[U-Boot] [PATCH] common: Move dram_init() declaration to common location
Build tested for Microblaze and x86. Created based on my discussion with Simon. --- arch/arm/include/asm/u-boot-arm.h | 1 - arch/nds32/include/asm/u-boot-nds32.h | 1 - arch/sandbox/include/asm/u-boot-sandbox.h | 1 - arch/x86/include/asm/u-boot-x86.h | 6 ------ include/common.h | 1 + 5 files changed, 1 insertion(+), 9 deletions(-)
diff --git a/arch/arm/include/asm/u-boot-arm.h b/arch/arm/include/asm/u-boot-arm.h index f97f3dd1496a..414042d4039b 100644 --- a/arch/arm/include/asm/u-boot-arm.h +++ b/arch/arm/include/asm/u-boot-arm.h @@ -36,7 +36,6 @@ int arch_early_init_r(void);
/* board/.../... */ int board_init(void); -int dram_init (void); void dram_init_banksize (void);
/* cpu/.../interrupt.c */ diff --git a/arch/nds32/include/asm/u-boot-nds32.h b/arch/nds32/include/asm/u-boot-nds32.h index b07908692a92..dee5f43ae155 100644 --- a/arch/nds32/include/asm/u-boot-nds32.h +++ b/arch/nds32/include/asm/u-boot-nds32.h @@ -22,7 +22,6 @@ int cleanup_before_linux(void);
/* board/.../... */ int board_init(void); -int dram_init(void);
/* cpu/.../interrupt.c */ void reset_timer_masked(void); diff --git a/arch/sandbox/include/asm/u-boot-sandbox.h b/arch/sandbox/include/asm/u-boot-sandbox.h index d2f1b6566d70..770ab5c9cc07 100644 --- a/arch/sandbox/include/asm/u-boot-sandbox.h +++ b/arch/sandbox/include/asm/u-boot-sandbox.h @@ -17,7 +17,6 @@
/* start.c */ int sandbox_early_getopt_check(void); diff --git a/arch/x86/include/asm/u-boot-x86.h b/arch/x86/include/asm/u-boot-x86.h index b98afa801d3a..c24846b3ed50 100644 --- a/arch/x86/include/asm/u-boot-x86.h +++ b/arch/x86/include/asm/u-boot-x86.h @@ -26,15 +26,9 @@ unsigned long get_tbclk_mhz(void); void timer_set_base(uint64_t base); int pcat_timer_init(void);
-/* Architecture specific DRAM init */ -int dram_init(void); - /* cpu/.../interrupts.c */ int cpu_init_interrupts(void);
-/* board/.../... */ -int dram_init(void); - int cleanup_before_linux(void); int x86_cleanup_before_linux(void); void x86_enable_caches(void); diff --git a/include/common.h b/include/common.h index 4b3e0d3bbd75..81edc7d2788c 100644 --- a/include/common.h +++ b/include/common.h @@ -183,6 +183,7 @@ typedef void (interrupt_handler_t)(void *); /* * Function Prototypes */ +int dram_init(void);
void hang (void) __attribute__ ((noreturn));
-- 1.8.2.3
On Fri, Jan 30, 2015 at 10:58:44AM +0100, Michal Simek wrote:
Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Simon Glass sjg@chromium.org
Michal Simek
