[U-Boot] [PATCH] i2c:zynq: I2C multi-bus support on Zynq
Changes: 'zynq_i2c.c': Adapted driver for compliance with "new" I2C driver model (CONFIG_SYS_I2C). Support for 0-length register address in 'i2c_write', 'i2c_read'. 'i2c.h', 'i2c_core.c': Support for Texas Instruments PCA9548 bus multiplexer.
Tested: Xilinx ZC702 eval board (single bus master 'I2C0' with multiplexer PCA9548). Write and read registers with addresses of length 0 and 1.
Note: Mainline code does not work "out of the box" on ZC702 at this time; ad hoc adaptations based on 'u-boot-xlnx' repository were needed in order to test on this board. (Those adapatations are not included with this patch.)
Signed-off-by: Michael Burr michael.burr@logicpd.com Cc: Heiko Schocher hs@denx.de Cc: Michal Simek monstr@monstr.eu --- drivers/i2c/i2c_core.c | 5 ++ drivers/i2c/zynq_i2c.c | 148 +++++++++++++++++++++++++++++------------------- include/i2c.h | 3 + 3 files changed, 97 insertions(+), 59 deletions(-)
diff --git a/drivers/i2c/i2c_core.c b/drivers/i2c/i2c_core.c index d1072e8..b263562 100644 --- a/drivers/i2c/i2c_core.c +++ b/drivers/i2c/i2c_core.c @@ -138,6 +138,11 @@ static int i2c_mux_set(struct i2c_adapter *adap, int mux_id, int chip, return -1; buf = (uint8_t)((channel & 0x07) | (1 << 3)); break; + case I2C_MUX_PCA9548_ID: + if (channel > 7) + return -1; + buf = (uint8_t)(0x01 << channel); + break; default: printf("%s: wrong mux id: %d\n", __func__, mux_id); return -1; diff --git a/drivers/i2c/zynq_i2c.c b/drivers/i2c/zynq_i2c.c index ce2d23f..be27966 100644 --- a/drivers/i2c/zynq_i2c.c +++ b/drivers/i2c/zynq_i2c.c @@ -7,6 +7,8 @@ * * Copyright (c) 2012-2013 Xilinx, Michal Simek * + * Copyright (c) 2013 Logic PD, Michael Burr + * * SPDX-License-Identifier: GPL-2.0+ */
@@ -64,18 +66,28 @@ struct zynq_i2c_registers { #define ZYNQ_I2C_FIFO_DEPTH 16 #define ZYNQ_I2C_TRANSFERT_SIZE_MAX 255 /* Controller transfer limit */
-#if defined(CONFIG_ZYNQ_I2C0) -# define ZYNQ_I2C_BASE ZYNQ_I2C_BASEADDR0 -#else -# define ZYNQ_I2C_BASE ZYNQ_I2C_BASEADDR1 -#endif - -static struct zynq_i2c_registers *zynq_i2c = - (struct zynq_i2c_registers *)ZYNQ_I2C_BASE; +static struct zynq_i2c_registers *i2c_select(struct i2c_adapter *adap) +{ + return adap->hwadapnr ? + /* Zynq PS I2C1 */ + (struct zynq_i2c_registers *)ZYNQ_I2C_BASEADDR1 : + /* Zynq PS I2C0 */ + (struct zynq_i2c_registers *)ZYNQ_I2C_BASEADDR0; +}
/* I2C init called by cmd_i2c when doing 'i2c reset'. */ -void i2c_init(int requested_speed, int slaveadd) +static void zynq_i2c_init(struct i2c_adapter *adap, int speed, int slaveaddr) { + struct zynq_i2c_registers *zynq_i2c = i2c_select(adap); + + if (speed != 100000) + debug("Warning: requested speed not supported.\n"); + if (slaveaddr) + debug("Warning: slave mode not supported.\n"); + + /* The following _assumes_ clock rate cpu_1x = 111 MHz */ + /* This could use improvement! Also see 'i2c_set_bus_speed' below */ + /* 111MHz / ( (3 * 17) * 22 ) = ~100KHz */ writel((16 << ZYNQ_I2C_CONTROL_DIV_B_SHIFT) | (2 << ZYNQ_I2C_CONTROL_DIV_A_SHIFT), &zynq_i2c->control); @@ -86,7 +98,7 @@ void i2c_init(int requested_speed, int slaveadd) }
#ifdef DEBUG -static void zynq_i2c_debug_status(void) +static void zynq_i2c_debug_status(struct zynq_i2c_registers *zynq_i2c) { int int_status; int status; @@ -128,7 +140,7 @@ static void zynq_i2c_debug_status(void) #endif
/* Wait for an interrupt */ -static u32 zynq_i2c_wait(u32 mask) +static u32 zynq_i2c_wait(struct zynq_i2c_registers *zynq_i2c, u32 mask) { int timeout, int_status;
@@ -139,7 +151,7 @@ static u32 zynq_i2c_wait(u32 mask) break; } #ifdef DEBUG - zynq_i2c_debug_status(); + zynq_i2c_debug_status(zynq_i2c); #endif /* Clear interrupt status flags */ writel(int_status & mask, &zynq_i2c->interrupt_status); @@ -151,17 +163,19 @@ static u32 zynq_i2c_wait(u32 mask) * I2C probe called by cmd_i2c when doing 'i2c probe'. * Begin read, nak data byte, end. */ -int i2c_probe(u8 dev) +static int zynq_i2c_probe(struct i2c_adapter *adap, uint8_t chip) { + struct zynq_i2c_registers *zynq_i2c = i2c_select(adap); + /* Attempt to read a byte */ setbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_CLR_FIFO | ZYNQ_I2C_CONTROL_RW); clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); writel(0xFF, &zynq_i2c->interrupt_status); - writel(dev, &zynq_i2c->address); + writel(chip, &zynq_i2c->address); writel(1, &zynq_i2c->transfer_size);
- return (zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP | + return (zynq_i2c_wait(zynq_i2c, ZYNQ_I2C_INTERRUPT_COMP | ZYNQ_I2C_INTERRUPT_NACK) & ZYNQ_I2C_INTERRUPT_COMP) ? 0 : -ETIMEDOUT; } @@ -170,14 +184,18 @@ int i2c_probe(u8 dev) * I2C read called by cmd_i2c when doing 'i2c read' and by cmd_eeprom.c * Begin write, send address byte(s), begin read, receive data bytes, end. */ -int i2c_read(u8 dev, uint addr, int alen, u8 *data, int length) +static int zynq_i2c_read(struct i2c_adapter *adap, uint8_t chip, uint addr, + int alen, uint8_t *buffer, int len) { + struct zynq_i2c_registers *zynq_i2c; u32 status; u32 i = 0; - u8 *cur_data = data; + u8 *cur_data = buffer; + + zynq_i2c = i2c_select(adap);
/* Check the hardware can handle the requested bytes */ - if ((length < 0) || (length > ZYNQ_I2C_TRANSFERT_SIZE_MAX)) + if ((len < 0) || (len > ZYNQ_I2C_TRANSFERT_SIZE_MAX)) return -EINVAL;
/* Write the register address */ @@ -187,30 +205,33 @@ int i2c_read(u8 dev, uint addr, int alen, u8 *data, int length) * Temporarily disable restart (by clearing hold) * It doesn't seem to work. */ - clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_RW | - ZYNQ_I2C_CONTROL_HOLD); + clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); + writel(0xFF, &zynq_i2c->interrupt_status); - while (alen--) - writel(addr >> (8*alen), &zynq_i2c->data); - writel(dev, &zynq_i2c->address); - - /* Wait for the address to be sent */ - if (!zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP)) { - /* Release the bus */ - clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); - return -ETIMEDOUT; + if (alen) { + clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_RW); + writel(chip, &zynq_i2c->address); + while (alen--) + writel(addr >> (8*alen), &zynq_i2c->data); + + /* Wait for the address to be sent */ + if (!zynq_i2c_wait(zynq_i2c, ZYNQ_I2C_INTERRUPT_COMP)) { + /* Release the bus */ + clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); + return -ETIMEDOUT; + } + debug("Device acked address\n"); } - debug("Device acked address\n");
setbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_CLR_FIFO | ZYNQ_I2C_CONTROL_RW); /* Start reading data */ - writel(dev, &zynq_i2c->address); - writel(length, &zynq_i2c->transfer_size); + writel(len, &zynq_i2c->transfer_size); + writel(chip, &zynq_i2c->address);
/* Wait for data */ do { - status = zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP | + status = zynq_i2c_wait(zynq_i2c, ZYNQ_I2C_INTERRUPT_COMP | ZYNQ_I2C_INTERRUPT_DATA); if (!status) { /* Release the bus */ @@ -218,15 +239,15 @@ int i2c_read(u8 dev, uint addr, int alen, u8 *data, int length) return -ETIMEDOUT; } debug("Read %d bytes\n", - length - readl(&zynq_i2c->transfer_size)); - for (; i < length - readl(&zynq_i2c->transfer_size); i++) + len - readl(&zynq_i2c->transfer_size)); + for (; i < len - readl(&zynq_i2c->transfer_size); i++) *(cur_data++) = readl(&zynq_i2c->data); } while (readl(&zynq_i2c->transfer_size) != 0); /* All done... release the bus */ clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD);
#ifdef DEBUG - zynq_i2c_debug_status(); + zynq_i2c_debug_status(zynq_i2c); #endif return 0; } @@ -235,30 +256,35 @@ int i2c_read(u8 dev, uint addr, int alen, u8 *data, int length) * I2C write called by cmd_i2c when doing 'i2c write' and by cmd_eeprom.c * Begin write, send address byte(s), send data bytes, end. */ -int i2c_write(u8 dev, uint addr, int alen, u8 *data, int length) +static int zynq_i2c_write(struct i2c_adapter *adap, uint8_t chip, uint addr, + int alen, uint8_t *buffer, int len) { - u8 *cur_data = data; + struct zynq_i2c_registers *zynq_i2c; + u8 *cur_data = buffer; + + zynq_i2c = i2c_select(adap);
/* Write the register address */ setbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_CLR_FIFO | ZYNQ_I2C_CONTROL_HOLD); clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_RW); writel(0xFF, &zynq_i2c->interrupt_status); - while (alen--) - writel(addr >> (8*alen), &zynq_i2c->data); - /* Start the tranfer */ - writel(dev, &zynq_i2c->address); - if (!zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP)) { - /* Release the bus */ - clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); - return -ETIMEDOUT; + writel(chip, &zynq_i2c->address); + if (alen) { + while (alen--) + writel(addr >> (8*alen), &zynq_i2c->data); + /* Start the tranfer */ + if (!zynq_i2c_wait(zynq_i2c, ZYNQ_I2C_INTERRUPT_COMP)) { + /* Release the bus */ + clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); + return -ETIMEDOUT; + } + debug("Device acked address\n"); } - - debug("Device acked address\n"); - while (length--) { + while (len--) { writel(*(cur_data++), &zynq_i2c->data); if (readl(&zynq_i2c->transfer_size) == ZYNQ_I2C_FIFO_DEPTH) { - if (!zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP)) { + if (!zynq_i2c_wait(zynq_i2c, ZYNQ_I2C_INTERRUPT_COMP)) { /* Release the bus */ clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); @@ -270,21 +296,25 @@ int i2c_write(u8 dev, uint addr, int alen, u8 *data, int length) /* All done... release the bus */ clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); /* Wait for the address and data to be sent */ - if (!zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP)) + if (!zynq_i2c_wait(zynq_i2c, ZYNQ_I2C_INTERRUPT_COMP)) return -ETIMEDOUT; return 0; }
-int i2c_set_bus_num(unsigned int bus) +static uint zynq_i2c_set_bus_speed(struct i2c_adapter *adap, uint speed) { - /* Only support bus 0 */ - if (bus > 0) + /* struct zynq_i2c_registers *zynq_i2c = i2c_select(adap); */ + + /* Bus-speed selection is not implemented */ + if (speed != 100000) return -1; - return 0; -}
-unsigned int i2c_get_bus_num(void) -{ - /* Only support bus 0 */ return 0; } + +U_BOOT_I2C_ADAP_COMPLETE(ZYNQ_I2C0, zynq_i2c_init, zynq_i2c_probe, + zynq_i2c_read, zynq_i2c_write, + zynq_i2c_set_bus_speed, 100000, 0, 0) +U_BOOT_I2C_ADAP_COMPLETE(ZYNQ_I2C1, zynq_i2c_init, zynq_i2c_probe, + zynq_i2c_read, zynq_i2c_write, + zynq_i2c_set_bus_speed, 100000, 0, 1) diff --git a/include/i2c.h b/include/i2c.h index 8fd17d1..683affe 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -40,6 +40,7 @@ #define CONFIG_SYS_I2C_MAX_HOPS 0 #define CONFIG_SYS_NUM_I2C_BUSES ll_entry_count(struct i2c_adapter, i2c) #else + /* we use i2c muxes */ #undef CONFIG_SYS_I2C_DIRECT_BUS #endif @@ -135,6 +136,8 @@ extern struct i2c_bus_hose i2c_bus[]; #define I2C_MUX_PCA9544 {I2C_MUX_PCA9544_ID, "PCA9544A"} #define I2C_MUX_PCA9547_ID 4 #define I2C_MUX_PCA9547 {I2C_MUX_PCA9547_ID, "PCA9547A"} +#define I2C_MUX_PCA9548_ID 5 +#define I2C_MUX_PCA9548 {I2C_MUX_PCA9548_ID, "PCA9548"} #endif
#ifndef I2C_SOFT_DECLARATIONS
Hello Michael,
Am 20.09.2013 22:40, schrieb Michael Burr:
Your commit message implements, that your patch contains 3 independent changes ... it would be better to seperate your patch in 3 pieces ... so if your patch introduces a problem, it is better to identify, which part it introduced ...
Can you do this easy? Except of this, I have only one minor Codingstyle comment
? Where can I find this repository?
Signed-off-by: Michael Burrmichael.burr@logicpd.com Cc: Heiko Schocherhs@denx.de Cc: Michal Simekmonstr@monstr.eu
Change not needed!
bye, Heiko
See below... (My replies are tagged with "[MRB:]".)
Michael Burr // Software Engineer II
Logic PD T // 612.436.7273 NOTICE: Important disclaimers and limitations apply to this email. Please see this web page for our disclaimers and limitations: http://logicpd.com/email-disclaimer/
-----Original Message----- From: Heiko Schocher [mailto:hs@denx.de] Sent: Sunday, September 22, 2013 2:33 AM To: Michael Burr Cc: u-boot@lists.denx.de; Michal Simek Subject: Re: [PATCH] i2c:zynq: I2C multi-bus support on Zynq
Hello Michael,
[MRB:] I will give it a try...
[MRB:] At the following address. (I believe Michal Simek is the person who manages this.)
http://github.com/Xilinx/u-boot-xlnx/
Change not needed!
[MRB:] Oops. I'll get rid of that...
bye, Heiko
That's xilinx repo. But you should remove this from commit message. If there is something wrong in the mainline u-boot initialization in connection to this you should send patch for it. As I wrote you in other email we are going to invest our time to sync configuration from this repo with mainline in the next merge window because also these changes when they are reviewed will go to the next u-boot version.
Thanks, Michal
Sorry, Michal
I only wrote that part to explain how I was able to test on the ZC702 board (in case somebody else should want to reproduce the results).
I understand that you will sync the 'u-boot-xlnx' repo with mainline at some time in the future, on your own schedule. I was not trying to suggest that anything else be done right now.
Thanks again for your feedback,
-----Original Message----- From: Michal Simek [mailto:monstr@monstr.eu] Sent: Tuesday, September 24, 2013 3:31 AM To: Michael Burr Cc: hs@denx.de; u-boot@lists.denx.de Subject: Re: [PATCH] i2c:zynq: I2C multi-bus support on Zynq
Thanks, Michal
-- Michal Simek, Ing. (M.Eng), OpenPGP -> KeyID: FE3D1F91 w: www.monstr.eu p: +42-0-721842854 Maintainer of Linux kernel - Microblaze cpu - http://www.monstr.eu/fdt/ Maintainer of Linux kernel - Xilinx Zynq ARM architecture Microblaze U-BOOT custodian and responsible for u-boot arm zynq platform
On 09/24/2013 04:58 PM, Michael Burr wrote:
Sorry, Michal
I got this but keep in your mind that Heiko or others will apply this patch by git-am and your commit message will be the part of u-boot source code. That's why there should be focus on problems which you are trying to solve.
If you need to point/explain something then write it below your SoB line and below "---" which ensure that git-am will remove these messages.
I would suggest to you to run git format-patch and then running git am < patch to see what will be there.
Thanks, Michal
Oh, OK. I see what you mean. I'm still very new to this process, so it takes some practice to "learn the customs". Thanks for clarifying.
So, in future I will keep those explanations below the "---" line.
-----Original Message----- From: Michal Simek [mailto:monstr@monstr.eu] Sent: Tuesday, September 24, 2013 10:19 AM To: Michael Burr Cc: hs@denx.de; u-boot@lists.denx.de Subject: Re: [PATCH] i2c:zynq: I2C multi-bus support on Zynq
Sorry, Michal
Thanks, Michal
Heiko Schocher
Michael Burr
Michal Simek
