[PATCH v2 0/3] board: rockchip: Add Hardkernel ODROID-M1S
This series add support for the RK3566 based Hardkernel ODROID-M1S and also correct the board compatible used for Hardkernel ODROID-M1.
Features tested on a ODROID-M1S 8GB rev1.0 20230906: - SD-card boot - eMMC boot - Ethernet - PCIe/NVMe - USB gadget - USB host
Changes in v2: - Fix clean apply on master branch
Jonas Karlman (3): arm64: dts: rockchip: Correct vendor prefix for Hardkernel ODROID-M1 arm64: dts: rockchip: Add Hardkernel ODROID-M1S board: rockchip: Add Hardkernel ODROID-M1S
arch/arm/dts/rk3566-odroid-m1s-u-boot.dtsi | 3 + arch/arm/mach-rockchip/rk3568/Kconfig | 6 + board/hardkernel/odroid_m1s/Kconfig | 12 + board/hardkernel/odroid_m1s/MAINTAINERS | 6 + configs/odroid-m1s-rk3566_defconfig | 93 +++ doc/board/rockchip/rockchip.rst | 1 + .../src/arm64/rockchip/rk3566-odroid-m1s.dts | 663 ++++++++++++++++++ .../src/arm64/rockchip/rk3568-odroid-m1.dts | 2 +- 8 files changed, 785 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/rk3566-odroid-m1s-u-boot.dtsi create mode 100644 board/hardkernel/odroid_m1s/Kconfig create mode 100644 board/hardkernel/odroid_m1s/MAINTAINERS create mode 100644 configs/odroid-m1s-rk3566_defconfig create mode 100644 dts/upstream/src/arm64/rockchip/rk3566-odroid-m1s.dts
The vendor prefix for Hardkernel ODROID-M1 is incorrectly listed as rockchip. Use the proper hardkernel vendor prefix for this board, while at it also drop the redundant soc prefix.
Fixes: fd3583267703 ("arm64: dts: rockchip: Add Hardkernel ODROID-M1 board") Reviewed-by: Aurelien Jarno aurelien@aurel32.net Signed-off-by: Jonas Karlman jonas@kwiboo.se Link: https://lore.kernel.org/r/20240827211825.1419820-3-jonas@kwiboo.se Signed-off-by: Heiko Stuebner heiko@sntech.de
[ upstream commit: 735065e774dcfc62e38df01a535862138b6c92ed ]
(cherry picked from commit e7259a2c4a6f2ebdfc96b8bbffc77fe67604b11f) Signed-off-by: Jonas Karlman jonas@kwiboo.se --- v2: No change --- dts/upstream/src/arm64/rockchip/rk3568-odroid-m1.dts | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/dts/upstream/src/arm64/rockchip/rk3568-odroid-m1.dts b/dts/upstream/src/arm64/rockchip/rk3568-odroid-m1.dts index a337f547caf5..6a02db4f073f 100644 --- a/dts/upstream/src/arm64/rockchip/rk3568-odroid-m1.dts +++ b/dts/upstream/src/arm64/rockchip/rk3568-odroid-m1.dts @@ -13,7 +13,7 @@
/ { model = "Hardkernel ODROID-M1"; - compatible = "rockchip,rk3568-odroid-m1", "rockchip,rk3568"; + compatible = "hardkernel,odroid-m1", "rockchip,rk3568";
aliases { ethernet0 = &gmac0;
v2: No change
Acked-by: Sumit Garg sumit.garg@linaro.org
-Sumit
compatible = "hardkernel,odroid-m1", "rockchip,rk3568"; aliases { ethernet0 = &gmac0;
-- 2.46.2
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
v2: No change
The Hardkernel ODROID-M1S is a single-board computer based on Rockchip RK3566 SoC. It features e.g. 4/8 GB LPDDR4 RAM, 64 GB eMMC, SD-card, GbE LAN, HDMI 2.0, M.2 NVMe and USB 2.0/3.0.
Add initial support for eMMC, SD-card, Ethernet, HDMI, PCIe and USB.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Link: https://lore.kernel.org/r/20240827211825.1419820-5-jonas@kwiboo.se Signed-off-by: Heiko Stuebner heiko@sntech.de
[ upstream commit: 10dc64fe0f980c47c7e747885ddf7a8c12780337 ]
(cherry picked from commit f811548e758b52896f725753086c42b49dc42c0d) Signed-off-by: Jonas Karlman jonas@kwiboo.se --- v2: No change --- .../src/arm64/rockchip/rk3566-odroid-m1s.dts | 663 ++++++++++++++++++ 1 file changed, 663 insertions(+) create mode 100644 dts/upstream/src/arm64/rockchip/rk3566-odroid-m1s.dts
diff --git a/dts/upstream/src/arm64/rockchip/rk3566-odroid-m1s.dts b/dts/upstream/src/arm64/rockchip/rk3566-odroid-m1s.dts new file mode 100644 index 000000000000..33bc5249d729 --- /dev/null +++ b/dts/upstream/src/arm64/rockchip/rk3566-odroid-m1s.dts @@ -0,0 +1,663 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include <dt-bindings/soc/rockchip,vop2.h> +#include "rk3566.dtsi" + +/ { + model = "Hardkernel ODROID-M1S"; + compatible = "hardkernel,odroid-m1s", "rockchip,rk3566"; + + aliases { + ethernet0 = &gmac1; + mmc0 = &sdhci; + mmc1 = &sdmmc0; + }; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + hdmi-con { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pwr_led>, <&sys_led>; + + led_pwr: led-0 { + color = <LED_COLOR_ID_RED>; + default-state = "on"; + function = LED_FUNCTION_POWER; + gpios = <&gpio0 RK_PC6 GPIO_ACTIVE_LOW>; + linux,default-trigger = "default-on"; + }; + + led_sys: led-1 { + color = <LED_COLOR_ID_BLUE>; + default-state = "on"; + function = LED_FUNCTION_HEARTBEAT; + gpios = <&gpio0 RK_PB7 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + }; + + vcc3v3_lcd: regulator-3v3-vcc-lcd { + compatible = "regulator-fixed"; + enable-active-high; + gpios = <&gpio0 RK_PC7 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&lcd_pwren>; + regulator-name = "vcc3v3_lcd"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc3v3_sys>; + }; + + vcc3v3_pcie: regulator-3v3-vcc-pcie { + compatible = "regulator-fixed"; + enable-active-high; + gpios = <&gpio2 RK_PC2 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_pwren>; + regulator-name = "vcc3v3_pcie"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc3v3_sys>; + }; + + vcc3v3_sys: regulator-3v3-vcc-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_sys: regulator-5v0-vcc-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc5v0_usb2_host: regulator-5v0-vcc-usb2-host { + compatible = "regulator-fixed"; + enable-active-high; + gpios = <&gpio3 RK_PB0 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb2_host_pwren>; + regulator-name = "vcc5v0_usb2_host"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_usb2_otg: regulator-5v0-vcc-usb2-otg { + compatible = "regulator-fixed"; + enable-active-high; + gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb2_otg_pwren>; + regulator-name = "vcc5v0_usb2_otg"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_usb3_host: regulator-5v0-vcc-usb3-host { + compatible = "regulator-fixed"; + enable-active-high; + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb3_host_pwren>; + regulator-name = "vcc5v0_usb3_host"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_sys>; + }; + + sound { + compatible = "simple-audio-card"; + simple-audio-card,format = "i2s"; + simple-audio-card,name = "Analog RK809"; + simple-audio-card,mclk-fs = <256>; + + simple-audio-card,cpu { + sound-dai = <&i2s1_8ch>; + }; + + simple-audio-card,codec { + sound-dai = <&rk809>; + }; + }; +}; + +&combphy1 { + status = "okay"; +}; + +&combphy2 { + status = "okay"; +}; + +&cpu0 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu1 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu2 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu3 { + cpu-supply = <&vdd_cpu>; +}; + +&gmac1 { + assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>; + assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru CLK_MAC1_2TOP>; + clock_in_out = "input"; + phy-handle = <&rgmii_phy1>; + phy-mode = "rgmii-id"; + phy-supply = <&vcc_3v3>; + pinctrl-names = "default"; + pinctrl-0 = <&gmac1m1_miim + &gmac1m1_tx_bus2 + &gmac1m1_rx_bus2 + &gmac1m1_rgmii_clk + &gmac1m1_rgmii_bus + &gmac1m1_clkinout>; + status = "okay"; +}; + +&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + +&hdmi { + avdd-0v9-supply = <&vdda0v9_image>; + avdd-1v8-supply = <&vcca1v8_image>; + status = "okay"; +}; + +&hdmi_in { + hdmi_in_vp0: endpoint { + remote-endpoint = <&vp0_out_hdmi>; + }; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&hdmi_sound { + status = "okay"; +}; + +&i2c0 { + status = "okay"; + + vdd_cpu: regulator@1c { + compatible = "tcs,tcs4525"; + reg = <0x1c>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1390000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc3v3_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + rk809: pmic@20 { + compatible = "rockchip,rk809"; + reg = <0x20>; + assigned-clocks = <&cru I2S1_MCLKOUT_TX>; + assigned-clock-parents = <&cru CLK_I2S1_8CH_TX>; + #clock-cells = <1>; + clocks = <&cru I2S1_MCLKOUT_TX>; + clock-names = "mclk"; + clock-output-names = "rk809-clkout1", "rk809-clkout2"; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int>, <&i2s1m0_mclk>; + #sound-dai-cells = <0>; + system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc3v3_sys>; + vcc2-supply = <&vcc3v3_sys>; + vcc3-supply = <&vcc3v3_sys>; + vcc4-supply = <&vcc3v3_sys>; + vcc5-supply = <&vcc3v3_sys>; + vcc6-supply = <&vcc3v3_sys>; + vcc7-supply = <&vcc3v3_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc3v3_sys>; + + regulators { + vdd_logic: DCDC_REG1 { + regulator-name = "vdd_logic"; + regulator-always-on; + regulator-boot-on; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: DCDC_REG2 { + regulator-name = "vdd_gpu"; + regulator-always-on; + regulator-boot-on; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-initial-mode = <0x2>; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vdd_npu: DCDC_REG4 { + regulator-name = "vdd_npu"; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG5 { + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda0v9_image: LDO_REG1 { + regulator-name = "vdda0v9_image"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda_0v9: LDO_REG2 { + regulator-name = "vdda_0v9"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda0v9_pmu: LDO_REG3 { + regulator-name = "vdda0v9_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <900000>; + }; + }; + + vccio_acodec: LDO_REG4 { + regulator-name = "vccio_acodec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_sd: LDO_REG5 { + regulator-name = "vccio_sd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_pmu: LDO_REG6 { + regulator-name = "vcc3v3_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcca_1v8: LDO_REG7 { + regulator-name = "vcca_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcca1v8_pmu: LDO_REG8 { + regulator-name = "vcca1v8_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcca1v8_image: LDO_REG9 { + regulator-name = "vcca1v8_image"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v3: SWITCH_REG1 { + regulator-name = "vcc_3v3"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_sd: SWITCH_REG2 { + regulator-name = "vcc3v3_sd"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; +}; + +&i2s0_8ch { + status = "okay"; +}; + +&i2s1_8ch { + pinctrl-names = "default"; + pinctrl-0 = <&i2s1m0_sclktx + &i2s1m0_lrcktx + &i2s1m0_sdi0 + &i2s1m0_sdo0>; + rockchip,trcm-sync-tx-only; + status = "okay"; +}; + +&mdio1 { + rgmii_phy1: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + reset-assert-us = <20000>; + reset-deassert-us = <100000>; + reset-gpios = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + }; +}; + +&pcie2x1 { + pinctrl-names = "default"; + pinctrl-0 = <&pcie20_pins>; + reset-gpios = <&gpio1 RK_PB2 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_pcie>; + status = "okay"; +}; + +&pinctrl { + lcd { + lcd_pwren: lcd-pwren { + rockchip,pins = <0 RK_PC7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + leds { + pwr_led: pwr-led { + rockchip,pins = <0 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + sys_led: sys-led { + rockchip,pins = <0 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pcie { + pcie20_pins: pcie20-pins { + rockchip,pins = + <1 RK_PB0 4 &pcfg_pull_none>, + <1 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>, + <1 RK_PB1 4 &pcfg_pull_none>; + }; + + pcie_pwren: pcie-pwren { + rockchip,pins = <2 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pmic { + pmic_int: pmic-int { + rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + usb { + usb2_host_pwren: usb2-host-pwren { + rockchip,pins = <3 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + usb2_otg_pwren: usb2-otg-pwren { + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + usb3_host_pwren: usb3-host-pwren { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pmu_io_domains { + pmuio1-supply = <&vcc3v3_pmu>; + pmuio2-supply = <&vcc3v3_pmu>; + vccio1-supply = <&vccio_acodec>; + vccio2-supply = <&vcc_1v8>; + vccio3-supply = <&vccio_sd>; + vccio4-supply = <&vcc_3v3>; + vccio5-supply = <&vcc_3v3>; + vccio6-supply = <&vcc_3v3>; + vccio7-supply = <&vcc_3v3>; + status = "okay"; +}; + +&saradc { + vref-supply = <&vcca_1v8>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + cap-mmc-highspeed; + max-frequency = <200000000>; + mmc-hs200-1_8v; + no-sd; + no-sdio; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe &emmc_rstnout>; + vmmc-supply = <&vcc_3v3>; + vqmmc-supply = <&vcc_1v8>; + status = "okay"; +}; + +&sdmmc0 { + bus-width = <4>; + cap-sd-highspeed; + disable-wp; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>; + sd-uhs-sdr50; + vmmc-supply = <&vcc3v3_sd>; + vqmmc-supply = <&vccio_sd>; + status = "okay"; +}; + +&tsadc { + rockchip,hw-tshut-mode = <1>; + rockchip,hw-tshut-polarity = <0>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host0_xhci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&usb_host1_xhci { + status = "okay"; +}; + +&usb2phy0 { + status = "okay"; +}; + +&usb2phy0_host { + phy-supply = <&vcc5v0_usb3_host>; + status = "okay"; +}; + +&usb2phy0_otg { + phy-supply = <&vcc5v0_usb2_otg>; + status = "okay"; +}; + +&usb2phy1 { + status = "okay"; +}; + +&usb2phy1_host { + phy-supply = <&vcc5v0_usb2_host>; + status = "okay"; +}; + +&usb2phy1_otg { + phy-supply = <&vcc5v0_usb2_host>; + status = "okay"; +}; + +&vop { + assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>; + assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>; + status = "okay"; +}; + +&vop_mmu { + status = "okay"; +}; + +&vp0 { + vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { + reg = <ROCKCHIP_VOP2_EP_HDMI0>; + remote-endpoint = <&hdmi_in_vp0>; + }; +};
Will this not just come through with the dts sync process?
v2: No change
+/dts-v1/;
aliases {
ethernet0 = &gmac1;
mmc0 = &sdhci;
mmc1 = &sdmmc0;
chosen {
hdmi-con {
type = "a";
port {
leds {
led_pwr: led-0 {
led_sys: led-1 {
enable-active-high;
enable-active-high;
regulator-boot-on;
regulator-boot-on;
enable-active-high;
enable-active-high;
enable-active-high;
sound {
+&combphy1 {
status = "okay";
+&combphy2 {
status = "okay";
+&cpu0 {
+&cpu1 {
+&cpu2 {
+&cpu3 {
+&gmac1 {
&gmac1m1_tx_bus2
&gmac1m1_rx_bus2
&gmac1m1_rgmii_clk
&gmac1m1_rgmii_bus
&gmac1m1_clkinout>;
status = "okay";
+&gpu {
status = "okay";
+&hdmi {
status = "okay";
+&hdmi_in {
+&hdmi_out {
+&hdmi_sound {
status = "okay";
+&i2c0 {
status = "okay";
reg = <0x1c>;
regulator-boot-on;
rk809: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
+&i2s0_8ch {
status = "okay";
+&i2s1_8ch {
&i2s1m0_lrcktx
&i2s1m0_sdi0
&i2s1m0_sdo0>;
status = "okay";
+&mdio1 {
reg = <1>;
+&pcie2x1 {
status = "okay";
+&pinctrl {
lcd {
leds {
pwr_led: pwr-led {
sys_led: sys-led {
pcie {
rockchip,pins =
pmic {
usb {
+&pmu_io_domains {
status = "okay";
+&saradc {
status = "okay";
+&sdhci {
bus-width = <8>;
cap-mmc-highspeed;
mmc-hs200-1_8v;
no-sd;
no-sdio;
non-removable;
status = "okay";
+&sdmmc0 {
bus-width = <4>;
cap-sd-highspeed;
disable-wp;
sd-uhs-sdr50;
status = "okay";
+&tsadc {
status = "okay";
+&uart2 {
status = "okay";
+&usb_host0_ehci {
status = "okay";
+&usb_host0_ohci {
status = "okay";
+&usb_host0_xhci {
status = "okay";
+&usb_host1_ehci {
status = "okay";
+&usb_host1_ohci {
status = "okay";
+&usb_host1_xhci {
status = "okay";
+&usb2phy0 {
status = "okay";
+&usb2phy0_host {
status = "okay";
+&usb2phy0_otg {
status = "okay";
+&usb2phy1 {
status = "okay";
+&usb2phy1_host {
status = "okay";
+&usb2phy1_otg {
status = "okay";
+&vop {
status = "okay";
+&vop_mmu {
status = "okay";
+&vp0 {
2.46.2
Hi Peter,
The Linux DTs is synced to U-Boot before/during merge window closes, so for U-Boot v2025.01 dts/upstream will only sync Linux v6.11 DTs.
This board was merged into Linux v6.12-rc1, so we need to be pick DT from devicetree-rebasing v6.12-rc1-dts or wait for next dts/upstream sync in time for v2025.04.
This patch picks the DT so that we can add the board for v2025.01.
Regards, Jonas
v2: No change
[snip]
v2: No change
-Sumit
+/dts-v1/;
aliases {
ethernet0 = &gmac1;
mmc0 = &sdhci;
mmc1 = &sdmmc0;
chosen {
hdmi-con {
type = "a";
port {
leds {
led_pwr: led-0 {
led_sys: led-1 {
enable-active-high;
enable-active-high;
regulator-boot-on;
regulator-boot-on;
enable-active-high;
enable-active-high;
enable-active-high;
sound {
+&combphy1 {
status = "okay";
+&combphy2 {
status = "okay";
+&cpu0 {
+&cpu1 {
+&cpu2 {
+&cpu3 {
+&gmac1 {
&gmac1m1_tx_bus2
&gmac1m1_rx_bus2
&gmac1m1_rgmii_clk
&gmac1m1_rgmii_bus
&gmac1m1_clkinout>;
status = "okay";
+&gpu {
status = "okay";
+&hdmi {
status = "okay";
+&hdmi_in {
+&hdmi_out {
+&hdmi_sound {
status = "okay";
+&i2c0 {
status = "okay";
reg = <0x1c>;
regulator-boot-on;
rk809: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
+&i2s0_8ch {
status = "okay";
+&i2s1_8ch {
&i2s1m0_lrcktx
&i2s1m0_sdi0
&i2s1m0_sdo0>;
status = "okay";
+&mdio1 {
reg = <1>;
+&pcie2x1 {
status = "okay";
+&pinctrl {
lcd {
leds {
pwr_led: pwr-led {
sys_led: sys-led {
pcie {
rockchip,pins =
pmic {
usb {
+&pmu_io_domains {
status = "okay";
+&saradc {
status = "okay";
+&sdhci {
bus-width = <8>;
cap-mmc-highspeed;
mmc-hs200-1_8v;
no-sd;
no-sdio;
non-removable;
status = "okay";
+&sdmmc0 {
bus-width = <4>;
cap-sd-highspeed;
disable-wp;
sd-uhs-sdr50;
status = "okay";
+&tsadc {
status = "okay";
+&uart2 {
status = "okay";
+&usb_host0_ehci {
status = "okay";
+&usb_host0_ohci {
status = "okay";
+&usb_host0_xhci {
status = "okay";
+&usb_host1_ehci {
status = "okay";
+&usb_host1_ohci {
status = "okay";
+&usb_host1_xhci {
status = "okay";
+&usb2phy0 {
status = "okay";
+&usb2phy0_host {
status = "okay";
+&usb2phy0_otg {
status = "okay";
+&usb2phy1 {
status = "okay";
+&usb2phy1_host {
status = "okay";
+&usb2phy1_otg {
status = "okay";
+&vop {
status = "okay";
+&vop_mmu {
status = "okay";
+&vp0 {
2.46.2
Thanks, - Kever
v2: No change
+/dts-v1/;
- model = "Hardkernel ODROID-M1S";
- compatible = "hardkernel,odroid-m1s", "rockchip,rk3566";
- aliases {
ethernet0 = &gmac1;
mmc0 = &sdhci;
mmc1 = &sdmmc0;
- chosen {
- hdmi-con {
type = "a";
port {
- leds {
led_pwr: led-0 {
led_sys: led-1 {
- vcc3v3_lcd: regulator-3v3-vcc-lcd {
enable-active-high;
- vcc3v3_pcie: regulator-3v3-vcc-pcie {
enable-active-high;
- vcc3v3_sys: regulator-3v3-vcc-sys {
regulator-boot-on;
- vcc5v0_sys: regulator-5v0-vcc-sys {
regulator-boot-on;
- vcc5v0_usb2_host: regulator-5v0-vcc-usb2-host {
enable-active-high;
- vcc5v0_usb2_otg: regulator-5v0-vcc-usb2-otg {
enable-active-high;
- vcc5v0_usb3_host: regulator-5v0-vcc-usb3-host {
enable-active-high;
- sound {
+&combphy1 {
- status = "okay";
+&combphy2 {
- status = "okay";
+&cpu0 {
- cpu-supply = <&vdd_cpu>;
+&cpu1 {
+&cpu2 {
+&cpu3 {
+&gmac1 {
- assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>;
- assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru CLK_MAC1_2TOP>;
- clock_in_out = "input";
- phy-handle = <&rgmii_phy1>;
- phy-mode = "rgmii-id";
- phy-supply = <&vcc_3v3>;
- pinctrl-names = "default";
- pinctrl-0 = <&gmac1m1_miim
&gmac1m1_tx_bus2
&gmac1m1_rx_bus2
&gmac1m1_rgmii_clk
&gmac1m1_rgmii_bus
&gmac1m1_clkinout>;
- status = "okay";
+&gpu {
- mali-supply = <&vdd_gpu>;
- status = "okay";
+&hdmi {
- avdd-0v9-supply = <&vdda0v9_image>;
- avdd-1v8-supply = <&vcca1v8_image>;
- status = "okay";
+&hdmi_in {
- hdmi_in_vp0: endpoint {
+&hdmi_out {
- hdmi_out_con: endpoint {
+&hdmi_sound {
- status = "okay";
+&i2c0 {
- status = "okay";
- vdd_cpu: regulator@1c {
reg = <0x1c>;
regulator-boot-on;
- rk809: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
+&i2s0_8ch {
- status = "okay";
+&i2s1_8ch {
- pinctrl-0 = <&i2s1m0_sclktx
&i2s1m0_lrcktx
&i2s1m0_sdi0
&i2s1m0_sdo0>;
- rockchip,trcm-sync-tx-only;
- status = "okay";
+&mdio1 {
- rgmii_phy1: ethernet-phy@1 {
reg = <1>;
+&pcie2x1 {
- pinctrl-0 = <&pcie20_pins>;
- reset-gpios = <&gpio1 RK_PB2 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_pcie>;
- status = "okay";
+&pinctrl {
- lcd {
- leds {
pwr_led: pwr-led {
sys_led: sys-led {
- pcie {
rockchip,pins =
- pmic {
- usb {
+&pmu_io_domains {
- pmuio1-supply = <&vcc3v3_pmu>;
- pmuio2-supply = <&vcc3v3_pmu>;
- vccio1-supply = <&vccio_acodec>;
- vccio2-supply = <&vcc_1v8>;
- vccio3-supply = <&vccio_sd>;
- vccio4-supply = <&vcc_3v3>;
- vccio5-supply = <&vcc_3v3>;
- vccio6-supply = <&vcc_3v3>;
- vccio7-supply = <&vcc_3v3>;
- status = "okay";
+&saradc {
- vref-supply = <&vcca_1v8>;
- status = "okay";
+&sdhci {
- bus-width = <8>;
- cap-mmc-highspeed;
- max-frequency = <200000000>;
- mmc-hs200-1_8v;
- no-sd;
- no-sdio;
- non-removable;
- pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe &emmc_rstnout>;
- vmmc-supply = <&vcc_3v3>;
- vqmmc-supply = <&vcc_1v8>;
- status = "okay";
+&sdmmc0 {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>;
- sd-uhs-sdr50;
- vmmc-supply = <&vcc3v3_sd>;
- vqmmc-supply = <&vccio_sd>;
- status = "okay";
+&tsadc {
- rockchip,hw-tshut-mode = <1>;
- rockchip,hw-tshut-polarity = <0>;
- status = "okay";
+&uart2 {
- status = "okay";
+&usb_host0_ehci {
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
+&usb_host0_xhci {
- status = "okay";
+&usb_host1_ehci {
- status = "okay";
+&usb_host1_ohci {
- status = "okay";
+&usb_host1_xhci {
- status = "okay";
+&usb2phy0 {
- status = "okay";
+&usb2phy0_host {
- phy-supply = <&vcc5v0_usb3_host>;
- status = "okay";
+&usb2phy0_otg {
- phy-supply = <&vcc5v0_usb2_otg>;
- status = "okay";
+&usb2phy1 {
- status = "okay";
+&usb2phy1_host {
- phy-supply = <&vcc5v0_usb2_host>;
- status = "okay";
+&usb2phy1_otg {
- status = "okay";
+&vop {
- assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>;
- assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>;
- status = "okay";
+&vop_mmu {
- status = "okay";
+&vp0 {
- vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 {
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- v2: Fix clean apply on master branch --- arch/arm/dts/rk3566-odroid-m1s-u-boot.dtsi | 3 + arch/arm/mach-rockchip/rk3568/Kconfig | 6 ++ board/hardkernel/odroid_m1s/Kconfig | 12 +++ board/hardkernel/odroid_m1s/MAINTAINERS | 6 ++ configs/odroid-m1s-rk3566_defconfig | 93 ++++++++++++++++++++++ doc/board/rockchip/rockchip.rst | 1 + 6 files changed, 121 insertions(+) create mode 100644 arch/arm/dts/rk3566-odroid-m1s-u-boot.dtsi create mode 100644 board/hardkernel/odroid_m1s/Kconfig create mode 100644 board/hardkernel/odroid_m1s/MAINTAINERS create mode 100644 configs/odroid-m1s-rk3566_defconfig
diff --git a/arch/arm/dts/rk3566-odroid-m1s-u-boot.dtsi b/arch/arm/dts/rk3566-odroid-m1s-u-boot.dtsi new file mode 100644 index 000000000000..6e8307e3bdf6 --- /dev/null +++ b/arch/arm/dts/rk3566-odroid-m1s-u-boot.dtsi @@ -0,0 +1,3 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +#include "rk356x-u-boot.dtsi" diff --git a/arch/arm/mach-rockchip/rk3568/Kconfig b/arch/arm/mach-rockchip/rk3568/Kconfig index 899cf909fbb9..e646f714c929 100644 --- a/arch/arm/mach-rockchip/rk3568/Kconfig +++ b/arch/arm/mach-rockchip/rk3568/Kconfig @@ -22,6 +22,11 @@ config TARGET_ODROID_M1_RK3568 help Hardkernel ODROID-M1 single board computer with a RK3568B2 SoC.
+config TARGET_ODROID_M1S_RK3566 + bool "ODROID-M1S" + help + Hardkernel ODROID-M1S single board computer with a RK3566 SoC. + config TARGET_POWKIDDY_X55_RK3566 bool "Powkiddy X55" help @@ -62,6 +67,7 @@ config TEXT_BASE source "board/rockchip/evb_rk3568/Kconfig" source "board/anbernic/rgxx3_rk3566/Kconfig" source "board/hardkernel/odroid_m1/Kconfig" +source "board/hardkernel/odroid_m1s/Kconfig" source "board/pine64/quartz64_rk3566/Kconfig" source "board/powkiddy/x55/Kconfig" source "board/radxa/zero3-rk3566/Kconfig" diff --git a/board/hardkernel/odroid_m1s/Kconfig b/board/hardkernel/odroid_m1s/Kconfig new file mode 100644 index 000000000000..5e0d2ca6d08b --- /dev/null +++ b/board/hardkernel/odroid_m1s/Kconfig @@ -0,0 +1,12 @@ +if TARGET_ODROID_M1S_RK3566 + +config SYS_BOARD + default "odroid_m1s" + +config SYS_VENDOR + default "hardkernel" + +config SYS_CONFIG_NAME + default "odroid_m1" + +endif diff --git a/board/hardkernel/odroid_m1s/MAINTAINERS b/board/hardkernel/odroid_m1s/MAINTAINERS new file mode 100644 index 000000000000..0c8d11249bff --- /dev/null +++ b/board/hardkernel/odroid_m1s/MAINTAINERS @@ -0,0 +1,6 @@ +ODROID-M1S +M: Jonas Karlman jonas@kwiboo.se +S: Maintained +F: board/hardkernel/odroid_m1s/ +F: configs/odroid-m1s-rk3566_defconfig +F: arch/arm/dts/rk3566-odroid-m1s-u-boot.dtsi diff --git a/configs/odroid-m1s-rk3566_defconfig b/configs/odroid-m1s-rk3566_defconfig new file mode 100644 index 000000000000..21f4fcb9d7be --- /dev/null +++ b/configs/odroid-m1s-rk3566_defconfig @@ -0,0 +1,93 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3566-odroid-m1s" +CONFIG_ROCKCHIP_RK3568=y +CONFIG_SPL_SERIAL=y +CONFIG_TARGET_ODROID_M1S_RK3566=y +CONFIG_DEBUG_UART_BASE=0xFE660000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-odroid-m1s.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_INI=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_CRAMFS=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_AHCI_PCI=y +CONFIG_DWC_AHCI=y +CONFIG_SPL_CLK=y +# CONFIG_USB_FUNCTION_FASTBOOT is not set +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_SPL_RAM=y +CONFIG_SCSI=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_FUNCTION_ROCKUSB=y +CONFIG_FS_CRAMFS=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index a50e3d2b8f38..7b11a2e0a358 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -98,6 +98,7 @@ List of mainline supported Rockchip boards:
* rk3566 - Anbernic RGxx3 (anbernic-rgxx3-rk3566) + - Hardkernel ODROID-M1S (odroid-m1s-rk3566) - Pine64 PineTab2 (pinetab2-rk3566) - Pine64 Quartz64-A Board (quartz64-a-rk3566) - Pine64 Quartz64-B Board (quartz64-b-rk3566)
- SD-card boot
- eMMC boot
- Ethernet
- PCIe/NVMe
- USB gadget
- USB host
A couple of small queries below. Reviewed-by: Peter Robinson pbrobinson@gmail.com
bool "ODROID-M1S"
help
+config SYS_BOARD
+config SYS_VENDOR
default "odroid_m1"
I don't see a SATA connector on the board, is there an addon hat or similar? Same query for the other AHCI/SCSI options further below.
What's cramfs used for?
- rk3566
-- 2.46.2
Hi Peter,
- SD-card boot
- eMMC boot
- Ethernet
- PCIe/NVMe
- USB gadget
- USB host
bool "ODROID-M1S"
help
+config SYS_BOARD
+config SYS_VENDOR
default "odroid_m1"
True, there is no SATA connector or addon had that I know of. It was probably just me trying to keep M1 and M1S defconfig as close as possible and not noticing/thinking about it :-)
Can drop it in a v3.
Hardkernel use cramfs for their ODROIDBIOS.BIN file with vendor U-Boot.
For mainline U-Boot on M1/M1S/M2 I have just enabled any required Kconfig options and tested reading information from such file/fs, in case anyone wants to run boot scripts that works on vendor U-Boot for these boards.
I have no real idea if this is even useful for anyone ;-)
Regards, Jonas
- rk3566
-- 2.46.2
- SD-card boot
- eMMC boot
- Ethernet
- PCIe/NVMe
- USB gadget
- USB host
Thanks, - Kever
- bool "ODROID-M1S"
- help
- config TARGET_POWKIDDY_X55_RK3566 bool "Powkiddy X55" help
+config SYS_BOARD
- default "odroid_m1s"
+config SYS_VENDOR
- default "hardkernel"
- default "odroid_m1"
- rk3566
Jonas Karlman
Kever Yang
Peter Robinson
Sumit Garg
