[U-Boot] [PATCH v3] arm:exynos4:samsung:nuri Support for NURI target.
This patch adds support for Samsung's Exynos4 Nuri reference board.
New exynos4_nuri board has been added to boards.cfg
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v2: - MAINTAINERS file updated - CONFIG_MACH_TYPE added - hw_revision routine Changes for v3: - Entry to MAINTAINERS file added to preserve an alphabetical order - Redefinition of MACH_TYPE removed from exynos4_nuri.h - Code cleanup (dead spaces removed)
./tools/checkpatch.pl - total: 0 errors, 0 warnings, 867 lines checked
NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE --- MAINTAINERS | 4 + board/samsung/nuri/Makefile | 45 ++++ board/samsung/nuri/lowlevel_init.S | 395 ++++++++++++++++++++++++++++++++++++ board/samsung/nuri/nuri.c | 201 ++++++++++++++++++ boards.cfg | 1 + include/configs/exynos4_nuri.h | 209 +++++++++++++++++++ 6 files changed, 855 insertions(+), 0 deletions(-) create mode 100644 board/samsung/nuri/Makefile create mode 100644 board/samsung/nuri/lowlevel_init.S create mode 100644 board/samsung/nuri/nuri.c create mode 100644 include/configs/exynos4_nuri.h
diff --git a/MAINTAINERS b/MAINTAINERS index 576fea8..aa1fc15 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -724,6 +724,10 @@ Valentin Longchamp valentin.longchamp@keymile.com km_kirkwood ARM926EJS (Kirkwood SoC) portl2 ARM926EJS (Kirkwood SoC)
+Łukasz Majewski l.majewski@samsung.com + + exynos4_nuri ARM ARMV7 (S5PC210 SoC) + Nishanth Menon nm@ti.com
omap3_sdp3430 ARM ARMV7 (OMAP3xx SoC) diff --git a/board/samsung/nuri/Makefile b/board/samsung/nuri/Makefile new file mode 100644 index 0000000..27566de --- /dev/null +++ b/board/samsung/nuri/Makefile @@ -0,0 +1,45 @@ +# +# Copyright (C) 2010 Samsung Electronics +# Minkyu Kang mk7.kang@samsung.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y := nuri.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(SOBJS) $(OBJS) + $(call cmd_link_o_target, $(SOBJS) $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/samsung/nuri/lowlevel_init.S b/board/samsung/nuri/lowlevel_init.S new file mode 100644 index 0000000..67635bb --- /dev/null +++ b/board/samsung/nuri/lowlevel_init.S @@ -0,0 +1,395 @@ +/* + * Lowlevel setup for universal board based on S5PC210 + * + * Copyright (C) 2010 Samsung Electronics + * Kyungmin Park kyungmin.park@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/cpu.h> +#include <asm/arch/clock.h> + +/* + * Register usages: + * + * r5 has zero always + * r7 has GPIO part1 base 0x11400000 + * r6 has GPIO part2 base 0x11000000 + */ + + .globl lowlevel_init +lowlevel_init: + mov r11, lr + + /* r5 has always zero */ + mov r5, #0 + + ldr r7, =S5PC210_GPIO_PART1_BASE + ldr r6, =S5PC210_GPIO_PART2_BASE + + /* System Timer */ + ldr r0, =S5PC210_SYSTIMER_BASE + ldr r1, =0x5000 + str r1, [r0, #0x0] + ldr r1, =0xffffffff + str r1, [r0, #0x8] + ldr r1, =0x49 + str r1, [r0, #0x4] + + /* PMIC manual reset */ + /* nPOWER: XEINT_23: GPX2[7] */ + add r0, r6, #0xC40 @ S5PC210_GPIO_X2_OFFSET + ldr r1, [r0, #0x0] + bic r1, r1, #(0xf << 28) @ 28 = 7 * 4-bit + orr r1, r1, #(0x1 << 28) @ Output + str r1, [r0, #0x0] + + ldr r1, [r0, #0x4] + orr r1, r1, #(1 << 7) @ 7 = 7 * 1-bit + str r1, [r0, #0x4] + + /* init system clock */ + bl system_clock_init + + /* Disable Watchdog */ + ldr r0, =S5PC210_WATCHDOG_BASE @0x10060000 + str r5, [r0] + + /* UART */ + bl uart_asm_init + + /* PMU init */ + bl system_power_init + + bl tzpc_init + + mov lr, r11 + mov pc, lr + nop + nop + nop + +/* + * uart_asm_init: Initialize UART's pins + */ +uart_asm_init: + /* + * setup UART0-UART4 GPIOs (part1) + * GPA1CON[3] = I2C_3_SCL (3) + * GPA1CON[2] = I2C_3_SDA (3) + */ + mov r0, r7 + ldr r1, =0x22222222 + str r1, [r0, #0x00] @ S5PC210_GPIO_A0_OFFSET + ldr r1, =0x00223322 + str r1, [r0, #0x20] @ S5PC210_GPIO_A1_OFFSET + + /* UART_SEL GPY4[7] (part2) at S5PC210 */ + add r0, r6, #0x1A0 @ S5PC210_GPIO_Y4_OFFSET + ldr r1, [r0, #0x0] + bic r1, r1, #(0xf << 28) @ 28 = 7 * 4-bit + orr r1, r1, #(0x1 << 28) + str r1, [r0, #0x0] + + ldr r1, [r0, #0x8] + bic r1, r1, #(0x3 << 14) @ 14 = 7 * 2-bit + orr r1, r1, #(0x3 << 14) @ Pull-up enabled + str r1, [r0, #0x8] + + ldr r1, [r0, #0x4] + orr r1, r1, #(1 << 7) @ 7 = 7 * 1-bit + str r1, [r0, #0x4] + + mov pc, lr + nop + nop + nop + +system_clock_init: + ldr r0, =S5PC210_CLOCK_BASE + + /* APLL(1), MPLL(1), CORE(0), HPM(0) */ + ldr r1, =0x0101 + ldr r2, =0x14200 @ CLK_SRC_CPU + str r1, [r0, r2] + + /* wait ?us */ + mov r1, #0x10000 +1: subs r1, r1, #1 + bne 1b + + /* + * CLK_SRC_TOP0 + * MUX_ONENAND_SEL[28] 0: DOUT133, 1: DOUT166 + * MUX_VPLL_SEL[8] 0: FINPLL, 1: FOUTVPLL + * MUX_EPLL_SEL[4] 0: FINPLL, 1: FOUTEPLL + */ + ldr r1, =0x10000110 + ldr r2, =0x0C210 @ CLK_SRC_TOP + str r1, [r0, r2] + + /* SATA: SCLKMPLL(0), MMC[0:4]: SCLKMPLL(6) */ + ldr r1, =0x0066666 + ldr r2, =0x0C240 @ CLK_SRC_FSYS + str r1, [r0, r2] + /* UART[0:5], PWM: SCLKMPLL(6) */ + ldr r1, =0x6666666 + ldr r2, =0x0C250 @ CLK_SRC_PERIL0_OFFSET + str r1, [r0, r2] + + /* CPU0: CORE, COREM0, COREM1, PERI, ATB, PCLK_DBG, APLL */ + ldr r1, =0x0133730 + ldr r2, =0x14500 @ CLK_DIV_CPU0 + str r1, [r0, r2] + /* CPU1: COPY, HPM */ + ldr r1, =0x03 + ldr r2, =0x14504 @ CLK_DIV_CPU1 + str r1, [r0, r2] + /* DMC0: ACP, ACP_PCLK, DPHY, DMC, DMCD, DMCP, COPY2 CORE_TIMER */ + ldr r1, =0x13111113 + ldr r2, =0x10500 @ CLK_DIV_DMC0 + str r1, [r0, r2] + /* DMC1: PWI, DVSEM, DPM */ + ldr r1, =0x01010100 + ldr r2, =0x10504 @ CLK_DIV_DMC1 + str r1, [r0, r2] + /* LEFTBUS: GDL, GPL */ + ldr r1, =0x13 + ldr r2, =0x04500 @ CLK_DIV_LEFTBUS + str r1, [r0, r2] + /* RIGHHTBUS: GDR, GPR */ + ldr r1, =0x13 + ldr r2, =0x08500 @ CLK_DIV_RIGHTBUS + str r1, [r0, r2] + /* + * CLK_DIV_TOP + * ONENAND_RATIOD[18:16]: 0 SCLK_ONENAND = MOUTONENAND / (n + 1) + * ACLK_200, ACLK_100, ACLK_160, ACLK_133, + */ + ldr r1, =0x00005473 + ldr r2, =0x0C510 @ CLK_DIV_TOP + str r1, [r0, r2] + /* MMC[0:1] */ + ldr r1, =0x000f000f /* 800(MPLL) / (15 + 1) */ + ldr r2, =0x0C544 @ CLK_DIV_FSYS1 + str r1, [r0, r2] + /* MMC[2:3] */ + ldr r1, =0x000f000f /* 800(MPLL) / (15 + 1) */ + ldr r2, =0x0C548 @ CLK_DIV_FSYS2 + str r1, [r0, r2] + /* MMC4 */ + ldr r1, =0x000f /* 800(MPLL) / (15 + 1) */ + ldr r2, =0x0C54C @ CLK_DIV_FSYS3 + str r1, [r0, r2] + /* UART[0:5] */ + ldr r1, =0x774777 + ldr r2, =0x0C550 @ CLK_DIV_PERIL0 + str r1, [r0, r2] + /* SLIMBUS: ???, PWM */ + ldr r1, =0x8 + ldr r2, =0x0C55C @ CLK_DIV_PERIL3 + str r1, [r0, r2] + + /* PLL Setting */ + ldr r1, =0x1C20 + ldr r2, =0x14000 @ APLL_LOCK + str r1, [r0, r2] + ldr r2, =0x14008 @ MPLL_LOCK + str r1, [r0, r2] + ldr r2, =0x0C010 @ EPLL_LOCK + str r1, [r0, r2] + ldr r2, =0x0C020 @ VPLL_LOCK + str r1, [r0, r2] + + /* APLL */ + ldr r1, =0x8000001c + ldr r2, =0x14104 @ APLL_CON1 + str r1, [r0, r2] + ldr r1, =0x80c80601 @ 800MHz + ldr r2, =0x14100 @ APLL_CON0 + str r1, [r0, r2] + /* MPLL */ + ldr r1, =0x8000001C + ldr r2, =0x1410C @ MPLL_CON1 + str r1, [r0, r2] + ldr r1, =0x80c80601 @ 800MHz + ldr r2, =0x14108 @ MPLL_CON0 + str r1, [r0, r2] + /* EPLL */ + ldr r1, =0x0 + ldr r2, =0x0C114 @ EPLL_CON1 + str r1, [r0, r2] + ldr r1, =0x80300302 @ 96MHz + ldr r2, =0x0C110 @ EPLL_CON0 + str r1, [r0, r2] + /* VPLL */ + ldr r1, =0x11000400 + ldr r2, =0x0C124 @ VPLL_CON1 + str r1, [r0, r2] + ldr r1, =0x80350302 @ 108MHz + ldr r2, =0x0C120 @ VPLL_CON0 + str r1, [r0, r2] + + /* + * SMMUJPEG[11], JPEG[6], CSIS1[5] : 0111 1001 + * Turn off all + */ + ldr r1, =0xFFF80000 + ldr r2, =0x0C920 @ CLK_GATE_IP_CAM + str r1, [r0, r2] + + /* Turn off all */ + ldr r1, =0xFFFFFFC0 + ldr r2, =0x0C924 @ CLK_GATE_IP_VP + str r1, [r0, r2] + + /* Turn off all */ + ldr r1, =0xFFFFFFE0 + ldr r2, =0x0C928 @ CLK_GATE_IP_MFC + str r1, [r0, r2] + + /* Turn off all */ + ldr r1, =0xFFFFFFFC + ldr r2, =0x0C92C @ CLK_GATE_IP_G3D + str r1, [r0, r2] + + /* Turn off all */ + ldr r1, =0xFFFFFC00 + ldr r2, =0x0C930 @ CLK_GATE_IP_IMAGE + str r1, [r0, r2] + + /* DSIM0[3], MDNIE0[2], MIE0[1] : 0001 */ + ldr r1, =0xFFFFFFF1 + ldr r2, =0x0C934 @ CLK_GATE_IP_LCD0 + str r1, [r0, r2] + + /* Turn off all */ + ldr r1, =0xFFFFFFC0 + ldr r2, =0x0C938 @ CLK_GATE_IP_LCD1 + str r1, [r0, r2] + + /* + * SMMUPCIE[18], NFCON[16] : 1111 1010 + * PCIE[14], SATA[10], SDMMC43[9:8] : 1011 1000 + * SDMMC1[6], TSI[4], SATAPHY[3], PCIEPHY[2] : 1010 0011 + */ + ldr r1, =0xFFFAB8A3 + ldr r2, =0x0C940 @ CLK_GATE_IP_FSYS + str r1, [r0, r2] + + /* Turn off all */ + ldr r1, =0xFFFFFFFC + ldr r2, =0x0C94C @ CLK_GATE_IP_GPS + str r1, [r0, r2] + + /* + * AC97[27], SPDIF[26], SLIMBUS[25] : 1111 0001 + * I2C2[8] : 1111 1110 + */ + ldr r1, =0xF1FFFEFF + ldr r2, =0x0C950 @ CLK_GATE_IP_PERIL + str r1, [r0, r2] + + /* + * KEYIF[16] : 1111 1110 + */ + ldr r1, =0xFFFEFFFF + ldr r2, =0x0C960 @ CLK_GATE_IP_PERIR + str r1, [r0, r2] + + /* LCD1[5], G3D[3], MFC[2], TV[1] : 1101 0001 */ + ldr r1, =0xFFFFFFD1 + ldr r2, =0x0C970 @ CLK_GATE_BLOCK + str r1, [r0, r2] + mov pc, lr + nop + nop + nop + +system_power_init: + ldr r0, =S5PC210_POWER_BASE @ 0x10020000 + + ldr r2, =0x330C @ PS_HOLD_CONTROL + ldr r1, [r0, r2] + orr r1, r1, #(0x3 << 8) @ Data High, Output En + str r1, [r0, r2] + + /* Power Down */ + add r2, r0, #0x3000 + str r5, [r2, #0xC20] @ TV_CONFIGURATION + str r5, [r2, #0xC40] @ MFC_CONFIGURATION + str r5, [r2, #0xC60] @ G3D_CONFIGURATION + str r5, [r2, #0xCA0] @ LCD1_CONFIGURATION + str r5, [r2, #0xCE0] @ GPS_CONFIGURATION + + mov pc, lr + nop + nop + nop + +tzpc_init: + ldr r0, =0x10110000 + mov r1, #0x0 + str r1, [r0] + mov r1, #0xff + str r1, [r0, #0x0804] + str r1, [r0, #0x0810] + str r1, [r0, #0x081C] + str r1, [r0, #0x0828] + + ldr r0, =0x10120000 + mov r1, #0x0 + str r1, [r0] + mov r1, #0xff + str r1, [r0, #0x0804] + str r1, [r0, #0x0810] + str r1, [r0, #0x081C] + str r1, [r0, #0x0828] + + ldr r0, =0x10130000 + mov r1, #0x0 + str r1, [r0] + mov r1, #0xff + str r1, [r0, #0x0804] + str r1, [r0, #0x0810] + str r1, [r0, #0x081C] + str r1, [r0, #0x0828] + + ldr r0, =0x10140000 + mov r1, #0x0 + str r1, [r0] + mov r1, #0xff + str r1, [r0, #0x0804] + str r1, [r0, #0x0810] + str r1, [r0, #0x081C] + str r1, [r0, #0x0828] + + ldr r0, =0x10150000 + mov r1, #0x0 + str r1, [r0] + mov r1, #0xff + str r1, [r0, #0x0804] + str r1, [r0, #0x0810] + str r1, [r0, #0x081C] + str r1, [r0, #0x0828] + + mov pc, lr diff --git a/board/samsung/nuri/nuri.c b/board/samsung/nuri/nuri.c new file mode 100644 index 0000000..4a48526 --- /dev/null +++ b/board/samsung/nuri/nuri.c @@ -0,0 +1,201 @@ +/* + * Copyright (C) 2011 Samsung Electronics + * Minkyu Kang mk7.kang@samsung.com + * Kyungmin Park kyungmin.park@samsung.com + * Łukasz Majewski l.majewski@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/adc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/mmc.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct s5pc210_gpio_part1 *gpio1; +struct s5pc210_gpio_part2 *gpio2; +static unsigned int board_rev; + +u32 get_board_rev(void) +{ + return board_rev; +} + +static void check_hw_revision(void); + +int board_init(void) +{ + gpio1 = (struct s5pc210_gpio_part1 *) S5PC210_GPIO_PART1_BASE; + gpio2 = (struct s5pc210_gpio_part2 *) S5PC210_GPIO_PART2_BASE; + + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + check_hw_revision(); + printf("HW Revision:\t0x%x\n", board_rev); + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = \ + get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + + get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE) + + get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE) + + get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE); + + return 0; +} + +void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; + gd->bd->bi_dram[2].start = PHYS_SDRAM_3; + gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE; + gd->bd->bi_dram[3].start = PHYS_SDRAM_4; + gd->bd->bi_dram[3].size = PHYS_SDRAM_4_SIZE; +} + +static unsigned int get_hw_revision(void) +{ + int hwrev = 0; + int i; + + /* NFC_EN: GPL2[6]: output high - early enable for board type chcking */ + s5p_gpio_direction_output(&gpio2->l2, 6, 1); + + /* HW_REV[0:3]: GPE1[0:3] */ + for (i = 0; i < 4; i++) { + s5p_gpio_direction_input(&gpio1->e1, i); + s5p_gpio_set_pull(&gpio1->e1, i, GPIO_PULL_NONE); + } + + udelay(10); + + for (i = 0; i < 4; i++) + hwrev |= (s5p_gpio_get_value(&gpio1->e1, i) << i); + + debug("hwrev 0x%x\n", hwrev); + + return hwrev; +} + +static void check_hw_revision(void) +{ + board_rev = get_hw_revision(); +} + +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + puts("Board:\tExynos4 Nuri\n"); + return 0; +} +#endif + +#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + int i, err; + + /* MASSMEMORY_EN: GPL[1] -> output LOW */ + s5p_gpio_direction_output(&gpio2->l1, 1, 0); + s5p_gpio_set_pull(&gpio2->l1, 1, GPIO_PULL_NONE); + + /* + * eMMC GPIO: + * SDR 8-bit@48MHz at MMC0 + * GPK0[0] SD_0_CLK(2) + * GPK0[1] SD_0_CMD(2) + * GPK0[2] SD_0_CDn -> Not used + * GPK0[3:6] SD_0_DATA[0:3](2) + * GPK1[3:6] SD_0_DATA[0:3](3) + * + * DDR 4-bit@26MHz at MMC4 + * GPK0[0] SD_4_CLK(3) + * GPK0[1] SD_4_CMD(3) + * GPK0[2] SD_4_CDn -> Not used + * GPK0[3:6] SD_4_DATA[0:3](3) + * GPK1[3:6] SD_4_DATA[4:7](4) + */ + for (i = 0; i < 7; i++) { + if (i == 2) + continue; + /* GPK0[0:6] special function 2 */ + s5p_gpio_cfg_pin(&gpio2->k0, i, GPIO_FUNC(0x2)); + /* GPK0[0:6] pull disable */ + s5p_gpio_set_pull(&gpio2->k0, i, GPIO_PULL_NONE); + /* GPK0[0:6] drv 4x */ + s5p_gpio_set_drv(&gpio2->k0, i, GPIO_DRV_4X); + } + + for (i = 3; i < 7; i++) { + /* GPK1[3:6] special function 3 */ + s5p_gpio_cfg_pin(&gpio2->k1, i, GPIO_FUNC(0x3)); + /* GPK1[3:6] pull disable */ + s5p_gpio_set_pull(&gpio2->k1, i, GPIO_PULL_NONE); + /* GPK1[3:6] drv 4x */ + s5p_gpio_set_drv(&gpio2->k1, i, GPIO_DRV_4X); + } + + /* + * MMC device init + * mmc0 : eMMC (8-bit buswidth) + * mmc2 : SD card (4-bit buswidth) + */ + err = s5p_mmc_init(0, 8); + + /* T-flash detect */ + s5p_gpio_cfg_pin(&gpio2->x3, 3, GPIO_IRQ); + s5p_gpio_set_pull(&gpio2->x3, 3, GPIO_PULL_UP); + + /* + * Check the T-flash detect pin + * GPX3[3] T-flash detect pin + */ + if (!s5p_gpio_get_value(&gpio2->x3, 3)) { + /* + * SD card GPIO: + * GPK2[0] SD_2_CLK(2) + * GPK2[1] SD_2_CMD(2) + * GPK2[2] SD_2_CDn -> Not used + * GPK2[3:6] SD_2_DATA[0:3](2) + */ + for (i = 0; i < 7; i++) { + if (i == 2) + continue; + /* GPK2[0:6] special function 2 */ + s5p_gpio_cfg_pin(&gpio2->k2, i, GPIO_FUNC(0x2)); + /* GPK2[0:6] pull disable */ + s5p_gpio_set_pull(&gpio2->k2, i, GPIO_PULL_NONE); + /* GPK2[0:6] drv 4x */ + s5p_gpio_set_drv(&gpio2->k2, i, GPIO_DRV_4X); + } + err = s5p_mmc_init(2, 4); + } + + return err; +} +#endif diff --git a/boards.cfg b/boards.cfg index 604becf..6ae4f3d 100644 --- a/boards.cfg +++ b/boards.cfg @@ -189,6 +189,7 @@ omap4_panda arm armv7 panda ti omap4_sdp4430 arm armv7 sdp4430 ti omap4 s5p_goni arm armv7 goni samsung s5pc1xx smdkc100 arm armv7 smdkc100 samsung s5pc1xx +exynos4_nuri arm armv7 nuri samsung s5pc2xx origen arm armv7 origen samsung s5pc2xx s5pc210_universal arm armv7 universal_c210 samsung s5pc2xx smdkv310 arm armv7 smdkv310 samsung s5pc2xx diff --git a/include/configs/exynos4_nuri.h b/include/configs/exynos4_nuri.h new file mode 100644 index 0000000..813b301 --- /dev/null +++ b/include/configs/exynos4_nuri.h @@ -0,0 +1,209 @@ +/* + * Copyright (C) 2011 Samsung Electronics + * Łukasz Majewski l.majewski@samsung.com + * + * Configuation settings for the SAMSUNG Universal (s5pc100) board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Configuration Options + * + */ +#define CONFIG_SAMSUNG /* in a SAMSUNG core */ +#define CONFIG_S5P /* which is in a S5P Family */ +#define CONFIG_S5PC210 /* which is in a S5PC210 */ +#define CONFIG_NURI /* working with NURI */ + +#define CONFIG_MACH_TYPE 3379 /* NURI mach type */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ + +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +/* Keep L2 Cache Disabled */ +#define CONFIG_SYS_L2CACHE_OFF 1 + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define CONFIG_SYS_TEXT_BASE 0x44800000 + +/* input clock of PLL: Universal has 24MHz input clock at S5PC210 */ +#define CONFIG_SYS_CLK_FREQ_C210 24000000 + +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_CMDLINE_TAG +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG +#define CONFIG_CMDLINE_EDITING + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (1 << 20)) + +/* select serial console configuration */ +#define CONFIG_SERIAL_MULTI +#define CONFIG_SERIAL2 /* use SERIAL 2 */ +#define CONFIG_BAUDRATE 115200 + +/* MMC */ +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC +#define CONFIG_S5P_MMC + +/* PWM */ +#define CONFIG_PWM + +/* It should define before config_cmd_default.h */ +#define CONFIG_SYS_NO_FLASH + +/* Command definition */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_MISC +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_NFS +#undef CONFIG_CMD_XIMG +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_MMC +#define CONFIG_CMD_FAT + +#define CONFIG_BOOTDELAY 2 +#define CONFIG_ZERO_BOOTDELAY_CHECK + +#define CONFIG_BOOTARGS "Please use defined boot" +#define CONFIG_BOOTCOMMAND "run mmcboot" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" + +#define CONFIG_BOOTBLOCK "10" +#define CONFIG_UBIBLOCK "9" + +#define CONFIG_ENV_UBIFS_OPTION " rootflags=bulk_read,no_chk_data_crc " + +#define CONFIG_ENV_COMMON_BOOT "${console} ${meminfo}" + +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +#define MBRPARTS_DEFAULT "20M(permanent)"\ + ",20M(boot)"\ + ",1G(system)"\ + ",100M(swap)"\ + ",-(UMS)\0" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootk=" \ + "run loaduimage; bootm 0x40007FC0\0" \ + "updatemmc=" \ + "mmc boot 0 1 1 1; mmc write 0 0x42008000 0 0x200;" \ + "mmc boot 0 1 1 0\0" \ + "updatebackup=" \ + "mmc boot 0 1 1 2; mmc write 0 0x42100000 0 0x200;" \ + "mmc boot 0 1 1 0\0" \ + "updatebootb=" \ + "mmc read 0 0x42100000 0x80 0x200; run updatebackup\0" \ + "lpj=lpj=3981312\0" \ + "nfsboot=" \ + "set bootargs root=/dev/nfs rw " \ + "nfsroot=${nfsroot},nolock,tcp " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:" \ + "${netmask}:generic:usb0:off " CONFIG_ENV_COMMON_BOOT \ + "; run bootk\0" \ + "ramfsboot=" \ + "set bootargs root=/dev/ram0 rw rootfstype=ext2 " \ + "${console} ${meminfo} " \ + "initrd=0x43000000,8M ramdisk=8192\0" \ + "mmcboot=" \ + "set bootargs root=/dev/mmcblk${mmcdev}p${mmcrootpart} " \ + "${lpj} rootwait ${console} ${meminfo} ${opts} ${lcdinfo}; " \ + "run loaduimage; bootm 0x40007FC0\0" \ + "bootchart=set opts init=/sbin/bootchartd; run bootcmd\0" \ + "boottrace=setenv opts initcall_debug; run bootcmd\0" \ + "mmcoops=mmc read 0 0x40000000 0x40 8; md 0x40000000 0x400\0" \ + "verify=n\0" \ + "rootfstype=ext4\0" \ + "console=" CONFIG_DEFAULT_CONSOLE \ + "mbrparts=" MBRPARTS_DEFAULT \ + "meminfo=crashkernel=32M@0x50000000\0" \ + "nfsroot=/nfsroot/arm\0" \ + "bootblock=" CONFIG_BOOTBLOCK "\0" \ + "ubiblock=" CONFIG_UBIBLOCK" \0" \ + "loaduimage=fatload mmc ${mmcdev}:${mmcbootpart} 0x40007FC0 uImage\0" \ + "mmcdev=0\0" \ + "mmcbootpart=2\0" \ + "mmcrootpart=5\0" \ + "opts=always_resume=1" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_PROMPT "Nuri # " +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) + +#define CONFIG_SYS_HZ 1000 + +/* valid baudrates */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* Stack sizes */ +#define CONFIG_STACKSIZE (256 << 10) /* regular stack 256KB */ + +/* Nuri has 2 banks of DRAM -> support bank swapping */ +#define CONFIG_NR_DRAM_BANKS 4 +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE /* LDDDR2 DMC 0 */ +#define PHYS_SDRAM_1_SIZE (256 << 20) /* 256 MB in CS 0 */ +#define PHYS_SDRAM_2 0x50000000 /* LPDDR2 DMC 1 */ +#define PHYS_SDRAM_2_SIZE (256 << 20) /* 256 MB in CS 0 */ +#define PHYS_SDRAM_3 0x60000000 +#define PHYS_SDRAM_3_SIZE (256 << 20) +#define PHYS_SDRAM_4 0x70000000 +#define PHYS_SDRAM_4_SIZE (256 << 20) + +#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ + +#define CONFIG_SYS_MONITOR_BASE 0x00000000 +#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 4096 +#define CONFIG_ENV_OFFSET ((32 - 4) << 10)/* 32KiB - 4KiB */ + +#define CONFIG_DOS_PARTITION + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - GENERATED_GBL_DATA_SIZE) + +#define CONFIG_SYS_CACHELINE_SIZE 32 + +#endif /* __CONFIG_H */
- Lowlevel setup for universal board based on S5PC210
- Copyright (C) 2010 Samsung Electronics
- Kyungmin Park kyungmin.park@samsung.com
- project.
- MA 02111-1307 USA
- Register usages:
- r5 has zero always
- r7 has GPIO part1 base 0x11400000
- r6 has GPIO part2 base 0x11000000
+lowlevel_init:
mov r11, lr
mov r5, #0
/* System Timer */
ldr r1, =0x5000
str r1, [r0, #0x0]
ldr r1, =0xffffffff
str r1, [r0, #0x8]
ldr r1, =0x49
str r1, [r0, #0x4]
ldr r1, [r0, #0x0]
str r1, [r0, #0x0]
ldr r1, [r0, #0x4]
str r1, [r0, #0x4]
str r5, [r0]
/* UART */
bl uart_asm_init
/* PMU init */
bl tzpc_init
mov lr, r11
mov pc, lr
nop
nop
nop
- uart_asm_init: Initialize UART's pins
+uart_asm_init:
mov r0, r7
ldr r1, =0x22222222
ldr r1, =0x00223322
ldr r1, [r0, #0x0]
str r1, [r0, #0x0]
ldr r1, [r0, #0x8]
str r1, [r0, #0x8]
ldr r1, [r0, #0x4]
str r1, [r0, #0x4]
mov pc, lr
nop
nop
nop
+system_clock_init:
ldr r1, =0x0101
str r1, [r0, r2]
/* wait ?us */
mov r1, #0x10000
+1: subs r1, r1, #1
bne 1b
* CLK_SRC_TOP0
ldr r1, =0x10000110
str r1, [r0, r2]
ldr r1, =0x0066666
str r1, [r0, r2]
ldr r1, =0x6666666
str r1, [r0, r2]
ldr r1, =0x0133730
str r1, [r0, r2]
ldr r1, =0x03
str r1, [r0, r2]
ldr r1, =0x13111113
str r1, [r0, r2]
ldr r1, =0x01010100
str r1, [r0, r2]
ldr r1, =0x13
str r1, [r0, r2]
ldr r1, =0x13
str r1, [r0, r2]
* CLK_DIV_TOP
ldr r1, =0x00005473
str r1, [r0, r2]
/* MMC[0:1] */
str r1, [r0, r2]
/* MMC[2:3] */
str r1, [r0, r2]
/* MMC4 */
str r1, [r0, r2]
/* UART[0:5] */
ldr r1, =0x774777
str r1, [r0, r2]
ldr r1, =0x8
str r1, [r0, r2]
/* PLL Setting */
ldr r1, =0x1C20
str r1, [r0, r2]
str r1, [r0, r2]
str r1, [r0, r2]
str r1, [r0, r2]
/* APLL */
ldr r1, =0x8000001c
str r1, [r0, r2]
str r1, [r0, r2]
/* MPLL */
ldr r1, =0x8000001C
str r1, [r0, r2]
str r1, [r0, r2]
/* EPLL */
ldr r1, =0x0
str r1, [r0, r2]
str r1, [r0, r2]
/* VPLL */
ldr r1, =0x11000400
str r1, [r0, r2]
str r1, [r0, r2]
* Turn off all
ldr r1, =0xFFF80000
str r1, [r0, r2]
/* Turn off all */
ldr r1, =0xFFFFFFC0
str r1, [r0, r2]
/* Turn off all */
ldr r1, =0xFFFFFFE0
str r1, [r0, r2]
/* Turn off all */
ldr r1, =0xFFFFFFFC
str r1, [r0, r2]
/* Turn off all */
ldr r1, =0xFFFFFC00
str r1, [r0, r2]
ldr r1, =0xFFFFFFF1
str r1, [r0, r2]
/* Turn off all */
ldr r1, =0xFFFFFFC0
str r1, [r0, r2]
ldr r1, =0xFFFAB8A3
str r1, [r0, r2]
/* Turn off all */
ldr r1, =0xFFFFFFFC
str r1, [r0, r2]
ldr r1, =0xF1FFFEFF
str r1, [r0, r2]
ldr r1, =0xFFFEFFFF
str r1, [r0, r2]
ldr r1, =0xFFFFFFD1
str r1, [r0, r2]
mov pc, lr
nop
nop
nop
+system_power_init:
ldr r1, [r0, r2]
str r1, [r0, r2]
/* Power Down */
add r2, r0, #0x3000
mov pc, lr
nop
nop
nop
+tzpc_init:
ldr r0, =0x10110000
mov r1, #0x0
str r1, [r0]
mov r1, #0xff
ldr r0, =0x10120000
mov r1, #0x0
str r1, [r0]
mov r1, #0xff
ldr r0, =0x10130000
mov r1, #0x0
str r1, [r0]
mov r1, #0xff
ldr r0, =0x10140000
mov r1, #0x0
str r1, [r0]
mov r1, #0xff
ldr r0, =0x10150000
mov r1, #0x0
str r1, [r0]
mov r1, #0xff
mov pc, lr
- Copyright (C) 2011 Samsung Electronics
- Minkyu Kang mk7.kang@samsung.com
- Łukasz Majewski l.majewski@samsung.com
- project.
- MA 02111-1307 USA
return board_rev;
gd->ram_size = \
please put ram size validation.
int hwrev = 0;
int i;
chcking */
udelay(10);
return hwrev;
+} +#endif
int i, err;
* eMMC GPIO:
if (i == 2)
continue;
* MMC device init
* SD card GPIO:
if (i == 2)
continue;
return err;
- Configuation settings for the SAMSUNG Universal (s5pc100) board.
- project.
- MA 02111-1307 USA
- High Level Configuration Options
Please use CONFIG_MACH_NURI instead of hard coding it. It is defined in ./arch/arm/include/asm/mach-types.h
",20M(boot)"\
",1G(system)"\
",100M(swap)"\
",-(UMS)\0"
"bootk=" \
"updatemmc=" \
"updatebackup=" \
"updatebootb=" \
"nfsboot=" \
"; run bootk\0" \
"ramfsboot=" \
"mmcboot=" \
"verify=n\0" \
uImage\0" \
"mmcdev=0\0" \
"mmcbootpart=2\0" \
"mmcrootpart=5\0" \
As per comment Nuri has 2 banks of DRAM, But configuration happens for 4 banks.
1.7.2.3
Chander Kashyap
Lukasz Majewski
