i2c2>; + status = "okay"; +}; + +&i2c3 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard2_i2c3>; + status = "okay"; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + hummingboard2 { + pinctrl_hog: hoggrp { + fsl,pins = < + /* + * 36 pin headers GPIO description. The pins + * numbering as following - + * + * 3.2v 5v 74 75 + * 73 72 71 70 + * 69 68 67 66 + * + * 77 78 79 76 + * 65 64 61 60 + * 53 52 51 50 + * 49 48 166 132 + * 95 94 90 91 + * GND 54 24 204 + * + * The GPIO numbers can be extracted using + * signal name from below. + * Example - + * MX6QDL_PAD_EIM_DA10__GPIO3_IO10 is + * GPIO(3,10) which is (3-1)*32+10 = gpio 74 + * + * i.e. The mapping of GPIO(X,Y) to Linux gpio + * number is : gpio number = (X-1) * 32 + Y + */ + /* DI1_PIN15 */ + MX6QDL_PAD_EIM_DA10__GPIO3_IO10 0x400130b1 + /* DI1_PIN02 */ + MX6QDL_PAD_EIM_DA11__GPIO3_IO11 0x400130b1 + /* DISP1_DATA00 */ + MX6QDL_PAD_EIM_DA9__GPIO3_IO09 0x400130b1 + /* DISP1_DATA01 */ + MX6QDL_PAD_EIM_DA8__GPIO3_IO08 0x400130b1 + /* DISP1_DATA02 */ + MX6QDL_PAD_EIM_DA7__GPIO3_IO07 0x400130b1 + /* DISP1_DATA03 */ + MX6QDL_PAD_EIM_DA6__GPIO3_IO06 0x400130b1 + /* DISP1_DATA04 */ + MX6QDL_PAD_EIM_DA5__GPIO3_IO05 0x400130b1 + /* DISP1_DATA05 */ + MX6QDL_PAD_EIM_DA4__GPIO3_IO04 0x400130b1 + /* DISP1_DATA06 */ + MX6QDL_PAD_EIM_DA3__GPIO3_IO03 0x400130b1 + /* DISP1_DATA07 */ + MX6QDL_PAD_EIM_DA2__GPIO3_IO02 0x400130b1 + /* DI1_D0_CS */ + MX6QDL_PAD_EIM_DA13__GPIO3_IO13 0x400130b1 + /* DI1_D1_CS */ + MX6QDL_PAD_EIM_DA14__GPIO3_IO14 0x400130b1 + /* DI1_PIN01 */ + MX6QDL_PAD_EIM_DA15__GPIO3_IO15 0x400130b1 + /* DI1_PIN03 */ + MX6QDL_PAD_EIM_DA12__GPIO3_IO12 0x400130b1 + /* DISP1_DATA08 */ + MX6QDL_PAD_EIM_DA1__GPIO3_IO01 0x400130b1 + /* DISP1_DATA09 */ + MX6QDL_PAD_EIM_DA0__GPIO3_IO00 0x400130b1 + /* DISP1_DATA10 */ + MX6QDL_PAD_EIM_EB1__GPIO2_IO29 0x400130b1 + /* DISP1_DATA11 */ + MX6QDL_PAD_EIM_EB0__GPIO2_IO28 0x400130b1 + /* DISP1_DATA12 */ + MX6QDL_PAD_EIM_A17__GPIO2_IO21 0x400130b1 + /* DISP1_DATA13 */ + MX6QDL_PAD_EIM_A18__GPIO2_IO20 0x400130b1 + /* DISP1_DATA14 */ + MX6QDL_PAD_EIM_A19__GPIO2_IO19 0x400130b1 + /* DISP1_DATA15 */ + MX6QDL_PAD_EIM_A20__GPIO2_IO18 0x400130b1 + /* DISP1_DATA16 */ + MX6QDL_PAD_EIM_A21__GPIO2_IO17 0x400130b1 + /* DISP1_DATA17 */ + MX6QDL_PAD_EIM_A22__GPIO2_IO16 0x400130b1 + /* DISP1_DATA18 */ + MX6QDL_PAD_EIM_A23__GPIO6_IO06 0x400130b1 + /* DISP1_DATA19 */ + MX6QDL_PAD_EIM_A24__GPIO5_IO04 0x400130b1 + /* DISP1_DATA20 */ + MX6QDL_PAD_EIM_D31__GPIO3_IO31 0x400130b1 + /* DISP1_DATA21 */ + MX6QDL_PAD_EIM_D30__GPIO3_IO30 0x400130b1 + /* DISP1_DATA22 */ + MX6QDL_PAD_EIM_D26__GPIO3_IO26 0x400130b1 + /* DISP1_DATA23 */ + MX6QDL_PAD_EIM_D27__GPIO3_IO27 0x400130b1 + /* DI1_DISP_CLK */ + MX6QDL_PAD_EIM_A16__GPIO2_IO22 0x400130b1 + /* SPDIF_IN */ + MX6QDL_PAD_ENET_RX_ER__GPIO1_IO24 0x400130b1 + /* SPDIF_OUT */ + MX6QDL_PAD_GPIO_17__GPIO7_IO12 0x400130b1 + + /* MikroBUS GPIO pin number 10 */ + MX6QDL_PAD_EIM_LBA__GPIO2_IO27 0x400130b1 + >; + }; + + pinctrl_hummingboard2_ecspi2: hummingboard2-ecspi2grp { + fsl,pins = < + MX6QDL_PAD_EIM_OE__ECSPI2_MISO 0x100b1 + MX6QDL_PAD_EIM_CS1__ECSPI2_MOSI 0x100b1 + MX6QDL_PAD_EIM_CS0__ECSPI2_SCLK 0x100b1 + MX6QDL_PAD_EIM_RW__GPIO2_IO26 0x000b1 /* CS */ + >; + }; + + pinctrl_hummingboard2_gpio7_9: hummingboard2-gpio7_9 { + fsl,pins = < + MX6QDL_PAD_SD4_CMD__GPIO7_IO09 0x80000000 + >; + }; + + pinctrl_hummingboard2_hdmi: hummingboard2-hdmi { + fsl,pins = < + MX6QDL_PAD_KEY_ROW2__HDMI_TX_CEC_LINE 0x1f8b0 + >; + }; + + pinctrl_hummingboard2_i2c1: hummingboard2-i2c1 { + fsl,pins = < + MX6QDL_PAD_EIM_D21__I2C1_SCL 0x4001b8b1 + MX6QDL_PAD_EIM_D28__I2C1_SDA 0x4001b8b1 + >; + }; + + pinctrl_hummingboard2_i2c2: hummingboard2-i2c2 { + fsl,pins = < + MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x4001b8b1 + MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x4001b8b1 + >; + }; + + pinctrl_hummingboard2_i2c3: hummingboard2-i2c3 { + fsl,pins = < + MX6QDL_PAD_EIM_D17__I2C3_SCL 0x4001b8b1 + MX6QDL_PAD_EIM_D18__I2C3_SDA 0x4001b8b1 + >; + }; + + pinctrl_hummingboard2_mipi: hummingboard2_mipi { + fsl,pins = < + MX6QDL_PAD_SD4_DAT2__GPIO2_IO10 0x4001b8b1 + MX6QDL_PAD_KEY_COL4__GPIO4_IO14 0x4001b8b1 + MX6QDL_PAD_NANDF_CS2__CCM_CLKO2 0x130b0 + >; + }; + + pinctrl_hummingboard2_pcie_reset: hummingboard2-pcie-reset { + fsl,pins = < + MX6QDL_PAD_SD4_DAT3__GPIO2_IO11 0x1b0b1 + >; + }; + + pinctrl_hummingboard2_pwm1: pwm1grp { + fsl,pins = < + MX6QDL_PAD_DISP0_DAT8__PWM1_OUT 0x1b0b1 + >; + }; + + pinctrl_hummingboard2_pwm3: pwm3grp { + fsl,pins = < + MX6QDL_PAD_SD4_DAT1__PWM3_OUT 0x1b0b1 + >; + }; + + pinctrl_hummingboard2_sgtl5000: hummingboard2-sgtl5000 { + fsl,pins = < + MX6QDL_PAD_DISP0_DAT19__AUD5_RXD 0x130b0 + MX6QDL_PAD_KEY_COL0__AUD5_TXC 0x130b0 + MX6QDL_PAD_KEY_ROW0__AUD5_TXD 0x110b0 + MX6QDL_PAD_KEY_COL1__AUD5_TXFS 0x130b0 + MX6QDL_PAD_GPIO_5__CCM_CLKO1 0x130b0 + >; + }; + + pinctrl_hummingboard2_usbh1_vbus: hummingboard2-usbh1-vbus { + fsl,pins = <MX6QDL_PAD_GPIO_0__GPIO1_IO00 0x1b0b0>; + }; + + pinctrl_hummingboard2_usbh2_vbus: hummingboard2-usbh2-vbus { + fsl,pins = <MX6QDL_PAD_SD4_DAT5__GPIO2_IO13 0x1b0b0>; + }; + + pinctrl_hummingboard2_usbh3_vbus: hummingboard2-usbh3-vbus { + fsl,pins = <MX6QDL_PAD_SD4_CLK__GPIO7_IO10 0x1b0b0>; + }; + + pinctrl_hummingboard2_usbotg_id: hummingboard2-usbotg-id { + /* + * We want it pulled down for a fixed host connection. + */ + fsl,pins = <MX6QDL_PAD_GPIO_1__USB_OTG_ID 0x13059>; + }; + + pinctrl_hummingboard2_usbotg_vbus: hummingboard2-usbotg-vbus { + fsl,pins = <MX6QDL_PAD_EIM_D22__GPIO3_IO22 0x1b0b0>; + }; + + pinctrl_hummingboard2_usdhc2_aux: hummingboard2-usdhc2-aux { + fsl,pins = < + MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x1f071 + MX6QDL_PAD_KEY_ROW1__SD2_VSELECT 0x1b071 + >; + }; + + pinctrl_hummingboard2_usdhc2: hummingboard2-usdhc2 { + fsl,pins = < + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x17059 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x10059 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x17059 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x17059 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x17059 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x13059 + >; + }; + + pinctrl_hummingboard2_usdhc2_100mhz: hummingboard2-usdhc2-100mhz { + fsl,pins = < + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x170b9 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x100b9 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x170b9 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x170b9 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x170b9 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x130b9 + >; + }; + + pinctrl_hummingboard2_usdhc2_200mhz: hummingboard2-usdhc2-200mhz { + fsl,pins = < + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x170f9 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x100f9 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x170f9 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x170f9 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x170f9 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x130f9 + >; + }; + + pinctrl_hummingboard2_vmmc: hummingboard2-vmmc { + fsl,pins = < + MX6QDL_PAD_DISP0_DAT9__GPIO4_IO30 0x1b0b0 + >; + }; + + pinctrl_hummingboard2_uart3: hummingboard2-uart3 { + fsl,pins = < + MX6QDL_PAD_EIM_D25__UART3_TX_DATA 0x1b0b1 + MX6QDL_PAD_EIM_D24__UART3_RX_DATA 0x40013000 + >; + }; + }; +}; + +&pcie { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard2_pcie_reset>; + reset-gpio = <&gpio2 11 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&pwm1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard2_pwm1>; + status = "okay"; +}; + +&pwm3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard2_pwm3>; + status = "okay"; +}; + +&ssi1 { + status = "okay"; +}; + +&usbh1 { + disable-over-current; + status = "okay"; +}; + +&usbotg { + disable-over-current; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard2_usbotg_id>; + vbus-supply = <&v_usb1>; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = < + &pinctrl_hummingboard2_usdhc2_aux + &pinctrl_hummingboard2_usdhc2 + >; + pinctrl-1 = < + &pinctrl_hummingboard2_usdhc2_aux + &pinctrl_hummingboard2_usdhc2_100mhz + >; + pinctrl-2 = < + &pinctrl_hummingboard2_usdhc2_aux + &pinctrl_hummingboard2_usdhc2_200mhz + >; + vmmc-supply = <&v_sd>; + cd-gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hummingboard2_uart3>; + status = "okay"; +}; + +&vcc_3v3 { + vin-supply = <&v_3v2>; +}; diff --git a/arch/arm/dts/imx6qdl-sr-som-emmc.dtsi b/arch/arm/dts/imx6qdl-sr-som-emmc.dtsi new file mode 100644 index 000000000000..5f3b8baab20f --- /dev/null +++ b/arch/arm/dts/imx6qdl-sr-som-emmc.dtsi @@ -0,0 +1,70 @@ +/* + * Copyright (C) 2013,2014 Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +&iomuxc { + microsom { + pinctrl_microsom_usdhc3: microsom-usdhc3 { + fsl,pins = < + MX6QDL_PAD_SD3_CMD__SD3_CMD 0x17059 + MX6QDL_PAD_SD3_CLK__SD3_CLK 0x10059 + MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x17059 + MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x17059 + MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x17059 + MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x17059 + MX6QDL_PAD_SD3_DAT4__SD3_DATA4 0x17059 + MX6QDL_PAD_SD3_DAT5__SD3_DATA5 0x17059 + MX6QDL_PAD_SD3_DAT6__SD3_DATA6 0x17059 + MX6QDL_PAD_SD3_DAT7__SD3_DATA7 0x17059 + MX6QDL_PAD_SD3_RST__SD3_RESET 0x17059 + >; + }; + }; +}; + +/* USDHC3 - eMMC */ +&usdhc3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_microsom_usdhc3>; + bus-width = <8>; + non-removable; + vmmc-supply = <&vcc_3v3>; + status = "okay"; +}; diff --git a/arch/arm/dts/imx6qdl-sr-som-ti.dtsi b/arch/arm/dts/imx6qdl-sr-som-ti.dtsi new file mode 100644 index 000000000000..44a97ba93a95 --- /dev/null +++ b/arch/arm/dts/imx6qdl-sr-som-ti.dtsi @@ -0,0 +1,170 @@ +/* + * Copyright (C) 2013,2014 Russell King + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +#include <dt-bindings/gpio/gpio.h> + +/ { + nvcc_sd1: regulator-nvcc-sd1 { + compatible = "regulator-fixed"; + regulator-always-on; + regulator-name = "nvcc_sd1"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_3v3>; + }; + + clk_ti_wifi: ti-wifi-clock { + /* This is a hack around the kernel - using "fixed clock" + * results in the "pinctrl" properties being ignored, and + * the clock not being output. Instead, use a gated clock + * and the unrouted WL_XTAL_PU gpio. + */ + compatible = "gpio-gate-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_microsom_ti_clk>; + enable-gpios = <&gpio5 5 GPIO_ACTIVE_HIGH>; + }; + + pwrseq_ti_wifi: ti-wifi-pwrseq { + compatible = "mmc-pwrseq-simple"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_microsom_ti_wifi_en>; + reset-gpios = <&gpio5 26 GPIO_ACTIVE_LOW>; + post-power-on-delay-ms = <200>; + clocks = <&clk_ti_wifi>; + clock-names = "ext_clock"; + }; +}; + +&iomuxc { + microsom { + pinctrl_microsom_ti_bt: microsom-ti-bt { + fsl,pins = < + /* BT_EN_SOC */ + MX6QDL_PAD_CSI0_DAT14__GPIO6_IO00 0x40013070 + >; + }; + + pinctrl_microsom_ti_clk: microsom-ti-clk { + fsl,pins = < + /* EXT_32K */ + MX6QDL_PAD_GPIO_8__XTALOSC_REF_CLK_32K 0x1b0b0 + /* WL_XTAL_PU (unrouted) */ + MX6QDL_PAD_DISP0_DAT11__GPIO5_IO05 0x40013070 + >; + }; + + pinctrl_microsom_ti_wifi_en: microsom-ti-wifi-en { + fsl,pins = < + /* WLAN_EN_SOC */ + MX6QDL_PAD_CSI0_DAT8__GPIO5_IO26 0x40013070 + >; + }; + + pinctrl_microsom_ti_wifi_irq: microsom-ti-wifi-irq { + fsl,pins = < + /* WLAN_IRQ */ + MX6QDL_PAD_CSI0_DAT18__GPIO6_IO04 0x40013070 + >; + }; + + pinctrl_microsom_uart4: microsom-uart4 { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT12__UART4_TX_DATA 0x1b0b1 + MX6QDL_PAD_CSI0_DAT13__UART4_RX_DATA 0x1b0b1 + MX6QDL_PAD_CSI0_DAT16__UART4_RTS_B 0x1b0b1 + MX6QDL_PAD_CSI0_DAT17__UART4_CTS_B 0x1b0b1 + >; + }; + + pinctrl_microsom_usdhc1: microsom-usdhc1 { + fsl,pins = < + MX6QDL_PAD_SD1_CMD__SD1_CMD 0x17059 + MX6QDL_PAD_SD1_CLK__SD1_CLK 0x10059 + MX6QDL_PAD_SD1_DAT0__SD1_DATA0 0x17059 + MX6QDL_PAD_SD1_DAT1__SD1_DATA1 0x17059 + MX6QDL_PAD_SD1_DAT2__SD1_DATA2 0x17059 + MX6QDL_PAD_SD1_DAT3__SD1_DATA3 0x17059 + >; + }; + }; +}; + +/* UART4 - Connected to optional TI Wi-Fi/BT/FM */ +&uart4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_microsom_uart4>; + uart-has-rtscts; + status = "okay"; + + bluetooth { + compatible = "ti,wl1837-st"; + clocks = <&clk_ti_wifi>; + clock-names = "ext_clock"; + enable-gpios = <&gpio6 0 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_microsom_ti_bt>; + }; +}; + +/* USDHC1 - Connected to optional TI Wi-Fi/BT/FM */ +&usdhc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_microsom_usdhc1>; + bus-width = <4>; + keep-power-in-suspend; + mmc-pwrseq = <&pwrseq_ti_wifi>; + non-removable; + vmmc-supply = <&vcc_3v3>; + /* vqmmc-supply = <&nvcc_sd1>; - MMC layer doesn't like it! */ + status = "okay"; + #address-cells = <1>; + #size-cells = <0>; + + wlcore@2 { + compatible = "ti,wl1837"; + reg = <2>; + interrupts-extended = <&gpio6 4 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_microsom_ti_wifi_irq>; + }; +};
On Sun, Nov 10, 2019 at 9:40 AM Baruch Siach baruch@tkos.co.il wrote:
These DT files are copied from kernel v5.3 with no changes.
This is part 2 of 2 commits. Included are DT files for SOM rev 1.5, and Hummingboard2 Gate/Edge.
Signed-off-by: Baruch Siach baruch@tkos.co.il
Reviewed-by: Fabio Estevam festevam@gmail.com
These DT files are copied from kernel v5.3 with no changes. This is part 2 of 2 commits. Included are DT files for SOM rev 1.5, and Hummingboard2 Gate/Edge. Signed-off-by: Baruch Siach baruch@tkos.co.il Reviewed-by: Fabio Estevam festevam@gmail.com
Applied to u-boot-imx, -next, thanks !
Best regards, Stefano Babic
Make first step in DT/DM migration. Enable OF_CONTROL only for the main U-Boot image for now.
Remove mmc_init_main() because board_mmc_init() is not called when DM_MMC is enabled.
DM_MMC requires DM_GPIO for card-detect to work. That in turn makes gpio request mandatory. Add code to request/free gpios in platform code.
MMC devices are now numbered according to DT. The SD card is 1, and eMMC is 2. Account for that in board_mmc_get_env_dev(), BOOT_TARGET_DEVICES, and has_emmc().
DM_MMC requires BLK. However, the (BLK && !DM_USB) combination disables USB_STORAGE. Enable DM_USB to preserve USB functionality. Add also DM_REGULATORS for the USB power controller. This allows us to drop board_ehci_hcd_init() and setup_usb().
Runtime selection of DT is necessary because of the i.MX6QD vs i.MX6SDL incompatibility. DT selection does not rely on GPIOs, since DM_GPIO depends on DT. Instead, we take one "fully featured" DT of each variant. That should be enough to boot from both SD card and eMMC.
Since we don't select the exact DT, override the generic show_board_info() that shows the selected DT 'model' field.
Signed-off-by: Baruch Siach baruch@tkos.co.il --- v2: No change --- board/solidrun/mx6cuboxi/mx6cuboxi.c | 119 ++++++++++++++++----------- configs/mx6cuboxi_defconfig | 16 +++- include/configs/mx6cuboxi.h | 6 +- 3 files changed, 89 insertions(+), 52 deletions(-)
diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c index f82fb0786a94..bb005aa28325 100644 --- a/board/solidrun/mx6cuboxi/mx6cuboxi.c +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -65,6 +65,8 @@ enum board_type { UNKNOWN = 0x03, };
+static struct gpio_desc board_detect_desc[5]; + #define MEM_STRIDE 0x4000000 static u32 get_ram_size_stride_test(u32 *base, u32 maxsize) { @@ -154,10 +156,6 @@ static iomux_v3_cfg_t const som_rev_detect[] = { IOMUX_PADS(PAD_CSI0_DAT18__GPIO6_IO04 | MUX_PAD_CTRL(UART_PAD_CTRL)), };
-static iomux_v3_cfg_t const usb_pads[] = { - IOMUX_PADS(PAD_GPIO_0__GPIO1_IO00 | MUX_PAD_CTRL(NO_PAD_CTRL)), -}; - static void setup_iomux_uart(void) { SETUP_IOMUX_PADS(uart1_pads); @@ -175,7 +173,7 @@ static struct fsl_esdhc_cfg emmc_cfg = {
int board_mmc_get_env_dev(int devno) { - return devno - 1; + return devno; }
#define USDHC2_CD_GPIO IMX_GPIO_NR(1, 4) @@ -197,27 +195,6 @@ int board_mmc_getcd(struct mmc *mmc) return ret; }
-static int mmc_init_main(bd_t *bis) -{ - int ret; - - /* - * Following map is done: - * (U-Boot device node) (Physical Port) - * mmc0 Carrier board MicroSD - * mmc1 SOM eMMC - */ - SETUP_IOMUX_PADS(usdhc2_pads); - usdhc_cfg.sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); - ret = fsl_esdhc_initialize(bis, &usdhc_cfg); - if (ret) - return ret; - - SETUP_IOMUX_PADS(usdhc3_pads); - emmc_cfg.sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); - return fsl_esdhc_initialize(bis, &emmc_cfg); -} - static int mmc_init_spl(bd_t *bis) { struct src *psrc = (struct src *)SRC_BASE_ADDR; @@ -251,7 +228,7 @@ int board_mmc_init(bd_t *bis) if (IS_ENABLED(CONFIG_SPL_BUILD)) return mmc_init_spl(bis);
- return mmc_init_main(bis); + return 0; }
static iomux_v3_cfg_t const enet_pads[] = { @@ -283,12 +260,29 @@ static iomux_v3_cfg_t const enet_pads[] = {
static void setup_iomux_enet(void) { + struct gpio_desc desc; + int ret; + SETUP_IOMUX_PADS(enet_pads);
+ ret = dm_gpio_lookup_name("GPIO4_15", &desc); + if (ret) { + printf("%s: phy reset lookup failed\n", __func__); + return; + } + + ret = dm_gpio_request(&desc, "phy-reset"); + if (ret) { + printf("%s: phy reset request failed\n", __func__); + return; + } + gpio_direction_output(ETH_PHY_RESET, 0); mdelay(10); gpio_set_value(ETH_PHY_RESET, 1); udelay(100); + + gpio_free_list_nodev(&desc, 1); }
int board_phy_config(struct phy_device *phydev) @@ -433,21 +427,6 @@ static int setup_display(void) } #endif /* CONFIG_VIDEO_IPUV3 */
-#ifdef CONFIG_USB_EHCI_MX6 -static void setup_usb(void) -{ - SETUP_IOMUX_PADS(usb_pads); -} - -int board_ehci_hcd_init(int port) -{ - if (port == 1) - gpio_direction_output(USB_H1_VBUS, 1); - - return 0; -} -#endif - int board_early_init_f(void) { setup_iomux_uart(); @@ -455,10 +434,6 @@ int board_early_init_f(void) #ifdef CONFIG_CMD_SATA setup_sata(); #endif - -#ifdef CONFIG_USB_EHCI_MX6 - setup_usb(); -#endif return 0; }
@@ -476,6 +451,29 @@ int board_init(void) return ret; }
+static int request_detect_gpios(void) +{ + int node; + int ret; + + node = fdt_node_offset_by_compatible(gd->fdt_blob, 0, + "solidrun,hummingboard-detect"); + if (node < 0) + return -ENODEV; + + ret = gpio_request_list_by_name_nodev(offset_to_ofnode(node), + "detect-gpios", board_detect_desc, + ARRAY_SIZE(board_detect_desc), GPIOD_IS_IN); + + return ret; +} + +static int free_detect_gpios(void) +{ + return gpio_free_list_nodev(board_detect_desc, + ARRAY_SIZE(board_detect_desc)); +} + static enum board_type board_type(void) { int val1, val2, val3; @@ -531,7 +529,7 @@ static bool is_rev_15_som(void) static bool has_emmc(void) { struct mmc *mmc; - mmc = find_mmc_device(1); + mmc = find_mmc_device(2); if (!mmc) return 0; return (mmc_get_op_cond(mmc) < 0) ? 0 : 1; @@ -539,6 +537,8 @@ static bool has_emmc(void)
int checkboard(void) { + request_detect_gpios(); + switch (board_type()) { case CUBOXI: puts("Board: MX6 Cubox-i"); @@ -560,13 +560,22 @@ int checkboard(void) else puts("\n");
+ free_detect_gpios(); out: return 0; }
+/* Override the default implementation, DT model is not accurate */ +int show_board_info(void) +{ + return checkboard(); +} + int board_late_init(void) { #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + request_detect_gpios(); + switch (board_type()) { case CUBOXI: env_set("board_name", "CUBOXI"); @@ -593,11 +602,27 @@ int board_late_init(void) if (has_emmc()) env_set("has_emmc", "yes");
+ free_detect_gpios(); #endif
return 0; }
+/* + * This is not a perfect match. Avoid dependency on the DM GPIO driver needed + * for accurate board detection. Hummingboard2 DT is good enough for U-Boot on + * all Hummingboard/Cubox-i platforms. + */ +int board_fit_config_name_match(const char *name) +{ + char tmp_name[36]; + + snprintf(tmp_name, sizeof(tmp_name), "%s-hummingboard2-emmc-som-v15", + is_mx6dq() ? "imx6q" : "imx6dl"); + + return strcmp(name, tmp_name); +} + #ifdef CONFIG_SPL_BUILD #include <asm/arch/mx6-ddr.h> static const struct mx6dq_iomux_ddr_regs mx6q_ddr_ioregs = { diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index a13243fca69b..f8a9546e7b8e 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -12,8 +12,10 @@ CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y # CONFIG_CMD_BMODE is not set CONFIG_CMD_HDMIDETECT=y +CONFIG_AHCI=y CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_USE_PREBOOT=y @@ -26,22 +28,34 @@ CONFIG_SPL_WATCHDOG_SUPPORT=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y +# CONFIG_CMD_PINMUX is not set CONFIG_CMD_SATA=y CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_PARTITION_UUIDS is not set +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx6dl-hummingboard2-emmc-som-v15" +CONFIG_OF_LIST="imx6dl-hummingboard2-emmc-som-v15 imx6q-hummingboard2-emmc-som-v15" +CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_DWC_AHSATA=y +CONFIG_DM_GPIO=y +CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_THERMAL=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_IPUV3=y CONFIG_VIDEO=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_OF_LIBFDT=y diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 3cf2f1ce28a0..b4f3a83a2ef4 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -45,10 +45,7 @@ #define CONFIG_IMX_VIDEO_SKIP
/* USB */ -#define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CONFIG_MXC_USB_FLAGS 0 -#define CONFIG_USB_MAX_CONTROLLER_COUNT 2
/* Command definition */
@@ -108,7 +105,8 @@ BOOTENV
#define BOOT_TARGET_DEVICES(func) \ - func(MMC, mmc, 0) \ + func(MMC, mmc, 1) \ + func(MMC, mmc, 2) \ func(SATA, sata, 0) \ func(USB, usb, 0) \ func(PXE, pxe, na) \
Make first step in DT/DM migration. Enable OF_CONTROL only for the main U-Boot image for now. Remove mmc_init_main() because board_mmc_init() is not called when DM_MMC is enabled. DM_MMC requires DM_GPIO for card-detect to work. That in turn makes gpio request mandatory. Add code to request/free gpios in platform code. MMC devices are now numbered according to DT. The SD card is 1, and eMMC is 2. Account for that in board_mmc_get_env_dev(), BOOT_TARGET_DEVICES, and has_emmc(). DM_MMC requires BLK. However, the (BLK && !DM_USB) combination disables USB_STORAGE. Enable DM_USB to preserve USB functionality. Add also DM_REGULATORS for the USB power controller. This allows us to drop board_ehci_hcd_init() and setup_usb(). Runtime selection of DT is necessary because of the i.MX6QD vs i.MX6SDL incompatibility. DT selection does not rely on GPIOs, since DM_GPIO depends on DT. Instead, we take one "fully featured" DT of each variant. That should be enough to boot from both SD card and eMMC. Since we don't select the exact DT, override the generic show_board_info() that shows the selected DT 'model' field. Signed-off-by: Baruch Siach baruch@tkos.co.il Reviewed-by: Fabio Estevam festevam@gmail.com
On Sun, Nov 10, 2019 at 9:38 AM Baruch Siach baruch@tkos.co.il wrote:
Import fsl-imx-audmux.h from Linux as of v5.4-rc6. The header is unchanged since v4.18.
That would make it easier to import DT files that depend on imx-audmux definitions from the kernel tree.
Import fsl-imx-audmux.h from Linux as of v5.4-rc6. The header is unchanged since v4.18. That would make it easier to import DT files that depend on imx-audmux definitions from the kernel tree. Signed-off-by: Baruch Siach baruch@tkos.co.il Reviewed-by: Fabio Estevam festevam@gmail.com
Baruch Siach
Fabio Estevam
sbabic@denx.de
