[PATCH v3] arm: mvebu: Add support for Thecus N2350 (Armada 385) board
Thecus N2350 is a NAS based on Marvell Armada 385 SoC.
Specification:
- Processor: Marvel MV88F6820 Dual Core at 1GHz - 1 GiB DDR4 RAM - 4MB Macronix mx25l3205d SPI flash - 512MB Hynix H27U4G8F2DTR-BC NAND flash - I2C - 2x USB 3.0 - 1x GBE LAN port (PHY: Marvell 88E1510) - 2x SATA (hot swap slots) - 3x buttons - 10x LEDS - serial console
Signed-off-by: Tony Dinh mibodhi@gmail.com ---
Changes in v3: - Add missing DTS file path in MAINTAINERS file - Remove "common.h" in board file - Remove CFG_I2C_MVTWSI_BASE0 in include header file - Cleanup unecessary comments in include header file
Changes in v2: - Use node pointers already defined from armada-38x.dtsi in this board DTS - Remove extra compatible attributes in this board DTS - Remove unnecessary armada-385-thecus-n2350-u-boot.dtsi - Remove unnecessary check_board() function in board file - Remove unnecessary "default false" for DDR4 in arch/arm/mach-mvebu/Kconfig - Use "rootfs" as partition name for NAND partition - Various DTS naming convention correction
arch/arm/dts/Makefile | 1 + arch/arm/dts/armada-385-thecus-n2350.dts | 446 +++++++++++++++++++++++ arch/arm/mach-mvebu/Kconfig | 11 + board/thecus/n2350/MAINTAINERS | 7 + board/thecus/n2350/Makefile | 6 + board/thecus/n2350/n2350.c | 126 +++++++ configs/n2350_defconfig | 93 +++++ include/configs/n2350.h | 56 +++ 8 files changed, 746 insertions(+) create mode 100644 arch/arm/dts/armada-385-thecus-n2350.dts create mode 100644 board/thecus/n2350/MAINTAINERS create mode 100644 board/thecus/n2350/Makefile create mode 100644 board/thecus/n2350/n2350.c create mode 100644 configs/n2350_defconfig create mode 100644 include/configs/n2350.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 3ecd6a86e9..c5d1825a3b 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -245,6 +245,7 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-385-atl-x530.dtb \ armada-385-atl-x530DP.dtb \ armada-385-db-88f6820-amc.dtb \ + armada-385-thecus-n2350.dtb \ armada-385-turris-omnia.dtb \ armada-388-clearfog.dtb \ armada-388-gp.dtb \ diff --git a/arch/arm/dts/armada-385-thecus-n2350.dts b/arch/arm/dts/armada-385-thecus-n2350.dts new file mode 100644 index 0000000000..fc29c4d25a --- /dev/null +++ b/arch/arm/dts/armada-385-thecus-n2350.dts @@ -0,0 +1,446 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * Device Tree file for Thecus N2350 board + * + * Copyright (C) 2018-2023 Tony Dinh mibodhi@gmail.com + * Copyright (C) 2018 Manuel Jung manuel.jung@hotmail.com + */ + +/dts-v1/; +#include <dt-bindings/input/input.h> +#include <dt-bindings/gpio/gpio.h> +#include "armada-385.dtsi" + +/ { + model = "Thecus N2350"; + compatible = "thecus,n2350", "marvell,armada385"; + + aliases { + ethernet0 = ð0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory { + device_type = "memory"; + reg = <0x00000000 0x40000000>; /* 1GB */ + }; + + soc { + ranges = <MBUS_ID(0xf0, 0x01) 0 0xf1000000 0x100000 + MBUS_ID(0x01, 0x1d) 0 0xfff00000 0x100000 + MBUS_ID(0x09, 0x19) 0 0xf1100000 0x10000 + MBUS_ID(0x09, 0x15) 0 0xf1110000 0x10000 + MBUS_ID(0x0c, 0x04) 0 0xf1200000 0x100000>; + + }; + + usb3_0_phy: usb3_0_phy { + compatible = "usb-nop-xceiv"; + vcc-supply = <&usb3_0_power>; + }; + + usb3_1_phy: usb3_1_phy { + compatible = "usb-nop-xceiv"; + vcc-supply = <&usb3_1_power>; + }; + + gpio-keys { + compatible = "gpio-keys"; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-0 = <&pmx_power_button &pmx_copy_button &pmx_reset_button>; + pinctrl-names = "default"; + + button@1 { + label = "Power Button"; + linux,code = <KEY_POWER>; + gpios = <&gpio1 17 GPIO_ACTIVE_HIGH>; + }; + + button@2 { + label = "Copy Button"; + linux,code = <KEY_COPY>; + gpios = <&gpio1 20 GPIO_ACTIVE_HIGH>; + }; + + button@3 { + label = "Reset Button"; + linux,code = <KEY_RESTART>; + gpios = <&gpio1 18 GPIO_ACTIVE_HIGH>; + }; + }; + + gpio-leds { + compatible = "gpio-leds"; + pinctrl-0 = <&pmx_sata1_white_led + &pmx_sata1_red_led + &pmx_sata2_white_led + &pmx_sata2_red_led + &pmx_sys_white_led + &pmx_sys_red_led + &pmx_pwr_blue_led + &pmx_pwr_red_led + &pmx_usb_white_led + &pmx_usb_red_led>; + + pinctrl-names = "default"; + + white_sata1 { + label = "n2350:white:sata1"; + gpios = <&gpio0 20 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "ide-disk1"; + }; + + red_sata1 { + label = "n2350:red:sata1"; + gpios = <&gpio1 14 GPIO_ACTIVE_HIGH>; + }; + + white-sata2 { + label = "n2350:white:sata2"; + gpios = <&gpio0 19 GPIO_ACTIVE_HIGH>; + }; + + red-sata2 { + label = "n2350:red:sata2"; + gpios = <&gpio1 15 GPIO_ACTIVE_HIGH>; + }; + + white-sys { + label = "n2350:white:sys"; + gpios = <&gpio0 14 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "default-on"; + }; + + red-sys { + label = "n2350:red:sys"; + gpios = <&gpio0 15 GPIO_ACTIVE_HIGH>; + }; + + blue-pwr { + label = "n2350:blue:pwr"; + gpios = <&gpio1 11 GPIO_ACTIVE_HIGH>; + }; + + red-pwr { + label = "n2350:red:pwr"; + gpios = <&gpio0 18 GPIO_ACTIVE_HIGH>; + }; + + white-usb { + label = "n2350:white:usb"; + gpios = <&gpio0 16 GPIO_ACTIVE_HIGH>; + }; + + red-usb { + label = "n2350:red:usb"; + gpios = <&gpio0 17 GPIO_ACTIVE_HIGH>; + }; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + usb3_0_power: regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "USB3_0_Power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + gpio = <&gpio0 21 GPIO_ACTIVE_HIGH>; + }; + + usb3_1_power: regulator@2 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "USB3_1_Power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + gpio = <&gpio0 24 GPIO_ACTIVE_HIGH>; + }; + + reg_sata0: regulator@3 { + compatible = "regulator-fixed"; + regulator-name = "pwr_en_sata0"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + gpio = <&gpio1 12 GPIO_ACTIVE_HIGH>; + }; + + reg_5v_sata0: v5-sata0 { + compatible = "regulator-fixed"; + regulator-name = "v5.0-sata0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <®_sata0>; + }; + + reg_12v_sata0: v12-sata0 { + compatible = "regulator-fixed"; + regulator-name = "v12.0-sata0"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + vin-supply = <®_sata0>; + }; + + reg_sata1: regulator@4 { + regulator-name = "pwr_en_sata1"; + compatible = "regulator-fixed"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + gpio = <&gpio1 13 GPIO_ACTIVE_HIGH>; + }; + + reg_5v_sata1: v5-sata1 { + compatible = "regulator-fixed"; + regulator-name = "v5.0-sata1"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <®_sata1>; + }; + + reg_12v_sata1: v12-sata1 { + compatible = "regulator-fixed"; + regulator-name = "v12.0-sata1"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + vin-supply = <®_sata1>; + }; + + }; + + gpio-poweroff { + compatible = "gpio-poweroff"; + pinctrl-0 = <&pmx_pwr_off>; + pinctrl-names = "default"; + gpios = <&gpio1 22 GPIO_ACTIVE_HIGH>; + }; + +}; + +&ahci0 { + status = "okay"; +}; + +&bm { + status = "okay"; +}; + +&bm_bppi { + status = "okay"; +}; + +ð0 { + status = "okay"; + phy = <&phy0>; + phy-mode = "sgmii"; + buffer-manager = <&bm>; + bm,pool-long = <0>; + bm,pool-short = <1>; +}; + +&i2c0 { + status = "okay"; + clock-frequency = <100000>; +}; + +&i2c1 { + status = "okay"; + clock-frequency = <100000>; +}; + +&mdio { + phy0: ethernet-phy@0 { + reg = <1>; + }; +}; + +&nand_controller { + status = "okay"; + + nand@0 { + status = "okay"; + reg = <0>; + label = "pxa3xx_nand-0"; + nand-rb = <0>; + marvell,nand-keep-config; + nand-on-flash-bbt; + nand-ecc-strength = <4>; + nand-ecc-step-size = <512>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "rootfs"; + reg = <0x00000000 0x20000000>; + }; + + }; + }; +}; + +&pciec { + status = "okay"; + /* + * The two PCIe units are accessible through + * standard PCIe slots on the board. + */ + pcie@1,0 { + /* Port 0, Lane 0 */ + status = "okay"; + }; + pcie@2,0 { + /* Port 1, Lane 0 */ + status = "okay"; + }; +}; + +&pinctrl { + pinctrl-names = "default"; + + pmx_power_button: pmx-power-button { + marvell,pins = "mpp49"; + marvell,function = "gpio"; + }; + + pmx_copy_button: pmx-copy-button { + marvell,pins = "mpp52"; + marvell,function = "gpio"; + }; + + pmx_reset_button: pmx-reset-button { + marvell,pins = "mpp50"; + marvell,function = "gpio"; + }; + + pmx_sata1_white_led: pmx-sata1-white-led { + marvell,pins = "mpp20"; + marvell,function = "gpio"; + }; + + pmx_sata1_red_led: pmx-sata1-red-led { + marvell,pins = "mpp46"; + marvell,function = "gpio"; + }; + + pmx_sata2_white_led: pmx-sata2-white-led { + marvell,pins = "mpp19"; + marvell,function = "gpio"; + }; + + pmx_sata2_red_led: pmx-sata2-red-led { + marvell,pins = "mpp47"; + marvell,function = "gpio"; + }; + + pmx_sys_white_led: pmx-sys-white-led { + marvell,pins = "mpp14"; + marvell,function = "gpio"; + }; + + pmx_sys_red_led: pmx-sys-red-led { + marvell,pins = "mpp15"; + marvell,function = "gpio"; + }; + + pmx_buzzer: pmx-buzzer { + marvell,pins = "mpp51"; + marvell,function = "gpio"; + }; + + pmx_pwr_off: pmx-pwr-off { + marvell,pins = "mpp54"; + marvell,function = "gpio"; + }; + + pmx_pwr_blue_led: pmx-pwr-blue-led { + marvell,pins = "mpp43"; + marvell,function = "gpio"; + }; + + pmx_pwr_red_led: pmx-pwr-red-led { + marvell,pins = "mpp18"; + marvell,function = "gpio"; + }; + + pmx_usb_white_led: pmx-usb-white-led { + marvell,pins = "mpp16"; + marvell,function = "gpio"; + }; + + pmx_usb_red_led: pmx-usb-red-led { + marvell,pins = "mpp17"; + marvell,function = "gpio"; + }; +}; + +&sdhci { + broken-cd; + wp-inverted; + bus-width = <8>; + status = "okay"; + no-1-8-v; +}; + +&spi1 { + pinctrl-names = "default"; + pinctrl-0 = <&spi1_pins>; + status = "okay"; + + /* spi: 4M Flash Macronix MX25L3205D */ + spi-flash@0 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "macronix,mx25l3205d", "jedec,spi-nor"; + reg = <0>; + + spi-max-frequency = <108000000>; + spi-cpha; + + partition@0 { + label = "u-boot"; + reg = <0x00000000 0x00100000>; + }; + + partition@100000 { + label = "u-boot-env"; + reg = <0x00100000 0x00010000>; + }; + }; +}; + +&uart0 { + status = "okay"; +}; + +&usb0 { + status = "okay"; +}; + +&usb3_0 { + status = "okay"; +}; + +&usb3_1 { + status = "okay"; +}; diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 594e9a03d9..f829e40945 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -97,6 +97,9 @@ config 88F6820 config CUSTOMER_BOARD_SUPPORT bool
+config DDR4 + bool "Support Marvell DDR4 Training driver" + choice prompt "Armada XP/375/38x/3700/7K/8K/Alleycat-5 board select" optional @@ -175,6 +178,11 @@ config TARGET_MAXBCM select BOARD_ECC_SUPPORT select MV78460
+config TARGET_N2350 + bool "Support Thecus N2350" + select 88F6820 + select DDR4 + config TARGET_THEADORABLE bool "Support theadorable Armada XP" select BOARD_LATE_INIT if USB @@ -257,6 +265,7 @@ config SYS_BOARD default "db-mv784mp-gp" if TARGET_DB_MV784MP_GP default "ds414" if TARGET_DS414 default "maxbcm" if TARGET_MAXBCM + default "n2350" if TARGET_N2350 default "theadorable" if TARGET_THEADORABLE default "a38x" if TARGET_CONTROLCENTERDC default "x530" if TARGET_X530 @@ -276,6 +285,7 @@ config SYS_CONFIG_NAME default "db-mv784mp-gp" if TARGET_DB_MV784MP_GP default "ds414" if TARGET_DS414 default "maxbcm" if TARGET_MAXBCM + default "n2350" if TARGET_N2350 default "theadorable" if TARGET_THEADORABLE default "turris_omnia" if TARGET_TURRIS_OMNIA default "turris_mox" if TARGET_TURRIS_MOX @@ -298,6 +308,7 @@ config SYS_VENDOR default "solidrun" if TARGET_CLEARFOG default "kobol" if TARGET_HELIOS4 default "Synology" if TARGET_DS414 + default "thecus" if TARGET_N2350 default "CZ.NIC" if TARGET_TURRIS_OMNIA default "CZ.NIC" if TARGET_TURRIS_MOX default "gdsys" if TARGET_CONTROLCENTERDC diff --git a/board/thecus/n2350/MAINTAINERS b/board/thecus/n2350/MAINTAINERS new file mode 100644 index 0000000000..2b8774f8fb --- /dev/null +++ b/board/thecus/n2350/MAINTAINERS @@ -0,0 +1,7 @@ +N2350 BOARD +M: Tony Dinh mibodhi@gmail.com +S: Maintained +F: arch/arm/dts/armada-385-thecus-n2350.dts +F: board/thecus/n2350/ +F: include/configs/n2350.h +F: configs/n2350_defconfig diff --git a/board/thecus/n2350/Makefile b/board/thecus/n2350/Makefile new file mode 100644 index 0000000000..b220bb1925 --- /dev/null +++ b/board/thecus/n2350/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2023 Tony Dinh mibodhi@gmail.com +# + +obj-y := n2350.o diff --git a/board/thecus/n2350/n2350.c b/board/thecus/n2350/n2350.c new file mode 100644 index 0000000000..4cfdfba662 --- /dev/null +++ b/board/thecus/n2350/n2350.c @@ -0,0 +1,126 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023 Tony Dinh mibodhi@gmail.com + * + */ + +#include <i2c.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/soc.h> +#include <linux/bitops.h> + +#include "../drivers/ddr/marvell/a38x/ddr3_init.h" +#include <../serdes/a38x/high_speed_env_spec.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Those N2350_GPP_xx values and defines in board_serdes_map, and board_topology_map + * are taken from the Marvell U-Boot version "u-boot-a38x-2015T1_p18_Thecus" + */ + +#define N2350_GPP_OUT_ENA_LOW (~(BIT(20) | BIT(21) | BIT(24))) +#define N2350_GPP_OUT_ENA_MID (~(BIT(12) | BIT(13) | BIT(16) | BIT(19) | BIT(22))) +#define N2350_GPP_OUT_VAL_LOW 0x1200000 +#define N2350_GPP_OUT_VAL_MID 0x1001 +#define N2350_GPP_POL_LOW 0x0 +#define N2350_GPP_POL_MID 0x0 + +static struct serdes_map board_serdes_map[] = { + { SGMII0, SERDES_SPEED_1_25_GBPS, SERDES_DEFAULT_MODE, 0, 0}, + { SATA0, SERDES_SPEED_3_GBPS, SERDES_DEFAULT_MODE, 0, 0}, + { SATA1, SERDES_SPEED_3_GBPS, SERDES_DEFAULT_MODE, 0, 0}, + { DEFAULT_SERDES, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0}, + { USB3_HOST0, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0}, + { USB3_HOST1, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0}, +}; + +int hws_board_topology_load(struct serdes_map **serdes_map_array, u8 *count) +{ + *serdes_map_array = board_serdes_map; + *count = ARRAY_SIZE(board_serdes_map); + return 0; +} + +/* + * Define the DDR layout / topology here in the board file. This will + * be used by the DDR4 init code in the SPL U-Boot version to configure + * the DDR4 controller. + */ + +static struct mv_ddr_topology_map board_topology_map = { + DEBUG_LEVEL_ERROR, + 0x1, /* active interfaces */ + /* cs_mask, mirror, dqs_swap, ck_swap X PUPs */ + { { { {0x1, 0, 0, 0}, + {0x1, 0, 0, 0}, + {0x1, 0, 0, 0}, + {0x1, 0, 0, 0}, + {0x1, 0, 0, 0} }, + SPEED_BIN_DDR_1866L, /* speed_bin */ + MV_DDR_DEV_WIDTH_16BIT, /* memory_width - 16 bits */ + MV_DDR_DIE_CAP_4GBIT, /* mem_size - N2350 board has 2x512MB DRAM banks */ + MV_DDR_FREQ_800, /* frequency */ + 0, 0, /* cas_wl cas_l */ + MV_DDR_TEMP_LOW, /* temperature */ + MV_DDR_TIM_DEFAULT} }, /* timing */ + BUS_MASK_32BIT, /* Busses mask */ + MV_DDR_CFG_DEFAULT, /* ddr configuration data source */ + NOT_COMBINED, /* ddr twin-die combined */ + { {0} }, /* raw spd data */ + {0} /* timing parameters */ +}; + +struct mv_ddr_topology_map *mv_ddr_topology_map_get(void) +{ + /* Return the board topology as defined in the board code */ + return &board_topology_map; +} + +int board_early_init_f(void) +{ + /* Those MPP values are taken from the Marvell U-Boot version + * "u-boot-a38x-2015T1_p18_Thecus" + */ + + /* Configure MPP */ + writel(0x50111111, MVEBU_MPP_BASE + 0x00); /* MPP0_7 */ + writel(0x00555555, MVEBU_MPP_BASE + 0x04); /* MPP8_15 */ + writel(0x55000000, MVEBU_MPP_BASE + 0x08); /* MPP16_23 */ + writel(0x05050050, MVEBU_MPP_BASE + 0x0c); /* MPP24_31 */ + writel(0x05555555, MVEBU_MPP_BASE + 0x10); /* MPP32_39 */ + writel(0x00000565, MVEBU_MPP_BASE + 0x14); /* MPP40_47 */ + writel(0x00000000, MVEBU_MPP_BASE + 0x18); /* MPP48_55 */ + writel(0x00004444, MVEBU_MPP_BASE + 0x1c); /* MPP56_63 */ + + /* Set GPP Out value */ + writel(N2350_GPP_OUT_VAL_LOW, MVEBU_GPIO0_BASE + 0x00); + writel(N2350_GPP_OUT_VAL_MID, MVEBU_GPIO1_BASE + 0x00); + + /* Set GPP Polarity */ + writel(N2350_GPP_POL_LOW, MVEBU_GPIO0_BASE + 0x0c); + writel(N2350_GPP_POL_MID, MVEBU_GPIO1_BASE + 0x0c); + + /* Set GPP Out Enable */ + writel(N2350_GPP_OUT_ENA_LOW, MVEBU_GPIO0_BASE + 0x04); + writel(N2350_GPP_OUT_ENA_MID, MVEBU_GPIO1_BASE + 0x04); + + return 0; +} + +int board_init(void) +{ + /* Address of boot parameters */ + gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100; + + return 0; +} + +int board_eth_init(struct bd_info *bis) +{ + cpu_eth_init(bis); /* Built in controller(s) come first */ + return pci_eth_init(bis); +} diff --git a/configs/n2350_defconfig b/configs/n2350_defconfig new file mode 100644 index 0000000000..dcb2c96791 --- /dev/null +++ b/configs/n2350_defconfig @@ -0,0 +1,93 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_SYS_THUMB_BUILD=y +CONFIG_ARCH_MVEBU=y +CONFIG_SUPPORT_PASSING_ATAGS=y +CONFIG_CMDLINE_TAG=y +CONFIG_INITRD_TAG=y +CONFIG_TEXT_BASE=0x00800000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xff0000 +CONFIG_TARGET_N2350=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_DEFAULT_DEVICE_TREE="armada-385-thecus-n2350" +CONFIG_SPL_TEXT_BASE=0x40000030 +CONFIG_SYS_PROMPT="N2350 > " +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK=0x4002c000 +CONFIG_SPL=y +CONFIG_DEBUG_UART_BASE=0xf1012000 +CONFIG_DEBUG_UART_CLOCK=250000000 +CONFIG_IDENT_STRING="\nThecus N2350" +CONFIG_SYS_LOAD_ADDR=0x800000 +CONFIG_ENV_ADDR=0x100000 +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_PREBOOT=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x22fd0 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x40023000 +CONFIG_SPL_BSS_MAX_SIZE=0x4000 +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_I2C=y +CONFIG_SYS_MAXARGS=32 +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPIO_READ=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDPARTS_DEFAULT="mtdparts=pxa3xx_nand-0:-(rootfs);spi1.0:1M(u-boot),64K@1M(u-boot-env),-(data)" +CONFIG_ENV_OVERWRITE=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_VERSION_VARIABLE=y +CONFIG_ARP_TIMEOUT=200 +CONFIG_NET_RETRY_COUNT=50 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_AHCI_MVEBU=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_MTD=y +CONFIG_SF_DEFAULT_SPEED=50000000 +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHY_MARVELL=y +CONFIG_PHY_GIGE=y +CONFIG_MVNETA=y +CONFIG_MII=y +CONFIG_MVMDIO=y +CONFIG_PCI=y +CONFIG_PCI_MVEBU=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_ARMADA_38X=y +CONFIG_DM_RTC=y +CONFIG_RTC_ARMADA38X=y +CONFIG_SCSI=y +CONFIG_SPL_DEBUG_UART_BASE=0xd0012000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550=y +CONFIG_KIRKWOOD_SPI=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y diff --git a/include/configs/n2350.h b/include/configs/n2350.h new file mode 100644 index 0000000000..92b2270236 --- /dev/null +++ b/include/configs/n2350.h @@ -0,0 +1,56 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2023 Tony Dinh mibodhi@gmail.com + * + */ + +#ifndef _CONFIG_N2350_H +#define _CONFIG_N2350_H + +#define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */ + +/* Keep device tree and initrd in lower memory so the kernel can access them */ +#define RELOCATION_LIMITS_ENV_SETTINGS \ + "fdt_high=0x10000000\0" \ + "initrd_high=0x10000000\0" + +/* + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ +#include "mv-common.h" + +/* Include the common distro boot environment */ +#ifndef CONFIG_SPL_BUILD + +#define BOOT_TARGET_DEVICES(func) \ + func(SCSI, scsi, 0) \ + func(USB, usb, 0) \ + func(PXE, pxe, na) \ + func(DHCP, dhcp, na) + +#define KERNEL_ADDR_R __stringify(0x1000000) +#define FDT_ADDR_R __stringify(0x2000000) +#define RAMDISK_ADDR_R __stringify(0x2200000) +#define SCRIPT_ADDR_R __stringify(0x1800000) +#define PXEFILE_ADDR_R __stringify(0x1900000) + +#define LOAD_ADDRESS_ENV_SETTINGS \ + "kernel_addr_r=" KERNEL_ADDR_R "\0" \ + "fdt_addr_r=" FDT_ADDR_R "\0" \ + "ramdisk_addr_r=" RAMDISK_ADDR_R "\0" \ + "scriptaddr=" SCRIPT_ADDR_R "\0" \ + "pxefile_addr_r=" PXEFILE_ADDR_R "\0" + +#include <config_distro_bootcmd.h> + +#define CFG_EXTRA_ENV_SETTINGS \ + RELOCATION_LIMITS_ENV_SETTINGS \ + LOAD_ADDRESS_ENV_SETTINGS \ + "fdtfile=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ + "console=ttyS0,115200\0" \ + BOOTENV + +#endif /* CONFIG_SPL_BUILD */ + +#endif /* _CONFIG_N2350_H */
Specification:
- 1 GiB DDR4 RAM
- I2C
- 2x USB 3.0
- 3x buttons
- 10x LEDS
- serial console
Thanks, Stefan
Changes in v3:
Changes in v2:
- armada-385-thecus-n2350.dtb \ armada-385-turris-omnia.dtb \ armada-388-clearfog.dtb \ armada-388-gp.dtb \
- Device Tree file for Thecus N2350 board
- Copyright (C) 2018-2023 Tony Dinh mibodhi@gmail.com
- Copyright (C) 2018 Manuel Jung manuel.jung@hotmail.com
- model = "Thecus N2350";
- compatible = "thecus,n2350", "marvell,armada385";
- aliases {
ethernet0 = ð0;
- chosen {
- memory {
- soc {
- usb3_0_phy: usb3_0_phy {
- usb3_1_phy: usb3_1_phy {
- gpio-keys {
#size-cells = <0>;
button@1 {
button@2 {
button@3 {
- gpio-leds {
&pmx_sata1_red_led
&pmx_sata2_red_led
&pmx_sys_white_led
&pmx_sys_red_led
&pmx_pwr_blue_led
&pmx_pwr_red_led
&pmx_usb_white_led
&pmx_usb_red_led>;
white_sata1 {
red_sata1 {
white-sata2 {
red-sata2 {
white-sys {
red-sys {
blue-pwr {
red-pwr {
white-usb {
red-usb {
- regulators {
#size-cells = <0>;
reg = <1>;
enable-active-high;
regulator-boot-on;
reg = <1>;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
- gpio-poweroff {
+&ahci0 {
- status = "okay";
+&bm {
- status = "okay";
+&bm_bppi {
- status = "okay";
+ð0 {
- status = "okay";
- phy = <&phy0>;
- phy-mode = "sgmii";
- buffer-manager = <&bm>;
- bm,pool-long = <0>;
- bm,pool-short = <1>;
+&i2c0 {
- status = "okay";
- clock-frequency = <100000>;
+&i2c1 {
- status = "okay";
+&mdio {
- phy0: ethernet-phy@0 {
reg = <1>;
+&nand_controller {
- status = "okay";
- nand@0 {
status = "okay";
reg = <0>;
nand-rb = <0>;
nand-on-flash-bbt;
partitions {
#size-cells = <1>;
partition@0 {
label = "rootfs";
+&pciec {
- status = "okay";
- pcie@1,0 {
status = "okay";
- pcie@2,0 {
status = "okay";
+&pinctrl {
- pinctrl-names = "default";
- pmx_power_button: pmx-power-button {
- pmx_copy_button: pmx-copy-button {
- pmx_reset_button: pmx-reset-button {
- pmx_sata1_white_led: pmx-sata1-white-led {
- pmx_sata1_red_led: pmx-sata1-red-led {
- pmx_sata2_white_led: pmx-sata2-white-led {
- pmx_sata2_red_led: pmx-sata2-red-led {
- pmx_sys_white_led: pmx-sys-white-led {
- pmx_sys_red_led: pmx-sys-red-led {
- pmx_buzzer: pmx-buzzer {
- pmx_pwr_off: pmx-pwr-off {
- pmx_pwr_blue_led: pmx-pwr-blue-led {
- pmx_pwr_red_led: pmx-pwr-red-led {
- pmx_usb_white_led: pmx-usb-white-led {
- pmx_usb_red_led: pmx-usb-red-led {
+&sdhci {
- broken-cd;
- wp-inverted;
- bus-width = <8>;
- status = "okay";
- no-1-8-v;
+&spi1 {
- pinctrl-0 = <&spi1_pins>;
- status = "okay";
- /* spi: 4M Flash Macronix MX25L3205D */
- spi-flash@0 {
#size-cells = <0>;
reg = <0>;
spi-cpha;
partition@0 {
label = "u-boot";
partition@100000 {
+&uart0 {
- status = "okay";
+&usb0 {
- status = "okay";
+&usb3_0 {
- status = "okay";
+&usb3_1 {
- status = "okay";
+config DDR4
- bool "Support Marvell DDR4 Training driver"
- choice prompt "Armada XP/375/38x/3700/7K/8K/Alleycat-5 board select" optional
- bool "Support Thecus N2350"
- select 88F6820
- select DDR4
- config TARGET_THEADORABLE bool "Support theadorable Armada XP" select BOARD_LATE_INIT if USB
- default "n2350" if TARGET_N2350 default "theadorable" if TARGET_THEADORABLE default "a38x" if TARGET_CONTROLCENTERDC default "x530" if TARGET_X530
- default "n2350" if TARGET_N2350 default "theadorable" if TARGET_THEADORABLE default "turris_omnia" if TARGET_TURRIS_OMNIA default "turris_mox" if TARGET_TURRIS_MOX
- default "thecus" if TARGET_N2350 default "CZ.NIC" if TARGET_TURRIS_OMNIA default "CZ.NIC" if TARGET_TURRIS_MOX default "gdsys" if TARGET_CONTROLCENTERDC
- Copyright (C) 2023 Tony Dinh mibodhi@gmail.com
- Those N2350_GPP_xx values and defines in board_serdes_map, and board_topology_map
- are taken from the Marvell U-Boot version "u-boot-a38x-2015T1_p18_Thecus"
- { SGMII0, SERDES_SPEED_1_25_GBPS, SERDES_DEFAULT_MODE, 0, 0},
- { SATA0, SERDES_SPEED_3_GBPS, SERDES_DEFAULT_MODE, 0, 0},
- { SATA1, SERDES_SPEED_3_GBPS, SERDES_DEFAULT_MODE, 0, 0},
- { DEFAULT_SERDES, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0},
- { USB3_HOST0, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0},
- { USB3_HOST1, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0},
- *serdes_map_array = board_serdes_map;
- *count = ARRAY_SIZE(board_serdes_map);
- Define the DDR layout / topology here in the board file. This will
- be used by the DDR4 init code in the SPL U-Boot version to configure
- the DDR4 controller.
- DEBUG_LEVEL_ERROR,
- 0x1, /* active interfaces */
- /* cs_mask, mirror, dqs_swap, ck_swap X PUPs */
- { { { {0x1, 0, 0, 0},
{0x1, 0, 0, 0},
{0x1, 0, 0, 0},
{0x1, 0, 0, 0},
{0x1, 0, 0, 0} },
- BUS_MASK_32BIT, /* Busses mask */
- MV_DDR_CFG_DEFAULT, /* ddr configuration data source */
- NOT_COMBINED, /* ddr twin-die combined */
- { {0} }, /* raw spd data */
- {0} /* timing parameters */
- /* Return the board topology as defined in the board code */
- return &board_topology_map;
- /* Those MPP values are taken from the Marvell U-Boot version
- /* Configure MPP */
- writel(0x50111111, MVEBU_MPP_BASE + 0x00); /* MPP0_7 */
- writel(0x00555555, MVEBU_MPP_BASE + 0x04); /* MPP8_15 */
- writel(0x55000000, MVEBU_MPP_BASE + 0x08); /* MPP16_23 */
- writel(0x05050050, MVEBU_MPP_BASE + 0x0c); /* MPP24_31 */
- writel(0x05555555, MVEBU_MPP_BASE + 0x10); /* MPP32_39 */
- writel(0x00000565, MVEBU_MPP_BASE + 0x14); /* MPP40_47 */
- writel(0x00000000, MVEBU_MPP_BASE + 0x18); /* MPP48_55 */
- writel(0x00004444, MVEBU_MPP_BASE + 0x1c); /* MPP56_63 */
- /* Set GPP Out value */
- writel(N2350_GPP_OUT_VAL_LOW, MVEBU_GPIO0_BASE + 0x00);
- writel(N2350_GPP_OUT_VAL_MID, MVEBU_GPIO1_BASE + 0x00);
- /* Set GPP Polarity */
- writel(N2350_GPP_POL_LOW, MVEBU_GPIO0_BASE + 0x0c);
- writel(N2350_GPP_POL_MID, MVEBU_GPIO1_BASE + 0x0c);
- /* Set GPP Out Enable */
- writel(N2350_GPP_OUT_ENA_LOW, MVEBU_GPIO0_BASE + 0x04);
- writel(N2350_GPP_OUT_ENA_MID, MVEBU_GPIO1_BASE + 0x04);
- /* Address of boot parameters */
- gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100;
- cpu_eth_init(bis); /* Built in controller(s) come first */
- return pci_eth_init(bis);
- "fdt_high=0x10000000\0" \
- "initrd_high=0x10000000\0"
- mv-common.h should be defined after CMD configs since it used them
- to enable certain macros
- func(SCSI, scsi, 0) \
- func(USB, usb, 0) \
- func(PXE, pxe, na) \
- func(DHCP, dhcp, na)
- "kernel_addr_r=" KERNEL_ADDR_R "\0" \
- "fdt_addr_r=" FDT_ADDR_R "\0" \
- "ramdisk_addr_r=" RAMDISK_ADDR_R "\0" \
- "scriptaddr=" SCRIPT_ADDR_R "\0" \
- "pxefile_addr_r=" PXEFILE_ADDR_R "\0"
- RELOCATION_LIMITS_ENV_SETTINGS \
- LOAD_ADDRESS_ENV_SETTINGS \
- "fdtfile=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \
- "console=ttyS0,115200\0" \
- BOOTENV
Viele Grüße, Stefan Roese
Specification:
- 1 GiB DDR4 RAM
- I2C
- 2x USB 3.0
- 3x buttons
- 10x LEDS
- serial console
Applied to u-boot-marvell/master
Thanks, Stefan
Changes in v3:
Changes in v2:
- aliases {
ethernet0 = ð0;
- chosen {
- memory {
- soc {
- gpio-keys {
#size-cells = <0>;
button@1 {
button@2 {
button@3 {
- gpio-leds {
&pmx_sata1_red_led
&pmx_sata2_red_led
&pmx_sys_white_led
&pmx_sys_red_led
&pmx_pwr_blue_led
&pmx_pwr_red_led
&pmx_usb_white_led
&pmx_usb_red_led>;
white_sata1 {
red_sata1 {
white-sata2 {
red-sata2 {
white-sys {
red-sys {
blue-pwr {
red-pwr {
white-usb {
red-usb {
- regulators {
#size-cells = <0>;
reg = <1>;
enable-active-high;
regulator-boot-on;
reg = <1>;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
- gpio-poweroff {
+&ahci0 {
- status = "okay";
+&bm {
- status = "okay";
+&bm_bppi {
- status = "okay";
+ð0 {
- status = "okay";
- phy = <&phy0>;
+&i2c0 {
- status = "okay";
+&i2c1 {
- status = "okay";
+&mdio {
reg = <1>;
+&nand_controller {
- status = "okay";
- nand@0 {
status = "okay";
reg = <0>;
nand-rb = <0>;
nand-on-flash-bbt;
partitions {
#size-cells = <1>;
partition@0 {
label = "rootfs";
+&pciec {
- status = "okay";
- pcie@1,0 {
status = "okay";
- pcie@2,0 {
status = "okay";
+&pinctrl {
+&sdhci {
- broken-cd;
- wp-inverted;
- bus-width = <8>;
- status = "okay";
- no-1-8-v;
+&spi1 {
- status = "okay";
- spi-flash@0 {
#size-cells = <0>;
reg = <0>;
spi-cpha;
partition@0 {
label = "u-boot";
partition@100000 {
+&uart0 {
- status = "okay";
+&usb0 {
- status = "okay";
+&usb3_0 {
- status = "okay";
+&usb3_1 {
- status = "okay";
+config DDR4
- select 88F6820
- select DDR4
{0x1, 0, 0, 0},
{0x1, 0, 0, 0},
{0x1, 0, 0, 0},
{0x1, 0, 0, 0} },
- BOOTENV
Stefan Roese
Tony Dinh
