[U-Boot-Users] [PATCH] Consolidates ADS5121 IO Pin configuration
Signed-off-by: Martha Marx mmarx@silicontkx.com --- board/ads5121/Makefile | 2 +- board/ads5121/ads5121.c | 36 +------- board/ads5121/iopin.c | 96 ++++++++++++++++++++ board/ads5121/iopin.h | 220 +++++++++++++++++++++++++++++++++++++++++++++ cpu/mpc512x/fec.c | 15 --- include/configs/ads5121.h | 1 + 6 files changed, 321 insertions(+), 49 deletions(-) create mode 100644 board/ads5121/iopin.c create mode 100644 board/ads5121/iopin.h
diff --git a/board/ads5121/Makefile b/board/ads5121/Makefile index 0e4de61..88da762 100644 --- a/board/ads5121/Makefile +++ b/board/ads5121/Makefile @@ -27,7 +27,7 @@ $(shell mkdir -p $(OBJTREE)/board/freescale/common)
LIB = $(obj)lib$(BOARD).a
-COBJS-y := $(BOARD).o +COBJS-y := $(BOARD).o iopin.o COBJS-${CONFIG_FSL_DIU_FB} += ads5121_diu.o COBJS-${CONFIG_FSL_DIU_FB} += ../freescale/common/fsl_diu_fb.o COBJS-$(CONFIG_PCI) += pci.o diff --git a/board/ads5121/ads5121.c b/board/ads5121/ads5121.c index 95559ca..f6649a6 100644 --- a/board/ads5121/ads5121.c +++ b/board/ads5121/ads5121.c @@ -47,28 +47,13 @@ #define CSAW_START(start) ((start) & 0xFFFF0000) #define CSAW_STOP(start, size) (((start) + (size) - 1) >> 16)
-#define MPC5121_IOCTL_PSC6_0 (0x284/4) -#define MPC5121_IO_DIU_START (0x288/4) -#define MPC5121_IO_DIU_END (0x2fc/4) - -/* Functional pin muxing */ -#define MPC5121_IO_FUNC1 (0 << 7) -#define MPC5121_IO_FUNC2 (1 << 7) -#define MPC5121_IO_FUNC3 (2 << 7) -#define MPC5121_IO_FUNC4 (3 << 7) -#define MPC5121_IO_ST (1 << 2) -#define MPC5121_IO_DS_1 (0) -#define MPC5121_IO_DS_2 (1) -#define MPC5121_IO_DS_3 (2) -#define MPC5121_IO_DS_4 (3) - long int fixed_sdram(void); +extern void iopin_initialize(void);
int board_early_init_f (void) { volatile immap_t *im = (immap_t *) CFG_IMMR; u32 lpcaw, tmp32; - volatile ioctrl512x_t *ioctl = &(im->io_ctrl); int i;
/* @@ -114,16 +99,6 @@ int board_early_init_f (void) im->clk.sccr[0] = SCCR1_CLOCKS_EN; im->clk.sccr[1] = SCCR2_CLOCKS_EN;
- /* Configure DIU clock pin */ - tmp32 = ioctl->regs[MPC5121_IOCTL_PSC6_0]; - tmp32 &= ~0x1ff; - tmp32 |= MPC5121_IO_FUNC3 | MPC5121_IO_DS_4; - ioctl->regs[MPC5121_IOCTL_PSC6_0] = tmp32; - - /* Initialize IO pins (pin mux) for DIU function */ - for (i = MPC5121_IO_DIU_START; i < MPC5121_IO_DIU_END; i++) - ioctl->regs[i] |= (MPC5121_IO_FUNC3 | MPC5121_IO_DS_4); - return 0; }
@@ -265,17 +240,12 @@ int checkboard (void) { ushort brd_rev = *(vu_short *) (CFG_CPLD_BASE + 0x00); uchar cpld_rev = *(vu_char *) (CFG_CPLD_BASE + 0x02); - volatile immap_t *im = (immap_t *) CFG_IMMR; - volatile unsigned long *reg; - int i;
printf ("Board: ADS5121 rev. 0x%04x (CPLD rev. 0x%02x)\n", brd_rev, cpld_rev); + /* initialize function mux & slew rate IO inter alia on IO Pins */ + iopin_initialize();
- /* change the slew rate on all pata pins to max */ - reg = (unsigned long *) &(im->io_ctrl.regs[PATA_CE1_IDX]); - for (i = 0; i < 9; i++) - reg[i] |= 0x00000003; return 0; }
diff --git a/board/ads5121/iopin.c b/board/ads5121/iopin.c new file mode 100644 index 0000000..6a35c81 --- /dev/null +++ b/board/ads5121/iopin.c @@ -0,0 +1,96 @@ +/* + * (C) Copyright 2008 + * Martha J Marx, Silicon Turnkey Express, mmarx@silicontkx.com + * mpc512x I/O pin/pad initialization for the ADS5121 board + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <linux/types.h> +#include "iopin.h" + +/* + * IO PAD TYPES + * for all types fmux is used to select the funtion + * ds sets the slew rate + * STD pins nothing extra (can set ds & fmux only) + * STD_PU pue=1 to enable pull & pud sets whether up or down resistors + * STD_ST st sets the Schmitt trigger + * STD_PU_ST pue & pud sets pull-up/down resistors as in STD_PU + * st sets the Schmitt trigger + * PCI hold sets output delay + * PCI_ST hold sets output delay and st sets the Schmitt trigger + */ + +static struct iopin_t { + u_short p_offset; /* offset from IOCTL_MEM_OFFSET */ + u_short p_no; /* number of pins to set this way */ + u_short bit_or:7; /* Do bitwise OR instead of setting */ + u_short fmux:2; /* pad function select 0-3 */ + u_short hold:2; /* PCI pad types only; */ + u_short pud:1; /* pull resistor; PU types only; */ + /* if pue=1 then 0=pull-down, 1=pull-up */ + u_short pue:1; /* Pull resistor enable; _PU types only */ + u_short st:1; /* Schmitt trigger enable; _ST types only */ + u_short ds:2; /* Slew rate class, 0=class1, ..., 3=class4 */ +} ioregs_init[] = { +/* FUNC1=FEC_RX_DV Sets Next 3 to FEC pads */ + {IOCTL_SPDIF_TXCLK, 3, 0, 1, 0, 0, 0, 0, 3}, +/* Set highest Slew on 9 PATA pins */ + {IOCTL_PATA_CE1, 9, 1, 0, 0, 0, 0, 0, 3}, +/* FUNC1=FEC_COL Sets Next 15 to FEC pads */ + {IOCTL_PSC0_0, 15, 0, 1, 0, 0, 0, 0, 3}, +/* FUNC1=SPDIF_TXCLK */ + {IOCTL_LPC_CS1, 1, 0, 1, 0, 0, 0, 1, 3}, +/* FUNC2=SPDIF_TX and sets Next pin to SPDIF_RX */ + {IOCTL_I2C1_SCL, 2, 0, 2, 0, 0, 0, 1, 3}, +/* FUNC2=DIU CLK */ + {IOCTL_PSC6_0, 1, 0, 2, 0, 0, 0, 1, 3}, +/* FUNC2=DIU_HSYNC */ + {IOCTL_PSC6_1, 1, 0, 2, 0, 0, 0, 0, 3}, +/* FUNC2=DIUVSYNC Sets Next 26 to DIU Pads */ + {IOCTL_PSC6_4, 26, 0, 2, 0, 0, 0, 0, 3} +}; + +void iopin_initialize(void) +{ + short i, j, n, p; + u_long *reg; + + if (sizeof(ioregs_init) == 0) + return; + + immap_t *im = (immap_t *)CFG_IMMR; + reg = (u_long *)&(im->io_ctrl.regs[0]); + n = sizeof(ioregs_init) / sizeof(ioregs_init[0]); + + for (i = 0; i < n; i++) { + for (p = 0, j = ioregs_init[i].p_offset / sizeof(u_long); + p < ioregs_init[i].p_no; p++, j++) { + /* lowest 9 bits sets the register */ + if (ioregs_init[i].bit_or) + reg[j] |= *((u_long *) &ioregs_init[i].p_no) + & 0x000001ff; + else + reg[j] = *((u_long *) &ioregs_init[i].p_no) + & 0x000001ff; + } + } + return; +} diff --git a/board/ads5121/iopin.h b/board/ads5121/iopin.h new file mode 100644 index 0000000..73003e5 --- /dev/null +++ b/board/ads5121/iopin.h @@ -0,0 +1,220 @@ +/* + * (C) Copyright 2008 + * Martha J Marx, Silicon Turnkey Express, mmarx@silicontkx.com + * mpc512x I/O pin/pad initialization for the ADS5121 board + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#define IOCTL_MEM 0x000 +#define IOCTL_GP 0x004 +#define IOCTL_LPC_CLK 0x008 +#define IOCTL_LPC_OE 0x00C +#define IOCTL_LPC_RWB 0x010 +#define IOCTL_LPC_ACK 0x014 +#define IOCTL_LPC_CS0 0x018 +#define IOCTL_NFC_CE0 0x01C +#define IOCTL_LPC_CS1 0x020 +#define IOCTL_LPC_CS2 0x024 +#define IOCTL_LPC_AX03 0x028 +#define IOCTL_EMB_AX02 0x02C +#define IOCTL_EMB_AX01 0x030 +#define IOCTL_EMB_AX00 0x034 +#define IOCTL_EMB_AD31 0x038 +#define IOCTL_EMB_AD30 0x03C +#define IOCTL_EMB_AD29 0x040 +#define IOCTL_EMB_AD28 0x044 +#define IOCTL_EMB_AD27 0x048 +#define IOCTL_EMB_AD26 0x04C +#define IOCTL_EMB_AD25 0x050 +#define IOCTL_EMB_AD24 0x054 +#define IOCTL_EMB_AD23 0x058 +#define IOCTL_EMB_AD22 0x05C +#define IOCTL_EMB_AD21 0x060 +#define IOCTL_EMB_AD20 0x064 +#define IOCTL_EMB_AD19 0x068 +#define IOCTL_EMB_AD18 0x06C +#define IOCTL_EMB_AD17 0x070 +#define IOCTL_EMB_AD16 0x074 +#define IOCTL_EMB_AD15 0x078 +#define IOCTL_EMB_AD14 0x07C +#define IOCTL_EMB_AD13 0x080 +#define IOCTL_EMB_AD12 0x084 +#define IOCTL_EMB_AD11 0x088 +#define IOCTL_EMB_AD10 0x08C +#define IOCTL_EMB_AD09 0x090 +#define IOCTL_EMB_AD08 0x094 +#define IOCTL_EMB_AD07 0x098 +#define IOCTL_EMB_AD06 0x09C +#define IOCTL_EMB_AD05 0x0A0 +#define IOCTL_EMB_AD04 0x0A4 +#define IOCTL_EMB_AD03 0x0A8 +#define IOCTL_EMB_AD02 0x0AC +#define IOCTL_EMB_AD01 0x0B0 +#define IOCTL_EMB_AD00 0x0B4 +#define IOCTL_PATA_CE1 0x0B8 +#define IOCTL_PATA_CE2 0x0BC +#define IOCTL_PATA_ISOLATE 0x0C0 +#define IOCTL_PATA_IOR 0x0C4 +#define IOCTL_PATA_IOW 0x0C8 +#define IOCTL_PATA_IOCHRDY 0x0CC +#define IOCTL_PATA_INTRQ 0x0D0 +#define IOCTL_PATA_DRQ 0x0D4 +#define IOCTL_PATA_DACK 0x0D8 +#define IOCTL_NFC_WP 0x0DC +#define IOCTL_NFC_RB 0x0E0 +#define IOCTL_NFC_ALE 0x0E4 +#define IOCTL_NFC_CLE 0x0E8 +#define IOCTL_NFC_WE 0x0EC +#define IOCTL_NFC_RE 0x0F0 +#define IOCTL_PCI_AD31 0x0F4 +#define IOCTL_PCI_AD30 0x0F8 +#define IOCTL_PCI_AD29 0x0FC +#define IOCTL_PCI_AD28 0x100 +#define IOCTL_PCI_AD27 0x104 +#define IOCTL_PCI_AD26 0x108 +#define IOCTL_PCI_AD25 0x10C +#define IOCTL_PCI_AD24 0x110 +#define IOCTL_PCI_AD23 0x114 +#define IOCTL_PCI_AD22 0x118 +#define IOCTL_PCI_AD21 0x11C +#define IOCTL_PCI_AD20 0x120 +#define IOCTL_PCI_AD19 0x124 +#define IOCTL_PCI_AD18 0x128 +#define IOCTL_PCI_AD17 0x12C +#define IOCTL_PCI_AD16 0x130 +#define IOCTL_PCI_AD15 0x134 +#define IOCTL_PCI_AD14 0x138 +#define IOCTL_PCI_AD13 0x13C +#define IOCTL_PCI_AD12 0x140 +#define IOCTL_PCI_AD11 0x144 +#define IOCTL_PCI_AD10 0x148 +#define IOCTL_PCI_AD09 0x14C +#define IOCTL_PCI_AD08 0x150 +#define IOCTL_PCI_AD07 0x154 +#define IOCTL_PCI_AD06 0x158 +#define IOCTL_PCI_AD05 0x15C +#define IOCTL_PCI_AD04 0x160 +#define IOCTL_PCI_AD03 0x164 +#define IOCTL_PCI_AD02 0x168 +#define IOCTL_PCI_AD01 0x16C +#define IOCTL_PCI_AD00 0x170 +#define IOCTL_PCI_CBE0 0x174 +#define IOCTL_PCI_CBE1 0x178 +#define IOCTL_PCI_CBE2 0x17C +#define IOCTL_PCI_CBE3 0x180 +#define IOCTL_PCI_GNT2 0x184 +#define IOCTL_PCI_REQ2 0x188 +#define IOCTL_PCI_GNT1 0x18C +#define IOCTL_PCI_REQ1 0x190 +#define IOCTL_PCI_GNT0 0x194 +#define IOCTL_PCI_REQ0 0x198 +#define IOCTL_PCI_INTA 0x19C +#define IOCTL_PCI_CLK 0x1A0 +#define IOCTL_PCI_RST_OUT 0x1A4 +#define IOCTL_PCI_FRAME 0x1A8 +#define IOCTL_PCI_IDSEL 0x1AC +#define IOCTL_PCI_DEVSEL 0x1B0 +#define IOCTL_PCI_IRDY 0x1B4 +#define IOCTL_PCI_TRDY 0x1B8 +#define IOCTL_PCI_STOP 0x1BC +#define IOCTL_PCI_PAR 0x1C0 +#define IOCTL_PCI_PERR 0x1C4 +#define IOCTL_PCI_SERR 0x1C8 +#define IOCTL_SPDIF_TXCLK 0x1CC +#define IOCTL_SPDIF_TX 0x1D0 +#define IOCTL_SPDIF_RX 0x1D4 +#define IOCTL_I2C0_SCL 0x1D8 +#define IOCTL_I2C0_SDA 0x1DC +#define IOCTL_I2C1_SCL 0x1E0 +#define IOCTL_I2C1_SDA 0x1E4 +#define IOCTL_I2C2_SCL 0x1E8 +#define IOCTL_I2C2_SDA 0x1EC +#define IOCTL_IRQ0 0x1F0 +#define IOCTL_IRQ1 0x1F4 +#define IOCTL_CAN1_TX 0x1F8 +#define IOCTL_CAN2_TX 0x1FC +#define IOCTL_J1850_TX 0x200 +#define IOCTL_J1850_RX 0x204 +#define IOCTL_PSC_MCLK_IN 0x208 +#define IOCTL_PSC0_0 0x20C +#define IOCTL_PSC0_1 0x210 +#define IOCTL_PSC0_2 0x214 +#define IOCTL_PSC0_3 0x218 +#define IOCTL_PSC0_4 0x21C +#define IOCTL_PSC1_0 0x220 +#define IOCTL_PSC1_1 0x224 +#define IOCTL_PSC1_2 0x228 +#define IOCTL_PSC1_3 0x22C +#define IOCTL_PSC1_4 0x230 +#define IOCTL_PSC2_0 0x234 +#define IOCTL_PSC2_1 0x238 +#define IOCTL_PSC2_2 0x23C +#define IOCTL_PSC2_3 0x240 +#define IOCTL_PSC2_4 0x244 +#define IOCTL_PSC3_0 0x248 +#define IOCTL_PSC3_1 0x24C +#define IOCTL_PSC3_2 0x250 +#define IOCTL_PSC3_3 0x254 +#define IOCTL_PSC3_4 0x258 +#define IOCTL_PSC4_0 0x25C +#define IOCTL_PSC4_1 0x260 +#define IOCTL_PSC4_2 0x264 +#define IOCTL_PSC4_3 0x268 +#define IOCTL_PSC4_4 0x26C +#define IOCTL_PSC5_0 0x270 +#define IOCTL_PSC5_1 0x274 +#define IOCTL_PSC5_2 0x278 +#define IOCTL_PSC5_3 0x27C +#define IOCTL_PSC5_4 0x280 +#define IOCTL_PSC6_0 0x284 +#define IOCTL_PSC6_1 0x288 +#define IOCTL_PSC6_2 0x28C +#define IOCTL_PSC6_3 0x290 +#define IOCTL_PSC6_4 0x294 +#define IOCTL_PSC7_0 0x298 +#define IOCTL_PSC7_1 0x29C +#define IOCTL_PSC7_2 0x2A0 +#define IOCTL_PSC7_3 0x2A4 +#define IOCTL_PSC7_4 0x2A8 +#define IOCTL_PSC8_0 0x2AC +#define IOCTL_PSC8_1 0x2B0 +#define IOCTL_PSC8_2 0x2B4 +#define IOCTL_PSC8_3 0x2B8 +#define IOCTL_PSC8_4 0x2BC +#define IOCTL_PSC9_0 0x2C0 +#define IOCTL_PSC9_1 0x2C4 +#define IOCTL_PSC9_2 0x2C8 +#define IOCTL_PSC9_3 0x2CC +#define IOCTL_PSC9_4 0x2D0 +#define IOCTL_PSC10_0 0x2D4 +#define IOCTL_PSC10_1 0x2D8 +#define IOCTL_PSC10_2 0x2DC +#define IOCTL_PSC10_3 0x2E0 +#define IOCTL_PSC10_4 0x2E4 +#define IOCTL_PSC11_0 0x2E8 +#define IOCTL_PSC11_1 0x2EC +#define IOCTL_PSC11_2 0x2F0 +#define IOCTL_PSC11_3 0x2F4 +#define IOCTL_PSC11_4 0x2F8 +#define IOCTL_HRESET 0x2FC +#define IOCTL_SRESET 0x300 +#define IOCTL_CKSTP_OUT 0x304 +#define IOCTL_USB2_VBUS_PWR_FAULT 0x308 +#define IOCTL_USB2_VBUS_PWR_SELECT 0x30C +#define IOCTL_USB2_PHY_DRVV_BUS 0x310 diff --git a/cpu/mpc512x/fec.c b/cpu/mpc512x/fec.c index c226a8a..e9df7de 100644 --- a/cpu/mpc512x/fec.c +++ b/cpu/mpc512x/fec.c @@ -604,13 +604,10 @@ static int mpc512x_fec_recv (struct eth_device *dev) /********************************************************************/ int mpc512x_fec_initialize (bd_t * bis) { - - immap_t *im = (immap_t*) CFG_IMMR; mpc512x_fec_priv *fec; struct eth_device *dev; int i; char *tmp, *end, env_enetaddr[6]; - uint32 *reg; void * bd;
fec = (mpc512x_fec_priv *) malloc (sizeof(*fec)); @@ -639,18 +636,6 @@ int mpc512x_fec_initialize (bd_t * bis) fec512x_miiphy_read, fec512x_miiphy_write); #endif
- /* - * Initialize I\O pins - */ - reg = (uint32 *) &(im->io_ctrl.regs[PSC0_0_IDX]); - - for (i = 0; i < 15; i++) - reg[i] = IOCTRL_MUX_FEC | 0x00000001; - - im->io_ctrl.regs[SPDIF_TXCLOCK_IDX] = IOCTRL_MUX_FEC | 0x00000001; - im->io_ctrl.regs[SPDIF_TX_IDX] = IOCTRL_MUX_FEC | 0x00000001; - im->io_ctrl.regs[SPDIF_RX_IDX] = IOCTRL_MUX_FEC | 0x00000001; - /* Clean up space FEC's MIB and FIFO RAM ...*/ memset ((void *) MPC512X_FEC + 0x200, 0x00, 0x400);
diff --git a/include/configs/ads5121.h b/include/configs/ads5121.h index ae98359..50b3512 100644 --- a/include/configs/ads5121.h +++ b/include/configs/ads5121.h @@ -27,6 +27,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_ADS5121 1 /* * Memory map for the ADS5121 board: *
It's good that you remove iomux setting from the drivers like fec it should not be there.
It's NOT good that you now put them in another "driver" iopin.
The pins should be in board specific files. iopin should only contain helper functions not data that everybody that do a new board needs to go in and change/add.
put the table in ads5121.c and I'm happy with it. well I'm not sure we need this fancy stuff only gets harder to read but I take that over having the config spread out over different files like it's now.
On Thu, May 29, 2008 at 2:11 PM, Kenneth Johansson kenneth@southpole.se wrote:
Acked-by: Grant Likely grant.likely@secretlab.ca
I think this approach is okay. For now it is isolated within the board directory, but it can be factored out into common code where there are a few more 5121 board ports.
Cheers, g.
Grant Likely
Kenneth Johansson
Martha Marx
