[U-Boot] [PATCH v1 1/1] spi: fsl_dspi fix to stop extra transmissions
Update to prevent a byte of zeros being transmitted between each byte in the tx buffer when providing both a tx buffer and a rx buffer.
Signed-off-by: Jared Bents jared.bents@rockwellcollins.com Cc: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- drivers/spi/fsl_dspi.c | 30 ++++++++++++++++++++++++++---- 1 file changed, 26 insertions(+), 4 deletions(-)
diff --git a/drivers/spi/fsl_dspi.c b/drivers/spi/fsl_dspi.c index 764c94215e..a68a51945e 100644 --- a/drivers/spi/fsl_dspi.c +++ b/drivers/spi/fsl_dspi.c @@ -273,7 +273,18 @@ static int dspi_xfer(struct fsl_dspi_priv *priv, uint cs, unsigned int bitlen, if (len > 1) { int tmp_len = len - 1; while (tmp_len--) { - if (dout != NULL) { + if ((dout != NULL) && (din != NULL)) { + if (priv->charbit == 16) { + dspi_tx(priv, ctrl, *spi_wr16++); + *spi_rd16++ = dspi_rx(priv); + } + else { + dspi_tx(priv, ctrl, *spi_wr++); + *spi_rd++ = dspi_rx(priv); + } + } + + else if (dout != NULL) { if (priv->charbit == 16) dspi_tx(priv, ctrl, *spi_wr16++); else @@ -281,7 +292,7 @@ static int dspi_xfer(struct fsl_dspi_priv *priv, uint cs, unsigned int bitlen, dspi_rx(priv); }
- if (din != NULL) { + else if (din != NULL) { dspi_tx(priv, ctrl, DSPI_IDLE_VAL); if (priv->charbit == 16) *spi_rd16++ = dspi_rx(priv); @@ -297,7 +308,18 @@ static int dspi_xfer(struct fsl_dspi_priv *priv, uint cs, unsigned int bitlen, ctrl &= ~DSPI_TFR_CONT;
if (len) { - if (dout != NULL) { + if ((dout != NULL) && (din != NULL)) { + if (priv->charbit == 16) { + dspi_tx(priv, ctrl, *spi_wr16++); + *spi_rd16++ = dspi_rx(priv); + } + else { + dspi_tx(priv, ctrl, *spi_wr++); + *spi_rd++ = dspi_rx(priv); + } + } + + else if (dout != NULL) { if (priv->charbit == 16) dspi_tx(priv, ctrl, *spi_wr16); else @@ -305,7 +327,7 @@ static int dspi_xfer(struct fsl_dspi_priv *priv, uint cs, unsigned int bitlen, dspi_rx(priv); }
- if (din != NULL) { + else if (din != NULL) { dspi_tx(priv, ctrl, DSPI_IDLE_VAL); if (priv->charbit == 16) *spi_rd16 = dspi_rx(priv);
Acked-by: Jagan Teki jagan@amarulasolutions.com
On Fri, Apr 12, 2019 at 11:23 AM Jagan Teki jagan@amarulasolutions.com wrote:
Applied to u-boot-spi/master
Jagan Teki
