[U-Boot] TFTP Timeout Interval problem
I got a problem with tftp and found this patch. ------------- commit 620776d734e4b126c407f636bda825a594a17723 Author: Pavel Machek pavel@denx.de Date: Tue Aug 18 14:34:26 2015 +0200
tftp: adjust settings to be suitable for 100Mbit ethernet -------------- The default timeout is changed to 100 (ms) and this causes "TFTP error: 'Unsupported option(s) requested' (8)".
Because the option is equal to timeout/1000, now it's zero(100/1000 -> 0) which is not supported. Actually I find in an original doc RFC-2349 which specifies this value should range between "1" and "255" seconds.
So I think there may be a conflict? Look forward to your help.
This is my test log: => tftp a0000000 gqy/bootscript Using FM1@DTSEC3 device TFTP from server 10.192.208.233; our IP address is 10.193.20.130 Filename 'gqy/bootscript'. Load address: 0xa0000000 Loading: * TFTP error: 'Unsupported option(s) requested' (8) Starting again => setenv tftptimeout 1000 => tftp a0000000 gqy/bootscript Using FM1@DTSEC3 device TFTP from server 10.192.208.233; our IP address is 10.193.20.130 Filename 'gqy/bootscript'. Load address: 0xa0000000 Loading: # 44.9 KiB/s done Bytes transferred = 92 (5c hex) =>
Regards, Qianyu
Hi!
Yes, sorry about that. Just revert it, or update to newer u-boot where it should be reverted.
Regards, Qianyu
That's all right. Thanks a lot!
Regards, Qianyu
-----Original Message----- From: Pavel Machek [mailto:pavel@denx.de] Sent: Monday, August 31, 2015 8:16 PM To: Gong Qianyu-B52263 Cc: u-boot@lists.denx.de Subject: Re: TFTP Timeout Interval problem
Hi!
Regards, Qianyu
-- (english) http://www.livejournal.com/~pavelmachek (cesky, pictures) http://atrey.karlin.mff.cuni.cz/~pavel/picture/horses/blog.html
Hi Qianyu,
Check this patch: http://patchwork.ozlabs.org/patch/511761/
I believe it should be applied soon.
Regards, Bin
Bin Meng
Gong Q.Y.
Pavel Machek
