Rockchip RK3328 4-byte addressing problem in SPI
Hello,
I would like to let you know how i've lost about 2 weeks because of lack of Rockchip BOOTROM documentation.
I tried to use Mainline Uboot to Boot NanoPI R2S using soldered SPI Winbond 25Q256 chip.
I had to make some patches in Uboot core files to make it work.
First one adds SPI boot device. File |arch/arm/mach-rockchip/rk3328/rk3328.c with adding: |
|[BROM_BOOTSOURCE_SPINOR] "/spi@ff190000", |const char * const boot_devices ||
Second was |arch/arm/mach-rockchip/spl-boot-order.c and last if statement:|
|if (!uclass_get_device_by_of_offset(UCLASS_SPI, node, &parent)) return BOOT_DEVICE_SPI;|
This patch is added because RockChip SPI driver is using UCLASS_SPI instead of SPI_FLASH so boot device wasn't connecting with right DM Driver rk_spi.c
Third one fixed SPL and it was added at the end: |drivers/spi/rk_spi.c |
|DM_DRIVER_ALIAS(rockchip_rk3288_spi, rockchip_rk3328_spi);|
After that board booted successfully. Second bigger problem was a mistake and lack of RockChip Bootrom documentation.
I've soldered 32Mbyte Flash and didn't know that U-Boot in SPL was switching it's 3-byte address mode to 4-byte one to gain access to full 32 Mbytes.
The problem was that board booted in cold-start but after issuing "reset" - it was going to MASKROM mode like no SPI was soldered or empty.
After loosing two weeks i figured that RockChip bootrom talks to SPI using only 3-byte addressing.
So leaving 4-byte switched by UBoot SPI chip made it unusable to RockChip Bootrom. I found this by dumping Bootrom and decompiling it.
I don't know if it's enough information to make a patch to MainLine (at least for SPI boot in RK3328).
Problem with 3-byte addressing is a complete different story.
Sorry for my "unproffesional" mail. I am writing this type of message for a first time.
Marcin
+Kever Yang
On Thu, 22 Dec 2022 at 18:30, Marcin Woźniak marcin.wadowice@gmail.com wrote:
Hello,
Marcin
Hi Macin,
On 2022/12/30 06:39, Simon Glass wrote:
+Kever Yang
Hello,
I didn't look into SPI boot flow, but there have many boards working with SPI including rk3399,
rk3328 and other SoCs. It should be work to sync with those boards.
Sync with engineer working on these area, and get below:
Yes, this "4-byte addressing problem in SPI" issue is in SoCs including rk3328, this only happen
on SPI NOR size at least 32MB, most of customers only use smaller size SPI NOR.
If 32MB+ SPI NOR is needed for the project, them we would suggest to use those SPI flash with
3&4 byte command set support; or else workaround to do the snor_deinit and exit_4byte_address_mode
will needed before every reboot/hot reset in the system.
Thanks,
- Kever
Marcin
Hi Kever,
+Kever Yang
Hello,
Can we have an explicit list of SoCs affected by this errata please?
So is this a bug where they misdetect that capability so you explicitly have to exit the mode if the flash isn't capable of it?
Thanks, Peter
Thanks,
- Kever
Marcin
I'm not sure this is a problem of the SoC (bootrom). The issue is either board design or flash usage pattern.
If you enable 4byte mode and don't have a hardware reset pin (or don't assert it during board reset) you are likely in trouble.
Have a look at JESD216D. The 16th DWORD lists 6 different software reset methods, there is even a "no software reset instruction is supported". That's also true for the "exit 4byte mode": there is no common way to exit it.
You could try to read the SFDP tables. But that will only work for flash devices with (valid) SFDP.
So in the general case, you are probably f** when you enable the 4 byte mode, boot from that flash and don't have a reset. As mentioned here, you should instead use the 4byte opcodes where possible.
-michael
participants (5)
Kever Yang
Marcin Woźniak
Michael Walle
Peter Robinson
