[PATCH 1/1] doc: document sbi command
Add a man-page for the sbi command.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- MAINTAINERS | 1 + doc/usage/index.rst | 1 + doc/usage/sbi.rst | 49 +++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 51 insertions(+) create mode 100644 doc/usage/sbi.rst
diff --git a/MAINTAINERS b/MAINTAINERS index a7a62dff81..e7a6dd9ce2 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -951,6 +951,7 @@ S: Maintained T: git https://gitlab.denx.de/u-boot/custodians/u-boot-riscv.git F: arch/riscv/ F: cmd/riscv/ +F: doc/usage/sbi.rst F: drivers/timer/andes_plmt_timer.c F: drivers/timer/sifive_clint_timer.c F: tools/prelink-riscv.c diff --git a/doc/usage/index.rst b/doc/usage/index.rst index 6def250766..eedcdb110b 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -19,3 +19,4 @@ Shell commands button mbr pstore + sbi diff --git a/doc/usage/sbi.rst b/doc/usage/sbi.rst new file mode 100644 index 0000000000..66bf4f634d --- /dev/null +++ b/doc/usage/sbi.rst @@ -0,0 +1,49 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +sbi command +=========== + +Synopsis +-------- + +:: + + sbi + +Description +----------- + +The sbi command is used to display information about the SBI (Supervisor Binary +Interface) implementation on RISC-V systems. + +The output may look like: + +:: + + => sbi + SBI 0.2 + OpenSBI + Extensions: + sbi_set_timer + sbi_console_putchar + sbi_console_getchar + sbi_clear_ipi + sbi_send_ipi + sbi_remote_fence_i + sbi_remote_sfence_vma + sbi_remote_sfence_vma_asid + sbi_shutdown + SBI Base Functionality + Timer Extension + IPI Extension + RFENCE Extension + Hart State Management Extension + +The first line indicates the version of the RISC-V SBI specification. +The second line indicates the implementation. +The further lines enumerate the implemented extensions. + +Configuration +------------- + +To use the sbi command you must specify CONFIG_CMD_SBI=y. -- 2.29.2
