[v2] armv8: fsl-layerscape: Kconfig: Correct I2C dependecies
Don't select SYS_I2C_MXC_I2C* when DM_I2C is enabled. This is required to resolve below warnings while 'make *defconfig'
ARCH_LS1046A [=y] && ARM [=y] WARNING: unmet direct dependencies detected for SYS_I2C_MXC_I2C3 Depends on [n]: SYS_I2C_MXC [=y] && (!DM_I2C [=y] || SPL [=n]) Selected by [y]:
Signed-off-by: Biwen Li biwen.li@nxp.com --- Change in v2: - update subject and descriptions
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 20 ++++++++++---------- 1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index f1578b10bc..84ece4d587 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -16,8 +16,8 @@ config ARCH_LS1012A select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F select SYS_I2C_MXC - select SYS_I2C_MXC_I2C1 - select SYS_I2C_MXC_I2C2 + select SYS_I2C_MXC_I2C1 if !DM_I2C + select SYS_I2C_MXC_I2C2 if !DM_I2C imply PANIC_HANG
config ARCH_LS1028A @@ -75,10 +75,10 @@ config ARCH_LS1043A select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F select SYS_I2C_MXC - select SYS_I2C_MXC_I2C1 - select SYS_I2C_MXC_I2C2 - select SYS_I2C_MXC_I2C3 - select SYS_I2C_MXC_I2C4 + select SYS_I2C_MXC_I2C1 if !DM_I2C + select SYS_I2C_MXC_I2C2 if !DM_I2C + select SYS_I2C_MXC_I2C3 if !DM_I2C + select SYS_I2C_MXC_I2C4 if !DM_I2C imply CMD_PCI
config ARCH_LS1046A @@ -108,10 +108,10 @@ config ARCH_LS1046A select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F select SYS_I2C_MXC - select SYS_I2C_MXC_I2C1 - select SYS_I2C_MXC_I2C2 - select SYS_I2C_MXC_I2C3 - select SYS_I2C_MXC_I2C4 + select SYS_I2C_MXC_I2C1 if !DM_I2C + select SYS_I2C_MXC_I2C2 if !DM_I2C + select SYS_I2C_MXC_I2C3 if !DM_I2C + select SYS_I2C_MXC_I2C4 if !DM_I2C imply SCSI imply SCSI_AHCI
Hi Biwen,
-----Original Message----- From: Biwen Li biwen.li@nxp.com Sent: Monday, December 23, 2019 12:09 PM To: Priyanka Jain priyanka.jain@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com Cc: u-boot@lists.denx.de; Jiafei Pan jiafei.pan@nxp.com; Biwen Li biwen.li@nxp.com Subject: [v2] armv8: fsl-layerscape: Kconfig: Correct I2C dependecies
Change in v2:
These changes are not required in upstream as this issue caused by http://patchwork.ozlabs.org/patch/1213011/ and it is not accepted yet. Merge these changes with http://patchwork.ozlabs.org/patch/1213011/.
- select SYS_I2C_MXC_I2C1 if !DM_I2C
- select SYS_I2C_MXC_I2C2 if !DM_I2C imply PANIC_HANG
Merge above changes in http://patchwork.ozlabs.org/patch/1213016/
- select SYS_I2C_MXC_I2C3 if !DM_I2C
- select SYS_I2C_MXC_I2C4 if !DM_I2C imply CMD_PCI
Merge above changes in http://patchwork.ozlabs.org/patch/1213017/
- select SYS_I2C_MXC_I2C4 if !DM_I2C imply SCSI imply SCSI_AHCI
Merge above changes in http://patchwork.ozlabs.org/patch/1213018/
--Jagdish
-----Original Message----- From: Jagdish Gediya jagdish.gediya@nxp.com Sent: 2019年12月23日 18:22 To: Biwen Li biwen.li@nxp.com; Priyanka Jain priyanka.jain@nxp.com Cc: u-boot@lists.denx.de; Jiafei Pan jiafei.pan@nxp.com; Biwen Li biwen.li@nxp.com Subject: RE: [v2] armv8: fsl-layerscape: Kconfig: Correct I2C dependecies
Hi Biwen,
Change in v2:
Ok, I will merge it in v6
Ok, I will merge it in v6.
--Jagdish
Biwen Li
Jagdish Gediya
