[U-Boot] [PATCH 0/2] drivers: timer: inroduce ARC timer driver
This patch series replaces legacy approach to access ARC timer via specific code in "arch/arc/lib/time.c" and uses timer driver instead.
ARC cores may have up to 2 built-in timers: timer0 and timer1, usually at least one of them exists.
They are controlled through auxiliary registers and so we don't have to remap their control registers as we used to do with MMIO registers of external peripheral devices.
Vlad Zakharov (2): drivers: timer: Introduce ARC timer driver arc: use timer driver instead of arch/arc/lib/timer.c
arch/arc/dts/skeleton.dtsi | 6 ++ arch/arc/include/asm/arcregs.h | 4 ++ arch/arc/lib/Makefile | 1 - arch/arc/lib/timer.c | 24 ------- configs/axs101_defconfig | 2 + configs/axs103_defconfig | 2 + configs/nsim_700_defconfig | 2 + configs/nsim_700be_defconfig | 2 + configs/nsim_hs38_defconfig | 2 + configs/nsim_hs38be_defconfig | 2 + configs/tb100_defconfig | 2 + doc/device-tree-bindings/timer/arc_timer.txt | 24 +++++++ drivers/timer/Kconfig | 7 ++ drivers/timer/Makefile | 1 + drivers/timer/arc_timer.c | 95 ++++++++++++++++++++++++++++ include/configs/axs10x.h | 2 - 16 files changed, 151 insertions(+), 27 deletions(-) delete mode 100644 arch/arc/lib/timer.c create mode 100644 doc/device-tree-bindings/timer/arc_timer.txt create mode 100644 drivers/timer/arc_timer.c
This commit introduces timer driver for ARC.
ARC timers are configured via ARC AUX registers so we use special functions to access timer control registers.
This driver allows utilization of either timer0 or timer1 depending on which one is available in real hardware. Essentially only existing timers should be mentioned in board's Device Tree description.
Signed-off-by: Vlad Zakharov vzakhar@synopsys.com --- arch/arc/include/asm/arcregs.h | 4 ++ doc/device-tree-bindings/timer/arc_timer.txt | 24 +++++++ drivers/timer/Kconfig | 7 ++ drivers/timer/Makefile | 1 + drivers/timer/arc_timer.c | 97 ++++++++++++++++++++++++++++ 5 files changed, 133 insertions(+) create mode 100644 doc/device-tree-bindings/timer/arc_timer.txt create mode 100644 drivers/timer/arc_timer.c
diff --git a/arch/arc/include/asm/arcregs.h b/arch/arc/include/asm/arcregs.h index cf999b0..54a9b00 100644 --- a/arch/arc/include/asm/arcregs.h +++ b/arch/arc/include/asm/arcregs.h @@ -33,6 +33,10 @@ #define ARC_AUX_TIMER0_CTRL 0x22 /* Timer 0 control */ #define ARC_AUX_TIMER0_LIMIT 0x23 /* Timer 0 limit */
+#define ARC_AUX_TIMER1_CNT 0x100 /* Timer 1 count */ +#define ARC_AUX_TIMER1_CTRL 0x101 /* Timer 1 control */ +#define ARC_AUX_TIMER1_LIMIT 0x102 /* Timer 1 limit */ + #define ARC_AUX_INTR_VEC_BASE 0x25
/* Data cache related auxiliary registers */ diff --git a/doc/device-tree-bindings/timer/arc_timer.txt b/doc/device-tree-bindings/timer/arc_timer.txt new file mode 100644 index 0000000..e25c6ae --- /dev/null +++ b/doc/device-tree-bindings/timer/arc_timer.txt @@ -0,0 +1,24 @@ +ARC Timer + +Required properties: + +- compatible : should be "snps,arc-timer" +- reg : Specifies timer ID, could be either 0 or 1. +- clock-frequency : The frequency of the clock that drives the counter, in Hz. + +Examples: + +timer@0 { + compatible = "snps,arc-timer"; + clock-frequency = <100000000>; + reg = <0>; +}; + +timer@1 { + compatible = "snps,arc-timer"; + clock-frequency = <100000000>; + reg = <1>; +}; + +NOTE: if you specify both timers, frequencies should always be the same as both timers +are driven by core clock. diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index cb18f12..721007d 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -46,4 +46,11 @@ config OMAP_TIMER help Select this to enable an timer for Omap devices.
+config ARC_TIMER + bool "ARC timer support" + depends on TIMER + depends on ARC + help + Select this to enable built-in ARC timers. + endmenu diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index f351fbb..e9624dd 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -9,3 +9,4 @@ obj-$(CONFIG_ALTERA_TIMER) += altera_timer.o obj-$(CONFIG_SANDBOX_TIMER) += sandbox_timer.o obj-$(CONFIG_X86_TSC_TIMER) += tsc_timer.o obj-$(CONFIG_OMAP_TIMER) += omap-timer.o +obj-$(CONFIG_ARC_TIMER) += arc_timer.o diff --git a/drivers/timer/arc_timer.c b/drivers/timer/arc_timer.c new file mode 100644 index 0000000..727f2df --- /dev/null +++ b/drivers/timer/arc_timer.c @@ -0,0 +1,97 @@ +/* + * Copyright (C) 2016 Synopsys, Inc. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <timer.h> +#include <asm/io.h> +#include <asm/arcregs.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * ARC timer control registers are mapped to auxiliary address space. + * There are special ARC asm command to access that addresses. + * Therefore we use built-in functions to read from and write to timer + * control register. + */ + +/* Driver private data. Contains AUX register number. */ +struct arc_timer_priv { + uint32_t timer_id; +}; + +static int arc_timer_get_count(struct udevice *dev, u64 *count) +{ + struct arc_timer_priv *priv = dev_get_priv(dev); + switch (priv->timer_id) { + case 0: + *count = read_aux_reg(ARC_AUX_TIMER0_CNT); + break; + case 1: + *count = read_aux_reg(ARC_AUX_TIMER1_CNT); + break; + } + return 0; +} + +static int arc_timer_probe(struct udevice *dev) +{ + int id; + + struct arc_timer_priv *priv = dev_get_priv(dev); + + /* Get registers offset and size */ + id = fdtdec_get_int(gd->fdt_blob, dev->of_offset, "reg", -1); + if (id < 0) + return -EINVAL; + if (id > 1) + return -ENXIO; + + priv->timer_id = (uint32_t)id; + +#define NH_MODE (1 << 1) + + switch (priv->timer_id) { + case 0: + /* Disable timer if CPU is halted */ + write_aux_reg(ARC_AUX_TIMER0_CTRL, NH_MODE); + /* Set max value for counter/timer */ + write_aux_reg(ARC_AUX_TIMER0_LIMIT, 0xffffffff); + /* Set initial count value and restart counter/timer */ + write_aux_reg(ARC_AUX_TIMER0_CNT, 0); + break; + case 1: + /* Disable timer if CPU is halted */ + write_aux_reg(ARC_AUX_TIMER1_CTRL, NH_MODE); + /* Set max value for counter/timer */ + write_aux_reg(ARC_AUX_TIMER1_LIMIT, 0xffffffff); + /* Set initial count value and restart counter/timer */ + write_aux_reg(ARC_AUX_TIMER1_CNT, 0); + break; + } + return 0; +} + + +static const struct timer_ops arc_timer_ops = { + .get_count = arc_timer_get_count, +}; + +static const struct udevice_id arc_timer_ids[] = { + { .compatible = "snps,arc-timer" }, + {} +}; + +U_BOOT_DRIVER(arc_timer) = { + .name = "arc_timer", + .id = UCLASS_TIMER, + .of_match = arc_timer_ids, + .probe = arc_timer_probe, + .ops = &arc_timer_ops, + .flags = DM_FLAG_PRE_RELOC, +};
Hi Vlad,
On 2 November 2016 at 09:44, Vlad Zakharov Vladislav.Zakharov@synopsys.com wrote:
Looks good. Nits below.
You might consider adding a #define to a file in include/dt-bindings/timer or similar for the 0 and 1. Then you can use it in the source code. Up to you though.
+Examples:
+timer@0 {
reg = <0>;
+timer@1 {
reg = <1>;
+config ARC_TIMER
depends on TIMER
depends on ARC
help
Good to include a bit more info like the capabilities of the timers
- Copyright (C) 2016 Synopsys, Inc. All rights reserved.
- ARC timer control registers are mapped to auxiliary address space.
- There are special ARC asm command to access that addresses.
- Therefore we use built-in functions to read from and write to timer
- control register.
uint32_t timer_id;
uint would do. It doesn't need to be 32 bits.
blank line here
case 0:
Here is where you could use the defines.
break;
case 1:
break;
blank line before 'return'
int id;
if (id < 0)
return -EINVAL;
if (id > 1)
Could use the define here
return -ENXIO;
This should really go to the top of the file.
case 0:
break;
case 1:
break;
.id = UCLASS_TIMER,
2.7.4
This commit replaces legacy timer code with usage of arc timer driver.
Also it adds timer0 device tree node with corresponding "clock-frequency" property.
Therefore we remove legacy CONFIG_SYS_TIMER_RATE config symbol that is not longer required.
Furthermore the commit adds CONFIG_TIMER and CONFIG_ARC_TIMER config symbols to arc-specific defconfigs.
Signed-off-by: Vlad Zakharov vzakhar@synopsys.com --- arch/arc/dts/skeleton.dtsi | 6 ++++++ arch/arc/lib/Makefile | 1 - arch/arc/lib/timer.c | 24 ------------------------ configs/axs101_defconfig | 2 ++ configs/axs103_defconfig | 2 ++ configs/nsim_700_defconfig | 2 ++ configs/nsim_700be_defconfig | 2 ++ configs/nsim_hs38_defconfig | 2 ++ configs/nsim_hs38be_defconfig | 2 ++ configs/tb100_defconfig | 2 ++ include/configs/axs10x.h | 2 -- 11 files changed, 20 insertions(+), 27 deletions(-) delete mode 100644 arch/arc/lib/timer.c
diff --git a/arch/arc/dts/skeleton.dtsi b/arch/arc/dts/skeleton.dtsi index b41d241..3e93d697 100644 --- a/arch/arc/dts/skeleton.dtsi +++ b/arch/arc/dts/skeleton.dtsi @@ -10,4 +10,10 @@ chosen { }; aliases { }; memory { device_type = "memory"; reg = <0 0>; }; + + timer@0 { + compatible = "snps,arc-timer"; + clock-frequency = <100000000>; + reg = <0>; + }; }; diff --git a/arch/arc/lib/Makefile b/arch/arc/lib/Makefile index eb62b3c..12097bf 100644 --- a/arch/arc/lib/Makefile +++ b/arch/arc/lib/Makefile @@ -18,7 +18,6 @@ obj-y += memcmp.o obj-y += memcpy-700.o obj-y += memset.o obj-y += reset.o -obj-y += timer.o obj-y += ints_low.o obj-y += init_helpers.o
diff --git a/arch/arc/lib/timer.c b/arch/arc/lib/timer.c deleted file mode 100644 index a0acbbc..0000000 --- a/arch/arc/lib/timer.c +++ /dev/null @@ -1,24 +0,0 @@ -/* - * Copyright (C) 2013-2014 Synopsys, Inc. All rights reserved. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <asm/arcregs.h> - -#define NH_MODE (1 << 1) /* Disable timer if CPU is halted */ - -int timer_init(void) -{ - write_aux_reg(ARC_AUX_TIMER0_CTRL, NH_MODE); - /* Set max value for counter/timer */ - write_aux_reg(ARC_AUX_TIMER0_LIMIT, 0xffffffff); - /* Set initial count value and restart counter/timer */ - write_aux_reg(ARC_AUX_TIMER0_CNT, 0); - return 0; -} - -unsigned long timer_read_counter(void) -{ - return read_aux_reg(ARC_AUX_TIMER0_CNT); -} diff --git a/configs/axs101_defconfig b/configs/axs101_defconfig index b8d8baf..2efe4c2 100644 --- a/configs/axs101_defconfig +++ b/configs/axs101_defconfig @@ -23,6 +23,8 @@ CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y +CONFIG_TIMER=y +CONFIG_ARC_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/axs103_defconfig b/configs/axs103_defconfig index 5e44633..0e4e2f1 100644 --- a/configs/axs103_defconfig +++ b/configs/axs103_defconfig @@ -23,6 +23,8 @@ CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y +CONFIG_TIMER=y +CONFIG_ARC_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/nsim_700_defconfig b/configs/nsim_700_defconfig index dab9bdf..00a9166 100644 --- a/configs/nsim_700_defconfig +++ b/configs/nsim_700_defconfig @@ -12,4 +12,6 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DM=y CONFIG_DM_SERIAL=y +CONFIG_TIMER=y +CONFIG_ARC_TIMER=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/nsim_700be_defconfig b/configs/nsim_700be_defconfig index 6f0e348..c23a202 100644 --- a/configs/nsim_700be_defconfig +++ b/configs/nsim_700be_defconfig @@ -13,4 +13,6 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DM=y CONFIG_DM_SERIAL=y +CONFIG_TIMER=y +CONFIG_ARC_TIMER=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/nsim_hs38_defconfig b/configs/nsim_hs38_defconfig index e35fe23..619fdf9 100644 --- a/configs/nsim_hs38_defconfig +++ b/configs/nsim_hs38_defconfig @@ -13,4 +13,6 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DM=y CONFIG_DM_SERIAL=y +CONFIG_TIMER=y +CONFIG_ARC_TIMER=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/nsim_hs38be_defconfig b/configs/nsim_hs38be_defconfig index e0001b6..cd82eba 100644 --- a/configs/nsim_hs38be_defconfig +++ b/configs/nsim_hs38be_defconfig @@ -14,4 +14,6 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DM=y CONFIG_DM_SERIAL=y +CONFIG_TIMER=y +CONFIG_ARC_TIMER=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/tb100_defconfig b/configs/tb100_defconfig index 6dc2242..830cc8c 100644 --- a/configs/tb100_defconfig +++ b/configs/tb100_defconfig @@ -17,4 +17,6 @@ CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y +CONFIG_TIMER=y +CONFIG_ARC_TIMER=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/include/configs/axs10x.h b/include/configs/axs10x.h index 3546c8d..0476223 100644 --- a/include/configs/axs10x.h +++ b/include/configs/axs10x.h @@ -11,8 +11,6 @@ /* * CPU configuration */ -#define CONFIG_SYS_TIMER_RATE CONFIG_SYS_CLK_FREQ - #define ARC_FPGA_PERIPHERAL_BASE 0xE0000000 #define ARC_APB_PERIPHERAL_BASE 0xF0000000 #define ARC_DWMMC_BASE (ARC_FPGA_PERIPHERAL_BASE + 0x15000)
Hi Vlad,
You might be able to add these to your arc Kconfig instead of adding it to each board:
select CONFIG_TIMER select CONFIG_ARC_TIMER
Vlad Zakharov
