[U-Boot-Users] need for explaination
Hi All, I like to clarify one doubt ,when i try to boot my kernel using ramdisk image via bootm command .I have back traced the cmd_bootm.c(Version u_boot-1.1.6 in the common directory) our code flow hangs at the following function:
(*kernel) (kbd, initrd_start, initrd_end, cmd_start, cmd_end);
it's calling function pointer .It hangs at this call can any one help me out where is the exact definition of this function call so that i can proceed further.I think it should be in the u-boot side.It will be of great help if any one reply me ASAP in this regard. Regards Ramesh.K.V
That's the branch to the kernel. Either you didn't load the kernel properly, or (more likely) the kernel simply isn't working, and needs to be debugged.
-Scott
rameah nathan
Scott Wood
