[U-Boot] [PATCH] tools: image: fix "algo" property of public key for verified boot
The "algo_name" points to a property in a blob being edited. The pointer becomes stale when fit_image_write_sig() inserts signatures. Then crypto->add_verify_data() writes wrong data to the public key destination.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
tools/image-host.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/image-host.c b/tools/image-host.c index c60d4ad..ad9a73a 100644 --- a/tools/image-host.c +++ b/tools/image-host.c @@ -166,7 +166,7 @@ static int fit_image_setup_sig(struct image_sign_info *info, info->keyname = fdt_getprop(fit, noffset, "key-name-hint", NULL); info->fit = fit; info->node_offset = noffset; - info->name = algo_name; + info->name = strdup(algo_name); info->checksum = image_get_checksum_algo(algo_name); info->crypto = image_get_crypto_algo(algo_name); info->require_keys = require_keys;
Masahiro Yamada
