Re: [DNX#2006040142001034] [U-Boot-Users] M5235EVB port
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006040142001034] was created:
<snip>
Attached is my recent port to coldfire 5235. Please take a look at it as it is my first look at U-Boot (which by the way, is very nice!) I'd be happy if this code was added to the archive for others to use.
thanks, wilson
</snip>
Your U-Boot support team
Here is a patch to the below patch to fix a problem with the ethernet buffer descriptors:
diff -Naur u-boot-1.1.4-new/CHANGELOG u-boot-1.1.4-bd/CHANGELOG --- u-boot-1.1.4-new/CHANGELOG 2005-12-16 11:39:27.000000000 -0500 +++ u-boot-1.1.4-bd/CHANGELOG 2006-05-15 13:39:33.000000000 -0400 @@ -2,6 +2,10 @@ Changes for U-Boot 1.1.4: ======================================================================
+* Fix M5235 Ethernet Buffer Descriptors. Put them in internal RAM instead + right in the middle of where an image loads. + Patch by Wilson Callan, 15 May 2006 + * Changes to Yellowstone & Yosemite 440EP/GR eval boards: - Changed GPIO setup to enable another address line in order to address 64M of FLASH. diff -Naur u-boot-1.1.4-new/include/configs/M5235EVB.h u-boot-1.1.4-bd/include/configs/M5235EVB.h --- u-boot-1.1.4-new/include/configs/M5235EVB.h 2006-02-22 15:43:15.000000000 -0500 +++ u-boot-1.1.4-bd/include/configs/M5235EVB.h 2006-05-15 10:03:21.000000000 -0400 @@ -89,9 +89,6 @@ */ #define CFG_MBAR 0x40000000
-#undef CFG_DISCOVER_PHY -#define CFG_ENET_BD_BASE 0x380000 - /*----------------------------------------------------------------------- * Definitions for initial stack pointer and data area (in DPRAM) */ @@ -101,6 +98,9 @@ #define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) #define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET
+#undef CFG_DISCOVER_PHY +#define CFG_ENET_BD_BASE CFG_INIT_RAM_ADDR + /*----------------------------------------------------------------------- * Start addresses for the final memory configuration * (Set up by the startup code)
On 3/31/06 6:50 PM, "DENX Support System" support@denx.de wrote:
Hello list,
<snip> > Attached is my recent port to coldfire 5235. Please take a look at > it as it is my first look at U-Boot (which by the way, is very > nice!) I'd be happy if this code was added to the archive for others > to use. > > thanks, wilson </snip>
This SF.Net email is sponsored by xPML, a groundbreaking scripting language that extends applications into web and mobile media. Attend the live webcast and join the prime developer group breaking into this new coding territory! http://sel.as-us.falkag.net/sel?cmd=lnk&kid%110944&bid$1720&dat%... _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
DENX Support System
Wilson Callan - RPM
