[PATCH 0/3] qcom: rpmh core and regulator support
This series introduces support for the RPMh (Resource Power Manager (hardened)) co-processor and associated regulator driver found on most modern Qualcomm platforms (since ~2017).
Even though most regulators are controlled via SPMI, the specific regions on the PMICs for controlling the regulators are restricted and can't be accessed by the Applications Processor (AP/HLOS). Instead, these resources are proxied via the RPMh where they can be voted on by multiple subsystems (Linux, the modem, and the other DSPs). This is done for security (to protect clocks, power domains, and regulators that are specifically relevant for the trustzone) as well as to simplify the management of shared peripherals and to allow for handover of peripherals like the USB controller.
For U-Boot, our main concern is the regulators. Since all regulators on the system are controlled via the RPMh, it is necessary to support it to enable USB VBUS on some platforms, and may be needed for other peripherals in the future.
Communicating with the RPMh additional requires accessing the cmd-db shared memory region, this contains key/value maps to determine the address of specific resources on the RPMh.
Introduce support for the cmd-db, the RPMh framework, and some of the regulators that are necessary to enable USB VBUS on the RB5 development board.
These drivers were originally taken from Linux, however they have been heavily modified and simplified for U-Boot. Since the original Linux drivers contained heavy optimisations related to multithreading and asynchronous probing, as well as support for idle and suspend states which we don't need to deal with here.
The U-Boot version of the driver supports a single TCS and always requests a response from the RPMh, since we don't need to worry about having multiple transactions in flight at once.
--- Caleb Connolly (3): linux/bitmap.h: add bitmap_empty helper soc: qcom: rpmh and cmd-db drivers power: regulator: add qcom-rpmh-regulator
drivers/power/regulator/Kconfig | 8 + drivers/power/regulator/Makefile | 1 + drivers/power/regulator/qcom-rpmh-regulator.c | 534 ++++++++++++++++++++++ drivers/soc/Kconfig | 1 + drivers/soc/Makefile | 1 + drivers/soc/qcom/Kconfig | 25 ++ drivers/soc/qcom/Makefile | 4 + drivers/soc/qcom/cmd-db.c | 246 ++++++++++ drivers/soc/qcom/rpmh-internal.h | 141 ++++++ drivers/soc/qcom/rpmh-rsc.c | 619 ++++++++++++++++++++++++++ drivers/soc/qcom/rpmh.c | 110 +++++ include/linux/bitmap.h | 8 + include/soc/qcom/cmd-db.h | 42 ++ include/soc/qcom/rpmh.h | 29 ++ include/soc/qcom/tcs.h | 78 ++++ 15 files changed, 1847 insertions(+) --- change-id: 20240611-b4-qcom-rpmh-fcfd32ac2940 base-commit: 65134a67bca5e11415e93262e530b1c91fee154f
// Caleb (they/them)
Import this function from Linux.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/linux/bitmap.h | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/include/linux/bitmap.h b/include/linux/bitmap.h index 0a8503af9f14..40ca2212cb40 100644 --- a/include/linux/bitmap.h +++ b/include/linux/bitmap.h @@ -195,8 +195,16 @@ static inline void bitmap_fill(unsigned long *dst, unsigned int nbits) memset(dst, 0xff, len); } }
+static inline bool bitmap_empty(const unsigned long *src, unsigned int nbits) +{ + if (small_const_nbits(nbits)) + return !(*src & BITMAP_LAST_WORD_MASK(nbits)); + + return find_first_bit(src, nbits) == nbits; +} + static inline void bitmap_or(unsigned long *dst, const unsigned long *src1, const unsigned long *src2, unsigned int nbits) { if (small_const_nbits(nbits))
Introduce two Qualcomm SoC drivers, the RPMh and cmd-db. RPMh is a the name for the second generation Resource Power Management hub on Qualcomm SoCs. Most core regulators have to be controlled via this hub.
The cmd-db is a region of memory which contains offsets and data about how to communicate with the RPMh.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/soc/Kconfig | 1 + drivers/soc/Makefile | 1 + drivers/soc/qcom/Kconfig | 25 ++ drivers/soc/qcom/Makefile | 4 + drivers/soc/qcom/cmd-db.c | 246 ++++++++++++++++ drivers/soc/qcom/rpmh-internal.h | 141 +++++++++ drivers/soc/qcom/rpmh-rsc.c | 619 +++++++++++++++++++++++++++++++++++++++ drivers/soc/qcom/rpmh.c | 110 +++++++ include/soc/qcom/cmd-db.h | 42 +++ include/soc/qcom/rpmh.h | 29 ++ include/soc/qcom/tcs.h | 78 +++++ 11 files changed, 1296 insertions(+)
diff --git a/drivers/soc/Kconfig b/drivers/soc/Kconfig index 03433bc0e6d2..8ceca0cb1386 100644 --- a/drivers/soc/Kconfig +++ b/drivers/soc/Kconfig @@ -39,8 +39,9 @@ config SOC_XILINX_VERSAL_NET Enable this option to select SoC device id driver for Xilinx Versal NET. This allows other drivers to verify the SoC familiy & revision using matching SoC attributes.
+source "drivers/soc/qcom/Kconfig" source "drivers/soc/samsung/Kconfig" source "drivers/soc/ti/Kconfig"
endmenu diff --git a/drivers/soc/Makefile b/drivers/soc/Makefile index 610bf816d40a..c3d484e5bf6c 100644 --- a/drivers/soc/Makefile +++ b/drivers/soc/Makefile @@ -3,8 +3,9 @@ # Makefile for the U-Boot SOC specific device drivers.
obj-$(CONFIG_SOC_SAMSUNG) += samsung/ obj-$(CONFIG_SOC_TI) += ti/ +obj-$(CONFIG_SOC_QCOM) += qcom/ obj-$(CONFIG_SOC_DEVICE) += soc-uclass.o obj-$(CONFIG_SOC_DEVICE_TI_K3) += soc_ti_k3.o obj-$(CONFIG_SANDBOX) += soc_sandbox.o obj-$(CONFIG_SOC_XILINX_ZYNQMP) += soc_xilinx_zynqmp.o diff --git a/drivers/soc/qcom/Kconfig b/drivers/soc/qcom/Kconfig new file mode 100644 index 000000000000..a0872c5b3c83 --- /dev/null +++ b/drivers/soc/qcom/Kconfig @@ -0,0 +1,25 @@ +# SPDX-License-Identifier: GPL-2.0+ + +menuconfig SOC_QCOM + bool "Qualcomm SOC drivers support" + help + Say Y here if you want to enable Qualcomm SOC drivers support. + +if SOC_QCOM + +config QCOM_COMMAND_DB + bool "Qualcomm Command DB" + help + Command DB queries shared memory by key string for shared system + resources. Platform drivers that require to set state of a shared + resource on a RPM-hardened platform must use this database to get + SoC specific identifier and information for the shared resources. + +config QCOM_RPMH + bool "Qualcomm RPMh support" + depends on QCOM_COMMAND_DB + help + Say y here to support the Qualcomm RPMh (resource peripheral manager) + if you need to control regulators on Qualcomm platforms, say y here. + +endif # SOC_QCOM diff --git a/drivers/soc/qcom/Makefile b/drivers/soc/qcom/Makefile new file mode 100644 index 000000000000..4fca569cfb77 --- /dev/null +++ b/drivers/soc/qcom/Makefile @@ -0,0 +1,4 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-$(CONFIG_QCOM_COMMAND_DB) += cmd-db.o +obj-$(CONFIG_QCOM_RPMH) += rpmh-rsc.o rpmh.o diff --git a/drivers/soc/qcom/cmd-db.c b/drivers/soc/qcom/cmd-db.c new file mode 100644 index 000000000000..7bfd72ae2f3f --- /dev/null +++ b/drivers/soc/qcom/cmd-db.c @@ -0,0 +1,246 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2016-2018, 2020, The Linux Foundation. All rights reserved. + * Copyright (c) 2023, Linaro Ltd. + */ + +#include <dm/device.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <linux/kernel.h> +#include <linux/types.h> +#include <linux/ioport.h> +#include <linux/byteorder/generic.h> + +#include <soc/qcom/cmd-db.h> + +#define NUM_PRIORITY 2 +#define MAX_SLV_ID 8 +#define SLAVE_ID_MASK 0x7 +#define SLAVE_ID_SHIFT 16 + +/** + * struct entry_header: header for each entry in cmddb + * + * @id: resource's identifier + * @priority: unused + * @addr: the address of the resource + * @len: length of the data + * @offset: offset from :@data_offset, start of the data + */ +struct entry_header { + u8 id[8]; + __le32 priority[NUM_PRIORITY]; + __le32 addr; + __le16 len; + __le16 offset; +}; + +/** + * struct rsc_hdr: resource header information + * + * @slv_id: id for the resource + * @header_offset: entry's header at offset from the end of the cmd_db_header + * @data_offset: entry's data at offset from the end of the cmd_db_header + * @cnt: number of entries for HW type + * @version: MSB is major, LSB is minor + * @reserved: reserved for future use. + */ +struct rsc_hdr { + __le16 slv_id; + __le16 header_offset; + __le16 data_offset; + __le16 cnt; + __le16 version; + __le16 reserved[3]; +}; + +/** + * struct cmd_db_header: The DB header information + * + * @version: The cmd db version + * @magic: constant expected in the database + * @header: array of resources + * @checksum: checksum for the header. Unused. + * @reserved: reserved memory + * @data: driver specific data + */ +struct cmd_db_header { + __le32 version; + u8 magic[4]; + struct rsc_hdr header[MAX_SLV_ID]; + __le32 checksum; + __le32 reserved; + u8 data[]; +}; + +/** + * DOC: Description of the Command DB database. + * + * At the start of the command DB memory is the cmd_db_header structure. + * The cmd_db_header holds the version, checksum, magic key as well as an + * array for header for each slave (depicted by the rsc_header). Each h/w + * based accelerator is a 'slave' (shared resource) and has slave id indicating + * the type of accelerator. The rsc_header is the header for such individual + * slaves of a given type. The entries for each of these slaves begin at the + * rsc_hdr.header_offset. In addition each slave could have auxiliary data + * that may be needed by the driver. The data for the slave starts at the + * entry_header.offset to the location pointed to by the rsc_hdr.data_offset. + * + * Drivers have a stringified key to a slave/resource. They can query the slave + * information and get the slave id and the auxiliary data and the length of the + * data. Using this information, they can format the request to be sent to the + * h/w accelerator and request a resource state. + */ + +static const u8 CMD_DB_MAGIC[] = { 0xdb, 0x30, 0x03, 0x0c }; + +static bool cmd_db_magic_matches(const struct cmd_db_header *header) +{ + const u8 *magic = header->magic; + + return memcmp(magic, CMD_DB_MAGIC, ARRAY_SIZE(CMD_DB_MAGIC)) == 0; +} + +static struct cmd_db_header *cmd_db_header; + +static inline const void *rsc_to_entry_header(const struct rsc_hdr *hdr) +{ + u16 offset = le16_to_cpu(hdr->header_offset); + + return cmd_db_header->data + offset; +} + +static inline void * +rsc_offset(const struct rsc_hdr *hdr, const struct entry_header *ent) +{ + u16 offset = le16_to_cpu(hdr->data_offset); + u16 loffset = le16_to_cpu(ent->offset); + + return cmd_db_header->data + offset + loffset; +} + +static int cmd_db_get_header(const char *id, const struct entry_header **eh, + const struct rsc_hdr **rh) +{ + const struct rsc_hdr *rsc_hdr; + const struct entry_header *ent; + int i, j; + u8 query[sizeof(ent->id)] __nonstring; + + /* + * Pad out query string to same length as in DB. NOTE: the output + * query string is not necessarily '\0' terminated if it bumps up + * against the max size. That's OK and expected. + */ + strncpy(query, id, sizeof(query)); + + for (i = 0; i < MAX_SLV_ID; i++) { + rsc_hdr = &cmd_db_header->header[i]; + if (!rsc_hdr->slv_id) + break; + + ent = rsc_to_entry_header(rsc_hdr); + for (j = 0; j < le16_to_cpu(rsc_hdr->cnt); j++, ent++) { + if (memcmp(ent->id, query, sizeof(ent->id)) == 0) { + if (eh) + *eh = ent; + if (rh) + *rh = rsc_hdr; + return 0; + } + } + } + + return -ENODEV; +} + +/** + * cmd_db_read_addr() - Query command db for resource id address. + * + * @id: resource id to query for address + * + * Return: resource address on success, 0 on error + * + * This is used to retrieve resource address based on resource + * id. + */ +u32 cmd_db_read_addr(const char *id) +{ + int ret; + const struct entry_header *ent; + + ret = cmd_db_get_header(id, &ent, NULL); + + return ret < 0 ? 0 : le32_to_cpu(ent->addr); +} +EXPORT_SYMBOL(cmd_db_read_addr); + +/** + * cmd_db_read_aux_data() - Query command db for aux data. + * + * @id: Resource to retrieve AUX Data on + * @len: size of data buffer returned + * + * Return: pointer to data on success, error pointer otherwise + */ +const void *cmd_db_read_aux_data(const char *id, size_t *len) +{ + int ret; + const struct entry_header *ent; + const struct rsc_hdr *rsc_hdr; + + ret = cmd_db_get_header(id, &ent, &rsc_hdr); + if (ret) + return ERR_PTR(ret); + + if (len) + *len = le16_to_cpu(ent->len); + + return rsc_offset(rsc_hdr, ent); +} +EXPORT_SYMBOL(cmd_db_read_aux_data); + +/** + * cmd_db_read_slave_id - Get the slave ID for a given resource address + * + * @id: Resource id to query the DB for version + * + * Return: cmd_db_hw_type enum on success, CMD_DB_HW_INVALID on error + */ +enum cmd_db_hw_type cmd_db_read_slave_id(const char *id) +{ + int ret; + const struct entry_header *ent; + u32 addr; + + ret = cmd_db_get_header(id, &ent, NULL); + if (ret < 0) + return CMD_DB_HW_INVALID; + + addr = le32_to_cpu(ent->addr); + return (addr >> SLAVE_ID_SHIFT) & SLAVE_ID_MASK; +} +EXPORT_SYMBOL(cmd_db_read_slave_id); + +int cmd_db_init(ofnode node) +{ + void __iomem *base; + + debug("%s(%s)\n", __func__, ofnode_get_name(node)); + + base = (void __iomem *)ofnode_get_addr(node); + if ((fdt_addr_t)base == FDT_ADDR_T_NONE) { + log_err("%s: Failed to read base address\n", __func__); + return -ENOENT; + } + + cmd_db_header = base; + if (!cmd_db_magic_matches(cmd_db_header)) { + log_err("%s: Invalid Command DB Magic\n", __func__); + return -EINVAL; + } + + return 0; +} +EXPORT_SYMBOL(cmd_db_init); diff --git a/drivers/soc/qcom/rpmh-internal.h b/drivers/soc/qcom/rpmh-internal.h new file mode 100644 index 000000000000..9dbb1c51cc35 --- /dev/null +++ b/drivers/soc/qcom/rpmh-internal.h @@ -0,0 +1,141 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2016-2018, The Linux Foundation. All rights reserved. + */ + +#ifndef __RPM_INTERNAL_H__ +#define __RPM_INTERNAL_H__ + +#include <linux/bitmap.h> +#include <soc/qcom/tcs.h> + +#define TCS_TYPE_NR 4 +#define MAX_CMDS_PER_TCS 16 +#define MAX_TCS_PER_TYPE 3 +#define MAX_TCS_NR (MAX_TCS_PER_TYPE * TCS_TYPE_NR) +#define MAX_TCS_SLOTS (MAX_CMDS_PER_TCS * MAX_TCS_PER_TYPE) + +#define USEC_PER_SEC 1000000UL + +struct rsc_drv; + +/** + * struct tcs_group: group of Trigger Command Sets (TCS) to send state requests + * to the controller + * + * @drv: The controller. + * @type: Type of the TCS in this group - active, sleep, wake. + * @mask: Mask of the TCSes relative to all the TCSes in the RSC. + * @offset: Start of the TCS group relative to the TCSes in the RSC. + * @num_tcs: Number of TCSes in this type. + * @ncpt: Number of commands in each TCS. + * @req: Requests that are sent from the TCS; only used for ACTIVE_ONLY + * transfers (could be on a wake/sleep TCS if we are borrowing for + * an ACTIVE_ONLY transfer). + * Start: grab drv->lock, set req, set tcs_in_use, drop drv->lock, + * trigger + * End: get irq, access req, + * grab drv->lock, clear tcs_in_use, drop drv->lock + * @slots: Indicates which of @cmd_addr are occupied; only used for + * SLEEP / WAKE TCSs. Things are tightly packed in the + * case that (ncpt < MAX_CMDS_PER_TCS). That is if ncpt = 2 and + * MAX_CMDS_PER_TCS = 16 then bit[2] = the first bit in 2nd TCS. + */ +struct tcs_group { + struct rsc_drv *drv; + int type; + u32 mask; + u32 offset; + int num_tcs; + int ncpt; + const struct tcs_request *req[MAX_TCS_PER_TYPE]; + DECLARE_BITMAP(slots, MAX_TCS_SLOTS); +}; + +/** + * struct rpmh_request: the message to be sent to rpmh-rsc + * + * @msg: the request + * @cmd: the payload that will be part of the @msg + * @completion: triggered when request is done + * @dev: the device making the request + * @needs_free: check to free dynamically allocated request object + */ +struct rpmh_request { + struct tcs_request msg; + struct tcs_cmd cmd[MAX_RPMH_PAYLOAD]; + const struct udevice *dev; + bool needs_free; +}; + +/** + * struct rpmh_ctrlr: our representation of the controller + * + * @cache: the list of cached requests + * @cache_lock: synchronize access to the cache data + * @dirty: was the cache updated since flush + * @batch_cache: Cache sleep and wake requests sent as batch + */ +struct rpmh_ctrlr { + struct list_head cache; + bool dirty; + struct list_head batch_cache; +}; + +struct rsc_ver { + u32 major; + u32 minor; +}; + +/** + * struct rsc_drv: the Direct Resource Voter (DRV) of the + * Resource State Coordinator controller (RSC) + * + * @name: Controller identifier. + * @base: Start address of the DRV registers in this controller. + * @tcs_base: Start address of the TCS registers in this controller. + * @id: Instance id in the controller (Direct Resource Voter). + * @num_tcs: Number of TCSes in this DRV. + * @rsc_pm: CPU PM notifier for controller. + * Used when solver mode is not present. + * @cpus_in_pm: Number of CPUs not in idle power collapse. + * Used when solver mode and "power-domains" is not present. + * @genpd_nb: PM Domain notifier for cluster genpd notifications. + * @tcs: TCS groups. + * @tcs_in_use: S/W state of the TCS; only set for ACTIVE_ONLY + * transfers, but might show a sleep/wake TCS in use if + * it was borrowed for an active_only transfer. You + * must hold the lock in this struct (AKA drv->lock) in + * order to update this. + * @lock: Synchronize state of the controller. If RPMH's cache + * lock will also be held, the order is: drv->lock then + * cache_lock. + * @tcs_wait: Wait queue used to wait for @tcs_in_use to free up a + * slot + * @client: Handle to the DRV's client. + * @dev: RSC device. + */ +struct rsc_drv { + const char *name; + void __iomem *base; + void __iomem *tcs_base; + int id; + int num_tcs; + struct tcs_group tcs[TCS_TYPE_NR]; + DECLARE_BITMAP(tcs_in_use, MAX_TCS_NR); + struct rpmh_ctrlr client; + struct udevice *dev; + struct rsc_ver ver; + u32 *regs; +}; + +int rpmh_rsc_send_data(struct rsc_drv *drv, const struct tcs_request *msg); +int rpmh_rsc_write_ctrl_data(struct rsc_drv *drv, + const struct tcs_request *msg); +void rpmh_rsc_invalidate(struct rsc_drv *drv); +void rpmh_rsc_write_next_wakeup(struct rsc_drv *drv); + +int rpmh_rsc_wait_for_resp(struct rsc_drv *drv, int tcs_id); +int rpmh_flush(struct rpmh_ctrlr *ctrlr); + +#endif /* __RPM_INTERNAL_H__ */ diff --git a/drivers/soc/qcom/rpmh-rsc.c b/drivers/soc/qcom/rpmh-rsc.c new file mode 100644 index 000000000000..3c73dc0ffe25 --- /dev/null +++ b/drivers/soc/qcom/rpmh-rsc.c @@ -0,0 +1,619 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2016-2018, 2020, The Linux Foundation. All rights reserved. + * Copyright (c) 2023, Linaro Ltd. + */ + +#include <linux/err.h> +#include <linux/types.h> +#include <dm.h> +#include <dm/ofnode.h> +#include <dm/devres.h> +#include <dm/device_compat.h> +#include <linux/delay.h> +#include <dm/lists.h> +#include <errno.h> +#include <asm/io.h> +#include <asm/bitops.h> +#include <linux/bitmap.h> +#include <log.h> + +#include <dt-bindings/soc/qcom,rpmh-rsc.h> +#include "rpmh-internal.h" + +#include <soc/qcom/rpmh.h> +#include <soc/qcom/cmd-db.h> + +#define RSC_DRV_ID 0 + +#define MAJOR_VER_MASK 0xFF +#define MAJOR_VER_SHIFT 16 +#define MINOR_VER_MASK 0xFF +#define MINOR_VER_SHIFT 8 + +enum { + RSC_DRV_TCS_OFFSET, + RSC_DRV_CMD_OFFSET, + DRV_SOLVER_CONFIG, + DRV_PRNT_CHLD_CONFIG, + RSC_DRV_IRQ_ENABLE, + RSC_DRV_IRQ_STATUS, + RSC_DRV_IRQ_CLEAR, + RSC_DRV_CMD_WAIT_FOR_CMPL, + RSC_DRV_CONTROL, + RSC_DRV_STATUS, + RSC_DRV_CMD_ENABLE, + RSC_DRV_CMD_MSGID, + RSC_DRV_CMD_ADDR, + RSC_DRV_CMD_DATA, + RSC_DRV_CMD_STATUS, + RSC_DRV_CMD_RESP_DATA, +}; + +/* DRV HW Solver Configuration Information Register */ +#define DRV_HW_SOLVER_MASK 1 +#define DRV_HW_SOLVER_SHIFT 24 + +/* DRV TCS Configuration Information Register */ +#define DRV_NUM_TCS_MASK 0x3F +#define DRV_NUM_TCS_SHIFT 6 +#define DRV_NCPT_MASK 0x1F +#define DRV_NCPT_SHIFT 27 + +/* Offsets for CONTROL TCS Registers */ +#define RSC_DRV_CTL_TCS_DATA_HI 0x38 +#define RSC_DRV_CTL_TCS_DATA_HI_MASK 0xFFFFFF +#define RSC_DRV_CTL_TCS_DATA_HI_VALID BIT(31) +#define RSC_DRV_CTL_TCS_DATA_LO 0x40 +#define RSC_DRV_CTL_TCS_DATA_LO_MASK 0xFFFFFFFF +#define RSC_DRV_CTL_TCS_DATA_SIZE 32 + +#define TCS_AMC_MODE_ENABLE BIT(16) +#define TCS_AMC_MODE_TRIGGER BIT(24) + +/* TCS CMD register bit mask */ +#define CMD_MSGID_LEN 8 +#define CMD_MSGID_RESP_REQ BIT(8) +#define CMD_MSGID_WRITE BIT(16) +#define CMD_STATUS_ISSUED BIT(8) +#define CMD_STATUS_COMPL BIT(16) + +/* + * Here's a high level overview of how all the registers in RPMH work + * together: + * + * - The main rpmh-rsc address is the base of a register space that can + * be used to find overall configuration of the hardware + * (DRV_PRNT_CHLD_CONFIG). Also found within the rpmh-rsc register + * space are all the TCS blocks. The offset of the TCS blocks is + * specified in the device tree by "qcom,tcs-offset" and used to + * compute tcs_base. + * - TCS blocks come one after another. Type, count, and order are + * specified by the device tree as "qcom,tcs-config". + * - Each TCS block has some registers, then space for up to 16 commands. + * Note that though address space is reserved for 16 commands, fewer + * might be present. See ncpt (num cmds per TCS). + * + * Here's a picture: + * + * +---------------------------------------------------+ + * |RSC | + * | ctrl | + * | | + * | Drvs: | + * | +-----------------------------------------------+ | + * | |DRV0 | | + * | | ctrl/config | | + * | | IRQ | | + * | | | | + * | | TCSes: | | + * | | +------------------------------------------+ | | + * | | |TCS0 | | | | | | | | | | | | | | | + * | | | ctrl | 0| 1| 2| 3| 4| 5| .| .| .| .|14|15| | | + * | | | | | | | | | | | | | | | | | | + * | | +------------------------------------------+ | | + * | | +------------------------------------------+ | | + * | | |TCS1 | | | | | | | | | | | | | | | + * | | | ctrl | 0| 1| 2| 3| 4| 5| .| .| .| .|14|15| | | + * | | | | | | | | | | | | | | | | | | + * | | +------------------------------------------+ | | + * | | +------------------------------------------+ | | + * | | |TCS2 | | | | | | | | | | | | | | | + * | | | ctrl | 0| 1| 2| 3| 4| 5| .| .| .| .|14|15| | | + * | | | | | | | | | | | | | | | | | | + * | | +------------------------------------------+ | | + * | | ...... | | + * | +-----------------------------------------------+ | + * | +-----------------------------------------------+ | + * | |DRV1 | | + * | | (same as DRV0) | | + * | +-----------------------------------------------+ | + * | ...... | + * +---------------------------------------------------+ + */ + +static u32 rpmh_rsc_reg_offset_ver_2_7[] = { + [RSC_DRV_TCS_OFFSET] = 672, + [RSC_DRV_CMD_OFFSET] = 20, + [DRV_SOLVER_CONFIG] = 0x04, + [DRV_PRNT_CHLD_CONFIG] = 0x0C, + [RSC_DRV_IRQ_ENABLE] = 0x00, + [RSC_DRV_IRQ_STATUS] = 0x04, + [RSC_DRV_IRQ_CLEAR] = 0x08, + [RSC_DRV_CMD_WAIT_FOR_CMPL] = 0x10, + [RSC_DRV_CONTROL] = 0x14, + [RSC_DRV_STATUS] = 0x18, + [RSC_DRV_CMD_ENABLE] = 0x1C, + [RSC_DRV_CMD_MSGID] = 0x30, + [RSC_DRV_CMD_ADDR] = 0x34, + [RSC_DRV_CMD_DATA] = 0x38, + [RSC_DRV_CMD_STATUS] = 0x3C, + [RSC_DRV_CMD_RESP_DATA] = 0x40, +}; + +static inline void __iomem * +tcs_reg_addr(const struct rsc_drv *drv, int reg, int tcs_id) +{ + return drv->tcs_base + drv->regs[RSC_DRV_TCS_OFFSET] * tcs_id + reg; +} + +static inline void __iomem * +tcs_cmd_addr(const struct rsc_drv *drv, int reg, int tcs_id, int cmd_id) +{ + return tcs_reg_addr(drv, reg, tcs_id) + drv->regs[RSC_DRV_CMD_OFFSET] * cmd_id; +} + +static u32 read_tcs_reg(const struct rsc_drv *drv, int reg, int tcs_id) +{ + return readl_relaxed(tcs_reg_addr(drv, reg, tcs_id)); +} + +static void write_tcs_cmd(const struct rsc_drv *drv, int reg, int tcs_id, + int cmd_id, u32 data) +{ + void __iomem *addr = tcs_cmd_addr(drv, reg, tcs_id, cmd_id); + + debug("%s: tcs(m): %d cmd(n): %d addr: %#x data: %#x\n", drv->name, + tcs_id, cmd_id, reg, data); + writel_relaxed(data, addr); +} + +static void write_tcs_reg(const struct rsc_drv *drv, int reg, int tcs_id, + u32 data) +{ + void __iomem *addr = tcs_reg_addr(drv, reg, tcs_id); + + debug("%s: tcs(m): %d addr: %#x data: %#x\n", drv->name, + tcs_id, reg, data); + writel_relaxed(data, addr); +} + +static void write_tcs_reg_sync(const struct rsc_drv *drv, int reg, int tcs_id, + u32 data) +{ + int i; + void __iomem *addr = tcs_reg_addr(drv, reg, tcs_id); + + debug("%s: tcs(m): %d addr: %#x data: %#x\n", drv->name, + tcs_id, reg, data); + + writel(data, addr); + + /* + * Wait until we read back the same value. Use a counter rather than + * ktime for timeout since this may be called after timekeeping stops. + */ + for (i = 0; i < USEC_PER_SEC; i++) { + if (readl(addr) == data) + return; + udelay(1); + } + pr_err("%s: error writing %#x to %d:%#x\n", drv->name, + data, tcs_id, reg); +} + +/** + * tcs_invalidate() - Invalidate all TCSes of the given type (sleep or wake). + * @drv: The RSC controller. + * @type: SLEEP_TCS or WAKE_TCS + * + * This will clear the "slots" variable of the given tcs_group and also + * tell the hardware to forget about all entries. + * + * The caller must ensure that no other RPMH actions are happening when this + * function is called, since otherwise the device may immediately become + * used again even before this function exits. + */ +static void tcs_invalidate(struct rsc_drv *drv, int type) +{ + int m; + struct tcs_group *tcs = &drv->tcs[type]; + + /* Caller ensures nobody else is running so no lock */ + if (bitmap_empty(tcs->slots, MAX_TCS_SLOTS)) + return; + + for (m = tcs->offset; m < tcs->offset + tcs->num_tcs; m++) + write_tcs_reg_sync(drv, drv->regs[RSC_DRV_CMD_ENABLE], m, 0); + + bitmap_zero(tcs->slots, MAX_TCS_SLOTS); +} + +/** + * rpmh_rsc_invalidate() - Invalidate sleep and wake TCSes. + * @drv: The RSC controller. + * + * The caller must ensure that no other RPMH actions are happening when this + * function is called, since otherwise the device may immediately become + * used again even before this function exits. + */ +void rpmh_rsc_invalidate(struct rsc_drv *drv) +{ + tcs_invalidate(drv, SLEEP_TCS); + tcs_invalidate(drv, WAKE_TCS); +} + +/** + * rpmh_rsc_wait_for_resp() - Spin until we get a response from the rpmh + * @drv: The controller. + * @tcs_id: The global ID of this TCS. + * + * This is for ACTIVE_ONLY transfers (which are the only ones we support in + * u-boot). As we don't support interrupts, we just spin on the IRQ_STATUS + * register until the bit is set to confirm that the TCS TX is done. + */ +int rpmh_rsc_wait_for_resp(struct rsc_drv *drv, int tcs_id) +{ + u32 reg; + int i; + + reg = drv->regs[RSC_DRV_IRQ_STATUS]; + + debug("%s: waiting for response on tcs %d\n", __func__, tcs_id); + + for (i = 0; i < 5 * USEC_PER_SEC; i++) { + if (readl(tcs_reg_addr(drv, reg, tcs_id)) & BIT(tcs_id)) + break; + udelay(1); + } + + if (i == 5 * USEC_PER_SEC) { + printf("%s: timeout waiting for response\n", drv->name); + return -ETIMEDOUT; + } + + writel_relaxed(BIT(tcs_id), drv->tcs_base + drv->regs[RSC_DRV_IRQ_CLEAR]); + + return 0; +} + +/** + * __tcs_buffer_write() - Write to TCS hardware from a request; don't trigger. + * @drv: The controller. + * @tcs_id: The global ID of this TCS. + * @cmd_id: The index within the TCS to start writing. + * @msg: The message we want to send, which will contain several addr/data + * pairs to program (but few enough that they all fit in one TCS). + * + * This is used for all types of transfers (active, sleep, and wake). + */ +static void __tcs_buffer_write(struct rsc_drv *drv, int tcs_id, int cmd_id, + const struct tcs_request *msg) +{ + u32 msgid; + u32 cmd_msgid = CMD_MSGID_LEN | CMD_MSGID_WRITE; + u32 cmd_enable = 0; + struct tcs_cmd *cmd; + int i, j; + + /* u-boot: get a response to ensure everything is golden before continuing */ + cmd_msgid |= CMD_MSGID_RESP_REQ; + + for (i = 0, j = cmd_id; i < msg->num_cmds; i++, j++) { + cmd = &msg->cmds[i]; + cmd_enable |= BIT(j); + msgid = cmd_msgid; + /* + * Additionally, if the cmd->wait is set, make the command + * response reqd even if the overall request was fire-n-forget. + */ + msgid |= cmd->wait ? CMD_MSGID_RESP_REQ : 0; + + write_tcs_cmd(drv, drv->regs[RSC_DRV_CMD_MSGID], tcs_id, j, msgid); + write_tcs_cmd(drv, drv->regs[RSC_DRV_CMD_ADDR], tcs_id, j, cmd->addr); + write_tcs_cmd(drv, drv->regs[RSC_DRV_CMD_DATA], tcs_id, j, cmd->data); + debug("%s: tcs(m): %d [%s] cmd(n): %d msgid: %#x addr: %#x data: %#x complete: %d\n", + drv->name, tcs_id, msg->state == RPMH_ACTIVE_ONLY_STATE ? "active" : "?", j, msgid, + cmd->addr, cmd->data, cmd->wait); + } + + cmd_enable |= read_tcs_reg(drv, drv->regs[RSC_DRV_CMD_ENABLE], tcs_id); + write_tcs_reg(drv, drv->regs[RSC_DRV_CMD_ENABLE], tcs_id, cmd_enable); +} + +/** + * __tcs_set_trigger() - Start xfer on a TCS or unset trigger on a borrowed TCS + * @drv: The controller. + * @tcs_id: The global ID of this TCS. + * @trigger: If true then untrigger/retrigger. If false then just untrigger. + * + * In the normal case we only ever call with "trigger=true" to start a + * transfer. That will un-trigger/disable the TCS from the last transfer + * then trigger/enable for this transfer. + * + * If we borrowed a wake TCS for an active-only transfer we'll also call + * this function with "trigger=false" to just do the un-trigger/disable + * before using the TCS for wake purposes again. + * + * Note that the AP is only in charge of triggering active-only transfers. + * The AP never triggers sleep/wake values using this function. + */ +static void __tcs_set_trigger(struct rsc_drv *drv, int tcs_id, bool trigger) +{ + u32 enable; + u32 reg = drv->regs[RSC_DRV_CONTROL]; + + /* + * HW req: Clear the DRV_CONTROL and enable TCS again + * While clearing ensure that the AMC mode trigger is cleared + * and then the mode enable is cleared. + */ + enable = read_tcs_reg(drv, reg, tcs_id); + enable &= ~TCS_AMC_MODE_TRIGGER; + write_tcs_reg_sync(drv, reg, tcs_id, enable); + enable &= ~TCS_AMC_MODE_ENABLE; + write_tcs_reg_sync(drv, reg, tcs_id, enable); + + if (trigger) { + /* Enable the AMC mode on the TCS and then trigger the TCS */ + enable = TCS_AMC_MODE_ENABLE; + write_tcs_reg_sync(drv, reg, tcs_id, enable); + enable |= TCS_AMC_MODE_TRIGGER; + write_tcs_reg(drv, reg, tcs_id, enable); + } +} + +/** + * get_tcs_for_msg() - Get the tcs_group used to send the given message. + * @drv: The RSC controller. + * @msg: The message we want to send. + * + * This is normally pretty straightforward except if we are trying to send + * an ACTIVE_ONLY message but don't have any active_only TCSes. + * + * Return: A pointer to a tcs_group or an ERR_PTR. + */ +static struct tcs_group *get_tcs_for_msg(struct rsc_drv *drv, + const struct tcs_request *msg) +{ + if (msg->state != RPMH_ACTIVE_ONLY_STATE) { + printf("WARN: only ACTIVE_ONLY state supported\n"); + return ERR_PTR(-EINVAL); + } + + return &drv->tcs[ACTIVE_TCS]; +} + +/** + * rpmh_rsc_send_data() - Write / trigger active-only message. + * @drv: The controller. + * @msg: The data to be sent. + * + * NOTES: + * - This is only used for "ACTIVE_ONLY" since the limitations of this + * function don't make sense for sleep/wake cases. + * - To do the transfer, we will grab a whole TCS for ourselves--we don't + * try to share. If there are none available we'll wait indefinitely + * for a free one. + * - This function will not wait for the commands to be finished, only for + * data to be programmed into the RPMh. See rpmh_tx_done() which will + * be called when the transfer is fully complete. + * - This function must be called with interrupts enabled. If the hardware + * is busy doing someone else's transfer we need that transfer to fully + * finish so that we can have the hardware, and to fully finish it needs + * the interrupt handler to run. If the interrupts is set to run on the + * active CPU this can never happen if interrupts are disabled. + * + * Return: 0 on success, -EINVAL on error. + */ +int rpmh_rsc_send_data(struct rsc_drv *drv, const struct tcs_request *msg) +{ + struct tcs_group *tcs; + int tcs_id; + unsigned long flags; + + tcs = get_tcs_for_msg(drv, msg); + if (IS_ERR(tcs)) + return PTR_ERR(tcs); + + spin_lock_irqsave(&drv->lock, flags); + + /* u-boot is single-threaded, always use the first TCS as we'll never conflict */ + tcs_id = tcs->offset; + + tcs->req[tcs_id - tcs->offset] = msg; + generic_set_bit(tcs_id, drv->tcs_in_use); + if (msg->state == RPMH_ACTIVE_ONLY_STATE && tcs->type != ACTIVE_TCS) { + /* + * Clear previously programmed WAKE commands in selected + * repurposed TCS to avoid triggering them. tcs->slots will be + * cleaned from rpmh_flush() by invoking rpmh_rsc_invalidate() + */ + write_tcs_reg_sync(drv, drv->regs[RSC_DRV_CMD_ENABLE], tcs_id, 0); + } + spin_unlock_irqrestore(&drv->lock, flags); + + /* + * These two can be done after the lock is released because: + * - We marked "tcs_in_use" under lock. + * - Once "tcs_in_use" has been marked nobody else could be writing + * to these registers until the interrupt goes off. + * - The interrupt can't go off until we trigger w/ the last line + * of __tcs_set_trigger() below. + */ + __tcs_buffer_write(drv, tcs_id, 0, msg); + __tcs_set_trigger(drv, tcs_id, true); + + rpmh_rsc_wait_for_resp(drv, tcs_id); + + return 0; +} + +static int rpmh_probe_tcs_config(struct udevice *dev, struct rsc_drv *drv) +{ + struct tcs_type_config { + u32 type; + u32 n; + } tcs_cfg[TCS_TYPE_NR] = { { 0 } }; + ofnode dn = dev_ofnode(dev); + u32 config, max_tcs, ncpt, offset; + int i, ret, n, st = 0; + struct tcs_group *tcs; + + ret = ofnode_read_u32(dn, "qcom,tcs-offset", &offset); + if (ret) + return ret; + drv->tcs_base = drv->base + offset; + + config = readl_relaxed(drv->base + drv->regs[DRV_PRNT_CHLD_CONFIG]); + + max_tcs = config; + max_tcs &= DRV_NUM_TCS_MASK << (DRV_NUM_TCS_SHIFT * drv->id); + max_tcs = max_tcs >> (DRV_NUM_TCS_SHIFT * drv->id); + + ncpt = config & (DRV_NCPT_MASK << DRV_NCPT_SHIFT); + ncpt = ncpt >> DRV_NCPT_SHIFT; + + n = ofnode_read_u32_array(dn, "qcom,tcs-config", (u32 *)tcs_cfg, 2 * TCS_TYPE_NR); + if (n < 0) { + printf("RPMh: %s: error reading qcom,tcs-config %d\n", dev->name, n); + return n; + } + + for (i = 0; i < TCS_TYPE_NR; i++) { + if (tcs_cfg[i].n > MAX_TCS_PER_TYPE) + return -EINVAL; + } + + for (i = 0; i < TCS_TYPE_NR; i++) { + tcs = &drv->tcs[tcs_cfg[i].type]; + if (tcs->drv) + return -EINVAL; + tcs->drv = drv; + tcs->type = tcs_cfg[i].type; + tcs->num_tcs = tcs_cfg[i].n; + tcs->ncpt = ncpt; + + if (!tcs->num_tcs || tcs->type == CONTROL_TCS) + continue; + + if (st + tcs->num_tcs > max_tcs || + st + tcs->num_tcs >= BITS_PER_BYTE * sizeof(tcs->mask)) + return -EINVAL; + + tcs->mask = ((1 << tcs->num_tcs) - 1) << st; + tcs->offset = st; + st += tcs->num_tcs; + } + + drv->num_tcs = st; + + return 0; +} + +static int rpmh_rsc_probe(struct udevice *dev) +{ + ofnode dn = dev_ofnode(dev); + ofnode rmem, node; + struct rsc_drv *drv; + char drv_id[10] = {0}; + int ret; + u32 rsc_id; + + /* + * Even though RPMh doesn't directly use cmd-db, all of its children + * do. We init cmd-db here or bail out if we can't. All child devices + * can therefore safely assume that cmd-db is available. + */ + rmem = ofnode_path("/reserved-memory"); + ofnode_for_each_subnode(node, rmem) { + if (ofnode_device_is_compatible(node, "qcom,cmd-db")) + goto found; + } + + printf("Couldn't find qcom,cmd-db node!\n"); + return -ENODEV; +found: + ret = cmd_db_init(node); + if (ret < 0) { + printf("Couldn't init cmd-db!\n"); + return ret; + } + + drv = dev_get_priv(dev); + + ret = ofnode_read_u32(dn, "qcom,drv-id", &drv->id); + if (ret) + return ret; + + drv->name = ofnode_get_property(dn, "label", NULL); + if (!drv->name) + drv->name = dev->name; + + snprintf(drv_id, ARRAY_SIZE(drv_id), "drv-%d", drv->id); + drv->base = (void __iomem*)dev_read_addr_name(dev, drv_id); + if (IS_ERR(drv->base)) + return PTR_ERR(drv->base); + + rsc_id = readl_relaxed(drv->base + RSC_DRV_ID); + drv->ver.major = rsc_id & (MAJOR_VER_MASK << MAJOR_VER_SHIFT); + drv->ver.major >>= MAJOR_VER_SHIFT; + drv->ver.minor = rsc_id & (MINOR_VER_MASK << MINOR_VER_SHIFT); + drv->ver.minor >>= MINOR_VER_SHIFT; + + if (drv->ver.major == 3) { + printf("RPMh v3 not supported\n"); + return -EOPNOTSUPP; + } else { + drv->regs = rpmh_rsc_reg_offset_ver_2_7; + } + + ret = rpmh_probe_tcs_config(dev, drv); + if (ret) + return ret; + + spin_lock_init(&drv->lock); + init_waitqueue_head(&drv->tcs_wait); + bitmap_zero(drv->tcs_in_use, MAX_TCS_NR); + + /* Enable the active TCS to send requests immediately */ + writel_relaxed(drv->tcs[ACTIVE_TCS].mask, + drv->tcs_base + drv->regs[RSC_DRV_IRQ_ENABLE]); + + spin_lock_init(&drv->client.cache_lock); + INIT_LIST_HEAD(&drv->client.cache); + INIT_LIST_HEAD(&drv->client.batch_cache); + + dev_set_drvdata(dev, drv); + drv->dev = dev; + + log_debug("RPMh: %s: v%d.%d\n", dev->name, drv->ver.major, drv->ver.minor); + + return ret; +} + +static const struct udevice_id qcom_rpmh_ids[] = { + { .compatible = "qcom,rpmh-rsc" }, + { } +}; + +U_BOOT_DRIVER(qcom_rpmh_rsc) = { + .name = "qcom_rpmh_rsc", + .id = UCLASS_MISC, + .priv_auto = sizeof(struct rsc_drv), + .probe = rpmh_rsc_probe, + .bind = dm_scan_fdt_dev, + .of_match = qcom_rpmh_ids, + /* rpmh is under CLUSTER_PD which we don't support */ + .flags = DM_FLAG_DEFAULT_PD_CTRL_OFF, +}; diff --git a/drivers/soc/qcom/rpmh.c b/drivers/soc/qcom/rpmh.c new file mode 100644 index 000000000000..f00c241de373 --- /dev/null +++ b/drivers/soc/qcom/rpmh.c @@ -0,0 +1,110 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2016-2018, The Linux Foundation. All rights reserved. + */ + +#include <linux/bug.h> +#include <linux/kernel.h> +#include <linux/list.h> +#include <linux/types.h> +#include <dm/device.h> + +#include <soc/qcom/rpmh.h> + +#include "rpmh-internal.h" + +#define RPMH_TIMEOUT_MS msecs_to_jiffies(10000) + +#define DEFINE_RPMH_MSG_ONSTACK(device, s, name) \ + struct rpmh_request name = { \ + .msg = { \ + .state = s, \ + .cmds = name.cmd, \ + .num_cmds = 0, \ + }, \ + .cmd = { { 0 } }, \ + .dev = device, \ + .needs_free = false, \ + } + +#define ctrlr_to_drv(ctrlr) container_of(ctrlr, struct rsc_drv, client) + +static struct rpmh_ctrlr *get_rpmh_ctrlr(const struct udevice *dev) +{ + struct rsc_drv *drv = (struct rsc_drv *)dev_get_priv(dev->parent); + + if (!drv) { + printf("BUG: no RPMh driver for %s (parent %s)\n", dev->name, dev->parent->name); + BUG(); + } + + return &drv->client; +} + +/** + * __rpmh_write: Cache and send the RPMH request + * + * @dev: The device making the request + * @state: Active/Sleep request type + * @rpm_msg: The data that needs to be sent (cmds). + * + * Cache the RPMH request and send if the state is ACTIVE_ONLY. + * SLEEP/WAKE_ONLY requests are not sent to the controller at + * this time. Use rpmh_flush() to send them to the controller. + */ +static int __rpmh_write(const struct udevice *dev, enum rpmh_state state, + struct rpmh_request *rpm_msg) +{ + struct rpmh_ctrlr *ctrlr = get_rpmh_ctrlr(dev); + + debug("rpmh_write: %s, %d\n", dev->name, state); + + if (state != RPMH_ACTIVE_ONLY_STATE) { + printf("WARN: only ACTIVE_ONLY state supported\n"); + return -EINVAL; + } + + return rpmh_rsc_send_data(ctrlr_to_drv(ctrlr), &rpm_msg->msg); +} + +static int __fill_rpmh_msg(struct rpmh_request *req, enum rpmh_state state, + const struct tcs_cmd *cmd, u32 n) +{ + if (!cmd || !n || n > MAX_RPMH_PAYLOAD) + return -EINVAL; + + memcpy(req->cmd, cmd, n * sizeof(*cmd)); + + req->msg.state = state; + req->msg.cmds = req->cmd; + req->msg.num_cmds = n; + + debug("rpmh_msg: %d, %d cmds [first %#x/%#x]\n", state, n, cmd->addr, cmd->data); + + return 0; +} + +/** + * rpmh_write: Write a set of RPMH commands and block until response + * + * @dev: The device making the request + * @state: Active/sleep set + * @cmd: The payload data + * @n: The number of elements in @cmd + * + * May sleep. Do not call from atomic contexts. + */ +int rpmh_write(const struct udevice *dev, enum rpmh_state state, + const struct tcs_cmd *cmd, u32 n) +{ + DEFINE_RPMH_MSG_ONSTACK(dev, state, rpm_msg); + int ret; + + ret = __fill_rpmh_msg(&rpm_msg, state, cmd, n); + if (ret) + return ret; + + ret = __rpmh_write(dev, state, &rpm_msg); + + return ret; +} diff --git a/include/soc/qcom/cmd-db.h b/include/soc/qcom/cmd-db.h new file mode 100644 index 000000000000..1e22d86c66c9 --- /dev/null +++ b/include/soc/qcom/cmd-db.h @@ -0,0 +1,42 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* Copyright (c) 2016-2018, The Linux Foundation. All rights reserved. */ + +#ifndef __QCOM_COMMAND_DB_H__ +#define __QCOM_COMMAND_DB_H__ + +#include <linux/err.h> +#include <dm/device.h> + +enum cmd_db_hw_type { + CMD_DB_HW_INVALID = 0, + CMD_DB_HW_MIN = 3, + CMD_DB_HW_ARC = CMD_DB_HW_MIN, + CMD_DB_HW_VRM = 4, + CMD_DB_HW_BCM = 5, + CMD_DB_HW_MAX = CMD_DB_HW_BCM, + CMD_DB_HW_ALL = 0xff, +}; + +#if IS_ENABLED(CONFIG_QCOM_COMMAND_DB) +u32 cmd_db_read_addr(const char *resource_id); + +const void *cmd_db_read_aux_data(const char *resource_id, size_t *len); + +enum cmd_db_hw_type cmd_db_read_slave_id(const char *resource_id); + +int cmd_db_init(ofnode node); + +#else +static inline u32 cmd_db_read_addr(const char *resource_id) +{ return 0; } + +static inline const void *cmd_db_read_aux_data(const char *resource_id, size_t *len) +{ return ERR_PTR(-ENODEV); } + +static inline enum cmd_db_hw_type cmd_db_read_slave_id(const char *resource_id) +{ return -ENODEV; } + +static inline int cmd_db_ready(void) +{ return -ENODEV; } +#endif /* CONFIG_QCOM_COMMAND_DB */ +#endif /* __QCOM_COMMAND_DB_H__ */ diff --git a/include/soc/qcom/rpmh.h b/include/soc/qcom/rpmh.h new file mode 100644 index 000000000000..eb7c067cc5fd --- /dev/null +++ b/include/soc/qcom/rpmh.h @@ -0,0 +1,29 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2016-2018, The Linux Foundation. All rights reserved. + */ + +#ifndef __SOC_QCOM_RPMH_H__ +#define __SOC_QCOM_RPMH_H__ + +#include <linux/types.h> +#include <linux/errno.h> +#include <soc/qcom/tcs.h> +#include <dm/device-internal.h> + +#if IS_ENABLED(CONFIG_QCOM_RPMH) +int rpmh_write(const struct udevice *dev, enum rpmh_state state, + const struct tcs_cmd *cmd, u32 n); + +#else + +static inline int rpmh_write(const struct udevice *dev, enum rpmh_state state, + const struct tcs_cmd *cmd, u32 n) +{ return -ENODEV; } + +#endif /* CONFIG_QCOM_RPMH */ + +/* u-boot: no multithreading */ +#define rpmh_write_async(dev, state, cmd, n) rpmh_write(dev, state, cmd, n) + +#endif /* __SOC_QCOM_RPMH_H__ */ diff --git a/include/soc/qcom/tcs.h b/include/soc/qcom/tcs.h new file mode 100644 index 000000000000..c8d28b052f1d --- /dev/null +++ b/include/soc/qcom/tcs.h @@ -0,0 +1,78 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2016-2019, The Linux Foundation. All rights reserved. + */ + +#ifndef __SOC_QCOM_TCS_H__ +#define __SOC_QCOM_TCS_H__ + +#define MAX_RPMH_PAYLOAD 16 + +/** + * rpmh_state: state for the request + * + * RPMH_SLEEP_STATE: State of the resource when the processor subsystem + * is powered down. There is no client using the + * resource actively. + * RPMH_WAKE_ONLY_STATE: Resume resource state to the value previously + * requested before the processor was powered down. + * RPMH_ACTIVE_ONLY_STATE: Active or AMC mode requests. Resource state + * is aggregated immediately. + */ +enum rpmh_state { + RPMH_SLEEP_STATE, + RPMH_WAKE_ONLY_STATE, + RPMH_ACTIVE_ONLY_STATE, +}; + +/** + * struct tcs_cmd: an individual request to RPMH. + * + * @addr: the address of the resource slv_id:18:16 | offset:0:15 + * @data: the resource state request + * @wait: ensure that this command is complete before returning. + * Setting "wait" here only makes sense during rpmh_write_batch() for + * active-only transfers, this is because: + * rpmh_write() - Always waits. + * (DEFINE_RPMH_MSG_ONSTACK will set .wait_for_compl) + * rpmh_write_async() - Never waits. + * (There's no request completion callback) + */ +struct tcs_cmd { + u32 addr; + u32 data; + u32 wait; +}; + +/** + * struct tcs_request: A set of tcs_cmds sent together in a TCS + * + * @state: state for the request. + * @num_cmds: the number of @cmds in this request + * @cmds: an array of tcs_cmds + */ +struct tcs_request { + enum rpmh_state state; + u32 num_cmds; + struct tcs_cmd *cmds; +}; + +#define BCM_TCS_CMD_COMMIT_SHFT 30 +#define BCM_TCS_CMD_COMMIT_MASK 0x40000000 +#define BCM_TCS_CMD_VALID_SHFT 29 +#define BCM_TCS_CMD_VALID_MASK 0x20000000 +#define BCM_TCS_CMD_VOTE_X_SHFT 14 +#define BCM_TCS_CMD_VOTE_MASK 0x3fff +#define BCM_TCS_CMD_VOTE_Y_SHFT 0 +#define BCM_TCS_CMD_VOTE_Y_MASK 0xfffc000 + +/* Construct a Bus Clock Manager (BCM) specific TCS command */ +#define BCM_TCS_CMD(commit, valid, vote_x, vote_y) \ + (((commit) << BCM_TCS_CMD_COMMIT_SHFT) | \ + ((valid) << BCM_TCS_CMD_VALID_SHFT) | \ + ((cpu_to_le32(vote_x) & \ + BCM_TCS_CMD_VOTE_MASK) << BCM_TCS_CMD_VOTE_X_SHFT) | \ + ((cpu_to_le32(vote_y) & \ + BCM_TCS_CMD_VOTE_MASK) << BCM_TCS_CMD_VOTE_Y_SHFT)) + +#endif /* __SOC_QCOM_TCS_H__ */
<snip>
- if (drv->ver.major == 3) {
return -EOPNOTSUPP;
- } else {
I think you can safely add the v3 offsets:
==========><====================================== diff --git a/drivers/soc/qcom/rpmh-rsc.c b/drivers/soc/qcom/rpmh-rsc.c index 29fc0c2ed49..a4ff374675d 100644 --- a/drivers/soc/qcom/rpmh-rsc.c +++ b/drivers/soc/qcom/rpmh-rsc.c @@ -152,6 +152,24 @@ static u32 rpmh_rsc_reg_offset_ver_2_7[] = { [RSC_DRV_CMD_RESP_DATA] = 0x40, };
+static u32 rpmh_rsc_reg_offset_ver_3_0[] = { + [RSC_DRV_TCS_OFFSET] = 672, + [RSC_DRV_CMD_OFFSET] = 24, + [DRV_SOLVER_CONFIG] = 0x04, + [DRV_PRNT_CHLD_CONFIG] = 0x0C, + [RSC_DRV_IRQ_ENABLE] = 0x00, + [RSC_DRV_IRQ_STATUS] = 0x04, + [RSC_DRV_IRQ_CLEAR] = 0x08, + [RSC_DRV_CMD_WAIT_FOR_CMPL] = 0x20, + [RSC_DRV_CONTROL] = 0x24, + [RSC_DRV_STATUS] = 0x28, + [RSC_DRV_CMD_ENABLE] = 0x2C, + [RSC_DRV_CMD_MSGID] = 0x34, + [RSC_DRV_CMD_ADDR] = 0x38, + [RSC_DRV_CMD_DATA] = 0x3C, + [RSC_DRV_CMD_STATUS] = 0x40, + [RSC_DRV_CMD_RESP_DATA] = 0x44, +};
static inline void __iomem * tcs_reg_addr(const struct rsc_drv *drv, int reg, int tcs_id) @@ -573,10 +591,9 @@ found: drv->ver.minor = rsc_id & (MINOR_VER_MASK << MINOR_VER_SHIFT); drv->ver.minor >>= MINOR_VER_SHIFT;
- if (drv->ver.major == 3) { - printf("RPMh v3 not supported\n"); - return -ENOTSUPP; - } else + if (drv->ver.major == 3) + drv->regs = rpmh_rsc_reg_offset_ver_3_0; + else drv->regs = rpmh_rsc_reg_offset_ver_2_7;
ret = rpmh_probe_tcs_config(dev, drv); ==========><======================================
And add my: Tested-by: Neil Armstrong neil.armstrong@linaro.org # on SM8550 & SM8^%)
<snip>
Hi Caleb,
On Mon, 17 Jun 2024 at 14:02, Caleb Connolly caleb.connolly@linaro.org wrote:
help
+if SOC_QCOM
help
+config QCOM_RPMH
help
- Copyright (c) 2016-2018, 2020, The Linux Foundation. All rights reserved.
- Copyright (c) 2023, Linaro Ltd.
- struct entry_header: header for each entry in cmddb
- @id: resource's identifier
- @priority: unused
- @addr: the address of the resource
- @len: length of the data
- @offset: offset from :@data_offset, start of the data
u8 id[8];
__le32 addr;
__le16 len;
__le16 offset;
- struct rsc_hdr: resource header information
- @slv_id: id for the resource
- @header_offset: entry's header at offset from the end of the cmd_db_header
- @data_offset: entry's data at offset from the end of the cmd_db_header
- @cnt: number of entries for HW type
- @version: MSB is major, LSB is minor
- @reserved: reserved for future use.
+struct rsc_hdr {
__le16 slv_id;
__le16 data_offset;
__le16 cnt;
__le16 version;
__le16 reserved[3];
- struct cmd_db_header: The DB header information
- @version: The cmd db version
- @magic: constant expected in the database
- @header: array of resources
- @checksum: checksum for the header. Unused.
- @reserved: reserved memory
- @data: driver specific data
__le32 version;
u8 magic[4];
__le32 checksum;
__le32 reserved;
u8 data[];
- DOC: Description of the Command DB database.
- At the start of the command DB memory is the cmd_db_header structure.
- The cmd_db_header holds the version, checksum, magic key as well as an
- array for header for each slave (depicted by the rsc_header). Each h/w
- based accelerator is a 'slave' (shared resource) and has slave id indicating
- the type of accelerator. The rsc_header is the header for such individual
- slaves of a given type. The entries for each of these slaves begin at the
- rsc_hdr.header_offset. In addition each slave could have auxiliary data
- that may be needed by the driver. The data for the slave starts at the
- entry_header.offset to the location pointed to by the rsc_hdr.data_offset.
- Drivers have a stringified key to a slave/resource. They can query the slave
- information and get the slave id and the auxiliary data and the length of the
- data. Using this information, they can format the request to be sent to the
- h/w accelerator and request a resource state.
int i, j;
break;
if (eh)
*eh = ent;
if (rh)
*rh = rsc_hdr;
return -ENODEV;
- cmd_db_read_addr() - Query command db for resource id address.
- @id: resource id to query for address
- Return: resource address on success, 0 on error
- This is used to retrieve resource address based on resource
- id.
int ret;
Export symbols aren't required in U-Boot here and other instances in this patch.
- cmd_db_read_aux_data() - Query command db for aux data.
- @id: Resource to retrieve AUX Data on
- @len: size of data buffer returned
- Return: pointer to data on success, error pointer otherwise
int ret;
if (ret)
if (len)
- cmd_db_read_slave_id - Get the slave ID for a given resource address
- @id: Resource id to query the DB for version
- Return: cmd_db_hw_type enum on success, CMD_DB_HW_INVALID on error
int ret;
u32 addr;
if (ret < 0)
void __iomem *base;
return -ENOENT;
return -EINVAL;
- Copyright (c) 2016-2018, The Linux Foundation. All rights reserved.
+struct rsc_drv;
- struct tcs_group: group of Trigger Command Sets (TCS) to send state requests
- to the controller
- @drv: The controller.
- @type: Type of the TCS in this group - active, sleep, wake.
- @mask: Mask of the TCSes relative to all the TCSes in the RSC.
- @offset: Start of the TCS group relative to the TCSes in the RSC.
- @num_tcs: Number of TCSes in this type.
- @ncpt: Number of commands in each TCS.
- @req: Requests that are sent from the TCS; only used for ACTIVE_ONLY
trigger
- @slots: Indicates which of @cmd_addr are occupied; only used for
+struct tcs_group {
int type;
u32 mask;
u32 offset;
int num_tcs;
int ncpt;
- struct rpmh_request: the message to be sent to rpmh-rsc
- @msg: the request
- @cmd: the payload that will be part of the @msg
- @completion: triggered when request is done
- @dev: the device making the request
- @needs_free: check to free dynamically allocated request object
bool needs_free;
- struct rpmh_ctrlr: our representation of the controller
- @cache: the list of cached requests
- @cache_lock: synchronize access to the cache data
- @dirty: was the cache updated since flush
- @batch_cache: Cache sleep and wake requests sent as batch
bool dirty;
+struct rsc_ver {
u32 major;
u32 minor;
- struct rsc_drv: the Direct Resource Voter (DRV) of the
- Resource State Coordinator controller (RSC)
- @name: Controller identifier.
- @base: Start address of the DRV registers in this controller.
- @tcs_base: Start address of the TCS registers in this controller.
- @id: Instance id in the controller (Direct Resource Voter).
- @num_tcs: Number of TCSes in this DRV.
- @rsc_pm: CPU PM notifier for controller.
- @cpus_in_pm: Number of CPUs not in idle power collapse.
- @genpd_nb: PM Domain notifier for cluster genpd notifications.
- @tcs: TCS groups.
- @tcs_in_use: S/W state of the TCS; only set for ACTIVE_ONLY
- @lock: Synchronize state of the controller. If RPMH's cache
cache_lock.
- @tcs_wait: Wait queue used to wait for @tcs_in_use to free up a
slot
- @client: Handle to the DRV's client.
- @dev: RSC device.
+struct rsc_drv {
const char *name;
void __iomem *base;
int id;
int num_tcs;
struct rsc_ver ver;
u32 *regs;
+enum {
RSC_DRV_TCS_OFFSET,
RSC_DRV_CMD_OFFSET,
DRV_SOLVER_CONFIG,
RSC_DRV_IRQ_ENABLE,
RSC_DRV_IRQ_STATUS,
RSC_DRV_IRQ_CLEAR,
RSC_DRV_CONTROL,
RSC_DRV_STATUS,
RSC_DRV_CMD_ENABLE,
RSC_DRV_CMD_MSGID,
RSC_DRV_CMD_ADDR,
RSC_DRV_CMD_DATA,
RSC_DRV_CMD_STATUS,
- Here's a high level overview of how all the registers in RPMH work
- together:
- be used to find overall configuration of the hardware
- (DRV_PRNT_CHLD_CONFIG). Also found within the rpmh-rsc register
- space are all the TCS blocks. The offset of the TCS blocks is
- specified in the device tree by "qcom,tcs-offset" and used to
- compute tcs_base.
- specified by the device tree as "qcom,tcs-config".
- Note that though address space is reserved for 16 commands, fewer
- might be present. See ncpt (num cmds per TCS).
- Here's a picture:
- |RSC |
- | ctrl |
- | Drvs: |
- | |DRV0 | |
- | | ctrl/config | |
- | | IRQ | |
- | | TCSes: | |
- | | |TCS0 | | | | | | | | | | | | | | |
- | | | ctrl | 0| 1| 2| 3| 4| 5| .| .| .| .|14|15| | |
- | | |TCS1 | | | | | | | | | | | | | | |
- | | |TCS2 | | | | | | | | | | | | | | |
- | |DRV1 | |
- | | (same as DRV0) | |
u32 data)
tcs_id, reg, data);
u32 data)
int i;
tcs_id, reg, data);
writel(data, addr);
return;
udelay(1);
Can we rather use readx_poll_sleep_timeout() here instead?
data, tcs_id, reg);
- tcs_invalidate() - Invalidate all TCSes of the given type (sleep or wake).
- @drv: The RSC controller.
- @type: SLEEP_TCS or WAKE_TCS
- This will clear the "slots" variable of the given tcs_group and also
- tell the hardware to forget about all entries.
- The caller must ensure that no other RPMH actions are happening when this
- function is called, since otherwise the device may immediately become
- used again even before this function exits.
int m;
return;
- rpmh_rsc_invalidate() - Invalidate sleep and wake TCSes.
- rpmh_rsc_wait_for_resp() - Spin until we get a response from the rpmh
- @tcs_id: The global ID of this TCS.
- This is for ACTIVE_ONLY transfers (which are the only ones we support in
- u-boot). As we don't support interrupts, we just spin on the IRQ_STATUS
- register until the bit is set to confirm that the TCS TX is done.
u32 reg;
int i;
break;
udelay(1);
return -ETIMEDOUT;
- __tcs_buffer_write() - Write to TCS hardware from a request; don't trigger.
- @cmd_id: The index within the TCS to start writing.
- @msg: The message we want to send, which will contain several addr/data
- This is used for all types of transfers (active, sleep, and wake).
u32 msgid;
u32 cmd_enable = 0;
int i, j;
msgid = cmd_msgid;
- __tcs_set_trigger() - Start xfer on a TCS or unset trigger on a borrowed TCS
- @trigger: If true then untrigger/retrigger. If false then just untrigger.
- In the normal case we only ever call with "trigger=true" to start a
- transfer. That will un-trigger/disable the TCS from the last transfer
- then trigger/enable for this transfer.
- If we borrowed a wake TCS for an active-only transfer we'll also call
- this function with "trigger=false" to just do the un-trigger/disable
- before using the TCS for wake purposes again.
- Note that the AP is only in charge of triggering active-only transfers.
- The AP never triggers sleep/wake values using this function.
u32 enable;
if (trigger) {
- get_tcs_for_msg() - Get the tcs_group used to send the given message.
- @msg: The message we want to send.
- This is normally pretty straightforward except if we are trying to send
- an ACTIVE_ONLY message but don't have any active_only TCSes.
- Return: A pointer to a tcs_group or an ERR_PTR.
- rpmh_rsc_send_data() - Write / trigger active-only message.
- @msg: The data to be sent.
- NOTES:
- function don't make sense for sleep/wake cases.
- try to share. If there are none available we'll wait indefinitely
- for a free one.
- data to be programmed into the RPMh. See rpmh_tx_done() which will
- be called when the transfer is fully complete.
- is busy doing someone else's transfer we need that transfer to fully
- finish so that we can have the hardware, and to fully finish it needs
- the interrupt handler to run. If the interrupts is set to run on the
- active CPU this can never happen if interrupts are disabled.
- Return: 0 on success, -EINVAL on error.
int tcs_id;
if (IS_ERR(tcs))
Locks aren't needed in U-Boot, can be dropped here and other places.
u32 type;
u32 n;
if (ret)
return ret;
max_tcs = config;
if (n < 0) {
return n;
return -EINVAL;
if (tcs->drv)
return -EINVAL;
tcs->drv = drv;
tcs->ncpt = ncpt;
continue;
return -EINVAL;
tcs->offset = st;
st += tcs->num_tcs;
drv->num_tcs = st;
ofnode rmem, node;
int ret;
u32 rsc_id;
goto found;
return -ENODEV;
+found:
if (ret < 0) {
return ret;
if (ret)
return ret;
if (!drv->name)
return -EOPNOTSUPP;
} else {
if (ret)
return ret;
Similarly waitqueue should be dropped too.
-Sumit
drv->dev = dev;
return ret;
.id = UCLASS_MISC,
.msg = { \
.state = s, \
.cmds = name.cmd, \
.num_cmds = 0, \
.cmd = { { 0 } }, \
.dev = device, \
if (!drv) {
BUG();
- __rpmh_write: Cache and send the RPMH request
- @dev: The device making the request
- @state: Active/Sleep request type
- @rpm_msg: The data that needs to be sent (cmds).
- Cache the RPMH request and send if the state is ACTIVE_ONLY.
- SLEEP/WAKE_ONLY requests are not sent to the controller at
- this time. Use rpmh_flush() to send them to the controller.
return -EINVAL;
return -EINVAL;
- rpmh_write: Write a set of RPMH commands and block until response
- @state: Active/sleep set
- @cmd: The payload data
- @n: The number of elements in @cmd
- May sleep. Do not call from atomic contexts.
int ret;
if (ret)
return ret;
return ret;
CMD_DB_HW_MIN = 3,
CMD_DB_HW_VRM = 4,
CMD_DB_HW_BCM = 5,
+#else
- Copyright (c) 2016-2019, The Linux Foundation. All rights reserved.
- rpmh_state: state for the request
- RPMH_SLEEP_STATE: State of the resource when the processor subsystem
resource actively.
- RPMH_WAKE_ONLY_STATE: Resume resource state to the value previously
- RPMH_ACTIVE_ONLY_STATE: Active or AMC mode requests. Resource state
+enum rpmh_state {
RPMH_SLEEP_STATE,
- struct tcs_cmd: an individual request to RPMH.
- @addr: the address of the resource slv_id:18:16 | offset:0:15
- @data: the resource state request
- @wait: ensure that this command is complete before returning.
+struct tcs_cmd {
u32 addr;
u32 data;
u32 wait;
- struct tcs_request: A set of tcs_cmds sent together in a TCS
- @state: state for the request.
- @num_cmds: the number of @cmds in this request
- @cmds: an array of tcs_cmds
u32 num_cmds;
-- 2.45.0
Hi Sumit,
Sorry for the late response.
In general, I'd rather keep this port closer to the Linux original, so that future cherry-picking of new features and fixes is easier. This is quite standard practice in U-Boot (and why the compatibility macro's are included in the first place).
Otherwise, we end up with our own quite different implementation, with the higher maintenance burden that comes with it.
This port doesn't do a perfect job at keeping close to upstream, but still I don't think we should stray further without a good justification.
Kind regards,
return;
udelay(1);
break;
udelay(1);
-Sumit
Hi Caleb,
On Mon, 8 Jul 2024 at 16:13, Caleb Connolly caleb.connolly@linaro.org wrote:
Hi Sumit,
As per your cover letter:
Quote: "These drivers were originally taken from Linux, however they have been heavily modified and simplified for U-Boot. Since the original Linux drivers contained heavy optimisations related to multithreading and asynchronous probing, as well as support for idle and suspend states which we don't need to deal with here."
This made me think the driver is nowhere close to Linux driver functionality wise. Also, the commit message doesn't say which Linux commit this driver is influenced from. I am not really sure if cherry-picking will be straight forward. IMHO, if we are heavily modifying a driver port for U-Boot then it should be done properly as per U-Boot needs. A middle ground approach which you have taken is only going to lead to confusion and rather negatively impact maintenance.
-Sumit
Kind regards,
return;
udelay(1);
break;
udelay(1);
-Sumit
-- // Caleb (they/them)
Hi Caleb,
<snip>
- const struct rsc_hdr *rsc_hdr;
- const struct entry_header *ent;
- int i, j;
- u8 query[sizeof(ent->id)] __nonstring;
- strncpy(query, id, sizeof(query));
- for (i = 0; i < MAX_SLV_ID; i++) {
break;
I had to change to: if (strncmp(ent->id, query, sizeof(ent->id)) == 0) { otherwise I get: Failed to read RPMh address for bobb1 ...
on SM8550 and SM8650.
Linux uses memcmp, but it pads the buffer with strtomem_pad(), strncpy doesn't seem to do the padding. Neil
if (eh)
*eh = ent;
if (rh)
*rh = rsc_hdr;
- return -ENODEV;
<snip>
Add a regulator driver for controlling the PMIC rails via the RPMh on Qualcomm platforms. This driver is restricted to only know about rails which are required by u-boot.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/power/regulator/Kconfig | 8 + drivers/power/regulator/Makefile | 1 + drivers/power/regulator/qcom-rpmh-regulator.c | 534 ++++++++++++++++++++++++++ 3 files changed, 543 insertions(+)
diff --git a/drivers/power/regulator/Kconfig b/drivers/power/regulator/Kconfig index 102ec7bc5f89..bc061c20d75e 100644 --- a/drivers/power/regulator/Kconfig +++ b/drivers/power/regulator/Kconfig @@ -215,8 +215,16 @@ config DM_REGULATOR_GPIO This config enables implementation of driver-model regulator uclass features for gpio regulators. The driver implements get/set for voltage value.
+config DM_REGULATOR_QCOM_RPMH + bool "Enable driver model for Qualcomm RPMh regulator" + depends on DM_REGULATOR && QCOM_RPMH + ---help--- + Enable support for the Qualcomm RPMh regulator. The driver + implements get/set api for a limited set of regulators used + by u-boot. + config SPL_DM_REGULATOR_GPIO bool "Enable Driver Model for GPIO REGULATOR in SPL" depends on DM_REGULATOR_GPIO && SPL_GPIO select SPL_DM_REGULATOR_COMMON diff --git a/drivers/power/regulator/Makefile b/drivers/power/regulator/Makefile index f79932d83307..56a527612b74 100644 --- a/drivers/power/regulator/Makefile +++ b/drivers/power/regulator/Makefile @@ -20,8 +20,9 @@ obj-$(CONFIG_$(SPL_)REGULATOR_PWM) += pwm_regulator.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_FAN53555) += fan53555.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_COMMON) += regulator_common.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_FIXED) += fixed.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_GPIO) += gpio-regulator.o +obj-$(CONFIG_DM_REGULATOR_QCOM_RPMH) += qcom-rpmh-regulator.o obj-$(CONFIG_$(SPL_TPL_)REGULATOR_RK8XX) += rk8xx.o obj-$(CONFIG_DM_REGULATOR_S2MPS11) += s2mps11_regulator.o obj-$(CONFIG_REGULATOR_S5M8767) += s5m8767.o obj-$(CONFIG_DM_REGULATOR_SANDBOX) += sandbox.o diff --git a/drivers/power/regulator/qcom-rpmh-regulator.c b/drivers/power/regulator/qcom-rpmh-regulator.c new file mode 100644 index 000000000000..51d8d493a3d5 --- /dev/null +++ b/drivers/power/regulator/qcom-rpmh-regulator.c @@ -0,0 +1,534 @@ +// SPDX-License-Identifier: GPL-2.0 +// Copyright (c) 2018-2021, The Linux Foundation. All rights reserved. + +#include <linux/err.h> +#include <dm/device_compat.h> +#include <dm/device.h> +#include <dm/devres.h> +#include <dm/lists.h> +#include <power/regulator.h> +#include <log.h> + +#include <soc/qcom/cmd-db.h> +#include <soc/qcom/rpmh.h> + +#include <dt-bindings/regulator/qcom,rpmh-regulator.h> + +/** + * enum rpmh_regulator_type - supported RPMh accelerator types + * @VRM: RPMh VRM accelerator which supports voting on enable, voltage, + * and mode of LDO, SMPS, and BOB type PMIC regulators. + * @XOB: RPMh XOB accelerator which supports voting on the enable state + * of PMIC regulators. + */ +enum rpmh_regulator_type { + VRM, + XOB, +}; + +enum rpmh_regulator_mode { + REGULATOR_MODE_RETENTION, + REGULATOR_MODE_LPM, + REGULATOR_MODE_AUTO, + REGULATOR_MODE_HPM, +}; + +#define RPMH_REGULATOR_REG_VRM_VOLTAGE 0x0 +#define RPMH_REGULATOR_REG_ENABLE 0x4 +#define RPMH_REGULATOR_REG_VRM_MODE 0x8 + +#define PMIC4_LDO_MODE_RETENTION 4 +#define PMIC4_LDO_MODE_LPM 5 +#define PMIC4_LDO_MODE_HPM 7 + +#define PMIC4_SMPS_MODE_RETENTION 4 +#define PMIC4_SMPS_MODE_PFM 5 +#define PMIC4_SMPS_MODE_AUTO 6 +#define PMIC4_SMPS_MODE_PWM 7 + +#define PMIC4_BOB_MODE_PASS 0 +#define PMIC4_BOB_MODE_PFM 1 +#define PMIC4_BOB_MODE_AUTO 2 +#define PMIC4_BOB_MODE_PWM 3 + +#define PMIC5_LDO_MODE_RETENTION 3 +#define PMIC5_LDO_MODE_LPM 4 +#define PMIC5_LDO_MODE_HPM 7 + +#define PMIC5_SMPS_MODE_RETENTION 3 +#define PMIC5_SMPS_MODE_PFM 4 +#define PMIC5_SMPS_MODE_AUTO 6 +#define PMIC5_SMPS_MODE_PWM 7 + +#define PMIC5_BOB_MODE_PASS 2 +#define PMIC5_BOB_MODE_PFM 4 +#define PMIC5_BOB_MODE_AUTO 6 +#define PMIC5_BOB_MODE_PWM 7 + +/** + * struct linear_range - table of selector - value pairs + * + * Define a lookup-table for range of values. Intended to help when looking + * for a register value matching certaing physical measure (like voltage). + * Usable when increment of one in register always results a constant increment + * of the physical measure (like voltage). + * + * @min: Lowest value in range + * @min_sel: Lowest selector for range + * @max_sel: Highest selector for range + * @step: Value step size + */ +struct linear_range { + unsigned int min; + unsigned int min_sel; + unsigned int max_sel; + unsigned int step; +}; + +/* Initialize struct linear_range for regulators */ +#define REGULATOR_LINEAR_RANGE(_min_uV, _min_sel, _max_sel, _step_uV) \ +{ \ + .min = _min_uV, \ + .min_sel = _min_sel, \ + .max_sel = _max_sel, \ + .step = _step_uV, \ +} + +/** + * struct rpmh_vreg_hw_data - RPMh regulator hardware configurations + * @regulator_type: RPMh accelerator type used to manage this + * regulator + * @ops: Pointer to regulator ops callback structure + * @voltage_range: The single range of voltages supported by this + * PMIC regulator type + * @n_voltages: The number of unique voltage set points defined + * by voltage_range + * @hpm_min_load_uA: Minimum load current in microamps that requires + * high power mode (HPM) operation. This is used + * for LDO hardware type regulators only. + * @pmic_mode_map: Array indexed by regulator framework mode + * containing PMIC hardware modes. Must be large + * enough to index all framework modes supported + * by this regulator hardware type. + * @of_map_mode: Maps an RPMH_REGULATOR_MODE_* mode value defined + * in device tree to a regulator framework mode + */ +struct rpmh_vreg_hw_data { + enum rpmh_regulator_type regulator_type; + const struct dm_regulator_ops *ops; + struct linear_range voltage_range; + int n_voltages; + int hpm_min_load_uA; + struct dm_regulator_mode *pmic_mode_map; + int n_modes; + unsigned int (*of_map_mode)(unsigned int mode); +}; + +/** + * struct rpmh_vreg - individual RPMh regulator data structure encapsulating a + * single regulator device + * @dev: Device pointer for the top-level PMIC RPMh + * regulator parent device. This is used as a + * handle in RPMh write requests. + * @addr: Base address of the regulator resource within + * an RPMh accelerator + * @rdesc: Regulator descriptor + * @hw_data: PMIC regulator configuration data for this RPMh + * regulator + * @always_wait_for_ack: Boolean flag indicating if a request must always + * wait for an ACK from RPMh before continuing even + * if it corresponds to a strictly lower power + * state (e.g. enabled --> disabled). + * @enabled: Flag indicating if the regulator is enabled or + * not + * @bypassed: Boolean indicating if the regulator is in + * bypass (pass-through) mode or not. This is + * only used by BOB rpmh-regulator resources. + * @uv: Selector used for get_voltage_sel() and + * set_value() callbacks + * @mode: RPMh VRM regulator current framework mode + */ +struct rpmh_vreg { + struct udevice *dev; + u32 addr; + const struct rpmh_vreg_hw_data *hw_data; + bool always_wait_for_ack; + + int enabled; + bool bypassed; + int uv; + int mode; +}; + +/** + * struct rpmh_vreg_init_data - initialization data for an RPMh regulator + * @name: Name for the regulator which also corresponds + * to the device tree subnode name of the regulator + * @resource_name: RPMh regulator resource name format string. + * This must include exactly one field: '%s' which + * is filled at run-time with the PMIC ID provided + * by device tree property qcom,pmic-id. Example: + * "ldo%s1" for RPMh resource "ldoa1". + * @supply_name: Parent supply regulator name + * @hw_data: Configuration data for this PMIC regulator type + */ +struct rpmh_vreg_init_data { + const char *name; + const char *resource_name; + const char *supply_name; + const struct rpmh_vreg_hw_data *hw_data; +}; + +/** + * rpmh_regulator_send_request() - send the request to RPMh + * @vreg: Pointer to the RPMh regulator + * @cmd: Pointer to the RPMh command to send + * @wait_for_ack: Boolean indicating if execution must wait until the + * request has been acknowledged as complete + * + * Return: 0 on success, errno on failure + */ +static int rpmh_regulator_send_request(struct rpmh_vreg *vreg, + struct tcs_cmd *cmd, bool wait_for_ack) +{ + int ret; + + if (wait_for_ack || vreg->always_wait_for_ack) + ret = rpmh_write(vreg->dev->parent, RPMH_ACTIVE_ONLY_STATE, cmd, 1); + else + ret = rpmh_write_async(vreg->dev->parent, RPMH_ACTIVE_ONLY_STATE, cmd, 1); + + return ret; +} + +static int _rpmh_regulator_vrm_set_value(struct udevice *rdev, + int uv, bool wait_for_ack) +{ + struct rpmh_vreg *vreg = dev_get_priv(rdev); + struct tcs_cmd cmd = { + .addr = vreg->addr + RPMH_REGULATOR_REG_VRM_VOLTAGE, + }; + int ret; + + /* VRM voltage control register is set with voltage in millivolts. */ + uv = (uv / vreg->hw_data->voltage_range.step) * + (vreg->hw_data->voltage_range.step / 1000); + cmd.data = uv; // XXX: CHECKME + + ret = rpmh_regulator_send_request(vreg, &cmd, wait_for_ack); + if (!ret) + vreg->uv = uv; + + return ret; +} + +static int rpmh_regulator_vrm_set_value(struct udevice *rdev, + int uv) +{ + struct rpmh_vreg *vreg = dev_get_priv(rdev); + + debug("%s: set_value %d (current %d)\n", rdev->name, uv, vreg->uv); + + if (vreg->enabled == -EINVAL) { + /* + * Cache the voltage and send it later when the regulator is + * enabled or disabled. + */ + vreg->uv = uv; + return 0; + } + + return _rpmh_regulator_vrm_set_value(rdev, uv, + uv > vreg->uv); +} + +static int rpmh_regulator_vrm_get_value(struct udevice *rdev) +{ + struct rpmh_vreg *vreg = dev_get_priv(rdev); + + debug("%s: get_value %d\n", rdev->name, vreg->uv); + + return vreg->uv; +} + +static int rpmh_regulator_is_enabled(struct udevice *rdev) +{ + struct rpmh_vreg *vreg = dev_get_priv(rdev); + + debug("%s: is_enabled %d\n", rdev->name, vreg->enabled); + + return vreg->enabled > 0; +} + +static int rpmh_regulator_set_enable_state(struct udevice *rdev, + bool enable) +{ + struct rpmh_vreg *vreg = dev_get_priv(rdev); + struct tcs_cmd cmd = { + .addr = vreg->addr + RPMH_REGULATOR_REG_ENABLE, + .data = enable, + }; + int ret; + + debug("%s: set_enable %d (current %d)\n", rdev->name, enable, + vreg->enabled); + + if (vreg->enabled == -EINVAL && + vreg->uv != -ENOTRECOVERABLE) { + ret = _rpmh_regulator_vrm_set_value(rdev, + vreg->uv, true); + if (ret < 0) + return ret; + } + + ret = rpmh_regulator_send_request(vreg, &cmd, enable); + if (!ret) + vreg->enabled = enable; + + return ret; +} + +static int rpmh_regulator_vrm_set_mode_bypass(struct rpmh_vreg *vreg, + unsigned int mode, bool bypassed) +{ + struct tcs_cmd cmd = { + .addr = vreg->addr + RPMH_REGULATOR_REG_VRM_MODE, + }; + struct dm_regulator_mode *pmic_mode; + int i; + + if (mode > REGULATOR_MODE_HPM) + return -EINVAL; + + for (i = 0; i < vreg->hw_data->n_modes; i++) { + pmic_mode = &vreg->hw_data->pmic_mode_map[i]; + if (pmic_mode->id == mode) + break; + } + if (pmic_mode->id != mode) { + printf("Invalid mode %d\n", mode); + return -EINVAL; + } + + if (bypassed) + cmd.data = PMIC4_BOB_MODE_PASS; + else + cmd.data = pmic_mode->id; + + return rpmh_regulator_send_request(vreg, &cmd, true); +} + +static int rpmh_regulator_vrm_set_mode(struct udevice *rdev, + int mode) +{ + struct rpmh_vreg *vreg = dev_get_priv(rdev); + int ret; + + debug("%s: set_mode %d (current %d)\n", rdev->name, mode, vreg->mode); + + if (mode == vreg->mode) + return 0; + + ret = rpmh_regulator_vrm_set_mode_bypass(vreg, mode, vreg->bypassed); + if (!ret) + vreg->mode = mode; + + return ret; +} + +static int rpmh_regulator_vrm_get_mode(struct udevice *rdev) +{ + struct rpmh_vreg *vreg = dev_get_priv(rdev); + + debug("%s: get_mode %d\n", rdev->name, vreg->mode); + + return vreg->mode; +} + +static const struct dm_regulator_ops rpmh_regulator_vrm_drms_ops = { + .get_value = rpmh_regulator_vrm_get_value, + .set_value = rpmh_regulator_vrm_set_value, + .set_enable = rpmh_regulator_set_enable_state, + .get_enable = rpmh_regulator_is_enabled, + .set_mode = rpmh_regulator_vrm_set_mode, + .get_mode = rpmh_regulator_vrm_get_mode, +}; + +static struct dm_regulator_mode pmic_mode_map_pmic5_ldo[] = { + { + .id = REGULATOR_MODE_RETENTION, + .register_value = PMIC5_LDO_MODE_RETENTION, + .name = "PMIC5_LDO_MODE_RETENTION" + }, { + .id = REGULATOR_MODE_LPM, + .register_value = PMIC5_LDO_MODE_LPM, + .name = "PMIC5_LDO_MODE_LPM" + }, { + .id = REGULATOR_MODE_HPM, + .register_value = PMIC5_LDO_MODE_HPM, + .name = "PMIC5_LDO_MODE_HPM" + }, +}; + +static const struct rpmh_vreg_hw_data pmic5_pldo_lv = { + .regulator_type = VRM, + .ops = &rpmh_regulator_vrm_drms_ops, + .voltage_range = REGULATOR_LINEAR_RANGE(1504000, 0, 62, 8000), + .n_voltages = 63, + .hpm_min_load_uA = 10000, + .pmic_mode_map = pmic_mode_map_pmic5_ldo, +}; + +static const struct rpmh_vreg_hw_data pmic5_pldo = { + .regulator_type = VRM, + .ops = &rpmh_regulator_vrm_drms_ops, + .voltage_range = REGULATOR_LINEAR_RANGE(1504000, 0, 255, 8000), + .n_voltages = 256, + .hpm_min_load_uA = 10000, + .pmic_mode_map = pmic_mode_map_pmic5_ldo, + .n_modes = ARRAY_SIZE(pmic_mode_map_pmic5_ldo), +}; + +#define RPMH_VREG(_name, _resource_name, _hw_data, _supply_name) \ +{ \ + .name = _name, \ + .resource_name = _resource_name, \ + .hw_data = _hw_data, \ + .supply_name = _supply_name, \ +} + +static const struct rpmh_vreg_init_data pm8150_vreg_data[] = { + RPMH_VREG("ldo13", "ldo%s13", &pmic5_pldo, "vdd-l13-l16-l17"), +}; + +static const struct rpmh_vreg_init_data pm8150l_vreg_data[] = { + RPMH_VREG("ldo1", "ldo%s1", &pmic5_pldo_lv, "vdd-l1-l8"), + RPMH_VREG("ldo11", "ldo%s11", &pmic5_pldo, "vdd-l7-l11"), + {} +}; + +/* probe an individual regulator */ +static int rpmh_regulator_probe(struct udevice *dev) +{ + const struct rpmh_vreg_init_data *init_data; + struct rpmh_vreg *priv; + struct dm_regulator_uclass_plat *plat_data; + + init_data = (const struct rpmh_vreg_init_data *)dev_get_driver_data(dev); + priv = dev_get_priv(dev); + plat_data = dev_get_uclass_plat(dev); + + priv->dev = dev; + priv->addr = cmd_db_read_addr(dev->name); + if (!priv->addr) { + printf("Failed to read RPMh address for %s\n", dev->name); + return -ENODEV; + } + + priv->hw_data = init_data->hw_data; + priv->enabled = -EINVAL; + priv->uv = -ENOTRECOVERABLE; + if (ofnode_read_u32(dev_ofnode(dev), "regulator-initial-mode", &priv->mode)) + priv->mode = -EINVAL; + + // handle stepping + // almost there!!! + plat_data->mode = priv->hw_data->pmic_mode_map; + plat_data->mode_count = priv->hw_data->n_modes; + + return 0; +} + +/* for non-drm, xob, or bypass regulators add additional driver definitions */ +U_BOOT_DRIVER(rpmh_regulator_drm) = { + .name = "rpmh_regulator_drm", + .id = UCLASS_REGULATOR, + .probe = rpmh_regulator_probe, + .priv_auto = sizeof(struct rpmh_vreg), + .ops = &rpmh_regulator_vrm_drms_ops, +}; + +/* This driver intentionally only supports a subset of the available regulators. + * This function checks to see if a given regulator node in DT matches a regulator + * defined in the driver. + */ +static const struct rpmh_vreg_init_data * +vreg_get_init_data(const struct rpmh_vreg_init_data *init_data, ofnode node) +{ + const struct rpmh_vreg_init_data *data; + + for (data = init_data; data->name; data++) { + if (!strcmp(data->name, ofnode_get_name(node))) + return data; + } + + return NULL; +} + +static int rpmh_regulators_bind(struct udevice *dev) +{ + const struct rpmh_vreg_init_data *init_data, *data; + const char *pmic_id; + char *name; + struct driver *drv; + ofnode node; + int ret; + size_t namelen; + + init_data = (const struct rpmh_vreg_init_data *)dev_get_driver_data(dev); + if (!init_data) { + printf("No RPMh regulator init data\n"); + return -ENODEV; + } + + pmic_id = ofnode_read_string(dev_ofnode(dev), "qcom,pmic-id"); + if (!pmic_id) { + printf("No PMIC ID\n"); + return -ENODEV; + } + + drv = lists_driver_lookup_name("rpmh_regulator_drm"); + + ofnode_for_each_subnode(node, dev_ofnode(dev)) { + data = vreg_get_init_data(init_data, node); + if (!data) + continue; + + /* %s is replaced with pmic_id, so subtract 2, then add 1 for the null terminator */ + namelen = strlen(data->resource_name) + strlen(pmic_id) - 1; + name = devm_kzalloc(dev, namelen, GFP_KERNEL); + ret = snprintf(name, namelen, data->resource_name, pmic_id); + if (ret < 0 || ret >= namelen) { + printf("Failed to create RPMh regulator name\n"); + return -ENOMEM; + } + + ret = device_bind_with_driver_data(dev, drv, name, (ulong)data, + node, NULL); + } + + return 0; +} + +static const struct udevice_id rpmh_regulator_ids[] = { + { + .compatible = "qcom,pm8150-rpmh-regulators", + .data = (ulong)pm8150_vreg_data, + }, + { + .compatible = "qcom,pm8150l-rpmh-regulators", + .data = (ulong)pm8150l_vreg_data, + }, + { /* sentinal */ }, +}; + +/* Driver for a 'bank' of regulators. This creates devices for each + * individual regulator + */ +U_BOOT_DRIVER(rpmh_regulators) = { + .name = "rpmh_regulators", + .id = UCLASS_MISC, + .bind = rpmh_regulators_bind, + .of_match = rpmh_regulator_ids, + .ops = &rpmh_regulator_vrm_drms_ops, +};
- bool "Enable driver model for Qualcomm RPMh regulator"
- depends on DM_REGULATOR && QCOM_RPMH
- ---help---
by u-boot.
- config SPL_DM_REGULATOR_GPIO bool "Enable Driver Model for GPIO REGULATOR in SPL" depends on DM_REGULATOR_GPIO && SPL_GPIO select SPL_DM_REGULATOR_COMMON
- enum rpmh_regulator_type - supported RPMh accelerator types
- @VRM: RPMh VRM accelerator which supports voting on enable, voltage,
- @XOB: RPMh XOB accelerator which supports voting on the enable state
of PMIC regulators.
- VRM,
- XOB,
- REGULATOR_MODE_RETENTION,
- REGULATOR_MODE_LPM,
- REGULATOR_MODE_AUTO,
- REGULATOR_MODE_HPM,
- struct linear_range - table of selector - value pairs
- Define a lookup-table for range of values. Intended to help when looking
- for a register value matching certaing physical measure (like voltage).
- Usable when increment of one in register always results a constant increment
- of the physical measure (like voltage).
- @min: Lowest value in range
- @min_sel: Lowest selector for range
- @max_sel: Highest selector for range
- @step: Value step size
- unsigned int min;
- unsigned int min_sel;
- unsigned int max_sel;
- unsigned int step;
- .min = _min_uV, \
- .min_sel = _min_sel, \
- .max_sel = _max_sel, \
- .step = _step_uV, \
- struct rpmh_vreg_hw_data - RPMh regulator hardware configurations
- @regulator_type: RPMh accelerator type used to manage this
regulator
- @ops: Pointer to regulator ops callback structure
- @voltage_range: The single range of voltages supported by this
PMIC regulator type
- @n_voltages: The number of unique voltage set points defined
by voltage_range
- @hpm_min_load_uA: Minimum load current in microamps that requires
- @pmic_mode_map: Array indexed by regulator framework mode
- @of_map_mode: Maps an RPMH_REGULATOR_MODE_* mode value defined
- enum rpmh_regulator_type regulator_type;
- const struct dm_regulator_ops *ops;
- struct linear_range voltage_range;
- int n_voltages;
- int hpm_min_load_uA;
- struct dm_regulator_mode *pmic_mode_map;
- int n_modes;
- unsigned int (*of_map_mode)(unsigned int mode);
- struct rpmh_vreg - individual RPMh regulator data structure encapsulating a
- @dev: Device pointer for the top-level PMIC RPMh
- @addr: Base address of the regulator resource within
an RPMh accelerator
- @rdesc: Regulator descriptor
- @hw_data: PMIC regulator configuration data for this RPMh
regulator
- @always_wait_for_ack: Boolean flag indicating if a request must always
- @enabled: Flag indicating if the regulator is enabled or
not
- @bypassed: Boolean indicating if the regulator is in
- @uv: Selector used for get_voltage_sel() and
- @mode: RPMh VRM regulator current framework mode
+struct rpmh_vreg {
- struct udevice *dev;
- u32 addr;
- const struct rpmh_vreg_hw_data *hw_data;
- bool always_wait_for_ack;
- int enabled;
- bool bypassed;
- int uv;
- int mode;
- struct rpmh_vreg_init_data - initialization data for an RPMh regulator
- @name: Name for the regulator which also corresponds
- @resource_name: RPMh regulator resource name format string.
- @supply_name: Parent supply regulator name
- @hw_data: Configuration data for this PMIC regulator type
- const char *name;
- const char *resource_name;
- const char *supply_name;
- rpmh_regulator_send_request() - send the request to RPMh
- @vreg: Pointer to the RPMh regulator
- @cmd: Pointer to the RPMh command to send
- @wait_for_ack: Boolean indicating if execution must wait until the
- Return: 0 on success, errno on failure
- int ret;
- if (wait_for_ack || vreg->always_wait_for_ack)
- else
- return ret;
- struct rpmh_vreg *vreg = dev_get_priv(rdev);
- struct tcs_cmd cmd = {
- int ret;
- /* VRM voltage control register is set with voltage in millivolts. */
- uv = (uv / vreg->hw_data->voltage_range.step) *
- cmd.data = uv; // XXX: CHECKME
While adding support for the *8550* regulators, I inspire myself from the Linux regulator_list_voltage_linear_range() and it gave me much better results:
``` unsigned int selector = (uv - vreg->hw_data->voltage_range.min) / vreg->hw_data->voltage_range.step; cmd.data = DIV_ROUND_UP(vreg->hw_data->voltage_range.min + selector * vreg->hw_data->voltage_range.step, 1000); vreg->uv = cmd.data * 1000; ```
Neil
- ret = rpmh_regulator_send_request(vreg, &cmd, wait_for_ack);
- if (!ret)
vreg->uv = uv;
- return ret;
int uv)
- debug("%s: set_value %d (current %d)\n", rdev->name, uv, vreg->uv);
- if (vreg->enabled == -EINVAL) {
vreg->uv = uv;
- return _rpmh_regulator_vrm_set_value(rdev, uv,
uv > vreg->uv);
- debug("%s: get_value %d\n", rdev->name, vreg->uv);
- return vreg->uv;
- debug("%s: is_enabled %d\n", rdev->name, vreg->enabled);
- return vreg->enabled > 0;
bool enable)
.data = enable,
- int ret;
- debug("%s: set_enable %d (current %d)\n", rdev->name, enable,
vreg->enabled);
- if (vreg->enabled == -EINVAL &&
vreg->uv, true);
if (ret < 0)
return ret;
- ret = rpmh_regulator_send_request(vreg, &cmd, enable);
- if (!ret)
- return ret;
- struct dm_regulator_mode *pmic_mode;
- int i;
- if (mode > REGULATOR_MODE_HPM)
return -EINVAL;
- for (i = 0; i < vreg->hw_data->n_modes; i++) {
break;
- if (pmic_mode->id != mode) {
return -EINVAL;
- if (bypassed)
- else
- return rpmh_regulator_send_request(vreg, &cmd, true);
int mode)
- int ret;
- debug("%s: set_mode %d (current %d)\n", rdev->name, mode, vreg->mode);
- if (mode == vreg->mode)
- ret = rpmh_regulator_vrm_set_mode_bypass(vreg, mode, vreg->bypassed);
- if (!ret)
vreg->mode = mode;
- return ret;
- debug("%s: get_mode %d\n", rdev->name, vreg->mode);
- return vreg->mode;
- .get_value = rpmh_regulator_vrm_get_value,
- .set_value = rpmh_regulator_vrm_set_value,
- .set_enable = rpmh_regulator_set_enable_state,
- .get_enable = rpmh_regulator_is_enabled,
- .set_mode = rpmh_regulator_vrm_set_mode,
- .get_mode = rpmh_regulator_vrm_get_mode,
- .regulator_type = VRM,
- .ops = &rpmh_regulator_vrm_drms_ops,
- .voltage_range = REGULATOR_LINEAR_RANGE(1504000, 0, 62, 8000),
- .n_voltages = 63,
- .hpm_min_load_uA = 10000,
- .pmic_mode_map = pmic_mode_map_pmic5_ldo,
- .voltage_range = REGULATOR_LINEAR_RANGE(1504000, 0, 255, 8000),
- .n_voltages = 256,
- .n_modes = ARRAY_SIZE(pmic_mode_map_pmic5_ldo),
- .name = _name, \
- .resource_name = _resource_name, \
- .hw_data = _hw_data, \
- .supply_name = _supply_name, \
- RPMH_VREG("ldo13", "ldo%s13", &pmic5_pldo, "vdd-l13-l16-l17"),
- RPMH_VREG("ldo1", "ldo%s1", &pmic5_pldo_lv, "vdd-l1-l8"),
- RPMH_VREG("ldo11", "ldo%s11", &pmic5_pldo, "vdd-l7-l11"),
- const struct rpmh_vreg_init_data *init_data;
- struct rpmh_vreg *priv;
- struct dm_regulator_uclass_plat *plat_data;
- init_data = (const struct rpmh_vreg_init_data *)dev_get_driver_data(dev);
- priv = dev_get_priv(dev);
- plat_data = dev_get_uclass_plat(dev);
- priv->dev = dev;
- priv->addr = cmd_db_read_addr(dev->name);
- if (!priv->addr) {
return -ENODEV;
- priv->hw_data = init_data->hw_data;
- priv->enabled = -EINVAL;
- priv->uv = -ENOTRECOVERABLE;
- if (ofnode_read_u32(dev_ofnode(dev), "regulator-initial-mode", &priv->mode))
- // handle stepping
- // almost there!!!
- plat_data->mode = priv->hw_data->pmic_mode_map;
- plat_data->mode_count = priv->hw_data->n_modes;
- .name = "rpmh_regulator_drm",
- .id = UCLASS_REGULATOR,
- .probe = rpmh_regulator_probe,
- .priv_auto = sizeof(struct rpmh_vreg),
- This function checks to see if a given regulator node in DT matches a regulator
- defined in the driver.
- const struct rpmh_vreg_init_data *data;
- for (data = init_data; data->name; data++) {
return data;
- return NULL;
- const struct rpmh_vreg_init_data *init_data, *data;
- const char *pmic_id;
- char *name;
- struct driver *drv;
- ofnode node;
- int ret;
- size_t namelen;
- if (!init_data) {
return -ENODEV;
- pmic_id = ofnode_read_string(dev_ofnode(dev), "qcom,pmic-id");
- if (!pmic_id) {
return -ENODEV;
- drv = lists_driver_lookup_name("rpmh_regulator_drm");
- ofnode_for_each_subnode(node, dev_ofnode(dev)) {
if (!data)
continue;
return -ENOMEM;
node, NULL);
- { /* sentinal */ },
- individual regulator
- .name = "rpmh_regulators",
- .id = UCLASS_MISC,
- .bind = rpmh_regulators_bind,
- .of_match = rpmh_regulator_ids,
Caleb Connolly
Neil Armstrong
Sumit Garg
