[U-Boot-Users] [PATCH] changes for IDS8247 board support
Patch proposed to support the IDS8247 board: - FCC2 is deactivated - FCC1 is activated - I2C is activated - Adapted for use with LIBFDT
Signed-off-by: Sergej Stepanov Sergej.Stepanov@ids.de --
diff --git a/board/ids8247/ids8247.c b/board/ids8247/ids8247.c index 19823a4..7804269 100644 --- a/board/ids8247/ids8247.c +++ b/board/ids8247/ids8247.c @@ -19,12 +19,19 @@ * along with this program; if not, write to the Free Software * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA + * */
#include <common.h> #include <ioports.h> #include <mpc8260.h>
+#if defined(CONFIG_OF_LIBFDT) +#include <libfdt.h> +#include <libfdt_env.h> +#include <fdt_support.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
/* @@ -38,12 +45,12 @@ const iop_conf_t iop_conf_tab[4][32] = {
/* Port A configuration */ { /* conf ppar psor pdir podr pdat */ - /* PA31 */ { 0, 1, 1, 0, 0, 0 }, /* FCC1 COL */ - /* PA30 */ { 0, 1, 1, 0, 0, 0 }, /* FCC1 CRS */ - /* PA29 */ { 0, 1, 1, 1, 0, 0 }, /* FCC1 TXER */ - /* PA28 */ { 0, 1, 1, 1, 0, 0 }, /* FCC1 TXEN */ - /* PA27 */ { 0, 1, 1, 0, 0, 0 }, /* FCC1 RXDV */ - /* PA26 */ { 0, 1, 1, 0, 0, 0 }, /* FCC1 RXER */ + /* PA31 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 COL */ + /* PA30 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 CRS */ + /* PA29 */ { 1, 1, 1, 1, 0, 0 }, /* FCC1 TXER */ + /* PA28 */ { 1, 1, 1, 1, 0, 0 }, /* FCC1 TXEN */ + /* PA27 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 RXDV */ + /* PA26 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 RXER */ /* PA25 */ { 0, 0, 0, 0, 1, 0 }, /* 8247_P0 */ #if defined(CONFIG_SOFT_I2C) /* PA24 */ { 1, 0, 0, 0, 1, 1 }, /* I2C_SDA2 */ @@ -53,14 +60,14 @@ const iop_conf_t iop_conf_tab[4][32] = { /* PA23 */ { 0, 0, 0, 1, 0, 0 }, /* PA23 */ #endif /* PA22 */ { 0, 0, 0, 0, 1, 0 }, /* SMC2_DCD */ - /* PA21 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 TXD3 */ - /* PA20 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 TXD2 */ - /* PA19 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 TXD1 */ - /* PA18 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 TXD0 */ - /* PA17 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 RXD0 */ - /* PA16 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 RXD1 */ - /* PA15 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 RXD2 */ - /* PA14 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 RXD3 */ + /* PA21 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD3 */ + /* PA20 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD2 */ + /* PA19 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD1 */ + /* PA18 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD0 */ + /* PA17 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD0 */ + /* PA16 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD1 */ + /* PA15 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD2 */ + /* PA14 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD3 */ /* PA13 */ { 0, 0, 0, 1, 1, 0 }, /* SMC2_RTS */ /* PA12 */ { 0, 0, 0, 0, 1, 0 }, /* SMC2_CTS */ /* PA11 */ { 0, 0, 0, 1, 1, 0 }, /* SMC2_DTR */ @@ -79,20 +86,20 @@ const iop_conf_t iop_conf_tab[4][32] = {
/* Port B configuration */ { /* conf ppar psor pdir podr pdat */ - /* PB31 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TX_ER */ - /* PB30 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_DV */ - /* PB29 */ { 1, 1, 1, 1, 0, 0 }, /* FCC2 MII TX_EN */ - /* PB28 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_ER */ - /* PB27 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII COL */ - /* PB26 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII CRS */ - /* PB25 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[3] */ - /* PB24 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[2] */ - /* PB23 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[1] */ - /* PB22 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[0] */ - /* PB21 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[0] */ - /* PB20 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[1] */ - /* PB19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[2] */ - /* PB18 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[3] */ + /* PB31 */ { 0, 1, 0, 1, 0, 0 }, /* FCC2 MII TX_ER */ + /* PB30 */ { 0, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_DV */ + /* PB29 */ { 0, 1, 1, 1, 0, 0 }, /* FCC2 MII TX_EN */ + /* PB28 */ { 0, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_ER */ + /* PB27 */ { 0, 1, 0, 0, 0, 0 }, /* FCC2 MII COL */ + /* PB26 */ { 0, 1, 0, 0, 0, 0 }, /* FCC2 MII CRS */ + /* PB25 */ { 0, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[3] */ + /* PB24 */ { 0, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[2] */ + /* PB23 */ { 0, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[1] */ + /* PB22 */ { 0, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[0] */ + /* PB21 */ { 0, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[0] */ + /* PB20 */ { 0, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[1] */ + /* PB19 */ { 0, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[2] */ + /* PB18 */ { 0, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[3] */ /* PB17 */ { 0, 0, 0, 0, 0, 0 }, /* PB17 */ /* PB16 */ { 0, 0, 0, 0, 0, 0 }, /* PB16 */ /* PB15 */ { 0, 0, 0, 0, 0, 0 }, /* PB15 */ @@ -123,8 +130,8 @@ const iop_conf_t iop_conf_tab[4][32] = { /* PC26 */ { 0, 0, 0, 1, 0, 0 }, /* PC26 */ /* PC25 */ { 0, 1, 1, 0, 0, 0 }, /* SYNC_IN */ /* PC24 */ { 0, 0, 0, 1, 0, 0 }, /* PC24 */ - /* PC23 */ { 0, 1, 0, 1, 0, 0 }, /* ATMTFCLK */ - /* PC22 */ { 0, 1, 0, 0, 0, 0 }, /* ATMRFCLK */ + /* PC23 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII TX_CLK */ + /* PC22 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII RX_CLK */ /* PC21 */ { 0, 1, 0, 0, 0, 0 }, /* SCC1 EN RXCLK */ /* PC20 */ { 0, 1, 0, 0, 0, 0 }, /* SCC1 EN TXCLK */ /* PC19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_CLK */ @@ -180,7 +187,7 @@ const iop_conf_t iop_conf_tab[4][32] = { /* PD10 */ { 0, 0, 0, 0, 0, 0 }, /* PD10 */ /* PD9 */ { 0, 0, 0, 0, 0, 0 }, /* PD9 */ /* PD8 */ { 0, 0, 0, 0, 0, 0 }, /* PD8 */ - /* PD7 */ { 0, 0, 0, 1, 0, 1 }, /* MII_MDIO */ + /* PD7 */ { 1, 0, 0, 1, 0, 1 }, /* MII_MDIO */ /* PD6 */ { 0, 0, 0, 1, 0, 1 }, /* PD6 */ /* PD5 */ { 0, 0, 0, 1, 0, 1 }, /* PD5 */ /* PD4 */ { 0, 0, 0, 1, 0, 1 }, /* PD4 */ @@ -224,7 +231,7 @@ static long int try_init (volatile memctl8260_t * memctl, ulong sdmr, * mapped by the controller. That means, that the initial mapping has * to be (at least) twice as large as the maximum expected size. */ - maxsize = (1 + (~orx | 0x7fff)) / 2; + maxsize = (1 + (~orx | 0x7fff))/* / 2*/;
sdmr_ptr = &memctl->memc_psdmr;OF Device tree is used orx_ptr = &memctl->memc_or2; @@ -315,4 +322,39 @@ nand_init (void) printf ("%4lu MB\n", totlen >>20); }
-#endif +#endif /* CFG_CMD_NAND */ + +#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) +/* + * update "memory" property in the blob + */ +void ft_blob_update(void *blob, bd_t *bd) +{ + int ret, nodeoffset = 0; + ulong memory_data[2] = {0}; + + memory_data[0] = cpu_to_be32(bd->bi_memstart); + memory_data[1] = cpu_to_be32(bd->bi_memsize);OF Device tree is used + + nodeoffset = fdt_find_node_by_path (blob, "/memory"); + if (nodeoffset >= 0) { + ret = fdt_setprop(blob, nodeoffset, "reg", memory_data, + sizeof(memory_data)); + if (ret < 0) + printf("ft_blob_update): cannot set /memory/reg " + "property err:%s\n", fdt_strerror(ret)); + } + else { + /* memory node is required in dts */ + printf("ft_blob_update(): cannot find /memory node " + "err:%s\n", fdt_strerror(nodeoffset)); + } +} + +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup( blob, bd); + ft_blob_update(blob, bd); OF Device tree is used +} +#endif /* defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) */ + diff --git a/include/configs/IDS8247.h b/include/configs/IDS8247.h index 85d2bb3..c78fe05 100644 --- a/include/configs/IDS8247.h +++ b/include/configs/IDS8247.h @@ -19,6 +19,14 @@ * along with this program; if not, write to the Free Software * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA + * + * For IDS8247 platform + * - FCC1 is activated + * - FCC2 is deactivated + * - I2C is activated + * - adopted for using with CONFIG_OF_LIBFDT + * Sergej Stepanov, IDS GmbH, Germany, Sergej.Stepanov@ids.de + * */
/* @@ -120,6 +128,17 @@
#define CFG_NS16550_COM1 (CFG_UART_BASE + 0x8000)
+ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 + +#define OF_CPU "PowerPC,8247@0" +#define OF_SOC "soc@f0000000" +#define OF_TBCLK (bd->bi_busfreq / 4) +#define OF_STDOUT_PATH "/soc@f0000000/serial8250@e0008000" + + /* * select ethernet configuration * @@ -133,20 +152,21 @@ #undef CONFIG_ETHER_ON_SCC /* define if ether on SCC */ #define CONFIG_ETHER_ON_FCC /* define if ether on FCC */ #undef CONFIG_ETHER_NONE /* define if ether on something else */ -#define CONFIG_ETHER_INDEX 2 /* which SCC/FCC channel for ethernet */ +#define CONFIG_ETHER_INDEX 1 /* which SCC/FCC channel for ethernet */ +#define CONFIG_ETHER_ON_FCC1 +#define FCC_ENET
/* - * - Rx-CLK is CLK13 - * - Tx-CLK is CLK14 + * - Rx-CLK is CLK10 + * - Tx-CLK is CLK9 * - RAM for BD/Buffers is on the 60x Bus (see 28-13) * - Enable Full Duplex in FSMR */ -# define CFG_CMXFCR_MASK (CMXFCR_FC2|CMXFCR_RF2CS_MSK|CMXFCR_TF2CS_MSK) -# define CFG_CMXFCR_VALUE (CMXFCR_RF2CS_CLK13|CMXFCR_TF2CS_CLK14) +# define CFG_CMXFCR_MASK (CMXFCR_FC1|CMXFCR_RF1CS_MSK|CMXFCR_TF1CS_MSK) +# define CFG_CMXFCR_VALUE (CMXFCR_RF1CS_CLK10|CMXFCR_TF1CS_CLK9) # define CFG_CPMFCR_RAMTYPE 0 # define CFG_FCC_PSMR (FCC_PSMR_FDE|FCC_PSMR_LPB)
- /* system clock rate (CLKIN) - equal to the 60x and local bus speed */ #define CONFIG_8260_CLKIN 66666666 /* in Hz */
@@ -166,6 +186,8 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
+#define CONFIG_RTC_PCF8563 +#define CFG_I2C_RTC_ADDR 0x51
/* * Command line configuration. @@ -211,7 +233,10 @@ */ #define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */
- +#define CFG_FLASH_CFI /* The flash is CFI compatible */ +#define CFG_FLASH_CFI_DRIVER /* Use common CFI driver */ +#define CFG_FLASH_BANKS_LIST { 0xFF800000 } +#define CFG_MAX_FLASH_BANKS_DETECT 1 /* What should the base address of the main FLASH be and how big is * it (in MBytes)? This must contain TEXT_BASE from board/ids8247/config.mk * The main FLASH is whichever is connected to *CS0. @@ -227,7 +252,7 @@ * FLASH organization */ #define CFG_MAX_FLASH_BANKS 1 /* max num of memory banks */ -#define CFG_MAX_FLASH_SECT 64 /* max num of sects on one chip */ +#define CFG_MAX_FLASH_SECT 128 /* max num of sects on one chip */
#define CFG_FLASH_ERASE_TOUT 240000 /* Flash Erase Timeout (in ms) */ #define CFG_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (in ms) */ @@ -511,12 +536,12 @@ */ #define CFG_OR2 ((~(CFG_GLOBAL_SDRAM_LIMIT-1) & ORxS_SDAM_MSK) |\ ORxS_BPD_4 |\ - ORxS_ROWST_PBI0_A10 |\ + ORxS_ROWST_PBI0_A9 |\ ORxS_NUMR_12)
-#define CFG_PSDMR (PSDMR_SDAM_A13_IS_A5 |\ +#define CFG_PSDMR (PSDMR_SDAM_A14_IS_A5 |\ PSDMR_BSMA_A15_A17 |\ - PSDMR_SDA10_PBI0_A11 |\ + PSDMR_SDA10_PBI0_A10 |\ PSDMR_RFRC_5_CLK |\ PSDMR_PRETOACT_2W |\ PSDMR_ACTTORW_2W |\
Sergej Stepanov
