[U-Boot] [PATCH] OMAP4: Fix bug in omap4460_volts struct
The omap4460_volts struct was incorrectly referencing tps62361 instead of twl6030 as PMIC for the core and mm voltages (the tps is used for mpu supply only). This shall lead to bad OPP settings while booting kernel. Fixing it.
Fix some comments as well.
Signed-off-by: Lubomir Popov lpopov@mm-sol.com --- This patch is separated from the OMAP4470/TWL6032 support series because it fixes an existing bug.
arch/arm/cpu/armv7/omap4/hw_data.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap4/hw_data.c b/arch/arm/cpu/armv7/omap4/hw_data.c index 7551b98..04977b4 100644 --- a/arch/arm/cpu/armv7/omap4/hw_data.c +++ b/arch/arm/cpu/armv7/omap4/hw_data.c @@ -216,14 +216,14 @@ struct dplls omap4460_dplls = {
struct pmic_data twl6030_4430es1 = { .base_offset = PHOENIX_SMPS_BASE_VOLT_STD_MODE_UV, - .step = 12660, /* 10 mV represented in uV */ + .step = 12660, /* 12.66 mV represented in uV */ /* The code starts at 1 not 0 */ .start_code = 1, };
struct pmic_data twl6030 = { .base_offset = PHOENIX_SMPS_BASE_VOLT_STD_MODE_WITH_OFFSET_UV, - .step = 12660, /* 10 mV represented in uV */ + .step = 12660, /* 12.66 mV represented in uV */ /* The code starts at 1 not 0 */ .start_code = 1, }; @@ -271,11 +271,11 @@ struct vcores_data omap4460_volts = {
.core.value = 1200, .core.addr = SMPS_REG_ADDR_VCORE1, - .core.pmic = &tps62361, + .core.pmic = &twl6030,
.mm.value = 1200, .mm.addr = SMPS_REG_ADDR_VCORE2, - .mm.pmic = &tps62361, + .mm.pmic = &twl6030, };
Applied to u-boot-ti/master, thanks!
Lubomir Popov
