[V3] gpio: mpc8xxx: support fsl-layerscape platform
Make the MPC8XXX gpio driver to support the fsl-layerscape.
Signed-off-by: hui.song hui.song_1@nxp.com --- drivers/gpio/mpc8xxx_gpio.c | 108 +++++++++++++++++++++++++++++------- 1 file changed, 87 insertions(+), 21 deletions(-)
diff --git a/drivers/gpio/mpc8xxx_gpio.c b/drivers/gpio/mpc8xxx_gpio.c index 1dfd22522c..27881a7322 100644 --- a/drivers/gpio/mpc8xxx_gpio.c +++ b/drivers/gpio/mpc8xxx_gpio.c @@ -6,12 +6,15 @@ * based on arch/powerpc/include/asm/mpc85xx_gpio.h, which is * * Copyright 2010 eXMeritus, A Boeing Company + * Copyright 2020 NXP */
#include <common.h> #include <dm.h> #include <mapmem.h> #include <asm/gpio.h> +#include <asm/io.h> +#include <dm/of_access.h>
struct ccsr_gpio { u32 gpdir; @@ -20,6 +23,7 @@ struct ccsr_gpio { u32 gpier; u32 gpimr; u32 gpicr; + u32 gpibe; };
struct mpc8xxx_gpio_data { @@ -35,6 +39,7 @@ struct mpc8xxx_gpio_data { */ u32 dat_shadow; ulong type; + bool little_endian; };
enum { @@ -47,33 +52,56 @@ inline u32 gpio_mask(uint gpio) return (1U << (31 - (gpio))); }
-static inline u32 mpc8xxx_gpio_get_val(struct ccsr_gpio *base, u32 mask) +static inline u32 mpc8xxx_gpio_get_val(struct udevice *dev, u32 mask) { - return in_be32(&base->gpdat) & mask; + struct mpc8xxx_gpio_data *data = dev_get_priv(dev); + + if (data->little_endian) + return in_le32(&data->base->gpdat) & mask; + else + return in_be32(&data->base->gpdat) & mask; }
-static inline u32 mpc8xxx_gpio_get_dir(struct ccsr_gpio *base, u32 mask) +static inline u32 mpc8xxx_gpio_get_dir(struct udevice *dev, u32 mask) { - return in_be32(&base->gpdir) & mask; + struct mpc8xxx_gpio_data *data = dev_get_priv(dev); + + if (data->little_endian) + return in_le32(&data->base->gpdir) & mask; + else + return in_be32(&data->base->gpdir) & mask; }
-static inline int mpc8xxx_gpio_open_drain_val(struct ccsr_gpio *base, u32 mask) +static inline int mpc8xxx_gpio_open_drain_val(struct udevice *dev, u32 mask) { - return in_be32(&base->gpodr) & mask; + struct mpc8xxx_gpio_data *data = dev_get_priv(dev); + + if (data->little_endian) + return in_le32(&data->base->gpodr) & mask; + else + return in_be32(&data->base->gpodr) & mask; }
-static inline void mpc8xxx_gpio_open_drain_on(struct ccsr_gpio *base, u32 +static inline void mpc8xxx_gpio_open_drain_on(struct udevice *dev, u32 gpios) { + struct mpc8xxx_gpio_data *data = dev_get_priv(dev); /* GPODR register 1 -> open drain on */ - setbits_be32(&base->gpodr, gpios); + if (data->little_endian) + setbits_le32(&data->base->gpodr, gpios); + else + setbits_be32(&data->base->gpodr, gpios); }
-static inline void mpc8xxx_gpio_open_drain_off(struct ccsr_gpio *base, +static inline void mpc8xxx_gpio_open_drain_off(struct udevice *dev, u32 gpios) { + struct mpc8xxx_gpio_data *data = dev_get_priv(dev); /* GPODR register 0 -> open drain off (actively driven) */ - clrbits_be32(&base->gpodr, gpios); + if (data->little_endian) + clrbits_le32(&data->base->gpodr, gpios); + else + clrbits_be32(&data->base->gpodr, gpios); }
static int mpc8xxx_gpio_direction_input(struct udevice *dev, uint gpio) @@ -82,7 +110,10 @@ static int mpc8xxx_gpio_direction_input(struct udevice *dev, uint gpio) u32 mask = gpio_mask(gpio);
/* GPDIR register 0 -> input */ - clrbits_be32(&data->base->gpdir, mask); + if (data->little_endian) + clrbits_le32(&data->base->gpdir, mask); + else + clrbits_be32(&data->base->gpdir, mask);
return 0; } @@ -100,10 +131,20 @@ static int mpc8xxx_gpio_set_value(struct udevice *dev, uint gpio, int value) data->dat_shadow &= ~mask; }
- gpdir = in_be32(&base->gpdir); + if (data->little_endian) + gpdir = in_le32(&base->gpdir); + else + gpdir = in_be32(&base->gpdir); + gpdir |= gpio_mask(gpio); - out_be32(&base->gpdat, gpdir & data->dat_shadow); - out_be32(&base->gpdir, gpdir); + + if (data->little_endian) { + out_le32(&base->gpdat, gpdir & data->dat_shadow); + out_le32(&base->gpdir, gpdir); + } else { + out_be32(&base->gpdat, gpdir & data->dat_shadow); + out_be32(&base->gpdir, gpdir); + }
return 0; } @@ -124,21 +165,20 @@ static int mpc8xxx_gpio_get_value(struct udevice *dev, uint gpio) { struct mpc8xxx_gpio_data *data = dev_get_priv(dev);
- if (!!mpc8xxx_gpio_get_dir(data->base, gpio_mask(gpio))) { + if (!!mpc8xxx_gpio_get_dir(dev, gpio_mask(gpio))) { /* Output -> use shadowed value */ return !!(data->dat_shadow & gpio_mask(gpio)); }
/* Input -> read value from GPDAT register */ - return !!mpc8xxx_gpio_get_val(data->base, gpio_mask(gpio)); + return !!mpc8xxx_gpio_get_val(dev, gpio_mask(gpio)); }
static int mpc8xxx_gpio_get_function(struct udevice *dev, uint gpio) { - struct mpc8xxx_gpio_data *data = dev_get_priv(dev); int dir;
- dir = !!mpc8xxx_gpio_get_dir(data->base, gpio_mask(gpio)); + dir = !!mpc8xxx_gpio_get_dir(dev, gpio_mask(gpio)); return dir ? GPIOF_OUTPUT : GPIOF_INPUT; }
@@ -146,14 +186,33 @@ static int mpc8xxx_gpio_get_function(struct udevice *dev, uint gpio) static int mpc8xxx_gpio_ofdata_to_platdata(struct udevice *dev) { struct mpc8xxx_gpio_plat *plat = dev_get_platdata(dev); + struct mpc8xxx_gpio_data *data = dev_get_priv(dev); fdt_addr_t addr; - u32 reg[2]; + u32 i; + u32 reg[4]; + + if (ofnode_read_bool(dev->node, "little-endian")) + data->little_endian = true; + + if (data->little_endian) + dev_read_u32_array(dev, "reg", reg, 4); + else + dev_read_u32_array(dev, "reg", reg, 2); + + if (data->little_endian) { + for (i = 0; i < 2; i++) + reg[i] = be32_to_cpu(reg[i]); + }
- dev_read_u32_array(dev, "reg", reg, 2); addr = dev_translate_address(dev, reg);
plat->addr = addr; - plat->size = reg[1]; + + if (data->little_endian) + plat->size = reg[3]; + else + plat->size = reg[1]; + plat->ngpios = dev_read_u32_default(dev, "ngpios", 32);
return 0; @@ -198,6 +257,13 @@ static int mpc8xxx_gpio_probe(struct udevice *dev) if (!str) return -ENOMEM;
+ if (ofnode_device_is_compatible(dev->node, "fsl,qoriq-gpio")) { + unsigned long gpibe = data->addr + sizeof(struct ccsr_gpio) + - sizeof(u32); + + out_be32((unsigned int *)gpibe, 0xffffffff); + } + uc_priv->bank_name = str; uc_priv->gpio_count = data->gpio_count;
Hui Song
