[U-Boot-Users] Re: Patch for U-Boot 0.1.1: sbc8260 configuration tweaks
Dear Jon,
in message 200211100411.XAA19783@lucky.si.com you wrote:
sbc8260 configuration tweaks:
Ummm... partially added, and in a modified form.
I wish you had negotiated your changes with Oliver Brown (the official maintainer of the SBC8260 board) first.
- The image timestamp support and the alternate memory test were activated.
Added.
- The extra env setttings were flushed out.
Added partially.
- The boot delay was reduced from 5 to 3 seconds
_NOT_ added.
- The default load address was increased from 0x140000 to 0x400000
Added.
Some comments;
--- include/configs/sbc8260.h 3 Nov 2002 00:57:12 -0000 1.1.1.1 +++ include/configs/sbc8260.h 10 Nov 2002 02:34:25 -0000 @@ -241,7 +241,7 @@ /*
- select SPI support configuration
*/ -#undef CONFIG_SPI /* enable SPI driver */ +#undef CONFIG_SPI /* Enable SPI driver */
Both versions look nonsense to me.
+/* Define this to contain any number of null terminated strings that
- will be part of the default enviroment compiled into the boot image.
+#define CONFIG_EXTRA_ENV_SETTINGS \ +"serverip=192.168.123.201\0" \ +"ipaddr=192.168.123.203\0" \
I wish you had checked this with the board maintainer first! Oliver, is this OK for you?
+"root-on-initrd="\
- "setenv bootcmd "\
- "version\;" \
- "echo\;" \
- "bootp\;" \
- "setenv bootargs root=/dev/ram0 rw " \
- "ip=\$(ipaddr):\$(serverip):\$(gatewayip):\$(netmask):\$(hostname)::off\;" \
- "run boot-hook\;" \
Changed. I guess you did not test this? It probably does not do what you intend to do, or I may be wrong. Please check the ckecked in code if it works as intended.
/* Ethernet MAC address */ -#define CONFIG_ETHADDR 00:a0:1e:a8:7b:cb +#define CONFIG_ETHADDR 00:a0:1e:a8:7b:aa
NOT accepted, as it will probbaly break Oliver's board; I don't like such stuff, but he is the board's maintainer, so he decides.
/* Set to a positive value to delay for running BOOTCOMMAND */ -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ +#define CONFIG_BOOTDELAY 3 /* autoboot after 3 seconds */
Same.
-#if 0 /* Be selective on what keys can delay or stop the autoboot process
To stop use: " "
*/ -# define CONFIG_AUTOBOOT_KEYED -# define CONFIG_AUTOBOOT_PROMPT "Autobooting in %d seconds, press " " to stop\n" -# define CONFIG_AUTOBOOT_STOP_STR " " -# undef CONFIG_AUTOBOOT_DELAY_STR -# define DEBUG_BOOTKEYS 0 -#endif +#define CONFIG_AUTOBOOT_KEYED +#define CONFIG_AUTOBOOT_PROMPT "\nAutobooting in %d seconds, press " " to stop\n" +#define CONFIG_AUTOBOOT_STOP_STR " " +#undef CONFIG_AUTOBOOT_DELAY_STR +#define DEBUG_BOOTKEYS 0
/* Define a command string that is automatically executed when no character
- is read on the console interface withing "Boot Delay" after reset.
Same.
