[PATCH] udoo_neo: Move to DM for REGUALTOR/PMIC/I2C drivers
This moves over the PMIC power init to DM and the associated i2c and regulator bits.
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- board/udoo/neo/neo.c | 139 +++---------------------------------- configs/udoo_neo_defconfig | 10 +-- include/configs/udoo_neo.h | 5 -- 3 files changed, 15 insertions(+), 139 deletions(-)
diff --git a/board/udoo/neo/neo.c b/board/udoo/neo/neo.c index 62f81fff68..d374b86b5d 100644 --- a/board/udoo/neo/neo.c +++ b/board/udoo/neo/neo.c @@ -51,11 +51,6 @@ enum { PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \ PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
-#define I2C_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ - PAD_CTL_ODE) - #define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_PUE | \ PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) @@ -81,135 +76,25 @@ int dram_init(void) return 0; }
-#ifdef CONFIG_SYS_I2C_MXC -#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) -/* I2C1 for PMIC */ -static struct i2c_pads_info i2c_pad_info1 = { - .scl = { - .i2c_mode = MX6_PAD_GPIO1_IO00__I2C1_SCL | PC, - .gpio_mode = MX6_PAD_GPIO1_IO00__GPIO1_IO_0 | PC, - .gp = IMX_GPIO_NR(1, 0), - }, - .sda = { - .i2c_mode = MX6_PAD_GPIO1_IO01__I2C1_SDA | PC, - .gpio_mode = MX6_PAD_GPIO1_IO01__GPIO1_IO_1 | PC, - .gp = IMX_GPIO_NR(1, 1), - }, -}; -#endif - -#if CONFIG_IS_ENABLED(POWER_LEGACY) int power_init_board(void) { - struct pmic *p; - int ret; - unsigned int reg, rev_id; - - ret = power_pfuze3000_init(PFUZE3000_I2C_BUS); - if (ret) - return ret; - - p = pmic_get("PFUZE3000"); - ret = pmic_probe(p); - if (ret) - return ret; + struct udevice *dev; + int ret, dev_id, rev_id;
- pmic_reg_read(p, PFUZE3000_DEVICEID, ®); - pmic_reg_read(p, PFUZE3000_REVID, &rev_id); - printf("PMIC: PFUZE3000 DEV_ID=0x%x REV_ID=0x%x\n", reg, rev_id); - - /* disable Low Power Mode during standby mode */ - pmic_reg_read(p, PFUZE3000_LDOGCTL, ®); - reg |= 0x1; - ret = pmic_reg_write(p, PFUZE3000_LDOGCTL, reg); - if (ret) + ret = pmic_get("pfuze3000@8", &dev); + if (ret == -ENODEV) + return 0; + if (ret != 0) return ret;
- ret = pmic_reg_write(p, PFUZE3000_SW1AMODE, 0xc); - if (ret) - return ret; + dev_id = pmic_reg_read(dev, PFUZE3000_DEVICEID); + rev_id = pmic_reg_read(dev, PFUZE3000_REVID); + printf("PMIC: PFUZE3000 DEV_ID=0x%x REV_ID=0x%x\n", dev_id, rev_id);
- ret = pmic_reg_write(p, PFUZE3000_SW1BMODE, 0xc); - if (ret) - return ret; - - ret = pmic_reg_write(p, PFUZE3000_SW2MODE, 0xc); - if (ret) - return ret; - - ret = pmic_reg_write(p, PFUZE3000_SW3MODE, 0xc); - if (ret) - return ret; - - /* set SW1A standby voltage 0.975V */ - pmic_reg_read(p, PFUZE3000_SW1ASTBY, ®); - reg &= ~0x3f; - reg |= PFUZE3000_SW1AB_SETP(9750); - ret = pmic_reg_write(p, PFUZE3000_SW1ASTBY, reg); - if (ret) - return ret; - - /* set SW1B standby voltage 0.975V */ - pmic_reg_read(p, PFUZE3000_SW1BSTBY, ®); - reg &= ~0x3f; - reg |= PFUZE3000_SW1AB_SETP(9750); - ret = pmic_reg_write(p, PFUZE3000_SW1BSTBY, reg); - if (ret) - return ret; - - /* set SW1A/VDD_ARM_IN step ramp up time from 16us to 4us/25mV */ - pmic_reg_read(p, PFUZE3000_SW1ACONF, ®); - reg &= ~0xc0; - reg |= 0x40; - ret = pmic_reg_write(p, PFUZE3000_SW1ACONF, reg); - if (ret) - return ret; - - /* set SW1B/VDD_SOC_IN step ramp up time from 16us to 4us/25mV */ - pmic_reg_read(p, PFUZE3000_SW1BCONF, ®); - reg &= ~0xc0; - reg |= 0x40; - ret = pmic_reg_write(p, PFUZE3000_SW1BCONF, reg); - if (ret) - return ret; - - /* set VDD_ARM_IN to 1.350V */ - pmic_reg_read(p, PFUZE3000_SW1AVOLT, ®); - reg &= ~0x3f; - reg |= PFUZE3000_SW1AB_SETP(13500); - ret = pmic_reg_write(p, PFUZE3000_SW1AVOLT, reg); - if (ret) - return ret; - - /* set VDD_SOC_IN to 1.350V */ - pmic_reg_read(p, PFUZE3000_SW1BVOLT, ®); - reg &= ~0x3f; - reg |= PFUZE3000_SW1AB_SETP(13500); - ret = pmic_reg_write(p, PFUZE3000_SW1BVOLT, reg); - if (ret) - return ret; - - /* set DDR_1_5V to 1.350V */ - pmic_reg_read(p, PFUZE3000_SW3VOLT, ®); - reg &= ~0x0f; - reg |= PFUZE3000_SW3_SETP(13500); - ret = pmic_reg_write(p, PFUZE3000_SW3VOLT, reg); - if (ret) - return ret; - - /* set VGEN2_1V5 to 1.5V */ - pmic_reg_read(p, PFUZE3000_VLDO2CTL, ®); - reg &= ~0x0f; - reg |= PFUZE3000_VLDO_SETP(15000); - /* enable */ - reg |= 0x10; - ret = pmic_reg_write(p, PFUZE3000_VLDO2CTL, reg); - if (ret) - return ret; + pmic_clrsetbits(dev, PFUZE3000_LDOGCTL, 0, 1);
return 0; } -#endif
static iomux_v3_cfg_t const uart1_pads[] = { MX6_PAD_GPIO1_IO04__UART1_TX | MUX_PAD_CTRL(UART_PAD_CTRL), @@ -299,10 +184,6 @@ int board_init(void) gpio_request(IMX_GPIO_NR(4, 16), "ncp692"); gpio_direction_output(IMX_GPIO_NR(4, 16) , 1);
-#ifdef CONFIG_SYS_I2C_MXC - setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); -#endif - setup_fec();
return 0; diff --git a/configs/udoo_neo_defconfig b/configs/udoo_neo_defconfig index ca08de1bd4..9177bdba65 100644 --- a/configs/udoo_neo_defconfig +++ b/configs/udoo_neo_defconfig @@ -10,8 +10,9 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x80000 CONFIG_MX6SX=y CONFIG_TARGET_UDOO_NEO=y -CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_DM_I2C=y CONFIG_DM_GPIO=y +CONFIG_DM_MMC=y CONFIG_DEFAULT_DEVICE_TREE="imx6sx-udoo-neo-basic" CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_MMC=y @@ -39,8 +40,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_DEV=1 CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_BOUNCE_BUFFER=y -CONFIG_SYS_I2C_LEGACY=y -CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y @@ -52,11 +51,12 @@ CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y -CONFIG_POWER_LEGACY=y -CONFIG_POWER_I2C=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PFUZE100=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_ANATOP=y CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_PFUZE100=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y diff --git a/include/configs/udoo_neo.h b/include/configs/udoo_neo.h index 3a7cb050b1..ac13c3e57f 100644 --- a/include/configs/udoo_neo.h +++ b/include/configs/udoo_neo.h @@ -68,9 +68,4 @@ #define CONFIG_SYS_INIT_SP_ADDR \ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
-/* PMIC */ -#define CONFIG_POWER_PFUZE3000 -#define CONFIG_POWER_PFUZE3000_I2C_ADDR 0x08 -#define PFUZE3000_I2C_BUS 0 - #endif /* __CONFIG_H */
Hi Peter,
Nice diff ;-)
Reviewed-by: Fabio Estevam festevam@gmail.com
PAD_CTL_ODE)
.scl = {
.sda = {
-}; -#endif
struct pmic *p;
int ret;
if (ret)
return ret;
if (ret)
return ret;
reg |= 0x1;
if (ret)
if (ret == -ENODEV)
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
reg &= ~0x3f;
if (ret)
return ret;
reg &= ~0x3f;
if (ret)
return ret;
reg &= ~0xc0;
reg |= 0x40;
if (ret)
return ret;
reg &= ~0xc0;
reg |= 0x40;
if (ret)
return ret;
reg &= ~0x3f;
if (ret)
return ret;
reg &= ~0x3f;
if (ret)
return ret;
reg &= ~0x0f;
if (ret)
return ret;
reg &= ~0x0f;
/* enable */
reg |= 0x10;
if (ret)
return ret;
pmic_clrsetbits(dev, PFUZE3000_LDOGCTL, 0, 1); return 0;
} -#endif
-#endif
setup_fec(); return 0;
2.33.1
hi Peter,
On 22.12.21 01:38, Fabio Estevam wrote:
Hi Peter,
Nice diff ;-)
I get warning after applying the patch:
board/udoo/neo/neo.c:86:15: error: implicit declaration of function 'pmic_get' [-Werror=implicit-function-declaration] + 86 | ret = pmic_get("pfuze3000@8", &dev); + | ^~~~~~~~ +board/udoo/neo/neo.c:92:18: error: implicit declaration of function 'pmic_reg_read'; did you mean 'dm_i2c_reg_read'? [-Werror=implicit-function-declaration] + 92 | dev_id = pmic_reg_read(dev, PFUZE3000_DEVICEID); + | ^~~~~~~~~~~~~ + | dm_i2c_reg_read +board/udoo/neo/neo.c:96:9: error: implicit declaration of function 'pmic_clrsetbits'; did you mean 'clrsetbits'? [-Werror=implicit-function-declaration] + 96 | pmic_clrsetbits(dev, PFUZE3000_LDOGCTL, 0, 1); + | ^~~~~~~~~~~~~~~ + | clrsetbits +cc1: all warnings being treated as errors +make[2]: *** [scripts/Makefile.build:254: board/udoo/neo/neo.o] Error 1 +make[1]: *** [Makefile:1890: board/udoo/neo] Error 2
Can you check and repost ?
Thanks !
Best regards, Stefano
PAD_CTL_ODE)
.scl = {
.sda = {
-}; -#endif
struct pmic *p;
int ret;
if (ret)
return ret;
if (ret)
return ret;
reg |= 0x1;
if (ret)
if (ret == -ENODEV)
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
reg &= ~0x3f;
if (ret)
return ret;
reg &= ~0x3f;
if (ret)
return ret;
reg &= ~0xc0;
reg |= 0x40;
if (ret)
return ret;
reg &= ~0xc0;
reg |= 0x40;
if (ret)
return ret;
reg &= ~0x3f;
if (ret)
return ret;
reg &= ~0x3f;
if (ret)
return ret;
reg &= ~0x0f;
if (ret)
return ret;
reg &= ~0x0f;
/* enable */
reg |= 0x10;
if (ret)
return ret;
-#endif
-#endif
-- 2.33.1
Fabio Estevam
Peter Robinson
Stefano Babic
