[U-Boot] [PATCH] Removed clearing of L2-as-SRAM
Removed clearing of L2 cache as SRAM as it is not necessary without ECC. This also speeds up the booting process.
Signed-off-by: Fabian Cenedese cenedese@indel.ch Cc: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/cpu_init_nand.c | 7 ------- 1 files changed, 0 insertions(+), 7 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init_nand.c b/arch/powerpc/cpu/mpc85xx/cpu_init_nand.c index 8fb27ab..1c42a0b 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init_nand.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init_nand.c @@ -42,8 +42,6 @@ void cpu_init_f(void)
#if defined(CONFIG_SYS_RAMBOOT) && defined(CONFIG_SYS_INIT_L2_ADDR) ccsr_l2cache_t *l2cache = (void *)CONFIG_SYS_MPC85xx_L2_ADDR; - char *l2srbar; - int i;
out_be32(&l2cache->l2srbar0, CONFIG_SYS_INIT_L2_ADDR);
@@ -54,10 +52,5 @@ void cpu_init_f(void) /* set L2E=1 & L2SRAM=001 */ out_be32(&l2cache->l2ctl, (MPC85xx_L2CTL_L2E | MPC85xx_L2CTL_L2SRAM_ENTIRE)); - - /* Initialize L2 SRAM to zero */ - l2srbar = (char *)CONFIG_SYS_INIT_L2_ADDR; - for (i = 0; i < CONFIG_SYS_L2_SIZE; i++) - l2srbar[i] = 0; #endif }
char *l2srbar;
int i; out_be32(&l2cache->l2srbar0, CONFIG_SYS_INIT_L2_ADDR);
l2srbar[i] = 0;
#endif } -- 1.7.3.1.msysgit.0
There haven't been any comments about this yet. Is this ok?
bye Fabi
char *l2srbar;
l2srbar[i] = 0;
bye Fabi
will take a look, thanks for the reminder.
- k
applied to 85xx
- k
Fabian Cenedese
Kumar Gala
