[U-Boot] [PATCH] board/b4860qds: Add support to make Aurora work on B4860QDS
1) Add new SerDes1 protocols having Aurora in them 2) Add VSC cross point connections for Aurora to work with CPRI and SGMIIs 3) Configure VSC crossbar switch to connect SerDes1 lanes to aurora on board, by checking SerDes1 protocols 4) SerDes1 Refclks have been set properly to make Aurora, CPRI and SGMIIs to work together properly
Signed-off-by: Shaveta Leekha shaveta@freescale.com --- arch/powerpc/cpu/mpc85xx/b4860_serdes.c | 32 +++++++++ board/freescale/b4860qds/b4860qds.c | 75 ++++++++++++++++++++- board/freescale/b4860qds/b4860qds_crossbar_con.h | 8 ++ 3 files changed, 111 insertions(+), 4 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/b4860_serdes.c b/arch/powerpc/cpu/mpc85xx/b4860_serdes.c index 6ff6a70..c96ad0b 100644 --- a/arch/powerpc/cpu/mpc85xx/b4860_serdes.c +++ b/arch/powerpc/cpu/mpc85xx/b4860_serdes.c @@ -18,6 +18,24 @@ struct serdes_config { #ifdef CONFIG_PPC_B4860 static struct serdes_config serdes1_cfg_tbl[] = { /* SerDes 1 */ + {0x02, {AURORA, AURORA, CPRI6, CPRI5, + CPRI4, CPRI3, CPRI2, CPRI1} }, + {0x04, {AURORA, AURORA, CPRI6, CPRI5, + CPRI4, CPRI3, CPRI2, CPRI1} }, + {0x05, {AURORA, AURORA, CPRI6, CPRI5, + CPRI4, CPRI3, CPRI2, CPRI1} }, + {0x06, {AURORA, AURORA, CPRI6, CPRI5, + CPRI4, CPRI3, CPRI2, CPRI1} }, + {0x08, {AURORA, AURORA, CPRI6, CPRI5, + CPRI4, CPRI3, CPRI2, CPRI1} }, + {0x09, {AURORA, AURORA, CPRI6, CPRI5, + CPRI4, CPRI3, CPRI2, CPRI1} }, + {0x0A, {AURORA, AURORA, CPRI6, CPRI5, + CPRI4, CPRI3, CPRI2, CPRI1} }, + {0x0B, {AURORA, AURORA, CPRI6, CPRI5, + CPRI4, CPRI3, CPRI2, CPRI1} }, + {0x0C, {AURORA, AURORA, CPRI6, CPRI5, + CPRI4, CPRI3, CPRI2, CPRI1} }, {0x0D, {CPRI8, CPRI7, CPRI6, CPRI5, CPRI4, CPRI3, CPRI2, CPRI1}}, {0x0E, {CPRI8, CPRI7, CPRI6, CPRI5, @@ -44,8 +62,22 @@ static struct serdes_config serdes1_cfg_tbl[] = { {0x34, {AURORA, AURORA, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, CPRI4, CPRI3, CPRI2, CPRI1}}, + {0x39, {AURORA, AURORA, CPRI6, CPRI5, + CPRI4, CPRI3, CPRI2, CPRI1} }, + {0x3A, {AURORA, AURORA, CPRI6, CPRI5, + CPRI4, CPRI3, CPRI2, CPRI1} }, + {0x3C, {AURORA, AURORA, CPRI6, CPRI5, + CPRI4, CPRI3, CPRI2, CPRI1} }, + {0x3D, {AURORA, AURORA, CPRI6, CPRI5, + CPRI4, CPRI3, CPRI2, CPRI1} }, {0x3E, {CPRI8, CPRI7, CPRI6, CPRI5, CPRI4, CPRI3, CPRI2, CPRI1}}, + {0x5C, {AURORA, AURORA, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, + CPRI4, CPRI3, CPRI2, CPRI1} }, + {0x5D, {AURORA, AURORA, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, + CPRI4, CPRI3, CPRI2, CPRI1} }, {} }; static struct serdes_config serdes2_cfg_tbl[] = { diff --git a/board/freescale/b4860qds/b4860qds.c b/board/freescale/b4860qds/b4860qds.c index f6b012d..f6faa24 100644 --- a/board/freescale/b4860qds/b4860qds.c +++ b/board/freescale/b4860qds/b4860qds.c @@ -151,6 +151,53 @@ int configure_vsc3316_3308(void) } break;
+ case 0x02: + case 0x04: + case 0x05: + case 0x06: + case 0x08: + case 0x09: + case 0x0A: + case 0x0B: + case 0x0C: + case 0x30: + case 0x32: + case 0x33: + case 0x34: + case 0x39: + case 0x3A: + case 0x3C: + case 0x3D: + case 0x5C: + case 0x5D: + /* + * Configuration: + * SERDES: 1 + * Lanes: A,B: AURORA + * Lanes: C,d: SGMII + * Lanes: E,F,G,H: CPRI + */ + debug("Configuring crossbar for Aurora, SGMII 3 and 4," + " and CPRI. srds_prctl:%x\n", serdes1_prtcl); + num_vsc16_con = NUM_CON_VSC3316; + /* Configure VSC3316 crossbar switch */ + ret = select_i2c_ch_pca(I2C_CH_VSC3316); + if (!ret) { + ret = vsc3316_config(VSC3316_TX_ADDRESS, + vsc16_tx_sfp_sgmii_aurora, + num_vsc16_con); + if (ret) + return ret; + ret = vsc3316_config(VSC3316_RX_ADDRESS, + vsc16_rx_sfp_sgmii_aurora, + num_vsc16_con); + if (ret) + return ret; + } else { + return ret; + } + break; + #ifdef CONFIG_PPC_B4420 case 0x18: /* @@ -245,7 +292,7 @@ int config_serdes1_refclks(void) serdes_corenet_t *srds_regs = (void *)CONFIG_SYS_FSL_CORENET_SERDES_ADDR; u32 serdes1_prtcl, lane; - unsigned int flag_sgmii_prtcl = 0; + unsigned int flag_sgmii_aurora_prtcl = 0; int ret, i;
serdes1_prtcl = in_be32(&gur->rcwsr[4]) & @@ -270,6 +317,25 @@ int config_serdes1_refclks(void) case 0x2C: case 0x2D: case 0x2E: + case 0x02: + case 0x04: + case 0x05: + case 0x06: + case 0x08: + case 0x09: + case 0x0A: + case 0x0B: + case 0x0C: + case 0x30: + case 0x32: + case 0x33: + case 0x34: + case 0x39: + case 0x3A: + case 0x3C: + case 0x3D: + case 0x5C: + case 0x5D: debug("Configuring idt8t49n222a for CPRI SerDes clks:" " for srds_prctl:%x\n", serdes1_prtcl); ret = select_i2c_ch_pca(I2C_CH_IDT); @@ -288,7 +354,7 @@ int config_serdes1_refclks(void) select_i2c_ch_pca(I2C_CH_DEFAULT);
/* Change SerDes1's Refclk1 to 125MHz for on board - * SGMIIs to work + * SGMIIs or Aurora to work */ for (lane = 0; lane < SRDS_MAX_LANES; lane++) { enum srds_prtcl lane_prtcl = serdes_get_prtcl @@ -300,14 +366,15 @@ int config_serdes1_refclks(void) case SGMII_FM1_DTSEC4: case SGMII_FM1_DTSEC5: case SGMII_FM1_DTSEC6: - flag_sgmii_prtcl++; + case AURORA: + flag_sgmii_aurora_prtcl++; break; default: break; } }
- if (flag_sgmii_prtcl) + if (flag_sgmii_aurora_prtcl) QIXIS_WRITE(brdcfg[4], QIXIS_SRDS1CLK_125);
/* Steps For SerDes PLLs reset and reconfiguration after diff --git a/board/freescale/b4860qds/b4860qds_crossbar_con.h b/board/freescale/b4860qds/b4860qds_crossbar_con.h index db0cf28..fcccb8f 100644 --- a/board/freescale/b4860qds/b4860qds_crossbar_con.h +++ b/board/freescale/b4860qds/b4860qds_crossbar_con.h @@ -24,6 +24,10 @@ static const int8_t vsc16_tx_4sfp_sgmii_34[8][2] = { {15, 7}, {0, 1}, {7, 8}, {9, 0}, {5, 14}, {4, 15}, {-1, -1}, {-1, -1} };
+static int8_t vsc16_tx_sfp_sgmii_aurora[8][2] = { {15, 7}, {0, 1}, + {7, 8}, {9, 0}, {5, 14}, + {4, 15}, {2, 12}, {12, 13} }; + #ifdef CONFIG_PPC_B4420 static int8_t vsc16_tx_sgmii_lane_cd[8][2] = { {5, 14}, {4, 15}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} }; @@ -46,6 +50,10 @@ static const int8_t vsc16_rx_4sfp_sgmii_34[8][2] = { {8, 15}, {0, 1}, {7, 8}, {1, 9}, {14, 11}, {15, 10}, {-1, -1}, {-1, -1} };
+static int8_t vsc16_rx_sfp_sgmii_aurora[8][2] = { {8, 15}, {0, 1}, + {7, 8}, {1, 9}, {14, 11}, + {15, 10}, {13, 3}, {12, 12} }; + #ifdef CONFIG_PPC_B4420 static int8_t vsc16_rx_sgmii_lane_cd[8][2] = { {14, 11}, {15, 10}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} };
On 02/26/2014 02:36 AM, Shaveta Leekha wrote:
- Add new SerDes1 protocols having Aurora in them
- Add VSC cross point connections for Aurora to work with CPRI and SGMIIs
- Configure VSC crossbar switch to connect SerDes1 lanes to aurora on board, by checking SerDes1 protocols
- SerDes1 Refclks have been set properly to make Aurora, CPRI and SGMIIs to work together properly
Applied to u-boot-mpc85xx/master. Thanks.
York
Shaveta Leekha
York Sun
