[PATCH] cmd: part: Add 'block' sub-command
From 4376dc705acefb5b5281d32dcc1cb5084c61f99c Mon Sep 17 00:00:00 2001
From: Razvan Becheriu razvan@gmail.com Date: Wed, 22 Apr 2020 00:17:33 +0300 Subject: [PATCH] cmd: part: Add 'block' sub-command
Add part block sub-command which returns partition block size.
e.g.: part block mmc $mmcdev system_a system_a_index --- cmd/part.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/cmd/part.c b/cmd/part.c index 5e4e45ca6d..d78d914e7a 100644 --- a/cmd/part.c +++ b/cmd/part.c @@ -25,6 +25,7 @@ enum cmd_part_info { CMD_PART_INFO_START = 0, CMD_PART_INFO_SIZE, + CMD_PART_INFO_BLOCK, CMD_PART_INFO_NUMBER };
@@ -151,6 +152,9 @@ static int do_part_info(int argc, char * const argv[], enum cmd_part_info param) case CMD_PART_INFO_SIZE: snprintf(buf, sizeof(buf), LBAF, info.size); break; + case CMD_PART_INFO_BLOCK: + snprintf(buf, sizeof(buf), LBAF, info.blksz); + break; case CMD_PART_INFO_NUMBER: snprintf(buf, sizeof(buf), "0x%x", part); break; @@ -177,6 +181,11 @@ static int do_part_size(int argc, char * const argv[]) return do_part_info(argc, argv, CMD_PART_INFO_SIZE); }
+static int do_part_block(int argc, char * const argv[]) +{ + return do_part_info(argc, argv, CMD_PART_INFO_BLOCK); +} + static int do_part_number(int argc, char * const argv[]) { return do_part_info(argc, argv, CMD_PART_INFO_NUMBER); @@ -195,6 +204,8 @@ static int do_part(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return do_part_start(argc - 2, argv + 2); else if (!strcmp(argv[1], "size")) return do_part_size(argc - 2, argv + 2); + else if (!strcmp(argv[1], "block")) + return do_part_block(argc - 2, argv + 2); else if (!strcmp(argv[1], "number")) return do_part_number(argc - 2, argv + 2);
@@ -219,6 +230,9 @@ U_BOOT_CMD( "part size <interface> <dev> <part> <varname>\n" " - set environment variable to the size of the partition (in blocks)\n" " part can be either partition number or partition name\n" + "part block <interface> <dev> <part> <varname>\n" + " - set environment variable to the size of the partition block\n" + " part can be either partition number or partition name\n" "part number <interface> <dev> <part> <varname>\n" " - set environment variable to the partition number using the partition name\n" " part must be specified as partition name"
On Wed, Apr 22, 2020 at 01:13:06AM +0300, razvan becheriu wrote:
From 4376dc705acefb5b5281d32dcc1cb5084c61f99c Mon Sep 17 00:00:00 2001 From: Razvan Becheriu razvan@gmail.com Date: Wed, 22 Apr 2020 00:17:33 +0300 Subject: [PATCH] cmd: part: Add 'block' sub-command
Add part block sub-command which returns partition block size. e.g.: part block mmc $mmcdev system_a system_a_index
- CMD_PART_INFO_BLOCK, CMD_PART_INFO_NUMBER
- case CMD_PART_INFO_BLOCK:
- snprintf(buf, sizeof(buf), LBAF, info.blksz);
- break; case CMD_PART_INFO_NUMBER: snprintf(buf, sizeof(buf), "0x%x", part); break;
- return do_part_info(argc, argv, CMD_PART_INFO_BLOCK);
- else if (!strcmp(argv[1], "block"))
- return do_part_block(argc - 2, argv + 2); else if (!strcmp(argv[1], "number")) return do_part_number(argc - 2, argv + 2);
- "part block <interface> <dev> <part> <varname>\n"
- " - set environment variable to the size of the partition block\n"
- " part can be either partition number or partition name\n" "part number <interface> <dev> <part> <varname>\n" " - set environment variable to the partition number using the
Please re-send this via git send-email as this is totally mangled. Also please explain the use case for this command as it's going to unconditionally grow a lot of platforms. Thanks!
razvan becheriu
