[l4m-2022.04][u-boot-at91] spi: atmel-quadspi.c: Fix the buswidth adjustment between spi-mem and controller
Use the spi_mem_default_supports_op() core helper in order to take into account the buswidth specified by the user in device tree.
Fixes: 24c8ff4684 ("spi: Add Atmel QuadSPI driver") Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- drivers/spi/atmel-quadspi.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/spi/atmel-quadspi.c b/drivers/spi/atmel-quadspi.c index 098298336d..cb64119f97 100644 --- a/drivers/spi/atmel-quadspi.c +++ b/drivers/spi/atmel-quadspi.c @@ -438,6 +438,9 @@ static bool atmel_qspi_supports_op(struct spi_slave *slave, { struct atmel_qspi *aq = dev_get_priv(slave->dev->parent);
+ if (!spi_mem_default_supports_op(slave, op)) + return false; + if (aq->caps->octal) { if (atmel_qspi_sama7g5_find_mode(op) < 0) return false;
oops, wrong subject, let me resend.
- if (!spi_mem_default_supports_op(slave, op))
return false;
- if (aq->caps->octal) { if (atmel_qspi_sama7g5_find_mode(op) < 0) return false;
Tudor Ambarus
Tudor.Ambarus@microchip.com
