[PATCH v2] clk: correct spelling of bound
bound is the correct past tense of bind.
Signed-off-by: Anatolij Gustschin agust@denx.de Reviewed-by: Peng Fan peng.fan@nxp.com --- Changes in v2: - rebase on current master - add RB tag from Peng
drivers/clk/clk-composite.c | 12 ++++++------ drivers/clk/clk-divider.c | 4 ++-- drivers/clk/clk-gate.c | 4 ++-- drivers/clk/clk-mux.c | 8 ++++---- drivers/clk/clk.c | 2 +- include/clk.h | 6 +++--- 6 files changed, 18 insertions(+), 18 deletions(-)
diff --git a/drivers/clk/clk-composite.c b/drivers/clk/clk-composite.c index a5626c33d1..484b4a82ba 100644 --- a/drivers/clk/clk-composite.c +++ b/drivers/clk/clk-composite.c @@ -18,7 +18,7 @@
static u8 clk_composite_get_parent(struct clk *clk) { - struct clk_composite *composite = to_clk_composite(clk_dev_binded(clk) ? + struct clk_composite *composite = to_clk_composite(clk_dev_bound(clk) ? (struct clk *)dev_get_clk_ptr(clk->dev) : clk); struct clk *mux = composite->mux;
@@ -27,7 +27,7 @@ static u8 clk_composite_get_parent(struct clk *clk)
static int clk_composite_set_parent(struct clk *clk, struct clk *parent) { - struct clk_composite *composite = to_clk_composite(clk_dev_binded(clk) ? + struct clk_composite *composite = to_clk_composite(clk_dev_bound(clk) ? (struct clk *)dev_get_clk_ptr(clk->dev) : clk); const struct clk_ops *mux_ops = composite->mux_ops; struct clk *mux = composite->mux; @@ -37,7 +37,7 @@ static int clk_composite_set_parent(struct clk *clk, struct clk *parent)
static unsigned long clk_composite_recalc_rate(struct clk *clk) { - struct clk_composite *composite = to_clk_composite(clk_dev_binded(clk) ? + struct clk_composite *composite = to_clk_composite(clk_dev_bound(clk) ? (struct clk *)dev_get_clk_ptr(clk->dev) : clk); const struct clk_ops *rate_ops = composite->rate_ops; struct clk *rate = composite->rate; @@ -47,7 +47,7 @@ static unsigned long clk_composite_recalc_rate(struct clk *clk)
static ulong clk_composite_set_rate(struct clk *clk, unsigned long rate) { - struct clk_composite *composite = to_clk_composite(clk_dev_binded(clk) ? + struct clk_composite *composite = to_clk_composite(clk_dev_bound(clk) ? (struct clk *)dev_get_clk_ptr(clk->dev) : clk); const struct clk_ops *rate_ops = composite->rate_ops; struct clk *clk_rate = composite->rate; @@ -57,7 +57,7 @@ static ulong clk_composite_set_rate(struct clk *clk, unsigned long rate)
static int clk_composite_enable(struct clk *clk) { - struct clk_composite *composite = to_clk_composite(clk_dev_binded(clk) ? + struct clk_composite *composite = to_clk_composite(clk_dev_bound(clk) ? (struct clk *)dev_get_clk_ptr(clk->dev) : clk); const struct clk_ops *gate_ops = composite->gate_ops; struct clk *gate = composite->gate; @@ -67,7 +67,7 @@ static int clk_composite_enable(struct clk *clk)
static int clk_composite_disable(struct clk *clk) { - struct clk_composite *composite = to_clk_composite(clk_dev_binded(clk) ? + struct clk_composite *composite = to_clk_composite(clk_dev_bound(clk) ? (struct clk *)dev_get_clk_ptr(clk->dev) : clk); const struct clk_ops *gate_ops = composite->gate_ops; struct clk *gate = composite->gate; diff --git a/drivers/clk/clk-divider.c b/drivers/clk/clk-divider.c index 822e09b084..d3c5db0be2 100644 --- a/drivers/clk/clk-divider.c +++ b/drivers/clk/clk-divider.c @@ -70,7 +70,7 @@ unsigned long divider_recalc_rate(struct clk *hw, unsigned long parent_rate,
static ulong clk_divider_recalc_rate(struct clk *clk) { - struct clk_divider *divider = to_clk_divider(clk_dev_binded(clk) ? + struct clk_divider *divider = to_clk_divider(clk_dev_bound(clk) ? dev_get_clk_ptr(clk->dev) : clk); unsigned long parent_rate = clk_get_parent_rate(clk); unsigned int val; @@ -150,7 +150,7 @@ int divider_get_val(unsigned long rate, unsigned long parent_rate,
static ulong clk_divider_set_rate(struct clk *clk, unsigned long rate) { - struct clk_divider *divider = to_clk_divider(clk_dev_binded(clk) ? + struct clk_divider *divider = to_clk_divider(clk_dev_bound(clk) ? dev_get_clk_ptr(clk->dev) : clk); unsigned long parent_rate = clk_get_parent_rate(clk); int value; diff --git a/drivers/clk/clk-gate.c b/drivers/clk/clk-gate.c index 70b8794554..905b98a448 100644 --- a/drivers/clk/clk-gate.c +++ b/drivers/clk/clk-gate.c @@ -43,7 +43,7 @@ */ static void clk_gate_endisable(struct clk *clk, int enable) { - struct clk_gate *gate = to_clk_gate(clk_dev_binded(clk) ? + struct clk_gate *gate = to_clk_gate(clk_dev_bound(clk) ? dev_get_clk_ptr(clk->dev) : clk); int set = gate->flags & CLK_GATE_SET_TO_DISABLE ? 1 : 0; u32 reg; @@ -86,7 +86,7 @@ static int clk_gate_disable(struct clk *clk)
int clk_gate_is_enabled(struct clk *clk) { - struct clk_gate *gate = to_clk_gate(clk_dev_binded(clk) ? + struct clk_gate *gate = to_clk_gate(clk_dev_bound(clk) ? dev_get_clk_ptr(clk->dev) : clk); u32 reg;
diff --git a/drivers/clk/clk-mux.c b/drivers/clk/clk-mux.c index 5acc0b8cbd..f7d07dc1dc 100644 --- a/drivers/clk/clk-mux.c +++ b/drivers/clk/clk-mux.c @@ -35,7 +35,7 @@ int clk_mux_val_to_index(struct clk *clk, u32 *table, unsigned int flags, unsigned int val) { - struct clk_mux *mux = to_clk_mux(clk_dev_binded(clk) ? + struct clk_mux *mux = to_clk_mux(clk_dev_bound(clk) ? dev_get_clk_ptr(clk->dev) : clk); int num_parents = mux->num_parents;
@@ -79,7 +79,7 @@ unsigned int clk_mux_index_to_val(u32 *table, unsigned int flags, u8 index)
u8 clk_mux_get_parent(struct clk *clk) { - struct clk_mux *mux = to_clk_mux(clk_dev_binded(clk) ? + struct clk_mux *mux = to_clk_mux(clk_dev_bound(clk) ? dev_get_clk_ptr(clk->dev) : clk); u32 val;
@@ -97,7 +97,7 @@ u8 clk_mux_get_parent(struct clk *clk) static int clk_fetch_parent_index(struct clk *clk, struct clk *parent) { - struct clk_mux *mux = to_clk_mux(clk_dev_binded(clk) ? + struct clk_mux *mux = to_clk_mux(clk_dev_bound(clk) ? dev_get_clk_ptr(clk->dev) : clk);
int i; @@ -115,7 +115,7 @@ static int clk_fetch_parent_index(struct clk *clk,
static int clk_mux_set_parent(struct clk *clk, struct clk *parent) { - struct clk_mux *mux = to_clk_mux(clk_dev_binded(clk) ? + struct clk_mux *mux = to_clk_mux(clk_dev_bound(clk) ? dev_get_clk_ptr(clk->dev) : clk); int index; u32 val; diff --git a/drivers/clk/clk.c b/drivers/clk/clk.c index 1cf9987f6c..8ba72ad821 100644 --- a/drivers/clk/clk.c +++ b/drivers/clk/clk.c @@ -57,7 +57,7 @@ const char *clk_hw_get_name(const struct clk *hw) return hw->dev->name; }
-bool clk_dev_binded(struct clk *clk) +bool clk_dev_bound(struct clk *clk) { if (clk->dev && (clk->dev->flags & DM_FLAG_BOUND)) return true; diff --git a/include/clk.h b/include/clk.h index 3336301815..c5fe3f4567 100644 --- a/include/clk.h +++ b/include/clk.h @@ -458,13 +458,13 @@ static inline bool clk_valid(struct clk *clk) int clk_get_by_id(ulong id, struct clk **clkp);
/** - * clk_dev_binded() - Check whether the clk has a device binded + * clk_dev_bound() - Check whether the clk has a device bound * * @clk A pointer to the clk * - * @return true on binded, or false on no + * @return true when bound, or false otherwise */ -bool clk_dev_binded(struct clk *clk); +bool clk_dev_bound(struct clk *clk); #endif
#define clk_prepare_enable(clk) clk_enable(clk)
Anatolij Gustschin
