[PATCH v2] travis: Correct error checking when building boards
At present if buildman reports an error, the travis build still succeeds.
This is because the travis script does not stop when it sees errors; nor does it automatically return the exit code. Also the current error checking never triggers since 'ret' is not set.
Fix this by setting 'ret' correctly.
Signed-off-by: Simon Glass sjg@chromium.org Reported-by: Michal Simek michal.simek@xilinx.com ---
Changes in v2: - Fix missing ret=0
.travis.yml | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/.travis.yml b/.travis.yml index b3253da13c..1dbc63cadf 100644 --- a/.travis.yml +++ b/.travis.yml @@ -208,7 +208,8 @@ script: # # Build a selection of boards if TEST_PY_BD is empty - if [[ "${BUILDMAN}" != "" ]]; then - tools/buildman/buildman -P -E -W ${BUILDMAN} ${OVERRIDE}; + ret=0 + tools/buildman/buildman -P -E -W ${BUILDMAN} ${OVERRIDE} || ret=$?; if [[ $ret -ne 0 ]]; then tools/buildman/buildman -seP ${BUILDMAN}; exit $ret;
Changes in v2:
- Fix missing ret=0
ret=0
Acked-by: Michal Simek michal.simek@xilinx.com
Thanks, Michal
Signed-off-by: Simon Glass sjg@chromium.org Reported-by: Michal Simek michal.simek@xilinx.com Acked-by: Michal Simek michal.simek@xilinx.com
Michal Simek
