[U-Boot] please pull u-boot-samsung master
Dear Tom,
The following changes since commit 2547e91dc15e5203e15d4ebde9172174743b14a7:
tegra: Indicate that binman makes all three output files (2018-07-26 15:49:40 -0400)
git://git.denx.de/u-boot-samsung master
for you to fetch changes up to 972d8576d225c5fa8187ba09306fd439967ca7d8:
arm: spring: fix alias of mmc correctly (2018-08-06 11:24:48 +0900)
---------------------------------------------------------------- Guillaume GARDET (1): snow: set fdtfile
Lukasz Majewski (8): ARM: dw_mmc: Exclude dwmci Exynos priv_data allocation from exynos_dwmci_get_config() ARM: Odroid XU3: config: Disable SDHCI support in the Odroid XU3 ARM: Odroid XU3: Enable driver model support for MMC (DM_MMC) ARM: Odroid XU3: Fix autoboot.cmd to use ${mmcbootdev} instead of hardcoded 0 ARM: Odroid XU3: Adjust BOOT_TARGET_DEVICES to allow booting from SD card (mmc2) ARM: Odroid XU3: MAINTAINERS: Add a co-maintainer for OdroidXU3 ARM: Odroid XU3: Fix the dwmci_exynos *priv data assignment for DM_MMC (sdr_timing) ARM: Odroid XU3: Modify exynos dw_mmc driver to support Odroid XU3 in DM MMC
Minkyu Kang (3): arm: exynos4: fix warning of dts arm: exynos5: fix warning of dts arm: spring: fix alias of mmc correctly
Vagrant Cascadian (4): arm: odroid: Use standard environment variable names kernel_addr_r, ramdisk_addr_r and fdt_addr_r. arm: odroid: Increase default env size in preparation for distro_bootcmd. arm: odroid: Enable distro_bootcmd support. arm: odroid: Inherit default value for bootdelay from distro_bootcmd.
arch/arm/dts/exynos4210-pinctrl-uboot.dtsi | 4 ---- arch/arm/dts/exynos4210-universal_c210.dts | 2 -- arch/arm/dts/exynos4x12-pinctrl-uboot.dtsi | 4 ---- arch/arm/dts/exynos5.dtsi | 2 -- arch/arm/dts/exynos5250-pinctrl-uboot.dtsi | 4 ---- arch/arm/dts/exynos5250-spring.dts | 2 +- arch/arm/dts/exynos54xx-pinctrl-uboot.dtsi | 8 -------- board/samsung/common/bootscripts/autoboot.cmd | 6 +++--- board/samsung/smdk5420/MAINTAINERS | 1 + configs/odroid-xu3_defconfig | 3 +-- drivers/mmc/exynos_dw_mmc.c | 37 +++++++++++++++++++++---------------- include/configs/exynos5-common.h | 1 + include/configs/odroid.h | 36 ++++++++++++++++++++---------------- include/configs/snow.h | 3 +++ 14 files changed, 51 insertions(+), 62 deletions(-)
On Wed, Aug 08, 2018 at 09:37:36AM +0900, Minkyu Kang wrote:
Dear Tom,
Minkyu Kang
