[PATCH v3 1/3] clk: imx8mm: Add support for PCIe clocks
Add support for PCIe clocks required to enable PCIe support on iMX8MM SoC.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- v3: wrap pcie clk config around IS_ENABLED to avoid SPL growth as suggested by Marek --- drivers/clk/imx/clk-imx8mm.c | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+)
diff --git a/drivers/clk/imx/clk-imx8mm.c b/drivers/clk/imx/clk-imx8mm.c index b5c253e49663..1a00dd1d287b 100644 --- a/drivers/clk/imx/clk-imx8mm.c +++ b/drivers/clk/imx/clk-imx8mm.c @@ -66,6 +66,17 @@ static const char *imx8mm_i2c3_sels[] = {"clock-osc-24m", "sys_pll1_160m", "sys_ static const char *imx8mm_i2c4_sels[] = {"clock-osc-24m", "sys_pll1_160m", "sys_pll2_50m", "sys_pll3_out", "audio_pll1_out", "video_pll1_out", "audio_pll2_out", "sys_pll1_133m", };
+#if CONFIG_IS_ENABLED(PCIE_DW_IMX) +static const char *imx8mm_pcie1_ctrl_sels[] = {"clock-osc-24m", "sys_pll2_250m", "sys_pll2_200m", "sys_pll1_266m", + "sys_pll1_800m", "sys_pll2_500m", "sys_pll2_333m", "sys_pll3_out", }; + +static const char *imx8mm_pcie1_phy_sels[] = {"clock-osc-24m", "sys_pll2_100m", "sys_pll2_500m", "clk_ext1", "clk_ext2", + "clk_ext3", "clk_ext4", "sys_pll1_400m", }; + +static const char *imx8mm_pcie1_aux_sels[] = {"clock-osc-24m", "sys_pll2_200m", "sys_pll2_50m", "sys_pll3_out", + "sys_pll2_100m", "sys_pll1_80m", "sys_pll1_160m", "sys_pll1_200m", }; +#endif + #ifndef CONFIG_SPL_BUILD static const char *imx8mm_pwm1_sels[] = {"clock-osc-24m", "sys_pll2_100m", "sys_pll1_160m", "sys_pll1_40m", "sys_pll3_out", "clk_ext1", "sys_pll1_80m", "video_pll1_out", }; @@ -256,6 +267,17 @@ static int imx8mm_clk_probe(struct udevice *dev) imx8m_clk_composite("usb_bus", imx8mm_usb_bus_sels, base + 0x8b80));
/* IP */ +#if CONFIG_IS_ENABLED(PCIE_DW_IMX) + clk_dm(IMX8MM_CLK_PCIE1_CTRL, + imx8m_clk_composite("pcie1_ctrl", imx8mm_pcie1_ctrl_sels, + base + 0xa300)); + clk_dm(IMX8MM_CLK_PCIE1_PHY, + imx8m_clk_composite("pcie1_phy", imx8mm_pcie1_phy_sels, + base + 0xa380)); + clk_dm(IMX8MM_CLK_PCIE1_AUX, + imx8m_clk_composite("pcie1_aux", imx8mm_pcie1_aux_sels, + base + 0xa400)); +#endif clk_dm(IMX8MM_CLK_USDHC1, imx8m_clk_composite("usdhc1", imx8mm_usdhc1_sels, base + 0xac00)); @@ -339,6 +361,11 @@ static int imx8mm_clk_probe(struct udevice *dev) imx_clk_gate4("pwm4_root_clk", "pwm4", base + 0x42b0, 0)); #endif
+#if CONFIG_IS_ENABLED(PCIE_DW_IMX) + clk_dm(IMX8MM_CLK_PCIE1_ROOT, + imx_clk_gate4("pcie1_root_clk", "pcie1_ctrl", base + 0x4250, 0)); +#endif + #if CONFIG_IS_ENABLED(DM_SPI) clk_dm(IMX8MM_CLK_ECSPI1, imx8m_clk_composite("ecspi1", imx8mm_ecspi1_sels, base + 0xb280));
Add support for the IMX8MM SoC by adding driver data with the compatible string of the GPR controller.
Reviewed-by: Marek Vasut marex@denx.de Signed-off-by: Tim Harvey tharvey@gateworks.com --- v3: collected tags v2: do not cache chip info in priv per Marek's suggestion --- drivers/pci/pcie_dw_imx.c | 18 ++++++++++++++++-- 1 file changed, 16 insertions(+), 2 deletions(-)
diff --git a/drivers/pci/pcie_dw_imx.c b/drivers/pci/pcie_dw_imx.c index a2ee228224b5..fdb463710ba1 100644 --- a/drivers/pci/pcie_dw_imx.c +++ b/drivers/pci/pcie_dw_imx.c @@ -56,6 +56,18 @@ struct pcie_dw_imx { struct udevice *vpcie; };
+struct pcie_chip_info { + const char *gpr; +}; + +static const struct pcie_chip_info imx8mm_chip_info = { + .gpr = "fsl,imx8mm-iomuxc-gpr", +}; + +static const struct pcie_chip_info imx8mp_chip_info = { + .gpr = "fsl,imx8mp-iomuxc-gpr", +}; + static void pcie_dw_configure(struct pcie_dw_imx *priv, u32 cap_speed) { dw_pcie_dbi_write_enable(&priv->dw, true); @@ -242,6 +254,7 @@ static int pcie_dw_imx_remove(struct udevice *dev)
static int pcie_dw_imx_of_to_plat(struct udevice *dev) { + struct pcie_chip_info *info = (void *)dev_get_driver_data(dev); struct pcie_dw_imx *priv = dev_get_priv(dev); ofnode gpr; int ret; @@ -287,7 +300,7 @@ static int pcie_dw_imx_of_to_plat(struct udevice *dev) goto err_phy; }
- gpr = ofnode_by_compatible(ofnode_null(), "fsl,imx8mp-iomuxc-gpr"); + gpr = ofnode_by_compatible(ofnode_null(), info->gpr); if (ofnode_equal(gpr, ofnode_null())) { dev_err(dev, "unable to find GPR node\n"); ret = -ENODEV; @@ -322,7 +335,8 @@ static const struct dm_pci_ops pcie_dw_imx_ops = { };
static const struct udevice_id pcie_dw_imx_ids[] = { - { .compatible = "fsl,imx8mp-pcie" }, + { .compatible = "fsl,imx8mm-pcie", .data = (ulong)&imx8mm_chip_info, }, + { .compatible = "fsl,imx8mp-pcie", .data = (ulong)&imx8mp_chip_info, }, { } };
Enable PCIe/NVMe support. Also, enable the reset driver which is a prerequisite for PCIe support.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- v3: no changes v2: no changes --- configs/imx8mm_venice_defconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/configs/imx8mm_venice_defconfig b/configs/imx8mm_venice_defconfig index 517b70b69477..0f97b4b84243 100644 --- a/configs/imx8mm_venice_defconfig +++ b/configs/imx8mm_venice_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="freescale/imx8mm-venice-gw71xx-0x" CONFIG_SPL_TEXT_BASE=0x7E1000 CONFIG_TARGET_IMX8MM_VENICE=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_DM_RESET=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y @@ -20,6 +21,7 @@ CONFIG_SPL_STACK=0x920000 CONFIG_SPL=y CONFIG_ENV_OFFSET_REDUND=0x3f8000 CONFIG_SYS_LOAD_ADDR=0x48200000 +CONFIG_PCI=y CONFIG_SYS_MEMTEST_START=0x40000000 CONFIG_SYS_MEMTEST_END=0x80000000 CONFIG_FIT=y @@ -60,6 +62,7 @@ CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_DHCP6=y @@ -120,6 +123,9 @@ CONFIG_PHY_GIGE=y CONFIG_FEC_MXC=y CONFIG_KSZ9477=y CONFIG_MII=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_IMX=y +CONFIG_PHY_IMX8M_PCIE=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_IMX8M=y
Applied all, thanks.
Hi Tim,
Although I was at EOSS last week, it is really nice to see more iMX SoCs adopting the modern PCIe DW iMX driver.
-Sumit
/* IP */
base + 0xa300));
base + 0xa380));
base + 0xa400));
#if CONFIG_IS_ENABLED(DM_SPI) clk_dm(IMX8MM_CLK_ECSPI1, imx8m_clk_composite("ecspi1", imx8mm_ecspi1_sels, base + 0xb280)); -- 2.25.1
Fabio Estevam
Sumit Garg
Tim Harvey
