[PATCH v2 00/21] Add i.MXRT family support
This patchset add support for i.MXRT family starting from i.MXRT1050 SoC. It provides: - i.MXRT1050 SoC entry - i.MXRT pinctrl driver - i.MXRT serial driver tweaking - i.MXRT sdram controller driver - i.MXRT usdhc driver tweaking - i.MXRT1050-evk initial support
It uses all DM clocks all around and it loads correctly a basic Linux zImage.
Changes: V1->V2: * added gpio driver adaption * fixed potential failure on lpuart get_clock() if DM is not used * introduced CONFIG_IMXRT and CONFIG_IMXRT1050 to prevent using ARCH_IMXRT * removed lcd enabling from defconfig(it's still not available) * added -u-boot.dtsi for imxrt1050-evk.dts board * re-grouped some patch separating support for board and support for i.MXRT family
Giulio Benetti (21): spl: fix entry_point equal to load_addr armv7m: cache: add mmu_set_region_dcache_behaviour() stub for compatibility clk: imx: pllv3: register PLLV3 GENERIC and USB as 2 different clocks clk: imx: pllv3: set div_mask differently if PLLV3 is GENERIC or USB clk: imx: pllv3: add enable() support clk: imx: pllv3: add disable() support clk: imx: pllv3: add set_rate() support clk: imx: pllv3: add PLLV3_SYS support clk: imx: pllv3: add support for PLLV3_AV type clk: imx: pfd: add set_rate() clk: imx: add i.IMXRT1050 clk driver pinctrl: add i.MXRT driver gpio: mxc_gpio: add support for i.MXRT1050 ARM: dts: imxrt1050: add dtsi file serial_lpuart: add clock enable if CONFIG_CLK is defined serial_lpuart: add support for i.MXRT ram: add SDRAM driver for i.MXRT SoCs mmc: fsl_esdhc: make if(CONFIG_IS_ENABLED(CLK)) an #if statement mmc: fsl_esdhc: add compatible for fsl, imxrt-usdhc imx: Add basic support for the NXP IMXRT10xx SoC family imx: imxrt1050-evk: Add support for the NXP i.MXRT1050-EVK
arch/arm/Kconfig | 10 + arch/arm/Makefile | 4 +- arch/arm/cpu/armv7m/cache.c | 6 + arch/arm/dts/Makefile | 2 + arch/arm/dts/imxrt1050-evk-u-boot.dtsi | 44 + arch/arm/dts/imxrt1050-evk.dts | 200 ++++ arch/arm/dts/imxrt1050.dtsi | 146 +++ arch/arm/include/asm/arch-imxrt/clock.h | 10 + arch/arm/include/asm/arch-imxrt/gpio.h | 19 + arch/arm/include/asm/arch-imxrt/imx-regs.h | 20 + arch/arm/include/asm/arch-imxrt/imxrt.h | 11 + arch/arm/include/asm/arch-imxrt/sys_proto.h | 11 + arch/arm/mach-imx/Makefile | 3 +- arch/arm/mach-imx/imxrt/Kconfig | 25 + arch/arm/mach-imx/imxrt/Makefile | 7 + arch/arm/mach-imx/imxrt/soc.c | 35 + board/freescale/imxrt1050-evk/Kconfig | 22 + board/freescale/imxrt1050-evk/MAINTAINERS | 6 + board/freescale/imxrt1050-evk/Makefile | 6 + board/freescale/imxrt1050-evk/README | 31 + board/freescale/imxrt1050-evk/imximage.cfg | 36 + board/freescale/imxrt1050-evk/imxrt1050-evk.c | 81 ++ common/spl/spl.c | 4 +- configs/imxrt1050-evk_defconfig | 69 ++ drivers/clk/imx/Kconfig | 16 + drivers/clk/imx/Makefile | 2 + drivers/clk/imx/clk-imxrt1050.c | 292 +++++ drivers/clk/imx/clk-pfd.c | 22 + drivers/clk/imx/clk-pllv3.c | 218 +++- drivers/gpio/mxc_gpio.c | 7 +- drivers/mmc/Kconfig | 2 +- drivers/mmc/fsl_esdhc_imx.c | 41 +- drivers/pinctrl/nxp/Kconfig | 14 + drivers/pinctrl/nxp/Makefile | 1 + drivers/pinctrl/nxp/pinctrl-imxrt.c | 40 + drivers/ram/Kconfig | 8 + drivers/ram/Makefile | 2 + drivers/ram/imxrt_sdram.c | 439 ++++++++ drivers/serial/serial_lpuart.c | 31 +- include/configs/imxrt1050-evk.h | 46 + include/dt-bindings/clock/imxrt1050-clock.h | 65 ++ include/dt-bindings/memory/imxrt-sdram.h | 100 ++ include/dt-bindings/pinctrl/pins-imxrt1050.h | 993 ++++++++++++++++++ include/fsl_lpuart.h | 3 +- 44 files changed, 3111 insertions(+), 39 deletions(-) create mode 100644 arch/arm/dts/imxrt1050-evk-u-boot.dtsi create mode 100644 arch/arm/dts/imxrt1050-evk.dts create mode 100644 arch/arm/dts/imxrt1050.dtsi create mode 100644 arch/arm/include/asm/arch-imxrt/clock.h create mode 100644 arch/arm/include/asm/arch-imxrt/gpio.h create mode 100644 arch/arm/include/asm/arch-imxrt/imx-regs.h create mode 100644 arch/arm/include/asm/arch-imxrt/imxrt.h create mode 100644 arch/arm/include/asm/arch-imxrt/sys_proto.h create mode 100644 arch/arm/mach-imx/imxrt/Kconfig create mode 100644 arch/arm/mach-imx/imxrt/Makefile create mode 100644 arch/arm/mach-imx/imxrt/soc.c create mode 100644 board/freescale/imxrt1050-evk/Kconfig create mode 100644 board/freescale/imxrt1050-evk/MAINTAINERS create mode 100644 board/freescale/imxrt1050-evk/Makefile create mode 100644 board/freescale/imxrt1050-evk/README create mode 100644 board/freescale/imxrt1050-evk/imximage.cfg create mode 100644 board/freescale/imxrt1050-evk/imxrt1050-evk.c create mode 100644 configs/imxrt1050-evk_defconfig create mode 100644 drivers/clk/imx/clk-imxrt1050.c create mode 100644 drivers/pinctrl/nxp/pinctrl-imxrt.c create mode 100644 drivers/ram/imxrt_sdram.c create mode 100644 include/configs/imxrt1050-evk.h create mode 100644 include/dt-bindings/clock/imxrt1050-clock.h create mode 100644 include/dt-bindings/memory/imxrt-sdram.h create mode 100644 include/dt-bindings/pinctrl/pins-imxrt1050.h
At the moment entry_point is set to image_get_load(header) that sets it to "load address" instead of "entry point", assuming entry_point is equal to load_addr, but it's not true. Then load_addr is set to "entry_point - header_size", but this is wrong too since load_addr is not an entry point.
So use image_get_ep() for entry_point assignment and image_get_load() for load_addr assignment.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- common/spl/spl.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index c1fce62b91..19085ad270 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -284,9 +284,9 @@ int spl_parse_image_header(struct spl_image_info *spl_image, spl_image->entry_point = image_get_ep(header); spl_image->size = image_get_data_size(header); } else { - spl_image->entry_point = image_get_load(header); + spl_image->entry_point = image_get_ep(header); /* Load including the header */ - spl_image->load_addr = spl_image->entry_point - + spl_image->load_addr = image_get_load(header) - header_size; spl_image->size = image_get_data_size(header) + header_size;
At the moment entry_point is set to image_get_load(header) that sets it to "load address" instead of "entry point", assuming entry_point is equal to load_addr, but it's not true. Then load_addr is set to "entry_point - header_size", but this is wrong too since load_addr is not an entry point. So use image_get_ep() for entry_point assignment and image_get_load() for load_addr assignment. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com
Best regards, Stefano Babic
Hi Giulio,
I'm concerned, that this change will silently break several boards - the problem is with assumption that entry point is equal to load_addr.
It would be best to pull this change ASAP, so we would have a chance to fix this by next release.
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Hi Lukasz,
all patch series has already been applied, anyway I answer to your suggestions since something was missing and I'm going to create a patch for that.
So...
On 1/28/20 9:09 AM, Lukasz Majewski wrote:
Hi Giulio,
It's been committed after Patrice fixed a lot of boards: https://gitlab.denx.de/u-boot/u-boot/commit/38a6cce65737096b836d43a22f09b7a5... and https://gitlab.denx.de/u-boot/u-boot/commit/74bb4570a952b06fecfafc5b961a5cb5...
Indeed at the first moment it's been committed by Tom Rini and started to cause boot failure as you were worried for, then it's been reverted, then it's been re-applied after applying Patrice series.
Best regards
On Tue, 28 Jan 2020 17:37:17 +0100 Giulio Benetti giulio.benetti@benettiengineering.com wrote:
Hi Lukasz,
So...
Hi Giulio,
Ach... Ok. No problem then.
Best regards
Lukasz Majewski
Since some driver requires this function add it as an empty stub when DCACHE is OFF.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/cpu/armv7m/cache.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/cpu/armv7m/cache.c b/arch/arm/cpu/armv7m/cache.c index f4ba3ad50e..7353698557 100644 --- a/arch/arm/cpu/armv7m/cache.c +++ b/arch/arm/cpu/armv7m/cache.c @@ -291,6 +291,12 @@ void flush_dcache_all(void) void invalidate_dcache_all(void) { } + +void mmu_set_region_dcache_behaviour(phys_addr_t start, size_t size, + enum dcache_option option) +{ +} + #endif
#if !CONFIG_IS_ENABLED(SYS_ICACHE_OFF)
Since some driver requires this function add it as an empty stub when DCACHE is OFF. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com
Hi Giulio,
Since some driver
I would prefer more verbose commit message. Please share which driver requires this change.
#endif
Lukasz Majewski
On 1/28/20 9:10 AM, Lukasz Majewski wrote:
Hi Giulio,
Since some driver
Yes, you were right, this is a quite dumb commit log.
Now commit log can't be changed, anyway this is the list of drivers that use it: drivers/video/mvebu_lcd.c drivers/video/mxsfb.c (that I'm going to use soon) drivers/video/bcm2835.c drivers/video/fsl_dcu_fb.c drivers/video/tegra.c drivers/video/imx/mxc_ipuv3_fb.c
drivers/net/zynq_gem.c drivers/net/mvneta.c drivers/net/mvpp2.c
And this function prototype is provided by arch/arm/include/asm/system.h
Everything came out when I've tried to build mxsfb.c.
But after this e-mail I've dug deeper and see that sometimes mmu_set_region_dcache_behaviour() call is guarded by CONFIG_IS_ENABLED(SYS_DCACHE_OFF) and sometimes i.e. arch/arm/cpu/armv8/cache_v8.c that function is defined both implemented and empty according to CONFIG_IS_ENABLED(SYS_DCACHE_OFF). So one chance is to put a check to guard against CONFIG_IS_ENABLED(SYS_DCACHE_OFF) on every call(the files listed above), otherwise, where is guarded we should remove the guard and adding missing mmu_set_region_dcache_behaviour() empty implementation. ~5 files to touch, but if you say it's worth, I can do patches for that, and I don't see any drawbacks expect having a standard way on dealing with the cache function.
What about that?
Kind regards
On Tue, 28 Jan 2020 17:50:03 +0100 Giulio Benetti giulio.benetti@benettiengineering.com wrote:
Hi Giulio,
Since some driver
What about that?
IMHO, it would be best to to this change when you decide to add support for DCACHE/ICACHE on this SoC.
Kind regards
Lukasz Majewski
Better to register the 2 clock as 2 different drivers because they work slightly differently depending on power_bit and powerup_set bits coming on next patches.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Lukasz Majewski lukma@denx.de --- drivers/clk/imx/clk-pllv3.c | 20 +++++++++++++++----- 1 file changed, 15 insertions(+), 5 deletions(-)
diff --git a/drivers/clk/imx/clk-pllv3.c b/drivers/clk/imx/clk-pllv3.c index fbb7b24d5e..d1e4c3fe30 100644 --- a/drivers/clk/imx/clk-pllv3.c +++ b/drivers/clk/imx/clk-pllv3.c @@ -13,7 +13,8 @@ #include <clk.h> #include "clk.h"
-#define UBOOT_DM_CLK_IMX_PLLV3 "imx_clk_pllv3" +#define UBOOT_DM_CLK_IMX_PLLV3_GENERIC "imx_clk_pllv3_generic" +#define UBOOT_DM_CLK_IMX_PLLV3_USB "imx_clk_pllv3_usb"
struct clk_pllv3 { struct clk clk; @@ -24,7 +25,7 @@ struct clk_pllv3 {
#define to_clk_pllv3(_clk) container_of(_clk, struct clk_pllv3, clk)
-static ulong clk_pllv3_get_rate(struct clk *clk) +static ulong clk_pllv3_generic_get_rate(struct clk *clk) { struct clk_pllv3 *pll = to_clk_pllv3(dev_get_clk_ptr(clk->dev)); unsigned long parent_rate = clk_get_parent_rate(clk); @@ -35,7 +36,7 @@ static ulong clk_pllv3_get_rate(struct clk *clk) }
static const struct clk_ops clk_pllv3_generic_ops = { - .get_rate = clk_pllv3_get_rate, + .get_rate = clk_pllv3_generic_get_rate, };
struct clk *imx_clk_pllv3(enum imx_pllv3_type type, const char *name, @@ -53,8 +54,10 @@ struct clk *imx_clk_pllv3(enum imx_pllv3_type type, const char *name,
switch (type) { case IMX_PLLV3_GENERIC: + drv_name = UBOOT_DM_CLK_IMX_PLLV3_GENERIC; + break; case IMX_PLLV3_USB: - drv_name = UBOOT_DM_CLK_IMX_PLLV3; + drv_name = UBOOT_DM_CLK_IMX_PLLV3_USB; break; default: kfree(pll); @@ -75,7 +78,14 @@ struct clk *imx_clk_pllv3(enum imx_pllv3_type type, const char *name, }
U_BOOT_DRIVER(clk_pllv3_generic) = { - .name = UBOOT_DM_CLK_IMX_PLLV3, + .name = UBOOT_DM_CLK_IMX_PLLV3_GENERIC, + .id = UCLASS_CLK, + .ops = &clk_pllv3_generic_ops, + .flags = DM_FLAG_PRE_RELOC, +}; + +U_BOOT_DRIVER(clk_pllv3_usb) = { + .name = UBOOT_DM_CLK_IMX_PLLV3_USB, .id = UCLASS_CLK, .ops = &clk_pllv3_generic_ops, .flags = DM_FLAG_PRE_RELOC,
Better to register the 2 clock as 2 different drivers because they work slightly differently depending on power_bit and powerup_set bits coming on next patches. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Lukasz Majewski lukma@denx.de
div_mask is different for GENERIC and USB pll, so set it according.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Lukasz Majewski lukma@denx.de --- drivers/clk/imx/clk-pllv3.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/clk/imx/clk-pllv3.c b/drivers/clk/imx/clk-pllv3.c index d1e4c3fe30..02c75c37ea 100644 --- a/drivers/clk/imx/clk-pllv3.c +++ b/drivers/clk/imx/clk-pllv3.c @@ -55,9 +55,11 @@ struct clk *imx_clk_pllv3(enum imx_pllv3_type type, const char *name, switch (type) { case IMX_PLLV3_GENERIC: drv_name = UBOOT_DM_CLK_IMX_PLLV3_GENERIC; + pll->div_shift = 0; break; case IMX_PLLV3_USB: drv_name = UBOOT_DM_CLK_IMX_PLLV3_USB; + pll->div_shift = 1; break; default: kfree(pll);
div_mask is different for GENERIC and USB pll, so set it according. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Lukasz Majewski lukma@denx.de
Before set_rate() pllv3 needs enable() to power the pll up. Add enable() taking into account different power_bit and different powerup_set, because some pll needs its power_bit to be set or reset to be powered on.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- drivers/clk/imx/clk-pllv3.c | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+)
diff --git a/drivers/clk/imx/clk-pllv3.c b/drivers/clk/imx/clk-pllv3.c index 02c75c37ea..d8cbe3dd4e 100644 --- a/drivers/clk/imx/clk-pllv3.c +++ b/drivers/clk/imx/clk-pllv3.c @@ -16,9 +16,13 @@ #define UBOOT_DM_CLK_IMX_PLLV3_GENERIC "imx_clk_pllv3_generic" #define UBOOT_DM_CLK_IMX_PLLV3_USB "imx_clk_pllv3_usb"
+#define BM_PLL_POWER (0x1 << 12) + struct clk_pllv3 { struct clk clk; void __iomem *base; + u32 power_bit; + bool powerup_set; u32 div_mask; u32 div_shift; }; @@ -35,8 +39,24 @@ static ulong clk_pllv3_generic_get_rate(struct clk *clk) return (div == 1) ? parent_rate * 22 : parent_rate * 20; }
+static int clk_pllv3_generic_enable(struct clk *clk) +{ + struct clk_pllv3 *pll = to_clk_pllv3(clk); + u32 val; + + val = readl(pll->base); + if (pll->powerup_set) + val |= pll->power_bit; + else + val &= ~pll->power_bit; + writel(val, pll->base); + + return 0; +} + static const struct clk_ops clk_pllv3_generic_ops = { .get_rate = clk_pllv3_generic_get_rate, + .enable = clk_pllv3_generic_enable, };
struct clk *imx_clk_pllv3(enum imx_pllv3_type type, const char *name, @@ -52,14 +72,18 @@ struct clk *imx_clk_pllv3(enum imx_pllv3_type type, const char *name, if (!pll) return ERR_PTR(-ENOMEM);
+ pll->power_bit = BM_PLL_POWER; + switch (type) { case IMX_PLLV3_GENERIC: drv_name = UBOOT_DM_CLK_IMX_PLLV3_GENERIC; pll->div_shift = 0; + pll->powerup_set = false; break; case IMX_PLLV3_USB: drv_name = UBOOT_DM_CLK_IMX_PLLV3_USB; pll->div_shift = 1; + pll->powerup_set = true; break; default: kfree(pll);
Before set_rate() pllv3 needs enable() to power the pll up. Add enable() taking into account different power_bit and different powerup_set, because some pll needs its power_bit to be set or reset to be powered on. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com
Hi Giulio,
I do guess that this code is similar to what we do have in the Linux kernel (and which I've probably omitted as it was not needed in the i.MX6Q use case)?
- u32 power_bit;
- bool powerup_set; u32 div_mask; u32 div_shift;
- struct clk_pllv3 *pll = to_clk_pllv3(clk);
- u32 val;
- val = readl(pll->base);
- if (pll->powerup_set)
- else
- writel(val, pll->base);
- .enable = clk_pllv3_generic_enable,
- pll->power_bit = BM_PLL_POWER;
- switch (type) { case IMX_PLLV3_GENERIC: drv_name = UBOOT_DM_CLK_IMX_PLLV3_GENERIC; pll->div_shift = 0;
break; case IMX_PLLV3_USB: drv_name = UBOOT_DM_CLK_IMX_PLLV3_USB; pll->div_shift = 1;pll->powerup_set = false;
break; default: kfree(pll);pll->powerup_set = true;
Lukasz Majewski
On 1/28/20 9:14 AM, Lukasz Majewski wrote:
Hi Giulio,
Exactly, in i.MXRT case need a different enabling sequence and this can be useful for other i.MX families.
Best regards
Add disable() support.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Lukasz Majewski lukma@denx.de --- drivers/clk/imx/clk-pllv3.c | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/drivers/clk/imx/clk-pllv3.c b/drivers/clk/imx/clk-pllv3.c index d8cbe3dd4e..9b37cd9cd9 100644 --- a/drivers/clk/imx/clk-pllv3.c +++ b/drivers/clk/imx/clk-pllv3.c @@ -54,9 +54,25 @@ static int clk_pllv3_generic_enable(struct clk *clk) return 0; }
+static int clk_pllv3_generic_disable(struct clk *clk) +{ + struct clk_pllv3 *pll = to_clk_pllv3(clk); + u32 val; + + val = readl(pll->base); + if (pll->powerup_set) + val &= ~pll->power_bit; + else + val |= pll->power_bit; + writel(val, pll->base); + + return 0; +} + static const struct clk_ops clk_pllv3_generic_ops = { .get_rate = clk_pllv3_generic_get_rate, .enable = clk_pllv3_generic_enable, + .disable = clk_pllv3_generic_disable, };
Add disable() support. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Lukasz Majewski lukma@denx.de
Add generic set_rate() support.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Lukasz Majewski lukma@denx.de --- drivers/clk/imx/clk-pllv3.c | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+)
diff --git a/drivers/clk/imx/clk-pllv3.c b/drivers/clk/imx/clk-pllv3.c index 9b37cd9cd9..a721dbee94 100644 --- a/drivers/clk/imx/clk-pllv3.c +++ b/drivers/clk/imx/clk-pllv3.c @@ -17,6 +17,7 @@ #define UBOOT_DM_CLK_IMX_PLLV3_USB "imx_clk_pllv3_usb"
#define BM_PLL_POWER (0x1 << 12) +#define BM_PLL_LOCK (0x1 << 31)
struct clk_pllv3 { struct clk clk; @@ -39,6 +40,31 @@ static ulong clk_pllv3_generic_get_rate(struct clk *clk) return (div == 1) ? parent_rate * 22 : parent_rate * 20; }
+static ulong clk_pllv3_generic_set_rate(struct clk *clk, ulong rate) +{ + struct clk_pllv3 *pll = to_clk_pllv3(clk); + unsigned long parent_rate = clk_get_parent_rate(clk); + u32 val, div; + + if (rate == parent_rate * 22) + div = 1; + else if (rate == parent_rate * 20) + div = 0; + else + return -EINVAL; + + val = readl(pll->base); + val &= ~(pll->div_mask << pll->div_shift); + val |= (div << pll->div_shift); + writel(val, pll->base); + + /* Wait for PLL to lock */ + while (!(readl(pll->base) & BM_PLL_LOCK)) + ; + + return 0; +} + static int clk_pllv3_generic_enable(struct clk *clk) { struct clk_pllv3 *pll = to_clk_pllv3(clk); @@ -73,6 +99,7 @@ static const struct clk_ops clk_pllv3_generic_ops = { .get_rate = clk_pllv3_generic_get_rate, .enable = clk_pllv3_generic_enable, .disable = clk_pllv3_generic_disable, + .set_rate = clk_pllv3_generic_set_rate, };
Add generic set_rate() support. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Lukasz Majewski lukma@denx.de
Add PLLV3_SYS support by adding set/get_rate() for PLLV3_SYS but keeping generic enable()/disable(). Add a different driver because ops are different respect to GENERIC/USB.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Lukasz Majewski lukma@denx.de --- drivers/clk/imx/clk-pllv3.c | 53 +++++++++++++++++++++++++++++++++++++ 1 file changed, 53 insertions(+)
diff --git a/drivers/clk/imx/clk-pllv3.c b/drivers/clk/imx/clk-pllv3.c index a721dbee94..d5087a104e 100644 --- a/drivers/clk/imx/clk-pllv3.c +++ b/drivers/clk/imx/clk-pllv3.c @@ -14,6 +14,7 @@ #include "clk.h"
#define UBOOT_DM_CLK_IMX_PLLV3_GENERIC "imx_clk_pllv3_generic" +#define UBOOT_DM_CLK_IMX_PLLV3_SYS "imx_clk_pllv3_sys" #define UBOOT_DM_CLK_IMX_PLLV3_USB "imx_clk_pllv3_usb"
#define BM_PLL_POWER (0x1 << 12) @@ -102,6 +103,46 @@ static const struct clk_ops clk_pllv3_generic_ops = { .set_rate = clk_pllv3_generic_set_rate, };
+static ulong clk_pllv3_sys_get_rate(struct clk *clk) +{ + struct clk_pllv3 *pll = to_clk_pllv3(clk); + unsigned long parent_rate = clk_get_parent_rate(clk); + u32 div = readl(pll->base) & pll->div_mask; + + return parent_rate * div / 2; +} + +static ulong clk_pllv3_sys_set_rate(struct clk *clk, ulong rate) +{ + struct clk_pllv3 *pll = to_clk_pllv3(clk); + unsigned long parent_rate = clk_get_parent_rate(clk); + unsigned long min_rate = parent_rate * 54 / 2; + unsigned long max_rate = parent_rate * 108 / 2; + u32 val, div; + + if (rate < min_rate || rate > max_rate) + return -EINVAL; + + div = rate * 2 / parent_rate; + val = readl(pll->base); + val &= ~pll->div_mask; + val |= div; + writel(val, pll->base); + + /* Wait for PLL to lock */ + while (!(readl(pll->base) & BM_PLL_LOCK)) + ; + + return 0; +} + +static const struct clk_ops clk_pllv3_sys_ops = { + .enable = clk_pllv3_generic_enable, + .disable = clk_pllv3_generic_disable, + .get_rate = clk_pllv3_sys_get_rate, + .set_rate = clk_pllv3_sys_set_rate, +}; + struct clk *imx_clk_pllv3(enum imx_pllv3_type type, const char *name, const char *parent_name, void __iomem *base, u32 div_mask) @@ -123,6 +164,11 @@ struct clk *imx_clk_pllv3(enum imx_pllv3_type type, const char *name, pll->div_shift = 0; pll->powerup_set = false; break; + case IMX_PLLV3_SYS: + drv_name = UBOOT_DM_CLK_IMX_PLLV3_SYS; + pll->div_shift = 0; + pll->powerup_set = false; + break; case IMX_PLLV3_USB: drv_name = UBOOT_DM_CLK_IMX_PLLV3_USB; pll->div_shift = 1; @@ -153,6 +199,13 @@ U_BOOT_DRIVER(clk_pllv3_generic) = { .flags = DM_FLAG_PRE_RELOC, };
+U_BOOT_DRIVER(clk_pllv3_sys) = { + .name = UBOOT_DM_CLK_IMX_PLLV3_SYS, + .id = UCLASS_CLK, + .ops = &clk_pllv3_sys_ops, + .flags = DM_FLAG_PRE_RELOC, +}; + U_BOOT_DRIVER(clk_pllv3_usb) = { .name = UBOOT_DM_CLK_IMX_PLLV3_USB, .id = UCLASS_CLK,
Add PLLV3_SYS support by adding set/get_rate() for PLLV3_SYS but keeping generic enable()/disable(). Add a different driver because ops are different respect to GENERIC/USB. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Lukasz Majewski lukma@denx.de
Add support for PLLV3 AV type.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- drivers/clk/imx/clk-pllv3.c | 76 +++++++++++++++++++++++++++++++++++++ 1 file changed, 76 insertions(+)
diff --git a/drivers/clk/imx/clk-pllv3.c b/drivers/clk/imx/clk-pllv3.c index d5087a104e..fc16416d5f 100644 --- a/drivers/clk/imx/clk-pllv3.c +++ b/drivers/clk/imx/clk-pllv3.c @@ -6,6 +6,7 @@
#include <common.h> #include <asm/io.h> +#include <div64.h> #include <malloc.h> #include <clk-uclass.h> #include <dm/device.h> @@ -16,6 +17,10 @@ #define UBOOT_DM_CLK_IMX_PLLV3_GENERIC "imx_clk_pllv3_generic" #define UBOOT_DM_CLK_IMX_PLLV3_SYS "imx_clk_pllv3_sys" #define UBOOT_DM_CLK_IMX_PLLV3_USB "imx_clk_pllv3_usb" +#define UBOOT_DM_CLK_IMX_PLLV3_AV "imx_clk_pllv3_av" + +#define PLL_NUM_OFFSET 0x10 +#define PLL_DENOM_OFFSET 0x20
#define BM_PLL_POWER (0x1 << 12) #define BM_PLL_LOCK (0x1 << 31) @@ -143,6 +148,65 @@ static const struct clk_ops clk_pllv3_sys_ops = { .set_rate = clk_pllv3_sys_set_rate, };
+static ulong clk_pllv3_av_get_rate(struct clk *clk) +{ + struct clk_pllv3 *pll = to_clk_pllv3(clk); + unsigned long parent_rate = clk_get_parent_rate(clk); + u32 mfn = readl(pll->base + PLL_NUM_OFFSET); + u32 mfd = readl(pll->base + PLL_DENOM_OFFSET); + u32 div = readl(pll->base) & pll->div_mask; + u64 temp64 = (u64)parent_rate; + + temp64 *= mfn; + do_div(temp64, mfd); + + return parent_rate * div + (unsigned long)temp64; +} + +static ulong clk_pllv3_av_set_rate(struct clk *clk, ulong rate) +{ + struct clk_pllv3 *pll = to_clk_pllv3(clk); + unsigned long parent_rate = clk_get_parent_rate(clk); + unsigned long min_rate = parent_rate * 27; + unsigned long max_rate = parent_rate * 54; + u32 val, div; + u32 mfn, mfd = 1000000; + u32 max_mfd = 0x3FFFFFFF; + u64 temp64; + + if (rate < min_rate || rate > max_rate) + return -EINVAL; + + if (parent_rate <= max_mfd) + mfd = parent_rate; + + div = rate / parent_rate; + temp64 = (u64)(rate - div * parent_rate); + temp64 *= mfd; + do_div(temp64, parent_rate); + mfn = temp64; + + val = readl(pll->base); + val &= ~pll->div_mask; + val |= div; + writel(val, pll->base); + writel(mfn, pll->base + PLL_NUM_OFFSET); + writel(mfd, pll->base + PLL_DENOM_OFFSET); + + /* Wait for PLL to lock */ + while (!(readl(pll->base) & BM_PLL_LOCK)) + ; + + return 0; +} + +static const struct clk_ops clk_pllv3_av_ops = { + .enable = clk_pllv3_generic_enable, + .disable = clk_pllv3_generic_disable, + .get_rate = clk_pllv3_av_get_rate, + .set_rate = clk_pllv3_av_set_rate, +}; + struct clk *imx_clk_pllv3(enum imx_pllv3_type type, const char *name, const char *parent_name, void __iomem *base, u32 div_mask) @@ -174,6 +238,11 @@ struct clk *imx_clk_pllv3(enum imx_pllv3_type type, const char *name, pll->div_shift = 1; pll->powerup_set = true; break; + case IMX_PLLV3_AV: + drv_name = UBOOT_DM_CLK_IMX_PLLV3_AV; + pll->div_shift = 0; + pll->powerup_set = false; + break; default: kfree(pll); return ERR_PTR(-ENOTSUPP); @@ -212,3 +281,10 @@ U_BOOT_DRIVER(clk_pllv3_usb) = { .ops = &clk_pllv3_generic_ops, .flags = DM_FLAG_PRE_RELOC, }; + +U_BOOT_DRIVER(clk_pllv3_av) = { + .name = UBOOT_DM_CLK_IMX_PLLV3_AV, + .id = UCLASS_CLK, + .ops = &clk_pllv3_av_ops, + .flags = DM_FLAG_PRE_RELOC, +};
Add support for PLLV3 AV type. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com
Hi Giulio,
If this code has been ported from Linux kernel, then provide SHA1, branch, and commit message.
Acked-by: Lukasz Majewski lukma@denx.de
- unsigned long parent_rate = clk_get_parent_rate(clk);
- u32 mfn = readl(pll->base + PLL_NUM_OFFSET);
- u32 mfd = readl(pll->base + PLL_DENOM_OFFSET);
- u32 div = readl(pll->base) & pll->div_mask;
- u64 temp64 = (u64)parent_rate;
- temp64 *= mfn;
- do_div(temp64, mfd);
- return parent_rate * div + (unsigned long)temp64;
- unsigned long min_rate = parent_rate * 27;
- unsigned long max_rate = parent_rate * 54;
- u32 val, div;
- u32 mfn, mfd = 1000000;
- u32 max_mfd = 0x3FFFFFFF;
- u64 temp64;
- if (rate < min_rate || rate > max_rate)
return -EINVAL;
- if (parent_rate <= max_mfd)
mfd = parent_rate;
- div = rate / parent_rate;
- temp64 = (u64)(rate - div * parent_rate);
- temp64 *= mfd;
- do_div(temp64, parent_rate);
- mfn = temp64;
- val &= ~pll->div_mask;
- val |= div;
- writel(mfn, pll->base + PLL_NUM_OFFSET);
- writel(mfd, pll->base + PLL_DENOM_OFFSET);
- /* Wait for PLL to lock */
- while (!(readl(pll->base) & BM_PLL_LOCK))
- .disable = clk_pllv3_generic_disable,
- .get_rate = clk_pllv3_av_get_rate,
- .set_rate = clk_pllv3_av_set_rate,
- case IMX_PLLV3_AV:
pll->div_shift = 0;
default: kfree(pll); return ERR_PTR(-ENOTSUPP);break;
- .name = UBOOT_DM_CLK_IMX_PLLV3_AV,
- .id = UCLASS_CLK,
- .ops = &clk_pllv3_av_ops,
- .flags = DM_FLAG_PRE_RELOC,
Lukasz Majewski
Hi Lukasz,
On 1/28/20 9:20 AM, Lukasz Majewski wrote:
Hi Giulio,
Oh sorry,
Code taken from Linux with below commit: "ARM: imx: add common clock support for pllv3" (sha1: a3f6b9dbf2a964b85f0523e577807d6f63d6b29d)
Hope this way is ok, I imitated other commit logs in u-boot.
Best regards
Implement set_rate() for pfd.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Lukasz Majewski lukma@denx.de --- drivers/clk/imx/clk-pfd.c | 22 ++++++++++++++++++++++ 1 file changed, 22 insertions(+)
diff --git a/drivers/clk/imx/clk-pfd.c b/drivers/clk/imx/clk-pfd.c index 188b2b3b90..4ae55f5a07 100644 --- a/drivers/clk/imx/clk-pfd.c +++ b/drivers/clk/imx/clk-pfd.c @@ -52,8 +52,30 @@ static unsigned long clk_pfd_recalc_rate(struct clk *clk) return tmp; }
+static unsigned long clk_pfd_set_rate(struct clk *clk, unsigned long rate) +{ + struct clk_pfd *pfd = to_clk_pfd(clk); + unsigned long parent_rate = clk_get_parent_rate(clk); + u64 tmp = parent_rate; + u8 frac; + + tmp = tmp * 18 + rate / 2; + do_div(tmp, rate); + frac = tmp; + if (frac < 12) + frac = 12; + else if (frac > 35) + frac = 35; + + writel(0x3f << (pfd->idx * 8), pfd->reg + CLR); + writel(frac << (pfd->idx * 8), pfd->reg + SET); + + return 0; +} + static const struct clk_ops clk_pfd_ops = { .get_rate = clk_pfd_recalc_rate, + .set_rate = clk_pfd_set_rate, };
struct clk *imx_clk_pfd(const char *name, const char *parent_name,
Implement set_rate() for pfd. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Lukasz Majewski lukma@denx.de
Add i.MXRT1050 clk driver support.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- drivers/clk/imx/Kconfig | 16 ++ drivers/clk/imx/Makefile | 2 + drivers/clk/imx/clk-imxrt1050.c | 292 ++++++++++++++++++++ include/dt-bindings/clock/imxrt1050-clock.h | 65 +++++ 4 files changed, 375 insertions(+) create mode 100644 drivers/clk/imx/clk-imxrt1050.c create mode 100644 include/dt-bindings/clock/imxrt1050-clock.h
diff --git a/drivers/clk/imx/Kconfig b/drivers/clk/imx/Kconfig index 2f149ff6f8..059bc2fbb9 100644 --- a/drivers/clk/imx/Kconfig +++ b/drivers/clk/imx/Kconfig @@ -68,3 +68,19 @@ config CLK_IMX8MP select CLK_CCF help This enables support clock driver for i.MX8MP platforms. + +config SPL_CLK_IMXRT1050 + bool "SPL clock support for i.MXRT1050" + depends on ARCH_IMXRT && SPL + select SPL_CLK + select SPL_CLK_CCF + help + This enables SPL DM/DTS support for clock driver in i.MXRT1050 + +config CLK_IMXRT1050 + bool "Clock support for i.MXRT1050" + depends on ARCH_IMXRT + select CLK + select CLK_CCF + help + This enables support clock driver for i.MXRT1050 platforms. diff --git a/drivers/clk/imx/Makefile b/drivers/clk/imx/Makefile index 255a87b18e..1e8a49d0f3 100644 --- a/drivers/clk/imx/Makefile +++ b/drivers/clk/imx/Makefile @@ -16,3 +16,5 @@ obj-$(CONFIG_$(SPL_TPL_)CLK_IMX8MN) += clk-imx8mn.o clk-pll14xx.o \ clk-composite-8m.o obj-$(CONFIG_$(SPL_TPL_)CLK_IMX8MP) += clk-imx8mp.o clk-pll14xx.o \ clk-composite-8m.o + +obj-$(CONFIG_$(SPL_TPL_)CLK_IMXRT1050) += clk-imxrt1050.o diff --git a/drivers/clk/imx/clk-imxrt1050.c b/drivers/clk/imx/clk-imxrt1050.c new file mode 100644 index 0000000000..44ca52c013 --- /dev/null +++ b/drivers/clk/imx/clk-imxrt1050.c @@ -0,0 +1,292 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright(C) 2019 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#include <common.h> +#include <clk.h> +#include <clk-uclass.h> +#include <dm.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <dt-bindings/clock/imxrt1050-clock.h> + +#include "clk.h" + +static ulong imxrt1050_clk_get_rate(struct clk *clk) +{ + struct clk *c; + int ret; + + debug("%s(#%lu)\n", __func__, clk->id); + + ret = clk_get_by_id(clk->id, &c); + if (ret) + return ret; + + return clk_get_rate(c); +} + +static ulong imxrt1050_clk_set_rate(struct clk *clk, ulong rate) +{ + struct clk *c; + int ret; + + debug("%s(#%lu), rate: %lu\n", __func__, clk->id, rate); + + ret = clk_get_by_id(clk->id, &c); + if (ret) + return ret; + + return clk_set_rate(c, rate); +} + +static int __imxrt1050_clk_enable(struct clk *clk, bool enable) +{ + struct clk *c; + int ret; + + debug("%s(#%lu) en: %d\n", __func__, clk->id, enable); + + ret = clk_get_by_id(clk->id, &c); + if (ret) + return ret; + + if (enable) + ret = clk_enable(c); + else + ret = clk_disable(c); + + return ret; +} + +static int imxrt1050_clk_disable(struct clk *clk) +{ + return __imxrt1050_clk_enable(clk, 0); +} + +static int imxrt1050_clk_enable(struct clk *clk) +{ + return __imxrt1050_clk_enable(clk, 1); +} + +static struct clk_ops imxrt1050_clk_ops = { + .set_rate = imxrt1050_clk_set_rate, + .get_rate = imxrt1050_clk_get_rate, + .enable = imxrt1050_clk_enable, + .disable = imxrt1050_clk_disable, +}; + +static const char * const pll_ref_sels[] = {"osc", "dummy", }; +static const char * const pll1_bypass_sels[] = {"pll1_arm", "pll1_arm_ref_sel", }; +static const char * const pll2_bypass_sels[] = {"pll2_sys", "pll2_sys_ref_sel", }; +static const char * const pll3_bypass_sels[] = {"pll3_usb_otg", "pll3_usb_otg_ref_sel", }; +static const char * const pll5_bypass_sels[] = {"pll5_video", "pll5_video_ref_sel", }; + +static const char *const pre_periph_sels[] = { "pll2_sys", "pll2_pfd2_396m", "pll2_pfd0_352m", "arm_podf", }; +static const char *const periph_sels[] = { "pre_periph_sel", "todo", }; +static const char *const usdhc_sels[] = { "pll2_pfd2_396m", "pll2_pfd0_352m", }; +static const char *const lpuart_sels[] = { "pll3_80m", "osc", }; +static const char *const semc_alt_sels[] = { "pll2_pfd2_396m", "pll3_pfd1_664_62m", }; +static const char *const semc_sels[] = { "periph_sel", "semc_alt_sel", }; +static const char *const lcdif_sels[] = { "pll2_sys", "pll3_pfd3_454_74m", "pll5_video:", "pll2_pfd0_352m", "pll2_pfd1_594m", "pll3_pfd1_664_62m"}; + +static int imxrt1050_clk_probe(struct udevice *dev) +{ + void *base; + + /* Anatop clocks */ + base = (void *)ANATOP_BASE_ADDR; + + clk_dm(IMXRT1050_CLK_PLL1_REF_SEL, + imx_clk_mux("pll1_arm_ref_sel", base + 0x0, 14, 2, + pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); + clk_dm(IMXRT1050_CLK_PLL2_REF_SEL, + imx_clk_mux("pll2_sys_ref_sel", base + 0x30, 14, 2, + pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); + clk_dm(IMXRT1050_CLK_PLL3_REF_SEL, + imx_clk_mux("pll3_usb_otg_ref_sel", base + 0x10, 14, 2, + pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); + clk_dm(IMXRT1050_CLK_PLL5_REF_SEL, + imx_clk_mux("pll5_video_ref_sel", base + 0xa0, 14, 2, + pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); + + clk_dm(IMXRT1050_CLK_PLL1_ARM, + imx_clk_pllv3(IMX_PLLV3_SYS, "pll1_arm", "pll1_arm_ref_sel", + base + 0x0, 0x7f)); + clk_dm(IMXRT1050_CLK_PLL2_SYS, + imx_clk_pllv3(IMX_PLLV3_GENERIC, "pll2_sys", "pll2_sys_ref_sel", + base + 0x30, 0x1)); + clk_dm(IMXRT1050_CLK_PLL3_USB_OTG, + imx_clk_pllv3(IMX_PLLV3_USB, "pll3_usb_otg", + "pll3_usb_otg_ref_sel", + base + 0x10, 0x1)); + clk_dm(IMXRT1050_CLK_PLL5_VIDEO, + imx_clk_pllv3(IMX_PLLV3_AV, "pll5_video", "pll5_video_ref_sel", + base + 0xa0, 0x7f)); + + /* PLL bypass out */ + clk_dm(IMXRT1050_CLK_PLL1_BYPASS, + imx_clk_mux_flags("pll1_bypass", base + 0x0, 16, 1, + pll1_bypass_sels, + ARRAY_SIZE(pll1_bypass_sels), + CLK_SET_RATE_PARENT)); + clk_dm(IMXRT1050_CLK_PLL2_BYPASS, + imx_clk_mux_flags("pll2_bypass", base + 0x30, 16, 1, + pll2_bypass_sels, + ARRAY_SIZE(pll2_bypass_sels), + CLK_SET_RATE_PARENT)); + clk_dm(IMXRT1050_CLK_PLL3_BYPASS, + imx_clk_mux_flags("pll3_bypass", base + 0x10, 16, 1, + pll3_bypass_sels, + ARRAY_SIZE(pll3_bypass_sels), + CLK_SET_RATE_PARENT)); + clk_dm(IMXRT1050_CLK_PLL5_BYPASS, + imx_clk_mux_flags("pll5_bypass", base + 0xa0, 16, 1, + pll5_bypass_sels, + ARRAY_SIZE(pll5_bypass_sels), + CLK_SET_RATE_PARENT)); + + clk_dm(IMXRT1050_CLK_VIDEO_POST_DIV_SEL, + imx_clk_divider("video_post_div_sel", "pll5_video", + base + 0xa0, 19, 2)); + clk_dm(IMXRT1050_CLK_VIDEO_DIV, + imx_clk_divider("video_div", "video_post_div_sel", + base + 0x170, 30, 2)); + + clk_dm(IMXRT1050_CLK_PLL3_80M, + imx_clk_fixed_factor("pll3_80m", "pll3_usb_otg", 1, 6)); + + clk_dm(IMXRT1050_CLK_PLL2_PFD0_352M, + imx_clk_pfd("pll2_pfd0_352m", "pll2_sys", base + 0x100, 0)); + clk_dm(IMXRT1050_CLK_PLL2_PFD1_594M, + imx_clk_pfd("pll2_pfd1_594m", "pll2_sys", base + 0x100, 1)); + clk_dm(IMXRT1050_CLK_PLL2_PFD2_396M, + imx_clk_pfd("pll2_pfd2_396m", "pll2_sys", base + 0x100, 2)); + clk_dm(IMXRT1050_CLK_PLL3_PFD1_664_62M, + imx_clk_pfd("pll3_pfd1_664_62m", "pll3_usb_otg", base + 0xf0, + 1)); + clk_dm(IMXRT1050_CLK_PLL3_PFD3_454_74M, + imx_clk_pfd("pll3_pfd3_454_74m", "pll3_usb_otg", base + 0xf0, + 3)); + + /* CCM clocks */ + base = dev_read_addr_ptr(dev); + if (base == (void *)FDT_ADDR_T_NONE) + return -EINVAL; + + clk_dm(IMXRT1050_CLK_ARM_PODF, + imx_clk_divider("arm_podf", "pll1_arm", + base + 0x10, 0, 3)); + + clk_dm(IMXRT1050_CLK_PRE_PERIPH_SEL, + imx_clk_mux("pre_periph_sel", base + 0x18, 18, 2, + pre_periph_sels, ARRAY_SIZE(pre_periph_sels))); + clk_dm(IMXRT1050_CLK_PERIPH_SEL, + imx_clk_mux("periph_sel", base + 0x14, 25, 1, + periph_sels, ARRAY_SIZE(periph_sels))); + clk_dm(IMXRT1050_CLK_USDHC1_SEL, + imx_clk_mux("usdhc1_sel", base + 0x1c, 16, 1, + usdhc_sels, ARRAY_SIZE(usdhc_sels))); + clk_dm(IMXRT1050_CLK_USDHC2_SEL, + imx_clk_mux("usdhc2_sel", base + 0x1c, 17, 1, + usdhc_sels, ARRAY_SIZE(usdhc_sels))); + clk_dm(IMXRT1050_CLK_LPUART_SEL, + imx_clk_mux("lpuart_sel", base + 0x24, 6, 1, + lpuart_sels, ARRAY_SIZE(lpuart_sels))); + clk_dm(IMXRT1050_CLK_SEMC_ALT_SEL, + imx_clk_mux("semc_alt_sel", base + 0x14, 7, 1, + semc_alt_sels, ARRAY_SIZE(semc_alt_sels))); + clk_dm(IMXRT1050_CLK_SEMC_SEL, + imx_clk_mux("semc_sel", base + 0x14, 6, 1, + semc_sels, ARRAY_SIZE(semc_sels))); + clk_dm(IMXRT1050_CLK_LCDIF_SEL, + imx_clk_mux("lcdif_sel", base + 0x38, 15, 3, + lcdif_sels, ARRAY_SIZE(lcdif_sels))); + + clk_dm(IMXRT1050_CLK_AHB_PODF, + imx_clk_divider("ahb_podf", "periph_sel", + base + 0x14, 10, 3)); + clk_dm(IMXRT1050_CLK_USDHC1_PODF, + imx_clk_divider("usdhc1_podf", "usdhc1_sel", + base + 0x24, 11, 3)); + clk_dm(IMXRT1050_CLK_USDHC2_PODF, + imx_clk_divider("usdhc2_podf", "usdhc2_sel", + base + 0x24, 16, 3)); + clk_dm(IMXRT1050_CLK_LPUART_PODF, + imx_clk_divider("lpuart_podf", "lpuart_sel", + base + 0x24, 0, 6)); + clk_dm(IMXRT1050_CLK_SEMC_PODF, + imx_clk_divider("semc_podf", "semc_sel", + base + 0x14, 16, 3)); + clk_dm(IMXRT1050_CLK_LCDIF_PRED, + imx_clk_divider("lcdif_pred", "lcdif_sel", + base + 0x38, 12, 3)); + clk_dm(IMXRT1050_CLK_LCDIF_PODF, + imx_clk_divider("lcdif_podf", "lcdif_pred", + base + 0x18, 23, 3)); + + clk_dm(IMXRT1050_CLK_USDHC1, + imx_clk_gate2("usdhc1", "usdhc1_podf", base + 0x80, 2)); + clk_dm(IMXRT1050_CLK_USDHC2, + imx_clk_gate2("usdhc2", "usdhc2_podf", base + 0x80, 4)); + clk_dm(IMXRT1050_CLK_LPUART1, + imx_clk_gate2("lpuart1", "lpuart_podf", base + 0x7c, 24)); + clk_dm(IMXRT1050_CLK_SEMC, + imx_clk_gate2("semc", "semc_podf", base + 0x74, 4)); + clk_dm(IMXRT1050_CLK_LCDIF, + imx_clk_gate2("lcdif", "lcdif_podf", base + 0x70, 28)); + +#ifdef CONFIG_SPL_BUILD + struct clk *clk, *clk1; + + /* bypass pll1 before setting its rate */ + clk_get_by_id(IMXRT1050_CLK_PLL1_REF_SEL, &clk); + clk_get_by_id(IMXRT1050_CLK_PLL1_BYPASS, &clk1); + clk_set_parent(clk1, clk); + + clk_get_by_id(IMXRT1050_CLK_PLL1_ARM, &clk); + clk_enable(clk); + clk_set_rate(clk, 1056000000UL); + + clk_get_by_id(IMXRT1050_CLK_PLL1_BYPASS, &clk1); + clk_set_parent(clk1, clk); + + clk_get_by_id(IMXRT1050_CLK_SEMC_SEL, &clk1); + clk_get_by_id(IMXRT1050_CLK_SEMC_ALT_SEL, &clk); + clk_set_parent(clk1, clk); + + clk_get_by_id(IMXRT1050_CLK_PLL2_SYS, &clk); + clk_enable(clk); + clk_set_rate(clk, 528000000UL); + + clk_get_by_id(IMXRT1050_CLK_PLL2_BYPASS, &clk1); + clk_set_parent(clk1, clk); + + /* Configure PLL3_USB_OTG to 480MHz */ + clk_get_by_id(IMXRT1050_CLK_PLL3_USB_OTG, &clk); + clk_enable(clk); + clk_set_rate(clk, 480000000UL); + + clk_get_by_id(IMXRT1050_CLK_PLL3_BYPASS, &clk1); + clk_set_parent(clk1, clk); + +#endif + + return 0; +} + +static const struct udevice_id imxrt1050_clk_ids[] = { + { .compatible = "fsl,imxrt1050-ccm" }, + { }, +}; + +U_BOOT_DRIVER(imxrt1050_clk) = { + .name = "clk_imxrt1050", + .id = UCLASS_CLK, + .of_match = imxrt1050_clk_ids, + .ops = &imxrt1050_clk_ops, + .probe = imxrt1050_clk_probe, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/include/dt-bindings/clock/imxrt1050-clock.h b/include/dt-bindings/clock/imxrt1050-clock.h new file mode 100644 index 0000000000..c174f90c1a --- /dev/null +++ b/include/dt-bindings/clock/imxrt1050-clock.h @@ -0,0 +1,65 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright(C) 2019 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#ifndef __DT_BINDINGS_CLOCK_IMXRT1050_H +#define __DT_BINDINGS_CLOCK_IMXRT1050_H + +#define IMXRT1050_CLK_DUMMY 0 +#define IMXRT1050_CLK_CKIL 1 +#define IMXRT1050_CLK_CKIH 2 +#define IMXRT1050_CLK_OSC 3 +#define IMXRT1050_CLK_PLL2_PFD0_352M 4 +#define IMXRT1050_CLK_PLL2_PFD1_594M 5 +#define IMXRT1050_CLK_PLL2_PFD2_396M 6 +#define IMXRT1050_CLK_PLL3_PFD0_720M 7 +#define IMXRT1050_CLK_PLL3_PFD1_664_62M 8 +#define IMXRT1050_CLK_PLL3_PFD2_508_24M 9 +#define IMXRT1050_CLK_PLL3_PFD3_454_74M 10 +#define IMXRT1050_CLK_PLL2_198M 11 +#define IMXRT1050_CLK_PLL3_120M 12 +#define IMXRT1050_CLK_PLL3_80M 13 +#define IMXRT1050_CLK_PLL3_60M 14 +#define IMXRT1050_CLK_PLL1_BYPASS 15 +#define IMXRT1050_CLK_PLL2_BYPASS 16 +#define IMXRT1050_CLK_PLL3_BYPASS 17 +#define IMXRT1050_CLK_PLL5_BYPASS 19 +#define IMXRT1050_CLK_PLL1_REF_SEL 20 +#define IMXRT1050_CLK_PLL2_REF_SEL 21 +#define IMXRT1050_CLK_PLL3_REF_SEL 22 +#define IMXRT1050_CLK_PLL5_REF_SEL 23 +#define IMXRT1050_CLK_PRE_PERIPH_SEL 24 +#define IMXRT1050_CLK_PERIPH_SEL 25 +#define IMXRT1050_CLK_SEMC_ALT_SEL 26 +#define IMXRT1050_CLK_SEMC_SEL 27 +#define IMXRT1050_CLK_USDHC1_SEL 28 +#define IMXRT1050_CLK_USDHC2_SEL 29 +#define IMXRT1050_CLK_LPUART_SEL 30 +#define IMXRT1050_CLK_LCDIF_SEL 31 +#define IMXRT1050_CLK_VIDEO_POST_DIV_SEL 32 +#define IMXRT1050_CLK_VIDEO_DIV 33 +#define IMXRT1050_CLK_ARM_PODF 34 +#define IMXRT1050_CLK_LPUART_PODF 35 +#define IMXRT1050_CLK_USDHC1_PODF 36 +#define IMXRT1050_CLK_USDHC2_PODF 37 +#define IMXRT1050_CLK_SEMC_PODF 38 +#define IMXRT1050_CLK_AHB_PODF 39 +#define IMXRT1050_CLK_LCDIF_PRED 40 +#define IMXRT1050_CLK_LCDIF_PODF 41 +#define IMXRT1050_CLK_USDHC1 42 +#define IMXRT1050_CLK_USDHC2 43 +#define IMXRT1050_CLK_LPUART1 44 +#define IMXRT1050_CLK_SEMC 45 +#define IMXRT1050_CLK_LCDIF 46 +#define IMXRT1050_CLK_PLL1_ARM 47 +#define IMXRT1050_CLK_PLL2_SYS 48 +#define IMXRT1050_CLK_PLL3_USB_OTG 49 +#define IMXRT1050_CLK_PLL4_AUDIO 50 +#define IMXRT1050_CLK_PLL5_VIDEO 51 +#define IMXRT1050_CLK_PLL6_ENET 52 +#define IMXRT1050_CLK_PLL7_USB_HOST 53 +#define IMXRT1050_CLK_END 54 + +#endif /* __DT_BINDINGS_CLOCK_IMXRT1050_H */
Add i.MXRT1050 clk driver support. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com
Hi Giulio,
- bool "SPL clock support for i.MXRT1050"
- depends on ARCH_IMXRT && SPL
- select SPL_CLK
- select SPL_CLK_CCF
- help
- bool "Clock support for i.MXRT1050"
- select CLK
- select CLK_CCF
- help
- Copyright(C) 2019
- Author(s): Giulio Benetti giulio.benetti@benettiengineering.com
+#include "clk.h"
- struct clk *c;
- int ret;
- debug("%s(#%lu)\n", __func__, clk->id);
- ret = clk_get_by_id(clk->id, &c);
- if (ret)
return ret;
- return clk_get_rate(c);
- struct clk *c;
- int ret;
- debug("%s(#%lu), rate: %lu\n", __func__, clk->id, rate);
- if (ret)
return ret;
- return clk_set_rate(c, rate);
- struct clk *c;
- int ret;
- debug("%s(#%lu) en: %d\n", __func__, clk->id, enable);
- if (ret)
return ret;
- if (enable)
- else
- return ret;
- return __imxrt1050_clk_enable(clk, 0);
- return __imxrt1050_clk_enable(clk, 1);
- .set_rate = imxrt1050_clk_set_rate,
- .get_rate = imxrt1050_clk_get_rate,
- .enable = imxrt1050_clk_enable,
- .disable = imxrt1050_clk_disable,
- void *base;
- /* Anatop clocks */
- base = (void *)ANATOP_BASE_ADDR;
- clk_dm(IMXRT1050_CLK_PLL1_REF_SEL,
- clk_dm(IMXRT1050_CLK_PLL2_REF_SEL,
- clk_dm(IMXRT1050_CLK_PLL3_REF_SEL,
2,
- clk_dm(IMXRT1050_CLK_PLL5_REF_SEL,
- clk_dm(IMXRT1050_CLK_PLL1_ARM,
"pll1_arm_ref_sel",
base + 0x0, 0x7f));
- clk_dm(IMXRT1050_CLK_PLL2_SYS,
"pll2_sys_ref_sel",
base + 0x30, 0x1));
- clk_dm(IMXRT1050_CLK_PLL3_USB_OTG,
base + 0x10, 0x1));
- clk_dm(IMXRT1050_CLK_PLL5_VIDEO,
- /* PLL bypass out */
- clk_dm(IMXRT1050_CLK_PLL1_BYPASS,
pll1_bypass_sels,
- clk_dm(IMXRT1050_CLK_PLL2_BYPASS,
pll2_bypass_sels,
- clk_dm(IMXRT1050_CLK_PLL3_BYPASS,
pll3_bypass_sels,
- clk_dm(IMXRT1050_CLK_PLL5_BYPASS,
pll5_bypass_sels,
- clk_dm(IMXRT1050_CLK_VIDEO_POST_DIV_SEL,
- clk_dm(IMXRT1050_CLK_VIDEO_DIV,
- clk_dm(IMXRT1050_CLK_PLL3_80M,
1, 6)); +
- clk_dm(IMXRT1050_CLK_PLL2_PFD0_352M,
0x100, 0));
- clk_dm(IMXRT1050_CLK_PLL2_PFD1_594M,
0x100, 1));
- clk_dm(IMXRT1050_CLK_PLL2_PFD2_396M,
0x100, 2));
- clk_dm(IMXRT1050_CLK_PLL3_PFD1_664_62M,
- 0xf0,
1));
- clk_dm(IMXRT1050_CLK_PLL3_PFD3_454_74M,
- 0xf0,
3));
- /* CCM clocks */
- base = dev_read_addr_ptr(dev);
- if (base == (void *)FDT_ADDR_T_NONE)
return -EINVAL;
- clk_dm(IMXRT1050_CLK_ARM_PODF,
- clk_dm(IMXRT1050_CLK_PRE_PERIPH_SEL,
pre_periph_sels,
- clk_dm(IMXRT1050_CLK_PERIPH_SEL,
- clk_dm(IMXRT1050_CLK_USDHC1_SEL,
- clk_dm(IMXRT1050_CLK_USDHC2_SEL,
- clk_dm(IMXRT1050_CLK_LPUART_SEL,
- clk_dm(IMXRT1050_CLK_SEMC_ALT_SEL,
semc_alt_sels,
- clk_dm(IMXRT1050_CLK_SEMC_SEL,
- clk_dm(IMXRT1050_CLK_LCDIF_SEL,
- clk_dm(IMXRT1050_CLK_AHB_PODF,
- clk_dm(IMXRT1050_CLK_USDHC1_PODF,
- clk_dm(IMXRT1050_CLK_USDHC2_PODF,
- clk_dm(IMXRT1050_CLK_LPUART_PODF,
- clk_dm(IMXRT1050_CLK_SEMC_PODF,
- clk_dm(IMXRT1050_CLK_LCDIF_PRED,
- clk_dm(IMXRT1050_CLK_LCDIF_PODF,
- clk_dm(IMXRT1050_CLK_USDHC1,
2));
- clk_dm(IMXRT1050_CLK_USDHC2,
4));
- clk_dm(IMXRT1050_CLK_LPUART1,
24));
- clk_dm(IMXRT1050_CLK_SEMC,
- clk_dm(IMXRT1050_CLK_LCDIF,
- struct clk *clk, *clk1;
- /* bypass pll1 before setting its rate */
- clk_get_by_id(IMXRT1050_CLK_PLL1_REF_SEL, &clk);
- clk_get_by_id(IMXRT1050_CLK_PLL1_BYPASS, &clk1);
- clk_set_parent(clk1, clk);
- clk_get_by_id(IMXRT1050_CLK_PLL1_ARM, &clk);
- clk_enable(clk);
- clk_set_rate(clk, 1056000000UL);
- clk_get_by_id(IMXRT1050_CLK_SEMC_SEL, &clk1);
- clk_get_by_id(IMXRT1050_CLK_SEMC_ALT_SEL, &clk);
- clk_get_by_id(IMXRT1050_CLK_PLL2_SYS, &clk);
- clk_enable(clk);
- clk_set_rate(clk, 528000000UL);
- clk_get_by_id(IMXRT1050_CLK_PLL2_BYPASS, &clk1);
- /* Configure PLL3_USB_OTG to 480MHz */
- clk_get_by_id(IMXRT1050_CLK_PLL3_USB_OTG, &clk);
- clk_enable(clk);
- clk_set_rate(clk, 480000000UL);
- clk_get_by_id(IMXRT1050_CLK_PLL3_BYPASS, &clk1);
- { .compatible = "fsl,imxrt1050-ccm" },
- .name = "clk_imxrt1050",
- .id = UCLASS_CLK,
- .of_match = imxrt1050_clk_ids,
- .ops = &imxrt1050_clk_ops,
- .probe = imxrt1050_clk_probe,
- Copyright(C) 2019
Lukasz Majewski
Add i.MXRT pinctrl driver.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- drivers/pinctrl/nxp/Kconfig | 14 ++++++++++ drivers/pinctrl/nxp/Makefile | 1 + drivers/pinctrl/nxp/pinctrl-imxrt.c | 40 +++++++++++++++++++++++++++++ 3 files changed, 55 insertions(+) create mode 100644 drivers/pinctrl/nxp/pinctrl-imxrt.c
diff --git a/drivers/pinctrl/nxp/Kconfig b/drivers/pinctrl/nxp/Kconfig index f2e67ca231..ec55351e61 100644 --- a/drivers/pinctrl/nxp/Kconfig +++ b/drivers/pinctrl/nxp/Kconfig @@ -99,6 +99,20 @@ config PINCTRL_MXS familiy, e.g. i.MX28. This feature depends on device tree configuration.
+config PINCTRL_IMXRT + bool "IMXRT pinctrl driver" + depends on ARCH_IMXRT && PINCTRL_FULL + select DEVRES + select PINCTRL_IMX + help + Say Y here to enable the imxrt pinctrl driver + + This provides a simple pinctrl driver for i.MXRT SoC familiy. + This feature depends on device tree configuration. This driver + is different from the linux one, this is a simple implementation, + only parses the 'fsl,pins' property and configure related + registers. + config PINCTRL_VYBRID bool "Vybrid (vf610) pinctrl driver" depends on ARCH_VF610 && PINCTRL_FULL diff --git a/drivers/pinctrl/nxp/Makefile b/drivers/pinctrl/nxp/Makefile index b86448aac9..066ca75b65 100644 --- a/drivers/pinctrl/nxp/Makefile +++ b/drivers/pinctrl/nxp/Makefile @@ -8,3 +8,4 @@ obj-$(CONFIG_PINCTRL_IMX8) += pinctrl-imx8.o obj-$(CONFIG_PINCTRL_IMX8M) += pinctrl-imx8m.o obj-$(CONFIG_PINCTRL_MXS) += pinctrl-mxs.o obj-$(CONFIG_PINCTRL_VYBRID) += pinctrl-vf610.o +obj-$(CONFIG_PINCTRL_IMXRT) += pinctrl-imxrt.o diff --git a/drivers/pinctrl/nxp/pinctrl-imxrt.c b/drivers/pinctrl/nxp/pinctrl-imxrt.c new file mode 100644 index 0000000000..4a93941927 --- /dev/null +++ b/drivers/pinctrl/nxp/pinctrl-imxrt.c @@ -0,0 +1,40 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#include <common.h> +#include <dm.h> +#include <dm/pinctrl.h> + +#include "pinctrl-imx.h" + +static struct imx_pinctrl_soc_info imxrt_pinctrl_soc_info = { + .flags = ZERO_OFFSET_VALID, +}; + +static int imxrt_pinctrl_probe(struct udevice *dev) +{ + struct imx_pinctrl_soc_info *info = + (struct imx_pinctrl_soc_info *)dev_get_driver_data(dev); + + return imx_pinctrl_probe(dev, info); +} + +static const struct udevice_id imxrt_pinctrl_match[] = { + { .compatible = "fsl,imxrt-iomuxc", + .data = (ulong)&imxrt_pinctrl_soc_info }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(imxrt_pinctrl) = { + .name = "imxrt-pinctrl", + .id = UCLASS_PINCTRL, + .of_match = of_match_ptr(imxrt_pinctrl_match), + .probe = imxrt_pinctrl_probe, + .remove = imx_pinctrl_remove, + .priv_auto_alloc_size = sizeof(struct imx_pinctrl_priv), + .ops = &imx_pinctrl_ops, + .flags = DM_FLAG_PRE_RELOC, +};
Add i.MXRT pinctrl driver. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com
Hi Giulio,
Please add information from where this code was ported (SHA1, branch, commit name).
Nit tip:
- Please use patman, which will give you a warning if somethinf with the commit or commit message is broken.
- bool "IMXRT pinctrl driver"
- depends on ARCH_IMXRT && PINCTRL_FULL
- select DEVRES
- select PINCTRL_IMX
- help
familiy.
driver
implementation,
registers.
- Copyright (C) 2019
- .flags = ZERO_OFFSET_VALID,
- struct imx_pinctrl_soc_info *info =
- return imx_pinctrl_probe(dev, info);
- { .compatible = "fsl,imxrt-iomuxc",
- { /* sentinel */ }
- .name = "imxrt-pinctrl",
- .id = UCLASS_PINCTRL,
- .of_match = of_match_ptr(imxrt_pinctrl_match),
- .probe = imxrt_pinctrl_probe,
- .remove = imx_pinctrl_remove,
- .priv_auto_alloc_size = sizeof(struct imx_pinctrl_priv),
- .ops = &imx_pinctrl_ops,
Lukasz Majewski
Add i.MXRT1050 support, there are 5 GPIO banks.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- V1->V2: * introduced this patch --- drivers/gpio/mxc_gpio.c | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/gpio/mxc_gpio.c b/drivers/gpio/mxc_gpio.c index 6592d141d3..c924e52f07 100644 --- a/drivers/gpio/mxc_gpio.c +++ b/drivers/gpio/mxc_gpio.c @@ -41,14 +41,15 @@ static unsigned long gpio_ports[] = { #if defined(CONFIG_MX25) || defined(CONFIG_MX27) || defined(CONFIG_MX51) || \ defined(CONFIG_MX53) || defined(CONFIG_MX6) || \ defined(CONFIG_MX7) || defined(CONFIG_IMX8M) || \ - defined(CONFIG_ARCH_IMX8) + defined(CONFIG_ARCH_IMX8) || defined(CONFIG_IMXRT1050) [3] = GPIO4_BASE_ADDR, #endif #if defined(CONFIG_MX27) || defined(CONFIG_MX53) || defined(CONFIG_MX6) || \ defined(CONFIG_MX7) || defined(CONFIG_IMX8M) || \ - defined(CONFIG_ARCH_IMX8) + defined(CONFIG_ARCH_IMX8) || defined(CONFIG_IMXRT1050) [4] = GPIO5_BASE_ADDR, -#if !(defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) || defined(CONFIG_IMX8M)) +#if !(defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) || \ + defined(CONFIG_IMX8M) || defined(CONFIG_IMXRT1050)) [5] = GPIO6_BASE_ADDR, #endif #endif
Add i.MXRT1050 support, there are 5 GPIO banks. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com
On Fri, 10 Jan 2020 15:47:03 +0100 Giulio Benetti giulio.benetti@benettiengineering.com wrote:
V1->V2:
- introduced this patch
[5] = GPIO6_BASE_ADDR,defined(CONFIG_IMX8M) || defined(CONFIG_IMXRT1050))
#endif #endif
Lukasz Majewski
Add dtsi file for i.MXRT1050.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/imxrt1050.dtsi | 146 +++ include/dt-bindings/pinctrl/pins-imxrt1050.h | 993 +++++++++++++++++++ 2 files changed, 1139 insertions(+) create mode 100644 arch/arm/dts/imxrt1050.dtsi create mode 100644 include/dt-bindings/pinctrl/pins-imxrt1050.h
diff --git a/arch/arm/dts/imxrt1050.dtsi b/arch/arm/dts/imxrt1050.dtsi new file mode 100644 index 0000000000..b1d98e6feb --- /dev/null +++ b/arch/arm/dts/imxrt1050.dtsi @@ -0,0 +1,146 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * Copyright (C) 2019 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#include "skeleton.dtsi" +#include "armv7-m.dtsi" +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/clock/imxrt1050-clock.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/memory/imxrt-sdram.h> + +/ { + aliases { + gpio0 = &gpio1; + gpio1 = &gpio2; + gpio2 = &gpio3; + gpio3 = &gpio4; + gpio4 = &gpio5; + mmc0 = &usdhc1; + serial0 = &lpuart1; + }; + + clocks { + u-boot,dm-spl; + + osc { + u-boot,dm-spl; + compatible = "fsl,imx-osc", "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24000000>; + }; + }; + + soc { + u-boot,dm-spl; + + semc: semc@402f0000 { + u-boot,dm-spl; + compatible = "fsl,imxrt-semc"; + reg = <0x402f0000 0x4000>; + clocks = <&clks IMXRT1050_CLK_SEMC>; + pinctrl-0 = <&pinctrl_semc>; + pinctrl-names = "default"; + status = "okay"; + }; + + lpuart1: serial@40184000 { + compatible = "fsl,imxrt-lpuart"; + reg = <0x40184000 0x4000>; + interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMXRT1050_CLK_LPUART1>; + clock-names = "per"; + status = "disabled"; + }; + + iomuxc: iomuxc@401f8000 { + compatible = "fsl,imxrt-iomuxc"; + reg = <0x401f8000 0x4000>; + fsl,mux_mask = <0x7>; + }; + + clks: ccm@400fc000 { + u-boot,dm-spl; + compatible = "fsl,imxrt1050-ccm"; + reg = <0x400fc000 0x4000>; + interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; + #clock-cells = <1>; + }; + + usdhc1: usdhc@402c0000 { + u-boot,dm-spl; + compatible = "fsl,imxrt-usdhc"; + reg = <0x402c0000 0x10000>; + interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMXRT1050_CLK_USDHC1>; + clock-names = "per"; + bus-width = <4>; + fsl,tuning-start-tap = <20>; + fsl,tuning-step= <2>; + status = "disabled"; + }; + + gpio1: gpio@401b8000 { + u-boot,dm-spl; + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x401b8000 0x4000>; + interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio@401bc000 { + u-boot,dm-spl; + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x401bc000 0x4000>; + interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio3: gpio@401c0000 { + u-boot,dm-spl; + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x401c0000 0x4000>; + interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio4: gpio@401c4000 { + u-boot,dm-spl; + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x401c4000 0x4000>; + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio5: gpio@400c0000 { + u-boot,dm-spl; + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x400c0000 0x4000>; + interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; +}; diff --git a/include/dt-bindings/pinctrl/pins-imxrt1050.h b/include/dt-bindings/pinctrl/pins-imxrt1050.h new file mode 100644 index 0000000000..a29031ab3d --- /dev/null +++ b/include/dt-bindings/pinctrl/pins-imxrt1050.h @@ -0,0 +1,993 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#ifndef _DT_BINDINGS_PINCTRL_IMXRT1050_PINFUNC_H +#define _DT_BINDINGS_PINCTRL_IMXRT1050_PINFUNC_H + +#define IMX_PAD_SION 0x40000000 + +/* + * The pin function ID is a tuple of + * <mux_reg conf_reg input_reg mux_mode input_val> + */ + +#define MXRT1050_IOMUXC_GPIO_EMC_00_SEMC_DA00 0x014 0x204 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_00_FLEXPWM4_PWM0_A 0x014 0x204 0x494 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_00_LPSPI2_SCK 0x014 0x204 0x500 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_00_XBAR_INOUT2 0x014 0x204 0x60C 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_00_FLEXIO1_D00 0x014 0x204 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_00_GPIO4_IO00 0x014 0x204 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_01_SEMC_DA01 0x018 0x208 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_01_FLEXPWM4_PWM0_B 0x018 0x208 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_01_LPSPI2_PCS0 0x018 0x208 0x4FC 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_01_XBAR_INOUT3 0x018 0x208 0x610 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_01_FLEXIO1_D01 0x018 0x208 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_01_GPIO4_IO01 0x018 0x208 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_02_SEMC_DA02 0x01C 0x20C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_02_FLEXPWM4_PWM1_A 0x01C 0x20C 0x498 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_02_LPSPI2_SDO 0x01C 0x20C 0x508 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_02_XBAR_INOUT4 0x01C 0x20C 0x614 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_02_FLEXIO1_D02 0x01C 0x20C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_02_GPIO4_IO02 0x01C 0x20C 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_03_SEMC_DA03 0x020 0x210 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_03_FLEXPWM4_PWM1_B 0x020 0x210 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_03_LPSPI2_SDI 0x020 0x210 0x504 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_03_XBAR_INOUT5 0x020 0x210 0x618 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_03_FLEXIO1_D03 0x020 0x210 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_03_GPIO4_IO03 0x020 0x210 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_04_SEMC_DA04 0x024 0x214 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_04_FLEXPWM4_PWM2_A 0x024 0x214 0x49C 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_04_SAI2_TX_DATA 0x024 0x214 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_04_XBAR_INOUT6 0x024 0x214 0x61C 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_04_FLEXIO1_D04 0x024 0x214 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_04_GPIO4_IO04 0x024 0x214 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_05_SEMC_DA05 0x028 0x218 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_05_FLEXPWM4_PWM2_B 0x028 0x218 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_05_SAI2_TX_SYNC 0x028 0x218 0x5C4 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_05_XBAR_INOUT7 0x028 0x218 0x620 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_05_FLEXIO1_D05 0x028 0x218 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_05_GPIO4_IO05 0x028 0x218 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_06_SEMC_DA06 0x02C 0x21C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_06_FLEXPWM2_PWM0_A 0x02C 0x21C 0x478 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_06_SAI2_TX_BCLK 0x02C 0x21C 0x5C0 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_06_XBAR_INOUT8 0x02C 0x21C 0x624 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_06_FLEXIO1_D06 0x02C 0x21C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_06_GPIO4_IO06 0x02C 0x21C 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_07_SEMC_DA07 0x030 0x220 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_07_FLEXPWM2_PWM0_B 0x030 0x220 0x488 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_07_SAI2_MCLK 0x030 0x220 0x5B0 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_07_XBAR_INOUT9 0x030 0x220 0x628 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_07_FLEXIO1_D07 0x030 0x220 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_07_GPIO4_IO07 0x030 0x220 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_08_SEMC_DM00 0x034 0x224 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_08_FLEXPWM2_PWM1_A 0x034 0x224 0x47C 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_08_SAI2_RX_DATA 0x034 0x224 0x5B8 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_08_XBAR_INOUT17 0x034 0x224 0x62C 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_08_FLEXIO1_D08 0x034 0x224 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_08_GPIO4_IO08 0x034 0x224 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_09_SEMC_ADDR00 0x038 0x228 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_09_FLEXPWM2_PWM1_B 0x038 0x228 0x48C 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_09_SAI2_RX_SYNC 0x038 0x228 0x5BC 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_09_FLEXCAN2_TX 0x038 0x228 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_09_FLEXIO1_D09 0x038 0x228 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_09_GPIO4_IO09 0x038 0x228 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_10_SEMC_ADDR01 0x03C 0x22C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_10_FLEXPWM2_PWM2_A 0x03C 0x22C 0x480 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_10_SAI2_RX_BCLK 0x03C 0x22C 0x5B4 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_10_FLEXCAN2_RX 0x03C 0x22C 0x450 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_10_FLEXIO1_D10 0x03C 0x22C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_10_GPIO4_IO10 0x03C 0x22C 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_11_SEMC_ADDR02 0x040 0x230 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_11_FLEXPWM2_PWM2_B 0x040 0x230 0x490 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_11_LPI2C4_SDA 0x040 0x230 0x4E8 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_11_USDHC2_RESET_B 0x040 0x230 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_11_FLEXIO1_D11 0x040 0x230 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_11_GPIO4_IO11 0x040 0x230 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_12_SEMC_ADDR03 0x044 0x234 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_12_XBAR_INOUT24 0x044 0x234 0x640 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_12_LPI2C4_SCL 0x044 0x234 0x4E4 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_12_USDHC2_WP 0x044 0x234 0x5D8 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_12_FLEXPWM1_PWM3_A 0x044 0x234 0x454 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_12_GPIO4_IO12 0x044 0x234 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_13_SEMC_ADDR04 0x048 0x238 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_13_XBAR_INOUT25 0x048 0x238 0x650 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_13_LPUART3_TXD 0x048 0x238 0x53C 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_13_MQS_RIGHT 0x048 0x238 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_13_FLEXPWM1_PWM3_B 0x048 0x238 0x464 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_13_GPIO4_IO13 0x048 0x238 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_14_SEMC_ADDR05 0x04C 0x23C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_14_XBAR_INOUT19 0x04C 0x23C 0x654 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_14_LPUART3_RXD 0x04C 0x23C 0x538 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_14_MQS_LEFT 0x04C 0x23C 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_14_LPSPI2_PCS1 0x04C 0x23C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_14_GPIO4_IO14 0x04C 0x23C 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_15_SEMC_ADDR06 0x050 0x240 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_15_XBAR_INOUT20 0x050 0x240 0x634 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_15_LPUART3_CTS_B 0x050 0x240 0x534 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_15_SPDIF_OUT 0x050 0x240 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_15_TMR3_TIMER0 0x050 0x240 0x57C 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_15_GPIO4_IO15 0x050 0x240 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_16_SEMC_ADDR07 0x054 0x244 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_16_XBAR_INOUT21 0x054 0x244 0x658 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_16_LPUART3_RTS_B 0x054 0x244 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_16_SPDIF_IN 0x054 0x244 0x5C8 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_16_TMR3_TIMER1 0x054 0x244 0x580 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_16_GPIO4_IO16 0x054 0x244 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_17_SEMC_ADDR08 0x058 0x248 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_17_FLEXPWM4_PWM3_A 0x058 0x248 0x4A0 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_17_LPUART4_CTS_B 0x058 0x248 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_17_FLEXCAN1_TX 0x058 0x248 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_17_TMR3_TIMER2 0x058 0x248 0x584 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_17_GPIO4_IO17 0x058 0x248 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_18_SEMC_ADDR09 0x05C 0x24C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_18_FLEXPWM4_PWM3_B 0x05C 0x24C 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_18_LPUART4_RTS_B 0x05C 0x24C 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_18_FLEXCAN1_RX 0x05C 0x24C 0x44C 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_18_TMR3_TIMER3 0x05C 0x24C 0x588 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_18_GPIO4_IO18 0x05C 0x24C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_18_SNVS_VIO_5_CTL 0x05C 0x24C 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_19_SEMC_ADDR11 0x060 0x250 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_19_FLEXPWM2_PWM3_A 0x060 0x250 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_19_LPUART4_TXD 0x060 0x250 0x544 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_19_ENET_RX_DATA01 0x060 0x250 0x438 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_19_TMR2_TIMER0 0x060 0x250 0x56C 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_19_GPIO4_IO19 0x060 0x250 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_19_SNVS_VIO_5 0x060 0x250 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_20_SEMC_ADDR12 0x064 0x254 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_20_FLEXPWM2_PWM3_B 0x064 0x254 0x484 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_20_LPUART4_RXD 0x064 0x254 0x540 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_20_ENET_RX_DATA00 0x064 0x254 0x434 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_20_TMR2_TIMER0 0x064 0x254 0x570 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_20_GPIO4_IO20 0x064 0x254 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_21_SEMC_BA0 0x068 0x258 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_21_FLEXPWM3_PWM3_A 0x068 0x258 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_21_LPI2C3_SDA 0x068 0x258 0x4E0 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_21_ENET_TX_DATA01 0x068 0x258 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_21_TMR2_TIMER2 0x068 0x258 0x574 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_21_GPIO4_IO21 0x068 0x258 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_22_SEMC_BA1 0x06C 0x25C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_22_FLEXPWM3_PWM3_B 0x06C 0x25C 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_22_LPI2C3_SCL 0x06C 0x25C 0x4DC 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_22_ENET_TX_DATA00 0x06C 0x25C 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_22_TMR2_TIMER3 0x06C 0x25C 0x578 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_22_GPIO4_IO22 0x06C 0x25C 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_23_SEMC_ADDR10 0x070 0x260 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_23_FLEXPWM1_PWM0_A 0x070 0x260 0x458 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_23_LPUART5_TXD 0x070 0x260 0x54C 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_23_ENET_RX_EN 0x070 0x260 0x43C 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_23_GPT1_CAPTURE2 0x070 0x260 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_23_GPIO4_IO23 0x070 0x260 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_24_SEMC_CAS 0x074 0x264 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_24_FLEXPWM1_PWM0_B 0x074 0x264 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_24_LPUART5_RXD 0x074 0x264 0x548 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_24_ENET_TX_EN 0x074 0x264 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_24_GPT1_CAPTURE1 0x074 0x264 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_24_GPIO4_IO24 0x074 0x264 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_25_SEMC_RAS 0x078 0x268 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_25_FLEXPWM1_PWM1_A 0x078 0x268 0x45C 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_25_LPUART6_TXD 0x078 0x268 0x554 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_25_ENET_TX_CLK 0x078 0x268 0x448 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_25_ENET_REF_CLK 0x078 0x268 0x42C 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_25_GPIO4_IO25 0x078 0x268 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_26_SEMC_CLK 0x07C 0x26C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_26_FLEXPWM1_PWM1_B 0x07C 0x26C 0x46C 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_26_LPUART6_RXD 0x07C 0x26C 0x550 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_26_ENET_RX_ER 0x07C 0x26C 0x440 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_26_FLEXIO1_D12 0x07C 0x26C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_26_GPIO4_IO26 0x07C 0x26C 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_27_SEMC_CKE 0x080 0x270 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_27_FLEXPWM1_PWM2_A 0x080 0x270 0x460 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_27_LPUART5_RTS_B 0x080 0x270 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_27_LPSPI1_SCK 0x080 0x270 0x4F0 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_27_FLEXIO1_D13 0x080 0x270 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_27_GPIO4_IO27 0x080 0x270 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_28_SEMC_WE 0x084 0x274 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_28_FLEXPWM1_PWM2_B 0x084 0x274 0x470 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_28_LPUART5_CTS_B 0x084 0x274 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_28_LPSPI1_SDO 0x084 0x274 0x4F8 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_28_FLEXIO1_D14 0x084 0x274 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_28_GPIO4_IO28 0x084 0x274 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_29_SEMC_CS0 0x088 0x278 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_29_FLEXPWM3_PWM0_A 0x088 0x278 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_29_LPUART6_RTS_B 0x088 0x278 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_29_LPSPI1_SDI 0x088 0x278 0x4F4 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_29_FLEXIO1_D15 0x088 0x278 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_29_GPIO4_IO29 0x088 0x278 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_30_SEMC_DA08 0x08C 0x27C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_30_FLEXPWM3_PWM0_B 0x08C 0x27C 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_30_LPUART6_CTS_B 0x08C 0x27C 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_30_LPSPI1_PCS0 0x08C 0x27C 0x4EC 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_30_CSI_DATA23 0x08C 0x27C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_30_GPIO4_IO30 0x08C 0x27C 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_31_SEMC_DA09 0x090 0x280 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_31_FLEXPWM3_PWM1_A 0x090 0x280 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_31_LPUART7_TXD 0x090 0x280 0x55C 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_31_LPSPI1_PCS1 0x090 0x280 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_31_CSI_DATA22 0x090 0x280 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_31_GPIO4_IO31 0x090 0x280 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_32_SEMC_DA10 0x094 0x284 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_32_FLEXPWM3_PWM1_B 0x094 0x284 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_32_LPUART7_RXD 0x094 0x284 0x558 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_32_CCM_PMIC_READY 0x094 0x284 0x3FC 0x3 0x4 +#define MXRT1050_IOMUXC_GPIO_EMC_32_CSI_DATA21 0x094 0x284 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_32_GPIO3_IO18 0x094 0x284 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_33_SEMC_DA11 0x098 0x288 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_33_FLEXPWM3_PWM2_A 0x098 0x288 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_33_USDHC1_RESET_B 0x098 0x288 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_33_SAI3_RX_DATA 0x098 0x288 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_33_CSI_DATA20 0x098 0x288 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_33_GPIO3_IO19 0x098 0x288 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_34_SEMC_DA12 0x09C 0x28C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_34_FLEXPWM3_PWM2_B 0x09C 0x28C 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_34_USDHC1_VSELECT 0x09C 0x28C 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_34_SAI3_RX_SYNC 0x09C 0x28C 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_34_CSI_DATA19 0x09C 0x28C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_34_GPIO3_IO20 0x09C 0x28C 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_35_SEMC_DA13 0x0A0 0x290 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_35_XBAR_INOUT18 0x0A0 0x290 0x630 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_35_GPT1_COMPARE1 0x0A0 0x290 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_35_SAI3_RX_BCLK 0x0A0 0x290 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_35_CSI_DATA18 0x0A0 0x290 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_35_GPIO3_IO21 0x0A0 0x290 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_35_USDHC1_CD_B 0x0A0 0x290 0x5D4 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_36_SEMC_DA14 0x0A4 0x294 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_36_XBAR_INOUT22 0x0A4 0x294 0x638 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_36_GPT1_COMPARE2 0x0A4 0x294 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_36_SAI3_TX_DATA 0x0A4 0x294 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_36_CSI_DATA17 0x0A4 0x294 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_36_GPIO3_IO22 0x0A4 0x294 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_36_USDHC1_WP 0x0A4 0x294 0x5D8 0x6 0x1 + +#define MXRT1050_IOMUXC_GPIO_EMC_37_SEMC_DA15 0x0A8 0x298 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_37_XBAR_INOUT23 0x0A8 0x298 0x63C 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_37_GPT1_COMPARE3 0x0A8 0x298 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_37_SAI3_MCLK 0x0A8 0x298 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_37_CSI_DATA16 0x0A8 0x298 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_37_GPIO3_IO23 0x0A8 0x298 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_37_USDHC2_WP 0x0A8 0x298 0x608 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_38_SEMC_DM01 0x0AC 0x29C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_38_FLEXPWM1_PWM3_A 0x0AC 0x29C 0x454 0x1 0x2 +#define MXRT1050_IOMUXC_GPIO_EMC_38_LPUART8_TXD 0x0AC 0x29C 0x564 0x2 0x2 +#define MXRT1050_IOMUXC_GPIO_EMC_38_SAI3_TX_BCLK 0x0AC 0x29C 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_38_CSI_FIELD 0x0AC 0x29C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_38_GPIO3_IO24 0x0AC 0x29C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_38_USDHC2_VSELECT 0x0AC 0x29C 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_39_SEMC_DQS 0x0B0 0x2A0 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_39_FLEXPWM1_PWM3_B 0x0B0 0x2A0 0x464 0x1 0x2 +#define MXRT1050_IOMUXC_GPIO_EMC_39_LPUART8_RXD 0x0B0 0x2A0 0x560 0x2 0x2 +#define MXRT1050_IOMUXC_GPIO_EMC_39_SAI3_TX_SYNC 0x0B0 0x2A0 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_39_WDOG1_B 0x0B0 0x2A0 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_39_GPIO3_IO25 0x0B0 0x2A0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_39_USDHC2_CD_B 0x0B0 0x2A0 0x5E0 0x6 0x1 + +#define MXRT1050_IOMUXC_GPIO_EMC_40_SEMC_RDY 0x0B4 0x2A4 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_40_GPT2_CAPTURE2 0x0B4 0x2A4 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_40_LPSPI1_PCS2 0x0B4 0x2A4 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_40_USB_OTG2_OC 0x0B4 0x2A4 0x5CC 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_40_ENET_MDC 0x0B4 0x2A4 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_40_GPIO3_IO26 0x0B4 0x2A4 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_40_USDHC2_RESET_B 0x0B4 0x2A4 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_41_SEMC_CSX0 0x0B8 0x2A8 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_41_GPT2_CAPTURE1 0x0B8 0x2A8 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_41_LPSPI1_PCS3 0x0B8 0x2A8 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_41_USB_OTG2_PWR 0x0B8 0x2A8 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_41_ENET_MDIO 0x0B8 0x2A8 0x430 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_41_GPIO3_IO27 0x0B8 0x2A8 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_41_USDHC2_VSELECT 0x0B8 0x2A8 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_00_FLEXPWM2_PWM3_A 0x0BC 0x2AC 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_00_XBAR_INOUT14 0x0BC 0x2AC 0x644 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_00_REF_CLK_32K 0x0BC 0x2AC 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_00_USB_OTG2_ID 0x0BC 0x2AC 0x3F8 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_00_LPI2C1_SCLS 0x0BC 0x2AC 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_00_GPIO1_IO00 0x0BC 0x2AC 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_00_USDHC1_RESET_B 0x0BC 0x2AC 0x000 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_00_LPSPI3_SCK 0x0BC 0x2AC 0x510 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_01_FLEXPWM2_PWM3_B 0x0C0 0x2B0 0x484 0x0 0x2 +#define MXRT1050_IOMUXC_GPIO_AD_B0_01_XBAR_INOUT15 0x0C0 0x2B0 0x648 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_01_REF_CLK_24M 0x0C0 0x2B0 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_01_USB_OTG1_ID 0x0C0 0x2B0 0x3F4 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_01_LPI2C1_SDAS 0x0C0 0x2B0 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_01_GPIO1_IO01 0x0C0 0x2B0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_01_EWM_OUT_B 0x0C0 0x2B0 0x000 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_01_LPSPI3_SDO 0x0C0 0x2B0 0x518 0x7 0x1 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_02_FLEXCAN2_TX 0x0C4 0x2B4 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_02_XBAR_INOUT16 0x0C4 0x2B4 0x64C 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_02_LPUART6_TXD 0x0C4 0x2B4 0x554 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_02_USB_OTG1_PWR 0x0C4 0x2B4 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_02_FLEXPWM1_PWM0_X 0x0C4 0x2B4 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_02_GPIO1_IO02 0x0C4 0x2B4 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_02_LPI2C1_HREQ 0x0C4 0x2B4 0x000 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_02_LPSPI3_SDI 0x0C4 0x2B4 0x514 0x7 0x1 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_03_FLEXCAN2_RX 0x0C8 0x2B8 0x450 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_03_XBAR_INOUT17 0x0C8 0x2B8 0x62C 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_03_LPUART6_RXD 0x0C8 0x2B8 0x550 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_03_USB_OTG1_OC 0x0C8 0x2B8 0x5D0 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_03_FLEXPWM1_PWM1_X 0x0C8 0x2B8 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_03_GPIO1_IO03 0x0C8 0x2B8 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_03_REF_CLK_24M 0x0C8 0x2B8 0x000 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_03_LPSPI3_PCS0 0x0C8 0x2B8 0x50C 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_04_SRC_BOOT_MODE00 0x0CC 0x2BC 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_04_MQS_RIGHT 0x0CC 0x2BC 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_04_ENET_TX_DATA03 0x0CC 0x2BC 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_04_SAI2_TX_SYNC 0x0CC 0x2BC 0x5C4 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_04_CSI_DATA09 0x0CC 0x2BC 0x41C 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_04_GPIO1_IO04 0x0CC 0x2BC 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_04_PIT_TRIGGER00 0x0CC 0x2BC 0x000 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_04_LPSPI3_PCS1 0x0CC 0x2BC 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_05_SRC_BOOT_MODE01 0x0D0 0x2C0 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_05_MQS_LEFT 0x0D0 0x2C0 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_05_ENET_TX_DATA02 0x0D0 0x2C0 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_05_SAI2_TX_BCLK 0x0D0 0x2C0 0x5C0 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_05_CSI_DATA08 0x0D0 0x2C0 0x418 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_05_GPIO1_IO05 0x0D0 0x2C0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_05_XBAR_INOUT17 0x0D0 0x2C0 0x62C 0x6 0x2 +#define MXRT1050_IOMUXC_GPIO_AD_B0_05_LPSPI3_PCS2 0x0D0 0x2C0 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_06_JTAG_TMS 0x0D4 0x2C4 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_06_GPT2_COMPARE1 0x0D4 0x2C4 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_06_ENET_RX_CLK 0x0D4 0x2C4 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_06_SAI2_RX_BCLK 0x0D4 0x2C4 0x5B4 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_06_CSI_DATA07 0x0D4 0x2C4 0x414 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_06_GPIO1_IO06 0x0D4 0x2C4 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_06_XBAR_INOUT18 0x0D4 0x2C4 0x630 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_06_LPSPI3_PCS3 0x0D4 0x2C4 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_07_JTAG_TCK 0x0D8 0x2C8 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_07_GPT2_COMPARE2 0x0D8 0x2C8 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_07_ENET_TX_ER 0x0D8 0x2C8 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_07_SAI2_RX_SYNC 0x0D8 0x2C8 0x5BC 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_07_CSI_DATA06 0x0D8 0x2C8 0x410 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_07_GPIO1_IO07 0x0D8 0x2C8 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_07_XBAR_INOUT19 0x0D8 0x2C8 0x654 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_07_ENET_1588_EVENT3_OUT 0x0D8 0x2C8 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_08_JTAG_MOD 0x0DC 0x2CC 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_08_GPT2_COMPARE3 0x0DC 0x2CC 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_08_ENET_RX_DATA03 0x0DC 0x2CC 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_08_SAI2_RX_DATA 0x0DC 0x2CC 0x5B8 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_08_CSI_DATA05 0x0DC 0x2CC 0x40C 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_08_GPIO1_IO08 0x0DC 0x2CC 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_08_XBAR_INOUT20 0x0DC 0x2CC 0x634 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_08_ENET_1588_EVENT3_IN 0x0DC 0x2CC 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_09_JTAG_TDI 0x0E0 0x2D0 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_09_FLEXPWM2_PWM3_A 0x0E0 0x2D0 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_09_ENET_RX_DATA02 0x0E0 0x2D0 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_09_SAI2_TX_DATA 0x0E0 0x2D0 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_09_CSI_DATA04 0x0E0 0x2D0 0x408 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_09_GPIO1_IO09 0x0E0 0x2D0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_09_XBAR_INOUT21 0x0E0 0x2D0 0x658 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_09_GPT2_CLK 0x0E0 0x2D0 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_10_JTAG_TDO 0x0E4 0x2D4 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_10_FLEXPWM1_PWM3_A 0x0E4 0x2D4 0x454 0x1 0x3 +#define MXRT1050_IOMUXC_GPIO_AD_B0_10_ENET_CRS 0x0E4 0x2D4 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_10_SAI2_MCLK 0x0E4 0x2D4 0x5B0 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_10_CSI_DATA03 0x0E4 0x2D4 0x404 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_10_GPIO1_IO10 0x0E4 0x2D4 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_10_XBAR_INOUT22 0x0E4 0x2D4 0x638 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_10_ENET_1588_EVENT0_OUT 0x0E4 0x2D4 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_11_JTAG_TRSTB 0x0E8 0x2D8 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_11_FLEXPWM1_PWM3_B 0x0E8 0x2D8 0x464 0x1 0x3 +#define MXRT1050_IOMUXC_GPIO_AD_B0_11_ENET_COL 0x0E8 0x2D8 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_11_WDOG1_B 0x0E8 0x2D8 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_11_CSI_DATA02 0x0E8 0x2D8 0x400 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_11_GPIO1_IO11 0x0E8 0x2D8 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_11_XBAR_INOUT23 0x0E8 0x2D8 0x63C 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_11_ENET_1588_EVENT0_IN 0x0E8 0x2D8 0x444 0x7 0x1 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_12_LPI2C4_SCL 0x0EC 0x2DC 0x4E4 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_12_CCM_PMIC_READY 0x0EC 0x2DC 0x3FC 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_12_LPUART1_TXD 0x0EC 0x2DC 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_12_WDOG2_B 0x0EC 0x2DC 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_12_FLEXPWM1_PWM2_X 0x0EC 0x2DC 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_12_GPIO1_IO12 0x0EC 0x2DC 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_12_ENET_1588_EVENT1_OUT 0x0EC 0x2DC 0x000 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_12_NMI 0x0EC 0x2DC 0x568 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_13_LPI2C4_SDA 0x0F0 0x2E0 0x4E8 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_13_GPT1_CLK 0x0F0 0x2E0 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_13_LPUART1_RXD 0x0F0 0x2E0 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_13_EWM_OUT_B 0x0F0 0x2E0 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_13_FLEXPWM1_PWM3_X 0x0F0 0x2E0 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_13_GPIO1_IO13 0x0F0 0x2E0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_13_ENET_1588_EVENT1_IN 0x0F0 0x2E0 0x000 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_13_REF_CLK_24M 0x0F0 0x2E0 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_14_USB_OTG2_OC 0x0F4 0x2E4 0x5CC 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_14_XBAR_INOUT24 0x0F4 0x2E4 0x640 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_14_LPUART1_CTS_B 0x0F4 0x2E4 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_14_ENET_1588_EVENT0_OUT 0x0F4 0x2E4 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_14_CSI_VSYNC 0x0F4 0x2E4 0x428 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_14_GPIO1_IO14 0x0F4 0x2E4 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_14_FLEXCAN2_TX 0x0F4 0x2E4 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_15_USB_OTG2_PWR 0x0F8 0x2E8 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_15_XBAR_INOUT25 0x0F8 0x2E8 0x650 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_15_LPUART1_RTS_B 0x0F8 0x2E8 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_15_ENET_1588_EVENT0_IN 0x0F8 0x2E8 0x444 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_15_CSI_HSYNC 0x0F8 0x2E8 0x420 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_15_GPIO1_IO15 0x0F8 0x2E8 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_15_FLEXCAN2_RX 0x0F8 0x2E8 0x450 0x6 0x2 +#define MXRT1050_IOMUXC_GPIO_AD_B0_15_WDOG1_WDOG_RST_B_DEB 0x0F8 0x2E8 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_00_USB_OTG2_ID 0x0FC 0x2EC 0x3F8 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_00_TMR3_TIMER0 0x0FC 0x2EC 0x57C 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_00_LPUART2_CTS_B 0x0FC 0x2EC 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_00_LPI2C1_SCL 0x0FC 0x2EC 0x4CC 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_00_WDOG1_B 0x0FC 0x2EC 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_00_GPIO1_IO16 0x0FC 0x2EC 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_00_USDHC1_WP 0x0FC 0x2EC 0x5D8 0x6 0x2 +#define MXRT1050_IOMUXC_GPIO_AD_B1_00_KPP_ROW07 0x0FC 0x2EC 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_01_USB_OTG1_PWR 0x100 0x2F0 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_01_TMR3_TIMER1 0x100 0x2F0 0x580 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_01_LPUART2_RTS_B 0x100 0x2F0 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_01_LPI2C1_SDA 0x100 0x2F0 0x4D0 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_01_CCM_PMIC_READY 0x100 0x2F0 0x3FC 0x4 0x2 +#define MXRT1050_IOMUXC_GPIO_AD_B1_01_GPIO1_IO17 0x100 0x2F0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_01_USDHC1_VSELECT 0x100 0x2F0 0x000 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_01_KPP_COL07 0x100 0x2F0 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_02_USB_OTG1_ID 0x104 0x2F4 0x3F4 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_02_TMR3_TIMER2 0x104 0x2F4 0x584 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_02_LPUART2_TXD 0x104 0x2F4 0x530 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_02_SPDIF_OUT 0x104 0x2F4 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_02_ENET_1588_EVENT2_OUT 0x104 0x2F4 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_02_GPIO1_IO18 0x104 0x2F4 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_02_USDHC1_CD_B 0x104 0x2F4 0x5D4 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_02_KPP_ROW06 0x104 0x2F4 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_03_USB_OTG1_OC 0x108 0x2F8 0x5D0 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_03_TMR3_TIMER3 0x108 0x2F8 0x588 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_03_LPUART2_RXD 0x108 0x2F8 0x52C 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_03_SPDIF_IN 0x108 0x2F8 0x5C8 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_03_ENET_1588_EVENT2_IN 0x108 0x2F8 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_03_GPIO1_IO19 0x108 0x2F8 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_03_USDHC2_CD_B 0x108 0x2F8 0x5E0 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_03_KPP_COL06 0x108 0x2F8 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_04_FLEXSPI_B_DATA3 0x10C 0x2FC 0x4C4 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_04_ENET_MDC 0x10C 0x2FC 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_04_LPUART3_CTS_B 0x10C 0x2FC 0x534 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_04_SPDIF_SR_CLK 0x10C 0x2FC 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_04_CSI_PIXCLK 0x10C 0x2FC 0x424 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_04_GPIO1_IO20 0x10C 0x2FC 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_04_USDHC2_DATA0 0x10C 0x2FC 0x5E8 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_04_KPP_ROW05 0x10C 0x2FC 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_05_FLEXSPI_B_DATA2 0x110 0x300 0x4C0 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_05_ENET_MDIO 0x110 0x300 0x430 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_05_LPUART3_RTS_B 0x110 0x300 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_05_SPDIF_OUT 0x110 0x300 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_05_CSI_MCLK 0x110 0x300 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_05_GPIO1_IO21 0x110 0x300 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_05_USDHC2_DATA1 0x110 0x300 0x5EC 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_05_KPP_COL05 0x110 0x300 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_06_FLEXSPI_B_DATA1 0x114 0x304 0x4BC 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_06_LPI2C3_SDA 0x114 0x304 0x4E0 0x1 0x2 +#define MXRT1050_IOMUXC_GPIO_AD_B1_06_LPUART3_TXD 0x114 0x304 0x53C 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_06_SPDIF_LOCK 0x114 0x304 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_06_CSI_VSYNC 0x114 0x304 0x428 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_06_GPIO1_IO22 0x114 0x304 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_06_USDHC2_DATA2 0x114 0x304 0x5F0 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_06_KPP_ROW04 0x114 0x304 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_07_FLEXSPI_B_DATA0 0x118 0x308 0x4B8 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_07_LPI2C3_SCL 0x118 0x308 0x4DC 0x1 0x2 +#define MXRT1050_IOMUXC_GPIO_AD_B1_07_LPUART3_RXD 0x118 0x308 0x538 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_07_SPDIF_EXT_CLK 0x118 0x308 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_07_CSI_HSYNC 0x118 0x308 0x420 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_07_GPIO1_IO23 0x118 0x308 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_07_USDHC2_DATA3 0x118 0x308 0x5F4 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_07_KPP_COL04 0x118 0x308 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_08_FLEXSPI_A_SS1_B 0x11C 0x30C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_08_FLEXPWM4_PWM0_A 0x11C 0x30C 0x494 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_08_FLEXCAN1_TX 0x11C 0x30C 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_08_CCM_PMIC_READY 0x11C 0x30C 0x3FC 0x3 0x3 +#define MXRT1050_IOMUXC_GPIO_AD_B1_08_CSI_DATA09 0x11C 0x30C 0x41C 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_08_GPIO1_IO24 0x11C 0x30C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_08_USDHC2_CMD 0x11C 0x30C 0x5E4 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_08_KPP_ROW03 0x11C 0x30C 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_09_FLEXSPI_A_DQS 0x120 0x310 0x4A4 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_09_FLEXPWM4_PWM1_A 0x120 0x310 0x498 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_09_FLEXCAN1_RX 0x120 0x310 0x44C 0x2 0x2 +#define MXRT1050_IOMUXC_GPIO_AD_B1_09_SAI1_MCLK 0x120 0x310 0x58C 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_09_CSI_DATA08 0x120 0x310 0x418 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_09_GPIO1_IO25 0x120 0x310 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_09_USDHC2_CLK 0x120 0x310 0x5DC 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_09_KPP_COL03 0x120 0x310 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_10_FLEXSPI_A_DATA3 0x124 0x314 0x4B4 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_10_WDOG1_B 0x124 0x314 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_10_LPUART8_TXD 0x124 0x314 0x564 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_10_SAI1_RX_SYNC 0x124 0x314 0x5A4 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_10_CSI_DATA07 0x124 0x314 0x414 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_10_GPIO1_IO26 0x124 0x314 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_10_USDHC2_WP 0x124 0x314 0x608 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_10_KPP_ROW02 0x124 0x314 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_11_FLEXSPI_A_DATA2 0x128 0x318 0x4B0 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_11_EWM_OUT_B 0x128 0x318 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_11_LPUART8_RXD 0x128 0x318 0x560 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_11_SAI1_RX_BCLK 0x128 0x318 0x590 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_11_CSI_DATA06 0x128 0x318 0x410 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_11_GPIO1_IO27 0x128 0x318 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_11_USDHC2_RESET_B 0x128 0x318 0x000 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_11_KPP_COL02 0x128 0x318 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_12_FLEXSPI_A_DATA1 0x12C 0x31C 0x4AC 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_12_ACMP1_OUT 0x12C 0x31C 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_12_LPSPI3_PCS0 0x12C 0x31C 0x50C 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_12_SAI1_RX_DATA00 0x12C 0x31C 0x594 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_12_CSI_DATA05 0x12C 0x31C 0x40C 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_12_GPIO1_IO28 0x12C 0x31C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_12_USDHC2_DATA4 0x12C 0x31C 0x5F8 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_12_KPP_ROW01 0x12C 0x31C 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_13_FLEXSPI_A_DATA0 0x130 0x320 0x4A8 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_13_ACMP2_OUT 0x130 0x320 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_13_LPSPI3_SDI 0x130 0x320 0x514 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_13_SAI1_TX_DATA00 0x130 0x320 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_13_CSI_DATA04 0x130 0x320 0x408 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_13_GPIO1_IO29 0x130 0x320 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_13_USDHC2_DATA5 0x130 0x320 0x5FC 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_13_KPP_COL01 0x130 0x320 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_14_FLEXSPI_A_SCLK 0x134 0x324 0x4C8 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_14_ACMP3_OUT 0x134 0x324 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_14_LPSPI3_SDO 0x134 0x324 0x518 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_14_SAI1_TX_BCLK 0x134 0x324 0x5A8 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_14_CSI_DATA03 0x134 0x324 0x404 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_14_GPIO1_IO30 0x134 0x324 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_14_USDHC2_DATA6 0x134 0x324 0x600 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_14_KPP_ROW00 0x134 0x324 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_15_FLEXSPI_A_SS0_B 0x138 0x328 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_15_ACMP4_OUT 0x138 0x328 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_15_LPSPI3_SCK 0x138 0x328 0x510 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_15_SAI1_TX_SYNC 0x138 0x328 0x5AC 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_15_CSI_DATA02 0x138 0x328 0x400 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_15_GPIO1_IO31 0x138 0x328 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_15_USDHC2_DATA7 0x138 0x328 0x604 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_15_KPP_COL00 0x138 0x328 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_00_LCD_CLK 0x13C 0x32C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_00_TMR1_TIMER0 0x13C 0x32C 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_00_MQS_RIGHT 0x13C 0x32C 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_00_LPSPI4_PCS0 0x13C 0x32C 0x51C 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_00_FLEXIO2_D00 0x13C 0x32C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_00_GPIO2_IO00 0x13C 0x32C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_00_SEMC_CSX1 0x13C 0x32C 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_01_LCD_ENABLE 0x140 0x330 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_01_TMR1_TIMER1 0x140 0x330 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_01_MQS_LEFT 0x140 0x330 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_01_LPSPI4_SDI 0x140 0x330 0x524 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_01_FLEXIO2_D01 0x140 0x330 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_01_GPIO2_IO01 0x140 0x330 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_01_SEMC_CSX2 0x140 0x330 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_02_LCD_HSYNC 0x144 0x334 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_02_TMR1_TIMER2 0x144 0x334 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_02_FLEXCAN1_TX 0x144 0x334 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_02_LPSPI4_SDO 0x144 0x334 0x528 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_02_FLEXIO2_D02 0x144 0x334 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_02_GPIO2_IO02 0x144 0x334 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_02_SEMC_CSX3 0x144 0x334 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_03_LCD_VSYNC 0x148 0x338 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_03_TMR2_TIMER0 0x148 0x338 0x56C 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_03_FLEXCAN1_RX 0x148 0x338 0x44C 0x2 0x3 +#define MXRT1050_IOMUXC_GPIO_B0_03_LPSPI4_SCK 0x148 0x338 0x520 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_03_FLEXIO2_D03 0x148 0x338 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_03_GPIO2_IO03 0x148 0x338 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_03_WDOG2_RESET_B_DEB 0x148 0x338 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_04_LCD_DATA00 0x14C 0x33C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_04_TMR2_TIMER1 0x14C 0x33C 0x570 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_04_LPI2C2_SCL 0x14C 0x33C 0x4D4 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_04_ARM_TRACE00 0x14C 0x33C 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_04_FLEXIO2_D04 0x14C 0x33C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_04_GPIO2_IO04 0x14C 0x33C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_04_SRC_BT_CFG00 0x14C 0x33C 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_05_LCD_DATA01 0x150 0x340 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_05_TMR2_TIMER2 0x150 0x340 0x574 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_05_LPI2C2_SDA 0x150 0x340 0x4D8 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_05_ARM_TRACE01 0x150 0x340 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_05_FLEXIO2_D05 0x150 0x340 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_05_GPIO2_IO05 0x150 0x340 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_05_SRC_BT_CFG01 0x150 0x340 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_06_LCD_DATA02 0x154 0x344 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_06_TMR3_TIMER0 0x154 0x344 0x57C 0x1 0x2 +#define MXRT1050_IOMUXC_GPIO_B0_06_FLEXPWM2_PWM0_A 0x154 0x344 0x478 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_06_ARM_TRACE02 0x154 0x344 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_06_FLEXIO2_D06 0x154 0x344 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_06_GPIO2_IO06 0x154 0x344 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_06_SRC_BT_CFG02 0x154 0x344 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_07_LCD_DATA03 0x158 0x348 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_07_TMR3_TIMER1 0x158 0x348 0x580 0x1 0x2 +#define MXRT1050_IOMUXC_GPIO_B0_07_FLEXPWM2_PWM0_B 0x158 0x348 0x488 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_07_ARM_TRACE03 0x158 0x348 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_07_FLEXIO2_D07 0x158 0x348 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_07_GPIO2_IO07 0x158 0x348 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_07_SRC_BT_CFG03 0x158 0x348 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_08_LCD_DATA04 0x15C 0x34C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_08_TMR3_TIMER2 0x15C 0x34C 0x584 0x1 0x2 +#define MXRT1050_IOMUXC_GPIO_B0_08_FLEXPWM2_PWM1_A 0x15C 0x34C 0x47C 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_08_LPUART3_TXD 0x15C 0x34C 0x53C 0x3 0x2 +#define MXRT1050_IOMUXC_GPIO_B0_08_FLEXIO2_D08 0x15C 0x34C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_08_GPIO2_IO08 0x15C 0x34C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_08_SRC_BT_CFG04 0x15C 0x34C 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_09_LCD_DATA05 0x160 0x350 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_09_TMR4_TIMER0 0x160 0x350 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_09_FLEXPWM2_PWM1_B 0x160 0x350 0x48C 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_09_LPUART3_RXD 0x160 0x350 0x538 0x3 0x2 +#define MXRT1050_IOMUXC_GPIO_B0_09_FLEXIO2_D09 0x160 0x350 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_09_GPIO2_IO09 0x160 0x350 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_09_SRC_BT_CFG05 0x160 0x350 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_10_LCD_DATA06 0x164 0x354 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_10_TMR4_TIMER1 0x164 0x354 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_10_FLEXPWM2_PWM2_A 0x164 0x354 0x480 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_10_SAI1_TX_DATA03 0x164 0x354 0x598 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_10_FLEXIO2_D10 0x164 0x354 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_10_GPIO2_IO10 0x164 0x354 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_10_SRC_BT_CFG06 0x164 0x354 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_11_LCD_DATA07 0x168 0x358 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_11_TMR4_TIMER2 0x168 0x358 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_11_FLEXPWM2_PWM2_B 0x168 0x358 0x490 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_11_SAI1_TX_DATA02 0x168 0x358 0x59C 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_11_FLEXIO2_D11 0x168 0x358 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_11_GPIO2_IO11 0x168 0x358 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_11_SRC_BT_CFG07 0x168 0x358 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_12_LCD_DATA08 0x16C 0x35C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_12_XBAR_INOUT10 0x16C 0x35C 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_12_ARM_TRACE_CLK 0x16C 0x35C 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_12_SAI1_TX_DATA01 0x16C 0x35C 0x5A0 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_12_FLEXIO2_D12 0x16C 0x35C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_12_GPIO2_IO12 0x16C 0x35C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_12_SRC_BT_CFG08 0x16C 0x35C 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_13_LCD_DATA09 0x170 0x360 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_13_XBAR_INOUT11 0x170 0x360 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_13_ARM_TRACE_SWO 0x170 0x360 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_13_SAI1_MCLK 0x170 0x360 0x58C 0x3 0x2 +#define MXRT1050_IOMUXC_GPIO_B0_13_FLEXIO2_D13 0x170 0x360 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_13_GPIO2_IO13 0x170 0x360 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_13_SRC_BT_CFG09 0x170 0x360 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_14_LCD_DATA10 0x174 0x364 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_14_XBAR_INOUT12 0x174 0x364 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_14_ARM_CM7_TXEV 0x174 0x364 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_14_SAI1_RX_SYNC 0x174 0x364 0x5A4 0x3 0x2 +#define MXRT1050_IOMUXC_GPIO_B0_14_FLEXIO2_D14 0x174 0x364 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_14_GPIO2_IO14 0x174 0x364 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_14_SRC_BT_CFG10 0x174 0x364 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_15_LCD_DATA11 0x178 0x368 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_15_XBAR_INOUT13 0x178 0x368 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_15_ARM_CM7_RXEV 0x178 0x368 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_15_SAI1_RX_BCLK 0x178 0x368 0x590 0x3 0x2 +#define MXRT1050_IOMUXC_GPIO_B0_15_FLEXIO2_D15 0x178 0x368 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_15_GPIO2_IO15 0x178 0x368 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_15_SRC_BT_CFG11 0x178 0x368 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B1_00_LCD_DATA12 0x17C 0x36C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_00_XBAR_INOUT14 0x17C 0x36C 0x644 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_00_LPUART4_TXD 0x17C 0x36C 0x544 0x2 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_00_SAI1_RX_DATA00 0x17C 0x36C 0x594 0x3 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_00_FLEXIO2_D16 0x17C 0x36C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_00_GPIO2_IO16 0x17C 0x36C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_00_FLEXPWM1_PWM3_A 0x17C 0x36C 0x454 0x6 0x4 + +#define MXRT1050_IOMUXC_GPIO_B1_01_LCD_DATA13 0x180 0x370 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_01_XBAR_INOUT15 0x180 0x370 0x648 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_01_LPUART4_RXD 0x180 0x370 0x540 0x2 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_01_SAI1_TX_DATA00 0x180 0x370 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_01_FLEXIO2_D17 0x180 0x370 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_01_GPIO2_IO17 0x180 0x370 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_01_FLEXPWM1_PWM3_B 0x180 0x370 0x464 0x6 0x4 + +#define MXRT1050_IOMUXC_GPIO_B1_02_LCD_DATA14 0x184 0x374 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_02_XBAR_INOUT16 0x184 0x374 0x64C 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_02_LPSPI4_PCS2 0x184 0x374 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_02_SAI1_TX_BCLK 0x184 0x374 0x5A8 0x3 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_02_FLEXIO2_D18 0x184 0x374 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_02_GPIO2_IO18 0x184 0x374 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_02_FLEXPWM2_PWM3_A 0x184 0x374 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B1_03_LCD_DATA15 0x188 0x378 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_03_XBAR_INOUT17 0x188 0x378 0x62C 0x1 0x3 +#define MXRT1050_IOMUXC_GPIO_B1_03_LPSPI4_PCS1 0x188 0x378 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_03_SAI1_TX_SYNC 0x188 0x378 0x5AC 0x3 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_03_FLEXIO2_D19 0x188 0x378 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_03_GPIO2_IO19 0x188 0x378 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_03_FLEXPWM2_PWM3_B 0x188 0x378 0x484 0x6 0x3 + +#define MXRT1050_IOMUXC_GPIO_B1_04_LCD_DATA16 0x18C 0x37C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_04_LPSPI4_PCS0 0x18C 0x37C 0x51C 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_04_CSI_DATA15 0x18C 0x37C 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_04_ENET_RX_DATA00 0x18C 0x37C 0x434 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_04_FLEXIO2_D20 0x18C 0x37C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_04_GPIO2_IO20 0x18C 0x37C 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_B1_05_LCD_DATA17 0x190 0x380 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_05_LPSPI4_SDI 0x190 0x380 0x524 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_05_CSI_DATA14 0x190 0x380 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_05_ENET_RX_DATA01 0x190 0x380 0x438 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_05_FLEXIO2_D21 0x190 0x380 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_05_GPIO2_IO21 0x190 0x380 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_B1_06_LCD_DATA18 0x194 0x384 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_06_LPSPI4_SDO 0x194 0x384 0x528 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_06_CSI_DATA13 0x194 0x384 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_06_ENET_RX_EN 0x194 0x384 0x43C 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_06_FLEXIO2_D22 0x194 0x384 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_06_GPIO2_IO22 0x194 0x384 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_B1_07_LCD_DATA19 0x198 0x388 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_07_LPSPI4_SCK 0x198 0x388 0x520 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_07_CSI_DATA12 0x198 0x388 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_07_ENET_TX_DATA00 0x198 0x388 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_07_FLEXIO2_D23 0x198 0x388 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_07_GPIO2_IO23 0x198 0x388 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_B1_08_LCD_DATA20 0x19C 0x38C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_08_TMR1_TIMER3 0x19C 0x38C 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_08_CSI_DATA11 0x19C 0x38C 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_08_ENET_TX_DATA01 0x19C 0x38C 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_08_FLEXIO2_D24 0x19C 0x38C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_08_GPIO2_IO24 0x19C 0x38C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_08_FLEXCAN2_TX 0x19C 0x38C 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B1_09_LCD_DATA21 0x1A0 0x390 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_09_TMR2_TIMER3 0x1A0 0x390 0x578 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_09_CSI_DATA10 0x1A0 0x390 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_09_ENET_TX_EN 0x1A0 0x390 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_09_FLEXIO2_D25 0x1A0 0x390 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_09_GPIO2_IO25 0x1A0 0x390 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_09_FLEXCAN2_RX 0x1A0 0x390 0x450 0x6 0x3 + +#define MXRT1050_IOMUXC_GPIO_B1_10_LCD_DATA22 0x1A4 0x394 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_10_TMR3_TIMER3 0x1A4 0x394 0x588 0x1 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_10_CSI_DATA00 0x1A4 0x394 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_10_ENET_TX_CLK 0x1A4 0x394 0x448 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_10_FLEXIO2_D26 0x1A4 0x394 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_10_GPIO2_IO26 0x1A4 0x394 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_10_ENET_REF_CLK 0x1A4 0x394 0x42C 0x6 0x1 + +#define MXRT1050_IOMUXC_GPIO_B1_11_LCD_DATA23 0x1A8 0x398 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_11_TMR4_TIMER3 0x1A8 0x398 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_11_CSI_DATA01 0x1A8 0x398 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_11_ENET_RX_ER 0x1A8 0x398 0x440 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_11_FLEXIO2_D27 0x1A8 0x398 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_11_GPIO2_IO27 0x1A8 0x398 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_11_LPSPI4_PCS3 0x1A8 0x398 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B1_12_LPUART5_TXD 0x1AC 0x39C 0x54C 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_12_CSI_PIXCLK 0x1AC 0x39C 0x424 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_12_ENET_1588_EVENT0_IN 0x1AC 0x39C 0x444 0x3 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_12_FLEXIO2_D28 0x1AC 0x39C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_12_GPIO2_IO28 0x1AC 0x39C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_12_USDHC1_CD_B 0x1AC 0x39C 0x5D4 0x6 0x2 + +#define MXRT1050_IOMUXC_GPIO_B1_13_WDOG1_B 0x1B0 0x3A0 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_13_LPUART5_RXD 0x1B0 0x3A0 0x548 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_13_CSI_VSYNC 0x1B0 0x3A0 0x428 0x2 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_13_ENET_1588_EVENT0_OUT 0x1B0 0x3A0 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_13_FLEXIO2_D29 0x1B0 0x3A0 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_13_GPIO2_IO29 0x1B0 0x3A0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_13_USDHC1_WP 0x1B0 0x3A0 0x5D8 0x6 0x3 + +#define MXRT1050_IOMUXC_GPIO_B1_14_ENET_MDC 0x1B4 0x3A4 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_14_FLEXPWM4_PWM2_A 0x1B4 0x3A4 0x49C 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_14_CSI_HSYNC 0x1B4 0x3A4 0x420 0x2 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_14_XBAR_INOUT02 0x1B4 0x3A4 0x60C 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_14_FLEXIO2_D30 0x1B4 0x3A4 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_14_GPIO2_IO30 0x1B4 0x3A4 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_14_USDHC1_VSELECT 0x1B4 0x3A4 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B1_15_ENET_MDIO 0x1B8 0x3A8 0x430 0x0 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_15_FLEXPWM4_PWM3_A 0x1B8 0x3A8 0x4A0 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_15_CSI_MCLK 0x1B8 0x3A8 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_15_XBAR_INOUT03 0x1B8 0x3A8 0x610 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_15_FLEXIO2_D31 0x1B8 0x3A8 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_15_GPIO2_IO31 0x1B8 0x3A8 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_15_USDHC1_RESET_B 0x1B8 0x3A8 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B0_00_USDHC1_CMD 0x1BC 0x3AC 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_00_FLEXPWM1_PWM0_A 0x1BC 0x3AC 0x458 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_00_LPI2C3_SCL 0x1BC 0x3AC 0x4DC 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_00_XBAR_INOUT04 0x1BC 0x3AC 0x614 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_00_LPSPI1_SCK 0x1BC 0x3AC 0x4F0 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_00_GPIO3_IO12 0x1BC 0x3AC 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_00_FLEXSPI_A_SS1_B 0x1BC 0x3AC 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B0_01_USDHC1_CLK 0x1C0 0x3B0 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_01_FLEXPWM1_PWM0_B 0x1C0 0x3B0 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_01_LPI2C3_SDA 0x1C0 0x3B0 0x4E0 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_01_XBAR_INOUT05 0x1C0 0x3B0 0x618 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_01_LPSPI1_PCS0 0x1C0 0x3B0 0x4EC 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_01_GPIO3_IO13 0x1C0 0x3B0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_01_FLEXSPI_B_SS1_B 0x1C0 0x3B0 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B0_02_USDHC1_DATA0 0x1C4 0x3B4 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_02_FLEXPWM1_PWM1_A 0x1C4 0x3B4 0x45C 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_02_LPUART8_CTS_B 0x1C4 0x3B4 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_02_XBAR_INOUT06 0x1C4 0x3B4 0x61C 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_02_LPSPI1_SDO 0x1C4 0x3B4 0x4F8 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_02_GPIO3_IO14 0x1C4 0x3B4 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B0_03_USDHC1_DATA1 0x1C8 0x3B8 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_03_FLEXPWM1_PWM1_B 0x1C8 0x3B8 0x46C 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_03_LPUART8_RTS_B 0x1C8 0x3B8 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_03_XBAR_INOUT07 0x1C8 0x3B8 0x620 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_03_LPSPI1_SDI 0x1C8 0x3B8 0x4F4 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_03_GPIO3_IO15 0x1C8 0x3B8 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B0_04_USDHC1_DATA2 0x1CC 0x3BC 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_04_FLEXPWM1_PWM2_A 0x1CC 0x3BC 0x460 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_04_LPUART8_TXD 0x1CC 0x3BC 0x564 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_04_XBAR_INOUT08 0x1CC 0x3BC 0x624 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_04_FLEXSPI_B_SS0_B 0x1CC 0x3BC 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_04_GPIO3_IO16 0x1CC 0x3BC 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_04_CCM_CLKO1 0x1CC 0x3BC 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B0_05_USDHC1_DATA3 0x1D0 0x3C0 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_05_FLEXPWM1_PWM2_B 0x1D0 0x3C0 0x470 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_05_LPUART8_RXD 0x1D0 0x3C0 0x560 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_05_XBAR_INOUT09 0x1D0 0x3C0 0x628 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_05_FLEXSPI_B_DQS 0x1D0 0x3C0 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_05_GPIO3_IO17 0x1D0 0x3C0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_05_CCM_CLKO2 0x1D0 0x3C0 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_00_USDHC2_DATA3 0x1D4 0x3C4 0x5F4 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_00_FLEXSPI_B_DATA3 0x1D4 0x3C4 0x4C4 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_00_FLEXPWM1_PWM3_A 0x1D4 0x3C4 0x454 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_00_SAI1_TX_DATA03 0x1D4 0x3C4 0x598 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_00_LPUART4_TXD 0x1D4 0x3C4 0x544 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_00_GPIO3_IO00 0x1D4 0x3C4 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_01_USDHC2_DATA2 0x1D8 0x3C8 0x5F0 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_01_FLEXSPI_B_DATA2 0x1D8 0x3C8 0x4C0 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_01_FLEXPWM1_PWM3_B 0x1D8 0x3C8 0x464 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_01_SAI1_TX_DATA02 0x1D8 0x3C8 0x59C 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_01_LPUART4_RXD 0x1D8 0x3C8 0x540 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_01_GPIO3_IO01 0x1D8 0x3C8 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_02_USDHC2_DATA1 0x1DC 0x3CC 0x5EC 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_02_FLEXSPI_B_DATA1 0x1DC 0x3CC 0x4BC 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_02_FLEXPWM2_PWM3_A 0x1DC 0x3CC 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_02_SAI1_TX_DATA01 0x1DC 0x3CC 0x5A0 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_02_FLEXCAN1_TX 0x1DC 0x3CC 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_02_GPIO3_IO02 0x1DC 0x3CC 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_02_CCM_WAIT 0x1DC 0x3CC 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_03_USDHC2_DATA0 0x1E0 0x3D0 0x5E8 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_03_FLEXSPI_B_DATA0 0x1E0 0x3D0 0x4B8 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_03_FLEXPWM2_PWM3_B 0x1E0 0x3D0 0x484 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_03_SAI1_MCLK 0x1E0 0x3D0 0x58C 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_03_FLEXCAN1_RX 0x1E0 0x3D0 0x44C 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_03_GPIO3_IO03 0x1E0 0x3D0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_03_CCM_PMIC_READY 0x1E0 0x3D0 0x3FC 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_04_USDHC2_CLK 0x1E4 0x3D4 0x5DC 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_04_FLEXSPI_B_SCLK 0x1E4 0x3D4 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_04_LPI2C1_SCL 0x1E4 0x3D4 0x4CC 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_04_SAI1_RX_SYNC 0x1E4 0x3D4 0x5A4 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_04_FLEXCAN1_A_SS1_B 0x1E4 0x3D4 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_04_GPIO3_IO04 0x1E4 0x3D4 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_04_CCM_STOP 0x1E4 0x3D4 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_05_USDHC2_CMD 0x1E8 0x3D8 0x5E4 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_05_FLEXSPI_A_DQS 0x1E8 0x3D8 0x4A4 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_05_LPI2C1_SDA 0x1E8 0x3D8 0x4D0 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_05_SAI1_RX_BCLK 0x1E8 0x3D8 0x590 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_05_FLEXCAN1_B_SS0_B 0x1E8 0x3D8 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_05_GPIO3_IO05 0x1E8 0x3D8 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_06_USDHC2_RESET_B 0x1EC 0x3DC 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_06_FLEXSPI_A_SS0_B 0x1EC 0x3DC 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_06_LPUART7_CTS_B 0x1EC 0x3DC 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_06_SAI1_RX_DATA00 0x1EC 0x3DC 0x594 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_06_LPSPI2_PCS0 0x1EC 0x3DC 0x4FC 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_06_GPIO3_IO06 0x1EC 0x3DC 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_07_SEMC_CSX1 0x1F0 0x3E0 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_07_FLEXSPI_A_SCLK 0x1F0 0x3E0 0x4C8 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_07_LPUART7_RTS_B 0x1F0 0x3E0 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_07_SAI1_TX_DATA00 0x1F0 0x3E0 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_07_LPSPI2_SCK 0x1F0 0x3E0 0x500 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_07_GPIO3_IO07 0x1F0 0x3E0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_07_CCM_REF_EN_B 0x1F0 0x3E0 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_08_USDHC2_DATA4 0x1F4 0x3E4 0x5F8 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_08_FLEXSPI_A_DATA0 0x1F4 0x3E4 0x4A8 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_08_LPUART7_TXD 0x1F4 0x3E4 0x55C 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_08_SAI1_TX_BLCK 0x1F4 0x3E4 0x5A8 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_08_LPSPI2_SDO 0x1F4 0x3E4 0x508 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_08_GPIO3_IO08 0x1F4 0x3E4 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_08_SEMC_CSX2 0x1F4 0x3E4 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_09_USDHC2_DATA5 0x1F8 0x3E8 0x5FC 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_09_FLEXSPI_A_DATA1 0x1F8 0x3E8 0x4AC 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_09_LPUART7_RXD 0x1F8 0x3E8 0x558 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_09_SAI1_TX_SYNC 0x1F8 0x3E8 0x5AC 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_09_LPSPI2_SDI 0x1F8 0x3E8 0x504 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_09_GPIO3_IO09 0x1F8 0x3E8 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_10_USDHC2_DATA6 0x1FC 0x3EC 0x600 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_10_FLEXSPI_A_DATA2 0x1FC 0x3EC 0x4B0 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_10_LPUART2_RXD 0x1FC 0x3EC 0x52C 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_10_LPI2C2_SDA 0x1FC 0x3EC 0x4D8 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_10_LPSPI2_PCS2 0x1FC 0x3EC 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_10_GPIO3_IO10 0x1FC 0x3EC 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_11_USDHC2_DATA7 0x200 0x3F0 0x604 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_11_FLEXSPI_A_DATA3 0x200 0x3F0 0x4B4 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_11_LPUART2_TXD 0x200 0x3F0 0x530 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_11_LPI2C2_SCL 0x200 0x3F0 0x4D4 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_11_LPSPI2_PCS3 0x200 0x3F0 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_11_GPIO3_IO11 0x200 0x3F0 0x000 0x5 0x0 + +#endif /* _DT_BINDINGS_PINCTRL_IMXRT1050_PINFUNC_H */
Add dtsi file for i.MXRT1050. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com
Best regards, Stefano Babic
Hi Giulio,
Please add information from where this code was ported (as I've pointed out in other mails).
Also a tip:
To avoid extra dtsi maintenance burden, there are u-boot*.dtsi files (in e.g. arch/arm/dts/) which add extra properties (U-boot specific).
In that way "original" dtsi (from e.g. Linux) are kept separated from U-Boot adjustments).
arch/arm/dts/imxrt1050.dtsi | 146 +++ include/dt-bindings/pinctrl/pins-imxrt1050.h | 993 +++++++++++++++++++ 2 files changed, 1139 insertions(+) create mode 100644 arch/arm/dts/imxrt1050.dtsi create mode 100644 include/dt-bindings/pinctrl/pins-imxrt1050.h
diff --git a/arch/arm/dts/imxrt1050.dtsi b/arch/arm/dts/imxrt1050.dtsi new file mode 100644 index 0000000000..b1d98e6feb --- /dev/null +++ b/arch/arm/dts/imxrt1050.dtsi @@ -0,0 +1,146 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/*
- Copyright (C) 2019
- Author(s): Giulio Benetti giulio.benetti@benettiengineering.com
+#include "skeleton.dtsi" +#include "armv7-m.dtsi" +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/clock/imxrt1050-clock.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/memory/imxrt-sdram.h>
- aliases {
gpio0 = &gpio1;
gpio1 = &gpio2;
gpio2 = &gpio3;
gpio3 = &gpio4;
gpio4 = &gpio5;
mmc0 = &usdhc1;
serial0 = &lpuart1;
- clocks {
u-boot,dm-spl;
osc {
u-boot,dm-spl;
compatible = "fsl,imx-osc", "fixed-clock";
#clock-cells = <0>;
clock-frequency = <24000000>;
- soc {
u-boot,dm-spl;
semc: semc@402f0000 {
u-boot,dm-spl;
compatible = "fsl,imxrt-semc";
reg = <0x402f0000 0x4000>;
clocks = <&clks IMXRT1050_CLK_SEMC>;
pinctrl-0 = <&pinctrl_semc>;
pinctrl-names = "default";
status = "okay";
lpuart1: serial@40184000 {
compatible = "fsl,imxrt-lpuart";
reg = <0x40184000 0x4000>;
interrupts = <GIC_SPI 20
IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMXRT1050_CLK_LPUART1>;
clock-names = "per";
status = "disabled";
iomuxc: iomuxc@401f8000 {
compatible = "fsl,imxrt-iomuxc";
reg = <0x401f8000 0x4000>;
fsl,mux_mask = <0x7>;
clks: ccm@400fc000 {
u-boot,dm-spl;
compatible = "fsl,imxrt1050-ccm";
reg = <0x400fc000 0x4000>;
interrupts = <GIC_SPI 95
IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 96
#clock-cells = <1>;
usdhc1: usdhc@402c0000 {
u-boot,dm-spl;
compatible = "fsl,imxrt-usdhc";
reg = <0x402c0000 0x10000>;
interrupts = <GIC_SPI 110
clocks = <&clks IMXRT1050_CLK_USDHC1>;
bus-width = <4>;
fsl,tuning-start-tap = <20>;
fsl,tuning-step= <2>;
gpio1: gpio@401b8000 {
u-boot,dm-spl;
compatible = "fsl,imxrt-gpio",
"fsl,imx35-gpio";
reg = <0x401b8000 0x4000>;
interrupts = <GIC_SPI 80
<GIC_SPI 81
gpio-controller;
#gpio-cells = <2>;
interrupt-controller;
#interrupt-cells = <2>;
gpio2: gpio@401bc000 {
u-boot,dm-spl;
"fsl,imx35-gpio";
reg = <0x401bc000 0x4000>;
interrupts = <GIC_SPI 82
<GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>;
gpio-controller;
#gpio-cells = <2>;
gpio3: gpio@401c0000 {
u-boot,dm-spl;
"fsl,imx35-gpio";
reg = <0x401c0000 0x4000>;
interrupts = <GIC_SPI 84
<GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>;
gpio-controller;
#gpio-cells = <2>;
gpio4: gpio@401c4000 {
u-boot,dm-spl;
"fsl,imx35-gpio";
reg = <0x401c4000 0x4000>;
interrupts = <GIC_SPI 86
<GIC_SPI 87
gpio-controller;
#gpio-cells = <2>;
gpio5: gpio@400c0000 {
u-boot,dm-spl;
"fsl,imx35-gpio";
reg = <0x400c0000 0x4000>;
interrupts = <GIC_SPI 88
<GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>;
gpio-controller;
#gpio-cells = <2>;
+}; diff --git a/include/dt-bindings/pinctrl/pins-imxrt1050.h b/include/dt-bindings/pinctrl/pins-imxrt1050.h new file mode 100644 index 0000000000..a29031ab3d --- /dev/null +++ b/include/dt-bindings/pinctrl/pins-imxrt1050.h @@ -0,0 +1,993 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
+#ifndef _DT_BINDINGS_PINCTRL_IMXRT1050_PINFUNC_H +#define _DT_BINDINGS_PINCTRL_IMXRT1050_PINFUNC_H
+#define IMX_PAD_SION 0x40000000
- The pin function ID is a tuple of
<mux_reg conf_reg input_reg mux_mode input_val>
+#define MXRT1050_IOMUXC_GPIO_EMC_00_SEMC_DA00 0x014 0x204 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_00_FLEXPWM4_PWM0_A 0x014 0x204 0x494 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_00_LPSPI2_SCK 0x014 0x204 0x500 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_00_XBAR_INOUT2 0x014 0x204 0x60C 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_00_FLEXIO1_D00 0x014 0x204 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_00_GPIO4_IO00 0x014 0x204 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_01_SEMC_DA01 0x018 0x208 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_01_FLEXPWM4_PWM0_B 0x018 0x208 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_01_LPSPI2_PCS0 0x018 0x208 0x4FC 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_01_XBAR_INOUT3 0x018 0x208 0x610 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_01_FLEXIO1_D01 0x018 0x208 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_01_GPIO4_IO01 0x018 0x208 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_02_SEMC_DA02 0x01C 0x20C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_02_FLEXPWM4_PWM1_A 0x01C 0x20C 0x498 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_02_LPSPI2_SDO 0x01C 0x20C 0x508 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_02_XBAR_INOUT4 0x01C 0x20C 0x614 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_02_FLEXIO1_D02 0x01C 0x20C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_02_GPIO4_IO02 0x01C 0x20C 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_03_SEMC_DA03 0x020 0x210 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_03_FLEXPWM4_PWM1_B 0x020 0x210 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_03_LPSPI2_SDI 0x020 0x210 0x504 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_03_XBAR_INOUT5 0x020 0x210 0x618 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_03_FLEXIO1_D03 0x020 0x210 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_03_GPIO4_IO03 0x020 0x210 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_04_SEMC_DA04 0x024 0x214 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_04_FLEXPWM4_PWM2_A 0x024 0x214 0x49C 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_04_SAI2_TX_DATA 0x024 0x214 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_04_XBAR_INOUT6 0x024 0x214 0x61C 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_04_FLEXIO1_D04 0x024 0x214 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_04_GPIO4_IO04 0x024 0x214 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_05_SEMC_DA05 0x028 0x218 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_05_FLEXPWM4_PWM2_B 0x028 0x218 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_05_SAI2_TX_SYNC 0x028 0x218 0x5C4 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_05_XBAR_INOUT7 0x028 0x218 0x620 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_05_FLEXIO1_D05 0x028 0x218 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_05_GPIO4_IO05 0x028 0x218 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_06_SEMC_DA06 0x02C 0x21C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_06_FLEXPWM2_PWM0_A 0x02C 0x21C 0x478 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_06_SAI2_TX_BCLK 0x02C 0x21C 0x5C0 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_06_XBAR_INOUT8 0x02C 0x21C 0x624 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_06_FLEXIO1_D06 0x02C 0x21C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_06_GPIO4_IO06 0x02C 0x21C 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_07_SEMC_DA07 0x030 0x220 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_07_FLEXPWM2_PWM0_B 0x030 0x220 0x488 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_07_SAI2_MCLK 0x030 0x220 0x5B0 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_07_XBAR_INOUT9 0x030 0x220 0x628 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_07_FLEXIO1_D07 0x030 0x220 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_07_GPIO4_IO07 0x030 0x220 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_08_SEMC_DM00 0x034 0x224 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_08_FLEXPWM2_PWM1_A 0x034 0x224 0x47C 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_08_SAI2_RX_DATA 0x034 0x224 0x5B8 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_08_XBAR_INOUT17 0x034 0x224 0x62C 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_08_FLEXIO1_D08 0x034 0x224 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_08_GPIO4_IO08 0x034 0x224 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_09_SEMC_ADDR00 0x038 0x228 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_09_FLEXPWM2_PWM1_B 0x038 0x228 0x48C 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_09_SAI2_RX_SYNC 0x038 0x228 0x5BC 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_09_FLEXCAN2_TX 0x038 0x228 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_09_FLEXIO1_D09 0x038 0x228 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_09_GPIO4_IO09 0x038 0x228 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_10_SEMC_ADDR01 0x03C 0x22C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_10_FLEXPWM2_PWM2_A 0x03C 0x22C 0x480 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_10_SAI2_RX_BCLK 0x03C 0x22C 0x5B4 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_10_FLEXCAN2_RX 0x03C 0x22C 0x450 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_10_FLEXIO1_D10 0x03C 0x22C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_10_GPIO4_IO10 0x03C 0x22C 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_11_SEMC_ADDR02 0x040 0x230 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_11_FLEXPWM2_PWM2_B 0x040 0x230 0x490 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_11_LPI2C4_SDA 0x040 0x230 0x4E8 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_11_USDHC2_RESET_B 0x040 0x230 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_11_FLEXIO1_D11 0x040 0x230 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_11_GPIO4_IO11 0x040 0x230 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_12_SEMC_ADDR03 0x044 0x234 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_12_XBAR_INOUT24 0x044 0x234 0x640 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_12_LPI2C4_SCL 0x044 0x234 0x4E4 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_12_USDHC2_WP 0x044 0x234 0x5D8 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_12_FLEXPWM1_PWM3_A 0x044 0x234 0x454 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_12_GPIO4_IO12 0x044 0x234 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_13_SEMC_ADDR04 0x048 0x238 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_13_XBAR_INOUT25 0x048 0x238 0x650 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_13_LPUART3_TXD 0x048 0x238 0x53C 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_13_MQS_RIGHT 0x048 0x238 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_13_FLEXPWM1_PWM3_B 0x048 0x238 0x464 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_13_GPIO4_IO13 0x048 0x238 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_14_SEMC_ADDR05 0x04C 0x23C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_14_XBAR_INOUT19 0x04C 0x23C 0x654 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_14_LPUART3_RXD 0x04C 0x23C 0x538 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_14_MQS_LEFT 0x04C 0x23C 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_14_LPSPI2_PCS1 0x04C 0x23C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_14_GPIO4_IO14 0x04C 0x23C 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_15_SEMC_ADDR06 0x050 0x240 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_15_XBAR_INOUT20 0x050 0x240 0x634 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_15_LPUART3_CTS_B 0x050 0x240 0x534 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_15_SPDIF_OUT 0x050 0x240 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_15_TMR3_TIMER0 0x050 0x240 0x57C 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_15_GPIO4_IO15 0x050 0x240 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_16_SEMC_ADDR07 0x054 0x244 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_16_XBAR_INOUT21 0x054 0x244 0x658 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_16_LPUART3_RTS_B 0x054 0x244 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_16_SPDIF_IN 0x054 0x244 0x5C8 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_16_TMR3_TIMER1 0x054 0x244 0x580 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_16_GPIO4_IO16 0x054 0x244 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_17_SEMC_ADDR08 0x058 0x248 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_17_FLEXPWM4_PWM3_A 0x058 0x248 0x4A0 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_17_LPUART4_CTS_B 0x058 0x248 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_17_FLEXCAN1_TX 0x058 0x248 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_17_TMR3_TIMER2 0x058 0x248 0x584 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_17_GPIO4_IO17 0x058 0x248 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_18_SEMC_ADDR09 0x05C 0x24C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_18_FLEXPWM4_PWM3_B 0x05C 0x24C 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_18_LPUART4_RTS_B 0x05C 0x24C 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_18_FLEXCAN1_RX 0x05C 0x24C 0x44C 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_18_TMR3_TIMER3 0x05C 0x24C 0x588 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_18_GPIO4_IO18 0x05C 0x24C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_18_SNVS_VIO_5_CTL 0x05C 0x24C 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_19_SEMC_ADDR11 0x060 0x250 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_19_FLEXPWM2_PWM3_A 0x060 0x250 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_19_LPUART4_TXD 0x060 0x250 0x544 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_19_ENET_RX_DATA01 0x060 0x250 0x438 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_19_TMR2_TIMER0 0x060 0x250 0x56C 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_19_GPIO4_IO19 0x060 0x250 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_19_SNVS_VIO_5 0x060 0x250 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_20_SEMC_ADDR12 0x064 0x254 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_20_FLEXPWM2_PWM3_B 0x064 0x254 0x484 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_20_LPUART4_RXD 0x064 0x254 0x540 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_20_ENET_RX_DATA00 0x064 0x254 0x434 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_20_TMR2_TIMER0 0x064 0x254 0x570 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_20_GPIO4_IO20 0x064 0x254 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_21_SEMC_BA0 0x068 0x258 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_21_FLEXPWM3_PWM3_A 0x068 0x258 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_21_LPI2C3_SDA 0x068 0x258 0x4E0 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_21_ENET_TX_DATA01 0x068 0x258 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_21_TMR2_TIMER2 0x068 0x258 0x574 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_21_GPIO4_IO21 0x068 0x258 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_22_SEMC_BA1 0x06C 0x25C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_22_FLEXPWM3_PWM3_B 0x06C 0x25C 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_22_LPI2C3_SCL 0x06C 0x25C 0x4DC 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_22_ENET_TX_DATA00 0x06C 0x25C 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_22_TMR2_TIMER3 0x06C 0x25C 0x578 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_22_GPIO4_IO22 0x06C 0x25C 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_23_SEMC_ADDR10 0x070 0x260 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_23_FLEXPWM1_PWM0_A 0x070 0x260 0x458 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_23_LPUART5_TXD 0x070 0x260 0x54C 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_23_ENET_RX_EN 0x070 0x260 0x43C 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_23_GPT1_CAPTURE2 0x070 0x260 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_23_GPIO4_IO23 0x070 0x260 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_24_SEMC_CAS 0x074 0x264 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_24_FLEXPWM1_PWM0_B 0x074 0x264 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_24_LPUART5_RXD 0x074 0x264 0x548 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_24_ENET_TX_EN 0x074 0x264 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_24_GPT1_CAPTURE1 0x074 0x264 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_24_GPIO4_IO24 0x074 0x264 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_25_SEMC_RAS 0x078 0x268 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_25_FLEXPWM1_PWM1_A 0x078 0x268 0x45C 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_25_LPUART6_TXD 0x078 0x268 0x554 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_25_ENET_TX_CLK 0x078 0x268 0x448 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_25_ENET_REF_CLK 0x078 0x268 0x42C 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_25_GPIO4_IO25 0x078 0x268 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_26_SEMC_CLK 0x07C 0x26C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_26_FLEXPWM1_PWM1_B 0x07C 0x26C 0x46C 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_26_LPUART6_RXD 0x07C 0x26C 0x550 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_26_ENET_RX_ER 0x07C 0x26C 0x440 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_26_FLEXIO1_D12 0x07C 0x26C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_26_GPIO4_IO26 0x07C 0x26C 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_27_SEMC_CKE 0x080 0x270 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_27_FLEXPWM1_PWM2_A 0x080 0x270 0x460 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_27_LPUART5_RTS_B 0x080 0x270 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_27_LPSPI1_SCK 0x080 0x270 0x4F0 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_27_FLEXIO1_D13 0x080 0x270 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_27_GPIO4_IO27 0x080 0x270 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_28_SEMC_WE 0x084 0x274 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_28_FLEXPWM1_PWM2_B 0x084 0x274 0x470 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_28_LPUART5_CTS_B 0x084 0x274 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_28_LPSPI1_SDO 0x084 0x274 0x4F8 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_28_FLEXIO1_D14 0x084 0x274 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_28_GPIO4_IO28 0x084 0x274 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_29_SEMC_CS0 0x088 0x278 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_29_FLEXPWM3_PWM0_A 0x088 0x278 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_29_LPUART6_RTS_B 0x088 0x278 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_29_LPSPI1_SDI 0x088 0x278 0x4F4 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_29_FLEXIO1_D15 0x088 0x278 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_29_GPIO4_IO29 0x088 0x278 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_30_SEMC_DA08 0x08C 0x27C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_30_FLEXPWM3_PWM0_B 0x08C 0x27C 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_30_LPUART6_CTS_B 0x08C 0x27C 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_30_LPSPI1_PCS0 0x08C 0x27C 0x4EC 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_30_CSI_DATA23 0x08C 0x27C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_30_GPIO4_IO30 0x08C 0x27C 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_31_SEMC_DA09 0x090 0x280 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_31_FLEXPWM3_PWM1_A 0x090 0x280 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_31_LPUART7_TXD 0x090 0x280 0x55C 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_31_LPSPI1_PCS1 0x090 0x280 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_31_CSI_DATA22 0x090 0x280 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_31_GPIO4_IO31 0x090 0x280 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_32_SEMC_DA10 0x094 0x284 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_32_FLEXPWM3_PWM1_B 0x094 0x284 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_32_LPUART7_RXD 0x094 0x284 0x558 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_32_CCM_PMIC_READY 0x094 0x284 0x3FC 0x3 0x4 +#define MXRT1050_IOMUXC_GPIO_EMC_32_CSI_DATA21 0x094 0x284 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_32_GPIO3_IO18 0x094 0x284 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_33_SEMC_DA11 0x098 0x288 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_33_FLEXPWM3_PWM2_A 0x098 0x288 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_33_USDHC1_RESET_B 0x098 0x288 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_33_SAI3_RX_DATA 0x098 0x288 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_33_CSI_DATA20 0x098 0x288 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_33_GPIO3_IO19 0x098 0x288 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_34_SEMC_DA12 0x09C 0x28C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_34_FLEXPWM3_PWM2_B 0x09C 0x28C 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_34_USDHC1_VSELECT 0x09C 0x28C 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_34_SAI3_RX_SYNC 0x09C 0x28C 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_34_CSI_DATA19 0x09C 0x28C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_34_GPIO3_IO20 0x09C 0x28C 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_35_SEMC_DA13 0x0A0 0x290 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_35_XBAR_INOUT18 0x0A0 0x290 0x630 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_35_GPT1_COMPARE1 0x0A0 0x290 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_35_SAI3_RX_BCLK 0x0A0 0x290 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_35_CSI_DATA18 0x0A0 0x290 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_35_GPIO3_IO21 0x0A0 0x290 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_35_USDHC1_CD_B 0x0A0 0x290 0x5D4 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_36_SEMC_DA14 0x0A4 0x294 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_36_XBAR_INOUT22 0x0A4 0x294 0x638 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_36_GPT1_COMPARE2 0x0A4 0x294 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_36_SAI3_TX_DATA 0x0A4 0x294 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_36_CSI_DATA17 0x0A4 0x294 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_36_GPIO3_IO22 0x0A4 0x294 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_36_USDHC1_WP 0x0A4 0x294 0x5D8 0x6 0x1 + +#define MXRT1050_IOMUXC_GPIO_EMC_37_SEMC_DA15 0x0A8 0x298 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_37_XBAR_INOUT23 0x0A8 0x298 0x63C 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_37_GPT1_COMPARE3 0x0A8 0x298 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_37_SAI3_MCLK 0x0A8 0x298 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_37_CSI_DATA16 0x0A8 0x298 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_37_GPIO3_IO23 0x0A8 0x298 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_37_USDHC2_WP 0x0A8 0x298 0x608 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_38_SEMC_DM01 0x0AC 0x29C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_38_FLEXPWM1_PWM3_A 0x0AC 0x29C 0x454 0x1 0x2 +#define MXRT1050_IOMUXC_GPIO_EMC_38_LPUART8_TXD 0x0AC 0x29C 0x564 0x2 0x2 +#define MXRT1050_IOMUXC_GPIO_EMC_38_SAI3_TX_BCLK 0x0AC 0x29C 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_38_CSI_FIELD 0x0AC 0x29C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_38_GPIO3_IO24 0x0AC 0x29C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_38_USDHC2_VSELECT 0x0AC 0x29C 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_39_SEMC_DQS 0x0B0 0x2A0 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_39_FLEXPWM1_PWM3_B 0x0B0 0x2A0 0x464 0x1 0x2 +#define MXRT1050_IOMUXC_GPIO_EMC_39_LPUART8_RXD 0x0B0 0x2A0 0x560 0x2 0x2 +#define MXRT1050_IOMUXC_GPIO_EMC_39_SAI3_TX_SYNC 0x0B0 0x2A0 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_39_WDOG1_B 0x0B0 0x2A0 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_39_GPIO3_IO25 0x0B0 0x2A0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_39_USDHC2_CD_B 0x0B0 0x2A0 0x5E0 0x6 0x1 + +#define MXRT1050_IOMUXC_GPIO_EMC_40_SEMC_RDY 0x0B4 0x2A4 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_40_GPT2_CAPTURE2 0x0B4 0x2A4 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_40_LPSPI1_PCS2 0x0B4 0x2A4 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_40_USB_OTG2_OC 0x0B4 0x2A4 0x5CC 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_40_ENET_MDC 0x0B4 0x2A4 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_40_GPIO3_IO26 0x0B4 0x2A4 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_40_USDHC2_RESET_B 0x0B4 0x2A4 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_EMC_41_SEMC_CSX0 0x0B8 0x2A8 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_41_GPT2_CAPTURE1 0x0B8 0x2A8 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_41_LPSPI1_PCS3 0x0B8 0x2A8 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_41_USB_OTG2_PWR 0x0B8 0x2A8 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_41_ENET_MDIO 0x0B8 0x2A8 0x430 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_EMC_41_GPIO3_IO27 0x0B8 0x2A8 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_EMC_41_USDHC2_VSELECT 0x0B8 0x2A8 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_00_FLEXPWM2_PWM3_A 0x0BC 0x2AC 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_00_XBAR_INOUT14 0x0BC 0x2AC 0x644 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_00_REF_CLK_32K 0x0BC 0x2AC 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_00_USB_OTG2_ID 0x0BC 0x2AC 0x3F8 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_00_LPI2C1_SCLS 0x0BC 0x2AC 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_00_GPIO1_IO00 0x0BC 0x2AC 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_00_USDHC1_RESET_B 0x0BC 0x2AC 0x000 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_00_LPSPI3_SCK 0x0BC 0x2AC 0x510 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_01_FLEXPWM2_PWM3_B 0x0C0 0x2B0 0x484 0x0 0x2 +#define MXRT1050_IOMUXC_GPIO_AD_B0_01_XBAR_INOUT15 0x0C0 0x2B0 0x648 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_01_REF_CLK_24M 0x0C0 0x2B0 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_01_USB_OTG1_ID 0x0C0 0x2B0 0x3F4 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_01_LPI2C1_SDAS 0x0C0 0x2B0 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_01_GPIO1_IO01 0x0C0 0x2B0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_01_EWM_OUT_B 0x0C0 0x2B0 0x000 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_01_LPSPI3_SDO 0x0C0 0x2B0 0x518 0x7 0x1 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_02_FLEXCAN2_TX 0x0C4 0x2B4 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_02_XBAR_INOUT16 0x0C4 0x2B4 0x64C 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_02_LPUART6_TXD 0x0C4 0x2B4 0x554 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_02_USB_OTG1_PWR 0x0C4 0x2B4 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_02_FLEXPWM1_PWM0_X 0x0C4 0x2B4 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_02_GPIO1_IO02 0x0C4 0x2B4 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_02_LPI2C1_HREQ 0x0C4 0x2B4 0x000 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_02_LPSPI3_SDI 0x0C4 0x2B4 0x514 0x7 0x1 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_03_FLEXCAN2_RX 0x0C8 0x2B8 0x450 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_03_XBAR_INOUT17 0x0C8 0x2B8 0x62C 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_03_LPUART6_RXD 0x0C8 0x2B8 0x550 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_03_USB_OTG1_OC 0x0C8 0x2B8 0x5D0 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_03_FLEXPWM1_PWM1_X 0x0C8 0x2B8 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_03_GPIO1_IO03 0x0C8 0x2B8 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_03_REF_CLK_24M 0x0C8 0x2B8 0x000 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_03_LPSPI3_PCS0 0x0C8 0x2B8 0x50C 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_04_SRC_BOOT_MODE00 0x0CC 0x2BC 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_04_MQS_RIGHT 0x0CC 0x2BC 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_04_ENET_TX_DATA03 0x0CC 0x2BC 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_04_SAI2_TX_SYNC 0x0CC 0x2BC 0x5C4 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_04_CSI_DATA09 0x0CC 0x2BC 0x41C 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_04_GPIO1_IO04 0x0CC 0x2BC 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_04_PIT_TRIGGER00 0x0CC 0x2BC 0x000 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_04_LPSPI3_PCS1 0x0CC 0x2BC 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_05_SRC_BOOT_MODE01 0x0D0 0x2C0 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_05_MQS_LEFT 0x0D0 0x2C0 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_05_ENET_TX_DATA02 0x0D0 0x2C0 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_05_SAI2_TX_BCLK 0x0D0 0x2C0 0x5C0 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_05_CSI_DATA08 0x0D0 0x2C0 0x418 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_05_GPIO1_IO05 0x0D0 0x2C0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_05_XBAR_INOUT17 0x0D0 0x2C0 0x62C 0x6 0x2 +#define MXRT1050_IOMUXC_GPIO_AD_B0_05_LPSPI3_PCS2 0x0D0 0x2C0 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_06_JTAG_TMS 0x0D4 0x2C4 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_06_GPT2_COMPARE1 0x0D4 0x2C4 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_06_ENET_RX_CLK 0x0D4 0x2C4 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_06_SAI2_RX_BCLK 0x0D4 0x2C4 0x5B4 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_06_CSI_DATA07 0x0D4 0x2C4 0x414 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_06_GPIO1_IO06 0x0D4 0x2C4 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_06_XBAR_INOUT18 0x0D4 0x2C4 0x630 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_06_LPSPI3_PCS3 0x0D4 0x2C4 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_07_JTAG_TCK 0x0D8 0x2C8 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_07_GPT2_COMPARE2 0x0D8 0x2C8 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_07_ENET_TX_ER 0x0D8 0x2C8 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_07_SAI2_RX_SYNC 0x0D8 0x2C8 0x5BC 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_07_CSI_DATA06 0x0D8 0x2C8 0x410 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_07_GPIO1_IO07 0x0D8 0x2C8 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_07_XBAR_INOUT19 0x0D8 0x2C8 0x654 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_07_ENET_1588_EVENT3_OUT 0x0D8 0x2C8 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_08_JTAG_MOD 0x0DC 0x2CC 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_08_GPT2_COMPARE3 0x0DC 0x2CC 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_08_ENET_RX_DATA03 0x0DC 0x2CC 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_08_SAI2_RX_DATA 0x0DC 0x2CC 0x5B8 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_08_CSI_DATA05 0x0DC 0x2CC 0x40C 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_08_GPIO1_IO08 0x0DC 0x2CC 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_08_XBAR_INOUT20 0x0DC 0x2CC 0x634 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_08_ENET_1588_EVENT3_IN 0x0DC 0x2CC 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_09_JTAG_TDI 0x0E0 0x2D0 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_09_FLEXPWM2_PWM3_A 0x0E0 0x2D0 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_09_ENET_RX_DATA02 0x0E0 0x2D0 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_09_SAI2_TX_DATA 0x0E0 0x2D0 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_09_CSI_DATA04 0x0E0 0x2D0 0x408 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_09_GPIO1_IO09 0x0E0 0x2D0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_09_XBAR_INOUT21 0x0E0 0x2D0 0x658 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_09_GPT2_CLK 0x0E0 0x2D0 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_10_JTAG_TDO 0x0E4 0x2D4 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_10_FLEXPWM1_PWM3_A 0x0E4 0x2D4 0x454 0x1 0x3 +#define MXRT1050_IOMUXC_GPIO_AD_B0_10_ENET_CRS 0x0E4 0x2D4 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_10_SAI2_MCLK 0x0E4 0x2D4 0x5B0 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_10_CSI_DATA03 0x0E4 0x2D4 0x404 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_10_GPIO1_IO10 0x0E4 0x2D4 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_10_XBAR_INOUT22 0x0E4 0x2D4 0x638 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_10_ENET_1588_EVENT0_OUT 0x0E4 0x2D4 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_11_JTAG_TRSTB 0x0E8 0x2D8 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_11_FLEXPWM1_PWM3_B 0x0E8 0x2D8 0x464 0x1 0x3 +#define MXRT1050_IOMUXC_GPIO_AD_B0_11_ENET_COL 0x0E8 0x2D8 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_11_WDOG1_B 0x0E8 0x2D8 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_11_CSI_DATA02 0x0E8 0x2D8 0x400 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_11_GPIO1_IO11 0x0E8 0x2D8 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_11_XBAR_INOUT23 0x0E8 0x2D8 0x63C 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_11_ENET_1588_EVENT0_IN 0x0E8 0x2D8 0x444 0x7 0x1 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_12_LPI2C4_SCL 0x0EC 0x2DC 0x4E4 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_12_CCM_PMIC_READY 0x0EC 0x2DC 0x3FC 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_12_LPUART1_TXD 0x0EC 0x2DC 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_12_WDOG2_B 0x0EC 0x2DC 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_12_FLEXPWM1_PWM2_X 0x0EC 0x2DC 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_12_GPIO1_IO12 0x0EC 0x2DC 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_12_ENET_1588_EVENT1_OUT 0x0EC 0x2DC 0x000 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_12_NMI 0x0EC 0x2DC 0x568 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_13_LPI2C4_SDA 0x0F0 0x2E0 0x4E8 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_13_GPT1_CLK 0x0F0 0x2E0 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_13_LPUART1_RXD 0x0F0 0x2E0 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_13_EWM_OUT_B 0x0F0 0x2E0 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_13_FLEXPWM1_PWM3_X 0x0F0 0x2E0 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_13_GPIO1_IO13 0x0F0 0x2E0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_13_ENET_1588_EVENT1_IN 0x0F0 0x2E0 0x000 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_13_REF_CLK_24M 0x0F0 0x2E0 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_14_USB_OTG2_OC 0x0F4 0x2E4 0x5CC 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_14_XBAR_INOUT24 0x0F4 0x2E4 0x640 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B0_14_LPUART1_CTS_B 0x0F4 0x2E4 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_14_ENET_1588_EVENT0_OUT 0x0F4 0x2E4 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_14_CSI_VSYNC 0x0F4 0x2E4 0x428 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_14_GPIO1_IO14 0x0F4 0x2E4 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_14_FLEXCAN2_TX 0x0F4 0x2E4 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B0_15_USB_OTG2_PWR 0x0F8 0x2E8 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_15_XBAR_INOUT25 0x0F8 0x2E8 0x650 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_15_LPUART1_RTS_B 0x0F8 0x2E8 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_15_ENET_1588_EVENT0_IN 0x0F8 0x2E8 0x444 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_15_CSI_HSYNC 0x0F8 0x2E8 0x420 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_15_GPIO1_IO15 0x0F8 0x2E8 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B0_15_FLEXCAN2_RX 0x0F8 0x2E8 0x450 0x6 0x2 +#define MXRT1050_IOMUXC_GPIO_AD_B0_15_WDOG1_WDOG_RST_B_DEB 0x0F8 0x2E8 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_00_USB_OTG2_ID 0x0FC 0x2EC 0x3F8 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_00_TMR3_TIMER0 0x0FC 0x2EC 0x57C 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_00_LPUART2_CTS_B 0x0FC 0x2EC 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_00_LPI2C1_SCL 0x0FC 0x2EC 0x4CC 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_00_WDOG1_B 0x0FC 0x2EC 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_00_GPIO1_IO16 0x0FC 0x2EC 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_00_USDHC1_WP 0x0FC 0x2EC 0x5D8 0x6 0x2 +#define MXRT1050_IOMUXC_GPIO_AD_B1_00_KPP_ROW07 0x0FC 0x2EC 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_01_USB_OTG1_PWR 0x100 0x2F0 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_01_TMR3_TIMER1 0x100 0x2F0 0x580 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_01_LPUART2_RTS_B 0x100 0x2F0 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_01_LPI2C1_SDA 0x100 0x2F0 0x4D0 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_01_CCM_PMIC_READY 0x100 0x2F0 0x3FC 0x4 0x2 +#define MXRT1050_IOMUXC_GPIO_AD_B1_01_GPIO1_IO17 0x100 0x2F0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_01_USDHC1_VSELECT 0x100 0x2F0 0x000 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_01_KPP_COL07 0x100 0x2F0 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_02_USB_OTG1_ID 0x104 0x2F4 0x3F4 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_02_TMR3_TIMER2 0x104 0x2F4 0x584 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_02_LPUART2_TXD 0x104 0x2F4 0x530 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_02_SPDIF_OUT 0x104 0x2F4 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_02_ENET_1588_EVENT2_OUT 0x104 0x2F4 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_02_GPIO1_IO18 0x104 0x2F4 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_02_USDHC1_CD_B 0x104 0x2F4 0x5D4 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_02_KPP_ROW06 0x104 0x2F4 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_03_USB_OTG1_OC 0x108 0x2F8 0x5D0 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_03_TMR3_TIMER3 0x108 0x2F8 0x588 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_03_LPUART2_RXD 0x108 0x2F8 0x52C 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_03_SPDIF_IN 0x108 0x2F8 0x5C8 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_03_ENET_1588_EVENT2_IN 0x108 0x2F8 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_03_GPIO1_IO19 0x108 0x2F8 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_03_USDHC2_CD_B 0x108 0x2F8 0x5E0 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_03_KPP_COL06 0x108 0x2F8 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_04_FLEXSPI_B_DATA3 0x10C 0x2FC 0x4C4 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_04_ENET_MDC 0x10C 0x2FC 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_04_LPUART3_CTS_B 0x10C 0x2FC 0x534 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_04_SPDIF_SR_CLK 0x10C 0x2FC 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_04_CSI_PIXCLK 0x10C 0x2FC 0x424 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_04_GPIO1_IO20 0x10C 0x2FC 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_04_USDHC2_DATA0 0x10C 0x2FC 0x5E8 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_04_KPP_ROW05 0x10C 0x2FC 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_05_FLEXSPI_B_DATA2 0x110 0x300 0x4C0 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_05_ENET_MDIO 0x110 0x300 0x430 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_05_LPUART3_RTS_B 0x110 0x300 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_05_SPDIF_OUT 0x110 0x300 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_05_CSI_MCLK 0x110 0x300 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_05_GPIO1_IO21 0x110 0x300 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_05_USDHC2_DATA1 0x110 0x300 0x5EC 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_05_KPP_COL05 0x110 0x300 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_06_FLEXSPI_B_DATA1 0x114 0x304 0x4BC 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_06_LPI2C3_SDA 0x114 0x304 0x4E0 0x1 0x2 +#define MXRT1050_IOMUXC_GPIO_AD_B1_06_LPUART3_TXD 0x114 0x304 0x53C 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_06_SPDIF_LOCK 0x114 0x304 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_06_CSI_VSYNC 0x114 0x304 0x428 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_06_GPIO1_IO22 0x114 0x304 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_06_USDHC2_DATA2 0x114 0x304 0x5F0 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_06_KPP_ROW04 0x114 0x304 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_07_FLEXSPI_B_DATA0 0x118 0x308 0x4B8 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_07_LPI2C3_SCL 0x118 0x308 0x4DC 0x1 0x2 +#define MXRT1050_IOMUXC_GPIO_AD_B1_07_LPUART3_RXD 0x118 0x308 0x538 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_07_SPDIF_EXT_CLK 0x118 0x308 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_07_CSI_HSYNC 0x118 0x308 0x420 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_07_GPIO1_IO23 0x118 0x308 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_07_USDHC2_DATA3 0x118 0x308 0x5F4 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_07_KPP_COL04 0x118 0x308 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_08_FLEXSPI_A_SS1_B 0x11C 0x30C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_08_FLEXPWM4_PWM0_A 0x11C 0x30C 0x494 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_08_FLEXCAN1_TX 0x11C 0x30C 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_08_CCM_PMIC_READY 0x11C 0x30C 0x3FC 0x3 0x3 +#define MXRT1050_IOMUXC_GPIO_AD_B1_08_CSI_DATA09 0x11C 0x30C 0x41C 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_08_GPIO1_IO24 0x11C 0x30C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_08_USDHC2_CMD 0x11C 0x30C 0x5E4 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_08_KPP_ROW03 0x11C 0x30C 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_09_FLEXSPI_A_DQS 0x120 0x310 0x4A4 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_09_FLEXPWM4_PWM1_A 0x120 0x310 0x498 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_09_FLEXCAN1_RX 0x120 0x310 0x44C 0x2 0x2 +#define MXRT1050_IOMUXC_GPIO_AD_B1_09_SAI1_MCLK 0x120 0x310 0x58C 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_09_CSI_DATA08 0x120 0x310 0x418 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_09_GPIO1_IO25 0x120 0x310 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_09_USDHC2_CLK 0x120 0x310 0x5DC 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_09_KPP_COL03 0x120 0x310 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_10_FLEXSPI_A_DATA3 0x124 0x314 0x4B4 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_10_WDOG1_B 0x124 0x314 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_10_LPUART8_TXD 0x124 0x314 0x564 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_10_SAI1_RX_SYNC 0x124 0x314 0x5A4 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_10_CSI_DATA07 0x124 0x314 0x414 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_10_GPIO1_IO26 0x124 0x314 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_10_USDHC2_WP 0x124 0x314 0x608 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_10_KPP_ROW02 0x124 0x314 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_11_FLEXSPI_A_DATA2 0x128 0x318 0x4B0 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_11_EWM_OUT_B 0x128 0x318 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_11_LPUART8_RXD 0x128 0x318 0x560 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_11_SAI1_RX_BCLK 0x128 0x318 0x590 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_11_CSI_DATA06 0x128 0x318 0x410 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_11_GPIO1_IO27 0x128 0x318 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_11_USDHC2_RESET_B 0x128 0x318 0x000 0x6 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_11_KPP_COL02 0x128 0x318 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_12_FLEXSPI_A_DATA1 0x12C 0x31C 0x4AC 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_12_ACMP1_OUT 0x12C 0x31C 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_12_LPSPI3_PCS0 0x12C 0x31C 0x50C 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_12_SAI1_RX_DATA00 0x12C 0x31C 0x594 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_12_CSI_DATA05 0x12C 0x31C 0x40C 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_12_GPIO1_IO28 0x12C 0x31C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_12_USDHC2_DATA4 0x12C 0x31C 0x5F8 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_12_KPP_ROW01 0x12C 0x31C 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_13_FLEXSPI_A_DATA0 0x130 0x320 0x4A8 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_13_ACMP2_OUT 0x130 0x320 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_13_LPSPI3_SDI 0x130 0x320 0x514 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_13_SAI1_TX_DATA00 0x130 0x320 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_13_CSI_DATA04 0x130 0x320 0x408 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_13_GPIO1_IO29 0x130 0x320 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_13_USDHC2_DATA5 0x130 0x320 0x5FC 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_13_KPP_COL01 0x130 0x320 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_14_FLEXSPI_A_SCLK 0x134 0x324 0x4C8 0x0 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_14_ACMP3_OUT 0x134 0x324 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_14_LPSPI3_SDO 0x134 0x324 0x518 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_14_SAI1_TX_BCLK 0x134 0x324 0x5A8 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_14_CSI_DATA03 0x134 0x324 0x404 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_14_GPIO1_IO30 0x134 0x324 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_14_USDHC2_DATA6 0x134 0x324 0x600 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_14_KPP_ROW00 0x134 0x324 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_AD_B1_15_FLEXSPI_A_SS0_B 0x138 0x328 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_15_ACMP4_OUT 0x138 0x328 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_15_LPSPI3_SCK 0x138 0x328 0x510 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_15_SAI1_TX_SYNC 0x138 0x328 0x5AC 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_15_CSI_DATA02 0x138 0x328 0x400 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_15_GPIO1_IO31 0x138 0x328 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_AD_B1_15_USDHC2_DATA7 0x138 0x328 0x604 0x6 0x1 +#define MXRT1050_IOMUXC_GPIO_AD_B1_15_KPP_COL00 0x138 0x328 0x000 0x7 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_00_LCD_CLK 0x13C 0x32C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_00_TMR1_TIMER0 0x13C 0x32C 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_00_MQS_RIGHT 0x13C 0x32C 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_00_LPSPI4_PCS0 0x13C 0x32C 0x51C 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_00_FLEXIO2_D00 0x13C 0x32C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_00_GPIO2_IO00 0x13C 0x32C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_00_SEMC_CSX1 0x13C 0x32C 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_01_LCD_ENABLE 0x140 0x330 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_01_TMR1_TIMER1 0x140 0x330 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_01_MQS_LEFT 0x140 0x330 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_01_LPSPI4_SDI 0x140 0x330 0x524 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_01_FLEXIO2_D01 0x140 0x330 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_01_GPIO2_IO01 0x140 0x330 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_01_SEMC_CSX2 0x140 0x330 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_02_LCD_HSYNC 0x144 0x334 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_02_TMR1_TIMER2 0x144 0x334 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_02_FLEXCAN1_TX 0x144 0x334 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_02_LPSPI4_SDO 0x144 0x334 0x528 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_02_FLEXIO2_D02 0x144 0x334 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_02_GPIO2_IO02 0x144 0x334 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_02_SEMC_CSX3 0x144 0x334 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_03_LCD_VSYNC 0x148 0x338 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_03_TMR2_TIMER0 0x148 0x338 0x56C 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_03_FLEXCAN1_RX 0x148 0x338 0x44C 0x2 0x3 +#define MXRT1050_IOMUXC_GPIO_B0_03_LPSPI4_SCK 0x148 0x338 0x520 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_03_FLEXIO2_D03 0x148 0x338 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_03_GPIO2_IO03 0x148 0x338 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_03_WDOG2_RESET_B_DEB 0x148 0x338 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_04_LCD_DATA00 0x14C 0x33C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_04_TMR2_TIMER1 0x14C 0x33C 0x570 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_04_LPI2C2_SCL 0x14C 0x33C 0x4D4 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_04_ARM_TRACE00 0x14C 0x33C 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_04_FLEXIO2_D04 0x14C 0x33C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_04_GPIO2_IO04 0x14C 0x33C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_04_SRC_BT_CFG00 0x14C 0x33C 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_05_LCD_DATA01 0x150 0x340 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_05_TMR2_TIMER2 0x150 0x340 0x574 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_05_LPI2C2_SDA 0x150 0x340 0x4D8 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_05_ARM_TRACE01 0x150 0x340 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_05_FLEXIO2_D05 0x150 0x340 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_05_GPIO2_IO05 0x150 0x340 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_05_SRC_BT_CFG01 0x150 0x340 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_06_LCD_DATA02 0x154 0x344 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_06_TMR3_TIMER0 0x154 0x344 0x57C 0x1 0x2 +#define MXRT1050_IOMUXC_GPIO_B0_06_FLEXPWM2_PWM0_A 0x154 0x344 0x478 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_06_ARM_TRACE02 0x154 0x344 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_06_FLEXIO2_D06 0x154 0x344 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_06_GPIO2_IO06 0x154 0x344 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_06_SRC_BT_CFG02 0x154 0x344 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_07_LCD_DATA03 0x158 0x348 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_07_TMR3_TIMER1 0x158 0x348 0x580 0x1 0x2 +#define MXRT1050_IOMUXC_GPIO_B0_07_FLEXPWM2_PWM0_B 0x158 0x348 0x488 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_07_ARM_TRACE03 0x158 0x348 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_07_FLEXIO2_D07 0x158 0x348 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_07_GPIO2_IO07 0x158 0x348 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_07_SRC_BT_CFG03 0x158 0x348 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_08_LCD_DATA04 0x15C 0x34C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_08_TMR3_TIMER2 0x15C 0x34C 0x584 0x1 0x2 +#define MXRT1050_IOMUXC_GPIO_B0_08_FLEXPWM2_PWM1_A 0x15C 0x34C 0x47C 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_08_LPUART3_TXD 0x15C 0x34C 0x53C 0x3 0x2 +#define MXRT1050_IOMUXC_GPIO_B0_08_FLEXIO2_D08 0x15C 0x34C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_08_GPIO2_IO08 0x15C 0x34C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_08_SRC_BT_CFG04 0x15C 0x34C 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_09_LCD_DATA05 0x160 0x350 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_09_TMR4_TIMER0 0x160 0x350 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_09_FLEXPWM2_PWM1_B 0x160 0x350 0x48C 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_09_LPUART3_RXD 0x160 0x350 0x538 0x3 0x2 +#define MXRT1050_IOMUXC_GPIO_B0_09_FLEXIO2_D09 0x160 0x350 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_09_GPIO2_IO09 0x160 0x350 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_09_SRC_BT_CFG05 0x160 0x350 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_10_LCD_DATA06 0x164 0x354 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_10_TMR4_TIMER1 0x164 0x354 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_10_FLEXPWM2_PWM2_A 0x164 0x354 0x480 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_10_SAI1_TX_DATA03 0x164 0x354 0x598 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_10_FLEXIO2_D10 0x164 0x354 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_10_GPIO2_IO10 0x164 0x354 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_10_SRC_BT_CFG06 0x164 0x354 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_11_LCD_DATA07 0x168 0x358 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_11_TMR4_TIMER2 0x168 0x358 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_11_FLEXPWM2_PWM2_B 0x168 0x358 0x490 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_11_SAI1_TX_DATA02 0x168 0x358 0x59C 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_11_FLEXIO2_D11 0x168 0x358 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_11_GPIO2_IO11 0x168 0x358 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_11_SRC_BT_CFG07 0x168 0x358 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_12_LCD_DATA08 0x16C 0x35C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_12_XBAR_INOUT10 0x16C 0x35C 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_12_ARM_TRACE_CLK 0x16C 0x35C 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_12_SAI1_TX_DATA01 0x16C 0x35C 0x5A0 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B0_12_FLEXIO2_D12 0x16C 0x35C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_12_GPIO2_IO12 0x16C 0x35C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_12_SRC_BT_CFG08 0x16C 0x35C 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_13_LCD_DATA09 0x170 0x360 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_13_XBAR_INOUT11 0x170 0x360 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_13_ARM_TRACE_SWO 0x170 0x360 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_13_SAI1_MCLK 0x170 0x360 0x58C 0x3 0x2 +#define MXRT1050_IOMUXC_GPIO_B0_13_FLEXIO2_D13 0x170 0x360 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_13_GPIO2_IO13 0x170 0x360 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_13_SRC_BT_CFG09 0x170 0x360 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_14_LCD_DATA10 0x174 0x364 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_14_XBAR_INOUT12 0x174 0x364 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_14_ARM_CM7_TXEV 0x174 0x364 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_14_SAI1_RX_SYNC 0x174 0x364 0x5A4 0x3 0x2 +#define MXRT1050_IOMUXC_GPIO_B0_14_FLEXIO2_D14 0x174 0x364 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_14_GPIO2_IO14 0x174 0x364 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_14_SRC_BT_CFG10 0x174 0x364 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B0_15_LCD_DATA11 0x178 0x368 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_15_XBAR_INOUT13 0x178 0x368 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_15_ARM_CM7_RXEV 0x178 0x368 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_15_SAI1_RX_BCLK 0x178 0x368 0x590 0x3 0x2 +#define MXRT1050_IOMUXC_GPIO_B0_15_FLEXIO2_D15 0x178 0x368 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_15_GPIO2_IO15 0x178 0x368 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B0_15_SRC_BT_CFG11 0x178 0x368 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B1_00_LCD_DATA12 0x17C 0x36C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_00_XBAR_INOUT14 0x17C 0x36C 0x644 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_00_LPUART4_TXD 0x17C 0x36C 0x544 0x2 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_00_SAI1_RX_DATA00 0x17C 0x36C 0x594 0x3 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_00_FLEXIO2_D16 0x17C 0x36C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_00_GPIO2_IO16 0x17C 0x36C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_00_FLEXPWM1_PWM3_A 0x17C 0x36C 0x454 0x6 0x4 + +#define MXRT1050_IOMUXC_GPIO_B1_01_LCD_DATA13 0x180 0x370 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_01_XBAR_INOUT15 0x180 0x370 0x648 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_01_LPUART4_RXD 0x180 0x370 0x540 0x2 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_01_SAI1_TX_DATA00 0x180 0x370 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_01_FLEXIO2_D17 0x180 0x370 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_01_GPIO2_IO17 0x180 0x370 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_01_FLEXPWM1_PWM3_B 0x180 0x370 0x464 0x6 0x4 + +#define MXRT1050_IOMUXC_GPIO_B1_02_LCD_DATA14 0x184 0x374 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_02_XBAR_INOUT16 0x184 0x374 0x64C 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_02_LPSPI4_PCS2 0x184 0x374 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_02_SAI1_TX_BCLK 0x184 0x374 0x5A8 0x3 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_02_FLEXIO2_D18 0x184 0x374 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_02_GPIO2_IO18 0x184 0x374 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_02_FLEXPWM2_PWM3_A 0x184 0x374 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B1_03_LCD_DATA15 0x188 0x378 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_03_XBAR_INOUT17 0x188 0x378 0x62C 0x1 0x3 +#define MXRT1050_IOMUXC_GPIO_B1_03_LPSPI4_PCS1 0x188 0x378 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_03_SAI1_TX_SYNC 0x188 0x378 0x5AC 0x3 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_03_FLEXIO2_D19 0x188 0x378 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_03_GPIO2_IO19 0x188 0x378 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_03_FLEXPWM2_PWM3_B 0x188 0x378 0x484 0x6 0x3 + +#define MXRT1050_IOMUXC_GPIO_B1_04_LCD_DATA16 0x18C 0x37C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_04_LPSPI4_PCS0 0x18C 0x37C 0x51C 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_04_CSI_DATA15 0x18C 0x37C 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_04_ENET_RX_DATA00 0x18C 0x37C 0x434 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_04_FLEXIO2_D20 0x18C 0x37C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_04_GPIO2_IO20 0x18C 0x37C 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_B1_05_LCD_DATA17 0x190 0x380 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_05_LPSPI4_SDI 0x190 0x380 0x524 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_05_CSI_DATA14 0x190 0x380 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_05_ENET_RX_DATA01 0x190 0x380 0x438 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_05_FLEXIO2_D21 0x190 0x380 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_05_GPIO2_IO21 0x190 0x380 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_B1_06_LCD_DATA18 0x194 0x384 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_06_LPSPI4_SDO 0x194 0x384 0x528 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_06_CSI_DATA13 0x194 0x384 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_06_ENET_RX_EN 0x194 0x384 0x43C 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_06_FLEXIO2_D22 0x194 0x384 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_06_GPIO2_IO22 0x194 0x384 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_B1_07_LCD_DATA19 0x198 0x388 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_07_LPSPI4_SCK 0x198 0x388 0x520 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_07_CSI_DATA12 0x198 0x388 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_07_ENET_TX_DATA00 0x198 0x388 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_07_FLEXIO2_D23 0x198 0x388 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_07_GPIO2_IO23 0x198 0x388 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_B1_08_LCD_DATA20 0x19C 0x38C 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_08_TMR1_TIMER3 0x19C 0x38C 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_08_CSI_DATA11 0x19C 0x38C 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_08_ENET_TX_DATA01 0x19C 0x38C 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_08_FLEXIO2_D24 0x19C 0x38C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_08_GPIO2_IO24 0x19C 0x38C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_08_FLEXCAN2_TX 0x19C 0x38C 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B1_09_LCD_DATA21 0x1A0 0x390 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_09_TMR2_TIMER3 0x1A0 0x390 0x578 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_09_CSI_DATA10 0x1A0 0x390 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_09_ENET_TX_EN 0x1A0 0x390 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_09_FLEXIO2_D25 0x1A0 0x390 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_09_GPIO2_IO25 0x1A0 0x390 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_09_FLEXCAN2_RX 0x1A0 0x390 0x450 0x6 0x3 + +#define MXRT1050_IOMUXC_GPIO_B1_10_LCD_DATA22 0x1A4 0x394 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_10_TMR3_TIMER3 0x1A4 0x394 0x588 0x1 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_10_CSI_DATA00 0x1A4 0x394 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_10_ENET_TX_CLK 0x1A4 0x394 0x448 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_10_FLEXIO2_D26 0x1A4 0x394 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_10_GPIO2_IO26 0x1A4 0x394 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_10_ENET_REF_CLK 0x1A4 0x394 0x42C 0x6 0x1 + +#define MXRT1050_IOMUXC_GPIO_B1_11_LCD_DATA23 0x1A8 0x398 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_11_TMR4_TIMER3 0x1A8 0x398 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_11_CSI_DATA01 0x1A8 0x398 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_11_ENET_RX_ER 0x1A8 0x398 0x440 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_11_FLEXIO2_D27 0x1A8 0x398 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_11_GPIO2_IO27 0x1A8 0x398 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_11_LPSPI4_PCS3 0x1A8 0x398 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B1_12_LPUART5_TXD 0x1AC 0x39C 0x54C 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_12_CSI_PIXCLK 0x1AC 0x39C 0x424 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_12_ENET_1588_EVENT0_IN 0x1AC 0x39C 0x444 0x3 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_12_FLEXIO2_D28 0x1AC 0x39C 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_12_GPIO2_IO28 0x1AC 0x39C 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_12_USDHC1_CD_B 0x1AC 0x39C 0x5D4 0x6 0x2 + +#define MXRT1050_IOMUXC_GPIO_B1_13_WDOG1_B 0x1B0 0x3A0 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_13_LPUART5_RXD 0x1B0 0x3A0 0x548 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_13_CSI_VSYNC 0x1B0 0x3A0 0x428 0x2 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_13_ENET_1588_EVENT0_OUT 0x1B0 0x3A0 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_13_FLEXIO2_D29 0x1B0 0x3A0 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_13_GPIO2_IO29 0x1B0 0x3A0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_13_USDHC1_WP 0x1B0 0x3A0 0x5D8 0x6 0x3 + +#define MXRT1050_IOMUXC_GPIO_B1_14_ENET_MDC 0x1B4 0x3A4 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_14_FLEXPWM4_PWM2_A 0x1B4 0x3A4 0x49C 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_14_CSI_HSYNC 0x1B4 0x3A4 0x420 0x2 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_14_XBAR_INOUT02 0x1B4 0x3A4 0x60C 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_14_FLEXIO2_D30 0x1B4 0x3A4 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_14_GPIO2_IO30 0x1B4 0x3A4 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_14_USDHC1_VSELECT 0x1B4 0x3A4 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_B1_15_ENET_MDIO 0x1B8 0x3A8 0x430 0x0 0x2 +#define MXRT1050_IOMUXC_GPIO_B1_15_FLEXPWM4_PWM3_A 0x1B8 0x3A8 0x4A0 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_15_CSI_MCLK 0x1B8 0x3A8 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_15_XBAR_INOUT03 0x1B8 0x3A8 0x610 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_B1_15_FLEXIO2_D31 0x1B8 0x3A8 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_15_GPIO2_IO31 0x1B8 0x3A8 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_B1_15_USDHC1_RESET_B 0x1B8 0x3A8 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B0_00_USDHC1_CMD 0x1BC 0x3AC 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_00_FLEXPWM1_PWM0_A 0x1BC 0x3AC 0x458 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_00_LPI2C3_SCL 0x1BC 0x3AC 0x4DC 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_00_XBAR_INOUT04 0x1BC 0x3AC 0x614 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_00_LPSPI1_SCK 0x1BC 0x3AC 0x4F0 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_00_GPIO3_IO12 0x1BC 0x3AC 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_00_FLEXSPI_A_SS1_B 0x1BC 0x3AC 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B0_01_USDHC1_CLK 0x1C0 0x3B0 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_01_FLEXPWM1_PWM0_B 0x1C0 0x3B0 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_01_LPI2C3_SDA 0x1C0 0x3B0 0x4E0 0x2 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_01_XBAR_INOUT05 0x1C0 0x3B0 0x618 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_01_LPSPI1_PCS0 0x1C0 0x3B0 0x4EC 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_01_GPIO3_IO13 0x1C0 0x3B0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_01_FLEXSPI_B_SS1_B 0x1C0 0x3B0 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B0_02_USDHC1_DATA0 0x1C4 0x3B4 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_02_FLEXPWM1_PWM1_A 0x1C4 0x3B4 0x45C 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_02_LPUART8_CTS_B 0x1C4 0x3B4 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_02_XBAR_INOUT06 0x1C4 0x3B4 0x61C 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_02_LPSPI1_SDO 0x1C4 0x3B4 0x4F8 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_02_GPIO3_IO14 0x1C4 0x3B4 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B0_03_USDHC1_DATA1 0x1C8 0x3B8 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_03_FLEXPWM1_PWM1_B 0x1C8 0x3B8 0x46C 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_03_LPUART8_RTS_B 0x1C8 0x3B8 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_03_XBAR_INOUT07 0x1C8 0x3B8 0x620 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_03_LPSPI1_SDI 0x1C8 0x3B8 0x4F4 0x4 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_03_GPIO3_IO15 0x1C8 0x3B8 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B0_04_USDHC1_DATA2 0x1CC 0x3BC 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_04_FLEXPWM1_PWM2_A 0x1CC 0x3BC 0x460 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_04_LPUART8_TXD 0x1CC 0x3BC 0x564 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_04_XBAR_INOUT08 0x1CC 0x3BC 0x624 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_04_FLEXSPI_B_SS0_B 0x1CC 0x3BC 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_04_GPIO3_IO16 0x1CC 0x3BC 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_04_CCM_CLKO1 0x1CC 0x3BC 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B0_05_USDHC1_DATA3 0x1D0 0x3C0 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_05_FLEXPWM1_PWM2_B 0x1D0 0x3C0 0x470 0x1 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_05_LPUART8_RXD 0x1D0 0x3C0 0x560 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_05_XBAR_INOUT09 0x1D0 0x3C0 0x628 0x3 0x1 +#define MXRT1050_IOMUXC_GPIO_SD_B0_05_FLEXSPI_B_DQS 0x1D0 0x3C0 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_05_GPIO3_IO17 0x1D0 0x3C0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B0_05_CCM_CLKO2 0x1D0 0x3C0 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_00_USDHC2_DATA3 0x1D4 0x3C4 0x5F4 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_00_FLEXSPI_B_DATA3 0x1D4 0x3C4 0x4C4 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_00_FLEXPWM1_PWM3_A 0x1D4 0x3C4 0x454 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_00_SAI1_TX_DATA03 0x1D4 0x3C4 0x598 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_00_LPUART4_TXD 0x1D4 0x3C4 0x544 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_00_GPIO3_IO00 0x1D4 0x3C4 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_01_USDHC2_DATA2 0x1D8 0x3C8 0x5F0 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_01_FLEXSPI_B_DATA2 0x1D8 0x3C8 0x4C0 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_01_FLEXPWM1_PWM3_B 0x1D8 0x3C8 0x464 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_01_SAI1_TX_DATA02 0x1D8 0x3C8 0x59C 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_01_LPUART4_RXD 0x1D8 0x3C8 0x540 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_01_GPIO3_IO01 0x1D8 0x3C8 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_02_USDHC2_DATA1 0x1DC 0x3CC 0x5EC 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_02_FLEXSPI_B_DATA1 0x1DC 0x3CC 0x4BC 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_02_FLEXPWM2_PWM3_A 0x1DC 0x3CC 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_02_SAI1_TX_DATA01 0x1DC 0x3CC 0x5A0 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_02_FLEXCAN1_TX 0x1DC 0x3CC 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_02_GPIO3_IO02 0x1DC 0x3CC 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_02_CCM_WAIT 0x1DC 0x3CC 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_03_USDHC2_DATA0 0x1E0 0x3D0 0x5E8 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_03_FLEXSPI_B_DATA0 0x1E0 0x3D0 0x4B8 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_03_FLEXPWM2_PWM3_B 0x1E0 0x3D0 0x484 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_03_SAI1_MCLK 0x1E0 0x3D0 0x58C 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_03_FLEXCAN1_RX 0x1E0 0x3D0 0x44C 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_03_GPIO3_IO03 0x1E0 0x3D0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_03_CCM_PMIC_READY 0x1E0 0x3D0 0x3FC 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_04_USDHC2_CLK 0x1E4 0x3D4 0x5DC 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_04_FLEXSPI_B_SCLK 0x1E4 0x3D4 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_04_LPI2C1_SCL 0x1E4 0x3D4 0x4CC 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_04_SAI1_RX_SYNC 0x1E4 0x3D4 0x5A4 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_04_FLEXCAN1_A_SS1_B 0x1E4 0x3D4 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_04_GPIO3_IO04 0x1E4 0x3D4 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_04_CCM_STOP 0x1E4 0x3D4 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_05_USDHC2_CMD 0x1E8 0x3D8 0x5E4 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_05_FLEXSPI_A_DQS 0x1E8 0x3D8 0x4A4 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_05_LPI2C1_SDA 0x1E8 0x3D8 0x4D0 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_05_SAI1_RX_BCLK 0x1E8 0x3D8 0x590 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_05_FLEXCAN1_B_SS0_B 0x1E8 0x3D8 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_05_GPIO3_IO05 0x1E8 0x3D8 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_06_USDHC2_RESET_B 0x1EC 0x3DC 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_06_FLEXSPI_A_SS0_B 0x1EC 0x3DC 0x000 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_06_LPUART7_CTS_B 0x1EC 0x3DC 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_06_SAI1_RX_DATA00 0x1EC 0x3DC 0x594 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_06_LPSPI2_PCS0 0x1EC 0x3DC 0x4FC 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_06_GPIO3_IO06 0x1EC 0x3DC 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_07_SEMC_CSX1 0x1F0 0x3E0 0x000 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_07_FLEXSPI_A_SCLK 0x1F0 0x3E0 0x4C8 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_07_LPUART7_RTS_B 0x1F0 0x3E0 0x000 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_07_SAI1_TX_DATA00 0x1F0 0x3E0 0x000 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_07_LPSPI2_SCK 0x1F0 0x3E0 0x500 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_07_GPIO3_IO07 0x1F0 0x3E0 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_07_CCM_REF_EN_B 0x1F0 0x3E0 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_08_USDHC2_DATA4 0x1F4 0x3E4 0x5F8 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_08_FLEXSPI_A_DATA0 0x1F4 0x3E4 0x4A8 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_08_LPUART7_TXD 0x1F4 0x3E4 0x55C 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_08_SAI1_TX_BLCK 0x1F4 0x3E4 0x5A8 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_08_LPSPI2_SDO 0x1F4 0x3E4 0x508 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_08_GPIO3_IO08 0x1F4 0x3E4 0x000 0x5 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_08_SEMC_CSX2 0x1F4 0x3E4 0x000 0x6 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_09_USDHC2_DATA5 0x1F8 0x3E8 0x5FC 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_09_FLEXSPI_A_DATA1 0x1F8 0x3E8 0x4AC 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_09_LPUART7_RXD 0x1F8 0x3E8 0x558 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_09_SAI1_TX_SYNC 0x1F8 0x3E8 0x5AC 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_09_LPSPI2_SDI 0x1F8 0x3E8 0x504 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_09_GPIO3_IO09 0x1F8 0x3E8 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_10_USDHC2_DATA6 0x1FC 0x3EC 0x600 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_10_FLEXSPI_A_DATA2 0x1FC 0x3EC 0x4B0 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_10_LPUART2_RXD 0x1FC 0x3EC 0x52C 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_10_LPI2C2_SDA 0x1FC 0x3EC 0x4D8 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_10_LPSPI2_PCS2 0x1FC 0x3EC 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_10_GPIO3_IO10 0x1FC 0x3EC 0x000 0x5 0x0 + +#define MXRT1050_IOMUXC_GPIO_SD_B1_11_USDHC2_DATA7 0x200 0x3F0 0x604 0x0 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_11_FLEXSPI_A_DATA3 0x200 0x3F0 0x4B4 0x1 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_11_LPUART2_TXD 0x200 0x3F0 0x530 0x2 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_11_LPI2C2_SCL 0x200 0x3F0 0x4D4 0x3 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_11_LPSPI2_PCS3 0x200 0x3F0 0x000 0x4 0x0 +#define MXRT1050_IOMUXC_GPIO_SD_B1_11_GPIO3_IO11 0x200 0x3F0 0x000 0x5 0x0 + +#endif /* _DT_BINDINGS_PINCTRL_IMXRT1050_PINFUNC_H */
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
On 1/28/20 9:31 AM, Lukasz Majewski wrote:
Hi Giulio,
Add dtsi file for i.MXRT1050.
Please add information from where this code was ported (as I've pointed out in other mails).
This is not ported, this is the original one. :-)
Also a tip:
To avoid extra dtsi maintenance burden, there are u-boot*.dtsi files (in e.g. arch/arm/dts/) which add extra properties (U-boot specific).
In that way "original" dtsi (from e.g. Linux) are kept separated from U-Boot adjustments).
Yes, next patch has -uboot.dtsi that includes this.
Best regards
This driver assumes that lpuart clock is already enabled before probing but using DM only lpuart won't be automatically enabled so add clk_enable() when probing if CONFIG_CLK is defined. If clock is not found, because DM is not used, let's emit a warning and proceed, because serial clock could also be already enabled by non DM code. If clock is found but cna't be enabled then return with error.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- V1->V2: * moved error as warning if clk not found --- drivers/serial/serial_lpuart.c | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/drivers/serial/serial_lpuart.c b/drivers/serial/serial_lpuart.c index 4b0a964d1b..b2ec56172e 100644 --- a/drivers/serial/serial_lpuart.c +++ b/drivers/serial/serial_lpuart.c @@ -483,6 +483,22 @@ static int lpuart_serial_pending(struct udevice *dev, bool input)
static int lpuart_serial_probe(struct udevice *dev) { +#if CONFIG_IS_ENABLED(CLK) + struct clk per_clk; + int ret; + + ret = clk_get_by_name(dev, "per", &per_clk); + if (!ret) { + ret = clk_enable(&per_clk); + if (ret) { + dev_err(dev, "Failed to get per clk: %d\n", ret); + return ret; + } + } else { + dev_warn(dev, "Failed to get per clk: %d\n", ret); + } +#endif + if (is_lpuart32(dev)) return _lpuart32_serial_init(dev); else
This driver assumes that lpuart clock is already enabled before probing but using DM only lpuart won't be automatically enabled so add clk_enable() when probing if CONFIG_CLK is defined. If clock is not found, because DM is not used, let's emit a warning and proceed, because serial clock could also be already enabled by non DM code. If clock is found but cna't be enabled then return with error. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com
Best regards, Stefano Babic
Hi Giulio,
^^^^ - can't
V1->V2:
- moved error as warning if clk not found
diff --git a/drivers/serial/serial_lpuart.c b/drivers/serial/serial_lpuart.c index 4b0a964d1b..b2ec56172e 100644 --- a/drivers/serial/serial_lpuart.c +++ b/drivers/serial/serial_lpuart.c @@ -483,6 +483,22 @@ static int lpuart_serial_pending(struct udevice *dev, bool input) static int lpuart_serial_probe(struct udevice *dev) { +#if CONFIG_IS_ENABLED(CLK)
- struct clk per_clk;
- int ret;
- ret = clk_get_by_name(dev, "per", &per_clk);
- if (!ret) {
if (ret) {
ret);
return ret;
- } else {
^^^^^^ - please change to debug() as some devices may enable CONFIG_CLK, but did not yet support (have implemented) this clock in CCF.
- if (is_lpuart32(dev)) return _lpuart32_serial_init(dev); else
Lukasz Majewski
Hi Lukasz,
On 1/28/20 9:36 AM, Lukasz Majewski wrote:
Hi Giulio,
^^^^ - can't
It's too late now, but...
V1->V2:
- int ret;
- if (!ret) {
if (ret) {
ret);
return ret;
- } else {
...not for this, I'm going to send a patch changing this string.
Best regards
Some device may enable CONFIG_CLK but not still support this clock in CC, so better use debug() in place of dev_warn() otherwise a lot of boards will throw useless dev_warn()s.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- drivers/serial/serial_lpuart.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/serial/serial_lpuart.c b/drivers/serial/serial_lpuart.c index ccb3ce6701..1087dc3b65 100644 --- a/drivers/serial/serial_lpuart.c +++ b/drivers/serial/serial_lpuart.c @@ -498,7 +498,7 @@ static int lpuart_serial_probe(struct udevice *dev) return ret; } } else { - dev_warn(dev, "Failed to get per clk: %d\n", ret); + debug("%s: Failed to get per clk: %d\n", __func__, ret); } #endif
On Fri, 31 Jan 2020 at 06:39, Giulio Benetti giulio.benetti@benettiengineering.com wrote:
Hi Lukasz,
^^ this must be CCF. Can you correct commit log while applying?
Thanks in advance
Hi Giulio,
Hi Lukasz,
I think that Stefano (or Tom) will apply this patch (as it is related to i.MX SoC's uart).
Thanks in advance
Lukasz Majewski
+Cc Stefano
On 2/1/20 1:48 PM, Lukasz Majewski wrote:
Hi Giulio,
Hi Lukasz,
Thanks in advance
Lukasz Majewski
Some device may enable CONFIG_CLK but not still support this clock in CC, so better use debug() in place of dev_warn() otherwise a lot of boards will throw useless dev_warn()s. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Reviewed-by: Simon Glass sjg@chromium.org
Giulio Benetti
Lukasz Majewski
sbabic@denx.de
