[U-Boot] [PATCH ATMEL REWORK] update arm/at91rm9200 work with rework rework110202
* update arm920t/at91 to ATMEL_xxx name scheme * convert at91rm9200ek and eb_cpux9k2 board to ATMEL_xxx name scheme * update arm920t/at91 soc lib * update at91_emac driver
Signed-off-by: Jens Scharsig js_at_ng@scharsoft.de ---
The eb_cpux9k2 board can compile and runs after patch changes The at91rm9200ek can compile, but i have no hardware to test it.
arch/arm/cpu/arm920t/at91/reset.c | 2 +- arch/arm/cpu/arm920t/at91/timer.c | 10 +- arch/arm/include/asm/arch-at91/at91_mc.h | 12 +- arch/arm/include/asm/arch-at91/at91_pmc.h | 10 +- arch/arm/include/asm/arch-at91/at91rm9200.h | 209 ++++++++++++++------------- board/BuS/eb_cpux9k2/cpux9k2.c | 52 ++++---- board/atmel/at91rm9200ek/at91rm9200ek.c | 4 +- board/atmel/at91rm9200ek/led.c | 22 ++-- drivers/net/at91_emac.c | 32 ++-- include/configs/at91rm9200ek.h | 2 +- include/configs/eb_cpux9k2.h | 29 +++-- 11 files changed, 201 insertions(+), 183 deletions(-)
diff --git a/arch/arm/cpu/arm920t/at91/reset.c b/arch/arm/cpu/arm920t/at91/reset.c index 51043ec..4fa0f98 100644 --- a/arch/arm/cpu/arm920t/at91/reset.c +++ b/arch/arm/cpu/arm920t/at91/reset.c @@ -42,7 +42,7 @@ void __attribute__((weak)) board_reset(void)
void reset_cpu(ulong ignored) { - at91_st_t *st = (at91_st_t *) AT91_ST_BASE; + at91_st_t *st = (at91_st_t *) ATMEL_BASE_ST; #if defined(CONFIG_AT91RM9200_USART) /*shutdown the console to avoid strange chars during reset */ serial_exit(); diff --git a/arch/arm/cpu/arm920t/at91/timer.c b/arch/arm/cpu/arm920t/at91/timer.c index c4c5eef..f0ad7d6 100644 --- a/arch/arm/cpu/arm920t/at91/timer.c +++ b/arch/arm/cpu/arm920t/at91/timer.c @@ -44,11 +44,11 @@ DECLARE_GLOBAL_DATA_PTR;
int timer_init(void) { - at91_tc_t *tc = (at91_tc_t *) AT91_TC_BASE; - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_tc_t *tc = (at91_tc_t *) ATMEL_BASE_TC; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
/* enables TC1.0 clock */ - writel(1 << AT91_ID_TC0, &pmc->pcer); /* enable clock */ + writel(1 << ATMEL_ID_TC0, &pmc->pcer); /* enable clock */
writel(0, &tc->bcr); writel(AT91_TC_BMR_TC0XC0S_NONE | AT91_TC_BMR_TC1XC1S_NONE | @@ -96,14 +96,14 @@ void __udelay(unsigned long usec) void reset_timer_masked(void) { /* reset time */ - at91_tc_t *tc = (at91_tc_t *) AT91_TC_BASE; + at91_tc_t *tc = (at91_tc_t *) ATMEL_BASE_TC; gd->lastinc = readl(&tc->tc[0].cv) & 0x0000ffff; gd->tbl = 0; }
ulong get_timer_raw(void) { - at91_tc_t *tc = (at91_tc_t *) AT91_TC_BASE; + at91_tc_t *tc = (at91_tc_t *) ATMEL_BASE_TC; u32 now;
now = readl(&tc->tc[0].cv) & 0x0000ffff; diff --git a/arch/arm/include/asm/arch-at91/at91_mc.h b/arch/arm/include/asm/arch-at91/at91_mc.h index acfbd10..e0d1320 100644 --- a/arch/arm/include/asm/arch-at91/at91_mc.h +++ b/arch/arm/include/asm/arch-at91/at91_mc.h @@ -23,12 +23,12 @@ #ifndef AT91_MC_H #define AT91_MC_H
-#define AT91_ASM_MC_EBI_CSA (AT91_MC_BASE + 0x60) -#define AT91_ASM_MC_EBI_CFG (AT91_MC_BASE + 0x64) -#define AT91_ASM_MC_SMC_CSR0 (AT91_MC_BASE + 0x70) -#define AT91_ASM_MC_SDRAMC_MR (AT91_MC_BASE + 0x90) -#define AT91_ASM_MC_SDRAMC_TR (AT91_MC_BASE + 0x94) -#define AT91_ASM_MC_SDRAMC_CR (AT91_MC_BASE + 0x98) +#define AT91_ASM_MC_EBI_CSA (ATMEL_BASE_MC + 0x60) +#define AT91_ASM_MC_EBI_CFG (ATMEL_BASE_MC + 0x64) +#define AT91_ASM_MC_SMC_CSR0 (ATMEL_BASE_MC + 0x70) +#define AT91_ASM_MC_SDRAMC_MR (ATMEL_BASE_MC + 0x90) +#define AT91_ASM_MC_SDRAMC_TR (ATMEL_BASE_MC + 0x94) +#define AT91_ASM_MC_SDRAMC_CR (ATMEL_BASE_MC + 0x98)
#ifndef __ASSEMBLY__
diff --git a/arch/arm/include/asm/arch-at91/at91_pmc.h b/arch/arm/include/asm/arch-at91/at91_pmc.h index fb8bb17..086cb9b 100644 --- a/arch/arm/include/asm/arch-at91/at91_pmc.h +++ b/arch/arm/include/asm/arch-at91/at91_pmc.h @@ -17,11 +17,11 @@ #ifndef AT91_PMC_H #define AT91_PMC_H
-#define AT91_ASM_PMC_MOR (AT91_PMC_BASE + 0x20) -#define AT91_ASM_PMC_PLLAR (AT91_PMC_BASE + 0x28) -#define AT91_ASM_PMC_PLLBR (AT91_PMC_BASE + 0x2c) -#define AT91_ASM_PMC_MCKR (AT91_PMC_BASE + 0x30) -#define AT91_ASM_PMC_SR (AT91_PMC_BASE + 0x68) +#define AT91_ASM_PMC_MOR (ATMEL_BASE_PMC + 0x20) +#define AT91_ASM_PMC_PLLAR (ATMEL_BASE_PMC + 0x28) +#define AT91_ASM_PMC_PLLBR (ATMEL_BASE_PMC + 0x2c) +#define AT91_ASM_PMC_MCKR (ATMEL_BASE_PMC + 0x30) +#define AT91_ASM_PMC_SR (ATMEL_BASE_PMC + 0x68)
diff --git a/arch/arm/include/asm/arch-at91/at91rm9200.h b/arch/arm/include/asm/arch-at91/at91rm9200.h index 1bee6f2..58f0e39 100644 --- a/arch/arm/include/asm/arch-at91/at91rm9200.h +++ b/arch/arm/include/asm/arch-at91/at91rm9200.h @@ -21,115 +21,126 @@ #ifndef __AT91RM9200_H__ #define __AT91RM9200_H__
+#define CONFIG_AT91FAMILY /* it's a member of AT91 */ +#define CONFIG_ARM920T /* This is an ARM920T Core */ + /* Periperial Identifiers */
-#define AT91_ID_SYS 1 /* System Peripheral */ -#define AT91_ID_PIOA 2 /* PIO port A */ -#define AT91_ID_PIOB 3 /* PIO port B */ -#define AT91_ID_PIOC 4 /* PIO port C */ -#define AT91_ID_PIOD 5 /* PIO port D BGA only */ -#define AT91_ID_USART0 6 /* USART 0 */ -#define AT91_ID_USART1 7 /* USART 1 */ -#define AT91_ID_USART2 8 /* USART 2 */ -#define AT91_ID_USART3 9 /* USART 3 */ -#define AT91_ID_MCI 10 /* Multimedia Card Interface */ -#define AT91_ID_UDP 11 /* USB Device Port */ -#define AT91_ID_TWI 12 /* Two Wire Interface */ -#define AT91_ID_SPI 13 /* Serial Peripheral Interface */ -#define AT91_ID_SSC0 14 /* Synch. Serial Controller 0 */ -#define AT91_ID_SSC1 15 /* Synch. Serial Controller 1 */ -#define AT91_ID_SSC2 16 /* Synch. Serial Controller 2 */ -#define AT91_ID_TC0 17 /* Timer Counter 0 */ -#define AT91_ID_TC1 18 /* Timer Counter 1 */ -#define AT91_ID_TC2 19 /* Timer Counter 2 */ -#define AT91_ID_TC3 20 /* Timer Counter 3 */ -#define AT91_ID_TC4 21 /* Timer Counter 4 */ -#define AT91_ID_TC5 22 /* Timer Counter 5 */ -#define AT91_ID_UHP 23 /* OHCI USB Host Port */ -#define AT91_ID_EMAC 24 /* Ethernet MAC */ -#define AT91_ID_IRQ0 25 /* Advanced Interrupt Controller */ -#define AT91_ID_IRQ1 26 /* Advanced Interrupt Controller */ -#define AT91_ID_IRQ2 27 /* Advanced Interrupt Controller */ -#define AT91_ID_IRQ3 28 /* Advanced Interrupt Controller */ -#define AT91_ID_IRQ4 29 /* Advanced Interrupt Controller */ -#define AT91_ID_IRQ5 30 /* Advanced Interrupt Controller */ -#define AT91_ID_IRQ6 31 /* Advanced Interrupt Controller */ - -#define AT91_USB_HOST_BASE 0x00300000 - -#define AT91_TC_BASE 0xFFFA0000 -#define AT91_UDP_BASE 0xFFFB0000 -#define AT91_MCI_BASE 0xFFFB4000 -#define AT91_TWI_BASE 0xFFFB8000 -#define AT91_EMAC_BASE 0xFFFBC000 -#define AT91_USART_BASE 0xFFFC0000 /* 4x 0x4000 Offset */ -#define AT91_SCC_BASE 0xFFFD0000 /* 4x 0x4000 Offset */ -#define AT91_SPI_BASE 0xFFFE0000 - -#define AT91_AIC_BASE 0xFFFFF000 -#define AT91_DBGU_BASE 0xFFFFF200 -#define AT91_PIO_BASE 0xFFFFF400 /* 4x 0x200 Offset */ -#define AT91_PMC_BASE 0xFFFFFC00 -#define AT91_ST_BASE 0xFFFFFD00 -#define AT91_ST_BASE 0xFFFFFD00 -#define AT91_RTC_BASE 0xFFFFFE00 -#define AT91_MC_BASE 0xFFFFFF00 +#define ATMEL_ID_SYS 1 /* System Peripheral */ +#define ATMEL_ID_PIOA 2 /* PIO port A */ +#define ATMEL_ID_PIOB 3 /* PIO port B */ +#define ATMEL_ID_PIOC 4 /* PIO port C */ +#define ATMEL_ID_PIOD 5 /* PIO port D BGA only */ +#define ATMEL_ID_USART0 6 /* USART 0 */ +#define ATMEL_ID_USART1 7 /* USART 1 */ +#define ATMEL_ID_USART2 8 /* USART 2 */ +#define ATMEL_ID_USART3 9 /* USART 3 */ +#define ATMEL_ID_MCI 10 /* Multimedia Card Interface */ +#define ATMEL_ID_UDP 11 /* USB Device Port */ +#define ATMEL_ID_TWI 12 /* Two Wire Interface */ +#define ATMEL_ID_SPI 13 /* Serial Peripheral Interface */ +#define ATMEL_ID_SSC0 14 /* Synch. Serial Controller 0 */ +#define ATMEL_ID_SSC1 15 /* Synch. Serial Controller 1 */ +#define ATMEL_ID_SSC2 16 /* Synch. Serial Controller 2 */ +#define ATMEL_ID_TC0 17 /* Timer Counter 0 */ +#define ATMEL_ID_TC1 18 /* Timer Counter 1 */ +#define ATMEL_ID_TC2 19 /* Timer Counter 2 */ +#define ATMEL_ID_TC3 20 /* Timer Counter 3 */ +#define ATMEL_ID_TC4 21 /* Timer Counter 4 */ +#define ATMEL_ID_TC5 22 /* Timer Counter 5 */ +#define ATMEL_ID_UHP 23 /* OHCI USB Host Port */ +#define ATMEL_ID_EMAC 24 /* Ethernet MAC */ +#define ATMEL_ID_IRQ0 25 /* Advanced Interrupt Controller */ +#define ATMEL_ID_IRQ1 26 /* Advanced Interrupt Controller */ +#define ATMEL_ID_IRQ2 27 /* Advanced Interrupt Controller */ +#define ATMEL_ID_IRQ3 28 /* Advanced Interrupt Controller */ +#define ATMEL_ID_IRQ4 29 /* Advanced Interrupt Controller */ +#define ATMEL_ID_IRQ5 30 /* Advanced Interrupt Controller */ +#define ATMEL_ID_IRQ6 31 /* Advanced Interrupt Controller */ + +#define ATMEL_USB_HOST_BASE 0x00300000 + +#define ATMEL_BASE_TC 0xFFFA0000 +#define ATMEL_BASE_UDP 0xFFFB0000 +#define ATMEL_BASE_MCI 0xFFFB4000 +#define ATMEL_BASE_TWI 0xFFFB8000 +#define ATMEL_BASE_EMAC 0xFFFBC000 +#define ATMEL_BASE_USART 0xFFFC0000 /* 4x 0x4000 Offset */ +#define ATMEL_BASE_USART0 ATMEL_BASE_USART +#define ATMEL_BASE_USART1 (ATMEL_BASE_USART + 0x4000) +#define ATMEL_BASE_USART2 (ATMEL_BASE_USART + 0x8000) +#define ATMEL_BASE_USART3 (ATMEL_BASE_USART + 0xC000) + +#define ATMEL_BASE_SCC 0xFFFD0000 /* 4x 0x4000 Offset */ +#define ATMEL_BASE_SPI 0xFFFE0000 + +#define ATMEL_BASE_AIC 0xFFFFF000 +#define ATMEL_BASE_DBGU 0xFFFFF200 +#define ATMEL_BASE_PIO 0xFFFFF400 /* 4x 0x200 Offset */ +#define ATMEL_BASE_PMC 0xFFFFFC00 +#define ATMEL_BASE_ST 0xFFFFFD00 +#define ATMEL_BASE_RTC 0xFFFFFE00 +#define ATMEL_BASE_MC 0xFFFFFF00
+#define AT91_PIO_BASE ATMEL_BASE_PIO
/* AT91RM9200 Periperial Multiplexing A */ /* Port A */ -#define AT91_PMX_AA_EREFCK 0x00000080 -#define AT91_PMX_AA_ETXCK 0x00000080 -#define AT91_PMX_AA_ETXEN 0x00000100 -#define AT91_PMX_AA_ETX0 0x00000200 -#define AT91_PMX_AA_ETX1 0x00000400 -#define AT91_PMX_AA_ECRS 0x00000800 -#define AT91_PMX_AA_ECRSDV 0x00000800 -#define AT91_PMX_AA_ERX0 0x00001000 -#define AT91_PMX_AA_ERX1 0x00002000 -#define AT91_PMX_AA_ERXER 0x00004000 -#define AT91_PMX_AA_EMDC 0x00008000 -#define AT91_PMX_AA_EMDIO 0x00010000 - -#define AT91_PMX_AA_TXD2 0x00810000 - -#define AT91_PMX_AA_TWD 0x02000000 -#define AT91_PMX_AA_TWCK 0x04000000 +#define ATMEL_PMX_AA_EREFCK 0x00000080 +#define ATMEL_PMX_AA_ETXCK 0x00000080 +#define ATMEL_PMX_AA_ETXEN 0x00000100 +#define ATMEL_PMX_AA_ETX0 0x00000200 +#define ATMEL_PMX_AA_ETX1 0x00000400 +#define ATMEL_PMX_AA_ECRS 0x00000800 +#define ATMEL_PMX_AA_ECRSDV 0x00000800 +#define ATMEL_PMX_AA_ERX0 0x00001000 +#define ATMEL_PMX_AA_ERX1 0x00002000 +#define ATMEL_PMX_AA_ERXER 0x00004000 +#define ATMEL_PMX_AA_EMDC 0x00008000 +#define ATMEL_PMX_AA_EMDIO 0x00010000 + +#define ATMEL_PMX_AA_TXD2 0x00810000 + +#define ATMEL_PMX_AA_TWD 0x02000000 +#define ATMEL_PMX_AA_TWCK 0x04000000
/* Port B */ -#define AT91_PMX_BA_ERXCK 0x00080000 -#define AT91_PMX_BA_ECOL 0x00040000 -#define AT91_PMX_BA_ERXDV 0x00020000 -#define AT91_PMX_BA_ERX3 0x00010000 -#define AT91_PMX_BA_ERX2 0x00008000 -#define AT91_PMX_BA_ETXER 0x00004000 -#define AT91_PMX_BA_ETX3 0x00002000 -#define AT91_PMX_BA_ETX2 0x00001000 +#define ATMEL_PMX_BA_ERXCK 0x00080000 +#define ATMEL_PMX_BA_ECOL 0x00040000 +#define ATMEL_PMX_BA_ERXDV 0x00020000 +#define ATMEL_PMX_BA_ERX3 0x00010000 +#define ATMEL_PMX_BA_ERX2 0x00008000 +#define ATMEL_PMX_BA_ETXER 0x00004000 +#define ATMEL_PMX_BA_ETX3 0x00002000 +#define ATMEL_PMX_BA_ETX2 0x00001000
/* Port B */
-#define AT91_PMX_CA_BFCK 0x00000001 -#define AT91_PMX_CA_BFRDY 0x00000002 -#define AT91_PMX_CA_SMOE 0x00000002 -#define AT91_PMX_CA_BFAVD 0x00000004 -#define AT91_PMX_CA_BFBAA 0x00000008 -#define AT91_PMX_CA_SMWE 0x00000008 -#define AT91_PMX_CA_BFOE 0x00000010 -#define AT91_PMX_CA_BFWE 0x00000020 -#define AT91_PMX_CA_NWAIT 0x00000040 -#define AT91_PMX_CA_A23 0x00000080 -#define AT91_PMX_CA_A24 0x00000100 -#define AT91_PMX_CA_A25 0x00000200 -#define AT91_PMX_CA_CFRNW 0x00000200 -#define AT91_PMX_CA_NCS4 0x00000400 -#define AT91_PMX_CA_CFCS 0x00000400 -#define AT91_PMX_CA_NCS5 0x00000800 -#define AT91_PMX_CA_CFCE1 0x00001000 -#define AT91_PMX_CA_NCS6 0x00001000 -#define AT91_PMX_CA_CFCE2 0x00002000 -#define AT91_PMX_CA_NCS7 0x00002000 -#define AT91_PMX_CA_D16_31 0xFFFF0000 - -#define CONFIG_SYS_AT91_CPU_NAME "AT91RM9200" +#define ATMEL_PMX_CA_BFCK 0x00000001 +#define ATMEL_PMX_CA_BFRDY 0x00000002 +#define ATMEL_PMX_CA_SMOE 0x00000002 +#define ATMEL_PMX_CA_BFAVD 0x00000004 +#define ATMEL_PMX_CA_BFBAA 0x00000008 +#define ATMEL_PMX_CA_SMWE 0x00000008 +#define ATMEL_PMX_CA_BFOE 0x00000010 +#define ATMEL_PMX_CA_BFWE 0x00000020 +#define ATMEL_PMX_CA_NWAIT 0x00000040 +#define ATMEL_PMX_CA_A23 0x00000080 +#define ATMEL_PMX_CA_A24 0x00000100 +#define ATMEL_PMX_CA_A25 0x00000200 +#define ATMEL_PMX_CA_CFRNW 0x00000200 +#define ATMEL_PMX_CA_NCS4 0x00000400 +#define ATMEL_PMX_CA_CFCS 0x00000400 +#define ATMEL_PMX_CA_NCS5 0x00000800 +#define ATMEL_PMX_CA_CFCE1 0x00001000 +#define ATMEL_PMX_CA_NCS6 0x00001000 +#define ATMEL_PMX_CA_CFCE2 0x00002000 +#define ATMEL_PMX_CA_NCS7 0x00002000 +#define ATMEL_PMX_CA_D16_31 0xFFFF0000 + +#define ATMEL_PIO_PORTS 4 /* theese SoCs have 3 PIO */ +#define ATMEL_PMC_UHP AT91RM9200_PMC_UHP + +#define CONFIG_SYS_ATMEL_CPU_NAME "AT91RM9200"
#endif diff --git a/board/BuS/eb_cpux9k2/cpux9k2.c b/board/BuS/eb_cpux9k2/cpux9k2.c index fe62a0f..e9a1cb2 100644 --- a/board/BuS/eb_cpux9k2/cpux9k2.c +++ b/board/BuS/eb_cpux9k2/cpux9k2.c @@ -57,12 +57,12 @@ DECLARE_GLOBAL_DATA_PTR;
int board_init(void) { - at91_pio_t *pio = (at91_pio_t *) AT91_PIO_BASE; + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIO; /* Enable Ctrlc */ console_init_f();
/* Correct IRDA resistor problem / Set PA23_TXD in Output */ - writel(AT91_PMX_AA_TXD2, &pio->pioa.oer); + writel(ATMEL_PMX_AA_TXD2, &pio->pioa.oer);
gd->bd->bi_arch_number = MACH_TYPE_EB_CPUX9K2; /* adress of boot parameters */ @@ -147,7 +147,7 @@ int dram_init(void) int board_eth_init(bd_t *bis) { int rc = 0; - rc = at91emac_register(bis, (u32) AT91_EMAC_BASE); + rc = at91emac_register(bis, (u32) ATMEL_BASE_EMAC); return rc; } #endif @@ -164,9 +164,9 @@ int board_eth_init(bd_t *bis) void cpux9k2_nand_hw_init(void) { unsigned long csr; - at91_pio_t *pio = (at91_pio_t *) AT91_PIO_BASE; - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; - at91_mc_t *mc = (at91_mc_t *) AT91_MC_BASE; + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIO; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; + at91_mc_t *mc = (at91_mc_t *) ATMEL_BASE_MC;
/* Setup Smart Media, fitst enable the address range of CS3 */ writel(readl(&mc->ebi.csa) | AT91_EBI_CSA_CS3A, &mc->ebi.csa); @@ -178,23 +178,23 @@ void cpux9k2_nand_hw_init(void) AT91_SMC_CSR_WSEN; writel(csr, &mc->smc.csr[3]);
- writel(AT91_PMX_CA_SMOE | AT91_PMX_CA_SMWE, &pio->pioc.asr); - writel(AT91_PMX_CA_BFCK | AT91_PMX_CA_SMOE | AT91_PMX_CA_SMWE, + writel(ATMEL_PMX_CA_SMOE | ATMEL_PMX_CA_SMWE, &pio->pioc.asr); + writel(ATMEL_PMX_CA_BFCK | ATMEL_PMX_CA_SMOE | ATMEL_PMX_CA_SMWE, &pio->pioc.pdr);
/* Configure PC2 as input (signal Nand READY ) */ - writel(AT91_PMX_CA_BFAVD, &pio->pioc.per); - writel(AT91_PMX_CA_BFAVD, &pio->pioc.odr); /* disable output */ - writel(AT91_PMX_CA_BFCK, &pio->pioc.codr); + writel(ATMEL_PMX_CA_BFAVD, &pio->pioc.per); + writel(ATMEL_PMX_CA_BFAVD, &pio->pioc.odr); /* disable output */ + writel(ATMEL_PMX_CA_BFCK, &pio->pioc.codr);
/* PIOC clock enabling */ - writel(1 << AT91_ID_PIOC, &pmc->pcer); + writel(1 << ATMEL_ID_PIOC, &pmc->pcer); }
static void board_nand_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) { - at91_pio_t *pio = (at91_pio_t *) AT91_PIO_BASE; + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIO; struct nand_chip *this = mtd->priv; ulong IO_ADDR_W = (ulong) this->IO_ADDR_W;
@@ -219,7 +219,7 @@ static void board_nand_hwcontrol(struct mtd_info *mtd,
static int board_nand_dev_ready(struct mtd_info *mtd) { - at91_pio_t *pio = (at91_pio_t *) AT91_PIO_BASE; + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIO; return ((readl(&pio->pioc.pdsr) & (1 << 2)) != 0); }
@@ -248,8 +248,8 @@ int drv_video_init(void) #endif char *s; unsigned long csr; - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; - at91_mc_t *mc = (at91_mc_t *) AT91_MC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; + at91_mc_t *mc = (at91_mc_t *) ATMEL_BASE_MC;
printf("Init Video as "); s = getenv("displaywidth"); @@ -270,7 +270,7 @@ int drv_video_init(void) AT91_SMC_CSR_ACSS_STANDARD | AT91_SMC_CSR_DBW_16 | AT91_SMC_CSR_BAT_16 | AT91_SMC_CSR_WSEN; writel(csr, &mc->smc.csr[2]); - writel(1 << AT91_ID_PIOB, &pmc->pcer); + writel(1 << ATMEL_ID_PIOB, &pmc->pcer);
vcxk_init(display_width, display_height); #ifdef CONFIG_SPLASH_SCREEN @@ -290,11 +290,11 @@ int drv_video_init(void) void i2c_init_board(void) { u32 pin; - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; - at91_pio_t *pio = (at91_pio_t *) AT91_PIO_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIO;
- writel(1 << AT91_ID_PIOA, &pmc->pcer); - pin = AT91_PMX_AA_TWD | AT91_PMX_AA_TWCK; + writel(1 << ATMEL_ID_PIOA, &pmc->pcer); + pin = ATMEL_PMX_AA_TWD | ATMEL_PMX_AA_TWCK; writel(pin, &pio->pioa.idr); writel(pin, &pio->pioa.pudr); writel(pin, &pio->pioa.per); @@ -310,7 +310,7 @@ void i2c_init_board(void)
void __led_toggle(led_id_t mask) { - at91_pio_t *pio = (at91_pio_t *) AT91_PIO_BASE; + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIO;
if (readl(&pio->piod.odsr) & mask) writel(mask, &pio->piod.codr); @@ -320,10 +320,10 @@ void __led_toggle(led_id_t mask)
void __led_init(led_id_t mask, int state) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; - at91_pio_t *pio = (at91_pio_t *) AT91_PIO_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIO;
- writel(1 << AT91_ID_PIOD, &pmc->pcer); /* Enable PIOB clock */ + writel(1 << ATMEL_ID_PIOD, &pmc->pcer); /* Enable PIOB clock */ /* Disable peripherals on LEDs */ writel(STATUS_LED_BIT | STATUS_LED_BIT1, &pio->piod.per); /* Enable pins as outputs */ @@ -336,7 +336,7 @@ void __led_init(led_id_t mask, int state)
void __led_set(led_id_t mask, int state) { - at91_pio_t *pio = (at91_pio_t *) AT91_PIO_BASE; + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIO; if (state == STATUS_LED_ON) writel(mask, &pio->piod.codr); else diff --git a/board/atmel/at91rm9200ek/at91rm9200ek.c b/board/atmel/at91rm9200ek/at91rm9200ek.c index d242583..5ebc24d 100644 --- a/board/atmel/at91rm9200ek/at91rm9200ek.c +++ b/board/atmel/at91rm9200ek/at91rm9200ek.c @@ -44,7 +44,7 @@ int board_init(void) * Correct IRDA resistor problem * Set PA23_TXD in Output */ - writel(AT91_PMX_AA_TXD2, &pio->pioa.oer); + writel(ATMEL_PMX_AA_TXD2, &pio->pioa.oer);
/* arch number of AT91RM9200EK-Board */ gd->bd->bi_arch_number = MACH_TYPE_AT91RM9200EK; @@ -65,6 +65,6 @@ int dram_init (void) #ifdef CONFIG_DRIVER_AT91EMAC int board_eth_init(bd_t *bis) { - return at91emac_register(bis, (u32) AT91_EMAC_BASE); + return at91emac_register(bis, (u32) ATMEL_BASE_EMAC); } #endif diff --git a/board/atmel/at91rm9200ek/led.c b/board/atmel/at91rm9200ek/led.c index 8d512e0..1766ddf 100644 --- a/board/atmel/at91rm9200ek/led.c +++ b/board/atmel/at91rm9200ek/led.c @@ -26,8 +26,10 @@ */
#include <common.h> -#include <asm/arch/gpio.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> #include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_pio.h>
/* bit mask in PIO port B */ #define GREEN_LED (1<<0) @@ -36,47 +38,47 @@
void green_LED_on(void) { - at91_pio_t *pio = (at91_pio_t *)AT91_PIO_BASE; + at91_pio_t *pio = (at91_pio_t *)ATMEL_BASE_PIO; writel(GREEN_LED, &pio->piob.codr); }
void yellow_LED_on(void) { - at91_pio_t *pio = (at91_pio_t *)AT91_PIO_BASE; + at91_pio_t *pio = (at91_pio_t *)ATMEL_BASE_PIO; writel(YELLOW_LED, &pio->piob.codr); }
void red_LED_on(void) { - at91_pio_t *pio = (at91_pio_t *)AT91_PIO_BASE; + at91_pio_t *pio = (at91_pio_t *)ATMEL_BASE_PIO; writel(RED_LED, &pio->piob.codr); }
void green_LED_off(void) { - at91_pio_t *pio = (at91_pio_t *)AT91_PIO_BASE; + at91_pio_t *pio = (at91_pio_t *)ATMEL_BASE_PIO; writel(GREEN_LED, &pio->piob.sodr); }
void yellow_LED_off(void) { - at91_pio_t *pio = (at91_pio_t *)AT91_PIO_BASE; + at91_pio_t *pio = (at91_pio_t *)ATMEL_BASE_PIO; writel(YELLOW_LED, &pio->piob.sodr); }
void red_LED_off(void) { - at91_pio_t *pio = (at91_pio_t *)AT91_PIO_BASE; + at91_pio_t *pio = (at91_pio_t *)ATMEL_BASE_PIO; writel(RED_LED, &pio->piob.sodr); }
void coloured_LED_init (void) { - at91_pmc_t *pmc = (at91_pmc_t *)AT91_PMC_BASE; - at91_pio_t *pio = (at91_pio_t *)AT91_PIO_BASE; + at91_pmc_t *pmc = (at91_pmc_t *)ATMEL_BASE_PMC; + at91_pio_t *pio = (at91_pio_t *)ATMEL_BASE_PIO;
/* Enable PIOB clock */ - writel(1 << AT91_ID_PIOB, &pmc->pcer); + writel(1 << ATMEL_ID_PIOB, &pmc->pcer);
/* Disable peripherals on LEDs */ writel(GREEN_LED | YELLOW_LED | RED_LED, &pio->piob.per); diff --git a/drivers/net/at91_emac.c b/drivers/net/at91_emac.c index 4e5685c..228dbae 100644 --- a/drivers/net/at91_emac.c +++ b/drivers/net/at91_emac.c @@ -342,34 +342,34 @@ static int at91emac_init(struct eth_device *netdev, bd_t *bd) u32 value; emac_device *dev; at91_emac_t *emac; - at91_pio_t *pio = (at91_pio_t *) AT91_PIO_BASE; - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIO; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
emac = (at91_emac_t *) netdev->iobase; dev = (emac_device *) netdev->priv;
/* PIO Disable Register */ - value = AT91_PMX_AA_EMDIO | AT91_PMX_AA_EMDC | - AT91_PMX_AA_ERXER | AT91_PMX_AA_ERX1 | - AT91_PMX_AA_ERX0 | AT91_PMX_AA_ECRS | - AT91_PMX_AA_ETX1 | AT91_PMX_AA_ETX0 | - AT91_PMX_AA_ETXEN | AT91_PMX_AA_EREFCK; + value = ATMEL_PMX_AA_EMDIO | ATMEL_PMX_AA_EMDC | + ATMEL_PMX_AA_ERXER | ATMEL_PMX_AA_ERX1 | + ATMEL_PMX_AA_ERX0 | ATMEL_PMX_AA_ECRS | + ATMEL_PMX_AA_ETX1 | ATMEL_PMX_AA_ETX0 | + ATMEL_PMX_AA_ETXEN | ATMEL_PMX_AA_EREFCK;
writel(value, &pio->pioa.pdr); writel(value, &pio->pioa.asr);
#ifdef CONFIG_RMII - value = AT91_PMX_BA_ERXCK; + value = ATMEL_PMX_BA_ERXCK; #else - value = AT91_PMX_BA_ERXCK | AT91_PMX_BA_ECOL | - AT91_PMX_BA_ERXDV | AT91_PMX_BA_ERX3 | - AT91_PMX_BA_ERX2 | AT91_PMX_BA_ETXER | - AT91_PMX_BA_ETX3 | AT91_PMX_BA_ETX2; + value = ATMEL_PMX_BA_ERXCK | ATMEL_PMX_BA_ECOL | + ATMEL_PMX_BA_ERXDV | ATMEL_PMX_BA_ERX3 | + ATMEL_PMX_BA_ERX2 | ATMEL_PMX_BA_ETXER | + ATMEL_PMX_BA_ETX3 | ATMEL_PMX_BA_ETX2; #endif writel(value, &pio->piob.pdr); writel(value, &pio->piob.bsr);
- writel(1 << AT91_ID_EMAC, &pmc->pcer); + writel(1 << ATMEL_ID_EMAC, &pmc->pcer); writel(readl(&emac->ctl) | AT91_EMAC_CTL_CSR, &emac->ctl);
/* Init Ethernet buffers */ @@ -476,11 +476,11 @@ static int at91emac_write_hwaddr(struct eth_device *netdev) { emac_device *dev; at91_emac_t *emac; - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; emac = (at91_emac_t *) netdev->iobase; dev = (emac_device *) netdev->priv;
- writel(1 << AT91_ID_EMAC, &pmc->pcer); + writel(1 << ATMEL_ID_EMAC, &pmc->pcer); DEBUG_AT91EMAC("init MAC-ADDR %x%x \n", cpu_to_le16(*((u16 *)(netdev->enetaddr + 4))), cpu_to_le32(*((u32 *)netdev->enetaddr))); @@ -498,7 +498,7 @@ int at91emac_register(bd_t *bis, unsigned long iobase) struct eth_device *dev;
if (iobase == 0) - iobase = AT91_EMAC_BASE; + iobase = ATMEL_BASE_EMAC; emac = malloc(sizeof(*emac)+512); if (emac == NULL) return -1; diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index 810023a..33212c3 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -172,7 +172,7 @@ #define CONFIG_DOS_PARTITION 1
#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 -#define CONFIG_SYS_USB_OHCI_REGS_BASE AT91_USB_HOST_BASE +#define CONFIG_SYS_USB_OHCI_REGS_BASE ATMEL_USB_HOST_BASE #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91rm9200" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 15
diff --git a/include/configs/eb_cpux9k2.h b/include/configs/eb_cpux9k2.h index 754fc8b..a635e58 100644 --- a/include/configs/eb_cpux9k2.h +++ b/include/configs/eb_cpux9k2.h @@ -29,12 +29,13 @@
-#define CONFIG_ARM920T 1 /* This is an ARM920T Core */ -#define CONFIG_AT91RM9200 1 /* It's an Atmel AT91RM9200 SoC */ -#define CONFIG_EB_CPUX9K2 1 /* on an EP+CPUX9K2 Board */ -#define USE_920T_MMU 1 +#define CONFIG_ARM920T /* This is an ARM920T Core */ +#define CONFIG_AT91FAMILY +#define CONFIG_AT91RM9200 /* It's an Atmel AT91RM9200 SoC */ +#define CONFIG_EB_CPUX9K2 /* on an EP+CPUX9K2 Board */ +#define USE_920T_MMU
-#define CONFIG_VERSION_VARIABLE 1 +#define CONFIG_VERSION_VARIABLE #define CONFIG_IDENT_STRING " on EB+CPUx9K2"
#include <asm/arch/hardware.h> /* needed for port definitions */ @@ -186,8 +187,12 @@ #define CONFIG_NET_RETRY_COUNT 10 #define CONFIG_RESET_PHY_R 1
+ #define CONFIG_DRIVER_AT91EMAC 1 #define CONFIG_DRIVER_AT91EMAC_QUIET 1 +/* +#define CONFIG_DRIVER_MACB 1 +*/ #define CONFIG_SYS_RX_ETH_BUFFER 8 #define CONFIG_MII 1
@@ -217,19 +222,19 @@ #define CONFIG_SYS_I2C_INIT_BOARD
#define I2C_INIT i2c_init_board(); -#define I2C_ACTIVE writel(AT91_PMX_AA_TWD, &pio->pioa.mddr); -#define I2C_TRISTATE writel(AT91_PMX_AA_TWD, &pio->pioa.mder); -#define I2C_READ ((readl(&pio->pioa.pdsr) & AT91_PMX_AA_TWD) != 0) +#define I2C_ACTIVE writel(ATMEL_PMX_AA_TWD, &pio->pioa.mddr); +#define I2C_TRISTATE writel(ATMEL_PMX_AA_TWD, &pio->pioa.mder); +#define I2C_READ ((readl(&pio->pioa.pdsr) & ATMEL_PMX_AA_TWD) != 0) #define I2C_SDA(bit) \ if (bit) \ - writel(AT91_PMX_AA_TWD, &pio->pioa.sodr); \ + writel(ATMEL_PMX_AA_TWD, &pio->pioa.sodr); \ else \ - writel(AT91_PMX_AA_TWD, &pio->pioa.codr); + writel(ATMEL_PMX_AA_TWD, &pio->pioa.codr); #define I2C_SCL(bit) \ if (bit) \ - writel(AT91_PMX_AA_TWCK, &pio->pioa.sodr); \ + writel(ATMEL_PMX_AA_TWCK, &pio->pioa.sodr); \ else \ - writel(AT91_PMX_AA_TWCK, &pio->pioa.codr); + writel(ATMEL_PMX_AA_TWCK, &pio->pioa.codr);
#define I2C_DELAY udelay(2500000/CONFIG_SYS_I2C_SPEED)
Dear Jens Scharsig,
Am 10.02.2011 um 20:31 schrieb Jens Scharsig:
- update arm920t/at91 to ATMEL_xxx name scheme
- convert at91rm9200ek and eb_cpux9k2 board to ATMEL_xxx name scheme
- update arm920t/at91 soc lib
- update at91_emac driver
Tested-by: Andreas Bießmann andreas.devel@gmail.com
But some changes
at91rm9200ek is working but the change for timer.c is needed Testet peripheral for at91rm9200ek is: - USB (fatls) - EMAC (tftp)
[reset.c is OK]
Please add:
diff --git a/arch/arm/cpu/arm920t/at91/timer.c b/arch/arm/cpu/arm920t/at91/timer.c index e2630b8..f0ad7d6 100644 --- a/arch/arm/cpu/arm920t/at91/timer.c +++ b/arch/arm/cpu/arm920t/at91/timer.c @@ -32,7 +32,7 @@
#include <common.h>
-#include <asm/arch/io.h> +#include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/at91_tc.h> #include <asm/arch/at91_pmc.h>
[other changes to timer.c are OK] [at91_mc.h is OK] [at91_pmc.h is OK]
These are defined in board header .. I saw they are defined also in other at91xxx.h files, we should discuss where to define these since all of the at91xx.h files are included by hardware.h
[snip changes to at91rm9200.h which are obviously OK]
3 or 4 PIO?
#endif
[cpux9k2.c is OK] [at91rm9200ek.c is OK] [at91rm9200ek/led.c is OK] [at91_emac.c is OK] [at91rm9200ek.h is OK]
please remove this additional empty line
why this? Either it is needed or not.
else \writel(ATMEL_PMX_AA_TWD, &pio->pioa.sodr); \
else \writel(ATMEL_PMX_AA_TWCK, &pio->pioa.sodr); \
-- 1.7.1
Dear Andreas Bießmann,
I'm offline for the net 10 days. So I fast include your comments to a V2 patch version
Am 11.02.2011 09:11, schrieb Andreas Bießmann:
Dear Jens Scharsig,
But some changes
I have prepare a second version of my patch.
The timer.c changes I sent i a previous patch. I have join them to V2
- USB (fatls)
- EMAC (tftp)
In V2 a have remove the define from board config's
3 or 4 PIO?
3 for PLCC and 4 for BGA variants. In PLCC the 4th port is not bound out. I set the comment to 4 in V2
removed
waste from testing, removed
Best regard
Jens Scharsig
Andreas Bießmann
Jens Scharsig
