[PATCH v2 0/2] smbios: copy QEMU tables
QEMU provides SMBIOS tables with detailed information. We should not try to replicate them in U-Boot.
With this series we add code to copy the QEMU generated SMBIOS tables to RAM. efi_smbios_register() later installs the SMBIOS table as EFI configuration table for the OS to pick it up.
If we want to inform about U-Boot, we can add a Firmware Inventory Information (type 45) table in future.
With 32bit ARM I did not see a correct SMBIOS table being transferred. We need to check if our code in qfw_read_entry() is 32bit compliant.
For providing SMBIOS support in QEMU for RISC-V I have sent a patch upstream:
[PATCH 1/1] target/riscv: SMBIOS support for RISC-V virt machine https://lore.kernel.org/qemu-riscv/9183a3fb-b9f7-470c-b9a6-8d8cc6dce7c3@cano...
Currently we have a predefined constant TABLE_SIZE = SZ_4K in lib/efi_loader/efi_smbios.c. We should strive to refactor the code in future to provide the length of the SMBIOS tables in global data. But that is beyond the scope of this series.
Further we should find a matainer for drivers/misc/qfw*. It would be plausible to add it to 'ACPI' maintenance.
A test via a new SMBIOS command is supplied in
[PATCH 0/5] cmd: provide command to display SMBIOS information https://lore.kernel.org/u-boot/20231223004429.247301-1-xypron.glpk@gmx.de/T/...
v2: fix parsing of SMBIOS anchor enable copying on x86 and 32bit ARM/RISC-V
Heinrich Schuchardt (2): smbios: SMBIOS 3.0 (64-bit) Entry Point structure smbios: copy QEMU tables
arch/x86/lib/tables.c | 2 +- drivers/misc/Kconfig | 7 ++ drivers/misc/Makefile | 1 + drivers/misc/qfw_smbios.c | 197 ++++++++++++++++++++++++++++++++++++ include/smbios.h | 26 +++++ lib/efi_loader/efi_smbios.c | 4 +- 6 files changed, 235 insertions(+), 2 deletions(-) create mode 100644 drivers/misc/qfw_smbios.c
-- 2.43.0
From: Heinrich Schuchardt heinrich.schuchardt@canonical.com
Add definition of the SMBIOS 3.0 (64-bit) Entry Point structure.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v2: no change --- include/smbios.h | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/include/smbios.h b/include/smbios.h index c9df2706f5..e601283d29 100644 --- a/include/smbios.h +++ b/include/smbios.h @@ -54,6 +54,32 @@ struct __packed smbios_entry { u8 bcd_rev; };
+/** + * struct smbios3_entry - SMBIOS 3.0 (64-bit) Entry Point structure + */ +struct __packed smbios3_entry { + /** @anchor: anchor string */ + u8 anchor[5]; + /** @checksum: checksum of the entry point structure */ + u8 checksum; + /** @length: length of the entry point structure */ + u8 length; + /** @major_ver: major version of the SMBIOS specification */ + u8 major_ver; + /** @minor_ver: minor version of the SMBIOS specification */ + u8 minor_ver; + /** @docrev: revision of the SMBIOS specification */ + u8 doc_rev; + /** @entry_point_rev: revision of the entry point structure */ + u8 entry_point_rev; + /** @reserved: reserved */ + u8 reserved; + /** maximum size of SMBIOS table */ + u32 max_struct_size; + /** @struct_table_address: 64-bit physical starting address */ + u64 struct_table_address; +}; + /* BIOS characteristics */ #define BIOS_CHARACTERISTICS_PCI_SUPPORTED (1 << 7) #define BIOS_CHARACTERISTICS_UPGRADEABLE (1 << 11) -- 2.43.0
Hi Heinrich,
On Sat, Dec 23, 2023 at 1:03 AM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
v2: no change
We have this struct elsewhere, as mentioned, but this one adds comments so is nicer.
- struct smbios3_entry - SMBIOS 3.0 (64-bit) Entry Point structure
u8 anchor[5];
u8 checksum;
u8 length;
u8 major_ver;
u8 minor_ver;
u8 doc_rev;
u8 entry_point_rev;
u8 reserved;
2.43.0
v2: no change
u8 anchor[5];
u8 checksum;
u8 length;
u8 major_ver;
u8 minor_ver;
u8 doc_rev;
u8 entry_point_rev;
u8 reserved;
2.43.0
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v2: fix parsing of SMBIOS anchor enable copying on x86 and 32bit ARM/RISC-V --- arch/x86/lib/tables.c | 2 +- drivers/misc/Kconfig | 7 ++ drivers/misc/Makefile | 1 + drivers/misc/qfw_smbios.c | 197 ++++++++++++++++++++++++++++++++++++ lib/efi_loader/efi_smbios.c | 4 +- 5 files changed, 209 insertions(+), 2 deletions(-) create mode 100644 drivers/misc/qfw_smbios.c
diff --git a/arch/x86/lib/tables.c b/arch/x86/lib/tables.c index 5b5070f7ca..914d9de0cb 100644 --- a/arch/x86/lib/tables.c +++ b/arch/x86/lib/tables.c @@ -61,7 +61,7 @@ static struct table_info table_list[] = { #ifdef CONFIG_GENERATE_ACPI_TABLE { "acpi", write_acpi_tables, BLOBLISTT_ACPI_TABLES, 0x10000, 0x1000}, #endif -#ifdef CONFIG_GENERATE_SMBIOS_TABLE +#if defined(CONFIG_GENERATE_SMBIOS_TABLE) && !defined(CONFIG_QFW_SMBIOS) { "smbios", write_smbios_table, BLOBLISTT_SMBIOS_TABLES, 0x1000, 0x100}, #endif }; diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index e8e4400516..d2536c54e0 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -561,6 +561,13 @@ config QFW_MMIO Hidden option to enable MMIO QEMU fw_cfg interface. This will be selected by the appropriate QEMU board.
+config QFW_SMBIOS + bool + default y + depends on QFW && SMBIOS && !SANDBOX + help + Hidden option to read SMBIOS tables from QEMU. + config I2C_EEPROM bool "Enable driver for generic I2C-attached EEPROMs" depends on MISC diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index cda701d38e..64bea92f51 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -66,6 +66,7 @@ obj-y += qfw.o obj-$(CONFIG_QFW_ACPI) += qfw_acpi.o obj-$(CONFIG_QFW_PIO) += qfw_pio.o obj-$(CONFIG_QFW_MMIO) += qfw_mmio.o +obj-$(CONFIG_QFW_SMBIOS) += qfw_smbios.o obj-$(CONFIG_SANDBOX) += qfw_sandbox.o endif obj-$(CONFIG_ROCKCHIP_EFUSE) += rockchip-efuse.o diff --git a/drivers/misc/qfw_smbios.c b/drivers/misc/qfw_smbios.c new file mode 100644 index 0000000000..9019345783 --- /dev/null +++ b/drivers/misc/qfw_smbios.c @@ -0,0 +1,197 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2023 Heinrich Schuchardt heinrich.schuchardt@canonical.com + */ + +#define LOG_CATEGORY UCLASS_QFW + +#include <efi_loader.h> +#include <errno.h> +#include <log.h> +#include <malloc.h> +#include <mapmem.h> +#include <qfw.h> +#include <smbios.h> +#include <tables_csum.h> +#include <linux/sizes.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * qfw_load_smbios_table() - load a QEMU firmware file + * + * @dev: QEMU firmware device + * @size: parameter to return the size of the loaded table + * @name: name of the table to load + * Return: address of the loaded table, NULL on error + */ +static void *qfw_load_smbios_table(struct udevice *dev, uint32_t *size, + char *name) +{ + struct fw_file *file; + struct bios_linker_entry *table; + + file = qfw_find_file(dev, name); + if (!file) { + log_debug("Can't find %s\n", name); + return NULL; + } + + *size = be32_to_cpu(file->cfg.size); + + table = malloc(*size); + if (!table) { + log_err("Out of memory\n"); + return NULL; + } + + qfw_read_entry(dev, be16_to_cpu(file->cfg.select), *size, table); + + return table; +} + +/** + * qfw_parse_smbios_anchor() - parse QEMU's SMBIOS anchor + * + * @dev: QEMU firmware device + * @entry: SMBIOS 3 structure to be filled from QEMU's anchor + * Return: 0 for success, -ve on error + */ +static int qfw_parse_smbios_anchor(struct udevice *dev, + struct smbios3_entry *entry) +{ + void *table; + uint32_t size; + struct smbios_entry *entry2; + struct smbios3_entry *entry3; + const char smbios_sig[] = "_SM_"; + const char smbios3_sig[] = "_SM3_"; + int ret = 0; + + table = qfw_load_smbios_table(dev, &size, "etc/smbios/smbios-anchor"); + if (!table) + return -ENOMEM; + if (!memcmp(table, smbios3_sig, sizeof(smbios3_sig) - 1)) { + entry3 = table; + if (entry3->length != sizeof(struct smbios3_entry)) { + ret = -ENOENT; + goto out; + } + memcpy(entry, entry3, sizeof(struct smbios3_entry)); + } else if (!memcmp(table, smbios_sig, sizeof(smbios_sig) - 1)) { + entry2 = table; + if (entry2->length != sizeof(struct smbios_entry)) { + ret = -ENOENT; + goto out; + } + memset(entry, 0, sizeof(struct smbios3_entry)); + memcpy(entry, smbios3_sig, sizeof(smbios3_sig)); + entry->length = sizeof(struct smbios3_entry); + entry->major_ver = entry2->major_ver; + entry->minor_ver = entry2->minor_ver; + entry->max_struct_size = entry2->max_struct_size; + } else { + ret = -ENOENT; + goto out; + } + ret = 0; +out: + free(table); + + return ret; +} + +/** + * qfw_write_smbios_tables() - copy SMBIOS tables from QEMU + * + * @addr: target buffer + * @size: size of target buffer + * Return: 0 for success, -ve on error + */ +static int qfw_write_smbios_tables(u8 *addr, uint32_t size) +{ + int ret; + struct udevice *dev; + struct smbios3_entry *entry = (void *)addr; + void *table; + uint32_t table_size; + + ret = qfw_get_dev(&dev); + if (ret) { + log_err("No QEMU firmware device\n"); + return ret; + } + + ret = qfw_read_firmware_list(dev); + if (ret) { + log_err("Can't read firmware file list\n"); + return ret; + } + + ret = qfw_parse_smbios_anchor(dev, entry); + if (ret) { + log_debug("Can't parse anchor\n"); + return ret; + } + + addr += entry->length; + entry->struct_table_address = (uintptr_t)addr; + entry->checksum = 0; + entry->checksum = table_compute_checksum(entry, + sizeof(struct smbios3_entry)); + + table = qfw_load_smbios_table(dev, &table_size, + "etc/smbios/smbios-tables"); + if (table_size + sizeof(struct smbios3_entry) > size) { + free(table); + return -ENOMEM; + } + memcpy(addr, table, table_size); + free(table); + + return 0; +} + +/** + * qfw_evt_write_smbios_tables() - event handler for copying QEMU SMBIOS tables + * + * Return: 0 on success, -ve on error (only out of memory) + */ +static int qfw_evt_write_smbios_tables(void) +{ + phys_addr_t addr; + void *ptr; + int ret; + /* + * TODO: + * This size is currently hard coded in lib/efi_loader/efi_smbios.c. + * We need a field in global data for the size. + */ + uint32_t size = SZ_4K; + + /* Reserve 64K for SMBIOS tables, aligned to a 4K boundary */ + ptr = memalign(SZ_4K, size); + if (!ptr) { + log_err("Out of memory\n"); + return -ENOMEM; + } + addr = map_to_sysmem(ptr); + + /* Generate SMBIOS tables */ + ret = qfw_write_smbios_tables(ptr, size); + if (ret) { + if (CONFIG_IS_ENABLED(GENERATE_SMBIOS_TABLE)) { + log_info("Falling back to U-Boot generated SMBIOS tables\n"); + write_smbios_table(addr); + } + } else { + log_debug("SMBIOS tables copied from QEMU\n"); + } + + gd_set_smbios_start(addr); + + return 0; +} + +EVENT_SPY_SIMPLE(EVT_LAST_STAGE_INIT, qfw_evt_write_smbios_tables); diff --git a/lib/efi_loader/efi_smbios.c b/lib/efi_loader/efi_smbios.c index bbb8421ce1..c4837da969 100644 --- a/lib/efi_loader/efi_smbios.c +++ b/lib/efi_loader/efi_smbios.c @@ -51,7 +51,9 @@ static int install_smbios_table(void) u64 addr; efi_status_t ret;
- if (!IS_ENABLED(CONFIG_GENERATE_SMBIOS_TABLE) || IS_ENABLED(CONFIG_X86)) + if (!IS_ENABLED(CONFIG_GENERATE_SMBIOS_TABLE) || + IS_ENABLED(CONFIG_X86) || + IS_ENABLED(CONFIG_QFW_SMBIOS)) return 0;
addr = SZ_4G; -- 2.43.0
Hi Heinrich,
+config QFW_SMBIOS
bool
default y
help
- (C) Copyright 2023 Heinrich Schuchardt heinrich.schuchardt@canonical.com
- qfw_load_smbios_table() - load a QEMU firmware file
- @dev: QEMU firmware device
- @size: parameter to return the size of the loaded table
- @name: name of the table to load
- Return: address of the loaded table, NULL on error
char *name)
if (!file) {
return NULL;
if (!table) {
return NULL;
return table;
- qfw_parse_smbios_anchor() - parse QEMU's SMBIOS anchor
- @entry: SMBIOS 3 structure to be filled from QEMU's anchor
- Return: 0 for success, -ve on error
void *table;
uint32_t size;
int ret = 0;
if (!table)
return -ENOMEM;
entry3 = table;
ret = -ENOENT;
goto out;
entry2 = table;
ret = -ENOENT;
goto out;
} else {
ret = -ENOENT;
goto out;
ret = 0;
+out:
free(table);
return ret;
- qfw_write_smbios_tables() - copy SMBIOS tables from QEMU
- @addr: target buffer
- @size: size of target buffer
int ret;
map_sysmem() so you can use a sandbox test
void *table;
if (ret) {
return ret;
if (ret) {
return ret;
if (ret) {
return ret;
free(table);
return -ENOMEM;
free(table);
- qfw_evt_write_smbios_tables() - event handler for copying QEMU SMBIOS tables
- Return: 0 on success, -ve on error (only out of memory)
phys_addr_t addr;
void *ptr;
int ret;
* TODO:
Is that because it might be >4KB?
if (!ptr) {
return -ENOMEM;
if (ret) {
Should we do this? Perhaps better to produce an error? If not, please add a comment as to why.
} else {
Hmm it seems we need an new Kconfig for this condition?
return 0; addr = SZ_4G;
-- 2.43.0
Otherwise:
On 12/26/23 10:47, Simon Glass wrote:
Hi Heinrich,
+config QFW_SMBIOS
bool
default y
help
- config I2C_EEPROM bool "Enable driver for generic I2C-attached EEPROMs" depends on MISC
char *name)
if (!file) {
return NULL;
if (!table) {
return NULL;
return table;
void *table;
uint32_t size;
int ret = 0;
if (!table)
return -ENOMEM;
entry3 = table;
ret = -ENOENT;
goto out;
entry2 = table;
ret = -ENOENT;
goto out;
} else {
ret = -ENOENT;
goto out;
ret = 0;
+out:
free(table);
return ret;
int ret;
This is a static function which never can be called directly by a test. The caller already has a map_sysmem(). See below.
void *table;
if (ret) {
return ret;
if (ret) {
return ret;
if (ret) {
return ret;
free(table);
return -ENOMEM;
free(table);
phys_addr_t addr;
void *ptr;
int ret;
* TODO:
if (!ptr) {
return -ENOMEM;
if (ret) {
Error messages are written.
If QEMU provides SMBIOS tables depends on the QEMU version. E.g for RISC-V patches enabling SMBIOS table generation are still pending.
Stopping the boot process because SMBIOS tables are not supplied by QEMU is not very helpful for users stuck on an old QEMU version. We should always do our best to complete the boot process.
} else {
I think we have too many symbols with unclear meaning.
Should we really use CONFIG_GENERATE_SMBIOS_TABLE=y in conjunction with CONFIG_QFW_SMBIOS=y? Or should we have a Kconfig choice where we have mutually exclusive sources for SMBIOS:
CONFIG SMBIOS_NONE - no SMBIOS table CONFIG_QFW_SMBIOS - copy SMBIOS table from QEMU CONFIG_SMBIOS_FROM DT - generate SMBIOS table from device-tree CONFIG_SMBIOS_COREBOOT - copy SMBIOS table from coreboot CONFIG SMBIOS_X86 - x86 specific code
There is nothing EFI specific in this function. Shouldn't we move it to a different module?
For ACPI we have a folder lib/acpi/ Should we have a folder lib/smbios/?
Best regards
Heinrich
-- 2.43.0
Otherwise:
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Simon Glass sjg@chromium.org
Ilias Apalodimas
