[U-Boot] [PATCH 1/1] doc: README.uefi: fix typos
%s/specfication/specification/ %s/selftest/self-test/ %s/little endian/little-endian/
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/README.uefi | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/doc/README.uefi b/doc/README.uefi index 6b9759cfed..0982fad92e 100644 --- a/doc/README.uefi +++ b/doc/README.uefi @@ -14,7 +14,7 @@ and boot loaders like GRUB or the FreeBSD loader can be executed.
## Building for UEFI
-The UEFI standard supports only little endian systems. The UEFI support can be +The UEFI standard supports only little-endian systems. The UEFI support can be activated for ARM and x86 by specifying
CONFIG_CMD_BOOTEFI=y @@ -53,7 +53,7 @@ arguments.
### Executing the boot manager
-The UEFI specfication foresees to define boot entries and boot sequence via UEFI +The UEFI specification foresees to define boot entries and boot sequence via UEFI variables. Booting according to these variables is possible via
bootefi bootmgr [fdt address] @@ -90,14 +90,14 @@ Below you find the output of an example session. The environment variable fdtcontroladdr points to U-Boot's internal device tree (if available).
-### Executing the built-in selftest +### Executing the built-in self-test
-An UEFI selftest suite can be embedded in U-Boot by building with +An UEFI self-test suite can be embedded in U-Boot by building with
CONFIG_CMD_BOOTEFI_SELFTEST=y
For testing the UEFI implementation the bootefi command can be used to start the -selftest. +self-test.
bootefi selftest [fdt address]
